[geos-commits] r3258 - in trunk: include/geos/operation/valid
src/operation/valid tests/xmltester/tests/general
svn_geos at osgeo.org
Wed Mar 2 08:13:50 EST 2011
Author: strk
Date: 2011-03-02 05:13:50 -0800 (Wed, 02 Mar 2011)
New Revision: 3258
trunk/include/geos/operation/valid/IsValidOp.h
trunk/src/operation/valid/IsValidOp.cpp
trunk/tests/xmltester/tests/general/TestValid.xml
Sync IsValidOp and related XML testcase to JTS-1.12
Modified: trunk/include/geos/operation/valid/IsValidOp.h
--- trunk/include/geos/operation/valid/IsValidOp.h 2011-03-02 12:46:57 UTC (rev 3257)
+++ trunk/include/geos/operation/valid/IsValidOp.h 2011-03-02 13:13:50 UTC (rev 3258)
@@ -15,7 +15,7 @@
- * Last port: operation/valid/IsValidOp.java rev. 38 (JTS-1.11+)
+ * Last port: operation/valid/IsValidOp.java r335 (JTS-1.12)
@@ -214,6 +214,14 @@
static bool isValid(const geom::Coordinate &coord);
+ * Tests whether a {@link Geometry} is valid.
+ * @param geom the Geometry to test
+ * @return true if the geometry is valid
+ static bool isValid(const geom::Geometry &geom);
IsValidOp(const geom::Geometry *geom)
parentGeometry(geom),
Modified: trunk/src/operation/valid/IsValidOp.cpp
--- trunk/src/operation/valid/IsValidOp.cpp 2011-03-02 12:46:57 UTC (rev 3257)
+++ trunk/src/operation/valid/IsValidOp.cpp 2011-03-02 13:13:50 UTC (rev 3258)
@@ -16,7 +16,7 @@
@@ -90,14 +90,7 @@
return validErr==NULL;
- * Checks whether a coordinate is valid for processing.
- * Coordinates are valid iff their x and y coordinates are in the
- * range of the floating point representation.
- * @param coord the coordinate to validate
- * @return <code>true</code> if the coordinate is valid
+/* static public */
bool
IsValidOp::isValid(const Coordinate &coord)
@@ -106,6 +99,14 @@
return true;
+bool
+IsValidOp::isValid(const Geometry &g)
+ IsValidOp op(&g);
+ return op.isValid();
TopologyValidationError *
IsValidOp::getValidationError()
Modified: trunk/tests/xmltester/tests/general/TestValid.xml
--- trunk/tests/xmltester/tests/general/TestValid.xml 2011-03-02 12:46:57 UTC (rev 3257)
+++ trunk/tests/xmltester/tests/general/TestValid.xml 2011-03-02 13:13:50 UTC (rev 3258)
@@ -22,17 +22,37 @@
<a>
POINT(10 10)
</a>
- <test>
- <op name="isValid" arg1="A">
- true
- </op>
- </test>
+ <test> <op name="isValid" arg1="A"> true </op> </test>
</case>
<case>
+ <desc>P - empty point</desc>
+ <a>
+ POINT EMPTY
+ </a>
+ </case>
+ <case>
+ <desc>P - point with invalid X ordinate</desc>
+ <a>
+ POINT(NaN 10)
+ </a>
+ <test> <op name="isValid" arg1="A"> false </op> </test>
+ </case>
+ <case>
+ <desc>P - point with invalid Y ordinate</desc>
+ <a>
+ POINT(10 NaN)
+ </a>
+ </case>
+ <case>
<desc>mP - no repeated points</desc>
<a>
- MULTIPOINT(10 10, 20 20, 30 30)
+ MULTIPOINT((10 10), (20 20), (30 30))
</a>
<test>
@@ -42,7 +62,7 @@
<case>
<desc>P - repeated points</desc>
<a>
- MULTIPOINT(10 10, 20 20, 30 30, 10 10)
+ MULTIPOINT((10 10), (20 20), (30 30), (10 10))
</a>
<test>
@@ -60,6 +80,16 @@
</case>
<case>
+ <desc>L - invalid ordinate</desc>
+ <a>
+LINESTRING (40 180, 120 120, 140 200, 200 140, NaN 200)
+ </a>
+ <test>
+ <op name="isValid" arg1="A"> false </op>
+ </test>
+ </case>
+ <case>
<desc>L - repeated points</desc>
<a>
LINESTRING (40 180, 120 120, 140 200, 140 200, 200 140, 240 200)
@@ -76,6 +106,14 @@
</test>
</case>
+ <case>
+ <desc>mL - MultiLinestring with two identical points in first component</desc>
+ <a>MULTILINESTRING((1 1, 0 0), (0 0, 0 0))</a>
+ <test>
+ </test>
+ </case>
<case>
<desc>mL - MultiLinestring with two identical points in second component</desc>
@@ -102,6 +140,14 @@
</case>
<case>
+ <desc>A - polygon with invalid point </desc>
+ <a>POLYGON ((0 0, 10 NaN, 20 0, 0 10, 0 0))</a>
+ <test>
+ </test>
+ </case>
+ <case>
<desc>A - polygon with repeated point </desc>
<a>POLYGON ((107 246, 107 246, 250 285, 294 137, 151 90, 15 125, 157 174, 107 246))</a>
<test>
More information about the geos-commits
