[geos-commits] r3717 - in branches/3.2/source: headers/geos/geom headers/geos/index/chain headers/geos/operation/valid headers/geos/planargraph headers/geos/simplify index/bintree index/strtree
svn_geos at osgeo.org
Mon Sep 17 01:40:43 PDT 2012
Author: strk
Date: 2012-09-17 01:40:42 -0700 (Mon, 17 Sep 2012)
New Revision: 3717
branches/3.2/source/headers/geos/geom/CoordinateSequenceFactory.h
branches/3.2/source/headers/geos/index/chain/MonotoneChainBuilder.h
branches/3.2/source/headers/geos/operation/valid/SimpleNestedRingTester.h
branches/3.2/source/headers/geos/planargraph/DirectedEdgeStar.h
branches/3.2/source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h
branches/3.2/source/headers/geos/simplify/TaggedLineString.h
branches/3.2/source/headers/geos/simplify/TaggedLineStringSimplifier.h
branches/3.2/source/index/bintree/Bintree.cpp
branches/3.2/source/index/bintree/Node.cpp
branches/3.2/source/index/bintree/Root.cpp
branches/3.2/source/index/strtree/AbstractNode.cpp
Fix build with gcc 4.6, adding stdlib includes (#592)
Modified: branches/3.2/source/headers/geos/geom/CoordinateSequenceFactory.h
--- branches/3.2/source/headers/geos/geom/CoordinateSequenceFactory.h 2012-09-10 10:34:13 UTC (rev 3716)
+++ branches/3.2/source/headers/geos/geom/CoordinateSequenceFactory.h 2012-09-17 08:40:42 UTC (rev 3717)
@@ -23,6 +23,7 @@
#include <geos/export.h>
#include <vector>
+#include <cstdlib> // for size_t
//#include <geos/geom/Coordinate.h>
#include <geos/inline.h>
Modified: branches/3.2/source/headers/geos/index/chain/MonotoneChainBuilder.h
--- branches/3.2/source/headers/geos/index/chain/MonotoneChainBuilder.h 2012-09-10 10:34:13 UTC (rev 3716)
+++ branches/3.2/source/headers/geos/index/chain/MonotoneChainBuilder.h 2012-09-17 08:40:42 UTC (rev 3717)
@@ -22,6 +22,7 @@
#include <vector>
+#include <cstdlib> // for size_t and NULL
// Forward declarations
namespace geos {
Modified: branches/3.2/source/headers/geos/operation/valid/SimpleNestedRingTester.h
--- branches/3.2/source/headers/geos/operation/valid/SimpleNestedRingTester.h 2012-09-10 10:34:13 UTC (rev 3716)
+++ branches/3.2/source/headers/geos/operation/valid/SimpleNestedRingTester.h 2012-09-17 08:40:42 UTC (rev 3717)
@@ -56,7 +56,7 @@
graph(newGraph),
rings(),
- nestedPt(NULL)
+ nestedPt(0)
~SimpleNestedRingTester() {
@@ -67,7 +67,7 @@
- * Be aware that the returned Coordinate (if != NULL)
+ * Be aware that the returned Coordinate (if != 0)
* will point to storage owned by one of the LinearRing
* previously added. If you destroy them, this
* will point to an invalid memory address.
Modified: branches/3.2/source/headers/geos/planargraph/DirectedEdgeStar.h
--- branches/3.2/source/headers/geos/planargraph/DirectedEdgeStar.h 2012-09-10 10:34:13 UTC (rev 3716)
+++ branches/3.2/source/headers/geos/planargraph/DirectedEdgeStar.h 2012-09-17 08:40:42 UTC (rev 3717)
@@ -20,6 +20,7 @@
#include <vector>
namespace geos {
Modified: branches/3.2/source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h
--- branches/3.2/source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h 2012-09-10 10:34:13 UTC (rev 3716)
+++ branches/3.2/source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h 2012-09-17 08:40:42 UTC (rev 3717)
@@ -23,6 +23,7 @@
#include <vector>
#include <memory> // for auto_ptr
namespace geos {
Modified: branches/3.2/source/headers/geos/simplify/TaggedLineString.h
--- branches/3.2/source/headers/geos/simplify/TaggedLineString.h 2012-09-10 10:34:13 UTC (rev 3716)
+++ branches/3.2/source/headers/geos/simplify/TaggedLineString.h 2012-09-17 08:40:42 UTC (rev 3717)
@@ -29,6 +29,7 @@
#include <vector>
#include <memory>
namespace geos {
Modified: branches/3.2/source/headers/geos/simplify/TaggedLineStringSimplifier.h
--- branches/3.2/source/headers/geos/simplify/TaggedLineStringSimplifier.h 2012-09-10 10:34:13 UTC (rev 3716)
+++ branches/3.2/source/headers/geos/simplify/TaggedLineStringSimplifier.h 2012-09-17 08:40:42 UTC (rev 3717)
@@ -28,6 +28,7 @@
#include <vector>
#include <memory>
+#include <cstdlib>
namespace geos {
Modified: branches/3.2/source/index/bintree/Bintree.cpp
--- branches/3.2/source/index/bintree/Bintree.cpp 2012-09-10 10:34:13 UTC (rev 3716)
+++ branches/3.2/source/index/bintree/Bintree.cpp 2012-09-17 08:40:42 UTC (rev 3717)
@@ -66,14 +66,14 @@
int
Bintree::depth()
- if (root!=NULL) return root->depth();
+ if (root!=0) return root->depth();
return 0;
int
Bintree::size()
- if (root!=NULL) return root->size();
+ if (root!=0) return root->size();
return 0;
@@ -85,7 +85,7 @@
int
Bintree::nodeSize()
- if (root!=NULL) return root->nodeSize();
+ if (root!=0) return root->nodeSize();
return 0;
Modified: branches/3.2/source/index/bintree/Node.cpp
--- branches/3.2/source/index/bintree/Node.cpp 2012-09-10 10:34:13 UTC (rev 3716)
+++ branches/3.2/source/index/bintree/Node.cpp 2012-09-17 08:40:42 UTC (rev 3717)
@@ -38,9 +38,9 @@
Node::createExpanded(Node *node,Interval *addInterval)
Interval *expandInt=new Interval(addInterval);
- if (node!=NULL) expandInt->expandToInclude(node->interval);
+ if (node!=0) expandInt->expandToInclude(node->interval);
Node *largerNode=createNode(expandInt);
- if (node!=NULL) largerNode->insert(node);
+ if (node!=0) largerNode->insert(node);
delete expandInt;
return largerNode;
@@ -99,7 +99,7 @@
int subnodeIndex=getSubnodeIndex(searchInterval,centre);
if (subnodeIndex==-1)
return this;
- if (subnode[subnodeIndex]!=NULL) {
+ if (subnode[subnodeIndex]!=0) {
// query lies in subnode, so search it
Node *node=subnode[subnodeIndex];
return node->find(searchInterval);
@@ -111,7 +111,7 @@
void
Node::insert(Node *node)
- assert(interval==NULL || interval->contains(node->interval));
+ assert(interval==0 || interval->contains(node->interval));
int index=getSubnodeIndex(node->interval,centre);
if (node->level==level-1) {
subnode[index]=node;
@@ -131,7 +131,7 @@
Node*
Node::getSubnode(int index)
- if (subnode[index]==NULL) {
+ if (subnode[index]==0) {
subnode[index]=createSubnode(index);
return subnode[index];
Modified: branches/3.2/source/index/bintree/Root.cpp
--- branches/3.2/source/index/bintree/Root.cpp 2012-09-10 10:34:13 UTC (rev 3716)
+++ branches/3.2/source/index/bintree/Root.cpp 2012-09-17 08:40:42 UTC (rev 3717)
@@ -47,7 +47,7 @@
* If the subnode doesn't exist or this item is not contained in it,
* have to expand the tree upward to contain the item.
- if (node==NULL || !node->getInterval()->contains(itemInterval))
+ if (node==0 || !node->getInterval()->contains(itemInterval))
Node* largerNode=Node::createExpanded(node,itemInterval);
// delete subnode[index];
Modified: branches/3.2/source/index/strtree/AbstractNode.cpp
--- branches/3.2/source/index/strtree/AbstractNode.cpp 2012-09-10 10:34:13 UTC (rev 3716)
+++ branches/3.2/source/index/strtree/AbstractNode.cpp 2012-09-17 08:40:42 UTC (rev 3717)
@@ -32,7 +32,7 @@
AbstractNode::AbstractNode(int newLevel, int capacity) {
childBoundables.reserve(capacity);
- bounds=NULL;
+ bounds=0;
level=newLevel;
@@ -42,7 +42,7 @@
const void *
AbstractNode::getBounds() const
- if (bounds==NULL) {
+ if (bounds==0) {
bounds = computeBounds();
return bounds;
@@ -61,7 +61,7 @@
* (wrapped in an ItemBoundable)
void AbstractNode::addChildBoundable(Boundable *childBoundable) {
- assert(bounds==NULL);
+ assert(bounds==0);
childBoundables.push_back(childBoundable);
More information about the geos-commits
