[geos-commits] r3851 - trunk/tests/xmltester/tests/ticket
svn_geos at osgeo.org
Wed Jul 31 01:30:53 PDT 2013
Author: strk
Date: 2013-07-31 01:30:52 -0700 (Wed, 31 Jul 2013)
New Revision: 3851
trunk/tests/xmltester/tests/ticket/bug275.xml
Turn test for ticket 275 into an "area test".
Area test checks that the area of the Union between two geometries
is about the same as the sum of area of symdifference + area of
intersection.
Modified: trunk/tests/xmltester/tests/ticket/bug275.xml
--- trunk/tests/xmltester/tests/ticket/bug275.xml 2013-07-25 21:00:17 UTC (rev 3850)
+++ trunk/tests/xmltester/tests/ticket/bug275.xml 2013-07-31 08:30:52 UTC (rev 3851)
@@ -21,8 +21,8 @@
<op name="isValid" arg1="B">true</op>
</test>
<test>
- <op name="union" arg1="A" arg2="B">
- POLYGON ((-3511.3162188351402619 3631.5163871940371791, -3511.3093623564318477 3779.2751088689078642, -3489.2809334334315281 3925.3825631523477568, -3445.7229817488723711 4066.5751434214562323, -3381.6084625862131361 4199.6990267427599974, -3298.3695038980586105 4321.7806209104110167, -3197.8654168207931434 4430.0929856651728187, -3082.3411641855241214 4522.2167444414280908, -2954.3772147154591039 4596.0941260546514968, -2816.8319030180368827 4650.0749291985657692, -2672.7775828783942416 4682.9533830416003184, -2592.0441774584969608 4689.0033359847420797, -2592.2292272141212379 4691.7359415891232857, 464.5127727858784965 4898.7359415891232857, 464.6978225415029442 4896.0033359847420797, 531.3099999999999454 4900.9950805664066138, 678.8370360718679422 4889.9260169705503358, 822.8852510671204072 4857.0208253636828886, 832.4966505855577452 4853.2466926456381771, 832.7155347673275401 4853.9304792686480141, 3440.9455347673278993 4019.0204792686481596, 3440.7266505855582182 4018.
3366926456378678, 3568.6505408654807070 3968.1044929749309631, 3696.6007755412720144 3894.2033608833789913, 3812.1079268348321420 3802.0581609104569907, 3912.5919080161379497 3693.7271431733465761, 3995.8082053600896870 3571.6301008898981308, 4059.8980139174327633 3438.4943193843760127, 4103.4297576971002854 3297.2936566327280161, 4111.9568486815251163 3240.6649172772094971, 4114.5449810944692217 3241.0993479430067055, 4438.8449810944684941 1309.0733479430066382, 4436.2568486815243887 1308.6389172772094298, 4449.7310668223972243 1219.1561161070862909, 4449.7104973863315536 1071.3973957048663124, 4427.6685088490185080 925.2919864301782127, 4384.0974537747060822 784.1034492265001745, 4319.9705801376658201 650.9855167172314623, 4236.7202918527709699 528.9116481847523801, 4136.2061531259496405 420.6086113205509491, 4020.6733513123099328 328.4955743328730478, 3892.7025460983149969 254.6300689133272499, 3755.1522252283625676 200.6620310892940324, 3611.0948543776285078 167.79694655
30077287, 3463.7482473934069276 156.7689236912091246, 3316.4036898899316839 167.8242957839195242, 3172.3524217021254117 200.7161186505198884, 3034.8121203619148218 254.7096866493769767, 2920.2486381949101997 320.8647580300017808, 3097.3929252677053228 -340.6343946513263745, 2829.3203546600025220 -1340.5704802618731719, 2566.4316545475776365 -1603.3983692935935323, 2589.9586987092807249 -1691.2539814346002913, 2550.3216026895242976 -1839.1041048139375107, 2582.0225141513105882 -1957.4828931887502677, 2523.0465473393464890 -2177.4688367911371643, 2361.9813735858801920 -2338.4967531528800464, 2141.9817920466971373 -2397.4218256316030420, 1921.9931199150225893 -2338.4560374338593647, 1915.5094890288899023 -2331.9715065100085667, 1790.8032356108271870 -2365.3730474120334293, 1773.3588004956532131 -2360.6972390794344392, 1755.9014460409671301 -2365.3730474120334293, 1535.9127739092928095 -2306.4072592142892972, 1470.0174606543544087 -2240.5027985744332000, 1267.8188705444704283 -2
294.6600223925997852, 1145.5500718010853234 -2750.7342254735290226, 779.4928666591022193 -3116.7067547270667092, 279.4938285436001593 -3250.6273710942414255, -220.4804154644647269 -3116.6142190040254718, -276.8825358097809044 -3060.2042690896628301, -317.8708072633123720 -3042.4487397531365787, -317.0081043084857697 -3040.4572078632113517, -353.9188796380849453 -3025.9673133506230442, -481.8759722620623052 -2952.0780561800302166, -597.3916747239470624 -2859.9435764086629206, -697.8857092860117746 -2751.6218846962374300, -781.1133376604859677 -2629.5325659449085833, -845.2155017965442312 -2496.4027329581699632, -881.7734250743712892 -2377.8616075414415718, -883.2163026251768088 -2378.2274205979942963, -915.6765245378969666 -2250.1944686487954641, -958.6488338256679071 -2176.6893024190303549, -958.3104527203266798 -2176.4914793507796276, -961.3773376604859777 -2171.9925659449086197, -1025.4795017965443549 -2038.8627329581699996, -1069.0243497161841333 -1897.6661108397263433, -
1091.0392188351402183 -1751.5566128059626863, -1091.0323623564322588 -1603.7978911310922285, -1089.6762878232161711 -1594.8034867385058533, -1104.6051239273215288 -1541.4387753320572756, -1142.1697554404233870 -1500.9481685832554376, -1144.1735018958338514 -1502.8286850026515822, -1237.9475018958337387 -1402.9096850026517131, -1235.9437554404232742 -1401.0291685832553412, -1283.8694719642787732 -1349.3704336840412452, -1284.3641704239839783 -1349.7723644815778243, -1285.2860836559341351 -1348.6376690100614724, -1338.3270735958196838 -1329.0603190321844522, -1337.4416005745254097 -1326.6613035542172838, -1425.0218796380850108 -1292.2803133506229187, -1552.9789722620623706 -1218.3910561800300911, -1668.4946747239471279 -1126.2565764086627951, -1679.3254791566805579 -1114.5821415641194108, -1680.0605373265407252 -1115.3491207030931491, -1702.7503708819851909 -1093.6036172334481762, -1770.9343685341837045 -1058.4171540195427497, -1770.1722772833329600 -1056.9403807575390601, -18
74.5379722620623397 -996.6740561800301066, -1895.7478836933294133 -979.7571858838782646, -1896.7182978644157174 -981.0996960943623435, -2746.6499049371641377 -366.7388744659292570, -2763.2967822031337164 -362.2768436281256186, -2790.5987539714260492 -334.9710818839997160, -2790.5987539714260492 -334.9710818839996023, -2842.3952978644156246 -297.5306960943622698, -2841.4248836933293205 -296.1881858838783614, -2935.7306747239472315 -220.9705764086628506, -3036.2247092860116027 -112.6488846962375874, -3086.2207836436286925 -39.3080148699587753, -3129.2862482014747911 3.7634279033554208, -3138.9918179090095691 39.9929298181513317, -3195.9318721744207323 131.7765582775780331, -3194.3605115562841092 132.7513874532058367, -3212.0423376604862824 158.6894340550911124, -3276.1445017965443185 291.8192670418299599, -3319.6893497161845517 433.0158891602736730, -3341.7042188351406367 579.1253871940372164, -3341.7041685876552037 580.2082322725017320, -3341.7842797495400191 580.202320676883
9145, -3358.7842797495400191 810.5783206768840046, -3358.7041685876552037 810.5842322725018221, -3358.6973623564326772 957.2601088689078779, -3336.6689334334319028 1103.3675631523476568, -3293.1109817488727458 1244.5601434214565870, -3260.5234971247000431 1312.2230153808816340, -3296.6374455479131029 1414.0631037763496352, -3294.8380822260414789 1414.7011836840215437, -3328.7143497161841879 1524.5468891602736221, -3349.7012648829327190 1663.8340056869151340, -3350.1912493926529351 1663.7938778131951949, -3510.7782493926529241 3624.6538778131953222, -3510.2882648829327081 3624.6940056869152613, -3511.3162188351402619 3631.5163871940371791), (-1458.2438853899545848 2786.7096887882385090, -1390.0104079583070416 1953.5395283355223910, -1308.4375544520867152 1723.5068962236503012, -1310.2333181418257482 1722.8700927968927772, -1276.3402423028999237 1612.9336566327281162, -1254.3389331776024846 1466.8221161070862308, -1254.3595026136681554 1319.0633957048662523, -1256.063974333603
7100 1307.7652980846462469, -1255.2787938929561733 1307.6972329071288641, -1257.2316394637061876 1285.1697643588329356, -1227.2802423028999783 1188.0186566327281525, -1205.2789331776025392 1041.9071161070862672, -1205.2904919563829935 958.8756534762312640, -798.3848875647835257 664.7497975144585780, -668.7086314658160973 597.8301540195427606, -669.4687336638634179 596.3572351253640136, -653.9962840476707697 587.4207017476531973, -634.6270161446395832 659.6966464095463607, 97.4196581300587923 1391.7094503287939915, 1097.3929445351700451 1659.6432199333848985, 2097.6867783781326580 1391.5243492190379584, 2485.1041348942267177 1003.9814942180254320, 2264.2788423241918281 2319.5541328332446938, 409.7273757065412383 2913.2071331414008455, -1458.2438853899545848 2786.7096887882385090))
+ <op name="areatest" arg1="A" arg2="B">
+ 1.5e-08
</op>
</test>
</case>
More information about the geos-commits
