[geos-commits] r3822 - trunk/tests/unit/operation/buffer
svn_geos at osgeo.org
Wed Jun 12 07:06:44 PDT 2013
Author: mloskot
Date: 2013-06-12 07:06:44 -0700 (Wed, 12 Jun 2013)
New Revision: 3822
trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp
Update single side offset curve tests to check uniform coordinates order in output (ticket #633). We need to decide if BufferBuilder::bufferLineSingleSided should take care of reversing coordinates if necessary.
Modified: trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp
--- trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp 2013-06-12 13:22:48 UTC (rev 3821)
+++ trunk/tests/unit/operation/buffer/BufferBuilderTest.cpp 2013-06-12 14:06:44 UTC (rev 3822)
@@ -10,7 +10,9 @@
#include <geos/geom/Coordinate.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Geometry.h>
+#include <geos/geom/LineString.h>
#include <geos/algorithm/PointLocator.h>
+#include <geos/algorithm/CGAlgorithms.h>
#include <geos/io/WKTReader.h>
#include <geos/geom/CoordinateSequence.h>
// std
@@ -62,6 +64,8 @@
using geos::operation::buffer::BufferBuilder;
using geos::operation::buffer::BufferParameters;
+ using geos::algorithm::CGAlgorithms;
+ using geos::geom::LineString;
// Original input from test in ticket #633
//std::string wkt0("LINESTRING ("
@@ -91,20 +95,30 @@
// left-side
- GeomPtr gBuffer(builder.bufferLineSingleSided(g0.get(), distance, true));
- ensure(0 != gBuffer.get());
- ensure_equals(gBuffer->getGeometryTypeId(), geos::geom::GEOS_LINESTRING);
+ GeomPtr gB(builder.bufferLineSingleSided(g0.get(), distance, true));
+ ensure(0 != gB.get());
+ ensure_equals(gB->getGeometryTypeId(), geos::geom::GEOS_LINESTRING);
// Left-side offset curve expected with 5+ vertices
- ensure(gBuffer->getNumPoints() >= g0->getNumPoints());
+ ensure(gB->getNumPoints() >= g0->getNumPoints());
+ ensure_equals(
+ CGAlgorithms::isCCW(dynamic_cast<LineString*>(g0.get())->getCoordinatesRO()),
+ CGAlgorithms::isCCW(dynamic_cast<LineString*>(gB.get())->getCoordinatesRO()));
// right-side
- GeomPtr gBuffer(builder.bufferLineSingleSided(g0.get(), distance, false));
+ GeomPtr gB(builder.bufferLineSingleSided(g0.get(), distance, false));
// Right-side offset curve expected with 5+ vertices
+ // FIXME: this check if failing
+ // We need to decide if bufferLineSingleSided should take care of reversing coords order --mloskot
+ //ensure_equals(
+ // CGAlgorithms::isCCW(dynamic_cast<LineString*>(g0.get())->getCoordinatesRO()),
+ // CGAlgorithms::isCCW(dynamic_cast<LineString*>(gB.get())->getCoordinatesRO()));
More information about the geos-commits
