[geos-commits] r3518 - in trunk: macros swig/ruby
svn_geos at osgeo.org
Thu Nov 24 17:07:19 EST 2011
Author: strk
Date: 2011-11-24 14:07:19 -0800 (Thu, 24 Nov 2011)
New Revision: 3518
trunk/macros/ruby.m4
trunk/swig/ruby/Makefile.am
trunk/swig/ruby/geos_wrap.cxx
trunk/swig/ruby/ruby.i
Fix to get swig/ruby compiling for ruby 1.9
Patch by Kashif Rasul
Modified: trunk/macros/ruby.m4
--- trunk/macros/ruby.m4 2011-11-06 03:25:10 UTC (rev 3517)
+++ trunk/macros/ruby.m4 2011-11-24 22:07:19 UTC (rev 3518)
@@ -24,9 +24,12 @@
dnl Get Ruby bin directory
RUBY_BIN_DIR=`$RUBY -rrbconfig -e 'puts Config::CONFIG[["bindir"]]'`
+ dnl Get Ruby site arch
+ RUBY_SITE_ARCH=`$RUBY -rrbconfig -e 'puts Config::CONFIG[["sitearch"]]'`
dnl Get Ruby include directory
- RUBY_INCLUDE_DIR=`$RUBY -rrbconfig -e 'puts Config::CONFIG[["archdir"]]'`
+ RUBY_INCLUDE_DIR=`$RUBY -rrbconfig -e 'puts Config::CONFIG[["rubyhdrdir"]] || Config::CONFIG[["archdir"]]'`
dnl Get Ruby lib directory
RUBY_LIB_DIR=`$RUBY -rrbconfig -e 'puts Config::CONFIG[["libdir"]]'`
@@ -43,6 +46,7 @@
AC_MSG_NOTICE([Ruby executable is '$RUBY'])
AC_MSG_NOTICE([Ruby version is '$RUBY_VERSION'])
AC_MSG_NOTICE([Ruby bin directory is '$RUBY_BIN_DIR'])
+ AC_MSG_NOTICE([Ruby site arch is '$RUBY_SITE_ARCH'])
AC_MSG_NOTICE([Ruby include directory is '$RUBY_INCLUDE_DIR'])
AC_MSG_NOTICE([Ruby library directory is '$RUBY_LIB_DIR'])
AC_MSG_NOTICE([Ruby extension directory is '$RUBY_EXTENSION_DIR'])
@@ -51,6 +55,7 @@
AC_SUBST([RUBY_VERSION])
AC_SUBST([RUBY_BIN_DIR])
+ AC_SUBST([RUBY_SITE_ARCH])
AC_SUBST([RUBY_INCLUDE_DIR])
AC_SUBST([RUBY_LIB_DIR])
AC_SUBST([RUBY_EXTENSION_DIR])
Modified: trunk/swig/ruby/Makefile.am
--- trunk/swig/ruby/Makefile.am 2011-11-06 03:25:10 UTC (rev 3517)
+++ trunk/swig/ruby/Makefile.am 2011-11-24 22:07:19 UTC (rev 3518)
@@ -17,7 +17,7 @@
rubyextensiondirdir = $(RUBY_EXTENSION_DIR)
# Setup includes
-INCLUDES = -I$(RUBY_INCLUDE_DIR)
+INCLUDES = -I$(RUBY_INCLUDE_DIR) -I$(RUBY_INCLUDE_DIR)/$(RUBY_SITE_ARCH)
# Build Ruby module as shared library
rubyextensiondir_LTLIBRARIES = geos.la
Modified: trunk/swig/ruby/geos_wrap.cxx
--- trunk/swig/ruby/geos_wrap.cxx 2011-11-06 03:25:10 UTC (rev 3517)
+++ trunk/swig/ruby/geos_wrap.cxx 2011-11-24 22:07:19 UTC (rev 3518)
@@ -1,7206 +1,9944 @@
- * This file was automatically generated by SWIG (http://www.swig.org).
- * Version 1.3.31
- * This file is not intended to be easily readable and contains a number of
- * coding conventions designed to improve portability and efficiency. Do not make
- * changes to this file unless you know what you are doing--modify the SWIG
- * interface file instead.
-#define SWIGRUBY
-#ifdef __cplusplus
-template<class T> class SwigValueWrapper {
- T *tt;
-public:
- SwigValueWrapper() : tt(0) { }
- SwigValueWrapper(const SwigValueWrapper<T>& rhs) : tt(new T(*rhs.tt)) { }
- SwigValueWrapper(const T& t) : tt(new T(t)) { }
- ~SwigValueWrapper() { delete tt; }
- SwigValueWrapper& operator=(const T& t) { delete tt; tt = new T(t); return *this; }
- operator T&() const { return *tt; }
- T *operator&() { return tt; }
-private:
- SwigValueWrapper& operator=(const SwigValueWrapper<T>& rhs);
-#endif
- * This section contains generic SWIG labels for method/variable
- * declarations/attributes, and other compiler dependent labels.
-/* template workaround for compilers that cannot correctly implement the C++ standard */
-#ifndef SWIGTEMPLATEDISAMBIGUATOR
-# if defined(__SUNPRO_CC)
-# if (__SUNPRO_CC <= 0x560)
-# define SWIGTEMPLATEDISAMBIGUATOR template
-# else
-# endif
-# else
-# endif
-#endif
-/* inline attribute */
-#ifndef SWIGINLINE
-# if defined(__cplusplus) || (defined(__GNUC__) && !defined(__STRICT_ANSI__))
-# define SWIGINLINE inline
-# else
-# endif
-#endif
-/* attribute recognised by some compilers to avoid 'unused' warnings */
-#ifndef SWIGUNUSED
-# if defined(__GNUC__)
-# if !(defined(__cplusplus)) || (__GNUC__ > 3 || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4))
-# define SWIGUNUSED __attribute__ ((__unused__))
-# else
-# endif
-# elif defined(__ICC)
-# else
-# endif
-#endif
-#ifndef SWIGUNUSEDPARM
-# ifdef __cplusplus
-# define SWIGUNUSEDPARM(p)
-# else
-# define SWIGUNUSEDPARM(p) p SWIGUNUSED
-# endif
-#endif
-/* internal SWIG method */
-#ifndef SWIGINTERN
-# define SWIGINTERN static SWIGUNUSED
-#endif
-/* internal inline SWIG method */
-#ifndef SWIGINTERNINLINE
-# define SWIGINTERNINLINE SWIGINTERN SWIGINLINE
-#endif
-/* exporting methods */
-#if (__GNUC__ >= 4) || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4)
-# ifndef GCC_HASCLASSVISIBILITY
-# define GCC_HASCLASSVISIBILITY
-# endif
-#endif
-#ifndef SWIGEXPORT
-# if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
-# if defined(STATIC_LINKED)
-# define SWIGEXPORT
-# else
-# define SWIGEXPORT __declspec(dllexport)
-# endif
-# else
-# if defined(__GNUC__) && defined(GCC_HASCLASSVISIBILITY)
-# define SWIGEXPORT __attribute__ ((visibility("default")))
-# else
-# endif
-# endif
-#endif
-/* calling conventions for Windows */
-#ifndef SWIGSTDCALL
-# define SWIGSTDCALL __stdcall
-# else
-# endif
-#endif
-/* Deal with Microsoft's attempt at deprecating C standard runtime functions */
-#if !defined(SWIG_NO_CRT_SECURE_NO_DEPRECATE) && defined(_MSC_VER) && !defined(_CRT_SECURE_NO_DEPRECATE)
-# define _CRT_SECURE_NO_DEPRECATE
-#endif
-# else
-# endif
-# else
-# endif
-#endif
-#ifndef SWIGINLINE
-# else
-# endif
-#endif
-#ifndef SWIGUNUSED
-# else
-# endif
-# else
-# endif
-#endif
-# else
-# endif
-#endif
-#ifndef SWIGINTERN
-#endif
-#endif
-# endif
-#endif
-#ifndef SWIGEXPORT
-# else
-# endif
-# else
-# else
-# endif
-# endif
-#endif
-# else
-# endif
-#endif
-#endif
- * swigrun.swg
- * This file contains generic CAPI SWIG runtime support for pointer
- * type checking.
-/* This should only be incremented when either the layout of swig_type_info changes,
- or for whatever reason, the runtime changes incompatibly */
-#define SWIG_RUNTIME_VERSION "3"
-/* define SWIG_TYPE_TABLE_NAME as "SWIG_TYPE_TABLE" */
-#ifdef SWIG_TYPE_TABLE
-# define SWIG_QUOTE_STRING(x) #x
-# define SWIG_EXPAND_AND_QUOTE_STRING(x) SWIG_QUOTE_STRING(x)
-# define SWIG_TYPE_TABLE_NAME SWIG_EXPAND_AND_QUOTE_STRING(SWIG_TYPE_TABLE)
-#else
-#endif
- You can use the SWIGRUNTIME and SWIGRUNTIMEINLINE macros for
- creating a static or dynamic library from the swig runtime code.
- In 99.9% of the cases, swig just needs to declare them as 'static'.
- But only do this if is strictly necessary, ie, if you have problems
- with your compiler or so.
-#ifndef SWIGRUNTIME
-# define SWIGRUNTIME SWIGINTERN
-#endif
-#ifndef SWIGRUNTIMEINLINE
-# define SWIGRUNTIMEINLINE SWIGRUNTIME SWIGINLINE
-#endif
-/* Generic buffer size */
-#ifndef SWIG_BUFFER_SIZE
-# define SWIG_BUFFER_SIZE 1024
-#endif
-/* Flags for pointer conversions */
-#define SWIG_POINTER_DISOWN 0x1
-/* Flags for new pointer objects */
-#define SWIG_POINTER_OWN 0x1
- Flags/methods for returning states.
- The swig conversion methods, as ConvertPtr, return and integer
- that tells if the conversion was successful or not. And if not,
- an error code can be returned (see swigerrors.swg for the codes).
- Use the following macros/flags to set or process the returning
- states.
- In old swig versions, you usually write code as:
- if (SWIG_ConvertPtr(obj,vptr,ty.flags) != -1) {
- // success code
- } else {
- //fail code
- Now you can be more explicit as:
- int res = SWIG_ConvertPtr(obj,vptr,ty.flags);
- if (SWIG_IsOK(res)) {
- // success code
- } else {
- // fail code
- that seems to be the same, but now you can also do
- Type *ptr;
- int res = SWIG_ConvertPtr(obj,(void **)(&ptr),ty.flags);
- // success code
- if (SWIG_IsNewObj(res) {
- delete *ptr;
- } else {
- } else {
- // fail code
- I.e., now SWIG_ConvertPtr can return new objects and you can
- identify the case and take care of the deallocation. Of course that
- requires also to SWIG_ConvertPtr to return new result values, as
- int SWIG_ConvertPtr(obj, ptr,...) {
- if (<obj is ok>) {
- if (<need new object>) {
- *ptr = <ptr to new allocated object>;
- return SWIG_NEWOBJ;
- } else {
- *ptr = <ptr to old object>;
- return SWIG_OLDOBJ;
- } else {
- return SWIG_BADOBJ;
- Of course, returning the plain '0(success)/-1(fail)' still works, but you can be
- more explicit by returning SWIG_BADOBJ, SWIG_ERROR or any of the
- swig errors code.
- Finally, if the SWIG_CASTRANK_MODE is enabled, the result code
- allows to return the 'cast rank', for example, if you have this
- int food(double)
- int fooi(int);
- and you call
- food(1) // cast rank '1' (1 -> 1.0)
- fooi(1) // cast rank '0'
- just use the SWIG_AddCast()/SWIG_CheckState()
-#define SWIG_OK (0)
-#define SWIG_ERROR (-1)
-#define SWIG_IsOK(r) (r >= 0)
-#define SWIG_ArgError(r) ((r != SWIG_ERROR) ? r : SWIG_TypeError)
-/* The CastRankLimit says how many bits are used for the cast rank */
-#define SWIG_CASTRANKLIMIT (1 << 8)
-/* The NewMask denotes the object was created (using new/malloc) */
-#define SWIG_NEWOBJMASK (SWIG_CASTRANKLIMIT << 1)
-/* The TmpMask is for in/out typemaps that use temporal objects */
-#define SWIG_TMPOBJMASK (SWIG_NEWOBJMASK << 1)
-/* Simple returning values */
-#define SWIG_BADOBJ (SWIG_ERROR)
-#define SWIG_OLDOBJ (SWIG_OK)
-#define SWIG_NEWOBJ (SWIG_OK | SWIG_NEWOBJMASK)
-#define SWIG_TMPOBJ (SWIG_OK | SWIG_TMPOBJMASK)
-/* Check, add and del mask methods */
-#define SWIG_AddNewMask(r) (SWIG_IsOK(r) ? (r | SWIG_NEWOBJMASK) : r)
-#define SWIG_DelNewMask(r) (SWIG_IsOK(r) ? (r & ~SWIG_NEWOBJMASK) : r)
-#define SWIG_IsNewObj(r) (SWIG_IsOK(r) && (r & SWIG_NEWOBJMASK))
-#define SWIG_AddTmpMask(r) (SWIG_IsOK(r) ? (r | SWIG_TMPOBJMASK) : r)
-#define SWIG_DelTmpMask(r) (SWIG_IsOK(r) ? (r & ~SWIG_TMPOBJMASK) : r)
-#define SWIG_IsTmpObj(r) (SWIG_IsOK(r) && (r & SWIG_TMPOBJMASK))
-/* Cast-Rank Mode */
-#if defined(SWIG_CASTRANK_MODE)
-# ifndef SWIG_TypeRank
-# define SWIG_TypeRank unsigned long
-# endif
-# ifndef SWIG_MAXCASTRANK /* Default cast allowed */
-# define SWIG_MAXCASTRANK (2)
-# endif
-# define SWIG_CASTRANKMASK ((SWIG_CASTRANKLIMIT) -1)
-# define SWIG_CastRank(r) (r & SWIG_CASTRANKMASK)
-SWIGINTERNINLINE int SWIG_AddCast(int r) {
- return SWIG_IsOK(r) ? ((SWIG_CastRank(r) < SWIG_MAXCASTRANK) ? (r + 1) : SWIG_ERROR) : r;
-SWIGINTERNINLINE int SWIG_CheckState(int r) {
- return SWIG_IsOK(r) ? SWIG_CastRank(r) + 1 : 0;
-#else /* no cast-rank mode */
-# define SWIG_AddCast
-# define SWIG_CheckState(r) (SWIG_IsOK(r) ? 1 : 0)
-#endif
-#include <string.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-typedef void *(*swig_converter_func)(void *);
-typedef struct swig_type_info *(*swig_dycast_func)(void **);
-/* Structure to store inforomation on one type */
-typedef struct swig_type_info {
- const char *name; /* mangled name of this type */
- const char *str; /* human readable name of this type */
- swig_dycast_func dcast; /* dynamic cast function down a hierarchy */
- struct swig_cast_info *cast; /* linked list of types that can cast into this type */
- void *clientdata; /* language specific type data */
- int owndata; /* flag if the structure owns the clientdata */
-} swig_type_info;
-/* Structure to store a type and conversion function used for casting */
-typedef struct swig_cast_info {
- swig_type_info *type; /* pointer to type that is equivalent to this type */
- swig_converter_func converter; /* function to cast the void pointers */
- struct swig_cast_info *next; /* pointer to next cast in linked list */
- struct swig_cast_info *prev; /* pointer to the previous cast */
-} swig_cast_info;
-/* Structure used to store module information
- * Each module generates one structure like this, and the runtime collects
- * all of these structures and stores them in a circularly linked list.*/
-typedef struct swig_module_info {
- swig_type_info **types; /* Array of pointers to swig_type_info structures that are in this module */
- size_t size; /* Number of types in this module */
- struct swig_module_info *next; /* Pointer to next element in circularly linked list */
- swig_type_info **type_initial; /* Array of initially generated type structures */
- swig_cast_info **cast_initial; /* Array of initially generated casting structures */
- void *clientdata; /* Language specific module data */
-} swig_module_info;
- Compare two type names skipping the space characters, therefore
- "char*" == "char *" and "Class<int>" == "Class<int >", etc.
- Return 0 when the two name types are equivalent, as in
- strncmp, but skipping ' '.
-SWIGRUNTIME int
-SWIG_TypeNameComp(const char *f1, const char *l1,
- const char *f2, const char *l2) {
- for (;(f1 != l1) && (f2 != l2); ++f1, ++f2) {
- while ((*f1 == ' ') && (f1 != l1)) ++f1;
- while ((*f2 == ' ') && (f2 != l2)) ++f2;
- if (*f1 != *f2) return (*f1 > *f2) ? 1 : -1;
- return (l1 - f1) - (l2 - f2);
- Check type equivalence in a name list like <name1>|<name2>|...
- Return 0 if not equal, 1 if equal
-SWIGRUNTIME int
-SWIG_TypeEquiv(const char *nb, const char *tb) {
- int equiv = 0;
- const char* te = tb + strlen(tb);
- const char* ne = nb;
- while (!equiv && *ne) {
- for (nb = ne; *ne; ++ne) {
- if (*ne == '|') break;
- equiv = (SWIG_TypeNameComp(nb, ne, tb, te) == 0) ? 1 : 0;
- if (*ne) ++ne;
- return equiv;
- Return 0 if equal, -1 if nb < tb, 1 if nb > tb
-SWIGRUNTIME int
-SWIG_TypeCompare(const char *nb, const char *tb) {
- int equiv = 0;
- if (*ne) ++ne;
- return equiv;
-/* think of this as a c++ template<> or a scheme macro */
-#define SWIG_TypeCheck_Template(comparison, ty) \
- if (ty) { \
- swig_cast_info *iter = ty->cast; \
- while (iter) { \
- if (comparison) { \
- if (iter == ty->cast) return iter; \
- /* Move iter to the top of the linked list */ \
- iter->prev->next = iter->next; \
- if (iter->next) \
- iter->next->prev = iter->prev; \
- iter->next = ty->cast; \
- iter->prev = 0; \
- if (ty->cast) ty->cast->prev = iter; \
- ty->cast = iter; \
- return iter; \
- iter = iter->next; \
- return 0
- Check the typename
-SWIGRUNTIME swig_cast_info *
-SWIG_TypeCheck(const char *c, swig_type_info *ty) {
- SWIG_TypeCheck_Template(strcmp(iter->type->name, c) == 0, ty);
-/* Same as previous function, except strcmp is replaced with a pointer comparison */
-SWIG_TypeCheckStruct(swig_type_info *from, swig_type_info *into) {
- SWIG_TypeCheck_Template(iter->type == from, into);
- Cast a pointer up an inheritance hierarchy
-SWIGRUNTIMEINLINE void *
-SWIG_TypeCast(swig_cast_info *ty, void *ptr) {
- return ((!ty) || (!ty->converter)) ? ptr : (*ty->converter)(ptr);
- Dynamic pointer casting. Down an inheritance hierarchy
-SWIGRUNTIME swig_type_info *
-SWIG_TypeDynamicCast(swig_type_info *ty, void **ptr) {
- swig_type_info *lastty = ty;
- if (!ty || !ty->dcast) return ty;
- while (ty && (ty->dcast)) {
- ty = (*ty->dcast)(ptr);
- if (ty) lastty = ty;
- return lastty;
- Return the name associated with this type
-SWIGRUNTIMEINLINE const char *
-SWIG_TypeName(const swig_type_info *ty) {
- return ty->name;
- Return the pretty name associated with this type,
- that is an unmangled type name in a form presentable to the user.
-SWIGRUNTIME const char *
-SWIG_TypePrettyName(const swig_type_info *type) {
- /* The "str" field contains the equivalent pretty names of the
- type, separated by vertical-bar characters. We choose
- to print the last name, as it is often (?) the most
- specific. */
- if (!type) return NULL;
- if (type->str != NULL) {
- const char *last_name = type->str;
- const char *s;
- for (s = type->str; *s; s++)
- if (*s == '|') last_name = s+1;
- return last_name;
- else
- return type->name;
- Set the clientdata field for a type
-SWIGRUNTIME void
-SWIG_TypeClientData(swig_type_info *ti, void *clientdata) {
- swig_cast_info *cast = ti->cast;
- /* if (ti->clientdata == clientdata) return; */
- ti->clientdata = clientdata;
- while (cast) {
- if (!cast->converter) {
- swig_type_info *tc = cast->type;
- if (!tc->clientdata) {
- SWIG_TypeClientData(tc, clientdata);
- cast = cast->next;
-SWIGRUNTIME void
-SWIG_TypeNewClientData(swig_type_info *ti, void *clientdata) {
- SWIG_TypeClientData(ti, clientdata);
- ti->owndata = 1;
- Search for a swig_type_info structure only by mangled name
- Search is a O(log #types)
- We start searching at module start, and finish searching when start == end.
- Note: if start == end at the beginning of the function, we go all the way around
- the circular list.
-SWIG_MangledTypeQueryModule(swig_module_info *start,
- swig_module_info *end,
- const char *name) {
- swig_module_info *iter = start;
- do {
- if (iter->size) {
- register size_t l = 0;
- register size_t r = iter->size - 1;
- do {
- /* since l+r >= 0, we can (>> 1) instead (/ 2) */
- register size_t i = (l + r) >> 1;
- const char *iname = iter->types[i]->name;
- if (iname) {
- register int compare = strcmp(name, iname);
- if (compare == 0) {
- return iter->types[i];
- } else if (compare < 0) {
- if (i) {
- r = i - 1;
- } else {
- break;
- } else if (compare > 0) {
- l = i + 1;
- } else {
- break; /* should never happen */
- } while (l <= r);
- } while (iter != end);
- return 0;
- Search for a swig_type_info structure for either a mangled name or a human readable name.
- It first searches the mangled names of the types, which is a O(log #types)
- If a type is not found it then searches the human readable names, which is O(#types).
-SWIG_TypeQueryModule(swig_module_info *start,
- /* STEP 1: Search the name field using binary search */
- swig_type_info *ret = SWIG_MangledTypeQueryModule(start, end, name);
- if (ret) {
- return ret;
- } else {
- /* STEP 2: If the type hasn't been found, do a complete search
- of the str field (the human readable name) */
- do {
- register size_t i = 0;
- for (; i < iter->size; ++i) {
- if (iter->types[i]->str && (SWIG_TypeEquiv(iter->types[i]->str, name)))
- /* neither found a match */
- return 0;
- Pack binary data into a string
-SWIGRUNTIME char *
-SWIG_PackData(char *c, void *ptr, size_t sz) {
- static const char hex[17] = "0123456789abcdef";
- register const unsigned char *u = (unsigned char *) ptr;
- register const unsigned char *eu = u + sz;
- for (; u != eu; ++u) {
- register unsigned char uu = *u;
- *(c++) = hex[(uu & 0xf0) >> 4];
- *(c++) = hex[uu & 0xf];
- return c;
- Unpack binary data from a string
-SWIG_UnpackData(const char *c, void *ptr, size_t sz) {
- register unsigned char *u = (unsigned char *) ptr;
- register char d = *(c++);
- register unsigned char uu;
- if ((d >= '0') && (d <= '9'))
- uu = ((d - '0') << 4);
- else if ((d >= 'a') && (d <= 'f'))
- uu = ((d - ('a'-10)) << 4);
- else
- return (char *) 0;
- d = *(c++);
- uu |= (d - '0');
- uu |= (d - ('a'-10));
- else
- *u = uu;
- return c;
- Pack 'void *' into a string buffer.
-SWIGRUNTIME char *
-SWIG_PackVoidPtr(char *buff, void *ptr, const char *name, size_t bsz) {
- char *r = buff;
- if ((2*sizeof(void *) + 2) > bsz) return 0;
- *(r++) = '_';
- r = SWIG_PackData(r,&ptr,sizeof(void *));
- if (strlen(name) + 1 > (bsz - (r - buff))) return 0;
- strcpy(r,name);
- return buff;
-SWIG_UnpackVoidPtr(const char *c, void **ptr, const char *name) {
- if (*c != '_') {
- if (strcmp(c,"NULL") == 0) {
- *ptr = (void *) 0;
- return name;
- } else {
- return 0;
- return SWIG_UnpackData(++c,ptr,sizeof(void *));
-SWIGRUNTIME char *
-SWIG_PackDataName(char *buff, void *ptr, size_t sz, const char *name, size_t bsz) {
- char *r = buff;
- size_t lname = (name ? strlen(name) : 0);
- if ((2*sz + 2 + lname) > bsz) return 0;
- *(r++) = '_';
- r = SWIG_PackData(r,ptr,sz);
- if (lname) {
- strncpy(r,name,lname+1);
- } else {
- *r = 0;
- return buff;
-SWIG_UnpackDataName(const char *c, void *ptr, size_t sz, const char *name) {
- if (*c != '_') {
- memset(ptr,0,sz);
- return name;
- } else {
- return 0;
- return SWIG_UnpackData(++c,ptr,sz);
-#ifdef __cplusplus
-#endif
-/* Errors in SWIG */
-#define SWIG_UnknownError -1
-#define SWIG_IOError -2
-#define SWIG_RuntimeError -3
-#define SWIG_IndexError -4
-#define SWIG_TypeError -5
-#define SWIG_DivisionByZero -6
-#define SWIG_OverflowError -7
-#define SWIG_SyntaxError -8
-#define SWIG_ValueError -9
-#define SWIG_SystemError -10
-#define SWIG_AttributeError -11
-#define SWIG_MemoryError -12
-#define SWIG_NullReferenceError -13
-#include <ruby.h>
-/* Ruby 1.7 defines NUM2LL(), LL2NUM() and ULL2NUM() macros */
-#ifndef NUM2LL
-#define NUM2LL(x) NUM2LONG((x))
-#endif
-#ifndef LL2NUM
-#define LL2NUM(x) INT2NUM((long) (x))
-#endif
-#ifndef ULL2NUM
-#define ULL2NUM(x) UINT2NUM((unsigned long) (x))
-#endif
-/* Ruby 1.7 doesn't (yet) define NUM2ULL() */
-#ifndef NUM2ULL
-#ifdef HAVE_LONG_LONG
-#define NUM2ULL(x) rb_num2ull((x))
-#else
-#define NUM2ULL(x) NUM2ULONG(x)
-#endif
-#endif
-/* RSTRING_LEN, etc are new in Ruby 1.9, but ->ptr and ->len no longer work */
-/* Define these for older versions so we can just write code the new way */
-#ifndef RSTRING_LEN
-# define RSTRING_LEN(x) RSTRING(x)->len
-#endif
-#ifndef RSTRING_PTR
-# define RSTRING_PTR(x) RSTRING(x)->ptr
-#endif
-#ifndef RARRAY_LEN
-# define RARRAY_LEN(x) RARRAY(x)->len
-#endif
-#ifndef RARRAY_PTR
-# define RARRAY_PTR(x) RARRAY(x)->ptr
-#endif
- * Need to be very careful about how these macros are defined, especially
- * when compiling C++ code or C code with an ANSI C compiler.
- * VALUEFUNC(f) is a macro used to typecast a C function that implements
- * a Ruby method so that it can be passed as an argument to API functions
- * like rb_define_method() and rb_define_singleton_method().
- * VOIDFUNC(f) is a macro used to typecast a C function that implements
- * either the "mark" or "free" stuff for a Ruby Data object, so that it
- * can be passed as an argument to API functions like Data_Wrap_Struct()
- * and Data_Make_Struct().
-#ifdef __cplusplus
-# ifndef RUBY_METHOD_FUNC /* These definitions should work for Ruby 1.4.6 */
-# define PROTECTFUNC(f) ((VALUE (*)()) f)
-# define VALUEFUNC(f) ((VALUE (*)()) f)
-# define VOIDFUNC(f) ((void (*)()) f)
-# else
-# ifndef ANYARGS /* These definitions should work for Ruby 1.6 */
-# define VOIDFUNC(f) ((RUBY_DATA_FUNC) f)
-# else /* These definitions should work for Ruby 1.7+ */
-# define PROTECTFUNC(f) ((VALUE (*)(VALUE)) f)
-# define VALUEFUNC(f) ((VALUE (*)(ANYARGS)) f)
-# endif
-# endif
-#else
-# define VALUEFUNC(f) (f)
-# define VOIDFUNC(f) (f)
-#endif
-/* Don't use for expressions have side effect */
-#ifndef RB_STRING_VALUE
-#define RB_STRING_VALUE(s) (TYPE(s) == T_STRING ? (s) : (*(volatile VALUE *)&(s) = rb_str_to_str(s)))
-#endif
-#ifndef StringValue
-#define StringValue(s) RB_STRING_VALUE(s)
-#endif
-#ifndef StringValuePtr
-#define StringValuePtr(s) RSTRING_PTR(RB_STRING_VALUE(s))
-#endif
-#ifndef StringValueLen
-#define StringValueLen(s) RSTRING_LEN(RB_STRING_VALUE(s))
-#endif
-#ifndef SafeStringValue
-#define SafeStringValue(v) do {\
- StringValue(v);\
- rb_check_safe_str(v);\
-} while (0)
-#endif
-#ifndef HAVE_RB_DEFINE_ALLOC_FUNC
-#define rb_define_alloc_func(klass, func) rb_define_singleton_method((klass), "new", VALUEFUNC((func)), -1)
-#define rb_undef_alloc_func(klass) rb_undef_method(CLASS_OF((klass)), "new")
-#endif
- * error manipulation
-/* Define some additional error types */
-#define SWIG_ObjectPreviouslyDeletedError -100
-/* Define custom exceptions for errors that do not map to existing Ruby
- exceptions. Note this only works for C++ since a global cannot be
- initialized by a funtion in C. For C, fallback to rb_eRuntimeError.*/
-SWIGINTERN VALUE
-getNullReferenceError(void) {
- static int init = 0;
- static VALUE rb_eNullReferenceError ;
- if (!init) {
- init = 1;
- rb_eNullReferenceError = rb_define_class("NullReferenceError", rb_eRuntimeError);
- return rb_eNullReferenceError;
-SWIGINTERN VALUE
-getObjectPreviouslyDeletedError(void) {
- static VALUE rb_eObjectPreviouslyDeleted ;
- if (!init) {
- init = 1;
- rb_eObjectPreviouslyDeleted = rb_define_class("ObjectPreviouslyDeleted", rb_eRuntimeError);
- return rb_eObjectPreviouslyDeleted;
-SWIGINTERN VALUE
-SWIG_Ruby_ErrorType(int SWIG_code) {
- VALUE type;
- switch (SWIG_code) {
- case SWIG_MemoryError:
- type = rb_eNoMemError;
- break;
- case SWIG_IOError:
- type = rb_eIOError;
- break;
- case SWIG_RuntimeError:
- type = rb_eRuntimeError;
- break;
- case SWIG_IndexError:
- type = rb_eIndexError;
- break;
- case SWIG_TypeError:
- type = rb_eTypeError;
- break;
- case SWIG_DivisionByZero:
- type = rb_eZeroDivError;
- break;
- case SWIG_OverflowError:
- type = rb_eRangeError;
- break;
- case SWIG_SyntaxError:
- type = rb_eSyntaxError;
- break;
- case SWIG_ValueError:
- type = rb_eArgError;
- break;
- case SWIG_SystemError:
- type = rb_eFatal;
- break;
- case SWIG_AttributeError:
- break;
- case SWIG_NullReferenceError:
- type = getNullReferenceError();
- break;
- case SWIG_ObjectPreviouslyDeletedError:
- type = getObjectPreviouslyDeletedError();
- break;
- case SWIG_UnknownError:
- break;
- default:
- return type;
- * See the LICENSE file for information on copyright, usage and redistribution
- * of SWIG, and the README file for authors - http://www.swig.org/release.html.
- * rubytracking.swg
- * This file contains support for tracking mappings from
- * Ruby objects to C++ objects. This functionality is needed
- * to implement mark functions for Ruby's mark and sweep
- * garbage collector.
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* Global Ruby hash table to store Trackings from C/C++
- structs to Ruby Objects. */
-static VALUE swig_ruby_trackings;
-/* Global variable that stores a reference to the ruby
- hash table delete function. */
-static ID swig_ruby_hash_delete = 0;
-/* Setup a Ruby hash table to store Trackings */
-SWIGRUNTIME void SWIG_RubyInitializeTrackings(void) {
- /* Create a ruby hash table to store Trackings from C++
- objects to Ruby objects. Also make sure to tell
- the garabage collector about the hash table. */
- swig_ruby_trackings = rb_hash_new();
- rb_gc_register_address(&swig_ruby_trackings);
- /* Now store a reference to the hash table delete function
- so that we only have to look it up once.*/
- swig_ruby_hash_delete = rb_intern("delete");
-/* Get a Ruby number to reference a pointer */
-SWIGRUNTIME VALUE SWIG_RubyPtrToReference(void* ptr) {
- /* We cast the pointer to an unsigned long
- and then store a reference to it using
- a Ruby number object. */
- /* Convert the pointer to a Ruby number */
- unsigned long value = (unsigned long) ptr;
- return LONG2NUM(value);
-/* Get a Ruby number to reference an object */
-SWIGRUNTIME VALUE SWIG_RubyObjectToReference(VALUE object) {
- /* We cast the object to an unsigned long
- /* Convert the Object to a Ruby number */
- unsigned long value = (unsigned long) object;
-/* Get a Ruby object from a previously stored reference */
-SWIGRUNTIME VALUE SWIG_RubyReferenceToObject(VALUE reference) {
- /* The provided Ruby number object is a reference
- to the Ruby object we want.*/
- /* First convert the Ruby number to a C number */
- unsigned long value = NUM2LONG(reference);
- return (VALUE) value;
-/* Add a Tracking from a C/C++ struct to a Ruby object */
-SWIGRUNTIME void SWIG_RubyAddTracking(void* ptr, VALUE object) {
- /* In a Ruby hash table we store the pointer and
- the associated Ruby object. The trick here is
- that we cannot store the Ruby object directly - if
- we do then it cannot be garbage collected. So
- instead we typecast it as a unsigned long and
- convert it to a Ruby number object.*/
- /* Get a reference to the pointer as a Ruby number */
- VALUE key = SWIG_RubyPtrToReference(ptr);
- /* Get a reference to the Ruby object as a Ruby number */
- VALUE value = SWIG_RubyObjectToReference(object);
- /* Store the mapping to the global hash table. */
- rb_hash_aset(swig_ruby_trackings, key, value);
-/* Get the Ruby object that owns the specified C/C++ struct */
-SWIGRUNTIME VALUE SWIG_RubyInstanceFor(void* ptr) {
- /* Now lookup the value stored in the global hash table */
- VALUE value = rb_hash_aref(swig_ruby_trackings, key);
- if (value == Qnil) {
- /* No object exists - return nil. */
- return Qnil;
- else {
- /* Convert this value to Ruby object */
- return SWIG_RubyReferenceToObject(value);
-/* Remove a Tracking from a C/C++ struct to a Ruby object. It
- is very important to remove objects once they are destroyed
- since the same memory address may be reused later to create
- a new object. */
-SWIGRUNTIME void SWIG_RubyRemoveTracking(void* ptr) {
- /* Delete the object from the hash table by calling Ruby's
- do this we need to call the Hash.delete method.*/
- rb_funcall(swig_ruby_trackings, swig_ruby_hash_delete, 1, key);
-/* This is a helper method that unlinks a Ruby object from its
- underlying C++ object. This is needed if the lifetime of the
- Ruby object is longer than the C++ object */
-SWIGRUNTIME void SWIG_RubyUnlinkObjects(void* ptr) {
- VALUE object = SWIG_RubyInstanceFor(ptr);
- if (object != Qnil) {
- DATA_PTR(object) = 0;
-#ifdef __cplusplus
-#endif
- * Ruby API portion that goes into the runtime
-#ifdef __cplusplus
-extern "C" {
-#endif
-SWIGINTERN VALUE
-SWIG_Ruby_AppendOutput(VALUE target, VALUE o) {
- if (NIL_P(target)) {
- target = o;
- } else {
- if (TYPE(target) != T_ARRAY) {
- VALUE o2 = target;
- target = rb_ary_new();
- rb_ary_push(target, o2);
- rb_ary_push(target, o);
- return target;
-#ifdef __cplusplus
-#endif
- * rubyrun.swg
- * This file contains the runtime support for Ruby modules
- * and includes code for managing global variables and pointer
- * type checking.
-/* For backward compatibility only */
-#define SWIG_POINTER_EXCEPTION 0
-/* for raw pointers */
-#define SWIG_ConvertPtr(obj, pptr, type, flags) SWIG_Ruby_ConvertPtrAndOwn(obj, pptr, type, flags, 0)
-#define SWIG_ConvertPtrAndOwn(obj,pptr,type,flags,own) SWIG_Ruby_ConvertPtrAndOwn(obj, pptr, type, flags, own)
-#define SWIG_NewPointerObj(ptr, type, flags) SWIG_Ruby_NewPointerObj(ptr, type, flags)
-#define SWIG_AcquirePtr(ptr, own) SWIG_Ruby_AcquirePtr(ptr, own)
-#define swig_owntype ruby_owntype
-/* for raw packed data */
-#define SWIG_ConvertPacked(obj, ptr, sz, ty) SWIG_Ruby_ConvertPacked(obj, ptr, sz, ty, flags)
-#define SWIG_NewPackedObj(ptr, sz, type) SWIG_Ruby_NewPackedObj(ptr, sz, type)
-/* for class or struct pointers */
-#define SWIG_ConvertInstance(obj, pptr, type, flags) SWIG_ConvertPtr(obj, pptr, type, flags)
-#define SWIG_NewInstanceObj(ptr, type, flags) SWIG_NewPointerObj(ptr, type, flags)
-/* for C or C++ function pointers */
-#define SWIG_ConvertFunctionPtr(obj, pptr, type) SWIG_ConvertPtr(obj, pptr, type, 0)
-#define SWIG_NewFunctionPtrObj(ptr, type) SWIG_NewPointerObj(ptr, type, 0)
-/* for C++ member pointers, ie, member methods */
-#define SWIG_ConvertMember(obj, ptr, sz, ty) SWIG_Ruby_ConvertPacked(obj, ptr, sz, ty)
-#define SWIG_NewMemberObj(ptr, sz, type) SWIG_Ruby_NewPackedObj(ptr, sz, type)
-/* Runtime API */
-#define SWIG_GetModule(clientdata) SWIG_Ruby_GetModule()
-#define SWIG_SetModule(clientdata, pointer) SWIG_Ruby_SetModule(pointer)
-/* Error manipulation */
-#define SWIG_ErrorType(code) SWIG_Ruby_ErrorType(code)
-#define SWIG_Error(code, msg) rb_raise(SWIG_Ruby_ErrorType(code), msg)
-#define SWIG_fail goto fail
-/* Ruby-specific SWIG API */
-#define SWIG_InitRuntime() SWIG_Ruby_InitRuntime()
-#define SWIG_define_class(ty) SWIG_Ruby_define_class(ty)
-#define SWIG_NewClassInstance(value, ty) SWIG_Ruby_NewClassInstance(value, ty)
-#define SWIG_MangleStr(value) SWIG_Ruby_MangleStr(value)
-#define SWIG_CheckConvert(value, ty) SWIG_Ruby_CheckConvert(value, ty)
- * pointers/data manipulation
-#ifdef __cplusplus
-extern "C" {
-#if 0
-} /* cc-mode */
-#endif
-#endif
-typedef struct {
- VALUE klass;
- VALUE mImpl;
- void (*mark)(void *);
- void (*destroy)(void *);
- int trackObjects;
-} swig_class;
-static VALUE _mSWIG = Qnil;
-static VALUE _cSWIG_Pointer = Qnil;
-static VALUE swig_runtime_data_type_pointer = Qnil;
-SWIGRUNTIME VALUE
-getExceptionClass(void) {
- static VALUE rubyExceptionClass ;
- if (!init) {
- init = 1;
- rubyExceptionClass = rb_const_get(_mSWIG, rb_intern("Exception"));
- return rubyExceptionClass;
-/* This code checks to see if the Ruby object being raised as part
- of an exception inherits from the Ruby class Exception. If so,
- the object is simply returned. If not, then a new Ruby exception
- object is created and that will be returned to Ruby.*/
-SWIGRUNTIME VALUE
-SWIG_Ruby_ExceptionType(swig_type_info *desc, VALUE obj) {
- VALUE exceptionClass = getExceptionClass();
- if (rb_obj_is_kind_of(obj, exceptionClass)) {
- return obj;
- } else {
- return rb_exc_new3(rb_eRuntimeError, rb_obj_as_string(obj));
-/* Initialize Ruby runtime support */
-SWIGRUNTIME void
-SWIG_Ruby_InitRuntime(void)
- if (_mSWIG == Qnil) {
- _mSWIG = rb_define_module("SWIG");
-/* Define Ruby class for C type */
-SWIGRUNTIME void
-SWIG_Ruby_define_class(swig_type_info *type)
- VALUE klass;
- char *klass_name = (char *) malloc(4 + strlen(type->name) + 1);
- sprintf(klass_name, "TYPE%s", type->name);
- if (NIL_P(_cSWIG_Pointer)) {
- _cSWIG_Pointer = rb_define_class_under(_mSWIG, "Pointer", rb_cObject);
- rb_undef_method(CLASS_OF(_cSWIG_Pointer), "new");
- klass = rb_define_class_under(_mSWIG, klass_name, _cSWIG_Pointer);
- free((void *) klass_name);
-/* Create a new pointer object */
-SWIGRUNTIME VALUE
-SWIG_Ruby_NewPointerObj(void *ptr, swig_type_info *type, int flags)
- int own = flags & SWIG_POINTER_OWN;
- char *klass_name;
- swig_class *sklass;
- VALUE klass;
- VALUE obj;
- if (!ptr)
- return Qnil;
- if (type->clientdata) {
- sklass = (swig_class *) type->clientdata;
- /* Are we tracking this class and have we already returned this Ruby object? */
- if (sklass->trackObjects) {
- obj = SWIG_RubyInstanceFor(ptr);
- /* Check the object's type and make sure it has the correct type.
- It might not in cases where methods do things like
- downcast methods. */
- if (obj != Qnil) {
- VALUE value = rb_iv_get(obj, "__swigtype__");
- char* type_name = RSTRING_PTR(value);
- if (strcmp(type->name, type_name) == 0) {
- return obj;
- /* Create a new Ruby object */
- obj = Data_Wrap_Struct(sklass->klass, VOIDFUNC(sklass->mark), (own ? VOIDFUNC(sklass->destroy) : 0), ptr);
- /* If tracking is on for this class then track this object. */
- SWIG_RubyAddTracking(ptr, obj);
- } else {
- klass_name = (char *) malloc(4 + strlen(type->name) + 1);
- klass = rb_const_get(_mSWIG, rb_intern(klass_name));
- obj = Data_Wrap_Struct(klass, 0, 0, ptr);
- rb_iv_set(obj, "__swigtype__", rb_str_new2(type->name));
- return obj;
-/* Create a new class instance (always owned) */
-SWIGRUNTIME VALUE
-SWIG_Ruby_NewClassInstance(VALUE klass, swig_type_info *type)
- VALUE obj;
- swig_class *sklass = (swig_class *) type->clientdata;
- obj = Data_Wrap_Struct(klass, VOIDFUNC(sklass->mark), VOIDFUNC(sklass->destroy), 0);
- return obj;
-/* Get type mangle from class name */
-SWIGRUNTIMEINLINE char *
-SWIG_Ruby_MangleStr(VALUE obj)
- VALUE stype = rb_iv_get(obj, "__swigtype__");
- return StringValuePtr(stype);
-/* Acquire a pointer value */
-typedef void (*ruby_owntype)(void*);
-SWIGRUNTIME ruby_owntype
-SWIG_Ruby_AcquirePtr(VALUE obj, ruby_owntype own) {
- if (obj) {
- ruby_owntype oldown = RDATA(obj)->dfree;
- RDATA(obj)->dfree = own;
- return oldown;
- } else {
- return 0;
-/* Convert a pointer value */
-SWIGRUNTIME int
-SWIG_Ruby_ConvertPtrAndOwn(VALUE obj, void **ptr, swig_type_info *ty, int flags, ruby_owntype *own)
- char *c;
- swig_cast_info *tc;
- void *vptr = 0;
- /* Grab the pointer */
- if (NIL_P(obj)) {
- *ptr = 0;
- return SWIG_OK;
- } else {
- if (TYPE(obj) != T_DATA) {
- return SWIG_ERROR;
- Data_Get_Struct(obj, void, vptr);
- if (own) *own = RDATA(obj)->dfree;
- /* Check to see if the input object is giving up ownership
- of the underlying C struct or C++ object. If so then we
- need to reset the destructor since the Ruby object no
- longer owns the underlying C++ object.*/
- if (flags & SWIG_POINTER_DISOWN) {
- /* Is tracking on for this class? */
- int track = 0;
- if (ty && ty->clientdata) {
- swig_class *sklass = (swig_class *) ty->clientdata;
- track = sklass->trackObjects;
- if (track) {
- /* We are tracking objects for this class. Thus we change the destructor
- * to SWIG_RubyRemoveTracking. This allows us to
- * remove the mapping from the C++ to Ruby object
- * when the Ruby object is garbage collected. If we don't
- * do this, then it is possible we will return a reference
- * to a Ruby object that no longer exists thereby crashing Ruby. */
- RDATA(obj)->dfree = SWIG_RubyRemoveTracking;
- } else {
- RDATA(obj)->dfree = 0;
- /* Do type-checking if type info was provided */
- if (ty) {
- if (ty->clientdata) {
- if (rb_obj_is_kind_of(obj, ((swig_class *) (ty->clientdata))->klass)) {
- if (vptr == 0) {
- /* The object has already been deleted */
- return SWIG_ObjectPreviouslyDeletedError;
- *ptr = vptr;
- return SWIG_OK;
- if ((c = SWIG_MangleStr(obj)) == NULL) {
- tc = SWIG_TypeCheck(c, ty);
- if (!tc) {
- *ptr = SWIG_TypeCast(tc, vptr);
- } else {
- *ptr = vptr;
- return SWIG_OK;
-/* Check convert */
-SWIGRUNTIMEINLINE int
-SWIG_Ruby_CheckConvert(VALUE obj, swig_type_info *ty)
- char *c = SWIG_MangleStr(obj);
- if (!c) return 0;
- return SWIG_TypeCheck(c,ty) != 0;
-SWIGRUNTIME VALUE
-SWIG_Ruby_NewPackedObj(void *ptr, int sz, swig_type_info *type) {
- char result[1024];
- char *r = result;
- if ((2*sz + 1 + strlen(type->name)) > 1000) return 0;
- *(r++) = '_';
- r = SWIG_PackData(r, ptr, sz);
- strcpy(r, type->name);
- return rb_str_new2(result);
-/* Convert a packed value value */
-SWIGRUNTIME int
-SWIG_Ruby_ConvertPacked(VALUE obj, void *ptr, int sz, swig_type_info *ty) {
- const char *c;
- if (TYPE(obj) != T_STRING) goto type_error;
- c = StringValuePtr(obj);
- /* Pointer values must start with leading underscore */
- if (*c != '_') goto type_error;
- c++;
- c = SWIG_UnpackData(c, ptr, sz);
- if (ty) {
- if (!tc) goto type_error;
- return SWIG_OK;
- type_error:
-SWIGRUNTIME swig_module_info *
-SWIG_Ruby_GetModule(void)
- VALUE pointer;
- swig_module_info *ret = 0;
- VALUE verbose = rb_gv_get("VERBOSE");
- /* temporarily disable warnings, since the pointer check causes warnings with 'ruby -w' */
- rb_gv_set("VERBOSE", Qfalse);
- /* first check if pointer already created */
- pointer = rb_gv_get("$swig_runtime_data_type_pointer" SWIG_RUNTIME_VERSION SWIG_TYPE_TABLE_NAME);
- if (pointer != Qnil) {
- Data_Get_Struct(pointer, swig_module_info, ret);
- /* reinstate warnings */
- rb_gv_set("VERBOSE", verbose);
- return ret;
-SWIGRUNTIME void
-SWIG_Ruby_SetModule(swig_module_info *pointer)
- /* register a new class */
- VALUE cl = rb_define_class("swig_runtime_data", rb_cObject);
- /* create and store the structure pointer to a global variable */
- swig_runtime_data_type_pointer = Data_Wrap_Struct(cl, 0, 0, pointer);
- rb_define_readonly_variable("$swig_runtime_data_type_pointer" SWIG_RUNTIME_VERSION SWIG_TYPE_TABLE_NAME, &swig_runtime_data_type_pointer);
-#ifdef __cplusplus
-#if 0
-{ /* cc-mode */
-#endif
-#endif
-#define SWIG_exception_fail(code, msg) do { SWIG_Error(code, msg); SWIG_fail; } while(0)
-#define SWIG_contract_assert(expr, msg) if (!(expr)) { SWIG_Error(SWIG_RuntimeError, msg); SWIG_fail; } else
- #define SWIG_exception(code, msg) do { SWIG_Error(code, msg);; } while(0)
-/* -------- TYPES TABLE (BEGIN) -------- */
-#define SWIGTYPE_p_GeosCoordinateSequence swig_types[0]
-#define SWIGTYPE_p_GeosGeometry swig_types[1]
-#define SWIGTYPE_p_GeosGeometryCollection swig_types[2]
-#define SWIGTYPE_p_GeosLineString swig_types[3]
-#define SWIGTYPE_p_GeosLinearRing swig_types[4]
-#define SWIGTYPE_p_GeosMultiLineString swig_types[5]
-#define SWIGTYPE_p_GeosMultiLinearRing swig_types[6]
-#define SWIGTYPE_p_GeosMultiPoint swig_types[7]
-#define SWIGTYPE_p_GeosMultiPolygon swig_types[8]
-#define SWIGTYPE_p_GeosPoint swig_types[9]
-#define SWIGTYPE_p_GeosPolygon swig_types[10]
-#define SWIGTYPE_p_GeosWkbReader swig_types[11]
-#define SWIGTYPE_p_GeosWkbWriter swig_types[12]
-#define SWIGTYPE_p_GeosWktReader swig_types[13]
-#define SWIGTYPE_p_GeosWktWriter swig_types[14]
-#define SWIGTYPE_p_char swig_types[15]
-#define SWIGTYPE_p_p_GeosLinearRing swig_types[16]
-#define SWIGTYPE_p_size_t swig_types[17]
-#define SWIGTYPE_p_unsigned_char swig_types[18]
-static swig_type_info *swig_types[20];
-static swig_module_info swig_module = {swig_types, 19, 0, 0, 0, 0};
-#define SWIG_TypeQuery(name) SWIG_TypeQueryModule(&swig_module, &swig_module, name)
-#define SWIG_MangledTypeQuery(name) SWIG_MangledTypeQueryModule(&swig_module, &swig_module, name)
-/* -------- TYPES TABLE (END) -------- */
-#define SWIG_init Init_geos
-#define SWIG_name "Geos"
-static VALUE mGeos;
-#define SWIGVERSION 0x010331
-#define SWIG_VERSION SWIGVERSION
-#define SWIG_as_voidptr(a) const_cast< void * >(static_cast< const void * >(a))
-#define SWIG_as_voidptrptr(a) ((void)SWIG_as_voidptr(*a),reinterpret_cast< void** >(a))
-#include <stdexcept>
-#include <string>
-#include <string>
-#define SWIG_FLOAT_P(x) ((TYPE(x) == T_FLOAT) || FIXNUM_P(x))
-bool SWIG_BOOL_P(VALUE) {
- // dummy test, RTEST should take care of everything
- return true;
-bool SWIG_RB2BOOL(VALUE x) {
- return RTEST(x);
-VALUE SWIG_BOOL2RB(bool b) {
- return b ? Qtrue : Qfalse;
-double SWIG_NUM2DBL(VALUE x) {
- return (FIXNUM_P(x) ? FIX2INT(x) : NUM2DBL(x));
-bool SWIG_STRING_P(VALUE x) {
- return TYPE(x) == T_STRING;
-std::string SWIG_RB2STR(VALUE x) {
- return std::string(RSTRING_PTR(x), RSTRING_LEN(x));
-VALUE SWIG_STR2RB(const std::string& s) {
- return rb_str_new(s.data(), s.size());
-#include <vector>
-#include <algorithm>
-#include "geos_c.h"
-/* Needed for va_start, etc. */
-#include <stdarg.h>
-#include <limits.h>
-#ifndef LLONG_MIN
-# define LLONG_MIN LONG_LONG_MIN
-#endif
-#ifndef LLONG_MAX
-# define LLONG_MAX LONG_LONG_MAX
-#endif
-#ifndef ULLONG_MAX
-# define ULLONG_MAX ULONG_LONG_MAX
-#endif
- #define SWIG_From_long LONG2NUM
-SWIGINTERNINLINE VALUE
-SWIG_From_int (int value)
- return SWIG_From_long (value);
-SWIGINTERN swig_type_info*
-SWIG_pchar_descriptor(void)
- static swig_type_info* info = 0;
- if (!init) {
- info = SWIG_TypeQuery("_p_char");
- init = 1;
- return info;
-SWIG_FromCharPtrAndSize(const char* carray, size_t size)
- if (carray) {
- if (size > LONG_MAX) {
- swig_type_info* pchar_descriptor = SWIG_pchar_descriptor();
- return pchar_descriptor ?
- SWIG_NewPointerObj(const_cast< char * >(carray), pchar_descriptor, 0) : Qnil;
- } else {
- return rb_str_new(carray, static_cast< long >(size));
- } else {
- return Qnil;
-SWIG_FromCharPtr(const char *cptr)
- return SWIG_FromCharPtrAndSize(cptr, (cptr ? strlen(cptr) : 0));
- static const int DEFAULT_QUADRANT_SEGMENTS=8;
-/* This is not thread safe ! */
-static const int MESSAGE_SIZE = 1000;
-static char message[MESSAGE_SIZE];
-void noticeHandler(const char *fmt, ...)
- va_list args;
- va_start(args, fmt);
- vsnprintf(message, sizeof(message) - 1, fmt, args);
- va_end(args);
-void errorHandler(const char *fmt, ...)
- va_list args;
- va_end(args);
-typedef void GeosCoordinateSequence;
-void checkCoordSeqBounds(const GEOSCoordSeq coordSeq, const size_t index)
- unsigned int size = 0;
- GEOSCoordSeq_getSize(coordSeq, &size);
- if (index < 0 || index >= size)
- throw std::runtime_error("Index out of bounds");
-SWIGINTERN VALUE
-SWIG_ruby_failed(void)
- return Qnil;
-/*@SWIG:%ruby_aux_method@*/
-SWIGINTERN VALUE SWIG_AUX_NUM2ULONG(VALUE *args)
- VALUE obj = args[0];
- VALUE type = TYPE(obj);
- unsigned long *res = (unsigned long *)(args[1]);
- *res = type == T_FIXNUM ? NUM2ULONG(obj) : rb_big2ulong(obj);
- return obj;
-/*@SWIG@*/
-SWIGINTERN int
-SWIG_AsVal_unsigned_SS_long (VALUE obj, unsigned long *val)
- if ((type == T_FIXNUM) || (type == T_BIGNUM)) {
- unsigned long v;
- VALUE a[2];
- a[0] = obj;
- a[1] = (VALUE)(&v);
- if (rb_rescue(RUBY_METHOD_FUNC(SWIG_AUX_NUM2ULONG), (VALUE)a, RUBY_METHOD_FUNC(SWIG_ruby_failed), 0) != Qnil) {
- if (val) *val = v;
- return SWIG_OK;
- return SWIG_TypeError;
-SWIG_AsVal_size_t (VALUE obj, size_t *val)
- unsigned long v;
- int res = SWIG_AsVal_unsigned_SS_long (obj, val ? &v : 0);
- if (SWIG_IsOK(res) && val) *val = static_cast< size_t >(v);
- return res;
-SWIGINTERN GeosCoordinateSequence *new_GeosCoordinateSequence(size_t size,size_t dims){
- return (GeosCoordinateSequence*) GEOSCoordSeq_create(size, dims);
-SWIGINTERN GeosCoordinateSequence *GeosCoordinateSequence_clone(GeosCoordinateSequence *self){
- GEOSCoordSeq coords = (GEOSCoordSeq) self;
- return (GeosCoordinateSequence*) GEOSCoordSeq_clone(coords);
-SWIGINTERN VALUE SWIG_AUX_NUM2DBL(VALUE *args)
- double *res = (double *)(args[1]);
- *res = (type == T_FLOAT ? NUM2DBL(obj) : (type == T_FIXNUM ? (double) FIX2INT(obj) : rb_big2dbl(obj)));
- return obj;
-/*@SWIG@*/
-SWIGINTERN int
-SWIG_AsVal_double (VALUE obj, double *val)
- if ((type == T_FLOAT) || (type == T_FIXNUM) || (type == T_BIGNUM)) {
- double v;
- VALUE a[2];
- a[0] = obj;
- if (rb_rescue(RUBY_METHOD_FUNC(SWIG_AUX_NUM2DBL), (VALUE)a, RUBY_METHOD_FUNC(SWIG_ruby_failed), 0) != Qnil) {
- return SWIG_OK;
-SWIGINTERN int GeosCoordinateSequence_setX(GeosCoordinateSequence *self,size_t idx,double val){
- checkCoordSeqBounds(coords, idx);
- return GEOSCoordSeq_setX(coords, idx, val);
-SWIGINTERN int GeosCoordinateSequence_setY(GeosCoordinateSequence *self,size_t idx,double val){
- return GEOSCoordSeq_setY(coords, idx, val);
-SWIGINTERN int GeosCoordinateSequence_setZ(GeosCoordinateSequence *self,size_t idx,double val){
- return GEOSCoordSeq_setZ(coords, idx, val);
-SWIGINTERN int GeosCoordinateSequence_setOrdinate(GeosCoordinateSequence *self,size_t idx,size_t dim,double val){
- return GEOSCoordSeq_setOrdinate(coords, idx, dim, val);
-SWIGINTERN double GeosCoordinateSequence_getX(GeosCoordinateSequence *self,size_t idx){
- double result;
- GEOSCoordSeq_getX(coords, idx, &result);
- return result;
- #define SWIG_From_double rb_float_new
-SWIGINTERN double GeosCoordinateSequence_getY(GeosCoordinateSequence *self,size_t idx){
- double result;
- GEOSCoordSeq_getY(coords, idx, &result);
- return result;
-SWIGINTERN double GeosCoordinateSequence_getZ(GeosCoordinateSequence *self,size_t idx){
- double result;
- GEOSCoordSeq_getZ(coords, idx, &result);
- return result;
-SWIGINTERN double GeosCoordinateSequence_getOrdinate(GeosCoordinateSequence *self,size_t idx,size_t dim){
- double result;
- GEOSCoordSeq_getOrdinate(coords, idx, dim, &result);
- return result;
-SWIGINTERN unsigned int GeosCoordinateSequence_getSize(GeosCoordinateSequence *self){
- unsigned int result;
- GEOSCoordSeq_getSize(coords, &result);
- return result;
-SWIG_From_unsigned_SS_long (unsigned long value)
- return ULONG2NUM(value);
-SWIG_From_unsigned_SS_int (unsigned int value)
- return SWIG_From_unsigned_SS_long (value);
-SWIGINTERN unsigned int GeosCoordinateSequence_getDimensions(GeosCoordinateSequence *self){
- GEOSCoordSeq_getDimensions(coords, &result);
- return result;
-typedef void GeosGeometry;
-typedef void GeosPoint;
-typedef void GeosLineString;
-typedef void GeosLinearRing;
-typedef void GeosPolygon;
-typedef void GeosGeometryCollection;
-typedef void GeosMultiPoint;
-typedef void GeosMultiLineString;
-typedef void GeosMultiLinearRing;
-typedef void GeosMultiPolygon;
-typedef void GeosWktReader;
-typedef void GeosWktWriter;
-typedef void GeosWkbReader;
-typedef void GeosWkbWriter;
-bool checkBoolResult(char result)
- int intResult = (int) result;
- if (intResult == 1)
- return true;
- else if (intResult == 0)
- return false;
- else
- throw std::runtime_error(message);
-SWIGINTERN GeosGeometry *GeosGeometry_clone(GeosGeometry *self){
- GEOSGeom geom = (GEOSGeom) self;
- return GEOSGeom_clone(geom);
-SWIGINTERN char *GeosGeometry_geomType(GeosGeometry *self){
- return GEOSGeomType(geom);
-SWIGINTERN int GeosGeometry_typeId(GeosGeometry *self){
- return GEOSGeomTypeId(geom);
-SWIGINTERN void GeosGeometry_normalize(GeosGeometry *self){
- int result = GEOSNormalize(geom);
- if (result == -1)
-SWIGINTERN int GeosGeometry_getSRID(GeosGeometry *self){
- return GEOSGetSRID(geom);
-SWIGINTERN VALUE SWIG_AUX_NUM2LONG(VALUE *args)
- long *res = (long *)(args[1]);
- *res = type == T_FIXNUM ? NUM2LONG(obj) : rb_big2long(obj);
- return obj;
-/*@SWIG@*/
-SWIGINTERN int
-SWIG_AsVal_long (VALUE obj, long* val)
- long v;
- VALUE a[2];
- a[0] = obj;
- if (rb_rescue(RUBY_METHOD_FUNC(SWIG_AUX_NUM2LONG), (VALUE)a, RUBY_METHOD_FUNC(SWIG_ruby_failed), 0) != Qnil) {
- return SWIG_OK;
-SWIGINTERN int
-SWIG_AsVal_int (VALUE obj, int *val)
- long v;
- int res = SWIG_AsVal_long (obj, &v);
- if ((v < INT_MIN || v > INT_MAX)) {
- return SWIG_OverflowError;
- } else {
- if (val) *val = static_cast< int >(v);
- return res;
-SWIGINTERN void GeosGeometry_setSRID(GeosGeometry *self,int SRID){
- return GEOSSetSRID(geom, SRID);
-SWIGINTERN size_t GeosGeometry_getDimensions(GeosGeometry *self){
- return GEOSGeom_getDimensions(geom);
-SWIG_From_size_t (size_t value)
- return SWIG_From_unsigned_SS_long (static_cast< unsigned long >(value));
-SWIGINTERN size_t GeosGeometry_getNumGeometries(GeosGeometry *self){
- size_t result = GEOSGetNumGeometries(geom);
- if ((int)result == -1)
- return result;
-SWIGINTERN GeosGeometry *GeosGeometry_intersection(GeosGeometry *self,GeosGeometry *other){
- GEOSGeom otherGeom = (GEOSGeom) other;
- return (GeosGeometry*) GEOSIntersection(geom, otherGeom);
-SWIGINTERN GeosGeometry *GeosGeometry_buffer(GeosGeometry *self,double width,int quadsegs){
- return (GeosGeometry*) GEOSBuffer(geom, width, quadsegs);
-SWIGINTERN GeosGeometry *GeosGeometry_convexHull(GeosGeometry *self){
- return (GeosGeometry*) GEOSConvexHull(geom);
-SWIGINTERN GeosGeometry *GeosGeometry_difference(GeosGeometry *self,GeosGeometry *other){
- return (GeosGeometry*) GEOSDifference(geom, otherGeom);
-SWIGINTERN GeosGeometry *GeosGeometry_symDifference(GeosGeometry *self,GeosGeometry *other){
- return (GeosGeometry*) GEOSSymDifference(geom, otherGeom);
-SWIGINTERN GeosGeometry *GeosGeometry_boundary(GeosGeometry *self){
- return (GeosGeometry*) GEOSBoundary(geom);
-SWIGINTERN GeosGeometry *GeosGeometry_geomUnion(GeosGeometry *self,GeosGeometry *other){
- return (GeosGeometry*) GEOSUnion(geom, otherGeom);
-SWIGINTERN GeosGeometry *GeosGeometry_pointOnSurface(GeosGeometry *self){
- return (GeosGeometry*) GEOSPointOnSurface(geom);
-SWIGINTERN GeosGeometry *GeosGeometry_getCentroid(GeosGeometry *self){
- return (GeosGeometry*) GEOSGetCentroid(geom);
-SWIGINTERN GeosGeometry *GeosGeometry_getEnvelope(GeosGeometry *self){
- return (GeosGeometry*) GEOSEnvelope(geom);
-SWIGINTERN char *GeosGeometry_relate(GeosGeometry *self,GeosGeometry *other){
- return GEOSRelate(geom, otherGeom);
-SWIGINTERN GeosGeometry *GeosGeometry_lineMerge(GeosGeometry *self){
- return GEOSLineMerge(geom);
-SWIGINTERN GeosGeometry *GeosGeometry_simplify(GeosGeometry *self,double tolerance){
- return (GeosGeometry*) GEOSSimplify(geom, tolerance);
-SWIGINTERN GeosGeometry *GeosGeometry_topologyPreserveSimplify(GeosGeometry *self,double tolerance){
- return (GeosGeometry*) GEOSTopologyPreserveSimplify(geom, tolerance);
-SWIGINTERN int
-SWIG_AsCharPtrAndSize(VALUE obj, char** cptr, size_t* psize, int *alloc)
- if (TYPE(obj) == T_STRING) {
- char *cstr = STR2CSTR(obj);
- size_t size = RSTRING_LEN(obj) + 1;
- if (cptr) {
- if (alloc) {
- if (*alloc == SWIG_NEWOBJ) {
- *cptr = reinterpret_cast< char* >(memcpy((new char[size]), cstr, sizeof(char)*(size)));
- } else {
- *cptr = cstr;
- *alloc = SWIG_OLDOBJ;
- if (psize) *psize = size;
- return SWIG_OK;
- } else {
- if (pchar_descriptor) {
- void* vptr = 0;
- if (SWIG_ConvertPtr(obj, &vptr, pchar_descriptor, 0) == SWIG_OK) {
- if (cptr) *cptr = (char *)vptr;
- if (psize) *psize = vptr ? (strlen((char*)vptr) + 1) : 0;
- if (alloc) *alloc = SWIG_OLDOBJ;
- return SWIG_OK;
-SWIGINTERN bool GeosGeometry_relatePattern(GeosGeometry *self,GeosGeometry const *other,char const *pat){
- return checkBoolResult(GEOSRelatePattern(geom, otherGeom, pat));
-SWIG_From_bool (bool value)
- return value ? Qtrue : Qfalse;
-SWIGINTERN bool GeosGeometry_disjoint(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSDisjoint(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_touches(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSTouches(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_intersects(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSIntersects(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_crosses(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSCrosses(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_within(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSWithin(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_contains(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSContains(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_overlaps(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSOverlaps(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_equals(GeosGeometry *self,GeosGeometry const *other){
- return checkBoolResult(GEOSEquals(geom, otherGeom));
-SWIGINTERN bool GeosGeometry_equalsExact(GeosGeometry *self,GeosGeometry const *other,double tolerance){
- return checkBoolResult(GEOSEqualsExact(geom, otherGeom, tolerance));
-SWIGINTERN bool GeosGeometry_isEmpty(GeosGeometry *self){
- return checkBoolResult(GEOSisEmpty(geom));
-SWIGINTERN bool GeosGeometry_isValid(GeosGeometry *self){
- return checkBoolResult(GEOSisValid(geom));
-SWIGINTERN bool GeosGeometry_isSimple(GeosGeometry *self){
- return checkBoolResult(GEOSisSimple(geom));
-SWIGINTERN bool GeosGeometry_isRing(GeosGeometry *self){
- return checkBoolResult(GEOSisRing(geom));
-SWIGINTERN bool GeosGeometry_hasZ(GeosGeometry *self){
- return checkBoolResult(GEOSHasZ(geom));
-SWIGINTERN double GeosGeometry_area(GeosGeometry *self){
- double result;
- int code = GEOSArea(geom, &result);
- if (code == 0)
- return result;
-SWIGINTERN double GeosGeometry_length(GeosGeometry *self){
- double result;
- int code = GEOSLength(geom, &result);
- if (code == 0)
- return result;
-SWIGINTERN double GeosGeometry_distance(GeosGeometry *self,GeosGeometry const *other){
- double result;
- int code = GEOSDistance(geom, otherGeom, &result);
- if (code == 0)
- return result;
-SWIGINTERN GeosCoordinateSequence const *GeosPoint_getCoordSeq(GeosPoint *self){
- const GEOSCoordSeq result = (const GEOSCoordSeq) GEOSGeom_getCoordSeq(geom);
- if (result == NULL)
- return (const GeosCoordinateSequence*) result;
-SWIGINTERN GeosCoordinateSequence const *GeosLineString_getCoordSeq(GeosLineString *self){
-SWIGINTERN GeosCoordinateSequence const *GeosLinearRing_getCoordSeq(GeosLinearRing *self){
-SWIGINTERN GeosGeometry const *GeosPolygon_getExteriorRing(GeosPolygon *self){
- const GEOSGeom result = (const GEOSGeom) GEOSGetExteriorRing(geom);
- return (const GeosGeometry*) result;
-SWIGINTERN size_t GeosPolygon_getNumInteriorRings(GeosPolygon *self){
- size_t result = GEOSGetNumInteriorRings(geom);
- return result;
-SWIGINTERN GeosGeometry const *GeosPolygon_getInteriorRingN(GeosPolygon *self,size_t n){
- size_t size = GEOSGetNumInteriorRings(geom);
- if (n < 0 || n >= size)
- const GEOSGeom result = (const GEOSGeom) GEOSGetInteriorRingN(geom, n);
-SWIGINTERN GeosGeometry const *GeosGeometryCollection_getGeometryN(GeosGeometryCollection *self,size_t n){
- const GEOSGeom result = (const GEOSGeom) GEOSGetGeometryN(geom, n);
-GeosGeometry *createPoint(GeosCoordinateSequence *s)
- GEOSCoordSeq coords = (GEOSCoordSeq) s;
- GEOSGeom geom = GEOSGeom_createPoint(coords);
- if(geom == NULL)
- return (GeosGeometry*) geom;
-GeosGeometry *createLineString(GeosCoordinateSequence *s)
- GEOSGeom geom = GEOSGeom_createLineString(coords);
- if(geom == NULL)
-GeosGeometry *createLinearRing(GeosCoordinateSequence *s)
- GEOSGeom geom = GEOSGeom_createLinearRing(coords);
- if(geom == NULL)
-GeosGeometry *createPolygon(GeosLinearRing *shell, GeosLinearRing **holes, size_t nholes)
- GEOSGeom shellGeom = (GEOSGeom) shell;
- GEOSGeom* holeGeoms = (GEOSGeom*) holes;
- GEOSGeom geom = GEOSGeom_createPolygon(shellGeom, holeGeoms, nholes);
- if(geom == NULL)
-SWIGINTERN GeosWktReader *new_GeosWktReader(){
- return GEOSWKTReader_create();
-SWIGINTERN GeosGeometry *GeosWktReader_read(GeosWktReader *self,char const *wkt){
- if(wkt == NULL)
- throw std::runtime_error("Trying to create geometry from a NULL string");
- GEOSWKTReader *reader = (GEOSWKTReader*) self;
- GEOSGeometry *geom = GEOSWKTReader_read(reader, wkt);
- if(geom == NULL)
-SWIGINTERN GeosWktWriter *new_GeosWktWriter(){
- return GEOSWKTWriter_create();
-SWIGINTERN char *GeosWktWriter_write(GeosWktWriter *self,GeosGeometry const *g){
- GEOSWKTWriter *writer = (GEOSWKTWriter*) self;
- GEOSGeom geom = (GEOSGeom) g;
- return GEOSWKTWriter_write(writer, geom);
-SWIGINTERN GeosWkbReader *new_GeosWkbReader(){
- return GEOSWKBReader_create();
-SWIGINTERN GeosGeometry *GeosWkbReader_read(GeosWkbReader *self,unsigned char const *wkb,size_t size){
- if(wkb == NULL)
- GEOSWKBReader *reader = (GEOSWKBReader*) self;
- GEOSGeometry *geom = GEOSWKBReader_read(reader, wkb, size);
- if(geom == NULL)
-SWIGINTERN GeosGeometry *GeosWkbReader_readHEX(GeosWkbReader *self,unsigned char const *wkb,size_t size){
- if(wkb == NULL)
- GEOSGeometry *geom = GEOSWKBReader_readHEX(reader, wkb, size);
- if(geom == NULL)
-SWIGINTERN GeosWkbWriter *new_GeosWkbWriter(){
- return GEOSWKBWriter_create();
-SWIGINTERN int GeosWkbWriter_getOutputDimension(GeosWkbWriter *self){
- GEOSWKBWriter *writer = (GEOSWKBWriter*) self;
- return GEOSWKBWriter_getOutputDimension(writer);
-SWIGINTERN void GeosWkbWriter_setOutputDimension(GeosWkbWriter *self,int newDimension){
- GEOSWKBWriter_setOutputDimension(writer, newDimension);
-SWIGINTERN int GeosWkbWriter_getByteOrder(GeosWkbWriter *self){
- return GEOSWKBWriter_getByteOrder(writer);
-SWIGINTERN void GeosWkbWriter_setByteOrder(GeosWkbWriter *self,int newByteOrder){
- return GEOSWKBWriter_setByteOrder(writer, newByteOrder);
-SWIGINTERN bool GeosWkbWriter_getIncludeSRID(GeosWkbWriter *self){
- return GEOSWKBWriter_getIncludeSRID(writer);
-SWIGINTERN int
-SWIG_AsVal_bool (VALUE obj, bool *val)
- if (obj == Qtrue) {
- if (val) *val = true;
- return SWIG_OK;
- } else if (obj == Qfalse) {
- if (val) *val = false;
- return SWIG_OK;
- } else {
- int res = 0;
- if (SWIG_AsVal_int (obj, &res) == SWIG_OK) {
- if (val) *val = res ? true : false;
- return SWIG_OK;
-SWIGINTERN void GeosWkbWriter_setIncludeSRID(GeosWkbWriter *self,bool newIncludeSRID){
- return GEOSWKBWriter_setIncludeSRID(writer, newIncludeSRID);
-SWIGINTERN unsigned char *GeosWkbWriter_write(GeosWkbWriter *self,GeosGeometry const *g,size_t *size){
- return GEOSWKBWriter_write(writer, geom, size);
-SWIGINTERN unsigned char *GeosWkbWriter_writeHEX(GeosWkbWriter *self,GeosGeometry const *g,size_t *size){
- return GEOSWKBWriter_writeHEX(writer, geom, size);
-SWIGINTERN VALUE
-_wrap_version(int argc, VALUE *argv, VALUE self) {
- char *result = 0 ;
- VALUE vresult = Qnil;
- if ((argc < 0) || (argc > 0)) {
- rb_raise(rb_eArgError, "wrong # of arguments(%d for 0)",argc); SWIG_fail;
- result = (char *)GEOSversion();
- vresult = SWIG_FromCharPtr((const char *)result);
- return vresult;
-fail:
- return Qnil;
-swig_class cCoordinateSequence;
-#ifdef HAVE_RB_DEFINE_ALLOC_FUNC
-SWIGINTERN VALUE
-_wrap_CoordinateSequence_allocate(VALUE self) {
-#else
- SWIGINTERN VALUE
- _wrap_CoordinateSequence_allocate(int argc, VALUE *argv, VALUE self) {
-#endif
- VALUE vresult = SWIG_NewClassInstance(self, SWIGTYPE_p_GeosCoordinateSequence);
- rb_obj_call_init(vresult, argc, argv);
-#endif
- return vresult;
-SWIGINTERN VALUE
-_wrap_new_CoordinateSequence(int argc, VALUE *argv, VALUE self) {
- size_t arg1 ;
- size_t arg2 ;
- GeosCoordinateSequence *result = 0 ;
- size_t val1 ;
- int ecode1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if ((argc < 2) || (argc > 2)) {
- rb_raise(rb_eArgError, "wrong # of arguments(%d for 2)",argc); SWIG_fail;
- ecode1 = SWIG_AsVal_size_t(argv[0], &val1);
- if (!SWIG_IsOK(ecode1)) {
- SWIG_exception_fail(SWIG_ArgError(ecode1), "in method '" "GeosCoordinateSequence" "', argument " "1"" of type '" "size_t""'");
- arg1 = static_cast< size_t >(val1);
- ecode2 = SWIG_AsVal_size_t(argv[1], &val2);
- if (!SWIG_IsOK(ecode2)) {
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "GeosCoordinateSequence" "', argument " "2"" of type '" "size_t""'");
- arg2 = static_cast< size_t >(val2);
- try
- result = (GeosCoordinateSequence *)new_GeosCoordinateSequence(arg1,arg2);DATA_PTR(self) = result;
- catch (const std::exception& e)
- SWIG_exception(SWIG_RuntimeError, e.what());
- return self;
-fail:
- return Qnil;
-SWIGINTERN void delete_GeosCoordinateSequence(GeosCoordinateSequence *self){
- return GEOSCoordSeq_destroy(coords);
-SWIGINTERN void
-free_GeosCoordinateSequence(GeosCoordinateSequence *arg1) {
- delete_GeosCoordinateSequence(arg1);
-SWIGINTERN VALUE
-_wrap_CoordinateSequence_clone(int argc, VALUE *argv, VALUE self) {
- GeosCoordinateSequence *arg1 = (GeosCoordinateSequence *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosCoordinateSequence, 0 | 0 );
- if (!SWIG_IsOK(res1)) {
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "clone" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- arg1 = reinterpret_cast< GeosCoordinateSequence * >(argp1);
- try
- result = (GeosCoordinateSequence *)GeosCoordinateSequence_clone(arg1);
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosCoordinateSequence, SWIG_POINTER_OWN | 0 );
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_CoordinateSequence_set_x(int argc, VALUE *argv, VALUE self) {
- size_t arg2 ;
- double arg3 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "setX" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- ecode2 = SWIG_AsVal_size_t(argv[0], &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "setX" "', argument " "2"" of type '" "size_t""'");
- ecode3 = SWIG_AsVal_double(argv[1], &val3);
- if (!SWIG_IsOK(ecode3)) {
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "setX" "', argument " "3"" of type '" "double""'");
- arg3 = static_cast< double >(val3);
- try
- result = (int)GeosCoordinateSequence_setX(arg1,arg2,arg3);
- vresult = SWIG_From_int(static_cast< int >(result));
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_CoordinateSequence_set_y(int argc, VALUE *argv, VALUE self) {
- size_t arg2 ;
- double arg3 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "setY" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "setY" "', argument " "2"" of type '" "size_t""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "setY" "', argument " "3"" of type '" "double""'");
- try
- result = (int)GeosCoordinateSequence_setY(arg1,arg2,arg3);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_CoordinateSequence_set_z(int argc, VALUE *argv, VALUE self) {
- size_t arg2 ;
- double arg3 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "setZ" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "setZ" "', argument " "2"" of type '" "size_t""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "setZ" "', argument " "3"" of type '" "double""'");
- try
- result = (int)GeosCoordinateSequence_setZ(arg1,arg2,arg3);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_CoordinateSequence_set_ordinate(int argc, VALUE *argv, VALUE self) {
- size_t arg2 ;
- size_t arg3 ;
- double arg4 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- size_t val3 ;
- int ecode3 = 0 ;
- double val4 ;
- int ecode4 = 0 ;
- if ((argc < 3) || (argc > 3)) {
- rb_raise(rb_eArgError, "wrong # of arguments(%d for 3)",argc); SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "setOrdinate" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "setOrdinate" "', argument " "2"" of type '" "size_t""'");
- ecode3 = SWIG_AsVal_size_t(argv[1], &val3);
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "setOrdinate" "', argument " "3"" of type '" "size_t""'");
- arg3 = static_cast< size_t >(val3);
- ecode4 = SWIG_AsVal_double(argv[2], &val4);
- if (!SWIG_IsOK(ecode4)) {
- SWIG_exception_fail(SWIG_ArgError(ecode4), "in method '" "setOrdinate" "', argument " "4"" of type '" "double""'");
- arg4 = static_cast< double >(val4);
- try
- result = (int)GeosCoordinateSequence_setOrdinate(arg1,arg2,arg3,arg4);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_CoordinateSequence_get_x(int argc, VALUE *argv, VALUE self) {
- size_t arg2 ;
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- if ((argc < 1) || (argc > 1)) {
- rb_raise(rb_eArgError, "wrong # of arguments(%d for 1)",argc); SWIG_fail;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getX" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "getX" "', argument " "2"" of type '" "size_t""'");
- try
- result = (double)GeosCoordinateSequence_getX(arg1,arg2);
- vresult = SWIG_From_double(static_cast< double >(result));
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_CoordinateSequence_get_y(int argc, VALUE *argv, VALUE self) {
- size_t arg2 ;
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getY" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "getY" "', argument " "2"" of type '" "size_t""'");
- try
- result = (double)GeosCoordinateSequence_getY(arg1,arg2);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_CoordinateSequence_get_z(int argc, VALUE *argv, VALUE self) {
- size_t arg2 ;
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getZ" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "getZ" "', argument " "2"" of type '" "size_t""'");
- try
- result = (double)GeosCoordinateSequence_getZ(arg1,arg2);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_CoordinateSequence_get_ordinate(int argc, VALUE *argv, VALUE self) {
- size_t arg2 ;
- size_t arg3 ;
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- size_t val3 ;
- int ecode3 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getOrdinate" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "getOrdinate" "', argument " "2"" of type '" "size_t""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "getOrdinate" "', argument " "3"" of type '" "size_t""'");
- try
- result = (double)GeosCoordinateSequence_getOrdinate(arg1,arg2,arg3);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_CoordinateSequence___len__(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getSize" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- try
- result = (unsigned int)GeosCoordinateSequence_getSize(arg1);
- vresult = SWIG_From_unsigned_SS_int(static_cast< unsigned int >(result));
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_CoordinateSequence_dimensions(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getDimensions" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- try
- result = (unsigned int)GeosCoordinateSequence_getDimensions(arg1);
- return vresult;
-fail:
- return Qnil;
-swig_class cGeometry;
-SWIGINTERN void delete_GeosGeometry(GeosGeometry *self){
- GEOSGeom_destroy(geom);
-SWIGINTERN void
-free_GeosGeometry(GeosGeometry *arg1) {
- delete_GeosGeometry(arg1);
-SWIGINTERN VALUE
-_wrap_Geometry_clone(int argc, VALUE *argv, VALUE self) {
- GeosGeometry *arg1 = (GeosGeometry *) 0 ;
- GeosGeometry *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosGeometry, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "clone" "', argument " "1"" of type '" "GeosGeometry *""'");
- arg1 = reinterpret_cast< GeosGeometry * >(argp1);
- try
- result = (GeosGeometry *)GeosGeometry_clone(arg1);
- /* %typemap(out) GeosGeometry */
- SWIG_exception(SWIG_RuntimeError, message);
- GeosGeometry *geom = result;
- GEOSGeomTypes geomId = (GEOSGeomTypes)GEOSGeomTypeId((GEOSGeom) geom);
- switch (geomId)
- case GEOS_POINT:
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPoint, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_LINESTRING:
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLineString, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_LINEARRING:
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLinearRing, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_POLYGON:
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPolygon, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_MULTIPOINT:
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPoint, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_MULTILINESTRING:
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiLineString, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_MULTIPOLYGON:
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPolygon, 0 | SWIG_POINTER_OWN);
- break;
- case GEOS_GEOMETRYCOLLECTION:
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosGeometryCollection, 0 | SWIG_POINTER_OWN);
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_geom_type(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "geomType" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (char *)GeosGeometry_geomType(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_type_id(int argc, VALUE *argv, VALUE self) {
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "typeId" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (int)GeosGeometry_typeId(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_normalize(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "normalize" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- GeosGeometry_normalize(arg1);
- return Qnil;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_srid(int argc, VALUE *argv, VALUE self) {
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getSRID" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (int)GeosGeometry_getSRID(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_sride___(int argc, VALUE *argv, VALUE self) {
- int arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "setSRID" "', argument " "1"" of type '" "GeosGeometry *""'");
- ecode2 = SWIG_AsVal_int(argv[0], &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "setSRID" "', argument " "2"" of type '" "int""'");
- arg2 = static_cast< int >(val2);
- try
- GeosGeometry_setSRID(arg1,arg2);
- return Qnil;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_dimensions(int argc, VALUE *argv, VALUE self) {
- size_t result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getDimensions" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = GeosGeometry_getDimensions(arg1);
- vresult = SWIG_From_size_t(static_cast< size_t >(result));
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_num_geometries(int argc, VALUE *argv, VALUE self) {
- size_t result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getNumGeometries" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = GeosGeometry_getNumGeometries(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_intersection(int argc, VALUE *argv, VALUE self) {
- GeosGeometry *arg2 = (GeosGeometry *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "intersection" "', argument " "1"" of type '" "GeosGeometry *""'");
- res2 = SWIG_ConvertPtr(argv[0], &argp2,SWIGTYPE_p_GeosGeometry, 0 | 0 );
- if (!SWIG_IsOK(res2)) {
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "intersection" "', argument " "2"" of type '" "GeosGeometry *""'");
- arg2 = reinterpret_cast< GeosGeometry * >(argp2);
- try
- result = (GeosGeometry *)GeosGeometry_intersection(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_buffer(int argc, VALUE *argv, VALUE self) {
- double arg2 ;
- int arg3 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- int val3 ;
- int ecode3 = 0 ;
- arg3 = DEFAULT_QUADRANT_SEGMENTS;
- if ((argc < 1) || (argc > 2)) {
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "buffer" "', argument " "1"" of type '" "GeosGeometry *""'");
- ecode2 = SWIG_AsVal_double(argv[0], &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "buffer" "', argument " "2"" of type '" "double""'");
- arg2 = static_cast< double >(val2);
- if (argc > 1) {
- ecode3 = SWIG_AsVal_int(argv[1], &val3);
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "buffer" "', argument " "3"" of type '" "int""'");
- arg3 = static_cast< int >(val3);
- try
- result = (GeosGeometry *)GeosGeometry_buffer(arg1,arg2,arg3);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_convex_hull(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "convexHull" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_convexHull(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_difference(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "difference" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "difference" "', argument " "2"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_difference(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_sym_difference(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "symDifference" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "symDifference" "', argument " "2"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_symDifference(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_boundary(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "boundary" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_boundary(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_union(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "geomUnion" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "geomUnion" "', argument " "2"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_geomUnion(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_point_on_surface(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "pointOnSurface" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_pointOnSurface(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_centroid(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getCentroid" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_getCentroid(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_envelope(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getEnvelope" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_getEnvelope(arg1);
- switch (geomId)
- case GEOS_POINT:
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPoint, 0 | 0);
- break;
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLineString, 0 | 0);
- break;
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLinearRing, 0 | 0);
- break;
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPolygon, 0 | 0);
- break;
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPoint, 0 | 0);
- break;
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiLineString, 0 | 0);
- break;
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPolygon, 0 | 0);
- break;
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosGeometryCollection, 0 | 0);
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_relate(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "relate" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "relate" "', argument " "2"" of type '" "GeosGeometry *""'");
- try
- result = (char *)GeosGeometry_relate(arg1,arg2);
- delete[] result;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_line_merge(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "lineMerge" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (GeosGeometry *)GeosGeometry_lineMerge(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_simplify(int argc, VALUE *argv, VALUE self) {
- double arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "simplify" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "simplify" "', argument " "2"" of type '" "double""'");
- try
- result = (GeosGeometry *)GeosGeometry_simplify(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_topology_preserve_simplify(int argc, VALUE *argv, VALUE self) {
- double arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- double val2 ;
- int ecode2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "topologyPreserveSimplify" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "topologyPreserveSimplify" "', argument " "2"" of type '" "double""'");
- try
- result = (GeosGeometry *)GeosGeometry_topologyPreserveSimplify(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_relate_pattern(int argc, VALUE *argv, VALUE self) {
- char *arg3 = (char *) 0 ;
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- int res3 ;
- char *buf3 = 0 ;
- int alloc3 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "relatePattern" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "relatePattern" "', argument " "2"" of type '" "GeosGeometry const *""'");
- res3 = SWIG_AsCharPtrAndSize(argv[1], &buf3, NULL, &alloc3);
- if (!SWIG_IsOK(res3)) {
- SWIG_exception_fail(SWIG_ArgError(res3), "in method '" "relatePattern" "', argument " "3"" of type '" "char const *""'");
- arg3 = reinterpret_cast< char * >(buf3);
- try
- result = (bool)GeosGeometry_relatePattern(arg1,(GeosGeometry const *)arg2,(char const *)arg3);
- vresult = SWIG_From_bool(static_cast< bool >(result));
- if (alloc3 == SWIG_NEWOBJ) delete[] buf3;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_disjointq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "disjoint" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "disjoint" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_disjoint(arg1,(GeosGeometry const *)arg2);
- vresult = (result ? Qtrue : Qfalse);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_touchesq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "touches" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "touches" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_touches(arg1,(GeosGeometry const *)arg2);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_intersectsq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "intersects" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "intersects" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_intersects(arg1,(GeosGeometry const *)arg2);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_crossesq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "crosses" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "crosses" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_crosses(arg1,(GeosGeometry const *)arg2);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_withinq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "within" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "within" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_within(arg1,(GeosGeometry const *)arg2);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_containsq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "contains" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "contains" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_contains(arg1,(GeosGeometry const *)arg2);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_overlapsq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "overlaps" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "overlaps" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_overlaps(arg1,(GeosGeometry const *)arg2);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_eqlq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "equals" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "equals" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (bool)GeosGeometry_equals(arg1,(GeosGeometry const *)arg2);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_eql_exactq___(int argc, VALUE *argv, VALUE self) {
- double arg3 ;
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- double val3 ;
- int ecode3 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "equalsExact" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "equalsExact" "', argument " "2"" of type '" "GeosGeometry const *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode3), "in method '" "equalsExact" "', argument " "3"" of type '" "double""'");
- try
- result = (bool)GeosGeometry_equalsExact(arg1,(GeosGeometry const *)arg2,arg3);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_emptyq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "isEmpty" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (bool)GeosGeometry_isEmpty(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_validq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "isValid" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (bool)GeosGeometry_isValid(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_simpleq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "isSimple" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (bool)GeosGeometry_isSimple(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_ringq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "isRing" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (bool)GeosGeometry_isRing(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_has_zq___(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "hasZ" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (bool)GeosGeometry_hasZ(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_area(int argc, VALUE *argv, VALUE self) {
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "area" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (double)GeosGeometry_area(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_length(int argc, VALUE *argv, VALUE self) {
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "length" "', argument " "1"" of type '" "GeosGeometry *""'");
- try
- result = (double)GeosGeometry_length(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Geometry_distance(int argc, VALUE *argv, VALUE self) {
- double result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "distance" "', argument " "1"" of type '" "GeosGeometry *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "distance" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (double)GeosGeometry_distance(arg1,(GeosGeometry const *)arg2);
- return vresult;
-fail:
- return Qnil;
-swig_class cPoint;
-SWIGINTERN void delete_GeosPoint(GeosPoint *self){
-SWIGINTERN void
-free_GeosPoint(GeosPoint *arg1) {
- delete_GeosPoint(arg1);
-SWIGINTERN VALUE
-_wrap_Point_coord_seq(int argc, VALUE *argv, VALUE self) {
- GeosPoint *arg1 = (GeosPoint *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosPoint, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getCoordSeq" "', argument " "1"" of type '" "GeosPoint *""'");
- arg1 = reinterpret_cast< GeosPoint * >(argp1);
- try
- result = (GeosCoordinateSequence *)GeosPoint_getCoordSeq(arg1);
- vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosCoordinateSequence, 0 | 0 );
- return vresult;
-fail:
- return Qnil;
-swig_class cLineString;
-SWIGINTERN void delete_GeosLineString(GeosLineString *self){
-SWIGINTERN void
-free_GeosLineString(GeosLineString *arg1) {
- delete_GeosLineString(arg1);
-SWIGINTERN VALUE
-_wrap_LineString_coord_seq(int argc, VALUE *argv, VALUE self) {
- GeosLineString *arg1 = (GeosLineString *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosLineString, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getCoordSeq" "', argument " "1"" of type '" "GeosLineString *""'");
- arg1 = reinterpret_cast< GeosLineString * >(argp1);
- try
- result = (GeosCoordinateSequence *)GeosLineString_getCoordSeq(arg1);
- return vresult;
-fail:
- return Qnil;
-swig_class cLinearRing;
-SWIGINTERN void delete_GeosLinearRing(GeosLinearRing *self){
-SWIGINTERN void
-free_GeosLinearRing(GeosLinearRing *arg1) {
- delete_GeosLinearRing(arg1);
-SWIGINTERN VALUE
-_wrap_LinearRing_coord_seq(int argc, VALUE *argv, VALUE self) {
- GeosLinearRing *arg1 = (GeosLinearRing *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosLinearRing, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getCoordSeq" "', argument " "1"" of type '" "GeosLinearRing *""'");
- arg1 = reinterpret_cast< GeosLinearRing * >(argp1);
- try
- result = (GeosCoordinateSequence *)GeosLinearRing_getCoordSeq(arg1);
- return vresult;
-fail:
- return Qnil;
-swig_class cPolygon;
-SWIGINTERN void delete_GeosPolygon(GeosPolygon *self){
-SWIGINTERN void
-free_GeosPolygon(GeosPolygon *arg1) {
- delete_GeosPolygon(arg1);
-SWIGINTERN VALUE
-_wrap_Polygon_exterior_ring(int argc, VALUE *argv, VALUE self) {
- GeosPolygon *arg1 = (GeosPolygon *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosPolygon, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getExteriorRing" "', argument " "1"" of type '" "GeosPolygon *""'");
- arg1 = reinterpret_cast< GeosPolygon * >(argp1);
- try
- result = (GeosGeometry *)GeosPolygon_getExteriorRing(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Polygon_num_interior_rings(int argc, VALUE *argv, VALUE self) {
- size_t result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getNumInteriorRings" "', argument " "1"" of type '" "GeosPolygon *""'");
- try
- result = GeosPolygon_getNumInteriorRings(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_Polygon_interior_ring_n(int argc, VALUE *argv, VALUE self) {
- size_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getInteriorRingN" "', argument " "1"" of type '" "GeosPolygon *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "getInteriorRingN" "', argument " "2"" of type '" "size_t""'");
- try
- result = (GeosGeometry *)GeosPolygon_getInteriorRingN(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-swig_class cGeometryCollection;
-SWIGINTERN void delete_GeosGeometryCollection(GeosGeometryCollection *self){
-SWIGINTERN void
-free_GeosGeometryCollection(GeosGeometryCollection *arg1) {
- delete_GeosGeometryCollection(arg1);
-SWIGINTERN VALUE
-_wrap_GeometryCollection_get_geometry_n(int argc, VALUE *argv, VALUE self) {
- GeosGeometryCollection *arg1 = (GeosGeometryCollection *) 0 ;
- size_t arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- size_t val2 ;
- int ecode2 = 0 ;
- res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosGeometryCollection, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getGeometryN" "', argument " "1"" of type '" "GeosGeometryCollection *""'");
- arg1 = reinterpret_cast< GeosGeometryCollection * >(argp1);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "getGeometryN" "', argument " "2"" of type '" "size_t""'");
- try
- result = (GeosGeometry *)GeosGeometryCollection_getGeometryN(arg1,arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-swig_class cMultiPoint;
-SWIGINTERN void delete_GeosMultiPoint(GeosMultiPoint *self){
-SWIGINTERN void
-free_GeosMultiPoint(GeosMultiPoint *arg1) {
- delete_GeosMultiPoint(arg1);
-swig_class cMultiLineString;
-SWIGINTERN void delete_GeosMultiLineString(GeosMultiLineString *self){
-SWIGINTERN void
-free_GeosMultiLineString(GeosMultiLineString *arg1) {
- delete_GeosMultiLineString(arg1);
-swig_class cMultiLinearRing;
-SWIGINTERN void delete_GeosMultiLinearRing(GeosMultiLinearRing *self){
-SWIGINTERN void
-free_GeosMultiLinearRing(GeosMultiLinearRing *arg1) {
- delete_GeosMultiLinearRing(arg1);
-swig_class cMultiPolygon;
-SWIGINTERN void delete_GeosMultiPolygon(GeosMultiPolygon *self){
-SWIGINTERN void
-free_GeosMultiPolygon(GeosMultiPolygon *arg1) {
- delete_GeosMultiPolygon(arg1);
-SWIGINTERN VALUE
-_wrap_create_point(int argc, VALUE *argv, VALUE self) {
- int res1 = 0 ;
- res1 = SWIG_ConvertPtr(argv[0], SWIG_as_voidptrptr(&arg1), SWIGTYPE_p_GeosCoordinateSequence, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "createPoint" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- try
- result = (GeosGeometry *)createPoint(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_create_line_string(int argc, VALUE *argv, VALUE self) {
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "createLineString" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- try
- result = (GeosGeometry *)createLineString(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_create_linear_ring(int argc, VALUE *argv, VALUE self) {
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "createLinearRing" "', argument " "1"" of type '" "GeosCoordinateSequence *""'");
- try
- result = (GeosGeometry *)createLinearRing(arg1);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_create_polygon(int argc, VALUE *argv, VALUE self) {
- GeosLinearRing **arg2 = (GeosLinearRing **) 0 ;
- size_t arg3 ;
- int res1 = 0 ;
- arg2 = NULL;
- arg3 = 0;
- res1 = SWIG_ConvertPtr(argv[0], SWIG_as_voidptrptr(&arg1), SWIGTYPE_p_GeosLinearRing, SWIG_POINTER_DISOWN | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "createPolygon" "', argument " "1"" of type '" "GeosLinearRing *""'");
- if (argc > 1) {
- if (NIL_P(argv[1]))
- arg2 = NULL;
- arg3 = 0;
- else
- /* Make sure the input can be treated as an array. */
- Check_Type(argv[1], T_ARRAY);
- /* Get the length */
- arg3 = RARRAY(argv[1])->len;
- /* Allocate space for the C array. */
- arg2 = (GeosLinearRing**) malloc(arg3*sizeof(GeosLinearRing*));
- for(size_t i = 0; i<arg3; i++)
- /* Get the Ruby Object */
- VALUE item = rb_ary_entry(argv[1],i);
- /* Get the underlying pointer and give up ownership of it. */
- GeosLinearRing *ring = NULL;
- int convertResult = SWIG_ConvertPtr(item, (void**)&ring, SWIGTYPE_p_GeosLinearRing, SWIG_POINTER_DISOWN);
- if (!SWIG_IsOK(convertResult)) {
- SWIG_exception_fail(SWIG_ArgError(convertResult), "in method '" "createPolygon" "', argument " "1"" of type '" "GeosLinearRing *""'");
- /* Put the pointer in the array */
- arg2[i] = ring;
- try
- result = (GeosGeometry *)createPolygon(arg1,arg2,arg3);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- if (arg2) {
- free((void*) arg2);
- return vresult;
-fail:
- if (arg2) {
- return Qnil;
-swig_class cWktReader;
-SWIGINTERN VALUE
-_wrap_WktReader_allocate(VALUE self) {
-#else
- SWIGINTERN VALUE
- _wrap_WktReader_allocate(int argc, VALUE *argv, VALUE self) {
-#endif
- VALUE vresult = SWIG_NewClassInstance(self, SWIGTYPE_p_GeosWktReader);
-#ifndef HAVE_RB_DEFINE_ALLOC_FUNC
-#endif
- return vresult;
-SWIGINTERN VALUE
-_wrap_new_WktReader(int argc, VALUE *argv, VALUE self) {
- GeosWktReader *result = 0 ;
- try
- result = (GeosWktReader *)new_GeosWktReader();DATA_PTR(self) = result;
- return self;
-fail:
- return Qnil;
-SWIGINTERN void delete_GeosWktReader(GeosWktReader *self){
- GEOSWKTReader_destroy(reader);
-SWIGINTERN void
-free_GeosWktReader(GeosWktReader *arg1) {
- delete_GeosWktReader(arg1);
-SWIGINTERN VALUE
-_wrap_WktReader_read(int argc, VALUE *argv, VALUE self) {
- GeosWktReader *arg1 = (GeosWktReader *) 0 ;
- char *arg2 = (char *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int res2 ;
- char *buf2 = 0 ;
- int alloc2 = 0 ;
- res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosWktReader, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "read" "', argument " "1"" of type '" "GeosWktReader *""'");
- arg1 = reinterpret_cast< GeosWktReader * >(argp1);
- res2 = SWIG_AsCharPtrAndSize(argv[0], &buf2, NULL, &alloc2);
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "read" "', argument " "2"" of type '" "char const *""'");
- arg2 = reinterpret_cast< char * >(buf2);
- try
- result = (GeosGeometry *)GeosWktReader_read(arg1,(char const *)arg2);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- if (alloc2 == SWIG_NEWOBJ) delete[] buf2;
- return vresult;
-fail:
- return Qnil;
-swig_class cWktWriter;
-SWIGINTERN VALUE
-_wrap_WktWriter_allocate(VALUE self) {
-#else
- SWIGINTERN VALUE
- _wrap_WktWriter_allocate(int argc, VALUE *argv, VALUE self) {
-#endif
- VALUE vresult = SWIG_NewClassInstance(self, SWIGTYPE_p_GeosWktWriter);
-#endif
- return vresult;
-SWIGINTERN VALUE
-_wrap_new_WktWriter(int argc, VALUE *argv, VALUE self) {
- GeosWktWriter *result = 0 ;
- try
- result = (GeosWktWriter *)new_GeosWktWriter();DATA_PTR(self) = result;
- return self;
-fail:
- return Qnil;
-SWIGINTERN void delete_GeosWktWriter(GeosWktWriter *self){
- GEOSWKTWriter_destroy(writer);
-SWIGINTERN void
-free_GeosWktWriter(GeosWktWriter *arg1) {
- delete_GeosWktWriter(arg1);
-SWIGINTERN VALUE
-_wrap_WktWriter_write(int argc, VALUE *argv, VALUE self) {
- GeosWktWriter *arg1 = (GeosWktWriter *) 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosWktWriter, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "write" "', argument " "1"" of type '" "GeosWktWriter *""'");
- arg1 = reinterpret_cast< GeosWktWriter * >(argp1);
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "write" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (char *)GeosWktWriter_write(arg1,(GeosGeometry const *)arg2);
- return vresult;
-fail:
- return Qnil;
-swig_class cWkbReader;
-SWIGINTERN VALUE
-_wrap_WkbReader_allocate(VALUE self) {
-#else
- SWIGINTERN VALUE
- _wrap_WkbReader_allocate(int argc, VALUE *argv, VALUE self) {
-#endif
- VALUE vresult = SWIG_NewClassInstance(self, SWIGTYPE_p_GeosWkbReader);
-#endif
- return vresult;
-SWIGINTERN VALUE
-_wrap_new_WkbReader(int argc, VALUE *argv, VALUE self) {
- GeosWkbReader *result = 0 ;
- try
- result = (GeosWkbReader *)new_GeosWkbReader();DATA_PTR(self) = result;
- return self;
-fail:
- return Qnil;
-SWIGINTERN void delete_GeosWkbReader(GeosWkbReader *self){
- GEOSWKBReader_destroy(reader);
-SWIGINTERN void
-free_GeosWkbReader(GeosWkbReader *arg1) {
- delete_GeosWkbReader(arg1);
-SWIGINTERN VALUE
-_wrap_WkbReader_read(int argc, VALUE *argv, VALUE self) {
- GeosWkbReader *arg1 = (GeosWkbReader *) 0 ;
- unsigned char *arg2 = (unsigned char *) 0 ;
- size_t arg3 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int alloc2 = 0 ;
- res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosWkbReader, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "read" "', argument " "1"" of type '" "GeosWkbReader *""'");
- arg1 = reinterpret_cast< GeosWkbReader * >(argp1);
- /* %typemap(in) (const unsigned char* wkb, size_t size) (int alloc2 = 0) */
- if (SWIG_AsCharPtrAndSize(argv[0], (char**)&arg2, &arg3, &alloc2) != SWIG_OK)
- SWIG_exception(SWIG_RuntimeError, "Expecting a string");
- /* Don't want to include last null character! */
- arg3--;
- try
- result = (GeosGeometry *)GeosWkbReader_read(arg1,(unsigned char const *)arg2,arg3);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_WkbReader_read_hex(int argc, VALUE *argv, VALUE self) {
- size_t arg3 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int alloc2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "readHEX" "', argument " "1"" of type '" "GeosWkbReader *""'");
- arg3--;
- try
- result = (GeosGeometry *)GeosWkbReader_readHEX(arg1,(unsigned char const *)arg2,arg3);
- switch (geomId)
- case GEOS_POINT:
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- break;
- return vresult;
-fail:
- return Qnil;
-swig_class cWkbWriter;
-SWIGINTERN VALUE
-_wrap_WkbWriter_allocate(VALUE self) {
-#else
- SWIGINTERN VALUE
- _wrap_WkbWriter_allocate(int argc, VALUE *argv, VALUE self) {
-#endif
- VALUE vresult = SWIG_NewClassInstance(self, SWIGTYPE_p_GeosWkbWriter);
-#endif
- return vresult;
-SWIGINTERN VALUE
-_wrap_new_WkbWriter(int argc, VALUE *argv, VALUE self) {
- GeosWkbWriter *result = 0 ;
- try
- result = (GeosWkbWriter *)new_GeosWkbWriter();DATA_PTR(self) = result;
- return self;
-fail:
- return Qnil;
-SWIGINTERN void delete_GeosWkbWriter(GeosWkbWriter *self){
- GEOSWKBWriter_destroy(writer);
-SWIGINTERN void
-free_GeosWkbWriter(GeosWkbWriter *arg1) {
- delete_GeosWkbWriter(arg1);
-SWIGINTERN VALUE
-_wrap_WkbWriter_output_dimensions(int argc, VALUE *argv, VALUE self) {
- GeosWkbWriter *arg1 = (GeosWkbWriter *) 0 ;
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosWkbWriter, 0 | 0 );
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getOutputDimension" "', argument " "1"" of type '" "GeosWkbWriter *""'");
- arg1 = reinterpret_cast< GeosWkbWriter * >(argp1);
- try
- result = (int)GeosWkbWriter_getOutputDimension(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_WkbWriter_output_dimensionse___(int argc, VALUE *argv, VALUE self) {
- int arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "setOutputDimension" "', argument " "1"" of type '" "GeosWkbWriter *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "setOutputDimension" "', argument " "2"" of type '" "int""'");
- try
- GeosWkbWriter_setOutputDimension(arg1,arg2);
- return Qnil;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_WkbWriter_byte_order(int argc, VALUE *argv, VALUE self) {
- int result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getByteOrder" "', argument " "1"" of type '" "GeosWkbWriter *""'");
- try
- result = (int)GeosWkbWriter_getByteOrder(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_WkbWriter_byte_ordere___(int argc, VALUE *argv, VALUE self) {
- int arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- int val2 ;
- int ecode2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "setByteOrder" "', argument " "1"" of type '" "GeosWkbWriter *""'");
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "setByteOrder" "', argument " "2"" of type '" "int""'");
- try
- GeosWkbWriter_setByteOrder(arg1,arg2);
- return Qnil;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_WkbWriter_include_srid(int argc, VALUE *argv, VALUE self) {
- bool result;
- void *argp1 = 0 ;
- int res1 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "getIncludeSRID" "', argument " "1"" of type '" "GeosWkbWriter *""'");
- try
- result = (bool)GeosWkbWriter_getIncludeSRID(arg1);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_WkbWriter_include_sride___(int argc, VALUE *argv, VALUE self) {
- bool arg2 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- bool val2 ;
- int ecode2 = 0 ;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "setIncludeSRID" "', argument " "1"" of type '" "GeosWkbWriter *""'");
- ecode2 = SWIG_AsVal_bool(argv[0], &val2);
- SWIG_exception_fail(SWIG_ArgError(ecode2), "in method '" "setIncludeSRID" "', argument " "2"" of type '" "bool""'");
- arg2 = static_cast< bool >(val2);
- try
- GeosWkbWriter_setIncludeSRID(arg1,arg2);
- return Qnil;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_WkbWriter_write(int argc, VALUE *argv, VALUE self) {
- size_t *arg3 = (size_t *) 0 ;
- unsigned char *result = 0 ;
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- size_t temp3 = 0 ;
- /* %typemap(in, numinputs=0) size_t *size (size_t temp3 = 0) */
- arg3 = &temp3;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "write" "', argument " "1"" of type '" "GeosWkbWriter *""'");
- try
- result = (unsigned char *)GeosWkbWriter_write(arg1,(GeosGeometry const *)arg2,arg3);
- /* %typemap(out) unsigned char* */
- /* %typemap(argout) size_t *size */
- vresult = SWIG_FromCharPtrAndSize((const char*)result, *arg3);
- /* %typemap(freearg) size_t *size */
- std::free(result);
- return vresult;
-fail:
- return Qnil;
-SWIGINTERN VALUE
-_wrap_WkbWriter_write_hex(int argc, VALUE *argv, VALUE self) {
- void *argp1 = 0 ;
- int res1 = 0 ;
- void *argp2 = 0 ;
- int res2 = 0 ;
- arg3 = &temp3;
- SWIG_exception_fail(SWIG_ArgError(res1), "in method '" "writeHEX" "', argument " "1"" of type '" "GeosWkbWriter *""'");
- SWIG_exception_fail(SWIG_ArgError(res2), "in method '" "writeHEX" "', argument " "2"" of type '" "GeosGeometry const *""'");
- try
- result = (unsigned char *)GeosWkbWriter_writeHEX(arg1,(GeosGeometry const *)arg2,arg3);
- return vresult;
-fail:
- return Qnil;
-/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (BEGIN) -------- */
-static void *_p_GeosMultiPolygonTo_p_GeosGeometryCollection(void *x) {
- return (void *)((GeosGeometryCollection *) ((GeosMultiPolygon *) x));
-static void *_p_GeosMultiPointTo_p_GeosGeometryCollection(void *x) {
- return (void *)((GeosGeometryCollection *) ((GeosMultiPoint *) x));
-static void *_p_GeosMultiLineStringTo_p_GeosGeometryCollection(void *x) {
- return (void *)((GeosGeometryCollection *) ((GeosMultiLineString *) x));
-static void *_p_GeosMultiLinearRingTo_p_GeosGeometryCollection(void *x) {
- return (void *)((GeosGeometryCollection *) ((GeosMultiLinearRing *) x));
-static void *_p_GeosPolygonTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) ((GeosPolygon *) x));
-static void *_p_GeosMultiPolygonTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiPolygon *) x));
-static void *_p_GeosPointTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) ((GeosPoint *) x));
-static void *_p_GeosLineStringTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) ((GeosLineString *) x));
-static void *_p_GeosLinearRingTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) ((GeosLinearRing *) x));
-static void *_p_GeosMultiPointTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiPoint *) x));
-static void *_p_GeosMultiLineStringTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiLineString *) x));
-static void *_p_GeosMultiLinearRingTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiLinearRing *) x));
-static void *_p_GeosGeometryCollectionTo_p_GeosGeometry(void *x) {
- return (void *)((GeosGeometry *) ((GeosGeometryCollection *) x));
-static swig_type_info _swigt__p_GeosCoordinateSequence = {"_p_GeosCoordinateSequence", "GeosCoordinateSequence *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosGeometry = {"_p_GeosGeometry", "GeosGeometry *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosGeometryCollection = {"_p_GeosGeometryCollection", "GeosGeometryCollection *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosLineString = {"_p_GeosLineString", "GeosLineString *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosLinearRing = {"_p_GeosLinearRing", "GeosLinearRing *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosMultiLineString = {"_p_GeosMultiLineString", "GeosMultiLineString *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosMultiLinearRing = {"_p_GeosMultiLinearRing", "GeosMultiLinearRing *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosMultiPoint = {"_p_GeosMultiPoint", "GeosMultiPoint *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosMultiPolygon = {"_p_GeosMultiPolygon", "GeosMultiPolygon *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosPoint = {"_p_GeosPoint", "GeosPoint *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosPolygon = {"_p_GeosPolygon", "GeosPolygon *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosWkbReader = {"_p_GeosWkbReader", "GeosWkbReader *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosWkbWriter = {"_p_GeosWkbWriter", "GeosWkbWriter *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosWktReader = {"_p_GeosWktReader", "GeosWktReader *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_GeosWktWriter = {"_p_GeosWktWriter", "GeosWktWriter *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_char = {"_p_char", "char *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_p_GeosLinearRing = {"_p_p_GeosLinearRing", "GeosLinearRing **", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_size_t = {"_p_size_t", "size_t *", 0, 0, (void*)0, 0};
-static swig_type_info _swigt__p_unsigned_char = {"_p_unsigned_char", "unsigned char *", 0, 0, (void*)0, 0};
-static swig_type_info *swig_type_initial[] = {
- &_swigt__p_GeosCoordinateSequence,
- &_swigt__p_GeosGeometry,
- &_swigt__p_GeosGeometryCollection,
- &_swigt__p_GeosLineString,
- &_swigt__p_GeosLinearRing,
- &_swigt__p_GeosMultiLineString,
- &_swigt__p_GeosMultiLinearRing,
- &_swigt__p_GeosMultiPoint,
- &_swigt__p_GeosMultiPolygon,
- &_swigt__p_GeosPoint,
- &_swigt__p_GeosPolygon,
- &_swigt__p_GeosWkbReader,
- &_swigt__p_GeosWkbWriter,
- &_swigt__p_GeosWktReader,
- &_swigt__p_GeosWktWriter,
- &_swigt__p_char,
- &_swigt__p_p_GeosLinearRing,
- &_swigt__p_size_t,
- &_swigt__p_unsigned_char,
-static swig_cast_info _swigc__p_GeosCoordinateSequence[] = { {&_swigt__p_GeosCoordinateSequence, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosGeometry[] = { {&_swigt__p_GeosPolygon, _p_GeosPolygonTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiPolygon, _p_GeosMultiPolygonTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosPoint, _p_GeosPointTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosGeometry, 0, 0, 0}, {&_swigt__p_GeosLineString, _p_GeosLineStringTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosLinearRing, _p_GeosLinearRingTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiPoint, _p_GeosMultiPointTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiLineString, _p_GeosMultiLineStringTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiLinearRing, _p_GeosMultiLinearRingTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosGeometryCollection, _p_GeosGeometryCollectionTo_p_GeosGeometry, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosGeometryCollection[] = { {&_swigt__p_GeosMultiPolygon, _p_GeosMultiPolygonTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosMultiPoint, _p_GeosMultiPointTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosMultiLineString, _p_GeosMultiLineStringTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosMultiLinearRing, _p_GeosMultiLinearRingTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosGeometryCollection, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosLineString[] = { {&_swigt__p_GeosLineString, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosLinearRing[] = { {&_swigt__p_GeosLinearRing, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosMultiLineString[] = { {&_swigt__p_GeosMultiLineString, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosMultiLinearRing[] = { {&_swigt__p_GeosMultiLinearRing, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosMultiPoint[] = { {&_swigt__p_GeosMultiPoint, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosMultiPolygon[] = { {&_swigt__p_GeosMultiPolygon, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosPoint[] = { {&_swigt__p_GeosPoint, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosPolygon[] = { {&_swigt__p_GeosPolygon, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosWkbReader[] = { {&_swigt__p_GeosWkbReader, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosWkbWriter[] = { {&_swigt__p_GeosWkbWriter, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosWktReader[] = { {&_swigt__p_GeosWktReader, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_GeosWktWriter[] = { {&_swigt__p_GeosWktWriter, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_char[] = { {&_swigt__p_char, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_p_GeosLinearRing[] = { {&_swigt__p_p_GeosLinearRing, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_size_t[] = { {&_swigt__p_size_t, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info _swigc__p_unsigned_char[] = { {&_swigt__p_unsigned_char, 0, 0, 0},{0, 0, 0, 0}};
-static swig_cast_info *swig_cast_initial[] = {
- _swigc__p_GeosCoordinateSequence,
- _swigc__p_GeosGeometry,
- _swigc__p_GeosGeometryCollection,
- _swigc__p_GeosLineString,
- _swigc__p_GeosLinearRing,
- _swigc__p_GeosMultiLineString,
- _swigc__p_GeosMultiLinearRing,
- _swigc__p_GeosMultiPoint,
- _swigc__p_GeosMultiPolygon,
- _swigc__p_GeosPoint,
- _swigc__p_GeosPolygon,
- _swigc__p_GeosWkbReader,
- _swigc__p_GeosWkbWriter,
- _swigc__p_GeosWktReader,
- _swigc__p_GeosWktWriter,
- _swigc__p_char,
- _swigc__p_p_GeosLinearRing,
- _swigc__p_size_t,
- _swigc__p_unsigned_char,
-/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (END) -------- */
- * Type initialization:
- * This problem is tough by the requirement that no dynamic
- * memory is used. Also, since swig_type_info structures store pointers to
- * swig_cast_info structures and swig_cast_info structures store pointers back
- * to swig_type_info structures, we need some lookup code at initialization.
- * The idea is that swig generates all the structures that are needed.
- * The runtime then collects these partially filled structures.
- * The SWIG_InitializeModule function takes these initial arrays out of
- * swig_module, and does all the lookup, filling in the swig_module.types
- * array with the correct data and linking the correct swig_cast_info
- * structures together.
- * The generated swig_type_info structures are assigned staticly to an initial
- * array. We just loop through that array, and handle each type individually.
- * First we lookup if this type has been already loaded, and if so, use the
- * loaded structure instead of the generated one. Then we have to fill in the
- * cast linked list. The cast data is initially stored in something like a
- * two-dimensional array. Each row corresponds to a type (there are the same
- * number of rows as there are in the swig_type_initial array). Each entry in
- * a column is one of the swig_cast_info structures for that type.
- * The cast_initial array is actually an array of arrays, because each row has
- * a variable number of columns. So to actually build the cast linked list,
- * we find the array of casts associated with the type, and loop through it
- * adding the casts to the list. The one last trick we need to do is making
- * sure the type pointer in the swig_cast_info struct is correct.
- * First off, we lookup the cast->type name to see if it is already loaded.
- * There are three cases to handle:
- * 1) If the cast->type has already been loaded AND the type we are adding
- * casting info to has not been loaded (it is in this module), THEN we
- * replace the cast->type pointer with the type pointer that has already
- * been loaded.
- * 2) If BOTH types (the one we are adding casting info to, and the
- * cast->type) are loaded, THEN the cast info has already been loaded by
- * the previous module so we just ignore it.
- * 3) Finally, if cast->type has not already been loaded, then we add that
- * swig_cast_info to the linked list (because the cast->type) pointer will
- * be correct.
-#ifdef __cplusplus
-extern "C" {
-#if 0
-} /* c-mode */
-#endif
-#endif
-#if 0
-#define SWIGRUNTIME_DEBUG
-#endif
-SWIGRUNTIME void
-SWIG_InitializeModule(void *clientdata) {
- size_t i;
- swig_module_info *module_head, *iter;
- int found;
- clientdata = clientdata;
- /* check to see if the circular list has been setup, if not, set it up */
- if (swig_module.next==0) {
- /* Initialize the swig_module */
- swig_module.type_initial = swig_type_initial;
- swig_module.cast_initial = swig_cast_initial;
- swig_module.next = &swig_module;
- /* Try and load any already created modules */
- module_head = SWIG_GetModule(clientdata);
- if (!module_head) {
- /* This is the first module loaded for this interpreter */
- /* so set the swig module into the interpreter */
- SWIG_SetModule(clientdata, &swig_module);
- module_head = &swig_module;
- } else {
- /* the interpreter has loaded a SWIG module, but has it loaded this one? */
- found=0;
- iter=module_head;
- do {
- if (iter==&swig_module) {
- found=1;
- break;
- iter=iter->next;
- } while (iter!= module_head);
- /* if the is found in the list, then all is done and we may leave */
- if (found) return;
- /* otherwise we must add out module into the list */
- swig_module.next = module_head->next;
- module_head->next = &swig_module;
- /* Now work on filling in swig_module.types */
-#ifdef SWIGRUNTIME_DEBUG
- printf("SWIG_InitializeModule: size %d\n", swig_module.size);
-#endif
- for (i = 0; i < swig_module.size; ++i) {
- swig_type_info *type = 0;
- swig_type_info *ret;
- swig_cast_info *cast;
- printf("SWIG_InitializeModule: type %d %s\n", i, swig_module.type_initial[i]->name);
-#endif
- /* if there is another module already loaded */
- if (swig_module.next != &swig_module) {
- type = SWIG_MangledTypeQueryModule(swig_module.next, &swig_module, swig_module.type_initial[i]->name);
- if (type) {
- /* Overwrite clientdata field */
- printf("SWIG_InitializeModule: found type %s\n", type->name);
-#endif
- if (swig_module.type_initial[i]->clientdata) {
- type->clientdata = swig_module.type_initial[i]->clientdata;
- printf("SWIG_InitializeModule: found and overwrite type %s \n", type->name);
-#endif
- } else {
- type = swig_module.type_initial[i];
- /* Insert casting types */
- cast = swig_module.cast_initial[i];
- while (cast->type) {
- /* Don't need to add information already in the list */
- ret = 0;
- printf("SWIG_InitializeModule: look cast %s\n", cast->type->name);
-#endif
- ret = SWIG_MangledTypeQueryModule(swig_module.next, &swig_module, cast->type->name);
- if (ret) printf("SWIG_InitializeModule: found cast %s\n", ret->name);
-#endif
- if (ret) {
- if (type == swig_module.type_initial[i]) {
- printf("SWIG_InitializeModule: skip old type %s\n", ret->name);
-#endif
- cast->type = ret;
- ret = 0;
- } else {
- /* Check for casting already in the list */
- swig_cast_info *ocast = SWIG_TypeCheck(ret->name, type);
- if (ocast) printf("SWIG_InitializeModule: skip old cast %s\n", ret->name);
-#endif
- if (!ocast) ret = 0;
- if (!ret) {
- printf("SWIG_InitializeModule: adding cast %s\n", cast->type->name);
-#endif
- if (type->cast) {
- type->cast->prev = cast;
- cast->next = type->cast;
- type->cast = cast;
- cast++;
- /* Set entry in modules->types array equal to the type */
- swig_module.types[i] = type;
- swig_module.types[i] = 0;
- printf("**** SWIG_InitializeModule: Cast List ******\n");
- int j = 0;
- swig_cast_info *cast = swig_module.cast_initial[i];
- printf("SWIG_InitializeModule: cast type %s\n", cast->type->name);
- cast++;
- ++j;
- printf("---- Total casts: %d\n",j);
-#endif
-/* This function will propagate the clientdata field of type to
-* any new swig_type_info structures that have been added into the list
-* of equivalent types. It is like calling
-* SWIG_TypeClientData(type, clientdata) a second time.
-SWIGRUNTIME void
-SWIG_PropagateClientData(void) {
- size_t i;
- swig_cast_info *equiv;
- static int init_run = 0;
- if (init_run) return;
- init_run = 1;
- for (i = 0; i < swig_module.size; i++) {
- if (swig_module.types[i]->clientdata) {
- equiv = swig_module.types[i]->cast;
- while (equiv) {
- if (!equiv->converter) {
- if (equiv->type && !equiv->type->clientdata)
- SWIG_TypeClientData(equiv->type, swig_module.types[i]->clientdata);
- equiv = equiv->next;
-#ifdef __cplusplus
-#if 0
-{ /* c-mode */
-#endif
-#endif
-#ifdef __cplusplus
-extern "C"
-#endif
-SWIGEXPORT void Init_geos(void) {
- size_t i;
- SWIG_InitRuntime();
- mGeos = rb_define_module("Geos");
- SWIG_InitializeModule(0);
- SWIG_define_class(swig_module.types[i]);
- SWIG_RubyInitializeTrackings();
- rb_define_const(mGeos, "GEOS_VERSION_MAJOR", SWIG_From_int(static_cast< int >(3)));
- rb_define_const(mGeos, "GEOS_VERSION_MINOR", SWIG_From_int(static_cast< int >(0)));
- rb_define_const(mGeos, "GEOS_VERSION", SWIG_FromCharPtr("3.0.0rc4"));
- rb_define_const(mGeos, "GEOS_JTS_PORT", SWIG_FromCharPtr("1.7.1"));
- rb_define_const(mGeos, "GEOS_CAPI_VERSION_MAJOR", SWIG_From_int(static_cast< int >(1)));
- rb_define_const(mGeos, "GEOS_CAPI_VERSION_MINOR", SWIG_From_int(static_cast< int >(3)));
- rb_define_const(mGeos, "GEOS_CAPI_VERSION_PATCH", SWIG_From_int(static_cast< int >(3)));
- rb_define_const(mGeos, "GEOS_CAPI_FIRST_INTERFACE", SWIG_From_int(static_cast< int >(1)));
- rb_define_const(mGeos, "GEOS_CAPI_LAST_INTERFACE", SWIG_From_int(static_cast< int >((1+3))));
- rb_define_const(mGeos, "GEOS_CAPI_VERSION", SWIG_FromCharPtr("3.0.0rc4-CAPI-1.3.3"));
- rb_define_const(mGeos, "GEOS_POINT", SWIG_From_int(static_cast< int >(GEOS_POINT)));
- rb_define_const(mGeos, "GEOS_LINESTRING", SWIG_From_int(static_cast< int >(GEOS_LINESTRING)));
- rb_define_const(mGeos, "GEOS_LINEARRING", SWIG_From_int(static_cast< int >(GEOS_LINEARRING)));
- rb_define_const(mGeos, "GEOS_POLYGON", SWIG_From_int(static_cast< int >(GEOS_POLYGON)));
- rb_define_const(mGeos, "GEOS_MULTIPOINT", SWIG_From_int(static_cast< int >(GEOS_MULTIPOINT)));
- rb_define_const(mGeos, "GEOS_MULTILINESTRING", SWIG_From_int(static_cast< int >(GEOS_MULTILINESTRING)));
- rb_define_const(mGeos, "GEOS_MULTIPOLYGON", SWIG_From_int(static_cast< int >(GEOS_MULTIPOLYGON)));
- rb_define_const(mGeos, "GEOS_GEOMETRYCOLLECTION", SWIG_From_int(static_cast< int >(GEOS_GEOMETRYCOLLECTION)));
- rb_define_const(mGeos, "GEOS_WKB_XDR", SWIG_From_int(static_cast< int >(GEOS_WKB_XDR)));
- rb_define_const(mGeos, "GEOS_WKB_NDR", SWIG_From_int(static_cast< int >(GEOS_WKB_NDR)));
- initGEOS(noticeHandler, errorHandler);
- rb_define_module_function(mGeos, "version", VALUEFUNC(_wrap_version), -1);
- cCoordinateSequence.klass = rb_define_class_under(mGeos, "CoordinateSequence", rb_cObject);
- SWIG_TypeClientData(SWIGTYPE_p_GeosCoordinateSequence, (void *) &cCoordinateSequence);
- rb_define_alloc_func(cCoordinateSequence.klass, _wrap_CoordinateSequence_allocate);
- rb_define_method(cCoordinateSequence.klass, "initialize", VALUEFUNC(_wrap_new_CoordinateSequence), -1);
- rb_define_method(cCoordinateSequence.klass, "clone", VALUEFUNC(_wrap_CoordinateSequence_clone), -1);
- rb_define_method(cCoordinateSequence.klass, "set_x", VALUEFUNC(_wrap_CoordinateSequence_set_x), -1);
- rb_define_method(cCoordinateSequence.klass, "set_y", VALUEFUNC(_wrap_CoordinateSequence_set_y), -1);
- rb_define_method(cCoordinateSequence.klass, "set_z", VALUEFUNC(_wrap_CoordinateSequence_set_z), -1);
- rb_define_method(cCoordinateSequence.klass, "set_ordinate", VALUEFUNC(_wrap_CoordinateSequence_set_ordinate), -1);
- rb_define_method(cCoordinateSequence.klass, "get_x", VALUEFUNC(_wrap_CoordinateSequence_get_x), -1);
- rb_define_method(cCoordinateSequence.klass, "get_y", VALUEFUNC(_wrap_CoordinateSequence_get_y), -1);
- rb_define_method(cCoordinateSequence.klass, "get_z", VALUEFUNC(_wrap_CoordinateSequence_get_z), -1);
- rb_define_method(cCoordinateSequence.klass, "get_ordinate", VALUEFUNC(_wrap_CoordinateSequence_get_ordinate), -1);
- rb_define_method(cCoordinateSequence.klass, "length", VALUEFUNC(_wrap_CoordinateSequence___len__), -1);
- rb_define_method(cCoordinateSequence.klass, "dimensions", VALUEFUNC(_wrap_CoordinateSequence_dimensions), -1);
- cCoordinateSequence.mark = 0;
- cCoordinateSequence.destroy = (void (*)(void *)) free_GeosCoordinateSequence;
- cCoordinateSequence.trackObjects = 0;
- cGeometry.klass = rb_define_class_under(mGeos, "Geometry", rb_cObject);
- SWIG_TypeClientData(SWIGTYPE_p_GeosGeometry, (void *) &cGeometry);
- rb_undef_alloc_func(cGeometry.klass);
- rb_define_method(cGeometry.klass, "clone", VALUEFUNC(_wrap_Geometry_clone), -1);
- rb_define_method(cGeometry.klass, "geom_type", VALUEFUNC(_wrap_Geometry_geom_type), -1);
- rb_define_method(cGeometry.klass, "type_id", VALUEFUNC(_wrap_Geometry_type_id), -1);
- rb_define_method(cGeometry.klass, "normalize", VALUEFUNC(_wrap_Geometry_normalize), -1);
- rb_define_method(cGeometry.klass, "srid", VALUEFUNC(_wrap_Geometry_srid), -1);
- rb_define_method(cGeometry.klass, "srid=", VALUEFUNC(_wrap_Geometry_sride___), -1);
- rb_define_method(cGeometry.klass, "dimensions", VALUEFUNC(_wrap_Geometry_dimensions), -1);
- rb_define_method(cGeometry.klass, "num_geometries", VALUEFUNC(_wrap_Geometry_num_geometries), -1);
- rb_define_method(cGeometry.klass, "intersection", VALUEFUNC(_wrap_Geometry_intersection), -1);
- rb_define_method(cGeometry.klass, "buffer", VALUEFUNC(_wrap_Geometry_buffer), -1);
- rb_define_method(cGeometry.klass, "convex_hull", VALUEFUNC(_wrap_Geometry_convex_hull), -1);
- rb_define_method(cGeometry.klass, "difference", VALUEFUNC(_wrap_Geometry_difference), -1);
- rb_define_method(cGeometry.klass, "sym_difference", VALUEFUNC(_wrap_Geometry_sym_difference), -1);
- rb_define_method(cGeometry.klass, "boundary", VALUEFUNC(_wrap_Geometry_boundary), -1);
- rb_define_method(cGeometry.klass, "union", VALUEFUNC(_wrap_Geometry_union), -1);
- rb_define_method(cGeometry.klass, "point_on_surface", VALUEFUNC(_wrap_Geometry_point_on_surface), -1);
- rb_define_method(cGeometry.klass, "centroid", VALUEFUNC(_wrap_Geometry_centroid), -1);
- rb_define_alias(cGeometry.klass, "center", "centroid");
- rb_define_method(cGeometry.klass, "envelope", VALUEFUNC(_wrap_Geometry_envelope), -1);
- rb_define_method(cGeometry.klass, "relate", VALUEFUNC(_wrap_Geometry_relate), -1);
- rb_define_method(cGeometry.klass, "line_merge", VALUEFUNC(_wrap_Geometry_line_merge), -1);
- rb_define_method(cGeometry.klass, "simplify", VALUEFUNC(_wrap_Geometry_simplify), -1);
- rb_define_method(cGeometry.klass, "topology_preserve_simplify", VALUEFUNC(_wrap_Geometry_topology_preserve_simplify), -1);
- rb_define_method(cGeometry.klass, "relate_pattern", VALUEFUNC(_wrap_Geometry_relate_pattern), -1);
- rb_define_method(cGeometry.klass, "disjoint?", VALUEFUNC(_wrap_Geometry_disjointq___), -1);
- rb_define_method(cGeometry.klass, "touches?", VALUEFUNC(_wrap_Geometry_touchesq___), -1);
- rb_define_method(cGeometry.klass, "intersects?", VALUEFUNC(_wrap_Geometry_intersectsq___), -1);
- rb_define_method(cGeometry.klass, "crosses?", VALUEFUNC(_wrap_Geometry_crossesq___), -1);
- rb_define_method(cGeometry.klass, "within?", VALUEFUNC(_wrap_Geometry_withinq___), -1);
- rb_define_method(cGeometry.klass, "contains?", VALUEFUNC(_wrap_Geometry_containsq___), -1);
- rb_define_method(cGeometry.klass, "overlaps?", VALUEFUNC(_wrap_Geometry_overlapsq___), -1);
- rb_define_method(cGeometry.klass, "eql?", VALUEFUNC(_wrap_Geometry_eqlq___), -1);
- rb_define_alias(cGeometry.klass, "==", "eql?");
- rb_define_method(cGeometry.klass, "eql_exact?", VALUEFUNC(_wrap_Geometry_eql_exactq___), -1);
- rb_define_method(cGeometry.klass, "empty?", VALUEFUNC(_wrap_Geometry_emptyq___), -1);
- rb_define_method(cGeometry.klass, "valid?", VALUEFUNC(_wrap_Geometry_validq___), -1);
- rb_define_method(cGeometry.klass, "simple?", VALUEFUNC(_wrap_Geometry_simpleq___), -1);
- rb_define_method(cGeometry.klass, "ring?", VALUEFUNC(_wrap_Geometry_ringq___), -1);
- rb_define_method(cGeometry.klass, "has_z?", VALUEFUNC(_wrap_Geometry_has_zq___), -1);
- rb_define_method(cGeometry.klass, "area", VALUEFUNC(_wrap_Geometry_area), -1);
- rb_define_method(cGeometry.klass, "length", VALUEFUNC(_wrap_Geometry_length), -1);
- rb_define_method(cGeometry.klass, "distance", VALUEFUNC(_wrap_Geometry_distance), -1);
- cGeometry.mark = 0;
- cGeometry.destroy = (void (*)(void *)) free_GeosGeometry;
- cGeometry.trackObjects = 0;
- cPoint.klass = rb_define_class_under(mGeos, "Point", ((swig_class *) SWIGTYPE_p_GeosGeometry->clientdata)->klass);
- SWIG_TypeClientData(SWIGTYPE_p_GeosPoint, (void *) &cPoint);
- rb_undef_alloc_func(cPoint.klass);
- rb_define_method(cPoint.klass, "coord_seq", VALUEFUNC(_wrap_Point_coord_seq), -1);
- cPoint.mark = 0;
- cPoint.destroy = (void (*)(void *)) free_GeosPoint;
- cPoint.trackObjects = 0;
- cLineString.klass = rb_define_class_under(mGeos, "LineString", ((swig_class *) SWIGTYPE_p_GeosGeometry->clientdata)->klass);
- SWIG_TypeClientData(SWIGTYPE_p_GeosLineString, (void *) &cLineString);
- rb_undef_alloc_func(cLineString.klass);
- rb_define_method(cLineString.klass, "coord_seq", VALUEFUNC(_wrap_LineString_coord_seq), -1);
- cLineString.mark = 0;
- cLineString.destroy = (void (*)(void *)) free_GeosLineString;
- cLineString.trackObjects = 0;
- cLinearRing.klass = rb_define_class_under(mGeos, "LinearRing", ((swig_class *) SWIGTYPE_p_GeosGeometry->clientdata)->klass);
- SWIG_TypeClientData(SWIGTYPE_p_GeosLinearRing, (void *) &cLinearRing);
- rb_undef_alloc_func(cLinearRing.klass);
- rb_define_method(cLinearRing.klass, "coord_seq", VALUEFUNC(_wrap_LinearRing_coord_seq), -1);
- cLinearRing.mark = 0;
- cLinearRing.destroy = (void (*)(void *)) free_GeosLinearRing;
- cLinearRing.trackObjects = 0;
- cPolygon.klass = rb_define_class_under(mGeos, "Polygon", ((swig_class *) SWIGTYPE_p_GeosGeometry->clientdata)->klass);
- SWIG_TypeClientData(SWIGTYPE_p_GeosPolygon, (void *) &cPolygon);
- rb_undef_alloc_func(cPolygon.klass);
- rb_define_method(cPolygon.klass, "exterior_ring", VALUEFUNC(_wrap_Polygon_exterior_ring), -1);
- rb_define_method(cPolygon.klass, "num_interior_rings", VALUEFUNC(_wrap_Polygon_num_interior_rings), -1);
- rb_define_method(cPolygon.klass, "interior_ring_n", VALUEFUNC(_wrap_Polygon_interior_ring_n), -1);
- cPolygon.mark = 0;
- cPolygon.destroy = (void (*)(void *)) free_GeosPolygon;
- cPolygon.trackObjects = 0;
- cGeometryCollection.klass = rb_define_class_under(mGeos, "GeometryCollection", ((swig_class *) SWIGTYPE_p_GeosGeometry->clientdata)->klass);
- SWIG_TypeClientData(SWIGTYPE_p_GeosGeometryCollection, (void *) &cGeometryCollection);
- rb_undef_alloc_func(cGeometryCollection.klass);
- rb_define_method(cGeometryCollection.klass, "get_geometry_n", VALUEFUNC(_wrap_GeometryCollection_get_geometry_n), -1);
- cGeometryCollection.mark = 0;
- cGeometryCollection.destroy = (void (*)(void *)) free_GeosGeometryCollection;
- cGeometryCollection.trackObjects = 0;
- cMultiPoint.klass = rb_define_class_under(mGeos, "MultiPoint", ((swig_class *) SWIGTYPE_p_GeosGeometryCollection->clientdata)->klass);
- SWIG_TypeClientData(SWIGTYPE_p_GeosMultiPoint, (void *) &cMultiPoint);
- rb_undef_alloc_func(cMultiPoint.klass);
- cMultiPoint.mark = 0;
- cMultiPoint.destroy = (void (*)(void *)) free_GeosMultiPoint;
- cMultiPoint.trackObjects = 0;
- cMultiLineString.klass = rb_define_class_under(mGeos, "MultiLineString", ((swig_class *) SWIGTYPE_p_GeosGeometryCollection->clientdata)->klass);
- SWIG_TypeClientData(SWIGTYPE_p_GeosMultiLineString, (void *) &cMultiLineString);
- rb_undef_alloc_func(cMultiLineString.klass);
- cMultiLineString.mark = 0;
- cMultiLineString.destroy = (void (*)(void *)) free_GeosMultiLineString;
- cMultiLineString.trackObjects = 0;
- cMultiLinearRing.klass = rb_define_class_under(mGeos, "MultiLinearRing", ((swig_class *) SWIGTYPE_p_GeosGeometryCollection->clientdata)->klass);
- SWIG_TypeClientData(SWIGTYPE_p_GeosMultiLinearRing, (void *) &cMultiLinearRing);
- rb_undef_alloc_func(cMultiLinearRing.klass);
- cMultiLinearRing.mark = 0;
- cMultiLinearRing.destroy = (void (*)(void *)) free_GeosMultiLinearRing;
- cMultiLinearRing.trackObjects = 0;
- cMultiPolygon.klass = rb_define_class_under(mGeos, "MultiPolygon", ((swig_class *) SWIGTYPE_p_GeosGeometryCollection->clientdata)->klass);
- SWIG_TypeClientData(SWIGTYPE_p_GeosMultiPolygon, (void *) &cMultiPolygon);
- rb_undef_alloc_func(cMultiPolygon.klass);
- cMultiPolygon.mark = 0;
- cMultiPolygon.destroy = (void (*)(void *)) free_GeosMultiPolygon;
- cMultiPolygon.trackObjects = 0;
- rb_define_module_function(mGeos, "create_point", VALUEFUNC(_wrap_create_point), -1);
- rb_define_module_function(mGeos, "create_line_string", VALUEFUNC(_wrap_create_line_string), -1);
- rb_define_module_function(mGeos, "create_linear_ring", VALUEFUNC(_wrap_create_linear_ring), -1);
- rb_define_module_function(mGeos, "create_polygon", VALUEFUNC(_wrap_create_polygon), -1);
- cWktReader.klass = rb_define_class_under(mGeos, "WktReader", rb_cObject);
- SWIG_TypeClientData(SWIGTYPE_p_GeosWktReader, (void *) &cWktReader);
- rb_define_alloc_func(cWktReader.klass, _wrap_WktReader_allocate);
- rb_define_method(cWktReader.klass, "initialize", VALUEFUNC(_wrap_new_WktReader), -1);
- rb_define_method(cWktReader.klass, "read", VALUEFUNC(_wrap_WktReader_read), -1);
- cWktReader.mark = 0;
- cWktReader.destroy = (void (*)(void *)) free_GeosWktReader;
- cWktReader.trackObjects = 0;
- cWktWriter.klass = rb_define_class_under(mGeos, "WktWriter", rb_cObject);
- SWIG_TypeClientData(SWIGTYPE_p_GeosWktWriter, (void *) &cWktWriter);
- rb_define_alloc_func(cWktWriter.klass, _wrap_WktWriter_allocate);
- rb_define_method(cWktWriter.klass, "initialize", VALUEFUNC(_wrap_new_WktWriter), -1);
- rb_define_method(cWktWriter.klass, "write", VALUEFUNC(_wrap_WktWriter_write), -1);
- cWktWriter.mark = 0;
- cWktWriter.destroy = (void (*)(void *)) free_GeosWktWriter;
- cWktWriter.trackObjects = 0;
- cWkbReader.klass = rb_define_class_under(mGeos, "WkbReader", rb_cObject);
- SWIG_TypeClientData(SWIGTYPE_p_GeosWkbReader, (void *) &cWkbReader);
- rb_define_alloc_func(cWkbReader.klass, _wrap_WkbReader_allocate);
- rb_define_method(cWkbReader.klass, "initialize", VALUEFUNC(_wrap_new_WkbReader), -1);
- rb_define_method(cWkbReader.klass, "read", VALUEFUNC(_wrap_WkbReader_read), -1);
- rb_define_method(cWkbReader.klass, "read_hex", VALUEFUNC(_wrap_WkbReader_read_hex), -1);
- cWkbReader.mark = 0;
- cWkbReader.destroy = (void (*)(void *)) free_GeosWkbReader;
- cWkbReader.trackObjects = 0;
- cWkbWriter.klass = rb_define_class_under(mGeos, "WkbWriter", rb_cObject);
- SWIG_TypeClientData(SWIGTYPE_p_GeosWkbWriter, (void *) &cWkbWriter);
- rb_define_alloc_func(cWkbWriter.klass, _wrap_WkbWriter_allocate);
- rb_define_method(cWkbWriter.klass, "initialize", VALUEFUNC(_wrap_new_WkbWriter), -1);
- rb_define_method(cWkbWriter.klass, "output_dimensions", VALUEFUNC(_wrap_WkbWriter_output_dimensions), -1);
- rb_define_method(cWkbWriter.klass, "output_dimensions=", VALUEFUNC(_wrap_WkbWriter_output_dimensionse___), -1);
- rb_define_method(cWkbWriter.klass, "byte_order", VALUEFUNC(_wrap_WkbWriter_byte_order), -1);
- rb_define_method(cWkbWriter.klass, "byte_order=", VALUEFUNC(_wrap_WkbWriter_byte_ordere___), -1);
- rb_define_method(cWkbWriter.klass, "include_srid", VALUEFUNC(_wrap_WkbWriter_include_srid), -1);
- rb_define_method(cWkbWriter.klass, "include_srid=", VALUEFUNC(_wrap_WkbWriter_include_sride___), -1);
- rb_define_method(cWkbWriter.klass, "write", VALUEFUNC(_wrap_WkbWriter_write), -1);
- rb_define_method(cWkbWriter.klass, "write_hex", VALUEFUNC(_wrap_WkbWriter_write_hex), -1);
- cWkbWriter.mark = 0;
- cWkbWriter.destroy = (void (*)(void *)) free_GeosWkbWriter;
- cWkbWriter.trackObjects = 0;
+ * This file was automatically generated by SWIG (http://www.swig.org).
+ * Version 1.3.40
+ * This file is not intended to be easily readable and contains a number of
+ * coding conventions designed to improve portability and efficiency. Do not make
+ * changes to this file unless you know what you are doing--modify the SWIG
+ * interface file instead.
+#define SWIGRUBY
+#ifdef __cplusplus
+/* SwigValueWrapper is described in swig.swg */
+template<typename T> class SwigValueWrapper {
+ struct SwigMovePointer {
+ T *ptr;
+ SwigMovePointer(T *p) : ptr(p) { }
+ ~SwigMovePointer() { delete ptr; }
+ SwigMovePointer& operator=(SwigMovePointer& rhs) { T* oldptr = ptr; ptr = 0; delete oldptr; ptr = rhs.ptr; rhs.ptr = 0; return *this; }
+ } pointer;
+ SwigValueWrapper& operator=(const SwigValueWrapper<T>& rhs);
+ SwigValueWrapper(const SwigValueWrapper<T>& rhs);
+public:
+ SwigValueWrapper() : pointer(0) { }
+ SwigValueWrapper& operator=(const T& t) { SwigMovePointer tmp(new T(t)); pointer = tmp; return *this; }
+ operator T&() const { return *pointer.ptr; }
+ T *operator&() { return pointer.ptr; }
+template <typename T> T SwigValueInit() {
+ return T();
+#endif
+ * This section contains generic SWIG labels for method/variable
+ * declarations/attributes, and other compiler dependent labels.
+/* template workaround for compilers that cannot correctly implement the C++ standard */
+#ifndef SWIGTEMPLATEDISAMBIGUATOR
+# if defined(__SUNPRO_CC) && (__SUNPRO_CC <= 0x560)
+# define SWIGTEMPLATEDISAMBIGUATOR template
+# elif defined(__HP_aCC)
+/* Needed even with `aCC -AA' when `aCC -V' reports HP ANSI C++ B3910B A.03.55 */
+/* If we find a maximum version that requires this, the test would be __HP_aCC <= 35500 for A.03.55 */
+# else
+# endif
+#endif
+/* inline attribute */
+#ifndef SWIGINLINE
+# if defined(__cplusplus) || (defined(__GNUC__) && !defined(__STRICT_ANSI__))
+# define SWIGINLINE inline
+# else
+# endif
+#endif
+/* attribute recognised by some compilers to avoid 'unused' warnings */
+#ifndef SWIGUNUSED
+# if defined(__GNUC__)
+# if !(defined(__cplusplus)) || (__GNUC__ > 3 || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4))
+# define SWIGUNUSED __attribute__ ((__unused__))
+# else
+# endif
+# elif defined(__ICC)
+# else
+# endif
+#endif
+#ifndef SWIG_MSC_UNSUPPRESS_4505
+# if defined(_MSC_VER)
+# pragma warning(disable : 4505) /* unreferenced local function has been removed */
+# endif
+#endif
+#ifndef SWIGUNUSEDPARM
+# ifdef __cplusplus
+# define SWIGUNUSEDPARM(p)
+# else
+# define SWIGUNUSEDPARM(p) p SWIGUNUSED
+# endif
+#endif
+/* internal SWIG method */
+#ifndef SWIGINTERN
+# define SWIGINTERN static SWIGUNUSED
+#endif
+/* internal inline SWIG method */
+#ifndef SWIGINTERNINLINE
+# define SWIGINTERNINLINE SWIGINTERN SWIGINLINE
+#endif
+/* exporting methods */
+#if (__GNUC__ >= 4) || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4)
+# ifndef GCC_HASCLASSVISIBILITY
+# define GCC_HASCLASSVISIBILITY
+# endif
+#endif
+#ifndef SWIGEXPORT
+# if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
+# if defined(STATIC_LINKED)
+# define SWIGEXPORT
+# else
+# define SWIGEXPORT __declspec(dllexport)
+# endif
+# else
+# if defined(__GNUC__) && defined(GCC_HASCLASSVISIBILITY)
+# define SWIGEXPORT __attribute__ ((visibility("default")))
+# else
+# endif
+# endif
+#endif
+/* calling conventions for Windows */
+#ifndef SWIGSTDCALL
+# define SWIGSTDCALL __stdcall
+# else
+# endif
+#endif
+/* Deal with Microsoft's attempt at deprecating C standard runtime functions */
+#if !defined(SWIG_NO_CRT_SECURE_NO_DEPRECATE) && defined(_MSC_VER) && !defined(_CRT_SECURE_NO_DEPRECATE)
+# define _CRT_SECURE_NO_DEPRECATE
+#endif
+/* Deal with Microsoft's attempt at deprecating methods in the standard C++ library */
+#if !defined(SWIG_NO_SCL_SECURE_NO_DEPRECATE) && defined(_MSC_VER) && !defined(_SCL_SECURE_NO_DEPRECATE)
+# define _SCL_SECURE_NO_DEPRECATE
+#endif
+# else
+# endif
+#endif
+#ifndef SWIGINLINE
+# else
+# endif
+#endif
+#ifndef SWIGUNUSED
+# else
+# endif
+# else
+# endif
+#endif
+# endif
+#endif
+# else
+# endif
+#endif
+#ifndef SWIGINTERN
+#endif
+#endif
+# endif
+#endif
+#ifndef SWIGEXPORT
+# else
+# endif
+# else
+# else
+# endif
+# endif
+#endif
+# else
+# endif
+#endif
+#endif
+#endif
+ * swigrun.swg
+ * This file contains generic C API SWIG runtime support for pointer
+ * type checking.
+/* This should only be incremented when either the layout of swig_type_info changes,
+ or for whatever reason, the runtime changes incompatibly */
+#define SWIG_RUNTIME_VERSION "4"
+/* define SWIG_TYPE_TABLE_NAME as "SWIG_TYPE_TABLE" */
+#ifdef SWIG_TYPE_TABLE
+# define SWIG_QUOTE_STRING(x) #x
+# define SWIG_EXPAND_AND_QUOTE_STRING(x) SWIG_QUOTE_STRING(x)
+# define SWIG_TYPE_TABLE_NAME SWIG_EXPAND_AND_QUOTE_STRING(SWIG_TYPE_TABLE)
+#else
+#endif
+ You can use the SWIGRUNTIME and SWIGRUNTIMEINLINE macros for
+ creating a static or dynamic library from the SWIG runtime code.
+ In 99.9% of the cases, SWIG just needs to declare them as 'static'.
+ But only do this if strictly necessary, ie, if you have problems
+ with your compiler or suchlike.
+#ifndef SWIGRUNTIME
+# define SWIGRUNTIME SWIGINTERN
+#endif
+#ifndef SWIGRUNTIMEINLINE
+# define SWIGRUNTIMEINLINE SWIGRUNTIME SWIGINLINE
+#endif
+/* Generic buffer size */
+#ifndef SWIG_BUFFER_SIZE
+# define SWIG_BUFFER_SIZE 1024
+#endif
+/* Flags for pointer conversions */
+#define SWIG_POINTER_DISOWN 0x1
+#define SWIG_CAST_NEW_MEMORY 0x2
+/* Flags for new pointer objects */
+#define SWIG_POINTER_OWN 0x1
+ Flags/methods for returning states.
+ The SWIG conversion methods, as ConvertPtr, return and integer
+ that tells if the conversion was successful or not. And if not,
+ an error code can be returned (see swigerrors.swg for the codes).
+ Use the following macros/flags to set or process the returning
+ states.
+ In old versions of SWIG, code such as the following was usually written:
+ if (SWIG_ConvertPtr(obj,vptr,ty.flags) != -1) {
+ // success code
+ } else {
+ //fail code
+ Now you can be more explicit:
+ int res = SWIG_ConvertPtr(obj,vptr,ty.flags);
+ if (SWIG_IsOK(res)) {
+ // success code
+ } else {
+ // fail code
+ which is the same really, but now you can also do
+ Type *ptr;
+ int res = SWIG_ConvertPtr(obj,(void **)(&ptr),ty.flags);
+ // success code
+ if (SWIG_IsNewObj(res) {
+ delete *ptr;
+ } else {
+ } else {
+ // fail code
+ I.e., now SWIG_ConvertPtr can return new objects and you can
+ identify the case and take care of the deallocation. Of course that
+ also requires SWIG_ConvertPtr to return new result values, such as
+ int SWIG_ConvertPtr(obj, ptr,...) {
+ if (<obj is ok>) {
+ if (<need new object>) {
+ *ptr = <ptr to new allocated object>;
+ return SWIG_NEWOBJ;
+ } else {
+ *ptr = <ptr to old object>;
+ return SWIG_OLDOBJ;
+ } else {
+ return SWIG_BADOBJ;
+ Of course, returning the plain '0(success)/-1(fail)' still works, but you can be
+ more explicit by returning SWIG_BADOBJ, SWIG_ERROR or any of the
+ SWIG errors code.
+ Finally, if the SWIG_CASTRANK_MODE is enabled, the result code
+ allows to return the 'cast rank', for example, if you have this
+ int food(double)
+ int fooi(int);
+ and you call
+ food(1) // cast rank '1' (1 -> 1.0)
+ fooi(1) // cast rank '0'
+ just use the SWIG_AddCast()/SWIG_CheckState()
+#define SWIG_OK (0)
+#define SWIG_ERROR (-1)
+#define SWIG_IsOK(r) (r >= 0)
+#define SWIG_ArgError(r) ((r != SWIG_ERROR) ? r : SWIG_TypeError)
+/* The CastRankLimit says how many bits are used for the cast rank */
+#define SWIG_CASTRANKLIMIT (1 << 8)
+/* The NewMask denotes the object was created (using new/malloc) */
+#define SWIG_NEWOBJMASK (SWIG_CASTRANKLIMIT << 1)
+/* The TmpMask is for in/out typemaps that use temporal objects */
+#define SWIG_TMPOBJMASK (SWIG_NEWOBJMASK << 1)
+/* Simple returning values */
+#define SWIG_BADOBJ (SWIG_ERROR)
+#define SWIG_OLDOBJ (SWIG_OK)
+#define SWIG_NEWOBJ (SWIG_OK | SWIG_NEWOBJMASK)
+#define SWIG_TMPOBJ (SWIG_OK | SWIG_TMPOBJMASK)
+/* Check, add and del mask methods */
+#define SWIG_AddNewMask(r) (SWIG_IsOK(r) ? (r | SWIG_NEWOBJMASK) : r)
+#define SWIG_DelNewMask(r) (SWIG_IsOK(r) ? (r & ~SWIG_NEWOBJMASK) : r)
+#define SWIG_IsNewObj(r) (SWIG_IsOK(r) && (r & SWIG_NEWOBJMASK))
+#define SWIG_AddTmpMask(r) (SWIG_IsOK(r) ? (r | SWIG_TMPOBJMASK) : r)
+#define SWIG_DelTmpMask(r) (SWIG_IsOK(r) ? (r & ~SWIG_TMPOBJMASK) : r)
+#define SWIG_IsTmpObj(r) (SWIG_IsOK(r) && (r & SWIG_TMPOBJMASK))
+/* Cast-Rank Mode */
+#if defined(SWIG_CASTRANK_MODE)
+# ifndef SWIG_TypeRank
+# define SWIG_TypeRank unsigned long
+# endif
+# ifndef SWIG_MAXCASTRANK /* Default cast allowed */
+# define SWIG_MAXCASTRANK (2)
+# endif
+# define SWIG_CASTRANKMASK ((SWIG_CASTRANKLIMIT) -1)
+# define SWIG_CastRank(r) (r & SWIG_CASTRANKMASK)
+SWIGINTERNINLINE int SWIG_AddCast(int r) {
+ return SWIG_IsOK(r) ? ((SWIG_CastRank(r) < SWIG_MAXCASTRANK) ? (r + 1) : SWIG_ERROR) : r;
+SWIGINTERNINLINE int SWIG_CheckState(int r) {
+ return SWIG_IsOK(r) ? SWIG_CastRank(r) + 1 : 0;
+#else /* no cast-rank mode */
+# define SWIG_AddCast
+# define SWIG_CheckState(r) (SWIG_IsOK(r) ? 1 : 0)
+#endif
+#include <string.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+typedef void *(*swig_converter_func)(void *, int *);
+typedef struct swig_type_info *(*swig_dycast_func)(void **);
+/* Structure to store information on one type */
+typedef struct swig_type_info {
+ const char *name; /* mangled name of this type */
+ const char *str; /* human readable name of this type */
+ swig_dycast_func dcast; /* dynamic cast function down a hierarchy */
+ struct swig_cast_info *cast; /* linked list of types that can cast into this type */
+ void *clientdata; /* language specific type data */
+ int owndata; /* flag if the structure owns the clientdata */
+} swig_type_info;
+/* Structure to store a type and conversion function used for casting */
+typedef struct swig_cast_info {
+ swig_type_info *type; /* pointer to type that is equivalent to this type */
+ swig_converter_func converter; /* function to cast the void pointers */
+ struct swig_cast_info *next; /* pointer to next cast in linked list */
+ struct swig_cast_info *prev; /* pointer to the previous cast */
+} swig_cast_info;
+/* Structure used to store module information
+ * Each module generates one structure like this, and the runtime collects
+ * all of these structures and stores them in a circularly linked list.*/
+typedef struct swig_module_info {
+ swig_type_info **types; /* Array of pointers to swig_type_info structures that are in this module */
+ size_t size; /* Number of types in this module */
+ struct swig_module_info *next; /* Pointer to next element in circularly linked list */
+ swig_type_info **type_initial; /* Array of initially generated type structures */
+ swig_cast_info **cast_initial; /* Array of initially generated casting structures */
+ void *clientdata; /* Language specific module data */
+} swig_module_info;
+ Compare two type names skipping the space characters, therefore
+ "char*" == "char *" and "Class<int>" == "Class<int >", etc.
+ Return 0 when the two name types are equivalent, as in
+ strncmp, but skipping ' '.
+SWIGRUNTIME int
+SWIG_TypeNameComp(const char *f1, const char *l1,
+ const char *f2, const char *l2) {
+ for (;(f1 != l1) && (f2 != l2); ++f1, ++f2) {
+ while ((*f1 == ' ') && (f1 != l1)) ++f1;
+ while ((*f2 == ' ') && (f2 != l2)) ++f2;
+ if (*f1 != *f2) return (*f1 > *f2) ? 1 : -1;
+ return (int)((l1 - f1) - (l2 - f2));
+ Check type equivalence in a name list like <name1>|<name2>|...
+ Return 0 if not equal, 1 if equal
+SWIGRUNTIME int
+SWIG_TypeEquiv(const char *nb, const char *tb) {
+ int equiv = 0;
+ const char* te = tb + strlen(tb);
+ const char* ne = nb;
+ while (!equiv && *ne) {
+ for (nb = ne; *ne; ++ne) {
+ if (*ne == '|') break;
+ equiv = (SWIG_TypeNameComp(nb, ne, tb, te) == 0) ? 1 : 0;
+ if (*ne) ++ne;
+ return equiv;
+ Return 0 if equal, -1 if nb < tb, 1 if nb > tb
+SWIGRUNTIME int
+SWIG_TypeCompare(const char *nb, const char *tb) {
+ int equiv = 0;
+ if (*ne) ++ne;
+ return equiv;
+ Check the typename
+SWIGRUNTIME swig_cast_info *
+SWIG_TypeCheck(const char *c, swig_type_info *ty) {
+ if (ty) {
+ swig_cast_info *iter = ty->cast;
+ while (iter) {
+ if (strcmp(iter->type->name, c) == 0) {
+ if (iter == ty->cast)
+ return iter;
+ /* Move iter to the top of the linked list */
+ iter->prev->next = iter->next;
+ if (iter->next)
+ iter->next->prev = iter->prev;
+ iter->next = ty->cast;
+ iter->prev = 0;
+ if (ty->cast) ty->cast->prev = iter;
+ ty->cast = iter;
+ return iter;
+ iter = iter->next;
+ return 0;
+ Identical to SWIG_TypeCheck, except strcmp is replaced with a pointer comparison
+SWIG_TypeCheckStruct(swig_type_info *from, swig_type_info *ty) {
+ if (ty) {
+ while (iter) {
+ if (iter->type == from) {
+ return iter;
+ if (iter->next)
+ iter->prev = 0;
+ ty->cast = iter;
+ return iter;
+ return 0;
+ Cast a pointer up an inheritance hierarchy
+SWIGRUNTIMEINLINE void *
+SWIG_TypeCast(swig_cast_info *ty, void *ptr, int *newmemory) {
+ return ((!ty) || (!ty->converter)) ? ptr : (*ty->converter)(ptr, newmemory);
+ Dynamic pointer casting. Down an inheritance hierarchy
+SWIGRUNTIME swig_type_info *
+SWIG_TypeDynamicCast(swig_type_info *ty, void **ptr) {
+ swig_type_info *lastty = ty;
+ if (!ty || !ty->dcast) return ty;
+ while (ty && (ty->dcast)) {
+ ty = (*ty->dcast)(ptr);
+ if (ty) lastty = ty;
+ return lastty;
+ Return the name associated with this type
+SWIGRUNTIMEINLINE const char *
+SWIG_TypeName(const swig_type_info *ty) {
+ return ty->name;
+ Return the pretty name associated with this type,
+ that is an unmangled type name in a form presentable to the user.
+SWIGRUNTIME const char *
+SWIG_TypePrettyName(const swig_type_info *type) {
+ /* The "str" field contains the equivalent pretty names of the
+ type, separated by vertical-bar characters. We choose
+ to print the last name, as it is often (?) the most
+ specific. */
+ if (!type) return NULL;
+ if (type->str != NULL) {
+ const char *last_name = type->str;
+ const char *s;
+ for (s = type->str; *s; s++)
+ if (*s == '|') last_name = s+1;
+ return last_name;
+ else
+ return type->name;
+ Set the clientdata field for a type
+SWIGRUNTIME void
+SWIG_TypeClientData(swig_type_info *ti, void *clientdata) {
+ swig_cast_info *cast = ti->cast;
+ /* if (ti->clientdata == clientdata) return; */
+ ti->clientdata = clientdata;
+ while (cast) {
+ if (!cast->converter) {
+ swig_type_info *tc = cast->type;
+ if (!tc->clientdata) {
+ SWIG_TypeClientData(tc, clientdata);
+ cast = cast->next;
+SWIGRUNTIME void
+SWIG_TypeNewClientData(swig_type_info *ti, void *clientdata) {
+ SWIG_TypeClientData(ti, clientdata);
+ ti->owndata = 1;
+ Search for a swig_type_info structure only by mangled name
+ Search is a O(log #types)
+ We start searching at module start, and finish searching when start == end.
+ Note: if start == end at the beginning of the function, we go all the way around
+ the circular list.
+SWIG_MangledTypeQueryModule(swig_module_info *start,
+ swig_module_info *end,
+ const char *name) {
+ swig_module_info *iter = start;
+ do {
+ if (iter->size) {
+ register size_t l = 0;
+ register size_t r = iter->size - 1;
+ do {
+ /* since l+r >= 0, we can (>> 1) instead (/ 2) */
+ register size_t i = (l + r) >> 1;
+ const char *iname = iter->types[i]->name;
+ if (iname) {
+ register int compare = strcmp(name, iname);
+ if (compare == 0) {
+ return iter->types[i];
+ } else if (compare < 0) {
+ if (i) {
+ r = i - 1;
+ } else {
+ break;
+ } else if (compare > 0) {
+ l = i + 1;
+ } else {
+ break; /* should never happen */
+ } while (l <= r);
+ } while (iter != end);
+ return 0;
+ Search for a swig_type_info structure for either a mangled name or a human readable name.
+ It first searches the mangled names of the types, which is a O(log #types)
+ If a type is not found it then searches the human readable names, which is O(#types).
+SWIG_TypeQueryModule(swig_module_info *start,
+ /* STEP 1: Search the name field using binary search */
+ swig_type_info *ret = SWIG_MangledTypeQueryModule(start, end, name);
+ if (ret) {
+ return ret;
+ } else {
+ /* STEP 2: If the type hasn't been found, do a complete search
+ of the str field (the human readable name) */
+ do {
+ register size_t i = 0;
+ for (; i < iter->size; ++i) {
+ if (iter->types[i]->str && (SWIG_TypeEquiv(iter->types[i]->str, name)))
+ /* neither found a match */
+ return 0;
+ Pack binary data into a string
+SWIGRUNTIME char *
+SWIG_PackData(char *c, void *ptr, size_t sz) {
+ static const char hex[17] = "0123456789abcdef";
+ register const unsigned char *u = (unsigned char *) ptr;
+ register const unsigned char *eu = u + sz;
+ for (; u != eu; ++u) {
+ register unsigned char uu = *u;
+ *(c++) = hex[(uu & 0xf0) >> 4];
+ *(c++) = hex[uu & 0xf];
+ return c;
+ Unpack binary data from a string
+SWIG_UnpackData(const char *c, void *ptr, size_t sz) {
+ register unsigned char *u = (unsigned char *) ptr;
+ register char d = *(c++);
+ register unsigned char uu;
+ if ((d >= '0') && (d <= '9'))
+ uu = ((d - '0') << 4);
+ else if ((d >= 'a') && (d <= 'f'))
+ uu = ((d - ('a'-10)) << 4);
+ else
+ return (char *) 0;
+ d = *(c++);
+ uu |= (d - '0');
+ uu |= (d - ('a'-10));
+ else
+ *u = uu;
+ return c;
+ Pack 'void *' into a string buffer.
+SWIGRUNTIME char *
+SWIG_PackVoidPtr(char *buff, void *ptr, const char *name, size_t bsz) {
+ char *r = buff;
+ if ((2*sizeof(void *) + 2) > bsz) return 0;
+ *(r++) = '_';
+ r = SWIG_PackData(r,&ptr,sizeof(void *));
+ if (strlen(name) + 1 > (bsz - (r - buff))) return 0;
+ strcpy(r,name);
+ return buff;
+SWIG_UnpackVoidPtr(const char *c, void **ptr, const char *name) {
+ if (*c != '_') {
+ if (strcmp(c,"NULL") == 0) {
+ *ptr = (void *) 0;
+ return name;
+ } else {
+ return 0;
+ return SWIG_UnpackData(++c,ptr,sizeof(void *));
+SWIGRUNTIME char *
+SWIG_PackDataName(char *buff, void *ptr, size_t sz, const char *name, size_t bsz) {
+ char *r = buff;
+ size_t lname = (name ? strlen(name) : 0);
+ if ((2*sz + 2 + lname) > bsz) return 0;
+ *(r++) = '_';
+ r = SWIG_PackData(r,ptr,sz);
+ if (lname) {
+ strncpy(r,name,lname+1);
+ } else {
+ *r = 0;
+ return buff;
+SWIG_UnpackDataName(const char *c, void *ptr, size_t sz, const char *name) {
+ if (*c != '_') {
+ memset(ptr,0,sz);
+ return name;
+ } else {
+ return 0;
+ return SWIG_UnpackData(++c,ptr,sz);
+#ifdef __cplusplus
+#endif
+/* Errors in SWIG */
+#define SWIG_UnknownError -1
+#define SWIG_IOError -2
+#define SWIG_RuntimeError -3
+#define SWIG_IndexError -4
+#define SWIG_TypeError -5
+#define SWIG_DivisionByZero -6
+#define SWIG_OverflowError -7
+#define SWIG_SyntaxError -8
+#define SWIG_ValueError -9
+#define SWIG_SystemError -10
+#define SWIG_AttributeError -11
+#define SWIG_MemoryError -12
+#define SWIG_NullReferenceError -13
+#include <ruby.h>
+/* Remove global macros defined in Ruby's win32.h */
+#ifdef write
+# undef write
+#endif
+#ifdef read
+# undef read
+#endif
+#ifdef bind
+# undef bind
+#endif
+#ifdef close
+# undef close
+#endif
+#ifdef connect
+# undef connect
+#endif
+/* Ruby 1.7 defines NUM2LL(), LL2NUM() and ULL2NUM() macros */
+#ifndef NUM2LL
+#define NUM2LL(x) NUM2LONG((x))
+#endif
+#ifndef LL2NUM
+#define LL2NUM(x) INT2NUM((long) (x))
+#endif
+#ifndef ULL2NUM
+#define ULL2NUM(x) UINT2NUM((unsigned long) (x))
+#endif
+/* Ruby 1.7 doesn't (yet) define NUM2ULL() */
+#ifndef NUM2ULL
+#ifdef HAVE_LONG_LONG
+#define NUM2ULL(x) rb_num2ull((x))
+#else
+#define NUM2ULL(x) NUM2ULONG(x)
+#endif
+#endif
+/* RSTRING_LEN, etc are new in Ruby 1.9, but ->ptr and ->len no longer work */
+/* Define these for older versions so we can just write code the new way */
+#ifndef RSTRING_LEN
+# define RSTRING_LEN(x) RSTRING(x)->len
+#endif
+#ifndef RSTRING_PTR
+# define RSTRING_PTR(x) RSTRING(x)->ptr
+#endif
+#ifndef RSTRING_END
+# define RSTRING_END(x) (RSTRING_PTR(x) + RSTRING_LEN(x))
+#endif
+#ifndef RARRAY_LEN
+# define RARRAY_LEN(x) RARRAY(x)->len
+#endif
+#ifndef RARRAY_PTR
+# define RARRAY_PTR(x) RARRAY(x)->ptr
+#endif
+#ifndef RFLOAT_VALUE
+# define RFLOAT_VALUE(x) RFLOAT(x)->value
+#endif
+#ifndef DOUBLE2NUM
+# define DOUBLE2NUM(x) rb_float_new(x)
+#endif
+#ifndef RHASH_TBL
+# define RHASH_TBL(x) (RHASH(x)->tbl)
+#endif
+#ifndef RHASH_ITER_LEV
+# define RHASH_ITER_LEV(x) (RHASH(x)->iter_lev)
+#endif
+#ifndef RHASH_IFNONE
+# define RHASH_IFNONE(x) (RHASH(x)->ifnone)
+#endif
+#ifndef RHASH_SIZE
+# define RHASH_SIZE(x) (RHASH(x)->tbl->num_entries)
+#endif
+#ifndef RHASH_EMPTY_P
+# define RHASH_EMPTY_P(x) (RHASH_SIZE(x) == 0)
+#endif
+#ifndef RSTRUCT_LEN
+# define RSTRUCT_LEN(x) RSTRUCT(x)->len
+#endif
+#ifndef RSTRUCT_PTR
+# define RSTRUCT_PTR(x) RSTRUCT(x)->ptr
+#endif
+ * Need to be very careful about how these macros are defined, especially
+ * when compiling C++ code or C code with an ANSI C compiler.
+ * VALUEFUNC(f) is a macro used to typecast a C function that implements
+ * a Ruby method so that it can be passed as an argument to API functions
+ * like rb_define_method() and rb_define_singleton_method().
+ * VOIDFUNC(f) is a macro used to typecast a C function that implements
+ * either the "mark" or "free" stuff for a Ruby Data object, so that it
+ * can be passed as an argument to API functions like Data_Wrap_Struct()
+ * and Data_Make_Struct().
+#ifdef __cplusplus
+# ifndef RUBY_METHOD_FUNC /* These definitions should work for Ruby 1.4.6 */
+# define PROTECTFUNC(f) ((VALUE (*)()) f)
+# define VALUEFUNC(f) ((VALUE (*)()) f)
+# define VOIDFUNC(f) ((void (*)()) f)
+# else
+# ifndef ANYARGS /* These definitions should work for Ruby 1.6 */
+# define VOIDFUNC(f) ((RUBY_DATA_FUNC) f)
+# else /* These definitions should work for Ruby 1.7+ */
+# define PROTECTFUNC(f) ((VALUE (*)(VALUE)) f)
+# define VALUEFUNC(f) ((VALUE (*)(ANYARGS)) f)
+# endif
+# endif
+#else
+# define VALUEFUNC(f) (f)
+# define VOIDFUNC(f) (f)
+#endif
+/* Don't use for expressions have side effect */
+#ifndef RB_STRING_VALUE
+#define RB_STRING_VALUE(s) (TYPE(s) == T_STRING ? (s) : (*(volatile VALUE *)&(s) = rb_str_to_str(s)))
+#endif
+#ifndef StringValue
+#define StringValue(s) RB_STRING_VALUE(s)
+#endif
+#ifndef StringValuePtr
+#define StringValuePtr(s) RSTRING_PTR(RB_STRING_VALUE(s))
+#endif
+#ifndef StringValueLen
+#define StringValueLen(s) RSTRING_LEN(RB_STRING_VALUE(s))
+#endif
+#ifndef SafeStringValue
+#define SafeStringValue(v) do {\
+ StringValue(v);\
+ rb_check_safe_str(v);\
+} while (0)
+#endif
+#ifndef HAVE_RB_DEFINE_ALLOC_FUNC
+#define rb_define_alloc_func(klass, func) rb_define_singleton_method((klass), "new", VALUEFUNC((func)), -1)
+#define rb_undef_alloc_func(klass) rb_undef_method(CLASS_OF((klass)), "new")
+#endif
+static VALUE _mSWIG = Qnil;
+ * error manipulation
+/* Define some additional error types */
+#define SWIG_ObjectPreviouslyDeletedError -100
+/* Define custom exceptions for errors that do not map to existing Ruby
+ exceptions. Note this only works for C++ since a global cannot be
+ initialized by a funtion in C. For C, fallback to rb_eRuntimeError.*/
+SWIGINTERN VALUE
+getNullReferenceError(void) {
+ static int init = 0;
+ static VALUE rb_eNullReferenceError ;
+ if (!init) {
+ init = 1;
+ rb_eNullReferenceError = rb_define_class("NullReferenceError", rb_eRuntimeError);
+ return rb_eNullReferenceError;
+SWIGINTERN VALUE
+getObjectPreviouslyDeletedError(void) {
+ static VALUE rb_eObjectPreviouslyDeleted ;
+ if (!init) {
+ init = 1;
+ rb_eObjectPreviouslyDeleted = rb_define_class("ObjectPreviouslyDeleted", rb_eRuntimeError);
+ return rb_eObjectPreviouslyDeleted;
+SWIGINTERN VALUE
+SWIG_Ruby_ErrorType(int SWIG_code) {
+ VALUE type;
+ switch (SWIG_code) {
+ case SWIG_MemoryError:
+ type = rb_eNoMemError;
+ break;
+ case SWIG_IOError:
+ type = rb_eIOError;
+ break;
+ case SWIG_RuntimeError:
+ type = rb_eRuntimeError;
+ break;
+ case SWIG_IndexError:
+ type = rb_eIndexError;
+ break;
+ case SWIG_TypeError:
+ type = rb_eTypeError;
+ break;
+ case SWIG_DivisionByZero:
+ type = rb_eZeroDivError;
+ break;
+ case SWIG_OverflowError:
+ type = rb_eRangeError;
+ break;
+ case SWIG_SyntaxError:
+ type = rb_eSyntaxError;
+ break;
+ case SWIG_ValueError:
+ type = rb_eArgError;
+ break;
+ case SWIG_SystemError:
+ type = rb_eFatal;
+ break;
+ case SWIG_AttributeError:
+ break;
+ case SWIG_NullReferenceError:
+ type = getNullReferenceError();
+ break;
+ case SWIG_ObjectPreviouslyDeletedError:
+ type = getObjectPreviouslyDeletedError();
+ break;
+ case SWIG_UnknownError:
+ break;
+ default:
+ return type;
+/* This function is called when a user inputs a wrong argument to
+ a method.
+SWIGINTERN
+const char* Ruby_Format_TypeError( const char* msg,
+ const char* type,
+ const char* name,
+ const int argn,
+ VALUE input )
+ char buf[128];
+ VALUE str;
+ VALUE asStr;
+ if ( msg && *msg )
+ str = rb_str_new2(msg);
+ else
+ str = rb_str_new(NULL, 0);
+ str = rb_str_cat2( str, "Expected argument " );
+ sprintf( buf, "%d of type ", argn-1 );
+ str = rb_str_cat2( str, buf );
+ str = rb_str_cat2( str, type );
+ str = rb_str_cat2( str, ", but got " );
+ str = rb_str_cat2( str, rb_obj_classname(input) );
+ str = rb_str_cat2( str, " " );
+ asStr = rb_inspect(input);
+ if ( RSTRING_LEN(asStr) > 30 )
+ str = rb_str_cat( str, StringValuePtr(asStr), 30 );
+ str = rb_str_cat2( str, "..." );
+ else
+ str = rb_str_append( str, asStr );
+ if ( name )
+ str = rb_str_cat2( str, "\n\tin SWIG method '" );
+ str = rb_str_cat2( str, name );
+ str = rb_str_cat2( str, "'" );
+ return StringValuePtr( str );
+/* This function is called when an overloaded method fails */
+SWIGINTERN
+void Ruby_Format_OverloadedError(
+ const int argc,
+ const int maxargs,
+ const char* method,
+ const char* prototypes
+ const char* msg = "Wrong # of arguments";
+ if ( argc <= maxargs ) msg = "Wrong arguments";
+ rb_raise(rb_eArgError,"%s for overloaded method '%s'.\n"
+ "Possible C/C++ prototypes are:\n%s",
+ msg, method, prototypes);
+ * See the LICENSE file for information on copyright, usage and redistribution
+ * of SWIG, and the README file for authors - http://www.swig.org/release.html.
+ * rubytracking.swg
+ * This file contains support for tracking mappings from
+ * Ruby objects to C++ objects. This functionality is needed
+ * to implement mark functions for Ruby's mark and sweep
+ * garbage collector.
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* Ruby 1.8 actually assumes the first case. */
+#if SIZEOF_VOIDP == SIZEOF_LONG
+# define SWIG2NUM(v) LONG2NUM((unsigned long)v)
+# define NUM2SWIG(x) (unsigned long)NUM2LONG(x)
+#elif SIZEOF_VOIDP == SIZEOF_LONG_LONG
+# define SWIG2NUM(v) LL2NUM((unsigned long long)v)
+# define NUM2SWIG(x) (unsigned long long)NUM2LL(x)
+#else
+# error sizeof(void*) is not the same as long or long long
+#endif
+/* Global Ruby hash table to store Trackings from C/C++
+ structs to Ruby Objects.
+static VALUE swig_ruby_trackings = Qnil;
+/* Global variable that stores a reference to the ruby
+ hash table delete function. */
+static ID swig_ruby_hash_delete;
+/* Setup a Ruby hash table to store Trackings */
+SWIGRUNTIME void SWIG_RubyInitializeTrackings(void) {
+ /* Create a ruby hash table to store Trackings from C++
+ objects to Ruby objects. */
+ /* Try to see if some other .so has already created a
+ tracking hash table, which we keep hidden in an instance var
+ in the SWIG module.
+ This is done to allow multiple DSOs to share the same
+ tracking table.
+ ID trackings_id = rb_intern( "@__trackings__" );
+ VALUE verbose = rb_gv_get("VERBOSE");
+ rb_gv_set("VERBOSE", Qfalse);
+ swig_ruby_trackings = rb_ivar_get( _mSWIG, trackings_id );
+ rb_gv_set("VERBOSE", verbose);
+ /* No, it hasn't. Create one ourselves */
+ if ( swig_ruby_trackings == Qnil )
+ swig_ruby_trackings = rb_hash_new();
+ rb_ivar_set( _mSWIG, trackings_id, swig_ruby_trackings );
+ /* Now store a reference to the hash table delete function
+ so that we only have to look it up once.*/
+ swig_ruby_hash_delete = rb_intern("delete");
+/* Get a Ruby number to reference a pointer */
+SWIGRUNTIME VALUE SWIG_RubyPtrToReference(void* ptr) {
+ /* We cast the pointer to an unsigned long
+ and then store a reference to it using
+ a Ruby number object. */
+ /* Convert the pointer to a Ruby number */
+ return SWIG2NUM(ptr);
+/* Get a Ruby number to reference an object */
+SWIGRUNTIME VALUE SWIG_RubyObjectToReference(VALUE object) {
+ /* We cast the object to an unsigned long
+ /* Convert the Object to a Ruby number */
+ return SWIG2NUM(object);
+/* Get a Ruby object from a previously stored reference */
+SWIGRUNTIME VALUE SWIG_RubyReferenceToObject(VALUE reference) {
+ /* The provided Ruby number object is a reference
+ to the Ruby object we want.*/
+ /* Convert the Ruby number to a Ruby object */
+ return NUM2SWIG(reference);
+/* Add a Tracking from a C/C++ struct to a Ruby object */
+SWIGRUNTIME void SWIG_RubyAddTracking(void* ptr, VALUE object) {
+ /* In a Ruby hash table we store the pointer and
+ the associated Ruby object. The trick here is
+ that we cannot store the Ruby object directly - if
+ we do then it cannot be garbage collected. So
+ instead we typecast it as a unsigned long and
+ convert it to a Ruby number object.*/
+ /* Get a reference to the pointer as a Ruby number */
+ VALUE key = SWIG_RubyPtrToReference(ptr);
+ /* Get a reference to the Ruby object as a Ruby number */
+ VALUE value = SWIG_RubyObjectToReference(object);
+ /* Store the mapping to the global hash table. */
+ rb_hash_aset(swig_ruby_trackings, key, value);
+/* Get the Ruby object that owns the specified C/C++ struct */
+SWIGRUNTIME VALUE SWIG_RubyInstanceFor(void* ptr) {
+ /* Now lookup the value stored in the global hash table */
+ VALUE value = rb_hash_aref(swig_ruby_trackings, key);
+ if (value == Qnil) {
+ /* No object exists - return nil. */
+ return Qnil;
+ else {
+ /* Convert this value to Ruby object */
+ return SWIG_RubyReferenceToObject(value);
+/* Remove a Tracking from a C/C++ struct to a Ruby object. It
+ is very important to remove objects once they are destroyed
+ since the same memory address may be reused later to create
+ a new object. */
+SWIGRUNTIME void SWIG_RubyRemoveTracking(void* ptr) {
+ /* Delete the object from the hash table by calling Ruby's
+ do this we need to call the Hash.delete method.*/
+ rb_funcall(swig_ruby_trackings, swig_ruby_hash_delete, 1, key);
+/* This is a helper method that unlinks a Ruby object from its
+ underlying C++ object. This is needed if the lifetime of the
+ Ruby object is longer than the C++ object */
+SWIGRUNTIME void SWIG_RubyUnlinkObjects(void* ptr) {
+ VALUE object = SWIG_RubyInstanceFor(ptr);
+ if (object != Qnil) {
+ DATA_PTR(object) = 0;
+#ifdef __cplusplus
+#endif
+ * Ruby API portion that goes into the runtime
+#ifdef __cplusplus
+extern "C" {
+#endif
+SWIGINTERN VALUE
+SWIG_Ruby_AppendOutput(VALUE target, VALUE o) {
+ if (NIL_P(target)) {
+ target = o;
+ } else {
+ if (TYPE(target) != T_ARRAY) {
+ VALUE o2 = target;
+ target = rb_ary_new();
+ rb_ary_push(target, o2);
+ rb_ary_push(target, o);
+ return target;
+/* For ruby1.8.4 and earlier. */
+#ifndef RUBY_INIT_STACK
+ RUBY_EXTERN void Init_stack(VALUE* addr);
+# define RUBY_INIT_STACK \
+ VALUE variable_in_this_stack_frame; \
+ Init_stack(&variable_in_this_stack_frame);
+#endif
+#ifdef __cplusplus
+#endif
+ * rubyrun.swg
+ * This file contains the runtime support for Ruby modules
+ * and includes code for managing global variables and pointer
+ * type checking.
+/* For backward compatibility only */
+#define SWIG_POINTER_EXCEPTION 0
+/* for raw pointers */
+#define SWIG_ConvertPtr(obj, pptr, type, flags) SWIG_Ruby_ConvertPtrAndOwn(obj, pptr, type, flags, 0)
+#define SWIG_ConvertPtrAndOwn(obj,pptr,type,flags,own) SWIG_Ruby_ConvertPtrAndOwn(obj, pptr, type, flags, own)
+#define SWIG_NewPointerObj(ptr, type, flags) SWIG_Ruby_NewPointerObj(ptr, type, flags)
+#define SWIG_AcquirePtr(ptr, own) SWIG_Ruby_AcquirePtr(ptr, own)
+#define swig_owntype ruby_owntype
+/* for raw packed data */
+#define SWIG_ConvertPacked(obj, ptr, sz, ty) SWIG_Ruby_ConvertPacked(obj, ptr, sz, ty, flags)
+#define SWIG_NewPackedObj(ptr, sz, type) SWIG_Ruby_NewPackedObj(ptr, sz, type)
+/* for class or struct pointers */
+#define SWIG_ConvertInstance(obj, pptr, type, flags) SWIG_ConvertPtr(obj, pptr, type, flags)
+#define SWIG_NewInstanceObj(ptr, type, flags) SWIG_NewPointerObj(ptr, type, flags)
+/* for C or C++ function pointers */
+#define SWIG_ConvertFunctionPtr(obj, pptr, type) SWIG_ConvertPtr(obj, pptr, type, 0)
+#define SWIG_NewFunctionPtrObj(ptr, type) SWIG_NewPointerObj(ptr, type, 0)
+/* for C++ member pointers, ie, member methods */
+#define SWIG_ConvertMember(obj, ptr, sz, ty) SWIG_Ruby_ConvertPacked(obj, ptr, sz, ty)
+#define SWIG_NewMemberObj(ptr, sz, type) SWIG_Ruby_NewPackedObj(ptr, sz, type)
+/* Runtime API */
+#define SWIG_GetModule(clientdata) SWIG_Ruby_GetModule()
+#define SWIG_SetModule(clientdata, pointer) SWIG_Ruby_SetModule(pointer)
+/* Error manipulation */
+#define SWIG_ErrorType(code) SWIG_Ruby_ErrorType(code)
+#define SWIG_Error(code, msg) rb_raise(SWIG_Ruby_ErrorType(code), msg)
+#define SWIG_fail goto fail
+/* Ruby-specific SWIG API */
+#define SWIG_InitRuntime() SWIG_Ruby_InitRuntime()
+#define SWIG_define_class(ty) SWIG_Ruby_define_class(ty)
+#define SWIG_NewClassInstance(value, ty) SWIG_Ruby_NewClassInstance(value, ty)
+#define SWIG_MangleStr(value) SWIG_Ruby_MangleStr(value)
+#define SWIG_CheckConvert(value, ty) SWIG_Ruby_CheckConvert(value, ty)
+#include "assert.h"
+ * pointers/data manipulation
+#ifdef __cplusplus
+extern "C" {
+#endif
+typedef struct {
+ VALUE klass;
+ VALUE mImpl;
+ void (*mark)(void *);
+ void (*destroy)(void *);
+ int trackObjects;
+} swig_class;
+/* Global pointer used to keep some internal SWIG stuff */
+static VALUE _cSWIG_Pointer = Qnil;
+static VALUE swig_runtime_data_type_pointer = Qnil;
+/* Global IDs used to keep some internal SWIG stuff */
+static ID swig_arity_id = 0;
+static ID swig_call_id = 0;
+ If your swig extension is to be run within an embedded ruby and has
+ director callbacks, you should set -DRUBY_EMBEDDED during compilation.
+ This will reset ruby's stack frame on each entry point from the main
+ program the first time a virtual director function is invoked (in a
+ non-recursive way).
+ If this is not done, you run the risk of Ruby trashing the stack.
+#ifdef RUBY_EMBEDDED
+# define SWIG_INIT_STACK \
+ if ( !swig_virtual_calls ) { RUBY_INIT_STACK } \
+ ++swig_virtual_calls;
+# define SWIG_RELEASE_STACK --swig_virtual_calls;
+# define Ruby_DirectorTypeMismatchException(x) \
+ rb_raise( rb_eTypeError, x ); return c_result;
+ static unsigned int swig_virtual_calls = 0;
+#else /* normal non-embedded extension */
+ throw Swig::DirectorTypeMismatchException( x );
+#endif /* RUBY_EMBEDDED */
+SWIGRUNTIME VALUE
+getExceptionClass(void) {
+ static VALUE rubyExceptionClass ;
+ if (!init) {
+ init = 1;
+ rubyExceptionClass = rb_const_get(_mSWIG, rb_intern("Exception"));
+ return rubyExceptionClass;
+/* This code checks to see if the Ruby object being raised as part
+ of an exception inherits from the Ruby class Exception. If so,
+ the object is simply returned. If not, then a new Ruby exception
+ object is created and that will be returned to Ruby.*/
+SWIGRUNTIME VALUE
+SWIG_Ruby_ExceptionType(swig_type_info *desc, VALUE obj) {
+ VALUE exceptionClass = getExceptionClass();
+ if (rb_obj_is_kind_of(obj, exceptionClass)) {
+ return obj;
+ } else {
+ return rb_exc_new3(rb_eRuntimeError, rb_obj_as_string(obj));
+/* Initialize Ruby runtime support */
+SWIGRUNTIME void
+SWIG_Ruby_InitRuntime(void)
+ if (_mSWIG == Qnil) {
+ _mSWIG = rb_define_module("SWIG");
+ swig_call_id = rb_intern("call");
+ swig_arity_id = rb_intern("arity");
+/* Define Ruby class for C type */
+SWIGRUNTIME void
+SWIG_Ruby_define_class(swig_type_info *type)
+ VALUE klass;
+ char *klass_name = (char *) malloc(4 + strlen(type->name) + 1);
+ sprintf(klass_name, "TYPE%s", type->name);
+ if (NIL_P(_cSWIG_Pointer)) {
+ _cSWIG_Pointer = rb_define_class_under(_mSWIG, "Pointer", rb_cObject);
+ rb_undef_method(CLASS_OF(_cSWIG_Pointer), "new");
+ klass = rb_define_class_under(_mSWIG, klass_name, _cSWIG_Pointer);
+ free((void *) klass_name);
+/* Create a new pointer object */
+SWIGRUNTIME VALUE
+SWIG_Ruby_NewPointerObj(void *ptr, swig_type_info *type, int flags)
+ int own = flags & SWIG_POINTER_OWN;
+ int track;
+ char *klass_name;
+ swig_class *sklass;
+ VALUE klass;
+ VALUE obj;
+ if (!ptr)
+ return Qnil;
+ if (type->clientdata) {
+ sklass = (swig_class *) type->clientdata;
+ /* Are we tracking this class and have we already returned this Ruby object? */
+ track = sklass->trackObjects;
+ if (track) {
+ obj = SWIG_RubyInstanceFor(ptr);
+ /* Check the object's type and make sure it has the correct type.
+ It might not in cases where methods do things like
+ downcast methods. */
+ if (obj != Qnil) {
+ VALUE value = rb_iv_get(obj, "@__swigtype__");
+ char* type_name = RSTRING_PTR(value);
+ if (strcmp(type->name, type_name) == 0) {
+ return obj;
+ /* Create a new Ruby object */
+ obj = Data_Wrap_Struct(sklass->klass, VOIDFUNC(sklass->mark),
+ ( own ? VOIDFUNC(sklass->destroy) :
+ (track ? VOIDFUNC(SWIG_RubyRemoveTracking) : 0 )
+ ), ptr);
+ /* If tracking is on for this class then track this object. */
+ if (track) {
+ SWIG_RubyAddTracking(ptr, obj);
+ } else {
+ klass_name = (char *) malloc(4 + strlen(type->name) + 1);
+ klass = rb_const_get(_mSWIG, rb_intern(klass_name));
+ obj = Data_Wrap_Struct(klass, 0, 0, ptr);
+ rb_iv_set(obj, "@__swigtype__", rb_str_new2(type->name));
+ return obj;
+/* Create a new class instance (always owned) */
+SWIGRUNTIME VALUE
+SWIG_Ruby_NewClassInstance(VALUE klass, swig_type_info *type)
+ VALUE obj;
+ swig_class *sklass = (swig_class *) type->clientdata;
+ obj = Data_Wrap_Struct(klass, VOIDFUNC(sklass->mark), VOIDFUNC(sklass->destroy), 0);
+ return obj;
+/* Get type mangle from class name */
+SWIGRUNTIMEINLINE char *
+SWIG_Ruby_MangleStr(VALUE obj)
+ VALUE stype = rb_iv_get(obj, "@__swigtype__");
+ return StringValuePtr(stype);
+/* Acquire a pointer value */
+typedef void (*ruby_owntype)(void*);
+SWIGRUNTIME ruby_owntype
+SWIG_Ruby_AcquirePtr(VALUE obj, ruby_owntype own) {
+ if (obj) {
+ ruby_owntype oldown = RDATA(obj)->dfree;
+ RDATA(obj)->dfree = own;
+ return oldown;
+ } else {
+ return 0;
+/* Convert a pointer value */
+SWIGRUNTIME int
+SWIG_Ruby_ConvertPtrAndOwn(VALUE obj, void **ptr, swig_type_info *ty, int flags, ruby_owntype *own)
+ char *c;
+ swig_cast_info *tc;
+ void *vptr = 0;
+ /* Grab the pointer */
+ if (NIL_P(obj)) {
+ *ptr = 0;
+ return SWIG_OK;
+ } else {
+ if (TYPE(obj) != T_DATA) {
+ return SWIG_ERROR;
+ Data_Get_Struct(obj, void, vptr);
+ if (own) *own = RDATA(obj)->dfree;
+ /* Check to see if the input object is giving up ownership
+ of the underlying C struct or C++ object. If so then we
+ need to reset the destructor since the Ruby object no
+ longer owns the underlying C++ object.*/
+ if (flags & SWIG_POINTER_DISOWN) {
+ /* Is tracking on for this class? */
+ int track = 0;
+ if (ty && ty->clientdata) {
+ swig_class *sklass = (swig_class *) ty->clientdata;
+ if (track) {
+ /* We are tracking objects for this class. Thus we change the destructor
+ * to SWIG_RubyRemoveTracking. This allows us to
+ * remove the mapping from the C++ to Ruby object
+ * when the Ruby object is garbage collected. If we don't
+ * do this, then it is possible we will return a reference
+ * to a Ruby object that no longer exists thereby crashing Ruby. */
+ RDATA(obj)->dfree = SWIG_RubyRemoveTracking;
+ } else {
+ RDATA(obj)->dfree = 0;
+ /* Do type-checking if type info was provided */
+ if (ty) {
+ if (ty->clientdata) {
+ if (rb_obj_is_kind_of(obj, ((swig_class *) (ty->clientdata))->klass)) {
+ if (vptr == 0) {
+ /* The object has already been deleted */
+ return SWIG_ObjectPreviouslyDeletedError;
+ *ptr = vptr;
+ return SWIG_OK;
+ if ((c = SWIG_MangleStr(obj)) == NULL) {
+ tc = SWIG_TypeCheck(c, ty);
+ if (!tc) {
+ } else {
+ int newmemory = 0;
+ *ptr = SWIG_TypeCast(tc, vptr, &newmemory);
+ assert(!newmemory); /* newmemory handling not yet implemented */
+ } else {
+ *ptr = vptr;
+ return SWIG_OK;
+/* Check convert */
+SWIGRUNTIMEINLINE int
+SWIG_Ruby_CheckConvert(VALUE obj, swig_type_info *ty)
+ char *c = SWIG_MangleStr(obj);
+ if (!c) return 0;
+ return SWIG_TypeCheck(c,ty) != 0;
+SWIGRUNTIME VALUE
+SWIG_Ruby_NewPackedObj(void *ptr, int sz, swig_type_info *type) {
+ char result[1024];
+ char *r = result;
+ if ((2*sz + 1 + strlen(type->name)) > 1000) return 0;
+ *(r++) = '_';
+ r = SWIG_PackData(r, ptr, sz);
+ strcpy(r, type->name);
+ return rb_str_new2(result);
+/* Convert a packed value value */
+SWIGRUNTIME int
+SWIG_Ruby_ConvertPacked(VALUE obj, void *ptr, int sz, swig_type_info *ty) {
+ const char *c;
+ if (TYPE(obj) != T_STRING) goto type_error;
+ c = StringValuePtr(obj);
+ /* Pointer values must start with leading underscore */
+ if (*c != '_') goto type_error;
+ c++;
+ c = SWIG_UnpackData(c, ptr, sz);
+ if (ty) {
+ if (!tc) goto type_error;
+ return SWIG_OK;
+ type_error:
+SWIGRUNTIME swig_module_info *
+SWIG_Ruby_GetModule(void)
+ VALUE pointer;
+ swig_module_info *ret = 0;
+ /* temporarily disable warnings, since the pointer check causes warnings with 'ruby -w' */
+ /* first check if pointer already created */
+ pointer = rb_gv_get("$swig_runtime_data_type_pointer" SWIG_RUNTIME_VERSION SWIG_TYPE_TABLE_NAME);
+ if (pointer != Qnil) {
+ Data_Get_Struct(pointer, swig_module_info, ret);
+ /* reinstate warnings */
+ return ret;
+SWIGRUNTIME void
+SWIG_Ruby_SetModule(swig_module_info *pointer)
+ /* register a new class */
+ VALUE cl = rb_define_class("swig_runtime_data", rb_cObject);
+ /* create and store the structure pointer to a global variable */
+ swig_runtime_data_type_pointer = Data_Wrap_Struct(cl, 0, 0, pointer);
+ rb_define_readonly_variable("$swig_runtime_data_type_pointer" SWIG_RUNTIME_VERSION SWIG_TYPE_TABLE_NAME, &swig_runtime_data_type_pointer);
+/* This function can be used to check whether a proc or method or similarly
+ callable function has been passed. Usually used in a %typecheck, like:
+ %typecheck(c_callback_t, precedence=SWIG_TYPECHECK_POINTER) {
+ $result = SWIG_Ruby_isCallable( $input );
+SWIGINTERN
+int SWIG_Ruby_isCallable( VALUE proc )
+ if ( rb_respond_to( proc, swig_call_id ) == Qtrue )
+ return 1;
+ return 0;
+/* This function can be used to check the arity (number of arguments)
+ a proc or method can take. Usually used in a %typecheck.
+ Valid arities will be that equal to minimal or those < 0
+ which indicate a variable number of parameters at the end.
+SWIGINTERN
+int SWIG_Ruby_arity( VALUE proc, int minimal )
+ if ( rb_respond_to( proc, swig_arity_id ) == Qtrue )
+ VALUE num = rb_funcall( proc, swig_arity_id, 0 );
+ int arity = NUM2INT(num);
+ if ( arity < 0 && (arity+1) < -minimal ) return 1;
+ if ( arity == minimal ) return 1;
+ return 1;
+ return 0;
+#ifdef __cplusplus
+#endif
+#define SWIG_exception_fail(code, msg) do { SWIG_Error(code, msg); SWIG_fail; } while(0)
+#define SWIG_contract_assert(expr, msg) if (!(expr)) { SWIG_Error(SWIG_RuntimeError, msg); SWIG_fail; } else
+ #define SWIG_exception(code, msg) do { SWIG_Error(code, msg);; } while(0)
+/* -------- TYPES TABLE (BEGIN) -------- */
+#define SWIGTYPE_p_GeosCoordinateSequence swig_types[0]
+#define SWIGTYPE_p_GeosGeometry swig_types[1]
+#define SWIGTYPE_p_GeosGeometryCollection swig_types[2]
+#define SWIGTYPE_p_GeosLineString swig_types[3]
+#define SWIGTYPE_p_GeosLinearRing swig_types[4]
+#define SWIGTYPE_p_GeosMultiLineString swig_types[5]
+#define SWIGTYPE_p_GeosMultiLinearRing swig_types[6]
+#define SWIGTYPE_p_GeosMultiPoint swig_types[7]
+#define SWIGTYPE_p_GeosMultiPolygon swig_types[8]
+#define SWIGTYPE_p_GeosPoint swig_types[9]
+#define SWIGTYPE_p_GeosPolygon swig_types[10]
+#define SWIGTYPE_p_GeosPreparedGeometry swig_types[11]
+#define SWIGTYPE_p_GeosSTRtree swig_types[12]
+#define SWIGTYPE_p_GeosWkbReader swig_types[13]
+#define SWIGTYPE_p_GeosWkbWriter swig_types[14]
+#define SWIGTYPE_p_GeosWktReader swig_types[15]
+#define SWIGTYPE_p_GeosWktWriter swig_types[16]
+#define SWIGTYPE_p_char swig_types[17]
+#define SWIGTYPE_p_p_GeosLinearRing swig_types[18]
+#define SWIGTYPE_p_p_void swig_types[19]
+#define SWIGTYPE_p_size_t swig_types[20]
+#define SWIGTYPE_p_swig__ConstIterator swig_types[21]
+#define SWIGTYPE_p_swig__GC_VALUE swig_types[22]
+#define SWIGTYPE_p_swig__Iterator swig_types[23]
+#define SWIGTYPE_p_unsigned_char swig_types[24]
+static swig_type_info *swig_types[26];
+static swig_module_info swig_module = {swig_types, 25, 0, 0, 0, 0};
+#define SWIG_TypeQuery(name) SWIG_TypeQueryModule(&swig_module, &swig_module, name)
+#define SWIG_MangledTypeQuery(name) SWIG_MangledTypeQueryModule(&swig_module, &swig_module, name)
+/* -------- TYPES TABLE (END) -------- */
+#define SWIG_init Init_geos
+#define SWIG_name "Geos"
+static VALUE mGeos;
+#define SWIG_RUBY_THREAD_BEGIN_BLOCK
+#define SWIG_RUBY_THREAD_END_BLOCK
+#define SWIGVERSION 0x010340
+#define SWIG_VERSION SWIGVERSION
+#define SWIG_as_voidptr(a) const_cast< void * >(static_cast< const void * >(a))
+#define SWIG_as_voidptrptr(a) ((void)SWIG_as_voidptr(*a),reinterpret_cast< void** >(a))
+#include <stdexcept>
+#include <string>
+#include <iostream>
+namespace swig {
+ class GC_VALUE {
+ protected:
+ // Hash of all GC_VALUE's currently in use
+ static VALUE _hash;
+ VALUE _obj;
+ static ID hash_id;
+ static ID lt_id;
+ static ID gt_id;
+ static ID eq_id;
+ static ID le_id;
+ static ID ge_id;
+ static ID pos_id;
+ static ID neg_id;
+ static ID inv_id;
+ static ID add_id;
+ static ID sub_id;
+ static ID mul_id;
+ static ID div_id;
+ static ID mod_id;
+ static ID and_id;
+ static ID or_id;
+ static ID xor_id;
+ static ID lshift_id;
+ static ID rshift_id;
+ struct OpArgs
+ VALUE src;
+ ID id;
+ int nargs;
+ VALUE target;
+ public:
+ static void initialize()
+ if ( _hash == Qnil )
+ _hash = rb_hash_new();
+ rb_gc_register_address( &_hash );
+ // this function is never called. Provided for symmetry only.
+ static void cleanup()
+ rb_gc_unregister_address( &_hash );
+ GC_VALUE() : _obj( Qnil )
+ GC_VALUE(const GC_VALUE& item) : _obj(item._obj)
+ GC_register();
+ GC_VALUE(VALUE obj) :_obj(obj)
+ GC_register();
+ ~GC_VALUE()
+ GC_unregister();
+ GC_VALUE & operator=(const GC_VALUE& item)
+ GC_unregister();
+ _obj = item._obj;
+ GC_register();
+ return *this;
+ void GC_register()
+ if ( FIXNUM_P(_obj) || SPECIAL_CONST_P(_obj) || SYMBOL_P(_obj) )
+ return;
+ VALUE val = rb_hash_aref( _hash, _obj );
+ unsigned n = FIXNUM_P(val) ? NUM2UINT(val) : 0;
+ ++n;
+ rb_hash_aset( _hash, _obj, INT2NUM(n) );
+ void GC_unregister()
+ return;
+ // this test should not be needed but I've noticed some very erratic
+ // behavior of none being unregistered in some very rare situations.
+ if ( BUILTIN_TYPE(_obj) == T_NONE ) return;
+ unsigned n = FIXNUM_P(val) ? NUM2UINT(val) : 1;
+ --n;
+ if ( n )
+ else
+ rb_hash_delete( _hash, _obj );
+ operator VALUE() const
+ return _obj;
+ VALUE inspect() const
+ return rb_inspect(_obj);
+ VALUE to_s() const
+ static VALUE swig_protect_funcall( VALUE p )
+ OpArgs* args = (OpArgs*) p;
+ return rb_funcall( args->src, args->id, args->nargs, args->target );
+#define GC_VALUE_CMP( op_id, op, cmp, cmpval ) \
+ bool op( const GC_VALUE& other ) const \
+ if ( FIXNUM_P(_obj) && FIXNUM_P(other._obj) ) \
+ return _obj cmp other._obj; \
+ bool res = false; \
+ VALUE ret = Qnil; \
+ SWIG_RUBY_THREAD_BEGIN_BLOCK; \
+ if ( rb_respond_to( _obj, op_id ) == Qtrue ) \
+ int status; \
+ OpArgs args; \
+ args.src = _obj; \
+ args.id = op_id; \
+ args.nargs = 1; \
+ args.target = VALUE(other); \
+ ret = rb_protect( PROTECTFUNC(swig_protect_funcall), \
+ VALUE(&args), &status ); \
+ if ( ret == Qnil ) { \
+ VALUE a = rb_funcall( _obj, hash_id, 0 ); \
+ VALUE b = rb_funcall( VALUE(other), hash_id, 0 ); \
+ res = a cmp b; \
+ else \
+ res = RTEST( ret ); \
+ SWIG_RUBY_THREAD_END_BLOCK; \
+ return res; \
+ GC_VALUE_CMP( eq_id, operator==, ==, == 0 )
+ GC_VALUE_CMP( lt_id, operator<, < , < 0 )
+ GC_VALUE_CMP( le_id, operator<=, <=, <= 0 )
+ GC_VALUE_CMP( gt_id, operator>, > , > 0 )
+ GC_VALUE_CMP( ge_id, operator>=, >=, >= 0 )
+#undef GC_VALUE_CMP
+ bool operator!=( const GC_VALUE& other )
+ return !(this->operator==(other));
+#define GC_VALUE_UNARY( proc_id, op ) \
+ GC_VALUE op() const \
+ int status; \
+ OpArgs args; \
+ args.id = proc_id; \
+ args.nargs = 0; \
+ args.target = Qnil; \
+ ret = rb_protect( PROTECTFUNC(swig_protect_funcall), VALUE(&args), \
+ &status ); \
+ return ret; \
+ GC_VALUE_UNARY( pos_id, operator+ )
+ GC_VALUE_UNARY( neg_id, operator- )
+ GC_VALUE_UNARY( inv_id, operator~ )
+#undef GC_VALUE_BINARY
+#define GC_VALUE_BINARY( proc_id, op ) \
+ GC_VALUE op( const GC_VALUE& other ) const \
+ int status; \
+ OpArgs args; \
+ args.nargs = 1; \
+ &status ); \
+ return GC_VALUE(ret); \
+ GC_VALUE_BINARY( add_id, operator+ );
+ GC_VALUE_BINARY( sub_id, operator- );
+ GC_VALUE_BINARY( mul_id, operator* );
+ GC_VALUE_BINARY( div_id, operator/ );
+ GC_VALUE_BINARY( mod_id, operator% );
+ GC_VALUE_BINARY( and_id, operator& );
+ GC_VALUE_BINARY( xor_id, operator^ );
+ GC_VALUE_BINARY( or_id, operator| );
+ GC_VALUE_BINARY( lshift_id, operator<< );
+ GC_VALUE_BINARY( rshift_id, operator>> );
+ ID GC_VALUE::hash_id = rb_intern("hash");
+ ID GC_VALUE::lt_id = rb_intern("<");
+ ID GC_VALUE::gt_id = rb_intern(">");
+ ID GC_VALUE::eq_id = rb_intern("==");
+ ID GC_VALUE::le_id = rb_intern("<=");
+ ID GC_VALUE::ge_id = rb_intern(">=");
+ ID GC_VALUE::pos_id = rb_intern("+@");
+ ID GC_VALUE::neg_id = rb_intern("-@");
+ ID GC_VALUE::inv_id = rb_intern("~");
+ ID GC_VALUE::add_id = rb_intern("+");
+ ID GC_VALUE::sub_id = rb_intern("-");
+ ID GC_VALUE::mul_id = rb_intern("*");
+ ID GC_VALUE::div_id = rb_intern("/");
+ ID GC_VALUE::mod_id = rb_intern("%");
+ ID GC_VALUE::and_id = rb_intern("&");
+ ID GC_VALUE::or_id = rb_intern("|");
+ ID GC_VALUE::xor_id = rb_intern("^");
+ ID GC_VALUE::lshift_id = rb_intern("<<");
+ ID GC_VALUE::rshift_id = rb_intern(">>");
+ VALUE GC_VALUE::_hash = Qnil;
+ typedef GC_VALUE LANGUAGE_OBJ;
+} // namespace swig
+#if defined(__GNUC__)
+# if __GNUC__ == 2 && __GNUC_MINOR <= 96
+# define SWIG_STD_NOMODERN_STL
+# endif
+#endif
+#include <string>
+namespace swig {
+ struct stop_iteration {
+ * Abstract base class used to represent all iterators of STL containers.
+ struct ConstIterator {
+ public:
+ typedef ConstIterator self_type;
+ protected:
+ GC_VALUE _seq;
+ protected:
+ ConstIterator(VALUE seq) : _seq(seq)
+ // Random access iterator methods, but not required in Ruby
+ virtual ptrdiff_t distance(const ConstIterator &x) const
+ throw std::invalid_argument("distance not supported");
+ virtual bool equal (const ConstIterator &x) const
+ throw std::invalid_argument("equal not supported");
+ virtual self_type* advance(ptrdiff_t n)
+ throw std::invalid_argument("advance not supported");
+ public:
+ virtual ~ConstIterator() {}
+ // Access iterator method, required by Ruby
+ virtual VALUE value() const {
+ throw std::invalid_argument("value not supported");
+ return Qnil;
+ virtual VALUE setValue( const VALUE& v ) {
+ throw std::invalid_argument("value= not supported");
+ return Qnil;
+ virtual self_type* next( size_t n = 1 )
+ return this->advance( n );
+ virtual self_type* previous( size_t n = 1 )
+ ptrdiff_t nn = n;
+ return this->advance( -nn );
+ virtual VALUE to_s() const {
+ throw std::invalid_argument("to_s not supported");
+ return Qnil;
+ virtual VALUE inspect() const {
+ throw std::invalid_argument("inspect not supported");
+ return Qnil;
+ virtual ConstIterator *dup() const
+ throw std::invalid_argument("dup not supported");
+ return NULL;
+ // C++ common/needed methods. We emulate a bidirectional
+ // operator, to be compatible with all the STL.
+ // The iterator traits will then tell the STL what type of
+ // iterator we really are.
+ ConstIterator() : _seq( Qnil )
+ ConstIterator( const self_type& b ) : _seq( b._seq )
+ self_type& operator=( const self_type& b )
+ _seq = b._seq;
+ return *this;
+ bool operator == (const ConstIterator& x) const
+ return equal(x);
+ bool operator != (const ConstIterator& x) const
+ return ! operator==(x);
+ // Pre-decrement operator
+ self_type& operator--()
+ return *previous();
+ // Pre-increment operator
+ self_type& operator++()
+ return *next();
+ // Post-decrement operator
+ self_type operator--(int)
+ self_type r = *this;
+ previous();
+ return r;
+ // Post-increment operator
+ self_type operator++(int)
+ next();
+ return r;
+ ConstIterator& operator += (ptrdiff_t n)
+ return *advance(n);
+ ConstIterator& operator -= (ptrdiff_t n)
+ return *advance(-n);
+ ConstIterator* operator + (ptrdiff_t n) const
+ return dup()->advance(n);
+ ConstIterator* operator - (ptrdiff_t n) const
+ return dup()->advance(-n);
+ ptrdiff_t operator - (const ConstIterator& x) const
+ return x.distance(*this);
+ static swig_type_info* descriptor() {
+ static swig_type_info* desc = 0;
+ if (!init) {
+ desc = SWIG_TypeQuery("swig::ConstIterator *");
+ init = 1;
+ return desc;
+ * Abstract base class used to represent all non-const iterators of STL containers.
+ struct Iterator : public ConstIterator {
+ public:
+ typedef Iterator self_type;
+ protected:
+ Iterator(VALUE seq) : ConstIterator(seq)
+ throw std::invalid_argument("operation not supported");
+ public:
+ if (!init) {
+ desc = SWIG_TypeQuery("swig::Iterator *");
+ init = 1;
+ return desc;
+ virtual Iterator *dup() const
+ return NULL;
+ ptrdiff_t nn = n;
+ return equal(x);
+ bool operator != (const Iterator& x) const
+ Iterator& operator += (ptrdiff_t n)
+ Iterator& operator -= (ptrdiff_t n)
+ Iterator* operator + (ptrdiff_t n) const
+ Iterator* operator - (ptrdiff_t n) const
+ ptrdiff_t operator - (const Iterator& x) const
+SWIGINTERN VALUE
+SWIG_ruby_failed(void)
+ return Qnil;
+/*@SWIG:/usr/share/swig1.3/ruby/rubyprimtypes.swg,23,%ruby_aux_method@*/
+SWIGINTERN VALUE SWIG_AUX_NUM2ULONG(VALUE *args)
+ VALUE obj = args[0];
+ VALUE type = TYPE(obj);
+ unsigned long *res = (unsigned long *)(args[1]);
+ *res = type == T_FIXNUM ? NUM2ULONG(obj) : rb_big2ulong(obj);
+ return obj;
+/*@SWIG@*/
+SWIGINTERN int
+SWIG_AsVal_unsigned_SS_long (VALUE obj, unsigned long *val)
+ if ((type == T_FIXNUM) || (type == T_BIGNUM)) {
+ unsigned long v;
+ VALUE a[2];
+ a[0] = obj;
+ a[1] = (VALUE)(&v);
+ if (rb_rescue(RUBY_METHOD_FUNC(SWIG_AUX_NUM2ULONG), (VALUE)a, RUBY_METHOD_FUNC(SWIG_ruby_failed), 0) != Qnil) {
+ if (val) *val = v;
+ return SWIG_OK;
+ return SWIG_TypeError;
+SWIG_AsVal_size_t (VALUE obj, size_t *val)
+ unsigned long v;
+ int res = SWIG_AsVal_unsigned_SS_long (obj, val ? &v : 0);
+ if (SWIG_IsOK(res) && val) *val = static_cast< size_t >(v);
+ return res;
+SWIGINTERNINLINE VALUE
+SWIG_From_bool (bool value)
+ return value ? Qtrue : Qfalse;
+SWIGINTERN VALUE SWIG_AUX_NUM2LONG(VALUE *args)
+ long *res = (long *)(args[1]);
+ *res = type == T_FIXNUM ? NUM2LONG(obj) : rb_big2long(obj);
+ return obj;
+/*@SWIG@*/
+SWIGINTERN int
+SWIG_AsVal_long (VALUE obj, long* val)
+ long v;
+ VALUE a[2];
+ a[0] = obj;
+ if (rb_rescue(RUBY_METHOD_FUNC(SWIG_AUX_NUM2LONG), (VALUE)a, RUBY_METHOD_FUNC(SWIG_ruby_failed), 0) != Qnil) {
+ return SWIG_OK;
+SWIG_AsVal_ptrdiff_t (VALUE obj, ptrdiff_t *val)
+ long v;
+ int res = SWIG_AsVal_long (obj, val ? &v : 0);
+ if (SWIG_IsOK(res) && val) *val = static_cast< ptrdiff_t >(v);
+ return res;
+#include <limits.h>
+#if !defined(SWIG_NO_LLONG_MAX)
+# if !defined(LLONG_MAX) && defined(__GNUC__) && defined (__LONG_LONG_MAX__)
+# define LLONG_MAX __LONG_LONG_MAX__
+# define LLONG_MIN (-LLONG_MAX - 1LL)
+# define ULLONG_MAX (LLONG_MAX * 2ULL + 1ULL)
+# endif
+#endif
+ #define SWIG_From_long LONG2NUM
+SWIG_From_ptrdiff_t (ptrdiff_t value)
+ return SWIG_From_long (static_cast< long >(value));
+#include <algorithm>
+#include <vector>
+#include "geos_c.h"
+/* Needed for va_start, etc. */
+#include <stdarg.h>
+SWIG_From_int (int value)
+ return SWIG_From_long (value);
+SWIGINTERN swig_type_info*
+SWIG_pchar_descriptor(void)
+ static swig_type_info* info = 0;
+ if (!init) {
+ info = SWIG_TypeQuery("_p_char");
+ init = 1;
+ return info;
+SWIG_FromCharPtrAndSize(const char* carray, size_t size)
+ if (carray) {
+ if (size > LONG_MAX) {
+ swig_type_info* pchar_descriptor = SWIG_pchar_descriptor();
+ return pchar_descriptor ?
+ SWIG_NewPointerObj(const_cast< char * >(carray), pchar_descriptor, 0) : Qnil;
+ } else {
+ return rb_str_new(carray, static_cast< long >(size));
+ } else {
+ return Qnil;
+SWIG_FromCharPtr(const char *cptr)
+ return SWIG_FromCharPtrAndSize(cptr, (cptr ? strlen(cptr) : 0));
+ static const int DEFAULT_QUADRANT_SEGMENTS=8;
+/* This is not thread safe ! */
+static const int MESSAGE_SIZE = 1000;
+static char message[MESSAGE_SIZE];
+void noticeHandler(const char *fmt, ...)
+ va_list args;
+ va_start(args, fmt);
+ vsnprintf(message, sizeof(message) - 1, fmt, args);
+ va_end(args);
+void errorHandler(const char *fmt, ...)
+ va_list args;
+ va_end(args);
+ /* this callback yields the data item to the block */
+ static void GeosSTRtree_query_callback (void *data, void *nothing) {
+ if (rb_block_given_p()) {
+ rb_yield((VALUE) data);
+ static void GeosSTRtree_mark_item (void *data, void *nothing)
+ if ((VALUE) data != Qnil) {
+ rb_gc_mark((VALUE)data);
+ static void mark_GeosSTRtree(void *self)
+ GEOSSTRtree *tree = (GEOSSTRtree *) self;
+ GEOSSTRtree_iterate(tree, GeosSTRtree_mark_item, NULL);
+typedef void GeosCoordinateSequence;
+void checkCoordSeqBounds(const GEOSCoordSeq coordSeq, const size_t index)
+ unsigned int size = 0;
+ GEOSCoordSeq_getSize(coordSeq, &size);
+ if (index < 0 || index >= size)
+ throw std::runtime_error("Index out of bounds");
+SWIGINTERN GeosCoordinateSequence *new_GeosCoordinateSequence(size_t size,size_t dims){
+ return (GeosCoordinateSequence*) GEOSCoordSeq_create(size, dims);
+SWIGINTERN GeosCoordinateSequence *GeosCoordinateSequence_clone(GeosCoordinateSequence *self){
+ GEOSCoordSeq coords = (GEOSCoordSeq) self;
+ return (GeosCoordinateSequence*) GEOSCoordSeq_clone(coords);
+SWIGINTERN VALUE SWIG_AUX_NUM2DBL(VALUE *args)
+ double *res = (double *)(args[1]);
+ *res = NUM2DBL(obj);
+ return obj;
+/*@SWIG@*/
+SWIGINTERN int
+SWIG_AsVal_double (VALUE obj, double *val)
+ if ((type == T_FLOAT) || (type == T_FIXNUM) || (type == T_BIGNUM)) {
+ double v;
+ VALUE a[2];
+ a[0] = obj;
+ if (rb_rescue(RUBY_METHOD_FUNC(SWIG_AUX_NUM2DBL), (VALUE)a, RUBY_METHOD_FUNC(SWIG_ruby_failed), 0) != Qnil) {
+ return SWIG_OK;
+SWIGINTERN int GeosCoordinateSequence_setX(GeosCoordinateSequence *self,size_t idx,double val){
+ checkCoordSeqBounds(coords, idx);
+ return GEOSCoordSeq_setX(coords, idx, val);
+SWIGINTERN int GeosCoordinateSequence_setY(GeosCoordinateSequence *self,size_t idx,double val){
+ return GEOSCoordSeq_setY(coords, idx, val);
+SWIGINTERN int GeosCoordinateSequence_setZ(GeosCoordinateSequence *self,size_t idx,double val){
+ return GEOSCoordSeq_setZ(coords, idx, val);
+SWIGINTERN int GeosCoordinateSequence_setOrdinate(GeosCoordinateSequence *self,size_t idx,size_t dim,double val){
+ return GEOSCoordSeq_setOrdinate(coords, idx, dim, val);
+SWIGINTERN double GeosCoordinateSequence_getX(GeosCoordinateSequence *self,size_t idx){
+ double result;
+ GEOSCoordSeq_getX(coords, idx, &result);
+ return result;
+ #define SWIG_From_double rb_float_new
+SWIGINTERN double GeosCoordinateSequence_getY(GeosCoordinateSequence *self,size_t idx){
+ double result;
+ GEOSCoordSeq_getY(coords, idx, &result);
+ return result;
+SWIGINTERN double GeosCoordinateSequence_getZ(GeosCoordinateSequence *self,size_t idx){
+ double result;
+ GEOSCoordSeq_getZ(coords, idx, &result);
+ return result;
+SWIGINTERN double GeosCoordinateSequence_getOrdinate(GeosCoordinateSequence *self,size_t idx,size_t dim){
+ double result;
+ GEOSCoordSeq_getOrdinate(coords, idx, dim, &result);
+ return result;
+SWIGINTERN unsigned int GeosCoordinateSequence_getSize(GeosCoordinateSequence *self){
+ unsigned int result;
+ GEOSCoordSeq_getSize(coords, &result);
+ return result;
+SWIG_From_unsigned_SS_long (unsigned long value)
+ return ULONG2NUM(value);
+SWIG_From_unsigned_SS_int (unsigned int value)
+ return SWIG_From_unsigned_SS_long (value);
+SWIGINTERN unsigned int GeosCoordinateSequence_getDimensions(GeosCoordinateSequence *self){
+ GEOSCoordSeq_getDimensions(coords, &result);
+ return result;
+typedef void GeosGeometry;
+typedef void GeosPoint;
+typedef void GeosLineString;
+typedef void GeosLinearRing;
+typedef void GeosPolygon;
+typedef void GeosGeometryCollection;
+typedef void GeosMultiPoint;
+typedef void GeosMultiLineString;
+typedef void GeosMultiLinearRing;
+typedef void GeosMultiPolygon;
+typedef void GeosWktReader;
+typedef void GeosWktWriter;
+typedef void GeosWkbReader;
+typedef void GeosWkbWriter;
+bool checkBoolResult(char result)
+ int intResult = (int) result;
+ if (intResult == 1)
+ return true;
+ else if (intResult == 0)
+ return false;
+ else
+ throw std::runtime_error(message);
+SWIGINTERN GeosGeometry *GeosGeometry_clone(GeosGeometry *self){
+ GEOSGeom geom = (GEOSGeom) self;
+ return GEOSGeom_clone(geom);
+SWIGINTERN char *GeosGeometry_geomType(GeosGeometry *self){
+ return GEOSGeomType(geom);
+SWIGINTERN int GeosGeometry_typeId(GeosGeometry *self){
+ return GEOSGeomTypeId(geom);
+SWIGINTERN void GeosGeometry_normalize(GeosGeometry *self){
+ int result = GEOSNormalize(geom);
+ if (result == -1)
+SWIGINTERN int GeosGeometry_getSRID(GeosGeometry *self){
+ return GEOSGetSRID(geom);
+SWIGINTERN int
+SWIG_AsVal_int (VALUE obj, int *val)
+ long v;
+ int res = SWIG_AsVal_long (obj, &v);
+ if ((v < INT_MIN || v > INT_MAX)) {
+ return SWIG_OverflowError;
+ } else {
+ if (val) *val = static_cast< int >(v);
+ return res;
+SWIGINTERN void GeosGeometry_setSRID(GeosGeometry *self,int SRID){
+ return GEOSSetSRID(geom, SRID);
+SWIGINTERN size_t GeosGeometry_getDimensions(GeosGeometry *self){
+ return GEOSGeom_getDimensions(geom);
+SWIG_From_size_t (size_t value)
+ return SWIG_From_unsigned_SS_long (static_cast< unsigned long >(value));
+SWIGINTERN size_t GeosGeometry_getNumGeometries(GeosGeometry *self){
+ size_t result = GEOSGetNumGeometries(geom);
+ if ((int)result == -1)
+ return result;
+SWIGINTERN GeosGeometry *GeosGeometry_intersection(GeosGeometry *self,GeosGeometry *other){
+ GEOSGeom otherGeom = (GEOSGeom) other;
+ return (GeosGeometry*) GEOSIntersection(geom, otherGeom);
+SWIGINTERN GeosGeometry *GeosGeometry_buffer(GeosGeometry *self,double width,int quadsegs){
+ return (GeosGeometry*) GEOSBuffer(geom, width, quadsegs);
+SWIGINTERN GeosGeometry *GeosGeometry_convexHull(GeosGeometry *self){
+ return (GeosGeometry*) GEOSConvexHull(geom);
+SWIGINTERN GeosGeometry *GeosGeometry_difference(GeosGeometry *self,GeosGeometry *other){
+ return (GeosGeometry*) GEOSDifference(geom, otherGeom);
+SWIGINTERN GeosGeometry *GeosGeometry_symDifference(GeosGeometry *self,GeosGeometry *other){
+ return (GeosGeometry*) GEOSSymDifference(geom, otherGeom);
+SWIGINTERN GeosGeometry *GeosGeometry_boundary(GeosGeometry *self){
+ return (GeosGeometry*) GEOSBoundary(geom);
+SWIGINTERN GeosGeometry *GeosGeometry_geomUnion(GeosGeometry *self,GeosGeometry *other){
+ return (GeosGeometry*) GEOSUnion(geom, otherGeom);
+SWIGINTERN GeosGeometry *GeosGeometry_pointOnSurface(GeosGeometry *self){
+ return (GeosGeometry*) GEOSPointOnSurface(geom);
+SWIGINTERN GeosGeometry *GeosGeometry_getCentroid(GeosGeometry *self){
+ return (GeosGeometry*) GEOSGetCentroid(geom);
+SWIGINTERN GeosGeometry *GeosGeometry_getEnvelope(GeosGeometry *self){
+ return (GeosGeometry*) GEOSEnvelope(geom);
+SWIGINTERN char *GeosGeometry_relate(GeosGeometry *self,GeosGeometry *other){
+ return GEOSRelate(geom, otherGeom);
+SWIGINTERN GeosGeometry *GeosGeometry_lineMerge(GeosGeometry *self){
+ return GEOSLineMerge(geom);
+SWIGINTERN GeosGeometry *GeosGeometry_simplify(GeosGeometry *self,double tolerance){
+ return (GeosGeometry*) GEOSSimplify(geom, tolerance);
+SWIGINTERN GeosGeometry *GeosGeometry_topologyPreserveSimplify(GeosGeometry *self,double tolerance){
+ return (GeosGeometry*) GEOSTopologyPreserveSimplify(geom, tolerance);
+SWIGINTERN int
+SWIG_AsCharPtrAndSize(VALUE obj, char** cptr, size_t* psize, int *alloc)
+ if (TYPE(obj) == T_STRING) {
+ #if defined(StringValuePtr)
+ char *cstr = StringValuePtr(obj);
+ #else
+ char *cstr = STR2CSTR(obj);
+ #endif
+ size_t size = RSTRING_LEN(obj) + 1;
+ if (cptr) {
+ if (alloc) {
+ if (*alloc == SWIG_NEWOBJ) {
+ *cptr = reinterpret_cast< char* >(memcpy((new char[size]), cstr, sizeof(char)*(size)));
+ } else {
+ *cptr = cstr;
+ *alloc = SWIG_OLDOBJ;
+ if (psize) *psize = size;
+ return SWIG_OK;
+ } else {
+ if (pchar_descriptor) {
+ void* vptr = 0;
+ if (SWIG_ConvertPtr(obj, &vptr, pchar_descriptor, 0) == SWIG_OK) {
+ if (cptr) *cptr = (char *)vptr;
+ if (psize) *psize = vptr ? (strlen((char*)vptr) + 1) : 0;
+ if (alloc) *alloc = SWIG_OLDOBJ;
+ return SWIG_OK;
+SWIGINTERN bool GeosGeometry_relatePattern(GeosGeometry *self,GeosGeometry const *other,char const *pat){
+ return checkBoolResult(GEOSRelatePattern(geom, otherGeom, pat));
+SWIGINTERN bool GeosGeometry_disjoint(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSDisjoint(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_touches(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSTouches(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_intersects(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSIntersects(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_crosses(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSCrosses(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_within(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSWithin(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_contains(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSContains(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_overlaps(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSOverlaps(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_equals(GeosGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSEquals(geom, otherGeom));
+SWIGINTERN bool GeosGeometry_equalsExact(GeosGeometry *self,GeosGeometry const *other,double tolerance){
+ return checkBoolResult(GEOSEqualsExact(geom, otherGeom, tolerance));
+SWIGINTERN bool GeosGeometry_isEmpty(GeosGeometry *self){
+ return checkBoolResult(GEOSisEmpty(geom));
+SWIGINTERN bool GeosGeometry_isValid(GeosGeometry *self){
+ return checkBoolResult(GEOSisValid(geom));
+SWIGINTERN bool GeosGeometry_isSimple(GeosGeometry *self){
+ return checkBoolResult(GEOSisSimple(geom));
+SWIGINTERN bool GeosGeometry_isRing(GeosGeometry *self){
+ return checkBoolResult(GEOSisRing(geom));
+SWIGINTERN bool GeosGeometry_hasZ(GeosGeometry *self){
+ return checkBoolResult(GEOSHasZ(geom));
+SWIGINTERN double GeosGeometry_area(GeosGeometry *self){
+ double result;
+ int code = GEOSArea(geom, &result);
+ if (code == 0)
+ return result;
+SWIGINTERN double GeosGeometry_length(GeosGeometry *self){
+ double result;
+ int code = GEOSLength(geom, &result);
+ if (code == 0)
+ return result;
+SWIGINTERN double GeosGeometry_distance(GeosGeometry *self,GeosGeometry const *other){
+ double result;
+ int code = GEOSDistance(geom, otherGeom, &result);
+ if (code == 0)
+ return result;
+SWIGINTERN GeosCoordinateSequence const *GeosPoint_getCoordSeq(GeosPoint *self){
+ const GEOSCoordSeq result = (const GEOSCoordSeq) GEOSGeom_getCoordSeq(geom);
+ if (result == NULL)
+ return (const GeosCoordinateSequence*) result;
+SWIGINTERN GeosCoordinateSequence const *GeosLineString_getCoordSeq(GeosLineString *self){
+SWIGINTERN GeosCoordinateSequence const *GeosLinearRing_getCoordSeq(GeosLinearRing *self){
+SWIGINTERN GeosGeometry const *GeosPolygon_getExteriorRing(GeosPolygon *self){
+ const GEOSGeom result = (const GEOSGeom) GEOSGetExteriorRing(geom);
+ return (const GeosGeometry*) result;
+SWIGINTERN size_t GeosPolygon_getNumInteriorRings(GeosPolygon *self){
+ size_t result = GEOSGetNumInteriorRings(geom);
+ return result;
+SWIGINTERN GeosGeometry const *GeosPolygon_getInteriorRingN(GeosPolygon *self,size_t n){
+ size_t size = GEOSGetNumInteriorRings(geom);
+ if (n < 0 || n >= size)
+ const GEOSGeom result = (const GEOSGeom) GEOSGetInteriorRingN(geom, n);
+SWIGINTERN GeosGeometry const *GeosGeometryCollection_getGeometryN(GeosGeometryCollection *self,size_t n){
+ const GEOSGeom result = (const GEOSGeom) GEOSGetGeometryN(geom, n);
+GeosGeometry *createPoint(GeosCoordinateSequence *s)
+ GEOSCoordSeq coords = (GEOSCoordSeq) s;
+ GEOSGeom geom = GEOSGeom_createPoint(coords);
+ if(geom == NULL)
+ return (GeosGeometry*) geom;
+GeosGeometry *createLineString(GeosCoordinateSequence *s)
+ GEOSGeom geom = GEOSGeom_createLineString(coords);
+ if(geom == NULL)
+GeosGeometry *createLinearRing(GeosCoordinateSequence *s)
+ GEOSGeom geom = GEOSGeom_createLinearRing(coords);
+ if(geom == NULL)
+GeosGeometry *createPolygon(GeosLinearRing *shell, GeosLinearRing **holes, size_t nholes)
+ GEOSGeom shellGeom = (GEOSGeom) shell;
+ GEOSGeom* holeGeoms = (GEOSGeom*) holes;
+ GEOSGeom geom = GEOSGeom_createPolygon(shellGeom, holeGeoms, nholes);
+ if(geom == NULL)
+typedef void GeosPreparedGeometry;
+SWIGINTERN GeosPreparedGeometry *new_GeosPreparedGeometry(GeosGeometry const *source){
+ const GEOSPreparedGeometry *prep = GEOSPrepare((const GEOSGeometry *)source);
+ if(prep == NULL)
+ return (GeosPreparedGeometry *) prep;
+SWIGINTERN bool GeosPreparedGeometry_contains(GeosPreparedGeometry *self,GeosGeometry const *other){
+ GEOSPreparedGeometry *prep = (GEOSPreparedGeometry *) self;
+ return checkBoolResult(GEOSPreparedContains(prep, otherGeom));
+SWIGINTERN bool GeosPreparedGeometry_containsProperly(GeosPreparedGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSPreparedContainsProperly(prep, otherGeom));
+SWIGINTERN bool GeosPreparedGeometry_covers(GeosPreparedGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSPreparedCovers(prep, otherGeom));
+SWIGINTERN bool GeosPreparedGeometry_intersects(GeosPreparedGeometry *self,GeosGeometry const *other){
+ return checkBoolResult(GEOSPreparedIntersects(prep, otherGeom));
+typedef void GeosSTRtree;
+/* GeosIndexItem typedef'd here so it can be %typemap(typecheck)'d
+ as a native object by each language specially */
+typedef void *GeosIndexItem;
+typedef GEOSQueryCallback GeosQueryCallback;
+SWIGINTERN GeosSTRtree *new_GeosSTRtree(int nodeCapacity){
+ GEOSSTRtree *tree = GEOSSTRtree_create(nodeCapacity);
+ if(tree == NULL)
+ return (GeosSTRtree *) tree;
+SWIGINTERN void GeosSTRtree_insert(GeosSTRtree *self,GeosGeometry const *g,GeosIndexItem item){
+ const GEOSGeometry *geom = (const GEOSGeometry *) g;
+ GEOSSTRtree_insert(tree, geom, item);
+SWIGINTERN void GeosSTRtree_remove(GeosSTRtree *self,GeosGeometry const *g,GeosIndexItem item){
+ GEOSSTRtree_remove(tree, geom, item);
+SWIGINTERN void GeosSTRtree_query(GeosSTRtree *self,GeosGeometry const *g,GeosQueryCallback callback,GeosIndexItem accumulator){
+ GEOSSTRtree_query(tree, geom, callback, accumulator);
+SWIGINTERN void GeosSTRtree_iterate(GeosSTRtree *self,GeosQueryCallback callback,GeosIndexItem accumulator){
+ GEOSSTRtree_iterate(tree, callback, accumulator);
+SWIGINTERN GeosWktReader *new_GeosWktReader(){
+ return GEOSWKTReader_create();
+SWIGINTERN GeosGeometry *GeosWktReader_read(GeosWktReader *self,char const *wkt){
+ if(wkt == NULL)
+ throw std::runtime_error("Trying to create geometry from a NULL string");
+ GEOSWKTReader *reader = (GEOSWKTReader*) self;
+ GEOSGeometry *geom = GEOSWKTReader_read(reader, wkt);
+ if(geom == NULL)
+SWIGINTERN GeosWktWriter *new_GeosWktWriter(){
+ return GEOSWKTWriter_create();
+SWIGINTERN char *GeosWktWriter_write(GeosWktWriter *self,GeosGeometry const *g){
+ GEOSWKTWriter *writer = (GEOSWKTWriter*) self;
+ GEOSGeom geom = (GEOSGeom) g;
+ return GEOSWKTWriter_write(writer, geom);
+SWIGINTERN GeosWkbReader *new_GeosWkbReader(){
+ return GEOSWKBReader_create();
+SWIGINTERN GeosGeometry *GeosWkbReader_read(GeosWkbReader *self,unsigned char const *wkb,size_t size){
+ if(wkb == NULL)
+ GEOSWKBReader *reader = (GEOSWKBReader*) self;
+ GEOSGeometry *geom = GEOSWKBReader_read(reader, wkb, size);
+ if(geom == NULL)
+SWIGINTERN GeosGeometry *GeosWkbReader_readHEX(GeosWkbReader *self,unsigned char const *wkb,size_t size){
+ if(wkb == NULL)
+ GEOSGeometry *geom = GEOSWKBReader_readHEX(reader, wkb, size);
+ if(geom == NULL)
+SWIGINTERN GeosWkbWriter *new_GeosWkbWriter(){
+ return GEOSWKBWriter_create();
+SWIGINTERN int GeosWkbWriter_getOutputDimension(GeosWkbWriter *self){
+ GEOSWKBWriter *writer = (GEOSWKBWriter*) self;
+ return GEOSWKBWriter_getOutputDimension(writer);
+SWIGINTERN void GeosWkbWriter_setOutputDimension(GeosWkbWriter *self,int newDimension){
+ GEOSWKBWriter_setOutputDimension(writer, newDimension);
+SWIGINTERN int GeosWkbWriter_getByteOrder(GeosWkbWriter *self){
+ return GEOSWKBWriter_getByteOrder(writer);
+SWIGINTERN void GeosWkbWriter_setByteOrder(GeosWkbWriter *self,int newByteOrder){
+ return GEOSWKBWriter_setByteOrder(writer, newByteOrder);
+SWIGINTERN bool GeosWkbWriter_getIncludeSRID(GeosWkbWriter *self){
+ return GEOSWKBWriter_getIncludeSRID(writer);
+SWIGINTERN int
+SWIG_AsVal_bool (VALUE obj, bool *val)
+ if (obj == Qtrue) {
+ if (val) *val = true;
+ return SWIG_OK;
+ } else if (obj == Qfalse) {
+ if (val) *val = false;
+ return SWIG_OK;
+ } else {
+ int res = 0;
+ if (SWIG_AsVal_int (obj, &res) == SWIG_OK) {
+ if (val) *val = res ? true : false;
+ return SWIG_OK;
+SWIGINTERN void GeosWkbWriter_setIncludeSRID(GeosWkbWriter *self,bool newIncludeSRID){
+ return GEOSWKBWriter_setIncludeSRID(writer, newIncludeSRID);
+SWIGINTERN unsigned char *GeosWkbWriter_write(GeosWkbWriter *self,GeosGeometry const *g,size_t *size){
+ return GEOSWKBWriter_write(writer, geom, size);
+SWIGINTERN unsigned char *GeosWkbWriter_writeHEX(GeosWkbWriter *self,GeosGeometry const *g,size_t *size){
+ return GEOSWKBWriter_writeHEX(writer, geom, size);
+swig_class SwigClassGCVALUE;
+ Document-method: Geos::GCVALUE.inspect
+ call-seq:
+ inspect -> VALUE
+Inspect class and its contents.
+SWIGINTERN VALUE
+_wrap_GCVALUE_inspect(int argc, VALUE *argv, VALUE self) {
+ swig::GC_VALUE *arg1 = (swig::GC_VALUE *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ VALUE result;
+ VALUE vresult = Qnil;
+ if ((argc < 0) || (argc > 0)) {
+ rb_raise(rb_eArgError, "wrong # of arguments(%d for 0)",argc); SWIG_fail;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_swig__GC_VALUE, 0 | 0 );
+ if (!SWIG_IsOK(res1)) {
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::GC_VALUE const *","inspect", 1, self ));
+ arg1 = reinterpret_cast< swig::GC_VALUE * >(argp1);
+ result = (VALUE)((swig::GC_VALUE const *)arg1)->inspect();
+ vresult = result;
+ return vresult;
+fail:
+ return Qnil;
+ Document-method: Geos::GCVALUE.to_s
+ call-seq:
+ to_s -> VALUE
+Convert class to a String representation.
+SWIGINTERN VALUE
+_wrap_GCVALUE_to_s(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ VALUE result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::GC_VALUE const *","to_s", 1, self ));
+ result = (VALUE)((swig::GC_VALUE const *)arg1)->to_s();
+ vresult = result;
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassConstIterator;
+SWIGINTERN void
+free_swig_ConstIterator(swig::ConstIterator *arg1) {
+ delete arg1;
+SWIGINTERN VALUE
+_wrap_ConstIterator_value(int argc, VALUE *argv, VALUE self) {
+ swig::ConstIterator *arg1 = (swig::ConstIterator *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ VALUE result;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_swig__ConstIterator, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::ConstIterator const *","value", 1, self ));
+ arg1 = reinterpret_cast< swig::ConstIterator * >(argp1);
+ try {
+ result = (VALUE)((swig::ConstIterator const *)arg1)->value();
+ catch(swig::stop_iteration &_e) {
+ (void)_e;
+ SWIG_Ruby_ExceptionType(NULL, Qnil);
+ SWIG_fail;
+ vresult = result;
+ return vresult;
+fail:
+ return Qnil;
+ Document-method: Geos::ConstIterator.dup
+ call-seq:
+ dup -> ConstIterator
+Create a duplicate of the class and unfreeze it if needed.
+SWIGINTERN VALUE
+_wrap_ConstIterator_dup(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ swig::ConstIterator *result = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::ConstIterator const *","dup", 1, self ));
+ result = (swig::ConstIterator *)((swig::ConstIterator const *)arg1)->dup();
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__ConstIterator, SWIG_POINTER_OWN | 0 );
+ return vresult;
+fail:
+ return Qnil;
+ Document-method: Geos::ConstIterator.inspect
+ call-seq:
+ inspect -> VALUE
+SWIGINTERN VALUE
+_wrap_ConstIterator_inspect(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ VALUE result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::ConstIterator const *","inspect", 1, self ));
+ result = (VALUE)((swig::ConstIterator const *)arg1)->inspect();
+ vresult = result;
+ return vresult;
+fail:
+ return Qnil;
+ Document-method: Geos::ConstIterator.to_s
+ call-seq:
+ to_s -> VALUE
+SWIGINTERN VALUE
+_wrap_ConstIterator_to_s(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ VALUE result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::ConstIterator const *","to_s", 1, self ));
+ result = (VALUE)((swig::ConstIterator const *)arg1)->to_s();
+ vresult = result;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_ConstIterator_next__SWIG_0(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ if ((argc < 1) || (argc > 1)) {
+ rb_raise(rb_eArgError, "wrong # of arguments(%d for 1)",argc); SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::ConstIterator *","next", 1, self ));
+ ecode2 = SWIG_AsVal_size_t(argv[0], &val2);
+ if (!SWIG_IsOK(ecode2)) {
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","next", 2, argv[0] ));
+ arg2 = static_cast< size_t >(val2);
+ result = (swig::ConstIterator *)(arg1)->next(arg2);
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__ConstIterator, 0 | 0 );
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_ConstIterator_next__SWIG_1(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ try {
+ result = (swig::ConstIterator *)(arg1)->next();
+ (void)_e;
+ SWIG_fail;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE _wrap_ConstIterator_next(int nargs, VALUE *args, VALUE self) {
+ int argc;
+ VALUE argv[3];
+ int ii;
+ argc = nargs + 1;
+ argv[0] = self;
+ if (argc > 3) SWIG_fail;
+ for (ii = 1; (ii < argc); ++ii) {
+ argv[ii] = args[ii-1];
+ if (argc == 1) {
+ int _v;
+ void *vptr = 0;
+ int res = SWIG_ConvertPtr(argv[0], &vptr, SWIGTYPE_p_swig__ConstIterator, 0);
+ _v = SWIG_CheckState(res);
+ if (_v) {
+ return _wrap_ConstIterator_next__SWIG_1(nargs, args, self);
+ if (argc == 2) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ int res = SWIG_AsVal_size_t(argv[1], NULL);
+ if (_v) {
+ return _wrap_ConstIterator_next__SWIG_0(nargs, args, self);
+fail:
+ Ruby_Format_OverloadedError( argc, 3, "ConstIterator.next",
+ " swig::ConstIterator * ConstIterator.next(size_t n)\n"
+ " swig::ConstIterator * ConstIterator.next()\n");
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_ConstIterator_previous__SWIG_0(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::ConstIterator *","previous", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","previous", 2, argv[0] ));
+ result = (swig::ConstIterator *)(arg1)->previous(arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_ConstIterator_previous__SWIG_1(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ try {
+ result = (swig::ConstIterator *)(arg1)->previous();
+ (void)_e;
+ SWIG_fail;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE _wrap_ConstIterator_previous(int nargs, VALUE *args, VALUE self) {
+ int argc;
+ VALUE argv[3];
+ int ii;
+ argc = nargs + 1;
+ argv[0] = self;
+ if (argc == 1) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ return _wrap_ConstIterator_previous__SWIG_1(nargs, args, self);
+ if (argc == 2) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ if (_v) {
+ return _wrap_ConstIterator_previous__SWIG_0(nargs, args, self);
+fail:
+ Ruby_Format_OverloadedError( argc, 3, "ConstIterator.previous",
+ " swig::ConstIterator * ConstIterator.previous(size_t n)\n"
+ " swig::ConstIterator * ConstIterator.previous()\n");
+ return Qnil;
+ Document-method: Geos::ConstIterator.==
+ call-seq:
+ ==(x) -> bool
+Equality comparison operator.
+SWIGINTERN VALUE
+_wrap_ConstIterator___eq__(int argc, VALUE *argv, VALUE self) {
+ swig::ConstIterator *arg2 = 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 ;
+ int res2 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::ConstIterator const *","operator ==", 1, self ));
+ res2 = SWIG_ConvertPtr(argv[0], &argp2, SWIGTYPE_p_swig__ConstIterator, 0 );
+ if (!SWIG_IsOK(res2)) {
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "swig::ConstIterator const &","operator ==", 2, argv[0] ));
+ if (!argp2) {
+ SWIG_exception_fail(SWIG_ValueError, Ruby_Format_TypeError("invalid null reference ", "swig::ConstIterator const &","operator ==", 2, argv[0]));
+ arg2 = reinterpret_cast< swig::ConstIterator * >(argp2);
+ result = (bool)((swig::ConstIterator const *)arg1)->operator ==((swig::ConstIterator const &)*arg2);
+ vresult = SWIG_From_bool(static_cast< bool >(result));
+ return vresult;
+fail:
+ return Qnil;
+ Document-method: Geos::ConstIterator.+
+ call-seq:
+ +(n) -> ConstIterator
+Add operator.
+SWIGINTERN VALUE
+_wrap_ConstIterator___add__(int argc, VALUE *argv, VALUE self) {
+ ptrdiff_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ ptrdiff_t val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::ConstIterator const *","operator +", 1, self ));
+ ecode2 = SWIG_AsVal_ptrdiff_t(argv[0], &val2);
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "ptrdiff_t","operator +", 2, argv[0] ));
+ arg2 = static_cast< ptrdiff_t >(val2);
+ try {
+ result = (swig::ConstIterator *)((swig::ConstIterator const *)arg1)->operator +(arg2);
+ (void)_e;
+ SWIG_fail;
+ return vresult;
+fail:
+ return Qnil;
+ Document-method: Geos::ConstIterator.-
+ call-seq:
+ -(n) -> ConstIterator
+ -(x) -> ptrdiff_t
+Substraction operator.
+SWIGINTERN VALUE
+_wrap_ConstIterator___sub____SWIG_0(int argc, VALUE *argv, VALUE self) {
+ ptrdiff_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ ptrdiff_t val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::ConstIterator const *","operator -", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "ptrdiff_t","operator -", 2, argv[0] ));
+ try {
+ result = (swig::ConstIterator *)((swig::ConstIterator const *)arg1)->operator -(arg2);
+ (void)_e;
+ SWIG_fail;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_ConstIterator___sub____SWIG_1(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 ;
+ int res2 = 0 ;
+ ptrdiff_t result;
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "swig::ConstIterator const &","operator -", 2, argv[0] ));
+ if (!argp2) {
+ SWIG_exception_fail(SWIG_ValueError, Ruby_Format_TypeError("invalid null reference ", "swig::ConstIterator const &","operator -", 2, argv[0]));
+ result = ((swig::ConstIterator const *)arg1)->operator -((swig::ConstIterator const &)*arg2);
+ vresult = SWIG_From_ptrdiff_t(static_cast< ptrdiff_t >(result));
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE _wrap_ConstIterator___sub__(int nargs, VALUE *args, VALUE self) {
+ int argc;
+ VALUE argv[3];
+ int ii;
+ argc = nargs + 1;
+ argv[0] = self;
+ if (argc == 2) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ void *vptr = 0;
+ int res = SWIG_ConvertPtr(argv[1], &vptr, SWIGTYPE_p_swig__ConstIterator, 0);
+ if (_v) {
+ return _wrap_ConstIterator___sub____SWIG_1(nargs, args, self);
+ if (argc == 2) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ int res = SWIG_AsVal_ptrdiff_t(argv[1], NULL);
+ if (_v) {
+ return _wrap_ConstIterator___sub____SWIG_0(nargs, args, self);
+fail:
+ Ruby_Format_OverloadedError( argc, 3, "__sub__.new",
+ " __sub__.new(ptrdiff_t n)\n"
+ " __sub__.new(swig::ConstIterator const &x)\n");
+ return Qnil;
+swig_class SwigClassIterator;
+SWIGINTERN VALUE
+_wrap_Iterator_valuee___(int argc, VALUE *argv, VALUE self) {
+ swig::Iterator *arg1 = (swig::Iterator *) 0 ;
+ VALUE *arg2 = 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ VALUE temp2 ;
+ VALUE result;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_swig__Iterator, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::Iterator *","setValue", 1, self ));
+ arg1 = reinterpret_cast< swig::Iterator * >(argp1);
+ temp2 = static_cast< VALUE >(argv[0]);
+ arg2 = &temp2;
+ result = (VALUE)(arg1)->setValue((VALUE const &)*arg2);
+ vresult = result;
+ return vresult;
+fail:
+ return Qnil;
+ Document-method: Geos::Iterator.dup
+ call-seq:
+ dup -> Iterator
+SWIGINTERN VALUE
+_wrap_Iterator_dup(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ swig::Iterator *result = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::Iterator const *","dup", 1, self ));
+ result = (swig::Iterator *)((swig::Iterator const *)arg1)->dup();
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__Iterator, SWIG_POINTER_OWN | 0 );
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Iterator_next__SWIG_0(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::Iterator *","next", 1, self ));
+ result = (swig::Iterator *)(arg1)->next(arg2);
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_swig__Iterator, 0 | 0 );
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Iterator_next__SWIG_1(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ try {
+ result = (swig::Iterator *)(arg1)->next();
+ (void)_e;
+ SWIG_fail;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE _wrap_Iterator_next(int nargs, VALUE *args, VALUE self) {
+ int argc;
+ VALUE argv[3];
+ int ii;
+ argc = nargs + 1;
+ argv[0] = self;
+ if (argc == 1) {
+ int _v;
+ void *vptr = 0;
+ int res = SWIG_ConvertPtr(argv[0], &vptr, SWIGTYPE_p_swig__Iterator, 0);
+ if (_v) {
+ return _wrap_Iterator_next__SWIG_1(nargs, args, self);
+ if (argc == 2) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ if (_v) {
+ return _wrap_Iterator_next__SWIG_0(nargs, args, self);
+fail:
+ Ruby_Format_OverloadedError( argc, 3, "Iterator.next",
+ " swig::Iterator * Iterator.next(size_t n)\n"
+ " swig::Iterator * Iterator.next()\n");
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Iterator_previous__SWIG_0(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::Iterator *","previous", 1, self ));
+ result = (swig::Iterator *)(arg1)->previous(arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Iterator_previous__SWIG_1(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ try {
+ result = (swig::Iterator *)(arg1)->previous();
+ (void)_e;
+ SWIG_fail;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE _wrap_Iterator_previous(int nargs, VALUE *args, VALUE self) {
+ int argc;
+ VALUE argv[3];
+ int ii;
+ argc = nargs + 1;
+ argv[0] = self;
+ if (argc == 1) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ return _wrap_Iterator_previous__SWIG_1(nargs, args, self);
+ if (argc == 2) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ if (_v) {
+ return _wrap_Iterator_previous__SWIG_0(nargs, args, self);
+fail:
+ Ruby_Format_OverloadedError( argc, 3, "Iterator.previous",
+ " swig::Iterator * Iterator.previous(size_t n)\n"
+ " swig::Iterator * Iterator.previous()\n");
+ return Qnil;
+ Document-method: Geos::Iterator.inspect
+ call-seq:
+ inspect -> VALUE
+SWIGINTERN VALUE
+_wrap_Iterator_inspect(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ VALUE result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::Iterator const *","inspect", 1, self ));
+ result = (VALUE)((swig::Iterator const *)arg1)->inspect();
+ vresult = result;
+ return vresult;
+fail:
+ return Qnil;
+ Document-method: Geos::Iterator.to_s
+ call-seq:
+ to_s -> VALUE
+SWIGINTERN VALUE
+_wrap_Iterator_to_s(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ VALUE result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::Iterator const *","to_s", 1, self ));
+ result = (VALUE)((swig::Iterator const *)arg1)->to_s();
+ vresult = result;
+ return vresult;
+fail:
+ return Qnil;
+ Document-method: Geos::Iterator.==
+ call-seq:
+ ==(x) -> bool
+SWIGINTERN VALUE
+_wrap_Iterator___eq__(int argc, VALUE *argv, VALUE self) {
+ swig::Iterator *arg2 = 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 ;
+ int res2 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::Iterator const *","operator ==", 1, self ));
+ res2 = SWIG_ConvertPtr(argv[0], &argp2, SWIGTYPE_p_swig__Iterator, 0 );
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "swig::Iterator const &","operator ==", 2, argv[0] ));
+ if (!argp2) {
+ SWIG_exception_fail(SWIG_ValueError, Ruby_Format_TypeError("invalid null reference ", "swig::Iterator const &","operator ==", 2, argv[0]));
+ arg2 = reinterpret_cast< swig::Iterator * >(argp2);
+ result = (bool)((swig::Iterator const *)arg1)->operator ==((swig::Iterator const &)*arg2);
+ return vresult;
+fail:
+ return Qnil;
+ Document-method: Geos::Iterator.+
+ call-seq:
+ +(n) -> Iterator
+Add operator.
+SWIGINTERN VALUE
+_wrap_Iterator___add__(int argc, VALUE *argv, VALUE self) {
+ ptrdiff_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ ptrdiff_t val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::Iterator const *","operator +", 1, self ));
+ try {
+ result = (swig::Iterator *)((swig::Iterator const *)arg1)->operator +(arg2);
+ (void)_e;
+ SWIG_fail;
+ return vresult;
+fail:
+ return Qnil;
+ Document-method: Geos::Iterator.-
+ call-seq:
+ -(n) -> Iterator
+ -(x) -> ptrdiff_t
+SWIGINTERN VALUE
+_wrap_Iterator___sub____SWIG_0(int argc, VALUE *argv, VALUE self) {
+ ptrdiff_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ ptrdiff_t val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "swig::Iterator const *","operator -", 1, self ));
+ try {
+ result = (swig::Iterator *)((swig::Iterator const *)arg1)->operator -(arg2);
+ (void)_e;
+ SWIG_fail;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Iterator___sub____SWIG_1(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 ;
+ int res2 = 0 ;
+ ptrdiff_t result;
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "swig::Iterator const &","operator -", 2, argv[0] ));
+ if (!argp2) {
+ SWIG_exception_fail(SWIG_ValueError, Ruby_Format_TypeError("invalid null reference ", "swig::Iterator const &","operator -", 2, argv[0]));
+ result = ((swig::Iterator const *)arg1)->operator -((swig::Iterator const &)*arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE _wrap_Iterator___sub__(int nargs, VALUE *args, VALUE self) {
+ int argc;
+ VALUE argv[3];
+ int ii;
+ argc = nargs + 1;
+ argv[0] = self;
+ if (argc == 2) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ void *vptr = 0;
+ int res = SWIG_ConvertPtr(argv[1], &vptr, SWIGTYPE_p_swig__Iterator, 0);
+ if (_v) {
+ return _wrap_Iterator___sub____SWIG_1(nargs, args, self);
+ if (argc == 2) {
+ int _v;
+ void *vptr = 0;
+ if (_v) {
+ if (_v) {
+ return _wrap_Iterator___sub____SWIG_0(nargs, args, self);
+fail:
+ " __sub__.new(swig::Iterator const &x)\n");
+ return Qnil;
+SWIGINTERN void
+free_swig_Iterator(swig::Iterator *arg1) {
+ delete arg1;
+SWIGINTERN VALUE
+_wrap_version(int argc, VALUE *argv, VALUE self) {
+ char *result = 0 ;
+ result = (char *)GEOSversion();
+ vresult = SWIG_FromCharPtr((const char *)result);
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassCoordinateSequence;
+#ifdef HAVE_RB_DEFINE_ALLOC_FUNC
+SWIGINTERN VALUE
+_wrap_CoordinateSequence_allocate(VALUE self) {
+#else
+ SWIGINTERN VALUE
+ _wrap_CoordinateSequence_allocate(int argc, VALUE *argv, VALUE self) {
+#endif
+ VALUE vresult = SWIG_NewClassInstance(self, SWIGTYPE_p_GeosCoordinateSequence);
+#ifndef HAVE_RB_DEFINE_ALLOC_FUNC
+ rb_obj_call_init(vresult, argc, argv);
+#endif
+ return vresult;
+SWIGINTERN VALUE
+_wrap_new_CoordinateSequence(int argc, VALUE *argv, VALUE self) {
+ size_t arg1 ;
+ size_t arg2 ;
+ size_t val1 ;
+ int ecode1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ GeosCoordinateSequence *result = 0 ;
+ if ((argc < 2) || (argc > 2)) {
+ rb_raise(rb_eArgError, "wrong # of arguments(%d for 2)",argc); SWIG_fail;
+ ecode1 = SWIG_AsVal_size_t(argv[0], &val1);
+ if (!SWIG_IsOK(ecode1)) {
+ SWIG_exception_fail(SWIG_ArgError(ecode1), Ruby_Format_TypeError( "", "size_t","GeosCoordinateSequence", 1, argv[0] ));
+ arg1 = static_cast< size_t >(val1);
+ ecode2 = SWIG_AsVal_size_t(argv[1], &val2);
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","GeosCoordinateSequence", 2, argv[1] ));
+ try
+ result = (GeosCoordinateSequence *)new_GeosCoordinateSequence(arg1,arg2);
+ DATA_PTR(self) = result;
+ catch (const std::exception& e)
+ SWIG_exception(SWIG_RuntimeError, e.what());
+ return self;
+fail:
+ return Qnil;
+SWIGINTERN void delete_GeosCoordinateSequence(GeosCoordinateSequence *self){
+ return GEOSCoordSeq_destroy(coords);
+SWIGINTERN void
+free_GeosCoordinateSequence(GeosCoordinateSequence *arg1) {
+ delete_GeosCoordinateSequence(arg1);
+ Document-method: Geos::CoordinateSequence.clone
+ call-seq:
+ clone -> CoordinateSequence
+Create a duplicate of the class.
+SWIGINTERN VALUE
+_wrap_CoordinateSequence_clone(int argc, VALUE *argv, VALUE self) {
+ GeosCoordinateSequence *arg1 = (GeosCoordinateSequence *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosCoordinateSequence, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","clone", 1, self ));
+ arg1 = reinterpret_cast< GeosCoordinateSequence * >(argp1);
+ try
+ result = (GeosCoordinateSequence *)GeosCoordinateSequence_clone(arg1);
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosCoordinateSequence, SWIG_POINTER_OWN | 0 );
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_CoordinateSequence_set_x(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ double arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ double val3 ;
+ int ecode3 = 0 ;
+ int result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","setX", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","setX", 2, argv[0] ));
+ ecode3 = SWIG_AsVal_double(argv[1], &val3);
+ if (!SWIG_IsOK(ecode3)) {
+ SWIG_exception_fail(SWIG_ArgError(ecode3), Ruby_Format_TypeError( "", "double","setX", 3, argv[1] ));
+ arg3 = static_cast< double >(val3);
+ try
+ result = (int)GeosCoordinateSequence_setX(arg1,arg2,arg3);
+ vresult = SWIG_From_int(static_cast< int >(result));
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_CoordinateSequence_set_y(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ double arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ double val3 ;
+ int ecode3 = 0 ;
+ int result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","setY", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","setY", 2, argv[0] ));
+ SWIG_exception_fail(SWIG_ArgError(ecode3), Ruby_Format_TypeError( "", "double","setY", 3, argv[1] ));
+ try
+ result = (int)GeosCoordinateSequence_setY(arg1,arg2,arg3);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_CoordinateSequence_set_z(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ double arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ double val3 ;
+ int ecode3 = 0 ;
+ int result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","setZ", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","setZ", 2, argv[0] ));
+ SWIG_exception_fail(SWIG_ArgError(ecode3), Ruby_Format_TypeError( "", "double","setZ", 3, argv[1] ));
+ try
+ result = (int)GeosCoordinateSequence_setZ(arg1,arg2,arg3);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_CoordinateSequence_set_ordinate(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ size_t arg3 ;
+ double arg4 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ size_t val3 ;
+ int ecode3 = 0 ;
+ double val4 ;
+ int ecode4 = 0 ;
+ int result;
+ if ((argc < 3) || (argc > 3)) {
+ rb_raise(rb_eArgError, "wrong # of arguments(%d for 3)",argc); SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","setOrdinate", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","setOrdinate", 2, argv[0] ));
+ ecode3 = SWIG_AsVal_size_t(argv[1], &val3);
+ SWIG_exception_fail(SWIG_ArgError(ecode3), Ruby_Format_TypeError( "", "size_t","setOrdinate", 3, argv[1] ));
+ arg3 = static_cast< size_t >(val3);
+ ecode4 = SWIG_AsVal_double(argv[2], &val4);
+ if (!SWIG_IsOK(ecode4)) {
+ SWIG_exception_fail(SWIG_ArgError(ecode4), Ruby_Format_TypeError( "", "double","setOrdinate", 4, argv[2] ));
+ arg4 = static_cast< double >(val4);
+ try
+ result = (int)GeosCoordinateSequence_setOrdinate(arg1,arg2,arg3,arg4);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_CoordinateSequence_get_x(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ double result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","getX", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","getX", 2, argv[0] ));
+ try
+ result = (double)GeosCoordinateSequence_getX(arg1,arg2);
+ vresult = SWIG_From_double(static_cast< double >(result));
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_CoordinateSequence_get_y(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ double result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","getY", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","getY", 2, argv[0] ));
+ try
+ result = (double)GeosCoordinateSequence_getY(arg1,arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_CoordinateSequence_get_z(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ double result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","getZ", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","getZ", 2, argv[0] ));
+ try
+ result = (double)GeosCoordinateSequence_getZ(arg1,arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_CoordinateSequence_get_ordinate(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ size_t arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ size_t val3 ;
+ int ecode3 = 0 ;
+ double result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","getOrdinate", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","getOrdinate", 2, argv[0] ));
+ SWIG_exception_fail(SWIG_ArgError(ecode3), Ruby_Format_TypeError( "", "size_t","getOrdinate", 3, argv[1] ));
+ try
+ result = (double)GeosCoordinateSequence_getOrdinate(arg1,arg2,arg3);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_CoordinateSequence___len__(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","getSize", 1, self ));
+ try
+ result = (unsigned int)GeosCoordinateSequence_getSize(arg1);
+ vresult = SWIG_From_unsigned_SS_int(static_cast< unsigned int >(result));
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_CoordinateSequence_dimensions(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","getDimensions", 1, self ));
+ try
+ result = (unsigned int)GeosCoordinateSequence_getDimensions(arg1);
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassGeometry;
+SWIGINTERN void delete_GeosGeometry(GeosGeometry *self){
+ GEOSGeom_destroy(geom);
+SWIGINTERN void
+free_GeosGeometry(GeosGeometry *arg1) {
+ delete_GeosGeometry(arg1);
+ Document-method: Geos::Geometry.clone
+ call-seq:
+ clone -> Geometry
+SWIGINTERN VALUE
+_wrap_Geometry_clone(int argc, VALUE *argv, VALUE self) {
+ GeosGeometry *arg1 = (GeosGeometry *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ GeosGeometry *result = 0 ;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosGeometry, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","clone", 1, self ));
+ arg1 = reinterpret_cast< GeosGeometry * >(argp1);
+ try
+ result = (GeosGeometry *)GeosGeometry_clone(arg1);
+ /* %typemap(out) GeosGeometry */
+ SWIG_exception(SWIG_RuntimeError, message);
+ GeosGeometry *geom = result;
+ GEOSGeomTypes geomId = (GEOSGeomTypes)GEOSGeomTypeId((GEOSGeom) geom);
+ switch (geomId)
+ case GEOS_POINT:
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPoint, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_LINESTRING:
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLineString, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_LINEARRING:
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLinearRing, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_POLYGON:
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPolygon, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_MULTIPOINT:
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPoint, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_MULTILINESTRING:
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiLineString, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_MULTIPOLYGON:
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPolygon, 0 | SWIG_POINTER_OWN);
+ break;
+ case GEOS_GEOMETRYCOLLECTION:
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosGeometryCollection, 0 | SWIG_POINTER_OWN);
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_geom_type(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","geomType", 1, self ));
+ try
+ result = (char *)GeosGeometry_geomType(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_type_id(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","typeId", 1, self ));
+ try
+ result = (int)GeosGeometry_typeId(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_normalize(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","normalize", 1, self ));
+ try
+ GeosGeometry_normalize(arg1);
+ return Qnil;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_srid(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","getSRID", 1, self ));
+ try
+ result = (int)GeosGeometry_getSRID(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_sride___(int argc, VALUE *argv, VALUE self) {
+ int arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","setSRID", 1, self ));
+ ecode2 = SWIG_AsVal_int(argv[0], &val2);
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "int","setSRID", 2, argv[0] ));
+ arg2 = static_cast< int >(val2);
+ try
+ GeosGeometry_setSRID(arg1,arg2);
+ return Qnil;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_dimensions(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","getDimensions", 1, self ));
+ try
+ result = GeosGeometry_getDimensions(arg1);
+ vresult = SWIG_From_size_t(static_cast< size_t >(result));
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_num_geometries(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","getNumGeometries", 1, self ));
+ try
+ result = GeosGeometry_getNumGeometries(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_intersection(int argc, VALUE *argv, VALUE self) {
+ GeosGeometry *arg2 = (GeosGeometry *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","intersection", 1, self ));
+ res2 = SWIG_ConvertPtr(argv[0], &argp2,SWIGTYPE_p_GeosGeometry, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry *","intersection", 2, argv[0] ));
+ arg2 = reinterpret_cast< GeosGeometry * >(argp2);
+ try
+ result = (GeosGeometry *)GeosGeometry_intersection(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_buffer(int argc, VALUE *argv, VALUE self) {
+ double arg2 ;
+ int arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ double val2 ;
+ int ecode2 = 0 ;
+ int val3 ;
+ int ecode3 = 0 ;
+ arg3 = DEFAULT_QUADRANT_SEGMENTS;
+ if ((argc < 1) || (argc > 2)) {
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","buffer", 1, self ));
+ ecode2 = SWIG_AsVal_double(argv[0], &val2);
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "double","buffer", 2, argv[0] ));
+ arg2 = static_cast< double >(val2);
+ if (argc > 1) {
+ ecode3 = SWIG_AsVal_int(argv[1], &val3);
+ SWIG_exception_fail(SWIG_ArgError(ecode3), Ruby_Format_TypeError( "", "int","buffer", 3, argv[1] ));
+ arg3 = static_cast< int >(val3);
+ try
+ result = (GeosGeometry *)GeosGeometry_buffer(arg1,arg2,arg3);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_convex_hull(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","convexHull", 1, self ));
+ try
+ result = (GeosGeometry *)GeosGeometry_convexHull(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_difference(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","difference", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry *","difference", 2, argv[0] ));
+ try
+ result = (GeosGeometry *)GeosGeometry_difference(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_sym_difference(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","symDifference", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry *","symDifference", 2, argv[0] ));
+ try
+ result = (GeosGeometry *)GeosGeometry_symDifference(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_boundary(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","boundary", 1, self ));
+ try
+ result = (GeosGeometry *)GeosGeometry_boundary(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_union(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","geomUnion", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry *","geomUnion", 2, argv[0] ));
+ try
+ result = (GeosGeometry *)GeosGeometry_geomUnion(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_point_on_surface(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","pointOnSurface", 1, self ));
+ try
+ result = (GeosGeometry *)GeosGeometry_pointOnSurface(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_centroid(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","getCentroid", 1, self ));
+ try
+ result = (GeosGeometry *)GeosGeometry_getCentroid(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_envelope(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","getEnvelope", 1, self ));
+ try
+ result = (GeosGeometry *)GeosGeometry_getEnvelope(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPoint, 0 | 0);
+ break;
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLineString, 0 | 0);
+ break;
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosLinearRing, 0 | 0);
+ break;
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosPolygon, 0 | 0);
+ break;
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPoint, 0 | 0);
+ break;
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiLineString, 0 | 0);
+ break;
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosMultiPolygon, 0 | 0);
+ break;
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosGeometryCollection, 0 | 0);
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_relate(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","relate", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry *","relate", 2, argv[0] ));
+ try
+ result = (char *)GeosGeometry_relate(arg1,arg2);
+ delete[] result;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_line_merge(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","lineMerge", 1, self ));
+ try
+ result = (GeosGeometry *)GeosGeometry_lineMerge(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_simplify(int argc, VALUE *argv, VALUE self) {
+ double arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ double val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","simplify", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "double","simplify", 2, argv[0] ));
+ try
+ result = (GeosGeometry *)GeosGeometry_simplify(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_topology_preserve_simplify(int argc, VALUE *argv, VALUE self) {
+ double arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ double val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","topologyPreserveSimplify", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "double","topologyPreserveSimplify", 2, argv[0] ));
+ try
+ result = (GeosGeometry *)GeosGeometry_topologyPreserveSimplify(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_relate_pattern(int argc, VALUE *argv, VALUE self) {
+ char *arg3 = (char *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ int res3 ;
+ char *buf3 = 0 ;
+ int alloc3 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","relatePattern", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","relatePattern", 2, argv[0] ));
+ res3 = SWIG_AsCharPtrAndSize(argv[1], &buf3, NULL, &alloc3);
+ if (!SWIG_IsOK(res3)) {
+ SWIG_exception_fail(SWIG_ArgError(res3), Ruby_Format_TypeError( "", "char const *","relatePattern", 3, argv[1] ));
+ arg3 = reinterpret_cast< char * >(buf3);
+ try
+ result = (bool)GeosGeometry_relatePattern(arg1,(GeosGeometry const *)arg2,(char const *)arg3);
+ if (alloc3 == SWIG_NEWOBJ) delete[] buf3;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_disjointq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","disjoint", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","disjoint", 2, argv[0] ));
+ try
+ result = (bool)GeosGeometry_disjoint(arg1,(GeosGeometry const *)arg2);
+ vresult = (result ? Qtrue : Qfalse);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_touchesq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","touches", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","touches", 2, argv[0] ));
+ try
+ result = (bool)GeosGeometry_touches(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_intersectsq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","intersects", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","intersects", 2, argv[0] ));
+ try
+ result = (bool)GeosGeometry_intersects(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_crossesq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","crosses", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","crosses", 2, argv[0] ));
+ try
+ result = (bool)GeosGeometry_crosses(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_withinq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","within", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","within", 2, argv[0] ));
+ try
+ result = (bool)GeosGeometry_within(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_containsq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","contains", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","contains", 2, argv[0] ));
+ try
+ result = (bool)GeosGeometry_contains(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_overlapsq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","overlaps", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","overlaps", 2, argv[0] ));
+ try
+ result = (bool)GeosGeometry_overlaps(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_eqlq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","equals", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","equals", 2, argv[0] ));
+ try
+ result = (bool)GeosGeometry_equals(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_eql_exactq___(int argc, VALUE *argv, VALUE self) {
+ double arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ double val3 ;
+ int ecode3 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","equalsExact", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","equalsExact", 2, argv[0] ));
+ SWIG_exception_fail(SWIG_ArgError(ecode3), Ruby_Format_TypeError( "", "double","equalsExact", 3, argv[1] ));
+ try
+ result = (bool)GeosGeometry_equalsExact(arg1,(GeosGeometry const *)arg2,arg3);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_emptyq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","isEmpty", 1, self ));
+ try
+ result = (bool)GeosGeometry_isEmpty(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_validq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","isValid", 1, self ));
+ try
+ result = (bool)GeosGeometry_isValid(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_simpleq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","isSimple", 1, self ));
+ try
+ result = (bool)GeosGeometry_isSimple(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_ringq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","isRing", 1, self ));
+ try
+ result = (bool)GeosGeometry_isRing(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_has_zq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","hasZ", 1, self ));
+ try
+ result = (bool)GeosGeometry_hasZ(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_area(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ double result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","area", 1, self ));
+ try
+ result = (double)GeosGeometry_area(arg1);
+ return vresult;
+fail:
+ return Qnil;
+ Document-method: Geos::Geometry.length
+ call-seq:
+ length -> double
+Size or Length of the Geometry.
+SWIGINTERN VALUE
+_wrap_Geometry_length(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ double result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","length", 1, self ));
+ try
+ result = (double)GeosGeometry_length(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Geometry_distance(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ double result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry *","distance", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","distance", 2, argv[0] ));
+ try
+ result = (double)GeosGeometry_distance(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassPoint;
+SWIGINTERN void delete_GeosPoint(GeosPoint *self){
+ GEOSGeom geom = (GEOSGeom) self;
+SWIGINTERN void
+free_GeosPoint(GeosPoint *arg1) {
+ delete_GeosPoint(arg1);
+SWIGINTERN VALUE
+_wrap_Point_coord_seq(int argc, VALUE *argv, VALUE self) {
+ GeosPoint *arg1 = (GeosPoint *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosPoint, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosPoint *","getCoordSeq", 1, self ));
+ arg1 = reinterpret_cast< GeosPoint * >(argp1);
+ try
+ result = (GeosCoordinateSequence *)GeosPoint_getCoordSeq(arg1);
+ vresult = SWIG_NewPointerObj(SWIG_as_voidptr(result), SWIGTYPE_p_GeosCoordinateSequence, 0 | 0 );
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassLineString;
+SWIGINTERN void delete_GeosLineString(GeosLineString *self){
+SWIGINTERN void
+free_GeosLineString(GeosLineString *arg1) {
+ delete_GeosLineString(arg1);
+SWIGINTERN VALUE
+_wrap_LineString_coord_seq(int argc, VALUE *argv, VALUE self) {
+ GeosLineString *arg1 = (GeosLineString *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosLineString, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosLineString *","getCoordSeq", 1, self ));
+ arg1 = reinterpret_cast< GeosLineString * >(argp1);
+ try
+ result = (GeosCoordinateSequence *)GeosLineString_getCoordSeq(arg1);
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassLinearRing;
+SWIGINTERN void delete_GeosLinearRing(GeosLinearRing *self){
+SWIGINTERN void
+free_GeosLinearRing(GeosLinearRing *arg1) {
+ delete_GeosLinearRing(arg1);
+SWIGINTERN VALUE
+_wrap_LinearRing_coord_seq(int argc, VALUE *argv, VALUE self) {
+ GeosLinearRing *arg1 = (GeosLinearRing *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosLinearRing, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosLinearRing *","getCoordSeq", 1, self ));
+ arg1 = reinterpret_cast< GeosLinearRing * >(argp1);
+ try
+ result = (GeosCoordinateSequence *)GeosLinearRing_getCoordSeq(arg1);
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassPolygon;
+SWIGINTERN void delete_GeosPolygon(GeosPolygon *self){
+SWIGINTERN void
+free_GeosPolygon(GeosPolygon *arg1) {
+ delete_GeosPolygon(arg1);
+SWIGINTERN VALUE
+_wrap_Polygon_exterior_ring(int argc, VALUE *argv, VALUE self) {
+ GeosPolygon *arg1 = (GeosPolygon *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosPolygon, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosPolygon *","getExteriorRing", 1, self ));
+ arg1 = reinterpret_cast< GeosPolygon * >(argp1);
+ try
+ result = (GeosGeometry *)GeosPolygon_getExteriorRing(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Polygon_num_interior_rings(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosPolygon *","getNumInteriorRings", 1, self ));
+ try
+ result = GeosPolygon_getNumInteriorRings(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Polygon_interior_ring_n(int argc, VALUE *argv, VALUE self) {
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosPolygon *","getInteriorRingN", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","getInteriorRingN", 2, argv[0] ));
+ try
+ result = (GeosGeometry *)GeosPolygon_getInteriorRingN(arg1,arg2);
+ if (result == NULL)
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassGeometryCollection;
+SWIGINTERN void delete_GeosGeometryCollection(GeosGeometryCollection *self){
+SWIGINTERN void
+free_GeosGeometryCollection(GeosGeometryCollection *arg1) {
+ delete_GeosGeometryCollection(arg1);
+SWIGINTERN VALUE
+_wrap_GeometryCollection_get_geometry_n(int argc, VALUE *argv, VALUE self) {
+ GeosGeometryCollection *arg1 = (GeosGeometryCollection *) 0 ;
+ size_t arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ size_t val2 ;
+ int ecode2 = 0 ;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosGeometryCollection, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometryCollection *","getGeometryN", 1, self ));
+ arg1 = reinterpret_cast< GeosGeometryCollection * >(argp1);
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "size_t","getGeometryN", 2, argv[0] ));
+ try
+ result = (GeosGeometry *)GeosGeometryCollection_getGeometryN(arg1,arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassMultiPoint;
+SWIGINTERN void delete_GeosMultiPoint(GeosMultiPoint *self){
+SWIGINTERN void
+free_GeosMultiPoint(GeosMultiPoint *arg1) {
+ delete_GeosMultiPoint(arg1);
+swig_class SwigClassMultiLineString;
+SWIGINTERN void delete_GeosMultiLineString(GeosMultiLineString *self){
+SWIGINTERN void
+free_GeosMultiLineString(GeosMultiLineString *arg1) {
+ delete_GeosMultiLineString(arg1);
+swig_class SwigClassMultiLinearRing;
+SWIGINTERN void delete_GeosMultiLinearRing(GeosMultiLinearRing *self){
+SWIGINTERN void
+free_GeosMultiLinearRing(GeosMultiLinearRing *arg1) {
+ delete_GeosMultiLinearRing(arg1);
+swig_class SwigClassMultiPolygon;
+SWIGINTERN void delete_GeosMultiPolygon(GeosMultiPolygon *self){
+SWIGINTERN void
+free_GeosMultiPolygon(GeosMultiPolygon *arg1) {
+ delete_GeosMultiPolygon(arg1);
+SWIGINTERN VALUE
+_wrap_create_point(int argc, VALUE *argv, VALUE self) {
+ int res1 = 0 ;
+ res1 = SWIG_ConvertPtr(argv[0], SWIG_as_voidptrptr(&arg1), SWIGTYPE_p_GeosCoordinateSequence, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","createPoint", 1, argv[0] ));
+ try
+ result = (GeosGeometry *)createPoint(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_create_line_string(int argc, VALUE *argv, VALUE self) {
+ int res1 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","createLineString", 1, argv[0] ));
+ try
+ result = (GeosGeometry *)createLineString(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_create_linear_ring(int argc, VALUE *argv, VALUE self) {
+ int res1 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosCoordinateSequence *","createLinearRing", 1, argv[0] ));
+ try
+ result = (GeosGeometry *)createLinearRing(arg1);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_create_polygon(int argc, VALUE *argv, VALUE self) {
+ GeosLinearRing **arg2 = (GeosLinearRing **) 0 ;
+ size_t arg3 ;
+ int res1 = 0 ;
+ arg2 = NULL;
+ arg3 = 0;
+ res1 = SWIG_ConvertPtr(argv[0], SWIG_as_voidptrptr(&arg1), SWIGTYPE_p_GeosLinearRing, SWIG_POINTER_DISOWN | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosLinearRing *","createPolygon", 1, argv[0] ));
+ if (argc > 1) {
+ if (NIL_P(argv[1]))
+ arg2 = NULL;
+ arg3 = 0;
+ else
+ /* Make sure the input can be treated as an array. */
+ Check_Type(argv[1], T_ARRAY);
+ /* Get the length */
+ arg3 = RARRAY_LEN(argv[1]);
+ /* Allocate space for the C array. */
+ arg2 = (GeosLinearRing**) malloc(arg3*sizeof(GeosLinearRing*));
+ for(size_t i = 0; i<arg3; i++)
+ /* Get the Ruby Object */
+ VALUE item = rb_ary_entry(argv[1],i);
+ /* Get the underlying pointer and give up ownership of it. */
+ GeosLinearRing *ring = NULL;
+ int convertResult = SWIG_ConvertPtr(item, (void**)&ring, SWIGTYPE_p_GeosLinearRing, SWIG_POINTER_DISOWN);
+ if (!SWIG_IsOK(convertResult)) {
+ SWIG_exception_fail(SWIG_ArgError(convertResult), "in method '" "createPolygon" "', argument " "1"" of type '" "GeosLinearRing *""'");
+ /* Put the pointer in the array */
+ arg2[i] = ring;
+ try
+ result = (GeosGeometry *)createPolygon(arg1,arg2,arg3);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ if (arg2) {
+ free((void*) arg2);
+ return vresult;
+fail:
+ if (arg2) {
+ return Qnil;
+swig_class SwigClassPrepared;
+SWIGINTERN VALUE
+_wrap_Prepared_allocate(VALUE self) {
+#else
+ SWIGINTERN VALUE
+ _wrap_Prepared_allocate(int argc, VALUE *argv, VALUE self) {
+#endif
+ VALUE vresult = SWIG_NewClassInstance(self, SWIGTYPE_p_GeosPreparedGeometry);
+#endif
+ return vresult;
+SWIGINTERN VALUE
+_wrap_new_Prepared(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ GeosPreparedGeometry *result = 0 ;
+ res1 = SWIG_ConvertPtr(argv[0], &argp1,SWIGTYPE_p_GeosGeometry, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosGeometry const *","GeosPreparedGeometry", 1, argv[0] ));
+ try
+ result = (GeosPreparedGeometry *)new_GeosPreparedGeometry((GeosGeometry const *)arg1);
+ return self;
+fail:
+ return Qnil;
+SWIGINTERN void delete_GeosPreparedGeometry(GeosPreparedGeometry *self){
+ GEOSPreparedGeometry *prep = (GEOSPreparedGeometry *) self;
+ return GEOSPreparedGeom_destroy(prep);
+SWIGINTERN void
+free_GeosPreparedGeometry(GeosPreparedGeometry *arg1) {
+ delete_GeosPreparedGeometry(arg1);
+SWIGINTERN VALUE
+_wrap_Prepared_containsq___(int argc, VALUE *argv, VALUE self) {
+ GeosPreparedGeometry *arg1 = (GeosPreparedGeometry *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ VALUE vresult = Qnil;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosPreparedGeometry, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosPreparedGeometry *","contains", 1, self ));
+ arg1 = reinterpret_cast< GeosPreparedGeometry * >(argp1);
+ try
+ result = (bool)GeosPreparedGeometry_contains(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Prepared_contains_properlyq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ if (!SWIG_IsOK(res1)) {
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosPreparedGeometry *","containsProperly", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","containsProperly", 2, argv[0] ));
+ try
+ result = (bool)GeosPreparedGeometry_containsProperly(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Prepared_coversq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosPreparedGeometry *","covers", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","covers", 2, argv[0] ));
+ try
+ result = (bool)GeosPreparedGeometry_covers(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_Prepared_intersectsq___(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosPreparedGeometry *","intersects", 1, self ));
+ try
+ result = (bool)GeosPreparedGeometry_intersects(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassSTRtree;
+SWIGINTERN VALUE
+_wrap_STRtree_allocate(VALUE self) {
+#else
+ SWIGINTERN VALUE
+ _wrap_STRtree_allocate(int argc, VALUE *argv, VALUE self) {
+#endif
+ VALUE vresult = SWIG_NewClassInstance(self, SWIGTYPE_p_GeosSTRtree);
+#endif
+ return vresult;
+SWIGINTERN VALUE
+_wrap_new_STRtree(int argc, VALUE *argv, VALUE self) {
+ int arg1 ;
+ int val1 ;
+ int ecode1 = 0 ;
+ GeosSTRtree *result = 0 ;
+ arg1 = 10;
+ if ((argc < 0) || (argc > 1)) {
+ rb_raise(rb_eArgError, "wrong # of arguments(%d for 0)",argc); SWIG_fail;
+ if (argc > 0) {
+ ecode1 = SWIG_AsVal_int(argv[0], &val1);
+ SWIG_exception_fail(SWIG_ArgError(ecode1), Ruby_Format_TypeError( "", "int","GeosSTRtree", 1, argv[0] ));
+ arg1 = static_cast< int >(val1);
+ try
+ result = (GeosSTRtree *)new_GeosSTRtree(arg1);
+ return self;
+fail:
+ return Qnil;
+SWIGINTERN void delete_GeosSTRtree(GeosSTRtree *self){
+ GEOSSTRtree *tree = (GEOSSTRtree *) self;
+ return GEOSSTRtree_destroy(tree);
+SWIGINTERN void
+free_GeosSTRtree(GeosSTRtree *arg1) {
+ delete_GeosSTRtree(arg1);
+ Document-method: Geos::STRtree.insert
+ call-seq:
+ insert(g, item)
+Insert one or more new elements in the STRtree.
+SWIGINTERN VALUE
+_wrap_STRtree_insert(int argc, VALUE *argv, VALUE self) {
+ GeosSTRtree *arg1 = (GeosSTRtree *) 0 ;
+ GeosIndexItem arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosSTRtree, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosSTRtree *","insert", 1, self ));
+ arg1 = reinterpret_cast< GeosSTRtree * >(argp1);
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","insert", 2, argv[0] ));
+ arg3 = (GeosIndexItem) argv[1];
+ try
+ GeosSTRtree_insert(arg1,(GeosGeometry const *)arg2,arg3);
+ return Qnil;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_STRtree_remove(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosSTRtree *","remove", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","remove", 2, argv[0] ));
+ try
+ GeosSTRtree_remove(arg1,(GeosGeometry const *)arg2,arg3);
+ return Qnil;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_STRtree_query(int argc, VALUE *argv, VALUE self) {
+ GeosQueryCallback arg3 ;
+ GeosIndexItem arg4 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ arg3 = GeosSTRtree_query_callback;
+ arg4 = (GeosIndexItem) Qnil;
+ if ((argc < 1) || (argc > 1)) {
+ rb_raise(rb_eArgError, "wrong # of arguments(%d for 1)",argc); SWIG_fail;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosSTRtree *","query", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","query", 2, argv[0] ));
+ try
+ GeosSTRtree_query(arg1,(GeosGeometry const *)arg2,arg3,arg4);
+ return Qnil;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_STRtree_each(int argc, VALUE *argv, VALUE self) {
+ GeosQueryCallback arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ arg2 = GeosSTRtree_query_callback;
+ arg3 = (GeosIndexItem) Qnil;
+ if ((argc < 0) || (argc > 0)) {
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosSTRtree *","iterate", 1, self ));
+ try
+ GeosSTRtree_iterate(arg1,arg2,arg3);
+ return Qnil;
+fail:
+ return Qnil;
+swig_class SwigClassWktReader;
+SWIGINTERN VALUE
+_wrap_WktReader_allocate(VALUE self) {
+#else
+ SWIGINTERN VALUE
+ _wrap_WktReader_allocate(int argc, VALUE *argv, VALUE self) {
+#endif
+ VALUE vresult = SWIG_NewClassInstance(self, SWIGTYPE_p_GeosWktReader);
+#endif
+ return vresult;
+SWIGINTERN VALUE
+_wrap_new_WktReader(int argc, VALUE *argv, VALUE self) {
+ GeosWktReader *result = 0 ;
+ try
+ result = (GeosWktReader *)new_GeosWktReader();
+ return self;
+fail:
+ return Qnil;
+SWIGINTERN void delete_GeosWktReader(GeosWktReader *self){
+ GEOSWKTReader *reader = (GEOSWKTReader*) self;
+ GEOSWKTReader_destroy(reader);
+SWIGINTERN void
+free_GeosWktReader(GeosWktReader *arg1) {
+ delete_GeosWktReader(arg1);
+SWIGINTERN VALUE
+_wrap_WktReader_read(int argc, VALUE *argv, VALUE self) {
+ GeosWktReader *arg1 = (GeosWktReader *) 0 ;
+ char *arg2 = (char *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int res2 ;
+ char *buf2 = 0 ;
+ int alloc2 = 0 ;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosWktReader, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosWktReader *","read", 1, self ));
+ arg1 = reinterpret_cast< GeosWktReader * >(argp1);
+ res2 = SWIG_AsCharPtrAndSize(argv[0], &buf2, NULL, &alloc2);
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "char const *","read", 2, argv[0] ));
+ arg2 = reinterpret_cast< char * >(buf2);
+ try
+ result = (GeosGeometry *)GeosWktReader_read(arg1,(char const *)arg2);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ if (alloc2 == SWIG_NEWOBJ) delete[] buf2;
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassWktWriter;
+SWIGINTERN VALUE
+_wrap_WktWriter_allocate(VALUE self) {
+#else
+ SWIGINTERN VALUE
+ _wrap_WktWriter_allocate(int argc, VALUE *argv, VALUE self) {
+#endif
+ VALUE vresult = SWIG_NewClassInstance(self, SWIGTYPE_p_GeosWktWriter);
+#endif
+ return vresult;
+SWIGINTERN VALUE
+_wrap_new_WktWriter(int argc, VALUE *argv, VALUE self) {
+ GeosWktWriter *result = 0 ;
+ try
+ result = (GeosWktWriter *)new_GeosWktWriter();
+ return self;
+fail:
+ return Qnil;
+SWIGINTERN void delete_GeosWktWriter(GeosWktWriter *self){
+ GEOSWKTWriter *writer = (GEOSWKTWriter*) self;
+ GEOSWKTWriter_destroy(writer);
+SWIGINTERN void
+free_GeosWktWriter(GeosWktWriter *arg1) {
+ delete_GeosWktWriter(arg1);
+SWIGINTERN VALUE
+_wrap_WktWriter_write(int argc, VALUE *argv, VALUE self) {
+ GeosWktWriter *arg1 = (GeosWktWriter *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosWktWriter, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosWktWriter *","write", 1, self ));
+ arg1 = reinterpret_cast< GeosWktWriter * >(argp1);
+ if (!SWIG_IsOK(res2)) {
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","write", 2, argv[0] ));
+ try
+ result = (char *)GeosWktWriter_write(arg1,(GeosGeometry const *)arg2);
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassWkbReader;
+SWIGINTERN VALUE
+_wrap_WkbReader_allocate(VALUE self) {
+#else
+ SWIGINTERN VALUE
+ _wrap_WkbReader_allocate(int argc, VALUE *argv, VALUE self) {
+#endif
+ VALUE vresult = SWIG_NewClassInstance(self, SWIGTYPE_p_GeosWkbReader);
+#endif
+ return vresult;
+SWIGINTERN VALUE
+_wrap_new_WkbReader(int argc, VALUE *argv, VALUE self) {
+ GeosWkbReader *result = 0 ;
+ try
+ result = (GeosWkbReader *)new_GeosWkbReader();
+ return self;
+fail:
+ return Qnil;
+SWIGINTERN void delete_GeosWkbReader(GeosWkbReader *self){
+ GEOSWKBReader *reader = (GEOSWKBReader*) self;
+ GEOSWKBReader_destroy(reader);
+SWIGINTERN void
+free_GeosWkbReader(GeosWkbReader *arg1) {
+ delete_GeosWkbReader(arg1);
+SWIGINTERN VALUE
+_wrap_WkbReader_read(int argc, VALUE *argv, VALUE self) {
+ GeosWkbReader *arg1 = (GeosWkbReader *) 0 ;
+ unsigned char *arg2 = (unsigned char *) 0 ;
+ size_t arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int alloc2 = 0 ;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosWkbReader, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosWkbReader *","read", 1, self ));
+ arg1 = reinterpret_cast< GeosWkbReader * >(argp1);
+ /* %typemap(in) (const unsigned char* wkb, size_t size) (int alloc2 = 0) */
+ if (SWIG_AsCharPtrAndSize(argv[0], (char**)&arg2, &arg3, &alloc2) != SWIG_OK)
+ SWIG_exception(SWIG_RuntimeError, "Expecting a string");
+ /* Don't want to include last null character! */
+ arg3--;
+ try
+ result = (GeosGeometry *)GeosWkbReader_read(arg1,(unsigned char const *)arg2,arg3);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_WkbReader_read_hex(int argc, VALUE *argv, VALUE self) {
+ size_t arg3 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int alloc2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosWkbReader *","readHEX", 1, self ));
+ arg3--;
+ try
+ result = (GeosGeometry *)GeosWkbReader_readHEX(arg1,(unsigned char const *)arg2,arg3);
+ switch (geomId)
+ case GEOS_POINT:
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ break;
+ return vresult;
+fail:
+ return Qnil;
+swig_class SwigClassWkbWriter;
+SWIGINTERN VALUE
+_wrap_WkbWriter_allocate(VALUE self) {
+#else
+ SWIGINTERN VALUE
+ _wrap_WkbWriter_allocate(int argc, VALUE *argv, VALUE self) {
+#endif
+ VALUE vresult = SWIG_NewClassInstance(self, SWIGTYPE_p_GeosWkbWriter);
+#endif
+ return vresult;
+SWIGINTERN VALUE
+_wrap_new_WkbWriter(int argc, VALUE *argv, VALUE self) {
+ GeosWkbWriter *result = 0 ;
+ try
+ result = (GeosWkbWriter *)new_GeosWkbWriter();
+ return self;
+fail:
+ return Qnil;
+SWIGINTERN void delete_GeosWkbWriter(GeosWkbWriter *self){
+ GEOSWKBWriter *writer = (GEOSWKBWriter*) self;
+ GEOSWKBWriter_destroy(writer);
+SWIGINTERN void
+free_GeosWkbWriter(GeosWkbWriter *arg1) {
+ delete_GeosWkbWriter(arg1);
+SWIGINTERN VALUE
+_wrap_WkbWriter_output_dimensions(int argc, VALUE *argv, VALUE self) {
+ GeosWkbWriter *arg1 = (GeosWkbWriter *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int result;
+ res1 = SWIG_ConvertPtr(self, &argp1,SWIGTYPE_p_GeosWkbWriter, 0 | 0 );
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosWkbWriter *","getOutputDimension", 1, self ));
+ arg1 = reinterpret_cast< GeosWkbWriter * >(argp1);
+ try
+ result = (int)GeosWkbWriter_getOutputDimension(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_WkbWriter_output_dimensionse___(int argc, VALUE *argv, VALUE self) {
+ int arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosWkbWriter *","setOutputDimension", 1, self ));
+ if (!SWIG_IsOK(ecode2)) {
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "int","setOutputDimension", 2, argv[0] ));
+ try
+ GeosWkbWriter_setOutputDimension(arg1,arg2);
+ return Qnil;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_WkbWriter_byte_order(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosWkbWriter *","getByteOrder", 1, self ));
+ try
+ result = (int)GeosWkbWriter_getByteOrder(arg1);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_WkbWriter_byte_ordere___(int argc, VALUE *argv, VALUE self) {
+ int arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ int val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosWkbWriter *","setByteOrder", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "int","setByteOrder", 2, argv[0] ));
+ try
+ GeosWkbWriter_setByteOrder(arg1,arg2);
+ return Qnil;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_WkbWriter_include_srid(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool result;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosWkbWriter *","getIncludeSRID", 1, self ));
+ try
+ result = (bool)GeosWkbWriter_getIncludeSRID(arg1);
+ vresult = SWIG_From_bool(static_cast< bool >(result));
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_WkbWriter_include_sride___(int argc, VALUE *argv, VALUE self) {
+ bool arg2 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ bool val2 ;
+ int ecode2 = 0 ;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosWkbWriter *","setIncludeSRID", 1, self ));
+ ecode2 = SWIG_AsVal_bool(argv[0], &val2);
+ SWIG_exception_fail(SWIG_ArgError(ecode2), Ruby_Format_TypeError( "", "bool","setIncludeSRID", 2, argv[0] ));
+ arg2 = static_cast< bool >(val2);
+ try
+ GeosWkbWriter_setIncludeSRID(arg1,arg2);
+ return Qnil;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_WkbWriter_write(int argc, VALUE *argv, VALUE self) {
+ size_t *arg3 = (size_t *) 0 ;
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ size_t temp3 = 0 ;
+ unsigned char *result = 0 ;
+ /* %typemap(in, numinputs=0) size_t *size (size_t temp3 = 0) */
+ arg3 = &temp3;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosWkbWriter *","write", 1, self ));
+ try
+ result = (unsigned char *)GeosWkbWriter_write(arg1,(GeosGeometry const *)arg2,arg3);
+ /* %typemap(out) unsigned char* */
+ /* %typemap(argout) size_t *size */
+ vresult = SWIG_FromCharPtrAndSize((const char*)result, *arg3);
+ /* %typemap(freearg) size_t *size */
+ std::free(result);
+ return vresult;
+fail:
+ return Qnil;
+SWIGINTERN VALUE
+_wrap_WkbWriter_write_hex(int argc, VALUE *argv, VALUE self) {
+ void *argp1 = 0 ;
+ int res1 = 0 ;
+ void *argp2 = 0 ;
+ int res2 = 0 ;
+ arg3 = &temp3;
+ SWIG_exception_fail(SWIG_ArgError(res1), Ruby_Format_TypeError( "", "GeosWkbWriter *","writeHEX", 1, self ));
+ SWIG_exception_fail(SWIG_ArgError(res2), Ruby_Format_TypeError( "", "GeosGeometry const *","writeHEX", 2, argv[0] ));
+ try
+ result = (unsigned char *)GeosWkbWriter_writeHEX(arg1,(GeosGeometry const *)arg2,arg3);
+ return vresult;
+fail:
+ return Qnil;
+/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (BEGIN) -------- */
+static void *_p_GeosMultiPolygonTo_p_GeosGeometryCollection(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometryCollection *) ((GeosMultiPolygon *) x));
+static void *_p_GeosMultiPointTo_p_GeosGeometryCollection(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometryCollection *) ((GeosMultiPoint *) x));
+static void *_p_GeosMultiLineStringTo_p_GeosGeometryCollection(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometryCollection *) ((GeosMultiLineString *) x));
+static void *_p_GeosMultiLinearRingTo_p_GeosGeometryCollection(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometryCollection *) ((GeosMultiLinearRing *) x));
+static void *_p_GeosPolygonTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) ((GeosPolygon *) x));
+static void *_p_GeosMultiPolygonTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiPolygon *) x));
+static void *_p_GeosPointTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) ((GeosPoint *) x));
+static void *_p_GeosLineStringTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) ((GeosLineString *) x));
+static void *_p_GeosLinearRingTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) ((GeosLinearRing *) x));
+static void *_p_GeosMultiPointTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiPoint *) x));
+static void *_p_GeosMultiLineStringTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiLineString *) x));
+static void *_p_GeosMultiLinearRingTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) (GeosGeometryCollection *) ((GeosMultiLinearRing *) x));
+static void *_p_GeosGeometryCollectionTo_p_GeosGeometry(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((GeosGeometry *) ((GeosGeometryCollection *) x));
+static void *_p_swig__IteratorTo_p_swig__ConstIterator(void *x, int *SWIGUNUSEDPARM(newmemory)) {
+ return (void *)((swig::ConstIterator *) ((swig::Iterator *) x));
+static swig_type_info _swigt__p_GeosCoordinateSequence = {"_p_GeosCoordinateSequence", "GeosCoordinateSequence *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosGeometry = {"_p_GeosGeometry", "GeosGeometry *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosGeometryCollection = {"_p_GeosGeometryCollection", "GeosGeometryCollection *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosLineString = {"_p_GeosLineString", "GeosLineString *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosLinearRing = {"_p_GeosLinearRing", "GeosLinearRing *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosMultiLineString = {"_p_GeosMultiLineString", "GeosMultiLineString *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosMultiLinearRing = {"_p_GeosMultiLinearRing", "GeosMultiLinearRing *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosMultiPoint = {"_p_GeosMultiPoint", "GeosMultiPoint *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosMultiPolygon = {"_p_GeosMultiPolygon", "GeosMultiPolygon *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosPoint = {"_p_GeosPoint", "GeosPoint *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosPolygon = {"_p_GeosPolygon", "GeosPolygon *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosPreparedGeometry = {"_p_GeosPreparedGeometry", "GeosPreparedGeometry *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosSTRtree = {"_p_GeosSTRtree", "GeosSTRtree *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosWkbReader = {"_p_GeosWkbReader", "GeosWkbReader *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosWkbWriter = {"_p_GeosWkbWriter", "GeosWkbWriter *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosWktReader = {"_p_GeosWktReader", "GeosWktReader *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_GeosWktWriter = {"_p_GeosWktWriter", "GeosWktWriter *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_char = {"_p_char", "char *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_p_GeosLinearRing = {"_p_p_GeosLinearRing", "GeosLinearRing **", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_p_void = {"_p_p_void", "void **|VALUE *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_size_t = {"_p_size_t", "size_t *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_swig__ConstIterator = {"_p_swig__ConstIterator", "swig::ConstIterator *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_swig__GC_VALUE = {"_p_swig__GC_VALUE", "swig::GC_VALUE *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_swig__Iterator = {"_p_swig__Iterator", "swig::Iterator *", 0, 0, (void*)0, 0};
+static swig_type_info _swigt__p_unsigned_char = {"_p_unsigned_char", "unsigned char *", 0, 0, (void*)0, 0};
+static swig_type_info *swig_type_initial[] = {
+ &_swigt__p_GeosCoordinateSequence,
+ &_swigt__p_GeosGeometry,
+ &_swigt__p_GeosGeometryCollection,
+ &_swigt__p_GeosLineString,
+ &_swigt__p_GeosLinearRing,
+ &_swigt__p_GeosMultiLineString,
+ &_swigt__p_GeosMultiLinearRing,
+ &_swigt__p_GeosMultiPoint,
+ &_swigt__p_GeosMultiPolygon,
+ &_swigt__p_GeosPoint,
+ &_swigt__p_GeosPolygon,
+ &_swigt__p_GeosPreparedGeometry,
+ &_swigt__p_GeosSTRtree,
+ &_swigt__p_GeosWkbReader,
+ &_swigt__p_GeosWkbWriter,
+ &_swigt__p_GeosWktReader,
+ &_swigt__p_GeosWktWriter,
+ &_swigt__p_char,
+ &_swigt__p_p_GeosLinearRing,
+ &_swigt__p_p_void,
+ &_swigt__p_size_t,
+ &_swigt__p_swig__ConstIterator,
+ &_swigt__p_swig__GC_VALUE,
+ &_swigt__p_swig__Iterator,
+ &_swigt__p_unsigned_char,
+static swig_cast_info _swigc__p_GeosCoordinateSequence[] = { {&_swigt__p_GeosCoordinateSequence, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosGeometry[] = { {&_swigt__p_GeosPolygon, _p_GeosPolygonTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiPolygon, _p_GeosMultiPolygonTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosPoint, _p_GeosPointTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosGeometry, 0, 0, 0}, {&_swigt__p_GeosLineString, _p_GeosLineStringTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosLinearRing, _p_GeosLinearRingTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiPoint, _p_GeosMultiPointTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiLineString, _p_GeosMultiLineStringTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosMultiLinearRing, _p_GeosMultiLinearRingTo_p_GeosGeometry, 0, 0}, {&_swigt__p_GeosGeometryCollection, _p_GeosGeometryCollectionTo_p_GeosGeometry, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosGeometryCollection[] = { {&_swigt__p_GeosMultiPolygon, _p_GeosMultiPolygonTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosMultiPoint, _p_GeosMultiPointTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosMultiLineString, _p_GeosMultiLineStringTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosMultiLinearRing, _p_GeosMultiLinearRingTo_p_GeosGeometryCollection, 0, 0}, {&_swigt__p_GeosGeometryCollection, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosLineString[] = { {&_swigt__p_GeosLineString, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosLinearRing[] = { {&_swigt__p_GeosLinearRing, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosMultiLineString[] = { {&_swigt__p_GeosMultiLineString, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosMultiLinearRing[] = { {&_swigt__p_GeosMultiLinearRing, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosMultiPoint[] = { {&_swigt__p_GeosMultiPoint, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosMultiPolygon[] = { {&_swigt__p_GeosMultiPolygon, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosPoint[] = { {&_swigt__p_GeosPoint, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosPolygon[] = { {&_swigt__p_GeosPolygon, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosPreparedGeometry[] = { {&_swigt__p_GeosPreparedGeometry, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosSTRtree[] = { {&_swigt__p_GeosSTRtree, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosWkbReader[] = { {&_swigt__p_GeosWkbReader, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosWkbWriter[] = { {&_swigt__p_GeosWkbWriter, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosWktReader[] = { {&_swigt__p_GeosWktReader, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_GeosWktWriter[] = { {&_swigt__p_GeosWktWriter, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_char[] = { {&_swigt__p_char, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_p_GeosLinearRing[] = { {&_swigt__p_p_GeosLinearRing, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_p_void[] = { {&_swigt__p_p_void, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_size_t[] = { {&_swigt__p_size_t, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_swig__ConstIterator[] = { {&_swigt__p_swig__ConstIterator, 0, 0, 0}, {&_swigt__p_swig__Iterator, _p_swig__IteratorTo_p_swig__ConstIterator, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_swig__GC_VALUE[] = { {&_swigt__p_swig__GC_VALUE, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_swig__Iterator[] = { {&_swigt__p_swig__Iterator, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info _swigc__p_unsigned_char[] = { {&_swigt__p_unsigned_char, 0, 0, 0},{0, 0, 0, 0}};
+static swig_cast_info *swig_cast_initial[] = {
+ _swigc__p_GeosCoordinateSequence,
+ _swigc__p_GeosGeometry,
+ _swigc__p_GeosGeometryCollection,
+ _swigc__p_GeosLineString,
+ _swigc__p_GeosLinearRing,
+ _swigc__p_GeosMultiLineString,
+ _swigc__p_GeosMultiLinearRing,
+ _swigc__p_GeosMultiPoint,
+ _swigc__p_GeosMultiPolygon,
+ _swigc__p_GeosPoint,
+ _swigc__p_GeosPolygon,
+ _swigc__p_GeosPreparedGeometry,
+ _swigc__p_GeosSTRtree,
+ _swigc__p_GeosWkbReader,
+ _swigc__p_GeosWkbWriter,
+ _swigc__p_GeosWktReader,
+ _swigc__p_GeosWktWriter,
+ _swigc__p_char,
+ _swigc__p_p_GeosLinearRing,
+ _swigc__p_p_void,
+ _swigc__p_size_t,
+ _swigc__p_swig__ConstIterator,
+ _swigc__p_swig__GC_VALUE,
+ _swigc__p_swig__Iterator,
+ _swigc__p_unsigned_char,
+/* -------- TYPE CONVERSION AND EQUIVALENCE RULES (END) -------- */
+ * Type initialization:
+ * This problem is tough by the requirement that no dynamic
+ * memory is used. Also, since swig_type_info structures store pointers to
+ * swig_cast_info structures and swig_cast_info structures store pointers back
+ * to swig_type_info structures, we need some lookup code at initialization.
+ * The idea is that swig generates all the structures that are needed.
+ * The runtime then collects these partially filled structures.
+ * The SWIG_InitializeModule function takes these initial arrays out of
+ * swig_module, and does all the lookup, filling in the swig_module.types
+ * array with the correct data and linking the correct swig_cast_info
+ * structures together.
+ * The generated swig_type_info structures are assigned staticly to an initial
+ * array. We just loop through that array, and handle each type individually.
+ * First we lookup if this type has been already loaded, and if so, use the
+ * loaded structure instead of the generated one. Then we have to fill in the
+ * cast linked list. The cast data is initially stored in something like a
+ * two-dimensional array. Each row corresponds to a type (there are the same
+ * number of rows as there are in the swig_type_initial array). Each entry in
+ * a column is one of the swig_cast_info structures for that type.
+ * The cast_initial array is actually an array of arrays, because each row has
+ * a variable number of columns. So to actually build the cast linked list,
+ * we find the array of casts associated with the type, and loop through it
+ * adding the casts to the list. The one last trick we need to do is making
+ * sure the type pointer in the swig_cast_info struct is correct.
+ * First off, we lookup the cast->type name to see if it is already loaded.
+ * There are three cases to handle:
+ * 1) If the cast->type has already been loaded AND the type we are adding
+ * casting info to has not been loaded (it is in this module), THEN we
+ * replace the cast->type pointer with the type pointer that has already
+ * been loaded.
+ * 2) If BOTH types (the one we are adding casting info to, and the
+ * cast->type) are loaded, THEN the cast info has already been loaded by
+ * the previous module so we just ignore it.
+ * 3) Finally, if cast->type has not already been loaded, then we add that
+ * swig_cast_info to the linked list (because the cast->type) pointer will
+ * be correct.
+#ifdef __cplusplus
+extern "C" {
+#if 0
+} /* c-mode */
+#endif
+#endif
+#if 0
+#define SWIGRUNTIME_DEBUG
+#endif
+SWIGRUNTIME void
+SWIG_InitializeModule(void *clientdata) {
+ size_t i;
+ swig_module_info *module_head, *iter;
+ int found, init;
+ clientdata = clientdata;
+ /* check to see if the circular list has been setup, if not, set it up */
+ if (swig_module.next==0) {
+ /* Initialize the swig_module */
+ swig_module.type_initial = swig_type_initial;
+ swig_module.cast_initial = swig_cast_initial;
+ swig_module.next = &swig_module;
+ init = 1;
+ } else {
+ init = 0;
+ /* Try and load any already created modules */
+ module_head = SWIG_GetModule(clientdata);
+ if (!module_head) {
+ /* This is the first module loaded for this interpreter */
+ /* so set the swig module into the interpreter */
+ SWIG_SetModule(clientdata, &swig_module);
+ module_head = &swig_module;
+ } else {
+ /* the interpreter has loaded a SWIG module, but has it loaded this one? */
+ found=0;
+ iter=module_head;
+ do {
+ if (iter==&swig_module) {
+ found=1;
+ break;
+ iter=iter->next;
+ } while (iter!= module_head);
+ /* if the is found in the list, then all is done and we may leave */
+ if (found) return;
+ /* otherwise we must add out module into the list */
+ swig_module.next = module_head->next;
+ module_head->next = &swig_module;
+ /* When multiple interpeters are used, a module could have already been initialized in
+ a different interpreter, but not yet have a pointer in this interpreter.
+ In this case, we do not want to continue adding types... everything should be
+ set up already */
+ if (init == 0) return;
+ /* Now work on filling in swig_module.types */
+#ifdef SWIGRUNTIME_DEBUG
+ printf("SWIG_InitializeModule: size %d\n", swig_module.size);
+#endif
+ for (i = 0; i < swig_module.size; ++i) {
+ swig_type_info *type = 0;
+ swig_type_info *ret;
+ swig_cast_info *cast;
+ printf("SWIG_InitializeModule: type %d %s\n", i, swig_module.type_initial[i]->name);
+#endif
+ /* if there is another module already loaded */
+ if (swig_module.next != &swig_module) {
+ type = SWIG_MangledTypeQueryModule(swig_module.next, &swig_module, swig_module.type_initial[i]->name);
+ if (type) {
+ /* Overwrite clientdata field */
+ printf("SWIG_InitializeModule: found type %s\n", type->name);
+#endif
+ if (swig_module.type_initial[i]->clientdata) {
+ type->clientdata = swig_module.type_initial[i]->clientdata;
+ printf("SWIG_InitializeModule: found and overwrite type %s \n", type->name);
+#endif
+ } else {
+ type = swig_module.type_initial[i];
+ /* Insert casting types */
+ cast = swig_module.cast_initial[i];
+ while (cast->type) {
+ /* Don't need to add information already in the list */
+ ret = 0;
+ printf("SWIG_InitializeModule: look cast %s\n", cast->type->name);
+#endif
+ ret = SWIG_MangledTypeQueryModule(swig_module.next, &swig_module, cast->type->name);
+ if (ret) printf("SWIG_InitializeModule: found cast %s\n", ret->name);
+#endif
+ if (ret) {
+ if (type == swig_module.type_initial[i]) {
+ printf("SWIG_InitializeModule: skip old type %s\n", ret->name);
+#endif
+ cast->type = ret;
+ ret = 0;
+ } else {
+ /* Check for casting already in the list */
+ swig_cast_info *ocast = SWIG_TypeCheck(ret->name, type);
+ if (ocast) printf("SWIG_InitializeModule: skip old cast %s\n", ret->name);
+#endif
+ if (!ocast) ret = 0;
+ if (!ret) {
+ printf("SWIG_InitializeModule: adding cast %s\n", cast->type->name);
+#endif
+ if (type->cast) {
+ type->cast->prev = cast;
+ cast->next = type->cast;
+ type->cast = cast;
+ cast++;
+ /* Set entry in modules->types array equal to the type */
+ swig_module.types[i] = type;
+ swig_module.types[i] = 0;
+ printf("**** SWIG_InitializeModule: Cast List ******\n");
+ int j = 0;
+ swig_cast_info *cast = swig_module.cast_initial[i];
+ printf("SWIG_InitializeModule: cast type %s\n", cast->type->name);
+ cast++;
+ ++j;
+ printf("---- Total casts: %d\n",j);
+#endif
+/* This function will propagate the clientdata field of type to
+* any new swig_type_info structures that have been added into the list
+* of equivalent types. It is like calling
+* SWIG_TypeClientData(type, clientdata) a second time.
+SWIGRUNTIME void
+SWIG_PropagateClientData(void) {
+ size_t i;
+ swig_cast_info *equiv;
+ static int init_run = 0;
+ if (init_run) return;
+ init_run = 1;
+ for (i = 0; i < swig_module.size; i++) {
+ if (swig_module.types[i]->clientdata) {
+ equiv = swig_module.types[i]->cast;
+ while (equiv) {
+ if (!equiv->converter) {
+ if (equiv->type && !equiv->type->clientdata)
+ SWIG_TypeClientData(equiv->type, swig_module.types[i]->clientdata);
+ equiv = equiv->next;
+#ifdef __cplusplus
+#if 0
+{ /* c-mode */
+#endif
+#endif
+#ifdef __cplusplus
+extern "C"
+#endif
+SWIGEXPORT void Init_geos(void) {
+ size_t i;
+ SWIG_InitRuntime();
+ mGeos = rb_define_module("Geos");
+ SWIG_InitializeModule(0);
+ SWIG_define_class(swig_module.types[i]);
+ SWIG_RubyInitializeTrackings();
+ SwigClassGCVALUE.klass = rb_define_class_under(mGeos, "GCVALUE", rb_cObject);
+ SWIG_TypeClientData(SWIGTYPE_p_swig__GC_VALUE, (void *) &SwigClassGCVALUE);
+ rb_undef_alloc_func(SwigClassGCVALUE.klass);
+ rb_define_method(SwigClassGCVALUE.klass, "inspect", VALUEFUNC(_wrap_GCVALUE_inspect), -1);
+ rb_define_method(SwigClassGCVALUE.klass, "to_s", VALUEFUNC(_wrap_GCVALUE_to_s), -1);
+ SwigClassGCVALUE.mark = 0;
+ SwigClassGCVALUE.trackObjects = 0;
+ swig::GC_VALUE::initialize();
+ SwigClassConstIterator.klass = rb_define_class_under(mGeos, "ConstIterator", rb_cObject);
+ SWIG_TypeClientData(SWIGTYPE_p_swig__ConstIterator, (void *) &SwigClassConstIterator);
+ rb_undef_alloc_func(SwigClassConstIterator.klass);
+ rb_define_method(SwigClassConstIterator.klass, "value", VALUEFUNC(_wrap_ConstIterator_value), -1);
+ rb_define_method(SwigClassConstIterator.klass, "dup", VALUEFUNC(_wrap_ConstIterator_dup), -1);
+ rb_define_method(SwigClassConstIterator.klass, "inspect", VALUEFUNC(_wrap_ConstIterator_inspect), -1);
+ rb_define_method(SwigClassConstIterator.klass, "to_s", VALUEFUNC(_wrap_ConstIterator_to_s), -1);
+ rb_define_method(SwigClassConstIterator.klass, "next", VALUEFUNC(_wrap_ConstIterator_next), -1);
+ rb_define_method(SwigClassConstIterator.klass, "previous", VALUEFUNC(_wrap_ConstIterator_previous), -1);
+ rb_define_method(SwigClassConstIterator.klass, "==", VALUEFUNC(_wrap_ConstIterator___eq__), -1);
+ rb_define_method(SwigClassConstIterator.klass, "+", VALUEFUNC(_wrap_ConstIterator___add__), -1);
+ rb_define_method(SwigClassConstIterator.klass, "-", VALUEFUNC(_wrap_ConstIterator___sub__), -1);
+ SwigClassConstIterator.mark = 0;
+ SwigClassConstIterator.destroy = (void (*)(void *)) free_swig_ConstIterator;
+ SwigClassConstIterator.trackObjects = 0;
+ SwigClassIterator.klass = rb_define_class_under(mGeos, "Iterator", ((swig_class *) SWIGTYPE_p_swig__ConstIterator->clientdata)->klass);
+ SWIG_TypeClientData(SWIGTYPE_p_swig__Iterator, (void *) &SwigClassIterator);
+ rb_undef_alloc_func(SwigClassIterator.klass);
+ rb_define_method(SwigClassIterator.klass, "value=", VALUEFUNC(_wrap_Iterator_valuee___), -1);
+ rb_define_method(SwigClassIterator.klass, "dup", VALUEFUNC(_wrap_Iterator_dup), -1);
+ rb_define_method(SwigClassIterator.klass, "next", VALUEFUNC(_wrap_Iterator_next), -1);
+ rb_define_method(SwigClassIterator.klass, "previous", VALUEFUNC(_wrap_Iterator_previous), -1);
+ rb_define_method(SwigClassIterator.klass, "inspect", VALUEFUNC(_wrap_Iterator_inspect), -1);
+ rb_define_method(SwigClassIterator.klass, "to_s", VALUEFUNC(_wrap_Iterator_to_s), -1);
+ rb_define_method(SwigClassIterator.klass, "==", VALUEFUNC(_wrap_Iterator___eq__), -1);
+ rb_define_method(SwigClassIterator.klass, "+", VALUEFUNC(_wrap_Iterator___add__), -1);
+ rb_define_method(SwigClassIterator.klass, "-", VALUEFUNC(_wrap_Iterator___sub__), -1);
+ SwigClassIterator.mark = 0;
+ SwigClassIterator.destroy = (void (*)(void *)) free_swig_Iterator;
+ SwigClassIterator.trackObjects = 0;
+ rb_define_const(mGeos, "GEOS_VERSION_MAJOR", SWIG_From_int(static_cast< int >(3)));
+ rb_define_const(mGeos, "GEOS_VERSION_MINOR", SWIG_From_int(static_cast< int >(4)));
+ rb_define_const(mGeos, "GEOS_VERSION", SWIG_FromCharPtr("3.4.0dev"));
+ rb_define_const(mGeos, "GEOS_JTS_PORT", SWIG_FromCharPtr("1.12.0"));
+ rb_define_const(mGeos, "GEOS_CAPI_VERSION_MAJOR", SWIG_From_int(static_cast< int >(1)));
+ rb_define_const(mGeos, "GEOS_CAPI_VERSION_MINOR", SWIG_From_int(static_cast< int >(8)));
+ rb_define_const(mGeos, "GEOS_CAPI_VERSION_PATCH", SWIG_From_int(static_cast< int >(0)));
+ rb_define_const(mGeos, "GEOS_CAPI_FIRST_INTERFACE", SWIG_From_int(static_cast< int >(1)));
+ rb_define_const(mGeos, "GEOS_CAPI_LAST_INTERFACE", SWIG_From_int(static_cast< int >((1+8))));
+ rb_define_const(mGeos, "GEOS_CAPI_VERSION", SWIG_FromCharPtr("3.4.0dev-CAPI-1.8.0"));
+ rb_define_const(mGeos, "GEOS_POINT", SWIG_From_int(static_cast< int >(GEOS_POINT)));
+ rb_define_const(mGeos, "GEOS_LINESTRING", SWIG_From_int(static_cast< int >(GEOS_LINESTRING)));
+ rb_define_const(mGeos, "GEOS_LINEARRING", SWIG_From_int(static_cast< int >(GEOS_LINEARRING)));
+ rb_define_const(mGeos, "GEOS_POLYGON", SWIG_From_int(static_cast< int >(GEOS_POLYGON)));
+ rb_define_const(mGeos, "GEOS_MULTIPOINT", SWIG_From_int(static_cast< int >(GEOS_MULTIPOINT)));
+ rb_define_const(mGeos, "GEOS_MULTILINESTRING", SWIG_From_int(static_cast< int >(GEOS_MULTILINESTRING)));
+ rb_define_const(mGeos, "GEOS_MULTIPOLYGON", SWIG_From_int(static_cast< int >(GEOS_MULTIPOLYGON)));
+ rb_define_const(mGeos, "GEOS_GEOMETRYCOLLECTION", SWIG_From_int(static_cast< int >(GEOS_GEOMETRYCOLLECTION)));
+ rb_define_const(mGeos, "GEOS_WKB_XDR", SWIG_From_int(static_cast< int >(GEOS_WKB_XDR)));
+ rb_define_const(mGeos, "GEOS_WKB_NDR", SWIG_From_int(static_cast< int >(GEOS_WKB_NDR)));
+ initGEOS(noticeHandler, errorHandler);
+ rb_define_module_function(mGeos, "version", VALUEFUNC(_wrap_version), -1);
+ SwigClassCoordinateSequence.klass = rb_define_class_under(mGeos, "CoordinateSequence", rb_cObject);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosCoordinateSequence, (void *) &SwigClassCoordinateSequence);
+ rb_define_alloc_func(SwigClassCoordinateSequence.klass, _wrap_CoordinateSequence_allocate);
+ rb_define_method(SwigClassCoordinateSequence.klass, "initialize", VALUEFUNC(_wrap_new_CoordinateSequence), -1);
+ rb_define_method(SwigClassCoordinateSequence.klass, "clone", VALUEFUNC(_wrap_CoordinateSequence_clone), -1);
+ rb_define_method(SwigClassCoordinateSequence.klass, "set_x", VALUEFUNC(_wrap_CoordinateSequence_set_x), -1);
+ rb_define_method(SwigClassCoordinateSequence.klass, "set_y", VALUEFUNC(_wrap_CoordinateSequence_set_y), -1);
+ rb_define_method(SwigClassCoordinateSequence.klass, "set_z", VALUEFUNC(_wrap_CoordinateSequence_set_z), -1);
+ rb_define_method(SwigClassCoordinateSequence.klass, "set_ordinate", VALUEFUNC(_wrap_CoordinateSequence_set_ordinate), -1);
+ rb_define_method(SwigClassCoordinateSequence.klass, "get_x", VALUEFUNC(_wrap_CoordinateSequence_get_x), -1);
+ rb_define_method(SwigClassCoordinateSequence.klass, "get_y", VALUEFUNC(_wrap_CoordinateSequence_get_y), -1);
+ rb_define_method(SwigClassCoordinateSequence.klass, "get_z", VALUEFUNC(_wrap_CoordinateSequence_get_z), -1);
+ rb_define_method(SwigClassCoordinateSequence.klass, "get_ordinate", VALUEFUNC(_wrap_CoordinateSequence_get_ordinate), -1);
+ rb_define_method(SwigClassCoordinateSequence.klass, "length", VALUEFUNC(_wrap_CoordinateSequence___len__), -1);
+ rb_define_method(SwigClassCoordinateSequence.klass, "dimensions", VALUEFUNC(_wrap_CoordinateSequence_dimensions), -1);
+ SwigClassCoordinateSequence.mark = 0;
+ SwigClassCoordinateSequence.destroy = (void (*)(void *)) free_GeosCoordinateSequence;
+ SwigClassCoordinateSequence.trackObjects = 0;
+ SwigClassGeometry.klass = rb_define_class_under(mGeos, "Geometry", rb_cObject);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosGeometry, (void *) &SwigClassGeometry);
+ rb_undef_alloc_func(SwigClassGeometry.klass);
+ rb_define_method(SwigClassGeometry.klass, "clone", VALUEFUNC(_wrap_Geometry_clone), -1);
+ rb_define_method(SwigClassGeometry.klass, "geom_type", VALUEFUNC(_wrap_Geometry_geom_type), -1);
+ rb_define_method(SwigClassGeometry.klass, "type_id", VALUEFUNC(_wrap_Geometry_type_id), -1);
+ rb_define_method(SwigClassGeometry.klass, "normalize", VALUEFUNC(_wrap_Geometry_normalize), -1);
+ rb_define_method(SwigClassGeometry.klass, "srid", VALUEFUNC(_wrap_Geometry_srid), -1);
+ rb_define_method(SwigClassGeometry.klass, "srid=", VALUEFUNC(_wrap_Geometry_sride___), -1);
+ rb_define_method(SwigClassGeometry.klass, "dimensions", VALUEFUNC(_wrap_Geometry_dimensions), -1);
+ rb_define_method(SwigClassGeometry.klass, "num_geometries", VALUEFUNC(_wrap_Geometry_num_geometries), -1);
+ rb_define_method(SwigClassGeometry.klass, "intersection", VALUEFUNC(_wrap_Geometry_intersection), -1);
+ rb_define_method(SwigClassGeometry.klass, "buffer", VALUEFUNC(_wrap_Geometry_buffer), -1);
+ rb_define_method(SwigClassGeometry.klass, "convex_hull", VALUEFUNC(_wrap_Geometry_convex_hull), -1);
+ rb_define_method(SwigClassGeometry.klass, "difference", VALUEFUNC(_wrap_Geometry_difference), -1);
+ rb_define_method(SwigClassGeometry.klass, "sym_difference", VALUEFUNC(_wrap_Geometry_sym_difference), -1);
+ rb_define_method(SwigClassGeometry.klass, "boundary", VALUEFUNC(_wrap_Geometry_boundary), -1);
+ rb_define_method(SwigClassGeometry.klass, "union", VALUEFUNC(_wrap_Geometry_union), -1);
+ rb_define_method(SwigClassGeometry.klass, "point_on_surface", VALUEFUNC(_wrap_Geometry_point_on_surface), -1);
+ rb_define_method(SwigClassGeometry.klass, "centroid", VALUEFUNC(_wrap_Geometry_centroid), -1);
+ rb_define_alias(SwigClassGeometry.klass, "center", "centroid");
+ rb_define_method(SwigClassGeometry.klass, "envelope", VALUEFUNC(_wrap_Geometry_envelope), -1);
+ rb_define_method(SwigClassGeometry.klass, "relate", VALUEFUNC(_wrap_Geometry_relate), -1);
+ rb_define_method(SwigClassGeometry.klass, "line_merge", VALUEFUNC(_wrap_Geometry_line_merge), -1);
+ rb_define_method(SwigClassGeometry.klass, "simplify", VALUEFUNC(_wrap_Geometry_simplify), -1);
+ rb_define_method(SwigClassGeometry.klass, "topology_preserve_simplify", VALUEFUNC(_wrap_Geometry_topology_preserve_simplify), -1);
+ rb_define_method(SwigClassGeometry.klass, "relate_pattern", VALUEFUNC(_wrap_Geometry_relate_pattern), -1);
+ rb_define_method(SwigClassGeometry.klass, "disjoint?", VALUEFUNC(_wrap_Geometry_disjointq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "touches?", VALUEFUNC(_wrap_Geometry_touchesq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "intersects?", VALUEFUNC(_wrap_Geometry_intersectsq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "crosses?", VALUEFUNC(_wrap_Geometry_crossesq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "within?", VALUEFUNC(_wrap_Geometry_withinq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "contains?", VALUEFUNC(_wrap_Geometry_containsq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "overlaps?", VALUEFUNC(_wrap_Geometry_overlapsq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "eql?", VALUEFUNC(_wrap_Geometry_eqlq___), -1);
+ rb_define_alias(SwigClassGeometry.klass, "==", "eql?");
+ rb_define_method(SwigClassGeometry.klass, "eql_exact?", VALUEFUNC(_wrap_Geometry_eql_exactq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "empty?", VALUEFUNC(_wrap_Geometry_emptyq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "valid?", VALUEFUNC(_wrap_Geometry_validq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "simple?", VALUEFUNC(_wrap_Geometry_simpleq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "ring?", VALUEFUNC(_wrap_Geometry_ringq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "has_z?", VALUEFUNC(_wrap_Geometry_has_zq___), -1);
+ rb_define_method(SwigClassGeometry.klass, "area", VALUEFUNC(_wrap_Geometry_area), -1);
+ rb_define_method(SwigClassGeometry.klass, "length", VALUEFUNC(_wrap_Geometry_length), -1);
+ rb_define_method(SwigClassGeometry.klass, "distance", VALUEFUNC(_wrap_Geometry_distance), -1);
+ SwigClassGeometry.mark = 0;
+ SwigClassGeometry.destroy = (void (*)(void *)) free_GeosGeometry;
+ SwigClassGeometry.trackObjects = 0;
+ SwigClassPoint.klass = rb_define_class_under(mGeos, "Point", ((swig_class *) SWIGTYPE_p_GeosGeometry->clientdata)->klass);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosPoint, (void *) &SwigClassPoint);
+ rb_undef_alloc_func(SwigClassPoint.klass);
+ rb_define_method(SwigClassPoint.klass, "coord_seq", VALUEFUNC(_wrap_Point_coord_seq), -1);
+ SwigClassPoint.mark = 0;
+ SwigClassPoint.destroy = (void (*)(void *)) free_GeosPoint;
+ SwigClassPoint.trackObjects = 0;
+ SwigClassLineString.klass = rb_define_class_under(mGeos, "LineString", ((swig_class *) SWIGTYPE_p_GeosGeometry->clientdata)->klass);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosLineString, (void *) &SwigClassLineString);
+ rb_undef_alloc_func(SwigClassLineString.klass);
+ rb_define_method(SwigClassLineString.klass, "coord_seq", VALUEFUNC(_wrap_LineString_coord_seq), -1);
+ SwigClassLineString.mark = 0;
+ SwigClassLineString.destroy = (void (*)(void *)) free_GeosLineString;
+ SwigClassLineString.trackObjects = 0;
+ SwigClassLinearRing.klass = rb_define_class_under(mGeos, "LinearRing", ((swig_class *) SWIGTYPE_p_GeosGeometry->clientdata)->klass);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosLinearRing, (void *) &SwigClassLinearRing);
+ rb_undef_alloc_func(SwigClassLinearRing.klass);
+ rb_define_method(SwigClassLinearRing.klass, "coord_seq", VALUEFUNC(_wrap_LinearRing_coord_seq), -1);
+ SwigClassLinearRing.mark = 0;
+ SwigClassLinearRing.destroy = (void (*)(void *)) free_GeosLinearRing;
+ SwigClassLinearRing.trackObjects = 0;
+ SwigClassPolygon.klass = rb_define_class_under(mGeos, "Polygon", ((swig_class *) SWIGTYPE_p_GeosGeometry->clientdata)->klass);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosPolygon, (void *) &SwigClassPolygon);
+ rb_undef_alloc_func(SwigClassPolygon.klass);
+ rb_define_method(SwigClassPolygon.klass, "exterior_ring", VALUEFUNC(_wrap_Polygon_exterior_ring), -1);
+ rb_define_method(SwigClassPolygon.klass, "num_interior_rings", VALUEFUNC(_wrap_Polygon_num_interior_rings), -1);
+ rb_define_method(SwigClassPolygon.klass, "interior_ring_n", VALUEFUNC(_wrap_Polygon_interior_ring_n), -1);
+ SwigClassPolygon.mark = 0;
+ SwigClassPolygon.destroy = (void (*)(void *)) free_GeosPolygon;
+ SwigClassPolygon.trackObjects = 0;
+ SwigClassGeometryCollection.klass = rb_define_class_under(mGeos, "GeometryCollection", ((swig_class *) SWIGTYPE_p_GeosGeometry->clientdata)->klass);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosGeometryCollection, (void *) &SwigClassGeometryCollection);
+ rb_undef_alloc_func(SwigClassGeometryCollection.klass);
+ rb_define_method(SwigClassGeometryCollection.klass, "get_geometry_n", VALUEFUNC(_wrap_GeometryCollection_get_geometry_n), -1);
+ SwigClassGeometryCollection.mark = 0;
+ SwigClassGeometryCollection.destroy = (void (*)(void *)) free_GeosGeometryCollection;
+ SwigClassGeometryCollection.trackObjects = 0;
+ SwigClassMultiPoint.klass = rb_define_class_under(mGeos, "MultiPoint", ((swig_class *) SWIGTYPE_p_GeosGeometryCollection->clientdata)->klass);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosMultiPoint, (void *) &SwigClassMultiPoint);
+ rb_undef_alloc_func(SwigClassMultiPoint.klass);
+ SwigClassMultiPoint.mark = 0;
+ SwigClassMultiPoint.destroy = (void (*)(void *)) free_GeosMultiPoint;
+ SwigClassMultiPoint.trackObjects = 0;
+ SwigClassMultiLineString.klass = rb_define_class_under(mGeos, "MultiLineString", ((swig_class *) SWIGTYPE_p_GeosGeometryCollection->clientdata)->klass);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosMultiLineString, (void *) &SwigClassMultiLineString);
+ rb_undef_alloc_func(SwigClassMultiLineString.klass);
+ SwigClassMultiLineString.mark = 0;
+ SwigClassMultiLineString.destroy = (void (*)(void *)) free_GeosMultiLineString;
+ SwigClassMultiLineString.trackObjects = 0;
+ SwigClassMultiLinearRing.klass = rb_define_class_under(mGeos, "MultiLinearRing", ((swig_class *) SWIGTYPE_p_GeosGeometryCollection->clientdata)->klass);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosMultiLinearRing, (void *) &SwigClassMultiLinearRing);
+ rb_undef_alloc_func(SwigClassMultiLinearRing.klass);
+ SwigClassMultiLinearRing.mark = 0;
+ SwigClassMultiLinearRing.destroy = (void (*)(void *)) free_GeosMultiLinearRing;
+ SwigClassMultiLinearRing.trackObjects = 0;
+ SwigClassMultiPolygon.klass = rb_define_class_under(mGeos, "MultiPolygon", ((swig_class *) SWIGTYPE_p_GeosGeometryCollection->clientdata)->klass);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosMultiPolygon, (void *) &SwigClassMultiPolygon);
+ rb_undef_alloc_func(SwigClassMultiPolygon.klass);
+ SwigClassMultiPolygon.mark = 0;
+ SwigClassMultiPolygon.destroy = (void (*)(void *)) free_GeosMultiPolygon;
+ SwigClassMultiPolygon.trackObjects = 0;
+ rb_define_module_function(mGeos, "create_point", VALUEFUNC(_wrap_create_point), -1);
+ rb_define_module_function(mGeos, "create_line_string", VALUEFUNC(_wrap_create_line_string), -1);
+ rb_define_module_function(mGeos, "create_linear_ring", VALUEFUNC(_wrap_create_linear_ring), -1);
+ rb_define_module_function(mGeos, "create_polygon", VALUEFUNC(_wrap_create_polygon), -1);
+ SwigClassPrepared.klass = rb_define_class_under(mGeos, "Prepared", rb_cObject);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosPreparedGeometry, (void *) &SwigClassPrepared);
+ rb_define_alloc_func(SwigClassPrepared.klass, _wrap_Prepared_allocate);
+ rb_define_method(SwigClassPrepared.klass, "initialize", VALUEFUNC(_wrap_new_Prepared), -1);
+ rb_define_method(SwigClassPrepared.klass, "contains?", VALUEFUNC(_wrap_Prepared_containsq___), -1);
+ rb_define_method(SwigClassPrepared.klass, "contains_properly?", VALUEFUNC(_wrap_Prepared_contains_properlyq___), -1);
+ rb_define_method(SwigClassPrepared.klass, "covers?", VALUEFUNC(_wrap_Prepared_coversq___), -1);
+ rb_define_method(SwigClassPrepared.klass, "intersects?", VALUEFUNC(_wrap_Prepared_intersectsq___), -1);
+ SwigClassPrepared.mark = 0;
+ SwigClassPrepared.destroy = (void (*)(void *)) free_GeosPreparedGeometry;
+ SwigClassPrepared.trackObjects = 0;
+ SwigClassSTRtree.klass = rb_define_class_under(mGeos, "STRtree", rb_cObject);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosSTRtree, (void *) &SwigClassSTRtree);
+ rb_define_alloc_func(SwigClassSTRtree.klass, _wrap_STRtree_allocate);
+ rb_define_method(SwigClassSTRtree.klass, "initialize", VALUEFUNC(_wrap_new_STRtree), -1);
+ rb_define_method(SwigClassSTRtree.klass, "insert", VALUEFUNC(_wrap_STRtree_insert), -1);
+ rb_define_method(SwigClassSTRtree.klass, "remove", VALUEFUNC(_wrap_STRtree_remove), -1);
+ rb_define_method(SwigClassSTRtree.klass, "query", VALUEFUNC(_wrap_STRtree_query), -1);
+ rb_define_method(SwigClassSTRtree.klass, "each", VALUEFUNC(_wrap_STRtree_each), -1);
+ SwigClassSTRtree.mark = (void (*)(void *)) mark_GeosSTRtree;
+ SwigClassSTRtree.destroy = (void (*)(void *)) free_GeosSTRtree;
+ SwigClassSTRtree.trackObjects = 0;
+ SwigClassWktReader.klass = rb_define_class_under(mGeos, "WktReader", rb_cObject);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosWktReader, (void *) &SwigClassWktReader);
+ rb_define_alloc_func(SwigClassWktReader.klass, _wrap_WktReader_allocate);
+ rb_define_method(SwigClassWktReader.klass, "initialize", VALUEFUNC(_wrap_new_WktReader), -1);
+ rb_define_method(SwigClassWktReader.klass, "read", VALUEFUNC(_wrap_WktReader_read), -1);
+ SwigClassWktReader.mark = 0;
+ SwigClassWktReader.destroy = (void (*)(void *)) free_GeosWktReader;
+ SwigClassWktReader.trackObjects = 0;
+ SwigClassWktWriter.klass = rb_define_class_under(mGeos, "WktWriter", rb_cObject);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosWktWriter, (void *) &SwigClassWktWriter);
+ rb_define_alloc_func(SwigClassWktWriter.klass, _wrap_WktWriter_allocate);
+ rb_define_method(SwigClassWktWriter.klass, "initialize", VALUEFUNC(_wrap_new_WktWriter), -1);
+ rb_define_method(SwigClassWktWriter.klass, "write", VALUEFUNC(_wrap_WktWriter_write), -1);
+ SwigClassWktWriter.mark = 0;
+ SwigClassWktWriter.destroy = (void (*)(void *)) free_GeosWktWriter;
+ SwigClassWktWriter.trackObjects = 0;
+ SwigClassWkbReader.klass = rb_define_class_under(mGeos, "WkbReader", rb_cObject);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosWkbReader, (void *) &SwigClassWkbReader);
+ rb_define_alloc_func(SwigClassWkbReader.klass, _wrap_WkbReader_allocate);
+ rb_define_method(SwigClassWkbReader.klass, "initialize", VALUEFUNC(_wrap_new_WkbReader), -1);
+ rb_define_method(SwigClassWkbReader.klass, "read", VALUEFUNC(_wrap_WkbReader_read), -1);
+ rb_define_method(SwigClassWkbReader.klass, "read_hex", VALUEFUNC(_wrap_WkbReader_read_hex), -1);
+ SwigClassWkbReader.mark = 0;
+ SwigClassWkbReader.destroy = (void (*)(void *)) free_GeosWkbReader;
+ SwigClassWkbReader.trackObjects = 0;
+ SwigClassWkbWriter.klass = rb_define_class_under(mGeos, "WkbWriter", rb_cObject);
+ SWIG_TypeClientData(SWIGTYPE_p_GeosWkbWriter, (void *) &SwigClassWkbWriter);
+ rb_define_alloc_func(SwigClassWkbWriter.klass, _wrap_WkbWriter_allocate);
+ rb_define_method(SwigClassWkbWriter.klass, "initialize", VALUEFUNC(_wrap_new_WkbWriter), -1);
+ rb_define_method(SwigClassWkbWriter.klass, "output_dimensions", VALUEFUNC(_wrap_WkbWriter_output_dimensions), -1);
+ rb_define_method(SwigClassWkbWriter.klass, "output_dimensions=", VALUEFUNC(_wrap_WkbWriter_output_dimensionse___), -1);
+ rb_define_method(SwigClassWkbWriter.klass, "byte_order", VALUEFUNC(_wrap_WkbWriter_byte_order), -1);
+ rb_define_method(SwigClassWkbWriter.klass, "byte_order=", VALUEFUNC(_wrap_WkbWriter_byte_ordere___), -1);
+ rb_define_method(SwigClassWkbWriter.klass, "include_srid", VALUEFUNC(_wrap_WkbWriter_include_srid), -1);
+ rb_define_method(SwigClassWkbWriter.klass, "include_srid=", VALUEFUNC(_wrap_WkbWriter_include_sride___), -1);
+ rb_define_method(SwigClassWkbWriter.klass, "write", VALUEFUNC(_wrap_WkbWriter_write), -1);
+ rb_define_method(SwigClassWkbWriter.klass, "write_hex", VALUEFUNC(_wrap_WkbWriter_write_hex), -1);
+ SwigClassWkbWriter.mark = 0;
+ SwigClassWkbWriter.destroy = (void (*)(void *)) free_GeosWkbWriter;
+ SwigClassWkbWriter.trackObjects = 0;
Modified: trunk/swig/ruby/ruby.i
--- trunk/swig/ruby/ruby.i 2011-11-06 03:25:10 UTC (rev 3517)
+++ trunk/swig/ruby/ruby.i 2011-11-24 22:07:19 UTC (rev 3518)
@@ -75,7 +75,7 @@
Check_Type($input, T_ARRAY);
- $2 = RARRAY($input)->len;
+ $2 = RARRAY_LEN($input);
$1 = (GeosLinearRing**) malloc($2*sizeof(GeosLinearRing*));
More information about the geos-commits
