[geos-commits] r3815 - in branches/3.3: . include/geos
svn_geos at osgeo.org
Tue Jun 11 05:36:30 PDT 2013
Author: strk
Date: 2013-06-11 05:36:24 -0700 (Tue, 11 Jun 2013)
New Revision: 3815
branches/3.3/NEWS
branches/3.3/include/geos/profiler.h
Fix for mingw64 compile, by Regina Obe (#630)
Modified: branches/3.3/NEWS
--- branches/3.3/NEWS 2013-06-07 09:29:05 UTC (rev 3814)
+++ branches/3.3/NEWS 2013-06-11 12:36:24 UTC (rev 3815)
@@ -7,6 +7,7 @@
- Fix RobustLineIntersector handling of invalid intersection points (#622)
- Reduce likelyhood of invalid output from snap operation (#629, #501)
- Reduce memory fragmentation of prepared Polygon/Point intersection op
+ - Fix mingw64 compile (#630)
Changes in 3.3.8
2013-02-28
Modified: branches/3.3/include/geos/profiler.h
--- branches/3.3/include/geos/profiler.h 2013-06-07 09:29:05 UTC (rev 3814)
+++ branches/3.3/include/geos/profiler.h 2013-06-11 12:36:24 UTC (rev 3815)
@@ -16,10 +16,12 @@
#ifndef GEOS_PROFILER_H
#define GEOS_PROFILER_H
+#include <stdlib.h> /** need this to correctly detect MINGW64 **/
#include <geos/export.h>
/* For MingW builds with __STRICT_ANSI__ (-ansi) */
-#if defined(__MINGW32__)
+/** MINGW64 doesn't have a config.h **/
+#if defined(__MINGW32__) && !defined(__MINGW64_VERSION_MAJOR)
/* Allow us to check for presence of gettimeofday in MingW */
#include <config.h>
@@ -32,7 +34,7 @@
#endif
-#if defined(_MSC_VER) || defined(__MINGW32__) && !defined(HAVE_GETTIMEOFDAY)
+#if defined(_MSC_VER) || defined(__MINGW32__) && !defined(HAVE_GETTIMEOFDAY) && !defined(__MINGW64_VERSION_MAJOR)
#include <geos/timeval.h>
#else
#include <sys/time.h>
More information about the geos-commits
