[geos-commits] r3847 - in branches/3.3: . src/operation/buffer tests/unit/capi
svn_geos at osgeo.org
Wed Jul 17 09:11:54 PDT 2013
Author: strk
Date: 2013-07-17 09:11:54 -0700 (Wed, 17 Jul 2013)
New Revision: 3847
branches/3.3/NEWS
branches/3.3/src/operation/buffer/BufferInputLineSimplifier.cpp
branches/3.3/src/operation/buffer/OffsetCurveBuilder.cpp
branches/3.3/src/operation/buffer/OffsetSegmentGenerator.cpp
branches/3.3/tests/unit/capi/GEOSOffsetCurveTest.cpp
Fix OffsetCurve op in presence of duplicated vertices (#602)
Modified: branches/3.3/NEWS
--- branches/3.3/NEWS 2013-07-17 16:07:56 UTC (rev 3846)
+++ branches/3.3/NEWS 2013-07-17 16:11:54 UTC (rev 3847)
@@ -2,6 +2,7 @@
2012-MM-DD
- Bug fixes / improvements
+ - Fix OffsetCurve op in presence of duplicated vertices (#602)
- Fix LineSegmentVisitor copy ctor (#636)
- Fix area boundary return from GEOSPointOnSurface (#623)
- Speedup GEOSWKBReader_read (#621)
Modified: branches/3.3/src/operation/buffer/BufferInputLineSimplifier.cpp
--- branches/3.3/src/operation/buffer/BufferInputLineSimplifier.cpp 2013-07-17 16:07:56 UTC (rev 3846)
+++ branches/3.3/src/operation/buffer/BufferInputLineSimplifier.cpp 2013-07-17 16:11:54 UTC (rev 3847)
@@ -81,7 +81,6 @@
* This ensures that end caps are generated consistently.
unsigned int index = 1;
- //int maxIndex = inputLine.size() - 1;
unsigned int midIndex = findNextNonDeletedIndex(index);
unsigned int lastIndex = findNextNonDeletedIndex(midIndex);
@@ -131,7 +130,7 @@
for (size_t i=0, n=inputLine.size(); i<n; ++i)
if (isDeleted[i] != DELETE)
- coordList->add(inputLine[i]);
+ coordList->add(inputLine[i], false);
return coordList;
Modified: branches/3.3/src/operation/buffer/OffsetCurveBuilder.cpp
--- branches/3.3/src/operation/buffer/OffsetCurveBuilder.cpp 2013-07-17 16:07:56 UTC (rev 3846)
+++ branches/3.3/src/operation/buffer/OffsetCurveBuilder.cpp 2013-07-17 16:11:54 UTC (rev 3847)
@@ -36,6 +36,7 @@
#include <geos/algorithm/NotRepresentableException.h>
#include <geos/algorithm/HCoordinate.h>
#include <geos/util.h>
+#include <geos/util/IllegalArgumentException.h>
#include "BufferInputLineSimplifier.h"
@@ -130,6 +131,8 @@
int n1 = simp1.size() - 1;
+ if ( ! n1 )
+ throw util::IllegalArgumentException("Cannot get offset of single-vertex line");
segGen->initSideSegments(simp1[0], simp1[1], Position::LEFT);
segGen->addFirstSegment();
for (int i = 2; i <= n1; ++i) {
@@ -147,6 +150,8 @@
const CoordinateSequence& simp2 = *simp2_;
int n2 = simp2.size() - 1;
+ if ( ! n2 )
segGen->initSideSegments(simp2[n2], simp2[n2-1], Position::LEFT);
for (int i = n2-2; i >= 0; --i) {
Modified: branches/3.3/src/operation/buffer/OffsetSegmentGenerator.cpp
--- branches/3.3/src/operation/buffer/OffsetSegmentGenerator.cpp 2013-07-17 16:07:56 UTC (rev 3846)
+++ branches/3.3/src/operation/buffer/OffsetSegmentGenerator.cpp 2013-07-17 16:11:54 UTC (rev 3847)
@@ -135,6 +135,10 @@
void
OffsetSegmentGenerator::addNextSegment(const Coordinate &p, bool addStartPoint)
+ // do nothing if points are equal
+ if (s2==p) return;
// s0-s1-s2 are the coordinates of the previous segment
// and the current one
s0=s1;
@@ -145,9 +149,6 @@
seg1.setCoordinates(s1, s2);
computeOffsetSegment(seg1, side, distance, offset1);
- // do nothing if points are equal
- if (s1==s2) return;
int orientation=CGAlgorithms::computeOrientation(s0, s1, s2);
bool outsideTurn =
(orientation==CGAlgorithms::CLOCKWISE
Modified: branches/3.3/tests/unit/capi/GEOSOffsetCurveTest.cpp
--- branches/3.3/tests/unit/capi/GEOSOffsetCurveTest.cpp 2013-07-17 16:07:56 UTC (rev 3846)
+++ branches/3.3/tests/unit/capi/GEOSOffsetCurveTest.cpp 2013-07-17 16:11:54 UTC (rev 3847)
@@ -189,5 +189,96 @@
+ // left-side and right-side curve
+ // See http://trac.osgeo.org/postgis/ticket/633
+ template<>
+ template<>
+ void object::test<7>()
+ std::string wkt0("LINESTRING ("
+ "665.7317504882812500 133.0762634277343700,"
+ "1774.4752197265625000 19.9391822814941410,"
+ "756.2413940429687500 466.8306579589843700,"
+ "626.1337890625000000 1898.0147705078125000,"
+ "433.8007202148437500 404.6052856445312500)");
+ geom1_ = GEOSGeomFromWKT(wkt0.c_str());
+ ensure( 0 != geom1_ );
+ double width = 57.164000837203;
+ // left-sided
+ geom2_ = GEOSOffsetCurve(geom1_, width, 8, GEOSBUF_JOIN_MITRE, 5.57);
+ ensure( 0 != geom2_ );
+ // likely, 5 >= 5
+ ensure(GEOSGeomGetNumPoints(geom2_) >= GEOSGeomGetNumPoints(geom1_));
+ wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
+ GEOSGeom_destroy(geom2_);
+ GEOSFree(wkt_);
+ //ensure_equals(std::string(wkt_), ...);
+ // right-sided
+ width = -width;
+ // likely, 5 >= 7
+ // Test duplicated inner vertex in input
+ // See http://trac.osgeo.org/postgis/ticket/602
+ template<>
+ template<>
+ void object::test<8>()
+ double width = -1;
+ geom1_ = GEOSGeomFromWKT("LINESTRING(0 0,0 10,0 10,10 10)");
+ geom2_ = GEOSOffsetCurve(geom1_, width, 8, GEOSBUF_JOIN_ROUND, 0);
+ ensure( "Unexpected exception", 0 != geom2_ );
+ ensure_equals(std::string(wkt_), "LINESTRING (10 9, 1 9, 1 0)");
+ // Test duplicated final vertex in input
+ template<>
+ template<>
+ void object::test<9>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING(0 0,0 10,0 10)");
+ ensure_equals(std::string(wkt_), "LINESTRING (1 10, 1 0)");
+ // Test only duplicated vertex in input
+ template<>
+ template<>
+ void object::test<10>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING(0 10,0 10,0 10)");
+ ensure( "Missing expected exception", 0 == geom2_ );
} // namespace tut
More information about the geos-commits
