[geos-commits] r3519 - in branches/3.3: . src/operation/buffer
tests/xmltester tests/xmltester/tests/safe
svn_geos at osgeo.org
Mon Nov 28 03:40:15 EST 2011
Author: strk
Date: 2011-11-28 00:40:15 -0800 (Mon, 28 Nov 2011)
New Revision: 3519
Added:
branches/3.3/tests/xmltester/tests/safe/buffer-1.01.xml
branches/3.3/NEWS
branches/3.3/src/operation/buffer/BufferBuilder.cpp
branches/3.3/tests/xmltester/Makefile.am
BufferBuilder: fix handling of collapsed edges skipping. Fixes #494.
Includes regression test, provided by SAFE.
Modified: branches/3.3/NEWS
--- branches/3.3/NEWS 2011-11-24 22:07:19 UTC (rev 3518)
+++ branches/3.3/NEWS 2011-11-28 08:40:15 UTC (rev 3519)
@@ -5,6 +5,7 @@
- Fixed CMAKE_CXX_FLAGS overridind -std=gnu++0x (#489)
- Missing versions update in CMake configuration (#490)
- Fix noding of self-intersecting lines through UnaryUnion (#482)
+ - Fix handling of collapsed edges skipping in BufferOp (#494)
Changes in 3.3.1
2011-09-27
Modified: branches/3.3/src/operation/buffer/BufferBuilder.cpp
--- branches/3.3/src/operation/buffer/BufferBuilder.cpp 2011-11-24 22:07:19 UTC (rev 3518)
+++ branches/3.3/src/operation/buffer/BufferBuilder.cpp 2011-11-28 08:40:15 UTC (rev 3519)
@@ -536,7 +536,7 @@
if ( cs->size() < 2 )
delete cs; // we need to take care of the memory here as cs is a new sequence
- return; // don't insert collapsed edges
+ continue; // don't insert collapsed edges
// we need to clone SegmentString coordinates
// as Edge will take ownership of them
Modified: branches/3.3/tests/xmltester/Makefile.am
--- branches/3.3/tests/xmltester/Makefile.am 2011-11-24 22:07:19 UTC (rev 3518)
+++ branches/3.3/tests/xmltester/Makefile.am 2011-11-28 08:40:15 UTC (rev 3519)
@@ -79,7 +79,8 @@
$(srcdir)/tests/hole_from_shell.xml \
$(srcdir)/tests/hole_red.xml \
$(srcdir)/tests/safe/16595.xml \
- $(srcdir)/tests/safe/16596.xml
+ $(srcdir)/tests/safe/16596.xml \
+ $(srcdir)/tests/safe/buffer-1.01.xml
INVALID_OUTPUT_XMLTESTS =
Added: branches/3.3/tests/xmltester/tests/safe/buffer-1.01.xml
--- branches/3.3/tests/xmltester/tests/safe/buffer-1.01.xml (rev 0)
+++ branches/3.3/tests/xmltester/tests/safe/buffer-1.01.xml 2011-11-28 08:40:15 UTC (rev 3519)
@@ -0,0 +1,18 @@
+<run>
+<precisionModel type="FLOATING"/>
+<case>
+ <desc>GEOS 3.3.1 produces rectangle buffer, GEOS 3.2.0 fine (#494)</desc>
+ <a>
+ POLYGON ((99736.4572496327 -2239219.11305743, 99736.6573549178 -2239219.11305743, 99736.6573549178 -2239219.01300479, 99736.5573022753 -2239219.01300479, 99736.5573022753 -2239218.8128995, 99736.6573549178 -2239218.8128995, 99736.6573549178 -2239218.91295215, 99736.7574075604 -2239218.91295215, 99736.7574075604 -2239219.01300479, 99736.8574602029 -2239219.01300479, 99736.8574602029 -2239219.11305743, 99736.9575128455 -2239219.11305743, 99736.9575128455 -2239219.21311007, 99737.057565488 -2239219.21311007, 99737.057565488 -2239219.01300479, 99737.2576707731 -2239219.01300479, 99737.2576707731 -2239219.11305743, 99737.4577760582 -2239219.11305743, 99737.4577760582 -2239219.01300479, 99737.958039271 -2239219.01300479, 99737.958039271 -2239218.91295215, 99738.0580919136 -2239218.91295215, 99738.0580919136 -2239218.51274158, 99738.1581445561 -2239218.51274158, 99738.1581445561 -2239218.61279422, 99738.3582498412 -2239218.61279422, 99738.3582498412 -2239218.41268893, 99738.458
3024838 -2239218.41268893, 99738.4583024838 -2239218.61279422, 99738.5583551263 -2239218.61279422, 99738.5583551263 -2239218.41268893, 99738.6584077689 -2239218.41268893, 99738.6584077689 -2239218.31263629, 99738.4583024838 -2239218.31263629, 99738.4583024838 -2239218.11253101, 99738.5583551263 -2239218.11253101, 99738.5583551263 -2239218.21258365, 99738.6584077689 -2239218.21258365, 99738.6584077689 -2239218.11253101, 99738.7584604114 -2239218.11253101, 99738.7584604114 -2239218.41268893, 99738.858513054 -2239218.41268893, 99738.858513054 -2239218.31263629, 99738.9585656965 -2239218.31263629, 99738.9585656965 -2239218.21258365, 99738.858513054 -2239218.21258365, 99738.858513054 -2239217.91242572, 99738.9585656965 -2239217.91242572, 99738.9585656965 -2239218.01247836, 99739.1586709816 -2239218.01247836, 99739.1586709816 -2239217.91242572, 99739.2587236242 -2239217.91242572, 99739.2587236242 -2239218.01247836, 99739.3587762667 -2239218.01247836, 99739.3587762667 -2239218.1125
3101, 99739.4588289093 -2239218.11253101, 99739.4588289093 -2239217.91242572, 99739.5588815519 -2239217.91242572, 99739.5588815519 -2239218.01247836, 99739.6589341944 -2239218.01247836, 99739.6589341944 -2239217.81237308, 99739.8590394795 -2239217.81237308, 99739.8590394795 -2239217.71232044, 99740.0591447646 -2239217.71232044, 99740.0591447646 -2239217.61226779, 99740.1591974072 -2239217.61226779, 99740.1591974072 -2239217.71232044, 99740.2592500497 -2239217.71232044, 99740.2592500497 -2239217.51221515, 99740.0591447646 -2239217.51221515, 99740.0591447646 -2239217.41216251, 99740.2592500497 -2239217.41216251, 99740.2592500497 -2239217.21205722, 99740.3593026923 -2239217.21205722, 99740.3593026923 -2239217.01195194, 99740.2592500497 -2239217.01195194, 99740.2592500497 -2239217.11200458, 99740.1591974072 -2239217.11200458, 99740.1591974072 -2239217.01195194, 99740.0591447646 -2239217.01195194, 99740.0591447646 -2239217.31210987, 99739.8590394795 -2239217.31210987, 99739.85903
94795 -2239217.41216251, 99739.6589341944 -2239217.41216251, 99739.6589341944 -2239217.51221515, 99739.4588289093 -2239217.51221515, 99739.4588289093 -2239217.61226779, 99738.9585656965 -2239217.61226779, 99738.9585656965 -2239217.51221515, 99738.7584604114 -2239217.51221515, 99738.7584604114 -2239217.41216251, 99738.5583551263 -2239217.41216251, 99738.5583551263 -2239217.31210987, 99738.4583024838 -2239217.31210987, 99738.4583024838 -2239217.21205722, 99738.6584077689 -2239217.21205722, 99738.6584077689 -2239217.11200458, 99738.9585656965 -2239217.11200458, 99738.9585656965 -2239217.01195194, 99738.7584604114 -2239217.01195194, 99738.7584604114 -2239216.9118993, 99738.3582498412 -2239216.9118993, 99738.3582498412 -2239217.01195194, 99738.2581971987 -2239217.01195194, 99738.2581971987 -2239216.9118993, 99738.1581445561 -2239216.9118993, 99738.1581445561 -2239217.01195194, 99738.0580919136 -2239217.01195194, 99738.0580919136 -2239216.9118993, 99737.8579866284 -2239216.9118993
, 99737.8579866284 -2239216.61174137, 99737.6578813433 -2239216.61174137, 99737.6578813433 -2239216.41163608, 99737.4577760582 -2239216.41163608, 99737.4577760582 -2239216.2115308, 99737.2576707731 -2239216.2115308, 99737.2576707731 -2239215.81132023, 99737.057565488 -2239215.81132023, 99737.057565488 -2239215.41110966, 99736.9575128455 -2239215.41110966, 99736.9575128455 -2239215.31105701, 99736.8574602029 -2239215.31105701, 99736.8574602029 -2239215.01089909, 99736.9575128455 -2239215.01089909, 99736.9575128455 -2239214.91084644, 99737.057565488 -2239214.91084644, 99737.057565488 -2239214.8107938, 99737.1576181306 -2239214.8107938, 99737.1576181306 -2239214.71074116, 99737.3577234157 -2239214.71074116, 99737.3577234157 -2239214.61068852, 99737.6578813433 -2239214.61068852, 99737.6578813433 -2239214.41058323, 99737.8579866284 -2239214.41058323, 99737.8579866284 -2239214.31053059, 99737.958039271 -2239214.31053059, 99737.958039271 -2239214.1104253, 99737.5578287008 -2239214.
1104253, 99737.5578287008 -2239214.21047795, 99737.4577760582 -2239214.21047795, 99737.4577760582 -2239214.01037266, 99737.6578813433 -2239214.01037266, 99737.6578813433 -2239213.91032002, 99737.7579339859 -2239213.91032002, 99737.7579339859 -2239213.71021473, 99737.8579866284 -2239213.71021473, 99737.8579866284 -2239213.61016209, 99737.7579339859 -2239213.61016209, 99737.7579339859 -2239213.51010945, 99737.8579866284 -2239213.51010945, 99737.8579866284 -2239213.41005681, 99737.958039271 -2239213.41005681, 99737.958039271 -2239213.31000416, 99737.8579866284 -2239213.31000416, 99737.8579866284 -2239213.20995152, 99737.7579339859 -2239213.20995152, 99737.7579339859 -2239213.31000416, 99737.5578287008 -2239213.31000416, 99737.5578287008 -2239213.10989888, 99737.3577234157 -2239213.10989888, 99737.3577234157 -2239212.90979359, 99737.4577760582 -2239212.90979359, 99737.4577760582 -2239212.80974095, 99737.3577234157 -2239212.80974095, 99737.3577234157 -2239212.70968831, 99737.2576
707731 -2239212.70968831, 99737.2576707731 -2239212.30947774, 99737.057565488 -2239212.30947774, 99737.057565488 -2239212.2094251, 99736.9575128455 -2239212.2094251, 99736.9575128455 -2239212.10937245, 99737.057565488 -2239212.10937245, 99737.057565488 -2239212.00931981, 99737.1576181306 -2239212.00931981, 99737.1576181306 -2239212.10937245, 99737.2576707731 -2239212.10937245, 99737.2576707731 -2239212.2094251, 99737.3577234157 -2239212.2094251, 99737.3577234157 -2239212.40953038, 99737.4577760582 -2239212.40953038, 99737.4577760582 -2239212.30947774, 99737.5578287008 -2239212.30947774, 99737.5578287008 -2239212.2094251, 99737.6578813433 -2239212.2094251, 99737.6578813433 -2239212.10937245, 99737.5578287008 -2239212.10937245, 99737.5578287008 -2239212.00931981, 99737.4577760582 -2239212.00931981, 99737.4577760582 -2239211.90926717, 99737.2576707731 -2239211.90926717, 99737.2576707731 -2239211.80921452, 99737.1576181306 -2239211.80921452, 99737.1576181306 -2239211.70916188, 9
9737.057565488 -2239211.70916188, 99737.057565488 -2239211.60910924, 99736.9575128455 -2239211.60910924, 99736.9575128455 -2239211.5090566, 99736.7574075604 -2239211.5090566, 99736.7574075604 -2239211.40900395, 99736.5573022753 -2239211.40900395, 99736.5573022753 -2239211.00879338, 99736.4572496327 -2239211.00879338, 99736.4572496327 -2239210.90874074, 99736.157091705 -2239210.90874074, 99736.157091705 -2239210.8086881, 99736.2571443476 -2239210.8086881, 99736.2571443476 -2239210.60858281, 99736.3571969901 -2239210.60858281, 99736.3571969901 -2239210.40847753, 99736.2571443476 -2239210.40847753, 99736.2571443476 -2239210.50853017, 99736.0570390625 -2239210.50853017, 99736.0570390625 -2239210.40847753, 99736.157091705 -2239210.40847753, 99736.157091705 -2239210.30842489, 99735.9569864199 -2239210.30842489, 99735.9569864199 -2239210.20837224, 99736.0570390625 -2239210.20837224, 99736.0570390625 -2239209.90821432, 99735.8569337774 -2239209.90821432, 99735.8569337774 -2239209.80
816167, 99735.9569864199 -2239209.80816167, 99735.9569864199 -2239209.60805639, 99735.8569337774 -2239209.60805639, 99735.8569337774 -2239209.50800375, 99735.7568811348 -2239209.50800375, 99735.7568811348 -2239209.4079511, 99735.8569337774 -2239209.4079511, 99735.8569337774 -2239209.30789846, 99735.7568811348 -2239209.30789846, 99735.7568811348 -2239209.20784582, 99735.6568284923 -2239209.20784582, 99735.6568284923 -2239209.00774053, 99735.7568811348 -2239209.00774053, 99735.7568811348 -2239208.80763525, 99735.6568284923 -2239208.80763525, 99735.6568284923 -2239208.60752996, 99735.5567758497 -2239208.60752996, 99735.5567758497 -2239208.50747732, 99735.6568284923 -2239208.50747732, 99735.6568284923 -2239208.40742468, 99735.5567758497 -2239208.40742468, 99735.5567758497 -2239208.30737204, 99735.4567232072 -2239208.30737204, 99735.4567232072 -2239208.20731939, 99735.5567758497 -2239208.20731939, 99735.5567758497 -2239208.00721411, 99735.4567232072 -2239208.00721411, 99735.45672
32072 -2239207.90716147, 99735.3566705646 -2239207.90716147, 99735.3566705646 -2239207.70705618, 99735.4567232072 -2239207.70705618, 99735.4567232072 -2239207.50695089, 99735.3566705646 -2239207.50695089, 99735.3566705646 -2239207.40689825, 99735.4567232072 -2239207.40689825, 99735.4567232072 -2239207.30684561, 99735.2566179221 -2239207.30684561, 99735.2566179221 -2239207.20679297, 99735.3566705646 -2239207.20679297, 99735.3566705646 -2239207.10674032, 99735.1565652795 -2239207.10674032, 99735.1565652795 -2239207.30684561, 99735.0565126369 -2239207.30684561, 99735.0565126369 -2239207.00668768, 99734.9564599944 -2239207.00668768, 99734.9564599944 -2239207.40689825, 99734.8564073518 -2239207.40689825, 99734.8564073518 -2239207.00668768, 99734.7563547093 -2239207.00668768, 99734.7563547093 -2239206.90663504, 99734.6563020667 -2239206.90663504, 99734.6563020667 -2239206.8065824, 99734.5562494242 -2239206.8065824, 99734.5562494242 -2239206.70652975, 99734.2560914965 -2239206.7065
2975, 99734.2560914965 -2239206.60647711, 99734.3561441391 -2239206.60647711, 99734.3561441391 -2239206.30631918, 99734.156038854 -2239206.30631918, 99734.156038854 -2239206.20626654, 99734.0559862114 -2239206.20626654, 99734.0559862114 -2239206.1062139, 99734.2560914965 -2239206.1062139, 99734.2560914965 -2239205.90610861, 99734.3561441391 -2239205.90610861, 99734.3561441391 -2239205.80605597, 99734.4561967816 -2239205.80605597, 99734.4561967816 -2239205.70600333, 99734.6563020667 -2239205.70600333, 99734.6563020667 -2239205.80605597, 99734.8564073518 -2239205.80605597, 99734.8564073518 -2239205.30579276, 99734.3561441391 -2239205.30579276, 99734.3561441391 -2239205.10568747, 99734.0559862114 -2239205.10568747, 99734.0559862114 -2239205.00563483, 99733.8558809263 -2239205.00563483, 99733.8558809263 -2239204.90558219, 99733.6557756412 -2239204.90558219, 99733.6557756412 -2239204.80552955, 99733.4556703561 -2239204.80552955, 99733.4556703561 -2239204.7054769, 99733.3556177135
-2239204.7054769, 99733.3556177135 -2239204.60542426, 99733.1555124284 -2239204.60542426, 99733.1555124284 -2239204.50537162, 99732.8553545008 -2239204.50537162, 99732.8553545008 -2239204.60542426, 99732.7553018582 -2239204.60542426, 99732.7553018582 -2239204.90558219, 99732.5551965731 -2239204.90558219, 99732.5551965731 -2239205.00563483, 99732.4551439306 -2239205.00563483, 99732.4551439306 -2239205.10568747, 99732.355091288 -2239205.10568747, 99732.355091288 -2239205.20574012, 99732.1549860029 -2239205.20574012, 99732.1549860029 -2239205.30579276, 99731.9548807178 -2239205.30579276, 99731.9548807178 -2239205.4058454, 99731.454617505 -2239205.4058454, 99731.454617505 -2239205.50589804, 99731.0544069348 -2239205.50589804, 99731.0544069348 -2239205.60595069, 99730.8543016497 -2239205.60595069, 99730.8543016497 -2239205.70600333, 99730.7542490072 -2239205.70600333, 99730.7542490072 -2239205.80605597, 99730.554143722 -2239205.80605597, 99730.554143722 -2239205.90610861, 99730.
4540910795 -2239205.90610861, 99730.4540910795 -2239206.00616126, 99730.3540384369 -2239206.00616126, 99730.3540384369 -2239206.50642447, 99730.2539857944 -2239206.50642447, 99730.2539857944 -2239206.70652975, 99730.1539331518 -2239206.70652975, 99730.1539331518 -2239206.8065824, 99729.9538278667 -2239206.8065824, 99729.9538278667 -2239206.90663504, 99729.5536172965 -2239206.90663504, 99729.5536172965 -2239207.00668768, 99729.3535120114 -2239207.00668768, 99729.3535120114 -2239207.10674032, 99729.2534593688 -2239207.10674032, 99729.2534593688 -2239207.20679297, 99729.0533540837 -2239207.20679297, 99729.0533540837 -2239207.30684561, 99728.9533014412 -2239207.30684561, 99728.9533014412 -2239207.40689825, 99728.8532487986 -2239207.40689825, 99728.8532487986 -2239207.50695089, 99728.7531961561 -2239207.50695089, 99728.7531961561 -2239207.60700354, 99728.6531435135 -2239207.60700354, 99728.6531435135 -2239208.10726675, 99728.553090871 -2239208.10726675, 99728.553090871 -2239208.3
0737204, 99728.4530382284 -2239208.30737204, 99728.4530382284 -2239208.50747732, 99728.6531435135 -2239208.50747732, 99728.6531435135 -2239208.60752996, 99728.2529329433 -2239208.60752996, 99728.2529329433 -2239208.70758261, 99727.8527223731 -2239208.70758261, 99727.8527223731 -2239208.60752996, 99727.5525644454 -2239208.60752996, 99727.5525644454 -2239208.70758261, 99727.4525118029 -2239208.70758261, 99727.4525118029 -2239208.60752996, 99726.4519853773 -2239208.60752996, 99726.4519853773 -2239208.70758261, 99726.2518800922 -2239208.70758261, 99726.2518800922 -2239208.80763525, 99726.1518274497 -2239208.80763525, 99726.1518274497 -2239208.90768789, 99726.0517748071 -2239208.90768789, 99726.0517748071 -2239209.00774053, 99725.9517221646 -2239209.00774053, 99725.9517221646 -2239209.10779318, 99725.851669522 -2239209.10779318, 99725.851669522 -2239209.20784582, 99725.7516168795 -2239209.20784582, 99725.7516168795 -2239209.4079511, 99725.6515642369 -2239209.4079511, 99725.651564
2369 -2239209.50800375, 99725.7516168795 -2239209.50800375, 99725.7516168795 -2239209.60805639, 99725.6515642369 -2239209.60805639, 99725.6515642369 -2239209.90821432, 99725.5515115944 -2239209.90821432, 99725.5515115944 -2239210.50853017, 99725.4514589518 -2239210.50853017, 99725.4514589518 -2239211.20889867, 99725.5515115944 -2239211.20889867, 99725.5515115944 -2239211.40900395, 99725.6515642369 -2239211.40900395, 99725.6515642369 -2239211.5090566, 99725.7516168795 -2239211.5090566, 99725.7516168795 -2239211.40900395, 99725.851669522 -2239211.40900395, 99725.851669522 -2239211.10884603, 99725.9517221646 -2239211.10884603, 99725.9517221646 -2239210.90874074, 99726.0517748071 -2239210.90874074, 99726.0517748071 -2239210.20837224, 99726.1518274497 -2239210.20837224, 99726.1518274497 -2239210.1083196, 99726.2518800922 -2239210.1083196, 99726.2518800922 -2239210.00826696, 99726.4519853773 -2239210.00826696, 99726.4519853773 -2239209.90821432, 99726.6520906625 -2239209.90821432,
99726.6520906625 -2239210.00826696, 99726.9522485901 -2239210.00826696, 99726.9522485901 -2239210.1083196, 99727.1523538752 -2239210.1083196, 99727.1523538752 -2239210.20837224, 99727.7526697305 -2239210.20837224, 99727.7526697305 -2239210.1083196, 99728.6531435135 -2239210.1083196, 99728.6531435135 -2239210.00826696, 99728.7531961561 -2239210.00826696, 99728.7531961561 -2239210.1083196, 99729.0533540837 -2239210.1083196, 99729.0533540837 -2239210.20837224, 99729.1534067263 -2239210.20837224, 99729.1534067263 -2239210.00826696, 99728.9533014412 -2239210.00826696, 99728.9533014412 -2239209.90821432, 99729.1534067263 -2239209.90821432, 99729.1534067263 -2239209.80816167, 99728.9533014412 -2239209.80816167, 99728.9533014412 -2239209.70810903, 99728.8532487986 -2239209.70810903, 99728.8532487986 -2239209.60805639, 99728.9533014412 -2239209.60805639, 99728.9533014412 -2239209.4079511, 99728.8532487986 -2239209.4079511, 99728.8532487986 -2239209.30789846, 99728.9533014412 -223920
9.30789846, 99728.9533014412 -2239209.00774053, 99729.0533540837 -2239209.00774053, 99729.0533540837 -2239208.90768789, 99729.5536172965 -2239208.90768789, 99729.5536172965 -2239208.80763525, 99729.7537225816 -2239208.80763525, 99729.7537225816 -2239208.90768789, 99729.8537752242 -2239208.90768789, 99729.8537752242 -2239209.00774053, 99729.9538278667 -2239209.00774053, 99729.9538278667 -2239209.10779318, 99730.1539331518 -2239209.10779318, 99730.1539331518 -2239209.30789846, 99730.0538805093 -2239209.30789846, 99730.0538805093 -2239209.4079511, 99730.1539331518 -2239209.4079511, 99730.1539331518 -2239209.50800375, 99730.0538805093 -2239209.50800375, 99730.0538805093 -2239209.80816167, 99729.9538278667 -2239209.80816167, 99729.9538278667 -2239210.00826696, 99729.8537752242 -2239210.00826696, 99729.8537752242 -2239210.1083196, 99729.7537225816 -2239210.1083196, 99729.7537225816 -2239210.20837224, 99729.5536172965 -2239210.20837224, 99729.5536172965 -2239210.1083196, 99729.3535
120114 -2239210.1083196, 99729.3535120114 -2239210.30842489, 99729.2534593688 -2239210.30842489, 99729.2534593688 -2239210.40847753, 99729.3535120114 -2239210.40847753, 99729.3535120114 -2239210.8086881, 99729.4535646539 -2239210.8086881, 99729.4535646539 -2239210.90874074, 99729.3535120114 -2239210.90874074, 99729.3535120114 -2239211.00879338, 99729.1534067263 -2239211.00879338, 99729.1534067263 -2239211.10884603, 99728.7531961561 -2239211.10884603, 99728.7531961561 -2239211.20889867, 99727.9527750156 -2239211.20889867, 99727.9527750156 -2239211.30895131, 99727.652617088 -2239211.30895131, 99727.652617088 -2239211.40900395, 99727.4525118029 -2239211.40900395, 99727.4525118029 -2239211.5090566, 99727.3524591603 -2239211.5090566, 99727.3524591603 -2239211.70916188, 99727.4525118029 -2239211.70916188, 99727.4525118029 -2239211.80921452, 99727.652617088 -2239211.80921452, 99727.652617088 -2239211.90926717, 99727.8527223731 -2239211.90926717, 99727.8527223731 -2239212.00931981,
99728.4530382284 -2239212.00931981, 99728.4530382284 -2239212.10937245, 99728.553090871 -2239212.10937245, 99728.553090871 -2239212.00931981, 99728.7531961561 -2239212.00931981, 99728.7531961561 -2239212.10937245, 99729.1534067263 -2239212.10937245, 99729.1534067263 -2239212.2094251, 99729.3535120114 -2239212.2094251, 99729.3535120114 -2239212.30947774, 99729.4535646539 -2239212.30947774, 99729.4535646539 -2239212.50958302, 99729.5536172965 -2239212.50958302, 99729.5536172965 -2239212.60963567, 99729.6536699391 -2239212.60963567, 99729.6536699391 -2239212.70968831, 99729.9538278667 -2239212.70968831, 99729.9538278667 -2239212.80974095, 99730.3540384369 -2239212.80974095, 99730.3540384369 -2239212.90979359, 99730.554143722 -2239212.90979359, 99730.554143722 -2239213.00984624, 99730.7542490072 -2239213.00984624, 99730.7542490072 -2239212.90979359, 99730.8543016497 -2239212.90979359, 99730.8543016497 -2239213.00984624, 99730.9543542922 -2239213.00984624, 99730.9543542922 -22392
13.20995152, 99731.0544069348 -2239213.20995152, 99731.0544069348 -2239213.10989888, 99731.1544595774 -2239213.10989888, 99731.1544595774 -2239213.31000416, 99731.3545648625 -2239213.31000416, 99731.3545648625 -2239213.41005681, 99731.454617505 -2239213.41005681, 99731.454617505 -2239213.51010945, 99731.5546701476 -2239213.51010945, 99731.5546701476 -2239213.61016209, 99731.6547227901 -2239213.61016209, 99731.6547227901 -2239213.81026738, 99731.7547754327 -2239213.81026738, 99731.7547754327 -2239213.91032002, 99731.8548280752 -2239213.91032002, 99731.8548280752 -2239214.1104253, 99731.9548807178 -2239214.1104253, 99731.9548807178 -2239214.31053059, 99732.0549333603 -2239214.31053059, 99732.0549333603 -2239214.41058323, 99731.9548807178 -2239214.41058323, 99731.9548807178 -2239214.51063587, 99732.0549333603 -2239214.51063587, 99732.0549333603 -2239214.71074116, 99732.1549860029 -2239214.71074116, 99732.1549860029 -2239214.91084644, 99732.2550386455 -2239214.91084644, 99732.25
50386455 -2239215.11095173, 99732.355091288 -2239215.11095173, 99732.355091288 -2239215.31105701, 99732.4551439306 -2239215.31105701, 99732.4551439306 -2239215.41110966, 99732.355091288 -2239215.41110966, 99732.355091288 -2239215.5111623, 99732.4551439306 -2239215.5111623, 99732.4551439306 -2239215.71126758, 99732.355091288 -2239215.71126758, 99732.355091288 -2239215.91137287, 99732.4551439306 -2239215.91137287, 99732.4551439306 -2239216.01142551, 99732.355091288 -2239216.01142551, 99732.355091288 -2239216.11147815, 99732.2550386455 -2239216.11147815, 99732.2550386455 -2239216.2115308, 99732.355091288 -2239216.2115308, 99732.355091288 -2239216.31158344, 99732.2550386455 -2239216.31158344, 99732.2550386455 -2239216.61174137, 99732.1549860029 -2239216.61174137, 99732.1549860029 -2239217.01195194, 99732.0549333603 -2239217.01195194, 99732.0549333603 -2239217.21205722, 99732.1549860029 -2239217.21205722, 99732.1549860029 -2239217.31210987, 99732.4551439306 -2239217.31210987, 997
32.4551439306 -2239217.41216251, 99732.5551965731 -2239217.41216251, 99732.5551965731 -2239217.31210987, 99732.7553018582 -2239217.31210987, 99732.7553018582 -2239217.41216251, 99732.8553545008 -2239217.41216251, 99732.8553545008 -2239217.51221515, 99732.9554071433 -2239217.51221515, 99732.9554071433 -2239217.31210987, 99733.1555124284 -2239217.31210987, 99733.1555124284 -2239217.41216251, 99733.255565071 -2239217.41216251, 99733.255565071 -2239217.31210987, 99733.4556703561 -2239217.31210987, 99733.4556703561 -2239217.41216251, 99733.5557229986 -2239217.41216251, 99733.5557229986 -2239217.31210987, 99733.6557756412 -2239217.31210987, 99733.6557756412 -2239217.21205722, 99733.8558809263 -2239217.21205722, 99733.8558809263 -2239217.11200458, 99733.9559335689 -2239217.11200458, 99733.9559335689 -2239217.01195194, 99734.0559862114 -2239217.01195194, 99734.0559862114 -2239217.21205722, 99734.156038854 -2239217.21205722, 99734.156038854 -2239217.11200458, 99734.2560914965 -223921
7.11200458, 99734.2560914965 -2239217.21205722, 99734.3561441391 -2239217.21205722, 99734.3561441391 -2239217.11200458, 99734.4561967816 -2239217.11200458, 99734.4561967816 -2239217.01195194, 99734.3561441391 -2239217.01195194, 99734.3561441391 -2239216.9118993, 99734.4561967816 -2239216.9118993, 99734.4561967816 -2239216.81184665, 99734.6563020667 -2239216.81184665, 99734.6563020667 -2239216.9118993, 99734.5562494242 -2239216.9118993, 99734.5562494242 -2239217.01195194, 99734.6563020667 -2239217.01195194, 99734.6563020667 -2239217.11200458, 99734.7563547093 -2239217.11200458, 99734.7563547093 -2239217.01195194, 99734.8564073518 -2239217.01195194, 99734.8564073518 -2239217.11200458, 99735.3566705646 -2239217.11200458, 99735.3566705646 -2239217.21205722, 99735.7568811348 -2239217.21205722, 99735.7568811348 -2239217.31210987, 99735.6568284923 -2239217.31210987, 99735.6568284923 -2239217.41216251, 99735.5567758497 -2239217.41216251, 99735.5567758497 -2239217.61226779, 99735.756
8811348 -2239217.61226779, 99735.7568811348 -2239217.71232044, 99735.9569864199 -2239217.71232044, 99735.9569864199 -2239218.01247836, 99735.8569337774 -2239218.01247836, 99735.8569337774 -2239218.11253101, 99735.9569864199 -2239218.11253101, 99735.9569864199 -2239218.21258365, 99736.0570390625 -2239218.21258365, 99736.0570390625 -2239218.41268893, 99735.9569864199 -2239218.41268893, 99735.9569864199 -2239218.61279422, 99736.0570390625 -2239218.61279422, 99736.0570390625 -2239218.71284686, 99735.9569864199 -2239218.71284686, 99735.9569864199 -2239218.8128995, 99736.0570390625 -2239218.8128995, 99736.0570390625 -2239218.91295215, 99736.3571969901 -2239218.91295215, 99736.3571969901 -2239219.01300479, 99736.4572496327 -2239219.01300479, 99736.4572496327 -2239219.11305743))
+ </a>
+ <test>
+ <op name="buffer" arg1="a" arg2="1.01">
+ POLYGON ((99724.5415116 -2239210.07866999,99724.5415116 -2239209.9082143,99724.5609185 -2239209.7111731,99724.6183933 -2239209.521704,99724.6415642 -2239209.4783543,99724.6415642 -2239209.4079511,99724.6609711 -2239209.2109099,99724.7184459 -2239209.0214408,99724.8094364244 -2239208.85120953,99724.8184986 -2239208.8213356,99724.9118326 -2239208.6467199,99725.037439 -2239208.493668,99725.0923925052 -2239208.44856881,99725.1374917 -2239208.3936153,99725.19244517 -2239208.34851617,99725.2375443 -2239208.2935627,99725.2924978955 -2239208.24846343,99725.337597 -2239208.19351,99725.39255036 -2239208.14841096,99725.4376496 -2239208.0934574,99725.4926031603 -2239208.04835816,99725.5377022 -2239207.9934048,99725.6907542 -2239207.8677983,99725.8653698 -2239207.7744643,99725.8952440723 -2239207.76540204,99726.0654751 -2239207.6744116,99726.2549442 -2239207.6169368,99726.4519854 -2239207.59753,99727.4525118 -2239207.59753,99727.5025381 -2239207.60245714,99727.5525644 -2239207.5975
3,99727.64407656 -2239207.59753,99727.6625504 -2239207.4099623,99727.7200252 -2239207.2204933,99727.8133592 -2239207.0458776,99727.9389657 -2239206.8928257,99727.9939189892 -2239206.84772668,99728.0390183 -2239206.792773,99728.09397177 -2239206.74767387,99728.1390709 -2239206.6927204,99728.1940245825 -2239206.64762109,99728.2391236 -2239206.5926678,99728.2940769089 -2239206.54756877,99728.3391762 -2239206.4926151,99728.4922281 -2239206.3670087,99728.6537698364 -2239206.28066278,99728.7923861 -2239206.1669034,99728.9670017 -2239206.0735694,99728.9968758442 -2239206.06450717,99729.167107 -2239205.9735167,99729.3528016278 -2239205.91718687,99729.3634453 -2239205.80912,99729.4209201 -2239205.619651,99729.5142541 -2239205.4450353,99729.6398606 -2239205.2919834,99729.6948141603 -2239205.24688416,99729.7399132 -2239205.1919308,99729.7948667052 -2239205.14683161,99729.8399659 -2239205.0918781,99729.9930178 -2239204.9662717,99730.1545592497 -2239204.87992594,99730.2931757 -2239204.76
61664,99730.4677914 -2239204.6728324,99730.4976652713 -2239204.66377026,99730.6678967 -2239204.5727797,99730.8573657 -2239204.5153049,99731.0180600617 -2239204.49947786,99731.0681072 -2239204.4727271,99731.2575763 -2239204.4152523,99731.4546175 -2239204.3958454,99731.5250206377 -2239204.3958454,99731.5683705 -2239204.3726744,99731.5982447981 -2239204.36361213,99731.7554017157 -2239204.27960999,99731.7959194991 -2239204.24635789,99731.8291718013 -2239204.2058398,99731.9155175 -2239204.0442983,99732.041124 -2239203.8912464,99732.0960776663 -2239203.84614711,99732.1411767 -2239203.7911938,99732.2942286 -2239203.6655873,99732.4688442 -2239203.5722533,99732.6583133 -2239203.5147785,99732.8553545 -2239203.4953716,99733.1555124 -2239203.4953716,99733.3525537 -2239203.5147785,99733.5420227 -2239203.5722533,99733.7122537168 -2239203.66324364,99733.742128 -2239203.6723059,99733.9167436 -2239203.76564,99734.0553600971 -2239203.8793995,99734.2125173287 -2239203.96340176,99734.2423912 -2
239203.9724639,99734.4126222168 -2239204.06345424,99734.4424965 -2239204.0725165,99734.5151443635 -2239204.1113476,99734.5531854 -2239204.1150943,99734.7426544 -2239204.1725691,99734.9172701 -2239204.2659032,99734.9669580798 -2239204.30668106,99735.0534486 -2239204.3151996,99735.2429176 -2239204.3726744,99735.4175333 -2239204.4660085,99735.5705852 -2239204.5916149,99735.6961917 -2239204.7446668,99735.7895257 -2239204.9192825,99735.8470005 -2239205.1087515,99735.8664074 -2239205.3057928,99735.8664074 -2239205.806056,99735.8470005 -2239206.0030972,99735.7895257 -2239206.1925662,99735.7871029413 -2239206.19709886,99735.9177965 -2239206.266956,99736.0708484 -2239206.3925625,99736.1964549 -2239206.5456144,99736.2897889 -2239206.7202301,99736.2988511704 -2239206.7501044,99736.3898415 -2239206.9203353,99736.4473163 -2239207.1098044,99736.4667232 -2239207.3068456,99736.4667232 -2239207.4068983,99736.4617960304 -2239207.4569246,99736.4667232 -2239207.5069509,99736.4667232 -2239207.57
735392,99736.4898942 -2239207.6207038,99736.547369 -2239207.8101729,99736.5631959389 -2239207.97086704,99736.5899468 -2239208.0209144,99736.6474216 -2239208.2103835,99736.6632486227 -2239208.37107766,99736.6899995 -2239208.421125,99736.7474743 -2239208.610594,99736.7668811 -2239208.8076352,99736.7668811 -2239208.87803829,99736.7900521 -2239208.9213882,99736.8475269 -2239209.1108572,99736.8512736244 -2239209.14889828,99736.8901047 -2239209.2215461,99736.9475796 -2239209.4110152,99736.951326291 -2239209.44905612,99736.9901574 -2239209.521704,99737.0329471384 -2239209.66276292,99737.0713748 -2239209.6942997,99737.1969813 -2239209.8473516,99737.2903153 -2239210.0219673,99737.3477901 -2239210.2114363,99737.367197 -2239210.4084775,99737.367197 -2239210.41124683,99737.3970866 -2239210.4476674,99737.4904206 -2239210.6222831,99737.5019722663 -2239210.66036386,99737.5186388 -2239210.6692723,99737.6716907 -2239210.7948787,99737.7167900108 -2239210.84983238,99737.7717433 -2239210.894931
4,99737.8168423337 -2239210.94988471,99737.8573605503 -2239210.98313714,99738.018902 -2239211.0694829,99738.1719539 -2239211.1950893,99738.2170533011 -2239211.25004306,99738.2720065 -2239211.295142,99738.3171054434 -2239211.3500952,99738.3720592 -2239211.3951946,99738.4976657 -2239211.5482465,99738.5909997 -2239211.7228622,99738.6484745 -2239211.9123312,99738.6678813 -2239212.1093725,99738.6678813 -2239212.2094251,99738.6484745 -2239212.4064663,99738.6081004414 -2239212.53956179,99738.61726363 -2239212.55072717,99738.6722171 -2239212.5958263,99738.7978236 -2239212.7488782,99738.8911576 -2239212.9234939,99738.9486324 -2239213.1129629,99738.9680393 -2239213.3100042,99738.9680393 -2239213.4100568,99738.9486324 -2239213.607098,99738.9021769824 -2239213.76024105,99738.9486324 -2239213.9133841,99738.9680393 -2239214.1104253,99738.9680393 -2239214.3105306,99738.9486324 -2239214.5075718,99738.8911576 -2239214.6970409,99738.7978236 -2239214.8716565,99738.6722171 -2239215.0247084,9973
8.6172637911 -2239215.06980743,99738.5721645 -2239215.1247611,99738.462257725 -2239215.21495922,99738.3720592 -2239215.3248664,99738.2190073 -2239215.4504728,99738.2014247057 -2239215.45987089,99738.2367425085 -2239215.57629807,99738.2621522445 -2239215.60725993,99738.3720592 -2239215.6974582,99738.462257725 -2239215.80736538,99738.5721645 -2239215.8975635,99738.5757227977 -2239215.9018993,99738.7584604 -2239215.9018993,99738.9555016 -2239215.9213062,99739.1449707 -2239215.978781,99739.3152014914 -2239216.06977127,99739.345076 -2239216.0788336,99739.5088552031 -2239216.16637542,99739.6726345 -2239216.0788336,99739.8621035 -2239216.0213588,99740.0591448 -2239216.0019519,99740.1591974 -2239216.0019519,99740.2092237 -2239216.00687907,99740.25925 -2239216.0019519,99740.3593027 -2239216.0019519,99740.5563439 -2239216.0213588,99740.745813 -2239216.0788336,99740.9204286 -2239216.1721676,99741.0734805 -2239216.2977741,99741.199087 -2239216.450826,99741.292421 -2239216.6254417,99741.
3498958 -2239216.8149107,99741.3693027 -2239217.0119519,99741.3693027 -2239217.2120572,99741.3498958 -2239217.4090984,99741.292421 -2239217.5985675,99741.26925 -2239217.64191741,99741.26925 -2239217.7123204,99741.2498432 -2239217.9093617,99741.1923684 -2239218.0988307,99741.0990344 -2239218.2734464,99740.9734279 -2239218.4264983,99740.820376 -2239218.5521047,99740.6457603 -2239218.6454388,99740.4562913 -2239218.7029136,99740.3869959453 -2239218.70973857,99740.373112 -2239218.7266562,99740.2200601 -2239218.8522627,99740.0454445 -2239218.9455967,99740.0155699914 -2239218.95465903,99739.8453392 -2239219.0456493,99739.6558701 -2239219.1031241,99739.5865749089 -2239219.10994909,99739.5726909 -2239219.1268668,99739.419639 -2239219.2524732,99739.2580975504 -2239219.33881896,99739.1194811 -2239219.4525785,99738.9448654 -2239219.5459125,99738.8038065828 -2239219.5887023,99738.7722698 -2239219.62713,99738.7173161175 -2239219.67222931,99738.6722171 -2239219.7271826,99738.5191652 -22392
19.8527891,99738.3445495 -2239219.9461231,99738.1550805 -2239220.0035979,99737.9580393 -2239220.0230048,99737.8876361623 -2239220.0230048,99737.8442863 -2239220.0461758,99737.6548173 -2239220.1036506,99737.4941231253 -2239220.11947754,99737.4440758 -2239220.1462284,99737.2546067 -2239220.2037032,99737.0575655 -2239220.2231101,99736.9575128 -2239220.2231101,99736.7604716 -2239220.2037032,99736.5710026 -2239220.1462284,99736.5276526912 -2239220.1230574,99736.4572496 -2239220.1230574,99736.2602084 -2239220.1036506,99736.0707394 -2239220.0461758,99735.8961237 -2239219.9528417,99735.8220170434 -2239219.89202396,99735.6705288 -2239219.8460705,99735.4959131 -2239219.7527365,99735.3428612 -2239219.62713,99735.29776207 -2239219.57217653,99735.2428086 -2239219.5270774,99735.1172021 -2239219.3740254,99735.0238681 -2239219.1994098,99734.9663933 -2239219.0099407,99734.9469864 -2239218.8128995,99734.9469864 -2239218.7128469,99734.9519135732 -2239218.66282054,99734.9469864 -2239218.6127942
,99734.9469864 -2239218.54239114,99734.9238154 -2239218.4990413,99734.8810256616 -2239218.35798238,99734.842598 -2239218.3264456,99734.7169915 -2239218.1733937,99734.7075934665 -2239218.15581122,99734.5531854 -2239218.2026504,99734.3561441 -2239218.2220572,99734.2560915 -2239218.2220572,99734.2060652 -2239218.21713006,99734.1560389 -2239218.2220572,99734.153269497 -2239218.2220572,99734.1168489 -2239218.2519468,99733.9422333 -2239218.3452808,99733.7527642 -2239218.4027556,99733.555723 -2239218.4221625,99733.4556704 -2239218.4221625,99733.3962216239 -2239218.4163073,99733.3419174 -2239218.4453335,99733.1524484 -2239218.5028083,99732.9554071 -2239218.5222152,99732.8553545 -2239218.5222152,99732.6583133 -2239218.5028083,99732.4688442 -2239218.4453335,99732.4187968324 -2239218.41858262,99732.2581027 -2239218.4027556,99732.0686337 -2239218.3452808,99731.9959858341 -2239218.30644972,99731.9579448 -2239218.302703,99731.7684757 -2239218.2452282,99731.5938601 -2239218.1518942,99731.4
408082 -2239218.0262877,99731.3957091663 -2239217.97133439,99731.3407555 -2239217.9262351,99731.2151491 -2239217.7731832,99731.121815 -2239217.5985675,99731.0643402 -2239217.4090984,99731.0449334 -2239217.2120572,99731.0449334 -2239217.0119519,99731.0643402 -2239216.8149107,99731.121815 -2239216.6254417,99731.1485658751 -2239216.57539437,99731.1643929 -2239216.4147001,99731.2218677 -2239216.2252311,99731.2450386 -2239216.18188138,99731.2450386 -2239216.1114782,99731.2644455 -2239215.9144369,99731.3219203 -2239215.7249679,99731.3486711837 -2239215.6749205,99731.354945644 -2239215.61121495,99731.3486711837 -2239215.5475094,99731.3219203 -2239215.497462,99731.3128580278 -2239215.4675877,99731.2218677 -2239215.2973567,99731.2128054311 -2239215.26748241,99731.121815 -2239215.0972514,99731.1127527279 -2239215.0673771,99731.0217624 -2239214.8971461,99730.9642876 -2239214.7076771,99730.9484605738 -2239214.5469829,99730.9286978954 -2239214.51000958,99730.8149385 -2239214.3713933,9973
0.7377477001 -2239214.22697941,99730.5977179188 -2239214.15213197,99730.567844 -2239214.1430698,99730.3932284 -2239214.0497358,99730.3191216666 -2239213.98891804,99730.1676335 -2239213.9429646,99729.997402493 -2239213.85197417,99729.9675282 -2239213.8429119,99729.9174808437 -2239213.81616104,99729.7567866 -2239213.8003341,99729.5673176 -2239213.7428593,99729.4946695048 -2239213.7040281,99729.4566287 -2239213.7002814,99729.2671597 -2239213.6428066,99729.092544 -2239213.5494726,99728.9394921 -2239213.4238662,99728.8943929214 -2239213.36891268,99728.8394394 -2239213.3238135,99728.79434027 -2239213.26886003,99728.7393868 -2239213.2237609,99728.6461920537 -2239213.11020282,99728.5530909 -2239213.1193725,99728.4530382 -2239213.1193725,99728.255997 -2239213.0999656,99728.066528 -2239213.0424908,99728.0231780912 -2239213.0193198,99727.8527224 -2239213.0193198,99727.6556811 -2239212.9999129,99727.4662121 -2239212.9424381,99727.2959810832 -2239212.85144776,99727.2661068 -2239212.84238
55,99727.0958760086 -2239212.75139523,99727.0660015 -2239212.7423329,99726.8913859 -2239212.6489988,99726.738334 -2239212.5233924,99726.6932348052 -2239212.4684389,99726.6382813 -2239212.4233397,99726.5126749 -2239212.2702878,99726.4789537659 -2239212.20720004,99726.4657947 -2239212.2232344,99726.3127428 -2239212.3488409,99726.1381271 -2239212.4421749,99725.9486581 -2239212.4996497,99725.7516169 -2239212.5190566,99725.6515642 -2239212.5190566,99725.454523 -2239212.4996497,99725.265054 -2239212.4421749,99725.0904383 -2239212.3488409,99724.9373864 -2239212.2232344,99724.8922873825 -2239212.16828111,99724.8373337 -2239212.1231818,99724.7117273 -2239211.9701299,99724.6183933 -2239211.7955142,99724.6093311591 -2239211.76564033,99724.5183406 -2239211.5954089,99724.4608658 -2239211.4059399,99724.441459 -2239211.2088987,99724.441459 -2239210.5085302,99724.4608658 -2239210.3114889,99724.5183406 -2239210.1220199,99724.5415116 -2239210.07866999))
+ </op>
+ </test>
+</case>
+</run>
More information about the geos-commits
