[geos-commits] r3816 - in trunk: . include/geos
svn_geos at osgeo.org
Tue Jun 11 05:42:27 PDT 2013
Author: strk
Date: 2013-06-11 05:42:27 -0700 (Tue, 11 Jun 2013)
New Revision: 3816
trunk/NEWS
trunk/include/geos/profiler.h
Fix for mingw64 compile, by Regina Obe (#630)
Modified: trunk/NEWS
--- trunk/NEWS 2013-06-11 12:36:24 UTC (rev 3815)
+++ trunk/NEWS 2013-06-11 12:42:27 UTC (rev 3816)
@@ -1,6 +1,85 @@
Changes in 3.4.0
+Changes in 3.3.8
+2013-02-28
+- Bug fixes / improvements
+ - IsValidOp: throw proper error on nested shells (#608)
+ - Fix header guards (#617, #618, #619)
+ - WKTWriter::appendCoordinate optimisation
+ - Fix centroid computation for collections with empty components (#582)
+Changes in 3.3.7
+2013-01-22
+ - Fix abort in RightmostEdgeFinder (#605)
+ - Do not force precision reduction below 6 significant digits
+ while trying to obtain a valid Buffer output (#605)
+ - Fix GEOSPointOnSurface with zero-length linestring (#609)
+ - Fix EMPTY return from zero-area polygon (#613)
+ - Segfault from symdifference (#615)
+Changes in 3.3.6
+2012-11-15 -- that's Post-GIS day !
+ - Add support for testing with phpunit 3.6 (not loosing support for 3.4)
+ - Segfault from intersection (#586, #598, #599)
+Changes in 3.3.5
+2012-06-25
+ - Correctly increment CAPI lib version from 3.3.3 (#558)
+ - Port robustness fix to CentroidArea (#559)
+ - Always return POINT from GEOSGetCentroid, even for EMPTY (#560)
+ - Always return POINT from GEOSPointOnSurface, even for EMPTY (#561)
+Changes in 3.3.4
+2012-05-31
+ - Do not abort on NaN overlay input (#530)
+ - Reduce CommonBitsRemover harmful effects during overlay op (#527)
+ - Better cross-compiler support (#534)
+ - Enable overlay ops short-circuits (#542)
+ - Envelope-based short-circuit for symDifference (#543)
+ - Fix support for PHP 5.4 (#513)
+ - Fix TopologyPreservingSimplifier invalid output on closed line (#508)
+ - Reduce calls to ptNotInList, greatly speeding up Polygonizer (#545)
+Changes in 3.3.3
+2012-04-01
+ - Fix simplification of collections with empty items (#519)
+ - Fix MSVC compilation of ambiguous log() call (#506)
+ - Fix CMake issues with std:: namespace detection (#493)
+Changes in 3.3.2
+2012-01-05
+ - Fix CMAKE_CXX_FLAGS overriding -std=gnu++0x (#489)
+ - Missing versions update in CMake configuration (#490)
+ - Fix noding of self-intersecting lines through UnaryUnion (#482)
+ - Fix handling of collapsed edges skipping in BufferOp (#494)
+ - Print up to 18 digits of precision for TopologyException points
+ - Fix noding with reduced precision in Buffer operation (#473)
+ - Fix HotPixel original point invalidation (#498)
+ - Fix CascadedPolygonUnion to discard non-polygonal components (#499)
+ - Improve buffer robustness by reverting to non-snaprounding noder (#495)
+ - Fix C++11 build by avoiding std::pair<auto_ptr> (#491)
+ - Add --clibs to geos-config and GEOS_C_LIBS to geos.m4 (#497)
+ - Apply shoelace formula for area calculation (#485)
+ - Fix default initialization issue for clang (#500)
+ - Improve overlay robustness by fixing areal validity on snapping (#488)
+Changes in 3.3.1
+2011-09-27
- New things:
- Delaunay Triangulation API (#487, #565, #570)
- Interruptibility API (C and C++)
Modified: trunk/include/geos/profiler.h
--- trunk/include/geos/profiler.h 2013-06-11 12:36:24 UTC (rev 3815)
+++ trunk/include/geos/profiler.h 2013-06-11 12:42:27 UTC (rev 3816)
@@ -15,10 +15,12 @@
#ifndef GEOS_PROFILER_H
#define GEOS_PROFILER_H
+#include <stdlib.h> /** need this to correctly detect MINGW64 **/
#include <geos/export.h>
/* For MingW builds with __STRICT_ANSI__ (-ansi) */
-#if defined(__MINGW32__)
+/** MINGW64 doesn't have a config.h **/
+#if defined(__MINGW32__) && !defined(__MINGW64_VERSION_MAJOR)
/* Allow us to check for presence of gettimeofday in MingW */
#include <config.h>
@@ -31,7 +33,7 @@
#endif
-#if defined(_MSC_VER) || defined(__MINGW32__) && !defined(HAVE_GETTIMEOFDAY)
+#if defined(_MSC_VER) || defined(__MINGW32__) && !defined(HAVE_GETTIMEOFDAY) && !defined(__MINGW64_VERSION_MAJOR)
#include <geos/timeval.h>
#else
#include <sys/time.h>
More information about the geos-commits
