[geos-commits] r3846 - in trunk: src/operation/buffer tests/unit/capi
svn_geos at osgeo.org
Wed Jul 17 09:07:57 PDT 2013
Author: strk
Date: 2013-07-17 09:07:56 -0700 (Wed, 17 Jul 2013)
New Revision: 3846
trunk/src/operation/buffer/OffsetCurveBuilder.cpp
trunk/tests/unit/capi/GEOSOffsetCurveTest.cpp
Make GEOSOffsetCurve survive single-point input (with an exception)
Modified: trunk/src/operation/buffer/OffsetCurveBuilder.cpp
--- trunk/src/operation/buffer/OffsetCurveBuilder.cpp 2013-07-17 15:58:30 UTC (rev 3845)
+++ trunk/src/operation/buffer/OffsetCurveBuilder.cpp 2013-07-17 16:07:56 UTC (rev 3846)
@@ -36,6 +36,7 @@
#include <geos/algorithm/NotRepresentableException.h>
#include <geos/algorithm/HCoordinate.h>
#include <geos/util.h>
+#include <geos/util/IllegalArgumentException.h>
#ifndef GEOS_DEBUG
#define GEOS_DEBUG 0
@@ -128,6 +129,8 @@
int n1 = simp1.size() - 1;
+ if ( ! n1 )
+ throw util::IllegalArgumentException("Cannot get offset of single-vertex line");
segGen->initSideSegments(simp1[0], simp1[1], Position::LEFT);
segGen->addFirstSegment();
for (int i = 2; i <= n1; ++i) {
@@ -145,6 +148,8 @@
const CoordinateSequence& simp2 = *simp2_;
int n2 = simp2.size() - 1;
+ if ( ! n2 )
segGen->initSideSegments(simp2[n2], simp2[n2-1], Position::LEFT);
for (int i = n2-2; i >= 0; --i) {
Modified: trunk/tests/unit/capi/GEOSOffsetCurveTest.cpp
--- trunk/tests/unit/capi/GEOSOffsetCurveTest.cpp 2013-07-17 15:58:30 UTC (rev 3845)
+++ trunk/tests/unit/capi/GEOSOffsetCurveTest.cpp 2013-07-17 16:07:56 UTC (rev 3846)
@@ -244,9 +244,7 @@
geom2_ = GEOSOffsetCurve(geom1_, width, 8, GEOSBUF_JOIN_ROUND, 0);
ensure( "Unexpected exception", 0 != geom2_ );
wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
- GEOSGeom_destroy(geom2_); geom2_ = 0;
ensure_equals(std::string(wkt_), "LINESTRING (10 9, 1 9, 1 0)");
- GEOSFree(wkt_); wkt_ = 0;
// Test duplicated final vertex in input
@@ -263,10 +261,23 @@
ensure_equals(std::string(wkt_), "LINESTRING (1 10, 1 0)");
+ // Test only duplicated vertex in input
+ // See http://trac.osgeo.org/postgis/ticket/602
+ template<>
+ template<>
+ void object::test<10>()
+ double width = -1;
+ geom1_ = GEOSGeomFromWKT("LINESTRING(0 10,0 10,0 10)");
+ ensure( 0 != geom1_ );
+ geom2_ = GEOSOffsetCurve(geom1_, width, 8, GEOSBUF_JOIN_ROUND, 0);
+ ensure( "Missing expected exception", 0 == geom2_ );
} // namespace tut
More information about the geos-commits
