[geos-commits] r3716 - in trunk: . src/triangulate/quadedge tests/unit/triangulate
svn_geos at osgeo.org
Mon Sep 10 03:34:14 PDT 2012
Author: strk
Date: 2012-09-10 03:34:13 -0700 (Mon, 10 Sep 2012)
New Revision: 3716
trunk/NEWS
trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
trunk/tests/unit/triangulate/DelaunayTest.cpp
Add Z support in delaunay triangulation (#570)
Thanks Benjamin Campbell
Modified: trunk/NEWS
--- trunk/NEWS 2012-09-10 09:23:47 UTC (rev 3715)
+++ trunk/NEWS 2012-09-10 10:34:13 UTC (rev 3716)
@@ -2,7 +2,7 @@
- New things:
- - Delaunay Triangulation API (#487, #565)
+ - Delaunay Triangulation API (#487, #565, #570)
- Interruptibility API (C and C++)
- CAPI: GEOSNode (#496) - PHP: Geometry->node
- GeometryPrecisionReducer class
Modified: trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
--- trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp 2012-09-10 09:23:47 UTC (rev 3715)
+++ trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp 2012-09-10 10:34:13 UTC (rev 3716)
@@ -24,6 +24,7 @@
#include <geos/geom/LineString.h>
#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/CoordinateArraySequence.h>
+#include <geos/geom/CoordinateSequenceFactory.h>
#include <geos/geom/CoordinateArraySequenceFactory.h>
#include <geos/geom/GeometryCollection.h>
#include <geos/geom/GeometryFactory.h>
@@ -379,7 +380,7 @@
void visit(QuadEdge* triEdges[3])
- geom::CoordinateSequence *coordSeq = coordSeqFact.create(4,2);
+ geom::CoordinateSequence *coordSeq = coordSeqFact.create(4,0);
for (int i = 0; i < 3; i++) {
Vertex v = triEdges[i]->orig();
coordSeq->setAt(v.getCoordinate(), i);
@@ -422,12 +423,12 @@
std::auto_ptr<QuadEdgeList> quadEdges(getPrimaryEdges(false));
std::vector<Geometry *> edges(quadEdges->size());
- CoordinateArraySequenceFactory coordSeqFact;
+ const CoordinateSequenceFactory *coordSeqFact = geomFact.getCoordinateSequenceFactory();
int i = 0;
for (QuadEdgeSubdivision::QuadEdgeList::iterator it = quadEdges->begin(); it != quadEdges->end(); ++it)
QuadEdge *qe = *it;
- CoordinateSequence *coordSeq = coordSeqFact.create((std::vector<geom::Coordinate>*)NULL, 2);;
+ CoordinateSequence *coordSeq = coordSeqFact->create((std::vector<geom::Coordinate>*)NULL);;
coordSeq->add(qe->orig().getCoordinate());
coordSeq->add(qe->dest().getCoordinate());
Modified: trunk/tests/unit/triangulate/DelaunayTest.cpp
--- trunk/tests/unit/triangulate/DelaunayTest.cpp 2012-09-10 09:23:47 UTC (rev 3715)
+++ trunk/tests/unit/triangulate/DelaunayTest.cpp 2012-09-10 10:34:13 UTC (rev 3716)
@@ -13,7 +13,7 @@
-#include <stdio.h>
+//#include <stdio.h>
using namespace geos::triangulate;
using namespace geos::triangulate::quadedge;
@@ -59,6 +59,7 @@
expected->normalize();
ensure(results->equalsExact(expected, 1e-7));
+ ensure(results->getCoordinateDimension() == expected->getCoordinateDimension());
delete sites;
delete expected;
@@ -90,7 +91,7 @@
template<>
void object::test<2>()
- const char * wkt = "MULTIPOINT ((10 10 1), (10 20 2), (20 20 3))";
+ const char * wkt = "MULTIPOINT ((10 10), (10 20), (20 20))";
const char* expectedEdges = "MULTILINESTRING ((10 20, 20 20), (10 10, 10 20), (10 10, 20 20))";
const char * expectedTri = "GEOMETRYCOLLECTION (POLYGON ((10 20, 10 10, 20 20, 10 20)))";
@@ -145,5 +146,18 @@
runDelaunay(wkt, false, expectedEdges);
+ // 7 - Test grid (2.5d)
+ template<>
+ template<>
+ void object::test<7>()
+ const char * wkt = "MULTIPOINT ((10 10 1), (10 20 2), (20 20 3), (20 10 1.5), (20 0 2.5), (10 0 3.5), (0 0 0), (0 10 .5), (0 20 .25))";
+ const char* expectedEdges = "MULTILINESTRING ((10 20 2, 20 20 3), (0 20 .25, 10 20 2), (0 10 .5, 0 20 .25), (0 0 0, 0 10 .5), (0 0 0, 10 0 3.5), (10 0 3.5, 20 0 2.5), (20 0 2.5, 20 10 1.5), (20 10 1.5, 20 20 3), (10 20 2, 20 10 1.5), (10 10 1, 20 10 1.6), (10 10 1, 10 20 2), (10 10 1, 0 20 .25), (10 10 1, 0 10 .5), (10 0 3.5, 10 10 1), (0 10 .5, 10 0 3.5), (10 10 1, 20 0 2.5))";
+ const char * expectedTri = "GEOMETRYCOLLECTION (POLYGON ((0 20 .25, 0 10 .5, 10 10 1, 0 20 .25)), POLYGON ((0 20 .25, 10 10 1, 10 20 2, 0 20 .25)), POLYGON ((10 20 2, 10 10 1, 20 10 1.5, 10 20 2)), POLYGON ((10 20 2, 20 10 1.5, 20 20 3, 10 20 2)), POLYGON ((10 0 3.5, 20 0 2.5, 10 10 1, 10 0 3.5)), POLYGON ((10 0 3.5, 10 10 1, 0 10 .5, 10 0 3.5)), POLYGON ((10 0 3.5, 0 10 .5, 0 0 0, 10 0 3.5)), POLYGON ((10 10 1, 20 0 2.5, 20 10 1.5, 10 10 1)))";
+ runDelaunay(wkt, false, expectedEdges);
+ runDelaunay(wkt, true, expectedTri);
} // namespace tut
More information about the geos-commits
