[geos-commits] r3259 - in trunk: include/geos/operation/distance
src/operation/distance
svn_geos at osgeo.org
Wed Mar 2 08:45:13 EST 2011
Author: strk
Date: 2011-03-02 05:45:13 -0800 (Wed, 02 Mar 2011)
New Revision: 3259
trunk/include/geos/operation/distance/DistanceOp.h
trunk/src/operation/distance/DistanceOp.cpp
Fixed Geometry.distance() and DistanceOp to return 0.0 for empty inputs (JTS-1.11)
Modified: trunk/include/geos/operation/distance/DistanceOp.h
--- trunk/include/geos/operation/distance/DistanceOp.h 2011-03-02 13:13:50 UTC (rev 3258)
+++ trunk/include/geos/operation/distance/DistanceOp.h 2011-03-02 13:45:13 UTC (rev 3259)
@@ -4,6 +4,7 @@
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
+ * Copyright (C) 2011 Sandro Santilli <strk at keybit.net>
* Copyright (C) 2006 Refractions Research Inc.
* This is free software; you can redistribute and/or modify it under
@@ -13,7 +14,7 @@
- * Last port: operation/distance/DistanceOp.java rev 1.21 (JTS-1.10)
+ * Last port: operation/distance/DistanceOp.java r335 (JTS-1.12-)
@@ -80,6 +81,8 @@
* @param g0 a {@link Geometry}
* @param g1 another {@link Geometry}
* @return the distance between the geometries
+ * @return 0 if either input geometry is empty
+ * @throws IllegalArgumentException if either input geometry is null
static double distance(const geom::Geometry& g0,
const geom::Geometry& g1);
Modified: trunk/src/operation/distance/DistanceOp.cpp
--- trunk/src/operation/distance/DistanceOp.cpp 2011-03-02 13:13:50 UTC (rev 3258)
+++ trunk/src/operation/distance/DistanceOp.cpp 2011-03-02 13:45:13 UTC (rev 3259)
@@ -4,6 +4,7 @@
* Copyright (C) 2001-2002 Vivid Solutions Inc.
@@ -14,7 +15,7 @@
@@ -34,6 +35,7 @@
#include <geos/geom/util/PolygonExtracter.h>
#include <geos/geom/util/LinearComponentExtracter.h>
#include <geos/geom/util/PointExtracter.h>
+#include <geos/util/IllegalArgumentException.h>
#include <vector>
#include <iostream>
@@ -138,6 +140,11 @@
double
DistanceOp::distance()
+ using geos::util::IllegalArgumentException;
+ if ( geom[0] == 0 || geom[1] == 0 )
+ throw IllegalArgumentException("null geometries are not supported");
+ if ( geom[0]->isEmpty() || geom[1]->isEmpty() ) return 0.0;
computeMinDistance();
return minDistance;
More information about the geos-commits
