[geos-commits] r3831 - trunk
    svn_geos at osgeo.org
    Wed Jul 10 22:46:13 PDT 2013
Author: strk
Date: 2013-07-10 22:46:13 -0700 (Wed, 10 Jul 2013)
New Revision: 3831
   trunk/NEWS
Add 3.3.1 to 3.3.8 section
Modified: trunk/NEWS
--- trunk/NEWS	2013-07-11 05:42:57 UTC (rev 3830)
+++ trunk/NEWS	2013-07-11 05:46:13 UTC (rev 3831)
@@ -29,7 +29,97 @@
   - Fixed CMake configuration to set correct SOVERSION (current - age)
   - Fix EMPTY return from single-point lines and zero-length polygons (#612)
+Changes in 3.3.8
+2013-02-28
+- Bug fixes / improvements
+    - IsValidOp: throw proper error on nested shells (#608)
+    - Fix header guards (#617, #618, #619)
+    - WKTWriter::appendCoordinate optimisation
+    - Fix centroid computation for collections with empty components (#582)
+Changes in 3.3.7
+2013-01-22
+    - Fix abort in RightmostEdgeFinder (#605)
+    - Do not force precision reduction below 6 significant digits
+      while trying to obtain a valid Buffer output (#605)
+    - Fix GEOSPointOnSurface with zero-length linestring (#609)
+    - Fix EMPTY return from zero-area polygon (#613)
+    - Segfault from symdifference (#615)
+Changes in 3.3.6
+2012-11-15 -- that's Post-GIS day !
+    - Add support for testing with phpunit 3.6 (not loosing support for 3.4)
+    - Segfault from intersection (#586, #598, #599)
+Changes in 3.3.5
+2012-06-25
+    - Correctly increment CAPI lib version from 3.3.3 (#558)
+    - Port robustness fix to CentroidArea (#559)
+    - Always return POINT from GEOSGetCentroid, even for EMPTY (#560)
+    - Always return POINT from GEOSPointOnSurface, even for EMPTY (#561)
+Changes in 3.3.4
+2012-05-31
+    - Do not abort on NaN overlay input (#530)
+    - Reduce CommonBitsRemover harmful effects during overlay op (#527)
+    - Better cross-compiler support (#534)
+    - Enable overlay ops short-circuits (#542)
+    - Envelope-based short-circuit for symDifference (#543)
+    - Fix support for PHP 5.4 (#513)
+    - Fix TopologyPreservingSimplifier invalid output on closed line (#508)
+    - Reduce calls to ptNotInList, greatly speeding up Polygonizer (#545)
+Changes in 3.3.3
+2012-04-01
+    - Fix simplification of collections with empty items (#519)
+    - Fix MSVC compilation of ambiguous log() call (#506)
+    - Fix CMake issues with std:: namespace detection (#493)
+Changes in 3.3.2
+2012-01-05
+    - Fix CMAKE_CXX_FLAGS overriding -std=gnu++0x (#489)
+    - Missing versions update in CMake configuration (#490)
+    - Fix noding of self-intersecting lines through UnaryUnion (#482)
+    - Fix handling of collapsed edges skipping in BufferOp (#494)
+    - Print up to 18 digits of precision for TopologyException points
+    - Fix noding with reduced precision in Buffer operation (#473)
+    - Fix HotPixel original point invalidation (#498)
+    - Fix CascadedPolygonUnion to discard non-polygonal components (#499)
+    - Improve buffer robustness by reverting to non-snaprounding noder (#495)
+    - Fix C++11 build by avoiding std::pair<auto_ptr> (#491)
+    - Add --clibs to geos-config and GEOS_C_LIBS to geos.m4 (#497)
+    - Apply shoelace formula for area calculation (#485)
+    - Fix default initialization issue for clang (#500)
+    - Improve overlay robustness by fixing areal validity on snapping (#488)
+Changes in 3.3.1
+2011-09-27
+  - Fix memory leak on invalid geometry in InteriorPointArea (#475)
+  - ValidOp abort in presence of 2 touching holes forming an island (#449)
+  - Enable prepared intersects operation for points
+  - Fortify suspicious code found by static analisys tools
+  - Fix for SOLARIS build (#461)
+  - Fix EMPTY result from GEOSOffsetCurve with distance 0 (#454)
+  - Fix Geometry::clone to copy SRID (#464)
+  - Fix for clang builds (#463)
+  - Fix out-of-place builds for python binding (#332) and regress testing
+  - Fix OS X framework cmake build (#385)
 Changes in 3.3.0
 2011-05-30
More information about the geos-commits
