[geos-commits] r3606 - in branches/3.3: . include/geos/geom
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Apr 10 11:02:24 EDT 2012
Author: strk
Date: 2012-04-10 08:02:23 -0700 (Tue, 10 Apr 2012)
New Revision: 3606
   branches/3.3/NEWS
   branches/3.3/include/geos/geom/BinaryOp.h
Reduce CommonBitsRemover harmful effects during overlay op (#527)
Modified: branches/3.3/NEWS
--- branches/3.3/NEWS	2012-04-10 08:38:18 UTC (rev 3605)
+++ branches/3.3/NEWS	2012-04-10 15:02:23 UTC (rev 3606)
@@ -2,7 +2,7 @@
 2012-??-??
 - Bug fixes / improvements
+    - Reduce CommonBitsRemover harmful effects during overlay op (#527)
 Changes in 3.3.3
 2012-04-01
Modified: branches/3.3/include/geos/geom/BinaryOp.h
--- branches/3.3/include/geos/geom/BinaryOp.h	2012-04-10 08:38:18 UTC (rev 3605)
+++ branches/3.3/include/geos/geom/BinaryOp.h	2012-04-10 15:02:23 UTC (rev 3606)
@@ -154,32 +154,10 @@
 /* A single component may become a multi component */
 inline std::auto_ptr<Geometry>
-fix_snap_collapses(std::auto_ptr<Geometry> g, const std::string& label)
+fix_self_intersections(std::auto_ptr<Geometry> g, const std::string& label)
-  // Areal geometries may become self-intersecting on snapping
-  if ( g->getGeometryTypeId() == GEOS_POLYGON ||
-       g->getGeometryTypeId() == GEOS_MULTIPOLYGON )
-    // TODO: use only ConsistentAreaTester
-    if ( ! check_valid(*g, label) ) {
-#if GEOS_DEBUG_BINARYOP
-      std::cerr << label << ": self-unioning" << std::endl;
-#endif
-      g = g->Union();
-      std::stringstream ss;
-      ss << label << " self-unioned";
-      check_valid(*g, ss.str());
-#endif
-  // TODO: check linear collapses ? (!isSimple)
-  return g;
+  // TODO: check for presence of self-intersections first ?
+  return g->Union();
@@ -234,14 +212,13 @@
 	GeometrySnapper snapper0( operand0 );
 	GeomPtr snapG0( snapper0.snapTo(operand1, snapTolerance) );
-	snapG0 = fix_snap_collapses(snapG0, "SNAP: snapped geom 0");
+	snapG0 = fix_self_intersections(snapG0, "SNAP: snapped geom 0");
 	// NOTE: second geom is snapped on the snapped first one
 	GeometrySnapper snapper1( operand1 );
 	GeomPtr snapG1( snapper1.snapTo(*snapG0, snapTolerance) );
-	snapG1 = fix_snap_collapses(snapG1, "SNAP: snapped geom 1");
+	snapG1 = fix_self_intersections(snapG1, "SNAP: snapped geom 1");
 	// Run the binary op
 	GeomPtr result( _Op(snapG0.get(), snapG1.get()) );
@@ -252,6 +229,7 @@
 #if CBR_BEFORE_SNAPPING
 	// Add common bits back in
 	cbr.addCommonBits( result.get() );
+	result = fix_self_intersections(result, "SNAP: result (after common-bits addition)");
 #endif
@@ -287,6 +265,13 @@
 		std::cerr << "Original exception: " << ex.what() << std::endl;
 #endif
+//#if GEOS_DEBUG_BINARYOP
+  // Should we just give up here ?
+  check_valid(*g0, "Input geom 0");
+  check_valid(*g1, "Input geom 1");
+//#endif
 #endif // USE_ORIGINAL_INPUT
@@ -328,9 +313,16 @@
 		cbr.addCommonBits( ret.get() );
-		check_valid(*ret, "CBR: result (before common-bits addition)");
+		check_valid(*ret, "CBR: result (after common-bits addition)");
 #endif
+		// Common-bits removal policy could introduce self-intersections
+		ret = fix_self_intersections(ret, "CBR: result (after common-bits addition)");
+#if GEOS_DEBUG_BINARYOP
+		check_valid(*ret, "CBR: result (after common-bits addition and fix_self_intersections)");
+#endif
 #if GEOS_CHECK_COMMONBITS_VALIDITY
 		// check that result is a valid geometry after the
 		// reshift to orginal precision (see EnhancedPrecisionOp)
More information about the geos-commits mailing list
