[geos-commits] r3382 - in trunk/tests: bigtest unit xmltester
svn_geos at osgeo.org
Mon May 30 05:41:41 EDT 2011
Author: mloskot
Date: 2011-05-30 02:41:41 -0700 (Mon, 30 May 2011)
New Revision: 3382
trunk/tests/bigtest/CMakeLists.txt
trunk/tests/unit/CMakeLists.txt
trunk/tests/xmltester/CMakeLists.txt
Applied supplementary tests.patch for 85 from William
Modified: trunk/tests/bigtest/CMakeLists.txt
--- trunk/tests/bigtest/CMakeLists.txt 2011-05-27 14:04:18 UTC (rev 3381)
+++ trunk/tests/bigtest/CMakeLists.txt 2011-05-30 09:41:41 UTC (rev 3382)
@@ -21,13 +21,22 @@
include_directories(${CMAKE_CURRENT_SOURCE_DIR}/src/io/markup)
add_executable(bug234 bug234.cpp)
- target_link_libraries(bug234 geos)
+ if(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK)
+ target_link_libraries(bug234 GEOS)
+ else()
+ target_link_libraries(bug234 geos)
+ endif()
add_executable(TestSweepLineSpeed
TestSweepLineSpeed.cpp
GeometryTestFactory.cpp
bigtest.h)
- target_link_libraries(TestSweepLineSpeed geos)
+ target_link_libraries(TestSweepLineSpeed GEOS)
+ else()
+ target_link_libraries(TestSweepLineSpeed geos)
+ endif()
add_test(bug234 ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/bug234)
add_test(TestSweepLineSpeed ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/TestSweepLineSpeed)
@@ -35,4 +44,4 @@
set(STATUS_RESULT "ON")
endif()
-message(STATUS "${STATUS_MESSAGE} - ${STATUS_RESULT}")
\ No newline at end of file
+message(STATUS "${STATUS_MESSAGE} - ${STATUS_RESULT}")
Modified: trunk/tests/unit/CMakeLists.txt
--- trunk/tests/unit/CMakeLists.txt 2011-05-27 14:04:18 UTC (rev 3381)
+++ trunk/tests/unit/CMakeLists.txt 2011-05-30 09:41:41 UTC (rev 3382)
@@ -23,7 +23,11 @@
file(GLOB_RECURSE geos_unit_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
add_executable(geos_unit ${geos_unit_SOURCES})
- target_link_libraries(geos_unit geos geos_c)
+ target_link_libraries(geos_unit GEOS)
+ else()
+ target_link_libraries(geos_unit geos geos_c)
+ endif()
add_test(geos_unit ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/geos_unit)
Modified: trunk/tests/xmltester/CMakeLists.txt
--- trunk/tests/xmltester/CMakeLists.txt 2011-05-27 14:04:18 UTC (rev 3381)
+++ trunk/tests/xmltester/CMakeLists.txt 2011-05-30 09:41:41 UTC (rev 3382)
@@ -32,10 +32,18 @@
SingleSidedBufferResultMatcher.cpp)
add_executable(simplewkttester ${simplewkttester_SOURCES})
- target_link_libraries(simplewkttester geos)
+ target_link_libraries(simplewkttester GEOS)
+ else()
+ target_link_libraries(simplewkttester geos)
+ endif()
add_executable(xmltester ${xmltester_SOURCES})
- target_link_libraries(xmltester geos)
+ target_link_libraries(xmltester GEOS)
+ else()
+ target_link_libraries(xmltester geos)
+ endif()
set(XMLTESTS_DIR ${CMAKE_CURRENT_SOURCE_DIR}/tests)
set(SAVE_XMLTESTS
@@ -103,4 +111,4 @@
endif()
More information about the geos-commits
