[geos-commits] r3671 - in trunk: capi tests/unit/capi
svn_geos at osgeo.org
Thu Jun 7 08:10:21 PDT 2012
Author: strk
Date: 2012-06-07 08:10:18 -0700 (Thu, 07 Jun 2012)
New Revision: 3671
trunk/capi/geos_ts_c.cpp
trunk/tests/unit/capi/GEOSInterruptTest.cpp
Revert the interrupt request callback reset on initGEOS
Once you set a callback why would you want it unregistered on
initGEOS ? You will not want that....
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2012-06-07 14:41:32 UTC (rev 3670)
+++ trunk/capi/geos_ts_c.cpp 2012-06-07 15:10:18 UTC (rev 3671)
@@ -209,7 +209,6 @@
geos::util::Interrupt::cancel();
- geos::util::Interrupt::registerCallback(0,0);
return static_cast<GEOSContextHandle_t>(extHandle);
Modified: trunk/tests/unit/capi/GEOSInterruptTest.cpp
--- trunk/tests/unit/capi/GEOSInterruptTest.cpp 2012-06-07 14:41:32 UTC (rev 3670)
+++ trunk/tests/unit/capi/GEOSInterruptTest.cpp 2012-06-07 15:10:18 UTC (rev 3671)
@@ -99,7 +99,7 @@
finishGEOS();
- /// Test interrupt callback being reset by initGEOS
+ /// Test interrupt callback being NOT reset by initGEOS
template<>
template<>
void object::test<2>()
@@ -120,7 +120,7 @@
ensure("GEOSBufferWithStyle failed", 0 != geom2);
- ensure_equals(numcalls, 0);
+ ensure("interrupt callback never called", numcalls > 0);
GEOSGeom_destroy(geom1);
GEOSGeom_destroy(geom2);
More information about the geos-commits
