[geos-commits] r3807 - trunk/src/operation/overlay/snap
svn_geos at osgeo.org
Thu Jun 6 09:39:20 PDT 2013
Author: strk
Date: 2013-06-06 09:39:20 -0700 (Thu, 06 Jun 2013)
New Revision: 3807
trunk/src/operation/overlay/snap/LineStringSnapper.cpp
Drop commented out / disabled code
Modified: trunk/src/operation/overlay/snap/LineStringSnapper.cpp
--- trunk/src/operation/overlay/snap/LineStringSnapper.cpp 2013-06-05 22:18:13 UTC (rev 3806)
+++ trunk/src/operation/overlay/snap/LineStringSnapper.cpp 2013-06-06 16:39:20 UTC (rev 3807)
@@ -107,81 +107,7 @@
return match;
-/*private*/
-#if 0 // changed to start looping from snap points
-void
-LineStringSnapper::snapVertices(geom::CoordinateList& srcCoords,
- const geom::Coordinate::ConstVect& snapPts)
- if ( srcCoords.empty() ) return;
-#if GEOS_DEBUG
-cerr << "Snapping vertices of: " << std::setprecision(15) << srcCoords << endl;
-#endif
- using geom::CoordinateList;
- geom::Coordinate::ConstVect::const_iterator not_found = snapPts.end();
- // try snapping vertices
- // if src is a ring then don't snap final vertex
- CoordinateList::iterator it = srcCoords.begin();
- CoordinateList::iterator end = srcCoords.end();
- CoordinateList::iterator last = end; --last;
- if ( isClosed ) --end;
- for ( ; it != end; ++it )
- Coordinate& srcPt = *it;
-#if GEOS_DEBUG
-cerr << "Checking for a snap for source coordinate " << srcPt << endl;
-#endif
- geom::Coordinate::ConstVect::const_iterator found = findSnapForVertex(srcPt, snapPts);
- if ( found == not_found )
- { // no snaps found (or no need to snap)
-#if GEOS_DEBUG
-cerr << " no snap found" << endl;
-#endif
- continue;
- assert(*found);
- const Coordinate& snapPt = *(*found);
-#if 1
- // Check if closest vertex for found snap is ourselves ?
- CoordinateList::iterator vertpos = findVertexToSnap(snapPt, srcCoords.begin(), srcCoords.end());
- if ( vertpos != it ) {
-#if GEOS_DEBUG
-cerr << " Snap found but it has a vertex point closer than this one" << endl;
- continue;
-#endif
-#endif
-#if GEOS_DEBUG
-cerr << " found snap point " << snapPt << endl;
-#endif
- // update src with snap pt
- *it = snapPt;
-#if GEOS_DEBUG
-cerr << " source point became " << srcPt << endl;
-#endif
- // keep final closing point in synch (rings only)
- if (it == srcCoords.begin() && isClosed)
- *last = snapPt;
-#endif
-#if 1
/*private*/
void
@@ -218,19 +144,7 @@
continue;
-#if 0
- // Check if closest snap for found vertex is ourselves ?
- Coordinate::ConstVect::const_iterator snappos =
- findSnapForVertex(*vertpos, snapPts);
- if ( snappos != it ) {
#if GEOS_DEBUG
-cerr << " Vertex found but it has a snap point closer than this one" << endl;
- continue;
-#endif
-#endif
-#if GEOS_DEBUG
cerr << " Vertex to be snapped found, snapping" << endl;
#endif
*vertpos = snapPt;
@@ -249,7 +163,6 @@
#endif
-#endif
/*private*/
More information about the geos-commits
