[geos-commits] r3383 - trunk/src
svn_geos at osgeo.org
Mon May 30 06:30:46 EDT 2011
Author: mloskot
Date: 2011-05-30 03:30:46 -0700 (Mon, 30 May 2011)
New Revision: 3383
trunk/src/CMakeLists.txt
Applied William\'s patch with missing library versions for OSX framework (Ticket #385)
Modified: trunk/src/CMakeLists.txt
--- trunk/src/CMakeLists.txt 2011-05-30 09:41:41 UTC (rev 3382)
+++ trunk/src/CMakeLists.txt 2011-05-30 10:30:46 UTC (rev 3383)
@@ -25,10 +25,15 @@
${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_ts_c.cpp)
add_library(GEOS SHARED ${geos_SOURCES} ${geos_c_SOURCES})
+ math(EXPR CVERSION "${VERSION_MAJOR} + 1")
+ # VERSION = current version, SOVERSION = compatibility version
set_target_properties(GEOS
PROPERTIES
CLEAN_DIRECT_OUTPUT 1
FRAMEWORK 1
+ VERSION "${CVERSION}.${VERSION_MINOR}.${VERSION_PATCH}"
+ SOVERSION ${CVERSION}
FRAMEWORK_VERSION ${VERSION_MAJOR}
MACOSX_FRAMEWORK_INFO_PLIST "${CMAKE_CURRENT_SOURCE_DIR}/Info.plist.in"
MACOSX_FRAMEWORK_BUNDLE_VERSION "GEOS ${VERSION}"
More information about the geos-commits
