[geos-commits] r3836 - trunk/tests/unit/capi
svn_geos at osgeo.org
Thu Jul 11 08:54:20 PDT 2013
Author: strk
Date: 2013-07-11 08:54:20 -0700 (Thu, 11 Jul 2013)
New Revision: 3836
trunk/tests/unit/capi/GEOSOffsetCurveTest.cpp
Drop carriage returns
Modified: trunk/tests/unit/capi/GEOSOffsetCurveTest.cpp
--- trunk/tests/unit/capi/GEOSOffsetCurveTest.cpp 2013-07-11 15:34:43 UTC (rev 3835)
+++ trunk/tests/unit/capi/GEOSOffsetCurveTest.cpp 2013-07-11 15:54:20 UTC (rev 3836)
@@ -194,21 +194,21 @@
template<>
void object::test<7>()
- std::string wkt0("LINESTRING ("
- "665.7317504882812500 133.0762634277343700,"
- "1774.4752197265625000 19.9391822814941410,"
- "756.2413940429687500 466.8306579589843700,"
- "626.1337890625000000 1898.0147705078125000,"
- "433.8007202148437500 404.6052856445312500)");
+ std::string wkt0("LINESTRING ("
+ "665.7317504882812500 133.0762634277343700,"
+ "1774.4752197265625000 19.9391822814941410,"
+ "756.2413940429687500 466.8306579589843700,"
+ "626.1337890625000000 1898.0147705078125000,"
+ "433.8007202148437500 404.6052856445312500)");
geom1_ = GEOSGeomFromWKT(wkt0.c_str());
- ensure( 0 != geom1_ );
- double width = 57.164000837203;
- // left-sided
- geom2_ = GEOSOffsetCurve(geom1_, width, 8, GEOSBUF_JOIN_MITRE, 5.57);
+ ensure( 0 != geom1_ );
+ double width = 57.164000837203;
+ // left-sided
+ geom2_ = GEOSOffsetCurve(geom1_, width, 8, GEOSBUF_JOIN_MITRE, 5.57);
ensure( 0 != geom2_ );
// likely, 5 >= 5
ensure(GEOSGeomGetNumPoints(geom2_) >= GEOSGeomGetNumPoints(geom1_));
@@ -216,10 +216,10 @@
//ensure_equals(std::string(wkt_), ...);
- // right-sided
- width = -width;
+ // right-sided
+ width = -width;
// likely, 5 >= 7
More information about the geos-commits
