[geos-commits] r3821 - in trunk/tests/unit: . operation/buffer
svn_geos at osgeo.org
Wed Jun 12 06:22:48 PDT 2013
Author: mloskot
Date: 2013-06-12 06:22:48 -0700 (Wed, 12 Jun 2013)
New Revision: 3821
Added:
trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp
trunk/tests/unit/Makefile.am
Add updated C++ API test case for the left/right offset curve (ticket #633)
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2013-06-12 09:56:59 UTC (rev 3820)
+++ trunk/tests/unit/Makefile.am 2013-06-12 13:22:48 UTC (rev 3821)
@@ -80,6 +80,7 @@
noding/SegmentPointComparatorTest.cpp \
noding/snapround/HotPixelTest.cpp \
noding/snapround/MCIndexSnapRounderTest.cpp \
+ operation/buffer/BufferBuilderTest.cpp \
operation/buffer/BufferOpTest.cpp \
operation/buffer/BufferParametersTest.cpp \
operation/distance/DistanceOpTest.cpp \
Added: trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp
--- trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp (rev 0)
+++ trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp 2013-06-12 13:22:48 UTC (rev 3821)
@@ -0,0 +1,112 @@
+// Test Suite for geos::operation::buffer::BufferBuilder class.
+// tut
+#include <tut.hpp>
+// geos
+#include <geos/operation/buffer/BufferBuilder.h>
+#include <geos/operation/buffer/BufferParameters.h>
+#include <geos/platform.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/algorithm/PointLocator.h>
+#include <geos/io/WKTReader.h>
+#include <geos/geom/CoordinateSequence.h>
+// std
+#include <memory>
+#include <string>
+#include <vector>
+namespace tut
+ // Test Group
+ // Common data used by tests
+ struct test_bufferbuilder_data
+ geos::geom::GeometryFactory gf;
+ geos::io::WKTReader wktreader;
+ int const default_quadrant_segments;
+ typedef geos::geom::Geometry::AutoPtr GeomPtr;
+ typedef std::auto_ptr<geos::geom::CoordinateSequence> CSPtr;
+ test_bufferbuilder_data()
+ : gf(), wktreader(&gf), default_quadrant_segments(geos::operation::buffer::BufferParameters::DEFAULT_QUADRANT_SEGMENTS)
+ ensure_equals(default_quadrant_segments, int(8));
+ private:
+ // noncopyable
+ test_bufferbuilder_data(test_bufferbuilder_data const& other);
+ test_bufferbuilder_data& operator=(test_bufferbuilder_data const& rhs);
+ typedef test_group<test_bufferbuilder_data> group;
+ typedef group::object object;
+ group test_bufferbuilder_group("geos::operation::buffer::BufferBuilder");
+ // Test Cases
+ // Left-side and right-side offset curve
+ // See http://trac.osgeo.org/geos/ticket/633
+ template<>
+ template<>
+ void object::test<1>()
+ using geos::operation::buffer::BufferBuilder;
+ using geos::operation::buffer::BufferParameters;
+ // Original input from test in ticket #633
+ //std::string wkt0("LINESTRING ("
+ // "665.7317504882812500 133.0762634277343700,"
+ // "1774.4752197265625000 19.9391822814941410,"
+ // "756.2413940429687500 466.8306579589843700,"
+ // "626.1337890625000000 1898.0147705078125000,"
+ // "433.8007202148437500 404.6052856445312500)");
+ //double const distance = 57.164000837203;
+ // Simplified equivalent input
+ std::string wkt0("LINESTRING(0 0, 50 -10, 10 10, 0 50, -10 10)");
+ double const distance = 5;
+ GeomPtr g0(wktreader.read(wkt0));
+ ensure(0 != g0.get());
+ ensure_equals(g0->getNumPoints(), std::size_t(5));
+ BufferParameters params;
+ params.setEndCapStyle(BufferParameters::CAP_FLAT);
+ params.setQuadrantSegments(8);
+ params.setJoinStyle(BufferParameters::JOIN_MITRE);
+ params.setMitreLimit(5.57F);
+ //params.setSingleSided(true); // DO NOT switch for non-areal input, see ticket #633
+ BufferBuilder builder(params);
+ ensure(distance > 0);
+ // left-side
+ GeomPtr gBuffer(builder.bufferLineSingleSided(g0.get(), distance, true));
+ ensure(0 != gBuffer.get());
+ ensure_equals(gBuffer->getGeometryTypeId(), geos::geom::GEOS_LINESTRING);
+ // Left-side offset curve expected with 5+ vertices
+ ensure(gBuffer->getNumPoints() >= g0->getNumPoints());
+ // right-side
+ GeomPtr gBuffer(builder.bufferLineSingleSided(g0.get(), distance, false));
+ // Right-side offset curve expected with 5+ vertices
+} // namespace tut
More information about the geos-commits
