[geos-commits] r3357 - in trunk: include/geos/noding src/noding
svn_geos at osgeo.org
Thu May 12 03:18:07 EDT 2011
Author: strk
Date: 2011-05-12 00:18:07 -0700 (Thu, 12 May 2011)
New Revision: 3357
trunk/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
trunk/src/noding/MCIndexSegmentSetMutualIntersector.cpp
Don't let MCIndexSegmentSetMutualIntersector grow in memory on every new ::process call. Fixes bug #342.
Modified: trunk/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
--- trunk/include/geos/noding/MCIndexSegmentSetMutualIntersector.h 2011-05-12 07:14:50 UTC (rev 3356)
+++ trunk/include/geos/noding/MCIndexSegmentSetMutualIntersector.h 2011-05-12 07:18:07 UTC (rev 3357)
@@ -59,6 +59,10 @@
~MCIndexSegmentSetMutualIntersector();
+ /* Returns a reference to a vector of MonotoneChain objects owned
+ * by this class and destroyed on next call to ::process.
+ * Copy them if you need them alive for longer.
std::vector<index::chain::MonotoneChain *>& getMonotoneChains()
return monoChains;
@@ -71,6 +75,7 @@
void setBaseSegments(SegmentString::ConstVect* segStrings);
+ // NOTE: re-populates the MonotoneChain vector with newly created chains
void process(SegmentString::ConstVect* segStrings);
class SegmentOverlapAction : public index::chain::MonotoneChainOverlapAction
@@ -107,9 +112,10 @@
// statistics
int nOverlaps;
- // memory management helper
- typedef std::vector<std::vector<index::chain::MonotoneChain*>*> chainstore_mm_type;
- chainstore_mm_type chainStore;
+ /* memory management helper, holds MonotoneChain objects used
+ * in the SpatialIndex. It's cleared when the SpatialIndex is
+ MonoChains chainStore;
void addToIndex( SegmentString * segStr);
Modified: trunk/src/noding/MCIndexSegmentSetMutualIntersector.cpp
--- trunk/src/noding/MCIndexSegmentSetMutualIntersector.cpp 2011-05-12 07:14:50 UTC (rev 3356)
+++ trunk/src/noding/MCIndexSegmentSetMutualIntersector.cpp 2011-05-12 07:18:07 UTC (rev 3357)
@@ -39,16 +39,16 @@
void
MCIndexSegmentSetMutualIntersector::addToIndex(SegmentString* segStr)
- std::vector<MonotoneChain*>* segChains = 0;
- segChains = MonotoneChainBuilder::getChains(segStr->getCoordinates(), segStr);
+ std::vector<MonotoneChain*> segChains;
+ MonotoneChainBuilder::getChains(segStr->getCoordinates(),
+ segStr, segChains);
- chainStore.push_back(segChains);
- for (std::size_t i = 0, n = segChains->size(); i < n; i++)
+ for (std::size_t i = 0, n = segChains.size(); i < n; i++)
- MonotoneChain * mc = (*segChains)[i];
+ MonotoneChain * mc = segChains[i];
mc->setId(indexCounter++);
index->insert(&(mc->getEnvelope()), mc);
+ chainStore.push_back(mc);
@@ -76,17 +76,17 @@
+/*private*/
void
MCIndexSegmentSetMutualIntersector::addToMonoChains(SegmentString* segStr)
- MonoChains* segChains =
- MonotoneChainBuilder::getChains(segStr->getCoordinates(), segStr);
+ MonoChains segChains;
- for (MonoChains::size_type i = 0, ni = segChains->size(); i < ni; i++)
+ for (MonoChains::size_type i = 0, ni = segChains.size(); i < ni; i++)
- MonotoneChain* mc = (*segChains)[i];
+ MonotoneChain* mc = segChains[i];
mc->setId( processCounter++ );
monoChains.push_back(mc);
@@ -109,17 +109,17 @@
delete index;
- chainstore_mm_type::iterator end = chainStore.end();
- for (chainstore_mm_type::iterator it = chainStore.begin(); it != end; ++it)
+ for (MonoChains::iterator it = chainStore.begin(), end = chainStore.end();
+ it != end; ++it)
- typedef std::vector<index::chain::MonotoneChain*> chainstore_type;
- chainstore_type::iterator csend = (*it)->end();
- for (chainstore_type::iterator csit = (*it)->begin(); csit != csend; ++csit)
- delete *csit;
delete *it;
+ for (MonoChains::iterator i = monoChains.begin(), e = monoChains.end();
+ i != e; i++)
+ delete *i;
void
@@ -135,11 +135,18 @@
+/*public*/
void
MCIndexSegmentSetMutualIntersector::process(SegmentString::ConstVect * segStrings)
processCounter = indexCounter + 1;
nOverlaps = 0;
+ i != e; i++)
+ delete *i;
monoChains.clear();
for (std::size_t i = 0, n = segStrings->size(); i < n; i++)
More information about the geos-commits
