[geos-commits] r3835 - in trunk: include/geos/triangulate/quadedge src/triangulate/quadedge tests/unit/triangulate
svn_geos at osgeo.org
Thu Jul 11 08:34:43 PDT 2013
Author: strk
Date: 2013-07-11 08:34:43 -0700 (Thu, 11 Jul 2013)
New Revision: 3835
trunk/include/geos/triangulate/quadedge/QuadEdge.h
trunk/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
trunk/include/geos/triangulate/quadedge/Vertex.h
trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
trunk/tests/unit/triangulate/DelaunayTest.cpp
Fix memory in QuadEdgeSubdivision (#604)
Modified: trunk/include/geos/triangulate/quadedge/QuadEdge.h
--- trunk/include/geos/triangulate/quadedge/QuadEdge.h 2013-07-11 08:21:54 UTC (rev 3834)
+++ trunk/include/geos/triangulate/quadedge/QuadEdge.h 2013-07-11 15:34:43 UTC (rev 3835)
@@ -33,14 +33,14 @@
* The quadedge algebra was described in a well-known paper by Guibas and Stolfi,
* "Primitives for the manipulation of general subdivisions and the computation of Voronoi diagrams",
* <i>ACM Transactions on Graphics</i>, 4(2), 1985, 75-123.
- * <p>
* Each edge object is part of a quartet of 4 edges,
* linked via their <tt>_rot</tt> references.
* Any edge in the group may be accessed using a series of {@link #rot()} operations.
* Quadedges in a subdivision are linked together via their <tt>next</tt> references.
* The linkage between the quadedge quartets determines the topology
* of the subdivision.
- * <p>
* The edge class does not contain separate information for vertice or faces; a vertex is implicitly
* defined as a ring of edges (created using the <tt>next</tt> field).
@@ -151,6 +151,8 @@
* that this quadedge quartet no longer participates
* in a subdivision.
+ * NOTE: called "delete" in JTS
void remove();
Modified: trunk/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
--- trunk/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h 2013-07-11 08:21:54 UTC (rev 3834)
+++ trunk/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h 2013-07-11 15:34:43 UTC (rev 3835)
@@ -91,7 +91,7 @@
private:
QuadEdgeList quadEdges;
- QuadEdgeList removedEdges;
+ QuadEdgeList createdEdges;
QuadEdge* startingEdges[3];
double tolerance;
double edgeCoincidenceTolerance;
Modified: trunk/include/geos/triangulate/quadedge/Vertex.h
--- trunk/include/geos/triangulate/quadedge/Vertex.h 2013-07-11 08:21:54 UTC (rev 3834)
+++ trunk/include/geos/triangulate/quadedge/Vertex.h 2013-07-11 15:34:43 UTC (rev 3835)
@@ -43,15 +43,15 @@
* Models a site (node) in a {@link QuadEdgeSubdivision}.
* The sites can be points on a line string representing a
* linear site.
- * <p>
* The vertex can be considered as a vector with a norm, length, inner product, cross
* product, etc. Additionally, point relations (e.g., is a point to the left of a line, the circle
* defined by this point and two others, etc.) are also defined in this class.
- * <p>
* It is common to want to attach user-defined data to
* the vertices of a subdivision.
* One way to do this is to subclass <tt>Vertex</tt>
- * to carry any desired information (see {@link ConstraintVertex}.
+ * to carry any desired information (see {@link ConstraintVertex}).
* @author JTS: David Skea
* @author JTS: Martin Davis
Modified: trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
--- trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp 2013-07-11 08:21:54 UTC (rev 3834)
+++ trunk/src/triangulate/quadedge/QuadEdgeSubdivision.cpp 2013-07-11 15:34:43 UTC (rev 3835)
@@ -63,23 +63,20 @@
createFrame(env);
initSubdiv(startingEdges);
quadEdges.push_back(startingEdges[0]);
+ createdEdges.push_back(startingEdges[0]);
quadEdges.push_back(startingEdges[1]);
+ createdEdges.push_back(startingEdges[1]);
quadEdges.push_back(startingEdges[2]);
+ createdEdges.push_back(startingEdges[2]);
QuadEdgeSubdivision::~QuadEdgeSubdivision()
- for(QuadEdgeList::iterator iter=quadEdges.begin(); iter!=quadEdges.end(); ++iter)
+ for(QuadEdgeList::iterator iter=createdEdges.begin(); iter!=createdEdges.end(); ++iter)
(*iter)->free();
delete *iter;
- for(QuadEdgeList::iterator iter=removedEdges.begin(); iter!=removedEdges.end(); ++iter)
- (*iter)->free();
- delete *iter;
void
@@ -134,6 +131,7 @@
QuadEdge *q0_ptr = q0.get();
q0.release();
+ createdEdges.push_back(q0_ptr);
quadEdges.push_back(q0_ptr);
return *q0_ptr;
@@ -145,6 +143,7 @@
q0.release();
return *q0_ptr;
@@ -161,9 +160,6 @@
//mark these edges as removed
e.remove();
- //keep a list of removed edges so that we can
- //properly free memory
- removedEdges.push_back(&e);
QuadEdge*
Modified: trunk/tests/unit/triangulate/DelaunayTest.cpp
--- trunk/tests/unit/triangulate/DelaunayTest.cpp 2013-07-11 08:21:54 UTC (rev 3834)
+++ trunk/tests/unit/triangulate/DelaunayTest.cpp 2013-07-11 15:34:43 UTC (rev 3835)
@@ -41,13 +41,14 @@
group test_incdelaunaytri_group("geos::triangulate::Delaunay");
//helper function for funning triangulation
- void runDelaunay(const char *sitesWkt, bool computeTriangles, const char *expectedWkt)
+ void runDelaunay(const char *sitesWkt, bool computeTriangles, const char *expectedWkt, double tolerance=0.0)
WKTReader reader;
std::auto_ptr<Geometry> results;
Geometry *sites = reader.read(sitesWkt);
Geometry *expected = reader.read(expectedWkt);
DelaunayTriangulationBuilder builder;
+ builder.setTolerance(tolerance);
GeometryFactory geomFact;
builder.setSites(*sites);
@@ -59,8 +60,8 @@
results->normalize();
expected->normalize();
- ensure(results->equalsExact(expected, 1e-7));
- ensure(results->getCoordinateDimension() == expected->getCoordinateDimension());
+ ensure(results->toString(), results->equalsExact(expected, 1e-7));
+ ensure_equals(results->getCoordinateDimension(), expected->getCoordinateDimension());
delete sites;
delete expected;
@@ -160,5 +161,16 @@
runDelaunay(wkt, false, expectedEdges);
runDelaunay(wkt, true, expectedTri);
+ // 8 - Tolerance robustness - http://trac.osgeo.org/geos/ticket/604
+ template<>
+ template<>
+ void object::test<8>()
+ const char * wkt = "MULTIPOINT(-118.3964065 56.0557,-118.396406 56.0475,-118.396407 56.04,-118.3968 56)";
+ const char* expectedEdges = "MULTILINESTRING ((-118.3964065 56.0557, -118.396406 56.0475), (-118.396407 56.04, -118.396406 56.0475), (-118.3968 56, -118.396407 56.04))";
+ runDelaunay(wkt, false, expectedEdges, 0.001);
} // namespace tut
More information about the geos-commits
