[geos-commits] r3605 - in trunk: . include/geos/precision
src/precision tests/unit tests/unit/precision
svn_geos at osgeo.org
Tue Apr 10 04:38:19 EDT 2012
Author: strk
Date: 2012-04-10 01:38:18 -0700 (Tue, 10 Apr 2012)
New Revision: 3605
Added:
trunk/include/geos/precision/GeometryPrecisionReducer.h
trunk/include/geos/precision/PrecisionReducerCoordinateOperation.h
trunk/src/precision/GeometryPrecisionReducer.cpp
trunk/src/precision/PrecisionReducerCoordinateOperation.cpp
trunk/tests/unit/precision/GeometryPrecisionReducerTest.cpp
trunk/NEWS
trunk/include/geos/precision/Makefile.am
trunk/src/precision/Makefile.am
trunk/src/precision/SimpleGeometryPrecisionReducer.cpp
trunk/tests/unit/Makefile.am
Port GeometryPrecisionReducer, include testcase
Modified: trunk/NEWS
--- trunk/NEWS 2012-04-06 19:04:01 UTC (rev 3604)
+++ trunk/NEWS 2012-04-10 08:38:18 UTC (rev 3605)
@@ -3,6 +3,7 @@
- New things:
- CAPI: GEOSNode (#496)
+ - GeometryPrecisionReducer class
- C++ API changes:
- New noding::GeometryNoder class
- Added BufferOp::setSingleSided
Added: trunk/include/geos/precision/GeometryPrecisionReducer.h
--- trunk/include/geos/precision/GeometryPrecisionReducer.h (rev 0)
+++ trunk/include/geos/precision/GeometryPrecisionReducer.h 2012-04-10 08:38:18 UTC (rev 3605)
@@ -0,0 +1,159 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2012 Sandro Santilli <strk at keybit.net>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: precision/GeometryPrecisionReducer.cpp rev. 1.10 (JTS-1.7)
+#ifndef GEOS_PRECISION_GEOMETRYPRECISIONREDUCER_H
+#define GEOS_PRECISION_GEOMETRYPRECISIONREDUCER_H
+#include <geos/export.h>
+#include <memory> // for auto_ptr
+// Forward declarations
+namespace geos {
+ namespace geom {
+ class PrecisionModel;
+ class GeometryFactory;
+ class Geometry;
+namespace geos {
+namespace precision { // geos.precision
+/** \brief
+ * Reduces the precision of a {@link Geometry}
+ * according to the supplied {@link PrecisionModel},
+ * ensuring that the result is topologically valid.
+class GEOS_DLL GeometryPrecisionReducer {
+private:
+ // Externally owned
+ const geom::GeometryFactory *newFactory;
+ const geom::PrecisionModel &targetPM;
+ bool removeCollapsed;
+ bool isPointwise;
+ std::auto_ptr<geom::Geometry> reducePointwise( const geom::Geometry& geom );
+ std::auto_ptr<geom::Geometry> fixPolygonalTopology(
+ const geom::Geometry& geom );
+ std::auto_ptr<geom::GeometryFactory> createFactory(
+ const geom::GeometryFactory& oldGF,
+ const geom::PrecisionModel& newPM );
+public:
+ * Convenience method for doing precision reduction
+ * on a single geometry,
+ * with collapses removed
+ * and keeping the geometry precision model the same,
+ * and preserving polygonal topology.
+ * @param g the geometry to reduce
+ * @param precModel the precision model to use
+ * @return the reduced geometry
+ static std::auto_ptr<geom::Geometry> reduce(
+ const geom::Geometry &g,
+ const geom::PrecisionModel &precModel )
+ GeometryPrecisionReducer reducer(precModel);
+ return reducer.reduce(g);
+ * but NOT preserving valid polygonal topology.
+ static std::auto_ptr<geom::Geometry> reducePointwise(
+ reducer.setPointwise(true);
+ GeometryPrecisionReducer(const geom::PrecisionModel &pm)
+ newFactory(0),
+ targetPM(pm),
+ removeCollapsed(true),
+ isPointwise(false)
+ * \brief
+ * Create a reducer that will change the precision model of the
+ * new reduced Geometry
+ * @param gf the factory for the created Geometry.
+ * Its PrecisionModel will be used for the reduction.
+ * NOTE: ownership left to caller must be kept alive for
+ * the whole lifetime of the returned Geometry.
+ GeometryPrecisionReducer(const geom::GeometryFactory &gf);
+ * Sets whether the reduction will result in collapsed components
+ * being removed completely, or simply being collapsed to an (invalid)
+ * Geometry of the same type.
+ * @param remove if <code>true</code> collapsed components will be removed
+ void setRemoveCollapsedComponents(bool remove) {
+ removeCollapsed = remove;
+ /** \brief
+ * Sets whether the precision reduction will be done
+ * in pointwise fashion only.
+ * Pointwise precision reduction reduces the precision
+ * of the individual coordinates only, but does
+ * not attempt to recreate valid topology.
+ * This is only relevant for geometries containing polygonal components.
+ * @param pointwise if reduction should be done pointwise only
+ void setPointwise(bool pointwise)
+ isPointwise = pointwise;
+ std::auto_ptr<geom::Geometry> reduce(const geom::Geometry& geom);
+} // namespace geos.precision
+#endif // GEOS_PRECISION_GEOMETRYPRECISIONREDUCER_H
Modified: trunk/include/geos/precision/Makefile.am
--- trunk/include/geos/precision/Makefile.am 2012-04-06 19:04:01 UTC (rev 3604)
+++ trunk/include/geos/precision/Makefile.am 2012-04-10 08:38:18 UTC (rev 3605)
@@ -12,4 +12,6 @@
CommonBitsOp.h \
CommonBitsRemover.h \
EnhancedPrecisionOp.h \
+ GeometryPrecisionReducer.h \
+ PrecisionReducerCoordinateOperation.h \
SimpleGeometryPrecisionReducer.h
Added: trunk/include/geos/precision/PrecisionReducerCoordinateOperation.h
--- trunk/include/geos/precision/PrecisionReducerCoordinateOperation.h (rev 0)
+++ trunk/include/geos/precision/PrecisionReducerCoordinateOperation.h 2012-04-10 08:38:18 UTC (rev 3605)
@@ -0,0 +1,66 @@
+ * Last port: precision/PrecisionreducerCoordinateOperation.java r591 (JTS-1.12)
+#ifndef GEOS_PRECISION_PRECISIONREDUCERCOORDINATEOPERATION_H
+#define GEOS_PRECISION_PRECISIONREDUCERCOORDINATEOPERATION_H
+#include <geos/geom/util/CoordinateOperation.h>
+namespace geos {
+ namespace geom {
+ class CoordinateSequence;
+ class Geometry;
+namespace geos {
+class PrecisionReducerCoordinateOperation :
+ public geom::util::CoordinateOperation
+using CoordinateOperation::edit;
+private:
+ const geom::PrecisionModel& targetPM;
+public:
+ PrecisionReducerCoordinateOperation( const geom::PrecisionModel& pm,
+ bool doRemoveCollapsed )
+ targetPM(pm),
+ removeCollapsed(doRemoveCollapsed)
+ /// Ownership of returned CoordinateSequence to caller
+ /// virtual function
+ geom::CoordinateSequence* edit(const geom::CoordinateSequence *coordinates,
+ const geom::Geometry *geom);
+#endif // GEOS_PRECISION_PRECISIONREDUCERCOORDINATEOPERATION_H
Added: trunk/src/precision/GeometryPrecisionReducer.cpp
--- trunk/src/precision/GeometryPrecisionReducer.cpp (rev 0)
+++ trunk/src/precision/GeometryPrecisionReducer.cpp 2012-04-10 08:38:18 UTC (rev 3605)
@@ -0,0 +1,145 @@
+ * Copyright (C) 2005-2006 Refractions Research Inc.
+ * Copyright (C) 2001-2002 Vivid Solutions Inc.
+#include <geos/precision/GeometryPrecisionReducer.h>
+#include <geos/precision/PrecisionReducerCoordinateOperation.h>
+#include <geos/geom/util/GeometryEditor.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/CoordinateSequenceFactory.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/LinearRing.h>
+#include <vector>
+#include <typeinfo>
+using namespace std;
+using namespace geos::geom;
+using namespace geos::geom::util;
+namespace geos {
+/* private */
+auto_ptr<Geometry>
+GeometryPrecisionReducer::reducePointwise(const Geometry &geom)
+ auto_ptr<GeometryEditor> geomEdit;
+ if ( newFactory ) {
+ geomEdit.reset( new GeometryEditor(newFactory) );
+ } else {
+ geomEdit.reset( new GeometryEditor() );
+ * For polygonal geometries, collapses are always removed, in order
+ * to produce correct topology
+ bool finalRemoveCollapsed = removeCollapsed;
+ if (geom.getDimension() >= 2)
+ finalRemoveCollapsed = true;
+ PrecisionReducerCoordinateOperation prco(targetPM, finalRemoveCollapsed);
+ std::auto_ptr<Geometry> g ( geomEdit->edit(&geom, &prco) );
+ return g;
+/* public */
+auto_ptr<Geometry>
+GeometryPrecisionReducer::reduce(const Geometry &geom)
+ auto_ptr<Geometry> reducePW = reducePointwise(geom);
+ if ( isPointwise ) return reducePW;
+ //TODO: handle GeometryCollections containing polys
+ if (! (dynamic_cast<const Polygonal*>(reducePW.get())) )
+ return reducePW;
+ // Geometry is polygonal - test if topology needs to be fixed
+ if (reducePW->isValid()) return reducePW;
+ // hack to fix topology.
+ // TODO: implement snap-rounding and use that.
+ return fixPolygonalTopology(*reducePW);
+/* public */
+GeometryPrecisionReducer::GeometryPrecisionReducer(const GeometryFactory &changeFactory)
+ newFactory(&changeFactory),
+ targetPM(*(changeFactory.getPrecisionModel())),
+/* private */
+auto_ptr<Geometry>
+GeometryPrecisionReducer::fixPolygonalTopology(const geom::Geometry& geom )
+ * If precision model was *not* changed, need to flip
+ * geometry to targetPM, buffer in that model, then flip back
+ auto_ptr<Geometry> tmp;
+ auto_ptr<GeometryFactory> tmpFactory;
+ const Geometry* geomToBuffer = &geom;
+ if ( ! newFactory ) {
+ tmpFactory = createFactory(*geom.getFactory(), targetPM);
+ tmp.reset( tmpFactory->createGeometry(&geom) );
+ geomToBuffer = tmp.get();
+ auto_ptr<Geometry> bufGeom ( geomToBuffer->buffer(0) );
+ // a slick way to copy the geometry with the original precision factory
+ bufGeom.reset( geom.getFactory()->createGeometry(bufGeom.get()) );
+ return bufGeom;
+/* private */
+auto_ptr<GeometryFactory>
+GeometryPrecisionReducer::createFactory( const GeometryFactory& oldGF,
+ const PrecisionModel& newPM )
+ auto_ptr<GeometryFactory> newFactory(
+ new GeometryFactory(&newPM,
+ oldGF.getSRID(),
+ const_cast<CoordinateSequenceFactory*>(oldGF.getCoordinateSequenceFactory()))
+ return newFactory;
Modified: trunk/src/precision/Makefile.am
--- trunk/src/precision/Makefile.am 2012-04-06 19:04:01 UTC (rev 3604)
+++ trunk/src/precision/Makefile.am 2012-04-10 08:38:18 UTC (rev 3605)
@@ -12,6 +12,8 @@
CommonBitsOp.cpp \
CommonBitsRemover.cpp \
EnhancedPrecisionOp.cpp \
+ GeometryPrecisionReducer.cpp \
+ PrecisionReducerCoordinateOperation.cpp \
libprecision_la_LIBADD =
Added: trunk/src/precision/PrecisionReducerCoordinateOperation.cpp
--- trunk/src/precision/PrecisionReducerCoordinateOperation.cpp (rev 0)
+++ trunk/src/precision/PrecisionReducerCoordinateOperation.cpp 2012-04-10 08:38:18 UTC (rev 3605)
@@ -0,0 +1,97 @@
+#include <geos/geom/Geometry.h>
+#include <vector>
+namespace geos {
+CoordinateSequence*
+PrecisionReducerCoordinateOperation::edit(const CoordinateSequence *cs,
+ const Geometry *geom)
+ unsigned int csSize = cs->getSize();
+ if ( csSize == 0 ) return NULL;
+ vector<Coordinate> *vc = new vector<Coordinate>(csSize);
+ // copy coordinates and reduce
+ for (unsigned int i=0; i<csSize; ++i) {
+ Coordinate coord=cs->getAt(i);
+ targetPM.makePrecise(&coord);
+ (*vc)[i] = coord;
+ // reducedCoords take ownership of 'vc'
+ CoordinateSequence *reducedCoords =
+ geom->getFactory()->getCoordinateSequenceFactory()->create(vc);
+ // remove repeated points, to simplify returned geometry as
+ // much as possible.
+ CoordinateSequence *noRepeatedCoords=CoordinateSequence::removeRepeatedPoints(reducedCoords);
+ * Check to see if the removal of repeated points
+ * collapsed the coordinate List to an invalid length
+ * for the type of the parent geometry.
+ * It is not necessary to check for Point collapses,
+ * since the coordinate list can
+ * never collapse to less than one point.
+ * If the length is invalid, return the full-length coordinate array
+ * first computed, or null if collapses are being removed.
+ * (This may create an invalid geometry - the client must handle this.)
+ unsigned int minLength = 0;
+ if ( dynamic_cast<const LineString*>(geom) ) minLength = 2;
+ if ( dynamic_cast<const LinearRing*>(geom) ) minLength = 4;
+ CoordinateSequence *collapsedCoords = reducedCoords;
+ if ( removeCollapsed )
+ delete reducedCoords; reducedCoords=0;
+ collapsedCoords=0;
+ // return null or orginal length coordinate array
+ if ( noRepeatedCoords->getSize() < minLength ) {
+ delete noRepeatedCoords;
+ return collapsedCoords;
+ // ok to return shorter coordinate array
+ return noRepeatedCoords;
Modified: trunk/src/precision/SimpleGeometryPrecisionReducer.cpp
--- trunk/src/precision/SimpleGeometryPrecisionReducer.cpp 2012-04-06 19:04:01 UTC (rev 3604)
+++ trunk/src/precision/SimpleGeometryPrecisionReducer.cpp 2012-04-10 08:38:18 UTC (rev 3605)
@@ -38,6 +38,8 @@
namespace geos {
+namespace {
@@ -119,6 +121,7 @@
+} // anonymous namespace
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2012-04-06 19:04:01 UTC (rev 3604)
+++ trunk/tests/unit/Makefile.am 2012-04-10 08:38:18 UTC (rev 3605)
@@ -97,6 +97,7 @@
operation/valid/ValidClosedRingTest.cpp \
operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp \
precision/SimpleGeometryPrecisionReducerTest.cpp \
+ precision/GeometryPrecisionReducerTest.cpp \
simplify/DouglasPeuckerSimplifierTest.cpp \
simplify/TopologyPreservingSimplifierTest.cpp \
util/UniqueCoordinateArrayFilterTest.cpp \
Added: trunk/tests/unit/precision/GeometryPrecisionReducerTest.cpp
--- trunk/tests/unit/precision/GeometryPrecisionReducerTest.cpp (rev 0)
+++ trunk/tests/unit/precision/GeometryPrecisionReducerTest.cpp 2012-04-10 08:38:18 UTC (rev 3605)
@@ -0,0 +1,193 @@
+// $Id$
+// Test Suite for geos::precision::GeometryPrecisionReducer class.
+// tut
+#include <tut.hpp>
+// geos
+#include <geos/io/WKTReader.h>
+// std
+#include <string>
+#include <vector>
+#include <iostream>
+namespace tut
+ // Test Group
+ // Common data used by tests
+ struct test_gpr_data
+ typedef std::auto_ptr<geos::geom::Geometry> GeometryPtr;
+ geos::geom::PrecisionModel pm_float_;
+ geos::geom::PrecisionModel pm_fixed_;
+ geos::geom::GeometryFactory factory_;
+ geos::geom::GeometryFactory factory_fixed_;
+ geos::io::WKTReader reader_;
+ geos::precision::GeometryPrecisionReducer reducer_;
+ geos::precision::GeometryPrecisionReducer reducerKeepCollapse_; // keep collapse
+ geos::precision::GeometryPrecisionReducer reducerChangePM_; // change precision model
+ test_gpr_data() :
+ pm_float_(),
+ pm_fixed_(1),
+ factory_(&pm_float_, 0),
+ factory_fixed_(&pm_fixed_, 0),
+ reader_(&factory_),
+ reducer_(pm_fixed_),
+ reducerKeepCollapse_(pm_fixed_),
+ reducerChangePM_(factory_fixed_)
+ reducerKeepCollapse_.setRemoveCollapsedComponents(false);
+ typedef test_group<test_gpr_data> group;
+ typedef group::object object;
+ group test_gpr_group("geos::precision::GeometryPrecisionReducer");
+ // Test Cases
+ // Test square
+ template<>
+ template<>
+ void object::test<1>()
+ GeometryPtr g1(reader_.read("POLYGON (( 0 0, 0 1.4, 1.4 1.4, 1.4 0, 0 0 ))"));
+ GeometryPtr g2(reader_.read("POLYGON (( 0 0, 0 1, 1 1, 1 0, 0 0 ))"));
+ GeometryPtr result(reducer_.reduce(*g1));
+ ensure( result->equalsExact(g2.get()) );
+ ensure( result->getFactory() == g2->getFactory() );
+ // Test tiny square collapse
+ template<>
+ template<>
+ void object::test<2>()
+ GeometryPtr g1(reader_.read("POLYGON (( 0 0, 0 .4, .4 .4, .4 0, 0 0 ))"));
+ GeometryPtr g2(reader_.read("POLYGON EMPTY"));
+ // Test square collapse
+ template<>
+ template<>
+ void object::test<3>()
+ GeometryPtr g1(reader_.read("POLYGON (( 0 0, 0 1.4, .4 .4, .4 0, 0 0 ))"));
+ // Test square keep collapse
+ template<>
+ template<>
+ void object::test<4>()
+ GeometryPtr result(reducerKeepCollapse_.reduce(*g1));
+ // Test line
+ template<>
+ template<>
+ void object::test<5>()
+ GeometryPtr g1(reader_.read("LINESTRING ( 0 0, 0 1.4 )"));
+ GeometryPtr g2(reader_.read("LINESTRING (0 0, 0 1)"));
+ // Test line remove collapse
+ template<>
+ template<>
+ void object::test<6>()
+ GeometryPtr g1(reader_.read("LINESTRING ( 0 0, 0 .4 )"));
+ GeometryPtr g2(reader_.read("LINESTRING EMPTY"));
+ // Test line keep collapse
+ template<>
+ template<>
+ void object::test<7>()
+ GeometryPtr g2(reader_.read("LINESTRING ( 0 0, 0 0 )"));
+ // Test square with changed PM
+ template<>
+ template<>
+ void object::test<8>()
+ GeometryPtr result(reducerChangePM_.reduce(*g1));
+ ensure( result->getFactory() == &factory_fixed_ );
+ // Test points with changed PM
+ template<>
+ template<>
+ void object::test<9>()
+ GeometryPtr g1(reader_.read("MULTIPOINT ((0 0), (0 1.4), (1.4 1.4), (1.4 0), (0.9 0) ))"));
+ GeometryPtr g2(reader_.read("MULTIPOINT ((0 0), (0 1), (1 1), (1 0), (1 0) ))"));
+} // namespace tut
More information about the geos-commits
