[geos-commits] r3853 - in trunk: . include/geos/geom include/geos/operation/overlay src/operation/overlay tests/xmltester tests/xmltester/tests/ticket
svn_geos at osgeo.org
Wed Jul 31 02:42:36 PDT 2013
Author: strk
Date: 2013-07-31 02:42:36 -0700 (Wed, 31 Jul 2013)
New Revision: 3853
Added:
trunk/tests/xmltester/tests/ticket/bug459.xml
trunk/NEWS
trunk/include/geos/geom/BinaryOp.h
trunk/include/geos/operation/overlay/OverlayOp.h
trunk/src/operation/overlay/OverlayOp.cpp
trunk/tests/xmltester/Makefile.am
trunk/tests/xmltester/tests/ticket/bug392.xml
trunk/tests/xmltester/tests/ticket/bug527.xml
trunk/tests/xmltester/tests/ticket/bug586.xml
trunk/tests/xmltester/tests/ticket/bug599.xml
Improve overlay robustness
- Validate CBR results before accepting them
- Enable overlay node validator even for FIXED precision
- Enable geometry-reduction policy
- Bail out on exception from overlay if any input is invalid
Fixes bug #459
Modified: trunk/NEWS
--- trunk/NEWS 2013-07-31 08:34:12 UTC (rev 3852)
+++ trunk/NEWS 2013-07-31 09:42:36 UTC (rev 3853)
@@ -11,6 +11,7 @@
- io::Writer::reserve() method
- CAPI: GEOSNearestPoints
- Add --cclibs, --static-clibs and --static-cclibs to geos-config (#497)
+ - Early bail out of overlay exception if input is invalid
- C++ API changes:
- New noding::GeometryNoder class
@@ -23,6 +24,8 @@
- NodedSegmentString takes ownership of CoordinateSenuence now
- io::Writer's toString() returns by const ref, write() takes a const ref
- Bug fixes / improvements
+ - Improve Overlay robustness by reducing input precision on topology
+ exception and by refusing to accept unnoded output (#459)
- Improve Buffer robustness by reducing input precision on topology
exception (#605)
- Fixed Linear Referencing API to handle MultiLineStrings consistently
Modified: trunk/include/geos/geom/BinaryOp.h
--- trunk/include/geos/geom/BinaryOp.h 2013-07-31 08:34:12 UTC (rev 3852)
+++ trunk/include/geos/geom/BinaryOp.h 2013-07-31 09:42:36 UTC (rev 3853)
@@ -49,16 +49,21 @@
#ifndef GEOS_GEOM_BINARYOP_H
#define GEOS_GEOM_BINARYOP_H
+#include <geos/algorithm/BoundaryNodeRule.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/GeometryCollection.h>
#include <geos/geom/Polygon.h>
+#include <geos/geom/Lineal.h>
#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/GeometryFactory.h>
#include <geos/precision/CommonBitsRemover.h>
#include <geos/precision/SimpleGeometryPrecisionReducer.h>
+#include <geos/precision/GeometryPrecisionReducer.h>
#include <geos/operation/overlay/snap/GeometrySnapper.h>
#include <geos/simplify/TopologyPreservingSimplifier.h>
+#include <geos/operation/IsSimpleOp.h>
#include <geos/operation/valid/IsValidOp.h>
#include <geos/operation/valid/TopologyValidationError.h>
#include <geos/util/TopologyException.h>
@@ -88,7 +93,7 @@
* robustness problems (handles TopologyExceptions)
#ifndef USE_PRECISION_REDUCTION_POLICY
-//# define USE_PRECISION_REDUCTION_POLICY 1
+# define USE_PRECISION_REDUCTION_POLICY 1
#endif
@@ -133,24 +138,41 @@
namespace geom { // geos::geom
inline bool
-check_valid(const Geometry& g, const std::string& label)
+check_valid(const Geometry& g, const std::string& label, bool doThrow=false, bool validOnly=false)
- operation::valid::IsValidOp ivo(&g);
- if ( ! ivo.isValid() )
+ if ( dynamic_cast<const Lineal*>(&g) ) {
+ if ( ! validOnly ) {
+ operation::IsSimpleOp sop(g, algorithm::BoundaryNodeRule::getBoundaryEndPoint());
+ if ( ! sop.isSimple() )
+ if ( doThrow ) {
+ throw geos::util::TopologyException(
+ label + " is not simple");
+ return false;
+ } else {
+ operation::valid::IsValidOp ivo(&g);
+ if ( ! ivo.isValid() )
+ using operation::valid::TopologyValidationError;
+ TopologyValidationError* err = ivo.getValidationError();
#ifdef GEOS_DEBUG_BINARYOP
- using operation::valid::TopologyValidationError;
- TopologyValidationError* err = ivo.getValidationError();
- std::cerr << label << " is INVALID: "
- << err->toString()
- << " (" << std::setprecision(20)
- << err->getCoordinate() << ")"
- << std::endl;
-#else
- (void)label;
+ std::cerr << label << " is INVALID: "
+ << err->toString()
+ << " (" << std::setprecision(20)
+ << err->getCoordinate() << ")"
+ << std::endl;
#endif
- return false;
+ if ( doThrow ) {
+ label + " is invalid: " + err->toString(),
+ err->getCoordinate());
+ return false;
return true;
@@ -254,12 +276,12 @@
GeometrySnapper snapper0( operand0 );
GeomPtr snapG0( snapper0.snapTo(operand1, snapTolerance) );
- snapG0 = fix_self_intersections(snapG0, "SNAP: snapped geom 0");
+ //snapG0 = fix_self_intersections(snapG0, "SNAP: snapped geom 0");
// NOTE: second geom is snapped on the snapped first one
GeometrySnapper snapper1( operand1 );
GeomPtr snapG1( snapper1.snapTo(*snapG0, snapTolerance) );
- snapG1 = fix_self_intersections(snapG1, "SNAP: snapped geom 1");
+ //snapG1 = fix_self_intersections(snapG1, "SNAP: snapped geom 1");
// Run the binary op
GeomPtr result( _Op(snapG0.get(), snapG1.get()) );
@@ -271,11 +293,10 @@
#if CBR_BEFORE_SNAPPING
// Add common bits back in
cbr.addCommonBits( result.get() );
- result = fix_self_intersections(result, "SNAP: result (after common-bits addition)");
-#endif
+ //result = fix_self_intersections(result, "SNAP: result (after common-bits addition)");
-#if GEOS_DEBUG_BINARYOP
- check_valid(*result, "SNAP: result (after common-bits addition");
+ check_valid(*result, "CBR: result (after common-bits addition)", true);
#endif
return result;
@@ -308,6 +329,9 @@
#endif
+ check_valid(*g0, "Input geom 0", true, true);
+ check_valid(*g1, "Input geom 1", true, true);
// Should we just give up here ?
check_valid(*g0, "Input geom 0");
@@ -316,7 +340,6 @@
#endif // USE_ORIGINAL_INPUT
#ifdef USE_COMMONBITS_POLICY
// Try removing common bits (possibly obsoleted by snapping below)
@@ -354,17 +377,8 @@
cbr.addCommonBits( ret.get() );
- check_valid(*ret, "CBR: result (after common-bits addition)");
-#endif
+ check_valid(*ret, "CBR: result (after common-bits addition)", true);
- // Common-bits removal policy could introduce self-intersections
- ret = fix_self_intersections(ret, "CBR: result (after common-bits addition)");
- check_valid(*ret, "CBR: result (after common-bits addition and fix_self_intersections)");
-#endif
#if GEOS_CHECK_COMMONBITS_VALIDITY
// check that result is a valid geometry after the
// reshift to orginal precision (see EnhancedPrecisionOp)
@@ -424,8 +438,6 @@
#endif // USE_SNAPPING_POLICY }
#if USE_PRECISION_REDUCTION_POLICY
@@ -433,29 +445,53 @@
// Try reducing precision
try
- int maxPrecision=25;
+ long unsigned int g0scale = g0->getFactory()->getPrecisionModel()->getScale();
+ long unsigned int g1scale = g1->getFactory()->getPrecisionModel()->getScale();
- for (int precision=maxPrecision; precision; --precision)
+#if GEOS_DEBUG_BINARYOP
+ std::cerr << "Original input scales are: "
+ << g0scale
+ << " and "
+ << g1scale
+ << std::endl;
+#endif
+ long unsigned int maxScale = 1e16;
+ // Don't use a scale bigger than the input one
+ if ( g0scale && g0scale < maxScale ) maxScale = g0scale;
+ if ( g1scale && g1scale < maxScale ) maxScale = g1scale;
+ for (long unsigned int scale=maxScale; scale >= 1; scale /= 10)
- std::auto_ptr<PrecisionModel> pm(new PrecisionModel(precision));
+ PrecisionModel pm(scale);
+ GeometryFactory gf(&pm);
- std::cerr << "Trying with precision " << precision << std::endl;
+ std::cerr << "Trying with scale " << scale << std::endl;
#endif
- precision::SimpleGeometryPrecisionReducer reducer( pm.get() );
- GeomPtr rG0( reducer.reduce(g0) );
- GeomPtr rG1( reducer.reduce(g1) );
+ precision::GeometryPrecisionReducer reducer( gf );
+ GeomPtr rG0( reducer.reduce(*g0) );
+ GeomPtr rG1( reducer.reduce(*g1) );
try
ret.reset( _Op(rG0.get(), rG1.get()) );
+ // restore original precision (least precision between inputs)
+ if ( g0->getFactory()->getPrecisionModel()->compareTo( g1->getFactory()->getPrecisionModel() ) < 0 ) {
+ ret.reset( g0->getFactory()->createGeometry(ret.get()) );
+ else {
+ ret.reset( g1->getFactory()->createGeometry(ret.get()) );
return ret;
catch (const geos::util::TopologyException& ex)
- if ( precision == 1 ) throw ex;
+ if ( scale == 1 ) throw ex;
- std::cerr << "Reduced with precision (" << precision << "): "
+ std::cerr << "Reduced with scale (" << scale << "): "
<< ex.what() << std::endl;
#endif
@@ -473,6 +509,10 @@
#endif
// USE_PRECISION_REDUCTION_POLICY }
#if USE_TP_SIMPLIFY_POLICY
Modified: trunk/include/geos/operation/overlay/OverlayOp.h
--- trunk/include/geos/operation/overlay/OverlayOp.h 2013-07-31 08:34:12 UTC (rev 3852)
+++ trunk/include/geos/operation/overlay/OverlayOp.h 2013-07-31 09:42:36 UTC (rev 3853)
@@ -12,7 +12,7 @@
- * Last port: operation/overlay/OverlayOp.java rev. 1.31 (JTS-1.10)
+ * Last port: operation/overlay/OverlayOp.java r567 (JTS-1.12+)
@@ -59,7 +59,7 @@
namespace operation { // geos::operation
namespace overlay { // geos::operation::overlay
-/// Computes the overlay of two Geometry.
+/// Computes the geometric overlay of two Geometry.
/// The overlay can be used to determine any
/// boolean combination of the geometries.
@@ -74,17 +74,42 @@
/// the resultants of the overlay.
enum OpCode {
- opINTERSECTION=1,
- opUNION,
- opDIFFERENCE,
- opSYMDIFFERENCE
+ /// The code for the Intersection overlay operation.
+ opINTERSECTION = 1,
+ /// The code for the Union overlay operation.
+ opUNION = 2,
+ /// The code for the Difference overlay operation.
+ opDIFFERENCE = 3,
+ /// The code for the Symmetric Difference overlay operation.
+ opSYMDIFFERENCE = 4
+ * Computes an overlay operation for the given geometry arguments.
+ * @param geom0 the first geometry argument
+ * @param geom1 the second geometry argument
+ * @param opCode the code for the desired overlay operation
+ * @return the result of the overlay operation
+ * @throws TopologyException if a robustness problem is encountered
static geom::Geometry* overlayOp(const geom::Geometry *geom0,
const geom::Geometry *geom1,
OpCode opCode);
//throw(TopologyException *);
+ * Tests whether a point with a given topological {@link Label}
+ * relative to two geometries is contained in
+ * the result of overlaying the geometries using
+ * a given overlay operation.
+ * The method handles arguments of {@link Location#NONE} correctly
+ * @param label the topological label of the point
+ * @param opCode the code for the overlay operation to test
+ * @return true if the label locations correspond to the overlayOpCode
static bool isResultOfOp(const geomgraph::Label& label, OpCode opCode);
/// This method will handle arguments of Location.NULL correctly
@@ -102,9 +127,23 @@
virtual ~OverlayOp(); // FIXME: virtual ?
- geom::Geometry* getResultGeometry(OpCode funcCode);
+ * Gets the result of the overlay for a given overlay operation.
+ * Note: this method can be called once only.
+ * @param overlayOpCode the overlay operation to perform
+ * @return the compute result geometry
+ geom::Geometry* getResultGeometry(OpCode overlayOpCode);
// throw(TopologyException *);
+ * Gets the graph constructed to compute the overlay.
+ * @return the overlay graph
geomgraph::PlanarGraph& getGraph() { return graph; }
/** \brief
Modified: trunk/src/operation/overlay/OverlayOp.cpp
--- trunk/src/operation/overlay/OverlayOp.cpp 2013-07-31 08:34:12 UTC (rev 3852)
+++ trunk/src/operation/overlay/OverlayOp.cpp 2013-07-31 09:42:36 UTC (rev 3853)
@@ -13,10 +13,8 @@
- * NOTE: Use of EdgeNodingValidator is not strictly the same
#include <geos/platform.h>
@@ -705,40 +703,31 @@
* In the future hopefully a faster check can be developed.
- if ( resultPrecisionModel->isFloating() ) // NOTE: this is not in JTS
+ try
+ // Will throw TopologyException if noding is
+ // found to be invalid
+ EdgeNodingValidator::checkValid(edgeList.getEdges());
+#ifdef GEOS_DEBUG_VALIDATION
+ cout << "EdgeNodingValidator accepted the noding" << endl;
+#endif
+ catch (const util::TopologyException& ex)
+ cout << "EdgeNodingValidator found noding invalid: " << ex.what() << endl;
+#endif
- try
- // Will throw TopologyException if noding is
- // found to be invalid
- EdgeNodingValidator::checkValid(edgeList.getEdges());
- catch (const util::TopologyException& ex)
-#ifdef GEOS_DEBUG_VALIDATION // {
- cout << "EdgeNodingValidator found noding invalid: " << ex.what() << endl;
-#endif // }
- // In the error scenario, the edgeList is not properly
- // deleted. Cannot add to the destructor of EdgeList
- // (as it should) because
- // "graph.addEdges(edgeList.getEdges());" below
- // takes over edgeList ownership in the success case.
- edgeList.clearList();
+ // In the error scenario, the edgeList is not properly
+ // deleted. Cannot add to the destructor of EdgeList
+ // (as it should) because
+ // "graph.addEdges(edgeList.getEdges());" below
+ // takes over edgeList ownership in the success case.
+ edgeList.clearList();
- throw ex;
- cout << "EdgeNodingValidator accepted the noding" << endl;
-#endif // }
+ throw ex;
- else
- cout << "Did not run EdgeNodingValidator as the precision model is not floating" << endl;
-#endif // GEOS_DEBUG_VALIDATION }
#endif // ENABLE_EDGE_NODING_VALIDATOR }
GEOS_CHECK_FOR_INTERRUPTS();
Modified: trunk/tests/xmltester/Makefile.am
--- trunk/tests/xmltester/Makefile.am 2013-07-31 08:34:12 UTC (rev 3852)
+++ trunk/tests/xmltester/Makefile.am 2013-07-31 09:42:36 UTC (rev 3853)
@@ -32,6 +32,7 @@
$(srcdir)/tests/ticket/bug392.xml \
$(srcdir)/tests/ticket/bug398.xml \
$(srcdir)/tests/ticket/bug434.xml \
+ $(srcdir)/tests/ticket/bug459.xml \
$(srcdir)/tests/ticket/bug527.xml \
$(srcdir)/tests/ticket/bug582.xml \
$(srcdir)/tests/ticket/bug586.xml \
Modified: trunk/tests/xmltester/tests/ticket/bug392.xml
--- trunk/tests/xmltester/tests/ticket/bug392.xml 2013-07-31 08:34:12 UTC (rev 3852)
+++ trunk/tests/xmltester/tests/ticket/bug392.xml 2013-07-31 09:42:36 UTC (rev 3853)
@@ -17,7 +17,7 @@
</test>
<test>
<op name="union" arg1="A">
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
362403B7A52D7FC9A42C0BE8575E31D536240DE91B1DAFC9A42C0CDEABBE31D536240C40DCFDAFC9A42C0010200000017000000CDEABBE31D536240C40DCFDAFC9A42C0DBF40C861F53624060FA038AFD9A42C0E8E6D143235362401EEB98A9FF9A42C0648918C025536240566133C0059B42C00702092F26536240959A3DD00A9B42C0AB4CE77926536240873C388E0E9B42C0077536892653624020EF552B139B42C09F5912A026536240C0A7DEBF1E9B42C05DC6A8C626536240987F9994279B42C0B9EEF7D526536240001EAC5A2D9B42C0AD88F5A1265362405BC0159A359B42C0A239FC7F26536240AC7EB61F3A9B42C05AE95A2026536240E6CC76853E9B42C07F4FAC5325536240881BA66C479B42C056ED3FD723536240F907DB99539B42C05C26796422536240B2C0B22D5E9B42C069780EC021536240BBB8E8BF629B42C0755776C12053624042D2020F679B42C07F5C2C561E53624090EE8C5B719B42C06B14ED851D5362409393E414789B42C05CB7F75F1D53624021BE5D40799B42C0472701201D536240E68013C0839B42C0C1BA9F8C1D536240FA9BD0F2889B42C0010200000003000000C1BA9F8C1D536240FA9BD0F2889B42C0A9DE75911D536240438B112E899B42C02B15B7931D536240D293414A899B42C00102000000060000002B15B7931D536240D2
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
F5EA0FF9A42C0E407F87F1F53624066FFF27FFD9A42C0CDEABBE31D536240C40DCFDAFC9A42C0010200000003000000CDEABBE31D536240C40DCFDAFC9A42C0EE0912DB1D5362408A9356D7FC9A42C0623B08DB1D5362403B7A52D7FC9A42C0010200000024000000623B08DB1D5362403B7A52D7FC9A42C0B75384E519536240F0A6B62FFB9A42C0EF33D362155362409320B7BAF79A42C0BB46263B1153624019A1E936F29A42C00D4059E70E536240D26AED22F19A42C005C314400C536240FC4BF7DFEF9A42C0C286A7570A536240FDDB65BFEE9A42C061DBA2CC06536240DAAF9696EC9A42C058C9C7EE025362403B2064B4E99A42C0F4F8BD4DFF5262400D38A682E59A42C051F932ACFD526240DBB28D89DE9A42C01A6B7F67FB52624035C703DBD29A42C02D697BAAF9526240E269430FC69A42C036AD1402F95262400E153EB6C09A42C02D3E05C0F85262409EEF0280BE9A42C007FE0120F8526240311BAE1FAC9A42C0915D0E60F65262406C58F89FA19A42C0D11CFE3FF352624005C655C0989A42C0EC55BF2DF35262403B21CF89989A42C04F47B6A9F0526240E569AFF4909A42C0773469AEEE526240AD557199899A42C0B0164449ED52624034C86EB0819A42C0106734A8EC526240A5D0C31A789A42C09348EC24EC526240149161156F9A42C01CE7DB27EC52
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
32928A09B42C0B2A7D370C052624072BF4351A09B42C0DC9FE63FBF5262401DC9E53FA49B42C05DE6CF12BF526240A04BDD3AA49B42C05491651CBE52624064613E0FA49B42C00417D0B0BD5262400573AA6BA39B42C03AFF1B20BD526240A728F27FA29B42C0DEAEF25FBB52624040964FA0999B42C007FE0120B8526240E613C31F8F9B42C07EECE4C2B752624087F71C588E9B42C02B39DD68B652624012B985538B9B42C0D4FCE71FB352624055E2957F889B42C0EA9BEA7FAF526240FEF0F3DF839B42C0593F0B9EAD5262409DE4954F809B42C0
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
D42C00102000000030000003A9702B96C5062400BBE498EEB9D42C0B05EFBB86C506240B7F3588EEB9D42C0BC7FE2B66C5062409FB18A92EB9D42C0010200000003000000BC7FE2B66C5062409FB18A92EB9D42C0D53A16806B5062406E3B2300EE9D42C0C68DB8D36A5062405EB86C75EF9D42C0010200000003000000C68DB8D36A5062405EB86C75EF9D42C002E264D16A506240A3BE767AEF9D42C05ED945CF6A506240E4AFAD7EEF9D42C00102000000030000005ED945CF6A506240E4AFAD7EEF9D42C0ACC1A0F169506240C6600F37F19D42C0A478A4056850624056DAF004F39D42C0010200000003000000A478A4056850624056DAF004F39D42C05F5B3FFD675062405A76D20CF39D42C0AD0008F56750624017362214F39D42C0010200000012000000AD0008F56750624017362214F39D42C0F199EC9F67506240E88CDE5FF39D42C0648918C065506240C52CC59FF29D42C0015CDABA65506240ADEAF6A3F29D42C0AE5D7FB765506240846B49A2F29D42C089B08630635062407DEA58A5F49D42C01E8D9EB661506240AAE683AFF99D42C07171546E62506240647DB905019E42C0A44808A062506240A5F04520039E42C0170912806450624013C25900099E42C0AABF14D466506240691D554D109E42C0EC0AC73D6750624032326DA4119E42C0C7A1D9D06850
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
FEFF0951624053AAE91FE99B42C01820D1040A516240946B651DE99B42C00102000000050000001820D1040A516240946B651DE99B42C0A1BEC0070A516240E869C020E99B42C0E2EFCD250B51624047BAB07FE89B42C0CAF21A600B516240304AD05FE89B42C062B933130C51624001BD9EF9E69B42C001020000000300000062B933130C51624001BD9EF9E69B42C029F8B7150C516240723F96F4E69B42C01236CF150C5162401D566AF4E69B42C00102000000040000001236CF150C5162401D566AF4E69B42C035A3D57F0C5162407E63192CE69B42C09C5C9DAD0D516240B5F81400E39B42C025AA5D670F516240B165B130DD9B42C001020000000400000025AA5D670F516240B165B130DD9B42C010EF94690F516240AC623B29DD9B42C0DD7305800F516240184740E0DC9B42C0A5AE6B6A0F516240EE23B726DD9B42C0010200000009000000D57036C2C7526240A85BD141F29942C0C50D0929C9526240FA25E2ADF39942C0F0B9B832CD52624051FDDE01F99942C079DE324CD2526240BB09BE69FA9942C061C7DA3AD3526240A3C7EF6DFA9942C02BC5E97FD45262406E3E6480FA9942C0BE1C2C52D7526240EB79ED88F99942C0F3B688DED8526240CE7AE706F99942C07D879512DB526240FAED9149F79942C00102000000030000007D879512DB526240FAED9
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
02000000030000006903899225536240DE36F4D0EA9B42C0648918C025536240C52CC59FF29B42C0547336742553624095F14B65F89B42C0010200000003000000547336742553624095F14B65F89B42C0611FF873255362401689096AF89B42C0A2FEEF73255362406D4F8D6AF89B42C0010200000004000000A2FEEF73255362406D4F8D6AF89B42C0E14ED83425536240618A7269FC9B42C04F89905F245362400455A357039C42C05770EB7223536240C4AE8EAD089C42C00102000000030000005770EB7223536240C4AE8EAD089C42C080E2B66C2353624084D95FD1089C42C035909A532353624032FB0262099C42C001020000001200000035909A532353624032FB0262099C42C094FF7F52235362402B8E5E68099C42C02F68210123536240D6E5EF390B9C42C015D9733E21536240AA549ADE0F9C42C013FFC1D11F5362403DD4B661149C42C0A65714C01E536240E82510C0179C42C021E7FD7F1C53624061E75C401E9C42C049360D40195362408DA90540269C42C0C1E50C2017536240A06B5F402F9C42C0A77E390E17536240210AC105349C42C06EB99FF816536240AE9E93DE379C42C08F6A7D36175362405DBB59283E9C42C0D955ED3F17536240F7EFB03F3F9C42C02CF587C11753624072EB7FCA429C42C06516461F18536240651DE967459C42C01FFC7
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
80B452624013DD6921B79942C0F72B5382B4526240690712CAB19942C091D6732DB5526240824CD7B8A39942C07610E099B55262404533AA679C9942C0F66DD27EB552624096027745959942C05F5BE443B5526240265305A3929942C0BB1006F9B4526240B583B641929942C01853FA53B45262403EDD8A0E929942C0BCB77DEAB35262405B66C7FC929942C07702AB34B35262402A60F18A969942C0B0822914B3526240B678C25C9C9942C0A54DD53DB25262407B832F4CA69942C0B365AF2DB252624063F9A9E0A69942C05E5CF45FB152624053EB5800AE9942C096804EF7B0526240DB807456B09942C001020000000400000096804EF7B0526240DB807456B09942C02891E975B05262405768D608B39942C0A68AF381AE526240E645DC52BD9942C00CDD9867AE526240D44A0AF5BD9942C00102000000030000000CDD9867AE526240D44A0AF5BD9942C04138B066AE5262402DF2A1FABD9942C01E8BE95DAE526240F4112D30BE9942C001020000001B0000001E8BE95DAE526240F4112D30BE9942C04BDB0940AD52624018B14F00C59942C0FB7A1920AC526240FC2257A0CC9942C0ECAAF69FAB52624024343800D19942C034153D4BAB526240632BC313D59942C0016C9B3DAB526240335F6FACD59942C0F02EBC37AB52624074345882D69942C0C66AF3FFAA526
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
</op>
</test>
</case>
Added: trunk/tests/xmltester/tests/ticket/bug459.xml
--- trunk/tests/xmltester/tests/ticket/bug459.xml (rev 0)
+++ trunk/tests/xmltester/tests/ticket/bug459.xml 2013-07-31 09:42:36 UTC (rev 3853)
@@ -0,0 +1,21 @@
+<run>
+ <desc>http://trac.osgeo.org/geos/ticket/459</desc>
+ <precisionModel type="FLOATING" />
+<case>
+ <a>
+0102000000080000003C0AD7E32D4E3A4152B81E250A4452412085EB91284A3A417A14AE2719445241285C8F42354A3A41A4703D6A1E445241CCCCCC0C474A3A415C8FC2851E445241C4F5289C4B4A3A415C8FC2C52B445241BE08DEAE534E3A41B1B518AB1F44524100000000604E3A419A9999C9064452413C0AD7E32D4E3A4152B81E250A445241
+ </a>
+ <b>
+010200000009000000B89C2EFE364A3A41DFC087291F445241545C8F42354A3A41A4703D6A1E4452418CEC6D6F354A3A41FE7E44D31D44524136C80FA4394A3A412D7F89121D445241409B06043D4A3A415860C1CC1C445241360D6849404A3A4136B46EC91C445241FC25CB4B474A3A41B72FD41F1D445241CDCCCC0C474A3A415C8FC2851E445241181E3474434A3A4116CE6F471F445241
+ </b>
+<test>
+ <op name="union" arg1="A" arg2="B">
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
+ </op>
+</test>
+</case>
+</run>
Modified: trunk/tests/xmltester/tests/ticket/bug527.xml
--- trunk/tests/xmltester/tests/ticket/bug527.xml 2013-07-31 08:34:12 UTC (rev 3852)
+++ trunk/tests/xmltester/tests/ticket/bug527.xml 2013-07-31 09:42:36 UTC (rev 3853)
@@ -19,7 +19,7 @@
</a>
<test>
<op name='union' arg1='A' >
-MULTILINESTRING ((1725064.1365604456514120 4819094.7023506900295615, 1725064.1365604463499039 4819094.7023506900295615), (1725064.1418305356055498 4819094.7022763714194298, 1725064.1418388199526817 4819094.7020855704322457, 1725064.1365604465827346 4819094.7023506900295615), (1725064.1418305356055498 4819094.7022763714194298, 1725064.1421036201063544 4819094.7022725204005837), (1725064.1365604465827346 4819094.7023506900295615, 1725064.1418305356055498 4819094.7022763714194298), (1725064.1365604465827346 4819094.7023506900295615, 1725064.1365604463499039 4819094.7023506900295615), (1725064.1365604440215975 4819094.7023506900295615, 1725064.1365604400634766 4819094.7023506900295615), (1725064.1365604456514120 4819094.7023506900295615, 1725064.1365604440215975 4819094.7023506900295615), (1725063.0000000000000000 4819121.0000000000000000, 1725064.1418305356055498 4819094.7022763714194298), (1725064.1365604400634766 4819094.7023506900295615, 1725064.1365604300517589 4819094.7023
506900295615, 1725063.0000000000000000 4819121.0000000000000000))
+MULTILINESTRING((1725063 4819121,1725064.14183054 4819094.70227637),(1725064.14183054 4819094.70227637,1725064.14183882 4819094.70208557,1725064.13656044 4819094.70235069),(1725064.13656044 4819094.70235069,1725064.14183054 4819094.70227637),(1725064.14183054 4819094.70227637,1725064.14210362 4819094.70227252,1725064.14183054 4819094.70227637),(1725064.13656044 4819094.70235069,1725064.13656043 4819094.70235069,1725063 4819121))
</op>
</test>
</case>
Modified: trunk/tests/xmltester/tests/ticket/bug586.xml
--- trunk/tests/xmltester/tests/ticket/bug586.xml 2013-07-31 08:34:12 UTC (rev 3852)
+++ trunk/tests/xmltester/tests/ticket/bug586.xml 2013-07-31 09:42:36 UTC (rev 3853)
@@ -13,7 +13,7 @@
</b>
<test>
<op name="intersection" arg1="A" arg2="B">
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
5BDC19754C005172B6A305D454001020000000200000024C79DD2C19754C08D2991442F5D4540B4BB28C4C19754C00A16BD662F5D454001020000000200000024C79DD2C19754C08D2991442F5D454035D474C6C19754C0AAA8196D2F5D454001020000000200000025C79DD2C19754C077BE9F1A2F5D4540EE0C476FC19754C08694AE7B2E5D454001020000000200000025C79DD2C19754C077BE9F1A2F5D454051F379D0C19754C0D31F81092F5D454001020000000200000026C79DD2C19754C078BE9F1A2F5D454052F379D0C19754C0D41F81092F5D454001020000000200000026C79DD2C19754C078BE9F1A2F5D454025C79DD2C19754C077BE9F1A2F5D45400102000000020000007A3251D6C19754C01A193B382F5D454024C79DD2C19754C08D2991442F5D45400102000000020000007A3251D6C19754C01A193B382F5D454025C79DD2C19754C077BE9F1A2F5D45400102000000020000007A3251D6C19754C019193B382F5D454026C79DD2C19754C078BE9F1A2F5D45400102000000020000007A3251D6C19754C019193B382F5D45407A3251D6C19754C01A193B382F5D454001020000000200000037D8A9D6C19754C00347003B2F5D454024C79DD2C19754C08D2991442F5D454001020000000200000037D8A9D6C19754C00347003B2F5D45407A3251D6C1
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
0B4497969315D4540A74C579DC29754C0AF0AE72D315D45400102000000020000002A6C20BBC29754C0B4497969315D4540DBC165ACC29754C0B2542F79315D4540010200000002000000A0DB14D6C29754C0D0D2B84C315D454036C7BC88C29754C05E8B043E305D4540010200000002000000A0DB14D6C29754C0D0D2B84C315D45402A6C20BBC29754C0B4497969315D4540
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
9D0C19754C0012081092F5D45400102000000020000007E3251D6C19754C03B193B382F5D454026C79DD2C19754C0892991442F5D45400102000000020000007E3251D6C19754C03B193B382F5D454026C79DD2C19754C077BE9F1A2F5D454001020000000200000023D8A9D6C19754C0F146003B2F5D454026C79DD2C19754C0892991442F5D454001020000000200000023D8A9D6C19754C0F146003B2F5D45407E3251D6C19754C03B193B382F5D454001020000000200000016481EDBC19754C096263A282F5D454026C79DD2C19754C077BE9F1A2F5D454001020000000200000016481EDBC19754C096263A282F5D45407E3251D6C19754C03B193B382F5D454001020000000200000084C232DDC19754C0901D8E2B2F5D454023D8A9D6C19754C0F146003B2F5D454001020000000200000084C232DDC19754C0901D8E2B2F5D454016481EDBC19754C096263A282F5D4540010200000002000000F36444DEC19754C0861BBB1D2F5D454057F379D0C19754C0012081092F5D4540010200000002000000F36444DEC19754C0861BBB1D2F5D454016481EDBC19754C096263A282F5D4540010200000002000000DE0033DFC19754C01D739EB12F5D4540FF3EE3C2C19754C05FEFFE782F5D4540010200000002000000DE0033DFC19754C01D739EB12F5D45401DD474C6C1
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
200000002000000DE327644C29754C0C71C63A9325D45408542232FC29754C05598CBFE315D4540010200000002000000A328DC48C29754C07E60725E2F5D4540392F7E2DC29754C04577A9FE2E5D4540010200000002000000A328DC48C29754C07E60725E2F5D4540E107733CC29754C0D1B271492F5D454001020000000200000065122C57C29754C0DCE60ECF2F5D4540D56B7321C29754C01D5944802F5D454001020000000200000065122C57C29754C0DCE60ECF2F5D4540E107733CC29754C0D1B271492F5D4540010200000002000000EA6DA85EC29754C05D428FF92D5D4540E060DFA3C19754C057322B162D5D4540010200000002000000EA6DA85EC29754C05D428FF92D5D45408EE0D019C29754C0EEED469C2E5D454001020000000200000001847B60C29754C046209CFD2F5D45406DB6D72CC29754C04B70FCAA2F5D454001020000000200000001847B60C29754C046209CFD2F5D454065122C57C29754C0DCE60ECF2F5D4540010200000002000000EC913668C29754C0B732EAC1315D45408FFBFB1EC29754C04B62917D315D4540010200000002000000EC913668C29754C0B732EAC1315D45408542232FC29754C05598CBFE315D4540010200000002000000EA20F971C29754C062E412112E5D45405BDA5F2CC29754C035CF11F92E5D454001020000
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
A9DB14D6C29754C0AAD2B84C315D454050C7BC88C29754C04F8B043E305D4540010200000002000000A9DB14D6C29754C0AAD2B84C315D4540456C20BBC29754C0EB497969315D4540
</op>
</test>
</case>
Modified: trunk/tests/xmltester/tests/ticket/bug599.xml
--- trunk/tests/xmltester/tests/ticket/bug599.xml 2013-07-31 08:34:12 UTC (rev 3852)
+++ trunk/tests/xmltester/tests/ticket/bug599.xml 2013-07-31 09:42:36 UTC (rev 3853)
@@ -22,7 +22,7 @@
</test>
<test>
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
E07549400102000000020000005842D2020F27ED3FBD378600E075494041DFCC9EBA28ED3F9DBB0276DA75494001020000000200000041DFCC9EBA28ED3F9DBB0276DA754940D4C78D6CF827ED3FD40E7F4DD6754940010200000002000000D4C78D6CF827ED3FD40E7F4DD6754940F150B92EA127ED3FDBBD816ED4754940010200000002000000D4C78D6CF827ED3FD40E7F4DD6754940640FA3D6EA21ED3F22A98592C9754940010200000002000000640FA3D6EA21ED3F22A98592C9754940893F790E1B1BED3FEF8A85C6B8754940
</op>
</test>
</case>
More information about the geos-commits
