[geos-commits] r3607 - trunk/include/geos/geom
svn_geos at osgeo.org
Tue Apr 10 11:04:31 EDT 2012
Author: strk
Date: 2012-04-10 08:04:30 -0700 (Tue, 10 Apr 2012)
New Revision: 3607
trunk/include/geos/geom/BinaryOp.h
Reduce CommonBitsRemover harmful effects during overlay op (#527)
Modified: trunk/include/geos/geom/BinaryOp.h
--- trunk/include/geos/geom/BinaryOp.h 2012-04-10 15:02:23 UTC (rev 3606)
+++ trunk/include/geos/geom/BinaryOp.h 2012-04-10 15:04:30 UTC (rev 3607)
@@ -153,32 +153,10 @@
/* A single component may become a multi component */
inline std::auto_ptr<Geometry>
-fix_snap_collapses(std::auto_ptr<Geometry> g, const std::string& label)
+fix_self_intersections(std::auto_ptr<Geometry> g, const std::string& label)
- // Areal geometries may become self-intersecting on snapping
- if ( g->getGeometryTypeId() == GEOS_POLYGON ||
- g->getGeometryTypeId() == GEOS_MULTIPOLYGON )
- // TODO: use only ConsistentAreaTester
- if ( ! check_valid(*g, label) ) {
-#if GEOS_DEBUG_BINARYOP
- std::cerr << label << ": self-unioning" << std::endl;
-#endif
- g = g->Union();
- std::stringstream ss;
- ss << label << " self-unioned";
- check_valid(*g, ss.str());
-#endif
- // TODO: check linear collapses ? (!isSimple)
- return g;
+ // TODO: check for presence of self-intersections first ?
+ return g->Union();
@@ -233,14 +211,13 @@
GeometrySnapper snapper0( operand0 );
GeomPtr snapG0( snapper0.snapTo(operand1, snapTolerance) );
- snapG0 = fix_snap_collapses(snapG0, "SNAP: snapped geom 0");
+ snapG0 = fix_self_intersections(snapG0, "SNAP: snapped geom 0");
// NOTE: second geom is snapped on the snapped first one
GeometrySnapper snapper1( operand1 );
GeomPtr snapG1( snapper1.snapTo(*snapG0, snapTolerance) );
- snapG1 = fix_snap_collapses(snapG1, "SNAP: snapped geom 1");
+ snapG1 = fix_self_intersections(snapG1, "SNAP: snapped geom 1");
// Run the binary op
GeomPtr result( _Op(snapG0.get(), snapG1.get()) );
@@ -251,6 +228,7 @@
#if CBR_BEFORE_SNAPPING
// Add common bits back in
cbr.addCommonBits( result.get() );
+ result = fix_self_intersections(result, "SNAP: result (after common-bits addition)");
#endif
@@ -286,6 +264,13 @@
std::cerr << "Original exception: " << ex.what() << std::endl;
#endif
+//#if GEOS_DEBUG_BINARYOP
+ // Should we just give up here ?
+ check_valid(*g0, "Input geom 0");
+ check_valid(*g1, "Input geom 1");
+//#endif
#endif // USE_ORIGINAL_INPUT
@@ -327,9 +312,16 @@
cbr.addCommonBits( ret.get() );
- check_valid(*ret, "CBR: result (before common-bits addition)");
+ check_valid(*ret, "CBR: result (after common-bits addition)");
#endif
+ // Common-bits removal policy could introduce self-intersections
+ ret = fix_self_intersections(ret, "CBR: result (after common-bits addition)");
+#if GEOS_DEBUG_BINARYOP
+ check_valid(*ret, "CBR: result (after common-bits addition and fix_self_intersections)");
+#endif
#if GEOS_CHECK_COMMONBITS_VALIDITY
// check that result is a valid geometry after the
// reshift to orginal precision (see EnhancedPrecisionOp)
More information about the geos-commits
