[geos-commits] r3808 - trunk/examples
svn_geos at osgeo.org
Thu Jun 6 13:18:50 PDT 2013
Author: strk
Date: 2013-06-06 13:18:50 -0700 (Thu, 06 Jun 2013)
New Revision: 3808
Removed:
trunk/examples/CPCLException.cpp
trunk/examples/CoordinateSequencesExample.cpp
trunk/examples/CustomCoordinateSequenceExample.cpp
trunk/examples/CustomCoordinateSequenceExample.h
trunk/examples/CustomPointCoordinateSequence.cpp
trunk/examples/Makefile.am
Drop obsoleted files
Deleted: trunk/examples/CPCLException.cpp
--- trunk/examples/CPCLException.cpp 2013-06-06 16:39:20 UTC (rev 3807)
+++ trunk/examples/CPCLException.cpp 2013-06-06 20:18:50 UTC (rev 3808)
@@ -1,32 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
-#include "CustomCoordinateSequenceExample.h"
-#include <geos/util.h>
-using namespace geos;
-CPCLException::CPCLException()
- GEOSException("CPCLException", "")
-CPCLException::CPCLException(const string& msg)
- GEOSException("CPCLException", msg)
-CPCLException::~CPCLException(){}
Deleted: trunk/examples/CoordinateSequencesExample.cpp
--- trunk/examples/CoordinateSequencesExample.cpp 2013-06-06 16:39:20 UTC (rev 3807)
+++ trunk/examples/CoordinateSequencesExample.cpp 2013-06-06 20:18:50 UTC (rev 3808)
@@ -1,108 +0,0 @@
- * WARNING! This example is obsoleted, read doc/example.cpp for
- * an updated example.
-#include <iostream>
-#include <geos/io.h>
-#include <geos/geom.h>
-#include <geos/geosAlgorithm.h>
-using namespace std;
-int main(int argc, char** argv)
- try {
- cout << "Start:" << endl << endl;
- CoordinateSequence *cl1=new CoordinateArraySequence();
- //CoordinateSequence cl1 is empty
- cout << endl << "CoordinateSequence cl1: " << cl1->toString() << endl;
- //Adding points
- cl1->add(*(new Coordinate(140,120)));
- cl1->add(*(new Coordinate(160,20)));
- cl1->add(*(new Coordinate(33,33)));
- cl1->add(*(new Coordinate(20,20)));
- cl1->add(*(new Coordinate(11,11)));
- cout << "CoordinateSequence cl1: " << cl1->toString() << endl;
- //Changing point
- cl1->setAt(*(new Coordinate(20,120)),4);
- //Deleting point
- cl1->deleteAt(2);
- //Switching CoordinateSequenceFactory to create PointCoordinateSequences
- //PointCoordinateSequence is a sample implementation of a user-defined
- //CoordinateSequence based on a vector of struct {3 x double}
- CoordinateSequenceFactory::internalFactory=new PointCoordinateSequenceFactory();
- //Now calls to CoordinateSequenceFactory would create PointCoordinateSequences
- CoordinateSequence *cl2=CoordinateSequenceFactory::internalFactory->createCoordinateSequence();
- //It is also possible to explicitly create PointCoordinateSequences
- //CoordinateSequence *cl2=new PointCoordinateSequence();
- //CoordinateSequence cl2 is empty
- cout << endl << "CoordinateSequence cl2: " << cl2->toString() << endl;
- //Adding points
- //Points could be added as Coordinates
- cl2->add(*(new Coordinate(11,11)));
- cl2->add(*(new Coordinate(140,200)));
- cl2->add(*(new Coordinate(33,33)));
- //or using native PointCoordinateSequence format
- point_3d p1={240,200,DoubleNotANumber};
- point_3d p2={55,55,DoubleNotANumber};
- point_3d p3={140,120,DoubleNotANumber};
- ((PointCoordinateSequence*) cl2)->add(p1);
- ((PointCoordinateSequence*) cl2)->add(p2);
- ((PointCoordinateSequence*) cl2)->add(p3);
- cout << "CoordinateSequence cl2: " << cl2->toString() << endl;
- //Changing point
- //Points can be set using Coordinates
- cl2->setAt(*(new Coordinate(240,120)),4);
- point_3d pn={140,120,DoubleNotANumber};
- ((PointCoordinateSequence*) cl2)->setAt(pn,0);
- //Deleting point
- cl2->deleteAt(2);
- //To do the operations:
- //First we need to create a GeometryFactory
- GeometryFactory *gf=new GeometryFactory(new PrecisionModel(),0);
- //Now we can create Geometries
- Geometry *geom1=gf->createPolygon(gf->createLinearRing(cl1),NULL);
- cout << endl << "Geometry 1:" << endl << geom1->toString() << endl;
- Geometry *geom2=gf->createPolygon(gf->createLinearRing(cl2),NULL);
- cout << endl << "Geometry 2:" << endl << geom2->toString() << endl;
- //And see how they relate to each other
- IntersectionMatrix *im=geom1->relate(geom2);
- cout << endl << "Result of relate() operation should be \"FF2F01212\"" << endl;
- cout << "Result is: " << im->toString() << endl;
- cout << "End" << endl;
- } catch (const GEOSException& ge) {
- cout << ge->toString() << endl;
- return 0;
Deleted: trunk/examples/CustomCoordinateSequenceExample.cpp
--- trunk/examples/CustomCoordinateSequenceExample.cpp 2013-06-06 16:39:20 UTC (rev 3807)
+++ trunk/examples/CustomCoordinateSequenceExample.cpp 2013-06-06 20:18:50 UTC (rev 3808)
@@ -1,82 +0,0 @@
-int main(int argc, char** argv) {
- try {
- //CustomPointCoordinateSequence is a sample implementation of a user-defined
- //wrapper around their internal storage format (array of point_3d struct {3 x double})
- point_3d p1={11,11,DoubleNotANumber};
- point_3d p2={140,200,DoubleNotANumber};
- point_3d p3={240,200,DoubleNotANumber};
- point_3d p4={55,55,DoubleNotANumber};
- point_3d p5={140,120,DoubleNotANumber};
- //Array of point_3d (internal storage format)
- point_3d points[5];
- points[0]=p1;
- points[1]=p2;
- points[2]=p3;
- points[3]=p4;
- points[4]=p5;
- //Creating CoordinateSequence
- CoordinateSequence *cl=new CustomPointCoordinateSequence(points,5);
- cout << endl << "CoordinateSequence cl: " << cl->toString() << endl;
- //Changing point
- cl->setAt(*(new Coordinate(240,120)),3);
- //or using native CustomPointCoordinateSequence format
- ((CustomPointCoordinateSequence*) cl)->setAt(pn,0);
- cout << "CoordinateSequence cl: " << cl->toString() << endl;
- //Since the underlying storage format is a fixed size array
- //points can't be added or deleted
- //cl->add(*(new Coordinate(240,120)),4); //Would cause exception
- //cl->deleteAt(2); //Would cause exception
- //Now we can create a Geometry
- Geometry *geom=gf->createPolygon(gf->createLinearRing(cl),NULL);
- cout << endl << "Geometry:" << endl << geom->toString() << endl;
- //And see if the geometry is valid
- cout << "Geometry is valid? " << (geom->isValid()?"true":"false") << endl;
- cout << ge.what() << endl;
- return 0;
Deleted: trunk/examples/CustomCoordinateSequenceExample.h
--- trunk/examples/CustomCoordinateSequenceExample.h 2013-06-06 16:39:20 UTC (rev 3807)
+++ trunk/examples/CustomCoordinateSequenceExample.h 2013-06-06 20:18:50 UTC (rev 3808)
@@ -1,66 +0,0 @@
-#ifndef GEOS_EX2_H
-#define GEOS_EX2_H
-#include <geos/platform.h>
- * This is an example of how you can create a custom CoordinateSequence class that wraps
- * your own way of storing lists of coordinates. Depending on your internal storage
- * format some methods in the wrapper class might not work properly (but have to be
- * preserved for the interface compatibility. In this example CustomPointCoordinateSequence
- * wraps an array of point_3d. Since the array is fixed length, methods like 'add' or
- * 'deleteAt' will not work.
-class CustomPointCoordinateSequence : public BasicCoordinateSequence {
-public:
- CustomPointCoordinateSequence(point_3d *newPts,int newSize);
- CustomPointCoordinateSequence(const CustomPointCoordinateSequence &cl);
- bool isEmpty();
- void add(Coordinate& c); //NoOp (exception)
- void add(point_3d p); //NoOp (exception)
- int getSize();
- Coordinate& getAt(int pos);
- point_3d getPointAt(int pos);
- void setAt(Coordinate& c, int pos);
- void setAt(point_3d p, int pos);
- void deleteAt(int pos); //NoOp (exception)
- vector<Coordinate>* toVector();
- vector<point_3d>* toPointVector();
- string toString();
- void setPoints(const vector<Coordinate> &v);
- void setPoints(const vector<point_3d> &v);
-private:
- point_3d *pts;
- int size;
-class CPCLException: public GEOSException {
-public:
- CPCLException();
- CPCLException(const string& msg);
- ~CPCLException();
-#endif
Deleted: trunk/examples/CustomPointCoordinateSequence.cpp
--- trunk/examples/CustomPointCoordinateSequence.cpp 2013-06-06 16:39:20 UTC (rev 3807)
+++ trunk/examples/CustomPointCoordinateSequence.cpp 2013-06-06 20:18:50 UTC (rev 3808)
@@ -1,137 +0,0 @@
-#include <sstream>
-CustomPointCoordinateSequence::CustomPointCoordinateSequence(point_3d *newPts,int newSize) {
- pts=newPts;
- size=newSize;
-CustomPointCoordinateSequence::CustomPointCoordinateSequence(const CustomPointCoordinateSequence &c) {
- pts=c.pts;
- size=c.size;
-void CustomPointCoordinateSequence::setPoints(const vector<Coordinate> &v) {
- if(v.size()==size) {
- point_3d pt;
- for(int i=0;i<(int)v.size(); i++) {
- pt.x=v[i].x;
- pt.y=v[i].y;
- pt.z=v[i].z;
- pts[i]=pt;
- } else {
- throw CPCLException("size mismatch\n");
-void CustomPointCoordinateSequence::setPoints(const vector<point_3d> &v) {
- pts[i]=v[i];
- } else {
-vector<Coordinate>* CustomPointCoordinateSequence::toVector() {
- vector<Coordinate>* v=new vector<Coordinate>();
- for(int i=0;i<size;i++) {
- v->push_back(*(new Coordinate(pts[i].x,pts[i].y,pts[i].z)));
- return v;
-vector<point_3d>* CustomPointCoordinateSequence::toPointVector() {
- vector<point_3d>* v=new vector<point_3d>();
- v->push_back(pts[i]);
- return v;
-bool CustomPointCoordinateSequence::isEmpty() {
- return size==0;
-void CustomPointCoordinateSequence::add(Coordinate& c){
- throw CPCLException("list's size can't be modified\n");
-void CustomPointCoordinateSequence::add(point_3d p){
-int CustomPointCoordinateSequence::getSize(){
- return size;
-Coordinate& CustomPointCoordinateSequence::getAt(int pos){
- point_3d pt;
- if (pos>=0 && pos<size) {
- pt=pts[pos];
- return *(new Coordinate(pt.x,pt.y,pt.z));
- } else
- throw CPCLException("can't retrieve element\n");
-point_3d CustomPointCoordinateSequence::getPointAt(int pos){
- return pts[pos];
- } else
-void CustomPointCoordinateSequence::setAt(Coordinate& c, int pos){
- point_3d pt={c.x,c.y,c.z};
- pts[pos]=pt;
- else
- throw CPCLException("can't change element\n");
-void CustomPointCoordinateSequence::setAt(point_3d p, int pos){
- pts[pos]=p;
- else
-void CustomPointCoordinateSequence::deleteAt(int pos){
-string CustomPointCoordinateSequence::toString() {
- ostringstream s;
- //string result("");
- //char buffer[100];
- for (int i=0;i<size;i++) {
- point_3d c=pts[i];
- //sprintf(buffer,"(%g,%g,%g) ",c.x,c.y,c.z);
- s<<"("<<c.x<<","<<c.y<<","<<c.z<<") ";
- //result.append(buffer);
- //result.append("");
- //return result;
- return s.str();
Deleted: trunk/examples/Makefile.am
--- trunk/examples/Makefile.am 2013-06-06 16:39:20 UTC (rev 3807)
+++ trunk/examples/Makefile.am 2013-06-06 20:18:50 UTC (rev 3808)
@@ -1,23 +0,0 @@
-# This file is part of project GEOS (http://trac.osgeo.org/geos/)
-noinst_PROGRAMS = \
- CoordinateSequencesExample \
- CustomCoordinateSequenceExample
-LIBS = $(top_srcdir)/src/geom/libgeos.la
-# -lmpatrol -lbfd -lintl -liberty -limagehlp
-CustomCoordinateSequenceExample_SOURCES = \
- CustomPointCoordinateSequence.cpp \
- CustomCoordinateSequenceExample.cpp \
- CPCLException.cpp \
- CustomCoordinateSequenceExample.h
-CustomCoordinateSequenceExample_LDADD = $(LIBS)
-CoordinateSequencesExample_SOURCES = CoordinateSequencesExample.cpp
-CoordinateSequencesExample_LDADD = $(LIBS)
-INCLUDES = -I$(top_srcdir)/include
-INCLUDES += -I$(top_srcdir)/io/markup
More information about the geos-commits
