[geos-commits] r3257 - in trunk: . include/geos/geom
include/geos/util src/geom
svn_geos at osgeo.org
Wed Mar 2 07:46:57 EST 2011
Author: strk
Date: 2011-03-02 04:46:57 -0800 (Wed, 02 Mar 2011)
New Revision: 3257
Added:
trunk/include/geos/util/IllegalStateException.h
trunk/NEWS
trunk/include/geos/geom/LineSegment.h
trunk/include/geos/geom/LineSegment.inl
trunk/include/geos/util/Makefile.am
trunk/src/geom/LineSegment.cpp
Added check for illegal state in offsetPoint method
Modified: trunk/NEWS
--- trunk/NEWS 2011-03-02 09:24:02 UTC (rev 3256)
+++ trunk/NEWS 2011-03-02 12:46:57 UTC (rev 3257)
@@ -37,6 +37,7 @@
- Fix NodedSegmentString to handle zero-length line segments correctly
(via safeOctant)
- Fixed buffer OffsetCurveSetBuilder to handle "flat" rings correctly
+ - Added illegal state check in LineSegment::pointAlongOffset()
Changes in 3.2.0
2009-12-14
Modified: trunk/include/geos/geom/LineSegment.h
--- trunk/include/geos/geom/LineSegment.h 2011-03-02 09:24:02 UTC (rev 3256)
+++ trunk/include/geos/geom/LineSegment.h 2011-03-02 12:46:57 UTC (rev 3257)
@@ -4,8 +4,9 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
- * Copyright (C) 2009 Sandro Santilli <strk at keybit.net>
- * Copyright (C) 2006 Refractions Research Inc.
+ * Copyright (C) 2009 2011 Sandro Santilli <strk at keybit.net>
+ * Copyright (C) 2005-2006 Refractions Research Inc.
+ * Copyright (C) 2001-2002 Vivid Solutions Inc.
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
@@ -14,7 +15,7 @@
- * Last port: geom/LineSegment.java rev. 1.30 (JTS-1.9)
+ * Last port: geom/LineSegment.java r18 (JTS-1.11)
@@ -211,6 +212,8 @@
* (positive is to the left, negative is to the right)
* @param ret will be set to the point at that distance and offset
+ * @throws IllegalStateException if the segment has zero length
void pointAlongOffset(double segmentLengthFraction,
double offsetDistance,
Modified: trunk/include/geos/geom/LineSegment.inl
--- trunk/include/geos/geom/LineSegment.inl 2011-03-02 09:24:02 UTC (rev 3256)
+++ trunk/include/geos/geom/LineSegment.inl 2011-03-02 12:46:57 UTC (rev 3257)
@@ -4,8 +4,9 @@
@@ -14,7 +15,7 @@
Added: trunk/include/geos/util/IllegalStateException.h
--- trunk/include/geos/util/IllegalStateException.h (rev 0)
+++ trunk/include/geos/util/IllegalStateException.h 2011-03-02 12:46:57 UTC (rev 3257)
@@ -0,0 +1,47 @@
+ * $Id$
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2011 Sandro Santilli <strk at keybit.net>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#ifndef GEOS_UTIL_ILLEGALSTATEEXCEPTION_H
+#define GEOS_UTIL_ILLEGALSTATEEXCEPTION_H
+#include <geos/export.h>
+#include <string>
+#include <geos/util/GEOSException.h>
+namespace geos {
+namespace util { // geos::util
+/// Indicates an illegal state
+class GEOS_DLL IllegalStateException: public GEOSException {
+public:
+ IllegalStateException()
+ GEOSException("IllegalStateException", "")
+ IllegalStateException(const std::string& msg)
+ GEOSException("IllegalStateException", msg)
+ ~IllegalStateException() throw() {};
+} // namespace geos::util
+#endif // GEOS_UTIL_ILLEGALSTATEEXCEPTION_H
Modified: trunk/include/geos/util/Makefile.am
--- trunk/include/geos/util/Makefile.am 2011-03-02 09:24:02 UTC (rev 3256)
+++ trunk/include/geos/util/Makefile.am 2011-03-02 12:46:57 UTC (rev 3257)
@@ -15,6 +15,7 @@
GeometricShapeFactory.h \
GEOSException.h \
IllegalArgumentException.h \
+ IllegalStateException.h \
math.h \
Machine.h \
TopologyException.h \
Modified: trunk/src/geom/LineSegment.cpp
--- trunk/src/geom/LineSegment.cpp 2011-03-02 09:24:02 UTC (rev 3256)
+++ trunk/src/geom/LineSegment.cpp 2011-03-02 12:46:57 UTC (rev 3257)
@@ -4,7 +4,7 @@
@@ -15,7 +15,7 @@
@@ -29,6 +29,7 @@
#include <geos/algorithm/LineIntersector.h>
#include <geos/algorithm/HCoordinate.h>
#include <geos/algorithm/NotRepresentableException.h>
+#include <geos/util/IllegalStateException.h>
#include <geos/profiler.h>
#include <geos/inline.h>
@@ -279,11 +280,20 @@
double dx = p1.x - p0.x;
double dy = p1.y - p0.y;
double len = sqrt(dx * dx + dy * dy);
- // u is the vector that is the length of the offset,
- // in the direction of the segment
- double ux = offsetDistance * dx / len;
- double uy = offsetDistance * dy / len;
+ double ux = 0.0;
+ double uy = 0.0;
+ if (offsetDistance != 0.0) {
+ if (len <= 0.0) {
+ throw util::IllegalStateException("Cannot compute offset from zero-length line segment");
+ // u is the vector that is the length of the offset,
+ // in the direction of the segment
+ ux = offsetDistance * dx / len;
+ uy = offsetDistance * dy / len;
// the offset point is the seg point plus the offset
// vector rotated 90 degrees CCW
double offsetx = segx - uy;
More information about the geos-commits
