[geos-commits] r3852 - trunk/tests/xmltester/tests
svn_geos at osgeo.org svn_geos at osgeo.org
Wed Jul 31 01:34:12 PDT 2013
Author: strk
Date: 2013-07-31 01:34:12 -0700 (Wed, 31 Jul 2013)
New Revision: 3852
   trunk/tests/xmltester/tests/buffer.xml
Do not expect invalid output from buffer
The test verification code is tollerant, but better fix this
Modified: trunk/tests/xmltester/tests/buffer.xml
--- trunk/tests/xmltester/tests/buffer.xml	2013-07-31 08:30:52 UTC (rev 3851)
+++ trunk/tests/xmltester/tests/buffer.xml	2013-07-31 08:34:12 UTC (rev 3852)
@@ -263,7 +263,7 @@
 </a>
 <test>
 <op name="buffer" arg1="a" arg2="1">
-	POLYGON ((-1.0000000000000000 9.9999999999999982, -0.9807852804032310 10.1950903220161262, -0.9238795325112880 10.3826834323650861, -0.8314696123025475 10.5555702330195995, -0.7071067811865505 10.7071067811865444, -0.5555702330196066 10.8314696123025431, -0.3826834323650944 10.9238795325112843, -0.1950903220161339 10.9807852804032287, -0.0000000000000064 11.0000000000000000, 0.0000000000000000 11.0000000000000000, 9.5857864376269042 11.0000000000000000, 19.2928932188134539 20.7071067811865461, 19.2928932188134539 20.7071067811865497, 19.4444297669803987 20.8314696123025449, 19.6173165676349122 20.9238795325112861, 19.8049096779838720 20.9807852804032322, 20.0000000000000000 21.0000000000000000, 20.1950903220161280 20.9807852804032287, 20.3826834323650914 20.9238795325112861, 20.5555702330196013 20.8314696123025449, 20.7071067811865461 20.7071067811865461, 20.8314696123025449 20.5555702330196013, 20.9238795325112861 20.3826834323650914, 20.9807852804032287 20.195090322016128
 0, 21.0000000000000000 20.0000000000000000, 20.9807852804032322 19.8049096779838720, 20.9238795325112861 19.6173165676349122, 20.8314696123025449 19.4444297669803987, 20.7071067811865461 19.2928932188134539, 11.0000000000000000 9.5857864376269042, 11.0000000000000000 0.0000000000000000, 10.9807852804032304 -0.1950903220161285, 10.9238795325112861 -0.3826834323650899, 10.8314696123025449 -0.5555702330196024, 10.7071067811865479 -0.7071067811865477, 10.5555702330196013 -0.8314696123025453, 10.3826834323650896 -0.9238795325112868, 10.1950903220161280 -0.9807852804032304, 10.0000000000000000 -1.0000000000000000, 9.8049096779838720 -0.9807852804032304, 9.6173165676349104 -0.9238795325112866, 9.4444297669803969 -0.8314696123025451, 9.2928932188134521 -0.7071067811865472, 9.2928932188134521 -0.7071067811865476, -0.7071067811865476 9.2928932188134521, -0.8314696123025448 9.4444297669803969, -0.9238795325112862 9.6173165676349086, -0.9807852804032300 9.8049096779838703, -1.0000000000
 000000 9.9999999999999982))
+POLYGON((0 11,9.5857864376269 11,19.2928932188135 20.7071067811865,19.4444297669804 20.8314696123025,19.6173165676349 20.9238795325113,19.8049096779839 20.9807852804032,20 21,20.1950903220161 20.9807852804032,20.3826834323651 20.9238795325113,20.5555702330196 20.8314696123025,20.7071067811865 20.7071067811865,20.8314696123025 20.5555702330196,20.9238795325113 20.3826834323651,20.9807852804032 20.1950903220161,21 20,20.9807852804032 19.8049096779839,20.9238795325113 19.6173165676349,20.8314696123025 19.4444297669804,20.7071067811865 19.2928932188135,11 9.5857864376269,11 0,10.9807852804032 -0.195090322016128,10.9238795325113 -0.38268343236509,10.8314696123025 -0.555570233019602,10.7071067811865 -0.707106781186548,10.5555702330196 -0.831469612302545,10.3826834323651 -0.923879532511287,10.1950903220161 -0.98078528040323,10 -1,9.80490967798387 -0.98078528040323,9.61731656763491 -0.923879532511287,9.4444297669804 -0.831469612302545,9.29289321881345 -0.707106781186547,-0.707106781
 186547 9.29289321881345,-0.831469612302545 9.4444297669804,-0.923879532511286 9.61731656763491,-0.98078528040323 9.80490967798387,-1 10,-0.980785280403231 10.1950903220161,-0.923879532511288 10.3826834323651,-0.831469612302547 10.5555702330196,-0.707106781186551 10.7071067811865,-0.555570233019607 10.8314696123025,-0.382683432365094 10.9238795325113,-0.195090322016134 10.9807852804032,0 11))
 </op>
 </test>
 </case>
More information about the geos-commits mailing list
