[geos-commits] r3672 - in trunk: capi include/geos/util src/util tests/unit/capi
svn_geos at osgeo.org
Thu Jun 7 08:11:08 PDT 2012
Author: strk
Date: 2012-06-07 08:11:06 -0700 (Thu, 07 Jun 2012)
New Revision: 3672
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/include/geos/util/Interrupt.h
trunk/src/util/Interrupt.cpp
trunk/tests/unit/capi/GEOSInterruptTest.cpp
Allow chaining interrupt callbacks, drop arg parameter
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2012-06-07 15:10:18 UTC (rev 3671)
+++ trunk/capi/geos_c.cpp 2012-06-07 15:11:06 UTC (rev 3672)
@@ -115,10 +115,10 @@
-void
-GEOS_interruptRegisterCallback(GEOSInterruptCallback* cb, void *cbarg)
+GEOSInterruptCallback*
+GEOS_interruptRegisterCallback(GEOSInterruptCallback* cb)
- geos::util::Interrupt::registerCallback(cb, cbarg);
+ return geos::util::Interrupt::registerCallback(cb);
void
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2012-06-07 15:10:18 UTC (rev 3671)
+++ trunk/capi/geos_c.h.in 2012-06-07 15:11:06 UTC (rev 3672)
@@ -155,8 +155,8 @@
* The callback will be invoked _before_ checking for
* interruption, so can be used to request it.
-typedef void (GEOSInterruptCallback)(void *arg);
-extern void GEOS_DLL GEOS_interruptRegisterCallback(GEOSInterruptCallback* cb, void *cbarg);
+typedef void (GEOSInterruptCallback)();
+extern GEOSInterruptCallback GEOS_DLL *GEOS_interruptRegisterCallback(GEOSInterruptCallback* cb);
/* Request safe interruption of operations */
extern void GEOS_DLL GEOS_interruptRequest();
/* Cancel a pending interruption request */
Modified: trunk/include/geos/util/Interrupt.h
--- trunk/include/geos/util/Interrupt.h 2012-06-07 15:10:18 UTC (rev 3671)
+++ trunk/include/geos/util/Interrupt.h 2012-06-07 15:11:06 UTC (rev 3672)
@@ -27,7 +27,7 @@
public:
- typedef void (Callback)(void *userdata);
+ typedef void (Callback)(void);
* Request interruption of operations
@@ -53,14 +53,18 @@
* The callback can be used to call Interrupt::request()
- static void registerCallback(Callback *cb, void *arg) { callback = cb; callback_arg = arg; }
+ static Callback* registerCallback(Callback *cb) {
+ Callback* prev = callback;
+ callback = cb;
+ return prev;
* Invoke the callback, if any. Process pending interruption, if any.
static void process() {
- if ( callback ) (*callback)(callback_arg);
+ if ( callback ) (*callback)();
if ( requested ) {
requested = false;
interrupt();
@@ -78,8 +82,6 @@
static Callback *callback;
- static void *callback_arg;
Modified: trunk/src/util/Interrupt.cpp
--- trunk/src/util/Interrupt.cpp 2012-06-07 15:10:18 UTC (rev 3671)
+++ trunk/src/util/Interrupt.cpp 2012-06-07 15:11:06 UTC (rev 3672)
@@ -32,7 +32,6 @@
bool Interrupt::requested = false;
Interrupt::Callback *Interrupt::callback = 0;
-void *Interrupt::callback_arg = 0;
} // namespace geos::util
} // namespace geos
Modified: trunk/tests/unit/capi/GEOSInterruptTest.cpp
--- trunk/tests/unit/capi/GEOSInterruptTest.cpp 2012-06-07 15:10:18 UTC (rev 3671)
+++ trunk/tests/unit/capi/GEOSInterruptTest.cpp 2012-06-07 15:11:06 UTC (rev 3672)
@@ -19,8 +19,8 @@
// Common data used in test cases.
struct test_capiinterrupt_data
- static int alloc_count;
- static int dealloc_count;
+ static int numcalls;
+ static GEOSInterruptCallback* nextcb;
static void notice(const char *fmt, ...)
@@ -42,21 +42,21 @@
- static void interruptNow(void *)
+ static void interruptNow()
- static void countCalls(void *arg)
+ static void countCalls()
- int* numcalls = reinterpret_cast<int*>(arg);
- ++(*numcalls);
+ ++numcalls;
+ if ( nextcb ) (*nextcb)();
- int test_capiinterrupt_data::alloc_count = 0;
- int test_capiinterrupt_data::dealloc_count = 0;
+ int test_capiinterrupt_data::numcalls = 0;
+ GEOSInterruptCallback* test_capiinterrupt_data::nextcb = 0;
typedef test_group<test_capiinterrupt_data> group;
typedef group::object object;
@@ -72,11 +72,11 @@
template<>
void object::test<1>()
- int numcalls = 0;
+ numcalls = 0;
initGEOS(notice, notice);
- GEOS_interruptRegisterCallback(countCalls, &numcalls);
+ GEOS_interruptRegisterCallback(countCalls);
ensure_equals(numcalls, 0);
@@ -93,7 +93,7 @@
GEOSGeom_destroy(geom1);
GEOSGeom_destroy(geom2);
- GEOS_interruptRegisterCallback(0, 0); /* unregister */
+ GEOS_interruptRegisterCallback(0); /* unregister */
finishGEOS();
@@ -104,9 +104,9 @@
template<>
void object::test<2>()
- int numcalls = 0;
+ numcalls = 0;
@@ -125,9 +125,8 @@
- GEOS_interruptRegisterCallback(0, 0); /* unregister (shouldn't be needed) */
finishGEOS();
@@ -142,11 +141,10 @@
ensure("GEOSGeomFromWKT failed", 0 != geom1);
- GEOS_interruptRegisterCallback(interruptNow, 0);
- bool interrupted = false;
+ GEOS_interruptRegisterCallback(interruptNow);
GEOSGeometry *geom2 = GEOSBuffer(geom1, 1, 8);
ensure("GEOSBuffer wasn't interrupted", 0 == geom2);
// TODO: check the actual exception ? (sent to notice() callback)
@@ -155,6 +153,32 @@
finishGEOS();
+ /// Test chaining interrupt callbacks
+ template<>
+ template<>
+ void object::test<4>()
+ numcalls = 0;
+ initGEOS(notice, notice);
+ GEOSGeometry *geom1 = GEOSGeomFromWKT("LINESTRING(0 0, 1 0)");
+ ensure("GEOSGeomFromWKT failed", 0 != geom1);
+ nextcb = GEOS_interruptRegisterCallback(countCalls);
+ GEOSGeometry *geom2 = GEOSBuffer(geom1, 1, 8);
+ ensure("GEOSBuffer wasn't interrupted", 0 == geom2);
+ ensure_equals(numcalls, 1);
+ nextcb = 0;
+ GEOSGeom_destroy(geom1);
+ finishGEOS();
} // namespace tut
More information about the geos-commits
