[geos-commits] r3356 - in trunk: include/geos/index/chain
src/index/chain
svn_geos at osgeo.org
Thu May 12 03:14:50 EDT 2011
Author: strk
Date: 2011-05-12 00:14:50 -0700 (Thu, 12 May 2011)
New Revision: 3356
trunk/include/geos/index/chain/MonotoneChainBuilder.h
trunk/src/index/chain/MonotoneChainBuilder.cpp
Port info for MonotoneChainBuilder
Modified: trunk/include/geos/index/chain/MonotoneChainBuilder.h
--- trunk/include/geos/index/chain/MonotoneChainBuilder.h 2011-05-12 06:20:11 UTC (rev 3355)
+++ trunk/include/geos/index/chain/MonotoneChainBuilder.h 2011-05-12 07:14:50 UTC (rev 3356)
@@ -1,5 +1,4 @@
- * $Id$
* GEOS - Geometry Engine Open Source
* http://geos.refractions.net
@@ -13,7 +12,7 @@
- * Last port: index/chain/MonotoneChainBuilder.java rev 1.12 (JTS-1.10)
+ * Last port: index/chain/MonotoneChainBuilder.java r388 (JTS-1.12)
@@ -108,10 +107,3 @@
#endif // GEOS_IDX_CHAIN_MONOTONECHAINBUILDER_H
- * $Log$
- * Revision 1.1 2006/03/22 18:12:31 strk
- * indexChain.h header split.
Modified: trunk/src/index/chain/MonotoneChainBuilder.cpp
--- trunk/src/index/chain/MonotoneChainBuilder.cpp 2011-05-12 06:20:11 UTC (rev 3355)
+++ trunk/src/index/chain/MonotoneChainBuilder.cpp 2011-05-12 07:14:50 UTC (rev 3356)
@@ -1,5 +1,4 @@
- * $Id$
@@ -13,7 +12,7 @@
@@ -143,16 +142,3 @@
} // namespace geos.index
} // namespace geos
- * $Log$
- * Revision 1.25 2006/06/12 11:29:23 strk
- * unsigned int => size_t
- * Revision 1.24 2006/03/23 13:31:58 strk
- * Fixed to allow build with GEOS_DEBUG
- * Revision 1.23 2006/03/22 18:12:32 strk
More information about the geos-commits
