[geos-commits] r3830 - trunk
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Jul 10 22:42:57 PDT 2013
Author: strk
Date: 2013-07-10 22:42:57 -0700 (Wed, 10 Jul 2013)
New Revision: 3830
   trunk/NEWS
Cleanup NEWS file confused in r3816
Modified: trunk/NEWS
--- trunk/NEWS	2013-07-05 14:56:31 UTC (rev 3829)
+++ trunk/NEWS	2013-07-11 05:42:57 UTC (rev 3830)
@@ -1,85 +1,6 @@
 Changes in 3.4.0
-Changes in 3.3.8
-2013-02-28
-- Bug fixes / improvements
-    - IsValidOp: throw proper error on nested shells (#608)
-    - Fix header guards (#617, #618, #619)
-    - WKTWriter::appendCoordinate optimisation
-    - Fix centroid computation for collections with empty components (#582)
-Changes in 3.3.7
-2013-01-22
-    - Fix abort in RightmostEdgeFinder (#605)
-    - Do not force precision reduction below 6 significant digits
-      while trying to obtain a valid Buffer output (#605)
-    - Fix GEOSPointOnSurface with zero-length linestring (#609)
-    - Fix EMPTY return from zero-area polygon (#613)
-    - Segfault from symdifference (#615)
-Changes in 3.3.6
-2012-11-15 -- that's Post-GIS day !
-    - Add support for testing with phpunit 3.6 (not loosing support for 3.4)
-    - Segfault from intersection (#586, #598, #599)
-Changes in 3.3.5
-2012-06-25
-    - Correctly increment CAPI lib version from 3.3.3 (#558)
-    - Port robustness fix to CentroidArea (#559)
-    - Always return POINT from GEOSGetCentroid, even for EMPTY (#560)
-    - Always return POINT from GEOSPointOnSurface, even for EMPTY (#561)
-Changes in 3.3.4
-2012-05-31
-    - Do not abort on NaN overlay input (#530)
-    - Reduce CommonBitsRemover harmful effects during overlay op (#527)
-    - Better cross-compiler support (#534)
-    - Enable overlay ops short-circuits (#542)
-    - Envelope-based short-circuit for symDifference (#543)
-    - Fix support for PHP 5.4 (#513)
-    - Fix TopologyPreservingSimplifier invalid output on closed line (#508)
-    - Reduce calls to ptNotInList, greatly speeding up Polygonizer (#545)
-Changes in 3.3.3
-2012-04-01
-    - Fix simplification of collections with empty items (#519)
-    - Fix MSVC compilation of ambiguous log() call (#506)
-    - Fix CMake issues with std:: namespace detection (#493)
-Changes in 3.3.2
-2012-01-05
-    - Fix CMAKE_CXX_FLAGS overriding -std=gnu++0x (#489)
-    - Missing versions update in CMake configuration (#490)
-    - Fix noding of self-intersecting lines through UnaryUnion (#482)
-    - Fix handling of collapsed edges skipping in BufferOp (#494)
-    - Print up to 18 digits of precision for TopologyException points
-    - Fix noding with reduced precision in Buffer operation (#473)
-    - Fix HotPixel original point invalidation (#498)
-    - Fix CascadedPolygonUnion to discard non-polygonal components (#499)
-    - Improve buffer robustness by reverting to non-snaprounding noder (#495)
-    - Fix C++11 build by avoiding std::pair<auto_ptr> (#491)
-    - Add --clibs to geos-config and GEOS_C_LIBS to geos.m4 (#497)
-    - Apply shoelace formula for area calculation (#485)
-    - Fix default initialization issue for clang (#500)
-    - Improve overlay robustness by fixing areal validity on snapping (#488)
-Changes in 3.3.1
-2011-09-27
 - New things:
   - Delaunay Triangulation API (#487, #565, #570)
   - Interruptibility API (C and C++)
More information about the geos-commits mailing list
