[geos-commits] r4020 - in branches/3.4: . php
svn_geos at osgeo.org
Wed Sep 24 00:54:58 PDT 2014
Author: strk
Date: 2014-09-24 00:54:58 -0700 (Wed, 24 Sep 2014)
New Revision: 4020
branches/3.4/NEWS
branches/3.4/php/geos.c
Fixed compilation against thread-safe PHP (ZTS)
Closes #541
Patch-by: Benjamin Morel <benjamin.morel at gmail.com>
Signed-off-by: Sandro Santilli <strk at keybit.net>
Modified: branches/3.4/NEWS
--- branches/3.4/NEWS 2014-09-24 07:52:27 UTC (rev 4019)
+++ branches/3.4/NEWS 2014-09-24 07:54:58 UTC (rev 4020)
@@ -2,6 +2,7 @@
YYYY-MM-DD
- Bug fixes / improvements
+ - Fixed compilation against thread-safe PHP (#541)
- Fix Empty to Empty equals (#703)
- Fix build on OpenBSD (#700)
- Fix build on HP-UX 11.23 (#664)
Modified: branches/3.4/php/geos.c
--- branches/3.4/php/geos.c 2014-09-24 07:52:27 UTC (rev 4019)
+++ branches/3.4/php/geos.c 2014-09-24 07:54:58 UTC (rev 4020)
@@ -78,6 +78,7 @@
static void noticeHandler(const char *fmt, ...)
+ TSRMLS_FETCH();
char message[256];
va_list args;
va_start(args, fmt);
@@ -89,6 +90,7 @@
static void errorHandler(const char *fmt, ...)
+ TSRMLS_FETCH();
char message[256];
va_list args;
@@ -96,7 +98,7 @@
va_end(args);
/* TODO: use a GEOSException ? */
- zend_throw_exception_ex(zend_exception_get_default(TSRMLS_CC),
+ zend_throw_exception_ex(zend_exception_get_default(TSRMLS_C),
1 TSRMLS_CC, "%s", message);
@@ -108,12 +110,14 @@
static void
setRelay(zval* val, void* obj) {
+ TSRMLS_FETCH();
Proxy* proxy = (Proxy*)zend_object_store_get_object(val TSRMLS_CC);
proxy->relay = obj;
static inline void *
getRelay(zval* val, zend_class_entry* ce) {
+ TSRMLS_FETCH();
Proxy *proxy = (Proxy*)zend_object_store_get_object(val TSRMLS_CC);
if ( proxy->std.ce != ce ) {
php_error_docref(NULL TSRMLS_CC, E_ERROR,
@@ -153,9 +157,10 @@
static zend_object_value
-Gen_create_obj (zend_class_entry *type TSRMLS_DC,
+Gen_create_obj (zend_class_entry *type,
zend_objects_free_object_storage_t st, zend_object_handlers* handlers)
+ TSRMLS_FETCH();
zval *tmp;
zend_object_value retval;
@@ -411,6 +416,7 @@
static void
dumpGeometry(GEOSGeometry* g, zval* array)
+ TSRMLS_FETCH();
int ngeoms, i;
More information about the geos-commits
