[geos-commits] r4021 - in trunk: . capi include/geos/operation	include/geos/operation/intersection src/geom src/operation	src/operation/intersection tests/unit tests/unit/capi	tests/unit/operation tests/unit/operation/intersection
    svn_geos at osgeo.org
    Thu Sep 25 03:46:21 PDT 2014
Author: strk
Date: 2014-09-25 03:46:20 -0700 (Thu, 25 Sep 2014)
New Revision: 4021
Added:
   trunk/include/geos/operation/intersection/
   trunk/include/geos/operation/intersection/Makefile.am
   trunk/include/geos/operation/intersection/Rectangle.h
   trunk/include/geos/operation/intersection/RectangleIntersection.h
   trunk/include/geos/operation/intersection/RectangleIntersectionBuilder.h
   trunk/src/operation/intersection/
   trunk/src/operation/intersection/Makefile.am
   trunk/src/operation/intersection/Rectangle.cpp
   trunk/src/operation/intersection/RectangleIntersection.cpp
   trunk/src/operation/intersection/RectangleIntersectionBuilder.cpp
   trunk/tests/unit/capi/GEOSClipByRectTest.cpp
   trunk/tests/unit/operation/intersection/
   trunk/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
   trunk/NEWS
   trunk/capi/geos_c.cpp
   trunk/capi/geos_c.h.in
   trunk/capi/geos_ts_c.cpp
   trunk/configure.ac
   trunk/include/geos/operation/Makefile.am
   trunk/src/geom/Geometry.cpp
   trunk/src/operation/Makefile.am
   trunk/tests/unit/Makefile.am
Add optimized RectangleIntersection functionality
Includes:
 C++ API, with tests
 C-API GEOSClipByRect, with tests
Initial C++ code provided by Mika Heiskanen.
Modified by me to work with arbitrarily ordered polygon ring vertices.
See #699 for background
Modified: trunk/NEWS
--- trunk/NEWS	2014-09-24 07:54:58 UTC (rev 4020)
+++ trunk/NEWS	2014-09-25 10:46:20 UTC (rev 4021)
@@ -6,6 +6,7 @@
   - PHP: Geometry->normalize method
   - GEOS_USE_ONLY_R_API macro support (#695)
   - PHP: WKBReader->read() & WKBWriter::write() methods (Benjamin Morel)
+  - RectangleIntersection, GEOSClipByRect (Mika Heiskanen, Sandro Santilli)
 - Improvements:
   - Speed-up intersection and difference between geometries
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp	2014-09-24 07:54:58 UTC (rev 4020)
+++ trunk/capi/geos_c.cpp	2014-09-25 10:46:20 UTC (rev 4021)
@@ -485,6 +485,11 @@
+Geometry *
+GEOSClipByRect(const Geometry *g, double xmin, double ymin, double xmax, double ymax)
+    return GEOSClipByRect_r( handle, g, xmin, ymin, xmax, ymax );
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in	2014-09-24 07:54:58 UTC (rev 4020)
+++ trunk/capi/geos_c.h.in	2014-09-25 10:46:20 UTC (rev 4021)
@@ -511,6 +511,12 @@
                                                 const GEOSGeometry* g);
 extern GEOSGeometry GEOS_DLL *GEOSNode_r(GEOSContextHandle_t handle,
+/* Fast, non-robust intersection between an arbitrary geometry and
+ * a rectangle. The returned geometry may be invalid. */
+extern GEOSGeometry GEOS_DLL *GEOSClipByRect_r(GEOSContextHandle_t handle,
+                                                 const GEOSGeometry* g,
+                                                 double xmin, double ymin,
+                                                 double xmax, double ymax);
  * all arguments remain ownership of the caller
@@ -1366,6 +1372,7 @@
 extern GEOSGeometry GEOS_DLL *GEOSPointOnSurface(const GEOSGeometry* g);
 extern GEOSGeometry GEOS_DLL *GEOSGetCentroid(const GEOSGeometry* g);
 extern GEOSGeometry GEOS_DLL *GEOSNode(const GEOSGeometry* g);
+extern GEOSGeometry GEOS_DLL *GEOSClipByRect(const GEOSGeometry* g, double xmin, double ymin, double xmax, double ymax);
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp	2014-09-24 07:54:58 UTC (rev 4020)
+++ trunk/capi/geos_ts_c.cpp	2014-09-25 10:46:20 UTC (rev 4021)
@@ -54,6 +54,8 @@
 #include <geos/operation/linemerge/LineMerger.h>
 #include <geos/operation/overlay/OverlayOp.h>
 #include <geos/operation/overlay/snap/GeometrySnapper.h>
+#include <geos/operation/intersection/Rectangle.h>
+#include <geos/operation/intersection/RectangleIntersection.h>
 #include <geos/operation/polygonize/Polygonizer.h>
 #include <geos/operation/relate/RelateOp.h>
 #include <geos/operation/sharedpaths/SharedPathsOp.h>
@@ -2158,6 +2160,48 @@
     return NULL;
+Geometry *
+GEOSClipByRect_r(GEOSContextHandle_t extHandle, const Geometry *g, double xmin, double ymin, double xmax, double ymax)
+    if ( 0 == extHandle )
+        return NULL;
+    GEOSContextHandleInternal_t *handle = 0;
+    handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+    if ( 0 == handle->initialized )
+        return NULL;
+    try
+        using geos::operation::intersection::Rectangle;
+        using geos::operation::intersection::RectangleIntersection;
+        Rectangle rect(xmin, ymin, xmax, ymax);
+        std::auto_ptr<Geometry> g3 = RectangleIntersection::clip(*g, rect);
+        return g3.release();
+    catch (const std::exception &e)
+#if VERBOSE_EXCEPTIONS
+        std::ostringstream s;
+        s << "Exception on GEOSClipByRect with following inputs:" << std::endl;
+        s << "A: "<<g1->toString() << std::endl;
+        s << "B: "<<g2->toString() << std::endl;
+        handle->NOTICE_MESSAGE("%s", s.str().c_str());
+#endif // VERBOSE_EXCEPTIONS
+        handle->ERROR_MESSAGE("%s", e.what());
+    catch (...)
+        handle->ERROR_MESSAGE("Unknown exception thrown");
+    return NULL;
 // memory management functions
Modified: trunk/configure.ac
--- trunk/configure.ac	2014-09-24 07:54:58 UTC (rev 4020)
+++ trunk/configure.ac	2014-09-25 10:46:20 UTC (rev 4021)
@@ -453,6 +453,7 @@
 	include/geos/operation/buffer/Makefile
 	include/geos/operation/distance/Makefile
+	include/geos/operation/intersection/Makefile
 	include/geos/operation/linemerge/Makefile
 	include/geos/operation/overlay/Makefile
 	include/geos/operation/overlay/snap/Makefile
@@ -484,6 +485,7 @@
 	src/operation/buffer/Makefile
 	src/operation/distance/Makefile
+	src/operation/intersection/Makefile
 	src/operation/linemerge/Makefile
 	src/operation/overlay/Makefile
 	src/operation/polygonize/Makefile
Modified: trunk/include/geos/operation/Makefile.am
--- trunk/include/geos/operation/Makefile.am	2014-09-24 07:54:58 UTC (rev 4020)
+++ trunk/include/geos/operation/Makefile.am	2014-09-25 10:46:20 UTC (rev 4021)
@@ -4,6 +4,7 @@
 SUBDIRS = \
     buffer \
     distance \
+    intersection \
     linemerge \
     overlay \
     polygonize \
Added: trunk/include/geos/operation/intersection/Makefile.am
--- trunk/include/geos/operation/intersection/Makefile.am	                        (rev 0)
+++ trunk/include/geos/operation/intersection/Makefile.am	2014-09-25 10:46:20 UTC (rev 4021)
@@ -0,0 +1,13 @@
+# This file is part of project GEOS (http://trac.osgeo.org/geos/)
+#SUBDIRS =
+#EXTRA_DIST =
+geosdir = $(includedir)/geos/operation/intersection
+geos_HEADERS = \
+  Rectangle.h \
+  RectangleIntersection.h \
+  RectangleIntersectionBuilder.h
Added: trunk/include/geos/operation/intersection/Rectangle.h
--- trunk/include/geos/operation/intersection/Rectangle.h	                        (rev 0)
+++ trunk/include/geos/operation/intersection/Rectangle.h	2014-09-25 10:46:20 UTC (rev 4021)
@@ -0,0 +1,209 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2014 Mika Heiskanen <mika.heiskanen at fmi.fi>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#ifndef GEOS_OP_INTERSECTION_RECTANGLE_H
+#define GEOS_OP_INTERSECTION_RECTANGLE_H
+#include <geos/export.h>
+#ifdef _MSC_VER
+#pragma warning(push)
+#pragma warning(disable: 4251) // warning C4251: needs to have dll-interface to be used by clients of class
+#endif
+// Forward declarations
+namespace geos {
+  namespace geom {
+	class GeometryFactory;
+	class Geometry;
+	class Polygon;
+	class LinearRing;
+namespace geos {
+namespace operation { // geos::operation
+namespace intersection { // geos::operation::intersection
+ * \brief Clipping rectangle
+ * A clipping rectangle defines the boundaries of the rectangle
+ * by defining the limiting x- and y-coordinates. The clipping
+ * rectangle must be non-empty. In addition, methods are provided
+ * for specifying the location of a given coordinate with respect
+ * to the clipping rectangle similarly to the Cohen-Sutherland
+ * clipping algorithm.
+class GEOS_DLL Rectangle
+ public:
+   * \brief Construct a clipping rectangle
+   * @param x1 x-coordinate of the left edge
+   * @param y1 y-coordinate of the bottom edge
+   * @param x2 x-coordinate of the right edge
+   * @param y2 y-coordinate of the right edge
+   * @throws IllegalArgumentException if the rectangle is empty
+  Rectangle(double x1, double y1, double x2, double y2);
+   * \@return the minimum x-coordinate of the rectangle
+  double xmin() const { return xMin; }
+   * \@return the minimum y-coordinate of the rectangle
+  double ymin() const { return yMin; }
+   * \@return the maximum x-coordinate of the rectangle
+  double xmax() const { return xMax; }
+   * \@return the maximum y-coordinate of the rectangle
+  double ymax() const { return yMax; }
+   * \@return the rectangle as a polygon geometry
+   * Ownership transferred to caller
+	geom::Polygon* toPolygon(const geom::GeometryFactory &f) const;
+	geom::LinearRing* toLinearRing(const geom::GeometryFactory &f) const;
+   * @brief Position with respect to a clipping rectangle
+  enum Position
+	Inside    = 1,
+	Outside   = 2,
+	Left        = 4,
+	Top         = 8,
+	Right       = 16,
+	Bottom      = 32,
+	TopLeft     = Top|Left,                 // 12
+	TopRight    = Top|Right,                // 24
+	BottomLeft  = Bottom|Left,              // 36
+	BottomRight = Bottom|Right              // 48
+   * @brief Test if the given position is on a {@link Rectangle] edge
+   * @param pos {@link Rectangle} {@link Position}
+   * @return true, if the position is on an edge
+  static bool onEdge(Position pos)
+	return (pos > Outside);
+   * @brief Test if the given positions are on the same {@link Rectangle} edge
+   * @param pos1 {@link Rectangle} {@link Position} of first coordinate
+   * @param pos2 {@link Rectangle} {@link Position} of second coordinate
+   * @return true, if the positions are on the same edge
+  static bool onSameEdge(Position pos1, Position pos2)
+	return onEdge(Position(pos1 & pos2));
+   * @brief Establish position of coordinate with respect to a {@link Rectangle}
+   * @param x x-coordinate
+   * @param y y-coordinate
+   * @return {@link Position} of the coordinate
+  Position position(double x, double y) const
+	// We assume the point to be inside and test it first
+	if(x>xMin && x<xMax && y>yMin && y<yMax)
+	  return Inside;
+	// Next we assume the point to be outside and test it next
+	if(x<xMin || x>xMax || y<yMin || y>yMax)
+	  return Outside;
+	// Slower cases
+	unsigned int pos = 0;
+	if(x==xMin)
+	  pos |= Left;
+	else if(x==xMax)
+	  pos |= Right;
+	if(y==yMin)
+	  pos |= Bottom;
+	else if(y==yMax)
+	  pos |= Top;
+	return Position(pos);
+   * @brief Next edge in clock-wise direction
+   * @return next {@Rectangle} {@link Position} in clock-wise direction
+  static Position nextEdge(Position pos)
+	switch(pos)
+	  case BottomLeft:
+	  case Left:       return Top;
+	  case TopLeft:
+	  case Top:        return Right;
+	  case TopRight:
+	  case Right:      return Bottom;
+	  case BottomRight:
+	  case Bottom:     return Left;
+	  /* silences compiler warnings, Inside & Outside are not handled explicitly */
+	  default:         return pos;
+ private:
+  Rectangle();
+  double xMin;
+  double yMin;
+  double xMax;
+  double yMax;
+}; // class RectangleIntersection
+} // namespace geos::operation::intersection
+#endif // GEOS_OP_INTERSECTION_RECTANGLE_H
Added: trunk/include/geos/operation/intersection/RectangleIntersection.h
--- trunk/include/geos/operation/intersection/RectangleIntersection.h	                        (rev 0)
+++ trunk/include/geos/operation/intersection/RectangleIntersection.h	2014-09-25 10:46:20 UTC (rev 4021)
@@ -0,0 +1,179 @@
+#ifndef GEOS_OP_RECTANGLE_INTERSECTION_H
+#define GEOS_OP_RECTANGLE_INTERSECTION_H
+#include <memory>
+#ifdef _MSC_VER
+#endif
+namespace geos {
+  namespace geom {
+	  class Point;
+	  class MultiPoint;
+	  class Polygon;
+	  class MultiPolygon;
+	  class LineString;
+	  class MultiLineString;
+	  class Geometry;
+	  class GeometryCollection;
+	  class CoordinateSequenceFactory;
+  namespace operation {
+	namespace intersection {
+	  class Rectangle;
+	  class RectangleIntersectionBuilder;
+namespace geos {
+ * \brief Speed-optimized clipping of a {@link Geometry} with a rectangle.
+ * Two different methods are provided. The first performs normal
+ * clipping, the second clips the boundaries of polygons, not
+ * the polygons themselves. In the first case a polygon will remain
+ * a polygon or is completely cut out. In the latter case polygons
+ * will be converted to polylines if any vertex is outside the clipping
+ * rectangle, or will be cut out completely.
+ * The algorithm works best when the number of intersections is very low.
+ * For example, if the geometry is completely to the left of the
+ * clipping rectangle, only the x-coordinate of the geometry is ever
+ * tested and is only compared with the x-coordinate of the left edge
+ * of the rectangle. Hence clipping may be faster than calculating
+ * the envelope of the geometry for trivial overlap tests.
+ * The input geometry must be valid. In particular all {@link LinearRing}s must
+ * be properly closed, or the algorithm may not terminate.
+class GEOS_DLL RectangleIntersection
+ public:
+   * \brief Clip geometry with a rectangle
+   * @param geom a {@link Geometry}
+   * @param rect a {@link Rectangle}
+   * @return the clipped geometry
+   * @return NULL if the geometry is outside the {@link Rectangle}
+  static std::auto_ptr<geom::Geometry> clip(const geom::Geometry & geom,
+							   const Rectangle & rect);
+   * \brief Clip boundary of a geometry with a rectangle
+   * Any polygon which intersects the rectangle will be converted to
+   * a polyline or a multipolyline - including the holes.
+  static std::auto_ptr<geom::Geometry> clipBoundary(const geom::Geometry & geom,
+private:
+  RectangleIntersection(const geom::Geometry& geom, const Rectangle& rect);
+  std::auto_ptr<geom::Geometry> clipBoundary();
+  std::auto_ptr<geom::Geometry> clip();
+  const geom::Geometry &_geom;
+  const Rectangle &_rect;
+  const geom::GeometryFactory *_gf;
+  const geom::CoordinateSequenceFactory *_csf;
+  void clip_geom(const geom::Geometry * g,
+           RectangleIntersectionBuilder & parts,
+           const Rectangle & rect,
+           bool keep_polygons);
+  void clip_point(const geom::Point * g,
+  void clip_multipoint(const geom::MultiPoint * g,
+  void clip_linestring(const geom::LineString * g,
+  void clip_multilinestring(const geom::MultiLineString * g,
+  void clip_polygon(const geom::Polygon * g,
+  void clip_multipolygon(const geom::MultiPolygon * g,
+  void clip_geometrycollection(
+               const geom::GeometryCollection * g,
+  void clip_polygon_to_linestrings(const geom::Polygon * g,
+  void clip_polygon_to_polygons(const geom::Polygon * g,
+   * \brief Clip geometry.
+   * Returns true if the geometry was fully inside, and does not output
+   * anything to RectangleIntersectionBuilder.
+  bool clip_linestring_parts(const geom::LineString * gi,
+#endif // GEOS_OP_RECTANGLE_INTERSECTION_H
Added: trunk/include/geos/operation/intersection/RectangleIntersectionBuilder.h
--- trunk/include/geos/operation/intersection/RectangleIntersectionBuilder.h	                        (rev 0)
+++ trunk/include/geos/operation/intersection/RectangleIntersectionBuilder.h	2014-09-25 10:46:20 UTC (rev 4021)
@@ -0,0 +1,161 @@
+#ifndef GEOS_OP_INTERSECTION_RECTANGLEINTERSECTIONBUILDER_H
+#define GEOS_OP_INTERSECTION_RECTANGLEINTERSECTIONBUILDER_H
+#ifdef _MSC_VER
+#endif
+#include <memory>
+#include <list>
+#include <vector>
+namespace geos {
+  namespace geom {
+	class Coordinate;
+	class Geometry;
+	class Polygon;
+	class LineString;
+	class Point;
+	  class Rectangle;
+namespace geos {
+ * \brief Rebuild geometries from subpaths left by clipping with a rectangle
+ * The RectangleIntersectionBuilder is used to maintain lists of polygons,
+ * linestrings and points left from clipping a {@link Geometry} with a {@link Rectangle}.
+ * Once all clipping has been done, the class builds a valid {@link Geometry} from
+ * the components.
+ * This is a utility class needed by {@link RectangleIntersection}, and is not
+ * intended for public use.
+class GEOS_DLL RectangleIntersectionBuilder
+  // Regular users are not supposed to use this utility class.
+  friend class RectangleIntersection;
+public:
+  ~RectangleIntersectionBuilder();
+private:
+   * \brief Build the result geometry from partial results and clean up
+  std::auto_ptr<geom::Geometry> build();
+   * \brief Build polygons from parts left by clipping one
+   * 1. Build exterior ring(s) from lines
+   * 2. Attach polygons as holes to the exterior ring(s)
+  void reconnectPolygons(const Rectangle & rect);
+   * Reconnect disjointed parts
+   * When we clip a LinearRing we may get multiple linestrings.
+   * Often the first and last ones can be reconnected to simplify
+   * output.
+   * Sample clip with a rectangle 0,0 --> 10,10 without reconnecting:
+   *   Input:   POLYGON ((5 10,0 0,10 0,5 10))
+   *   Output:  MULTILINESTRING ((5 10,0 0),(10 0,5 10))
+   *   Desired: LINESTRING (10 0,5 10,0 0)
+   * TODO: If there is a very sharp spike from inside the rectangle
+   *       outside, and then back in, it is possible that the
+   *       intersection points at the edge are equal. In this
+   *       case we could reconnect the linestrings. The task is
+   *       the same we're already doing for the 1st/last linestrings,
+   *       we'd just do it for any adjacent pair as well.
+  void reconnect();
+  void reverseLines();
+   * Export parts to another container
+  void release(RectangleIntersectionBuilder & parts);
+  // Adding Geometry components
+  void add(geom::Polygon * g);
+  void add(geom::LineString * g);
+  void add(geom::Point * g);
+  // Trivial methods
+  bool empty() const;
+  void clear();
+  // Added components
+  std::list<geom::Polygon *> polygons;
+  std::list<geom::LineString *> lines;
+  std::list<geom::Point *> points;
+   * \brief Close a ring clockwise along rectangle edges
+   * Only the 4 corners and x1,y1 need to be considered. The possible
+   * cases are:
+   *    x1,y1
+   *    corner1 x1,y1
+   *    corner1 corner2 x1,y1
+   *    corner1 corner2 corner3 x1,y1
+   *    corner1 corner2 corner3 corner4 x1,y1
+  void close_boundary(
+          std::vector<geom::Coordinate> * ring,
+          double x1, double y1,
+          double x2, double y2);
+  void close_ring(const Rectangle & rect, std::vector<geom::Coordinate> * ring);
+  RectangleIntersectionBuilder(const geom::GeometryFactory& f)
+    : _gf(f) {}
+  const geom::GeometryFactory &_gf;
+}; // class RectangleIntersectionBuilder
+#endif // GEOS_OP_INTERSECTION_RECTANGLEINTERSECTIONBUILDER_H
Modified: trunk/src/geom/Geometry.cpp
--- trunk/src/geom/Geometry.cpp	2014-09-24 07:54:58 UTC (rev 4020)
+++ trunk/src/geom/Geometry.cpp	2014-09-25 10:46:20 UTC (rev 4021)
@@ -39,6 +39,8 @@
 #include <geos/algorithm/InteriorPointLine.h>
 #include <geos/algorithm/InteriorPointArea.h>
 #include <geos/algorithm/ConvexHull.h>
 #include <geos/operation/predicate/RectangleContains.h>
 #include <geos/operation/predicate/RectangleIntersects.h>
@@ -67,6 +69,7 @@
 #endif
 #define SHORTCIRCUIT_PREDICATES 1
+//#define USE_RECTANGLE_INTERSECTION 1
 using namespace std;
 using namespace geos::algorithm;
@@ -500,8 +503,8 @@
 Geometry::intersection(const Geometry *other) const
-         * TODO: MD - add optimization for P-A case using Point-In-Polygon
+   * TODO: MD - add optimization for P-A case using Point-In-Polygon
 	// special case: if one input is empty ==> empty
 	if (isEmpty() || other->isEmpty() )
@@ -509,6 +512,24 @@
 		return getFactory()->createGeometryCollection();
+#ifdef USE_RECTANGLE_INTERSECTION
+	// optimization for rectangle arguments
+  using operation::intersection::Rectangle;
+  using operation::intersection::RectangleIntersection;
+	if ( isRectangle() ) {
+    const Envelope* env = getEnvelopeInternal();
+    Rectangle rect(env->getMinX(), env->getMinY(),
+                   env->getMaxX(), env->getMaxY());
+    return RectangleIntersection::clip(*other, rect).release();
+	if (other->isRectangle()) {
+    const Envelope* env = other->getEnvelopeInternal();
+    return RectangleIntersection::clip(*this, rect).release();
+#endif
 	return BinaryOp(this, other, overlayOp(OverlayOp::opINTERSECTION)).release();
Modified: trunk/src/operation/Makefile.am
--- trunk/src/operation/Makefile.am	2014-09-24 07:54:58 UTC (rev 4020)
+++ trunk/src/operation/Makefile.am	2014-09-25 10:46:20 UTC (rev 4021)
@@ -4,6 +4,7 @@
 SUBDIRS = \
     buffer \
     distance \
+    intersection \
     linemerge \
     overlay \
     polygonize \
@@ -24,6 +25,7 @@
 liboperation_la_LIBADD = \
     buffer/libopbuffer.la \
     distance/libopdistance.la \
+    intersection/libopintersection.la \
     linemerge/liboplinemerge.la \
     overlay/libopoverlay.la \
     polygonize/liboppolygonize.la \
Added: trunk/src/operation/intersection/Makefile.am
--- trunk/src/operation/intersection/Makefile.am	                        (rev 0)
+++ trunk/src/operation/intersection/Makefile.am	2014-09-25 10:46:20 UTC (rev 4021)
@@ -0,0 +1,15 @@
+SUBDIRS =
+noinst_LTLIBRARIES = libopintersection.la
+AM_CPPFLAGS = -I$(top_srcdir)/include
+libopintersection_la_SOURCES = \
+  Rectangle.cpp \
+  RectangleIntersection.cpp \
+  RectangleIntersectionBuilder.cpp
+libopintersection_la_LIBADD =
Added: trunk/src/operation/intersection/Rectangle.cpp
--- trunk/src/operation/intersection/Rectangle.cpp	                        (rev 0)
+++ trunk/src/operation/intersection/Rectangle.cpp	2014-09-25 10:46:20 UTC (rev 4021)
@@ -0,0 +1,65 @@
+#include <geos/util/IllegalArgumentException.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/CoordinateSequenceFactory.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/Coordinate.h>
+namespace geos {
+   * Create a clipping rectangle
+  Rectangle::Rectangle(double x1, double y1, double x2, double y2)
+	: xMin(x1)
+	, yMin(y1)
+	, xMax(x2)
+	, yMax(y2)
+	if(xMin >= xMax || yMin >= yMax)
+		throw util::IllegalArgumentException("Clipping rectangle must be non-empty");
+  geom::Polygon*
+  Rectangle::toPolygon(const geom::GeometryFactory &f) const
+    geom::LinearRing* ls = toLinearRing(f);
+    return f.createPolygon(ls, 0);
+  geom::LinearRing*
+  Rectangle::toLinearRing(const geom::GeometryFactory &f) const
+    const geom::CoordinateSequenceFactory *csf = f.getCoordinateSequenceFactory();
+    geom::CoordinateSequence *seq = csf->create(5, 2);
+    seq->setAt(geom::Coordinate(xMin, yMin), 0);
+    seq->setAt(geom::Coordinate(xMin, yMax), 1);
+    seq->setAt(geom::Coordinate(xMax, yMax), 2);
+    seq->setAt(geom::Coordinate(xMax, yMin), 3);
+    seq->setAt(seq->getAt(0), 4); // close
+    return f.createLinearRing(seq);
Added: trunk/src/operation/intersection/RectangleIntersection.cpp
--- trunk/src/operation/intersection/RectangleIntersection.cpp	                        (rev 0)
+++ trunk/src/operation/intersection/RectangleIntersection.cpp	2014-09-25 10:46:20 UTC (rev 4021)
@@ -0,0 +1,704 @@
+#include <geos/algorithm/CGAlgorithms.h>
+#include <geos/operation/intersection/RectangleIntersectionBuilder.h>
+#include <geos/operation/predicate/RectangleIntersects.h>
+#include <geos/geom/MultiPolygon.h>
+#include <geos/geom/Point.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/LinearRing.h>
+#include <geos/geom/Location.h>
+#include <geos/util/UnsupportedOperationException.h>
+#include <list>
+#include <stdexcept>
+using geos::operation::intersection::Rectangle;
+using geos::operation::intersection::RectangleIntersectionBuilder;
+using namespace geos::geom;
+namespace geos {
+ * \brief Test if two coordinates are different
+inline
+bool different(double x1, double y1, double x2, double y2)
+  return !(x1==x2 && y1==y2);
+ * \brief Calculate a line intersection point
+ * Note:
+ *   - Calling this with x1,y1 and x2,y2 swapped cuts the other end of the line
+ *   - Calling this with x and y swapped cuts in y-direction instead
+ *   - Calling with 1<->2 and x<->y swapped works too
+inline
+void clip_one_edge(double & x1, double & y1, double x2, double y2, double limit)
+  if(x1 != x2)
+	  y1 += (y2-y1)*(limit-x1)/(x2-x1);
+	  x1 = limit;
+ * \brief Start point is outside, endpoint is definitely inside
+ * Note: Even though one might think using >= etc operators would produce
+ *       the same result, that is not the case. We rely on the fact
+ *       that nothing is clipped unless the point is truly outside the
+ *       rectangle! Without this handling lines ending on the edges of
+ *       the rectangle would be very difficult.
+void clip_to_edges(double & x1, double & y1,
+				   double x2, double y2,
+  if(x1 < rect.xmin())
+	clip_one_edge(x1,y1,x2,y2,rect.xmin());
+  else if(x1 > rect.xmax())
+	clip_one_edge(x1,y1,x2,y2,rect.xmax());
+  if(y1<rect.ymin())
+	clip_one_edge(y1,x1,y2,x2,rect.ymin());
+  else if(y1>rect.ymax())
+	clip_one_edge(y1,x1,y2,x2,rect.ymax());
+ * Here outGeom may also be a MultiPoint
+void
+RectangleIntersection::clip_point(const geom::Point * g,
+  if(g == NULL)
+	return;
+  double x = g->getX();
+  double y = g->getY();
+  if(rect.position(x,y) == Rectangle::Inside)
+	parts.add(dynamic_cast<geom::Point*>(g->clone()));
+bool
+RectangleIntersection::clip_linestring_parts(const geom::LineString * gi,
+  using namespace geos::geom;
+  int n = gi->getNumPoints();
+  if(gi == NULL || n<1)
+	return false;
+  // For shorthand code
+  std::vector<Coordinate> cs;
+  gi->getCoordinatesRO()->toVector(cs);
+  //const geom::CoordinateSequence &cs = *(gi->getCoordinatesRO());
+  // Keep a record of the point where a line segment entered
+  // the rectangle. If the boolean is set, we must insert
+  // the point to the beginning of the linestring which then
+  // continues inside the rectangle.
+  double x0 = 0;
+  double y0 = 0;
+  bool add_start = false;
+  // Start iterating
+  int i = 0;
+  while(i<n)
+	  // Establish initial position
+	  double x = cs[i].x;
+	  double y = cs[i].y;
+	  Rectangle::Position pos = rect.position(x,y);
+	  if(pos == Rectangle::Outside)
+		  // Skip points as fast as possible until something has to be checked
+		  // in more detail.
+		  ++i;	// we already know it is outside
+		  if(x < rect.xmin())
+			while(i < n && cs[i].x < rect.xmin())
+			  ++i;
+		  else if(x > rect.xmax())
+			while(i < n && cs[i].x > rect.xmax())
+			  ++i;
+		  else if(y < rect.ymin())
+			while(i < n && cs[i].y < rect.ymin())
+			  ++i;
+		  else if(y > rect.ymax())
+			while(i < n && cs[i].y > rect.ymax())
+			  ++i;
+		  if(i >= n)
+			return false;
+		  // Establish new position
+		  x = cs[i].x;
+		  y = cs[i].y;
+		  pos = rect.position(x,y);
+		  // Handle all possible cases
+		  x0 = cs[i-1].x;
+		  y0 = cs[i-1].y;
+		  clip_to_edges(x0,y0,x,y,rect);
+		  if(pos == Rectangle::Inside)
+			  add_start = true;	// x0,y0 must have clipped the rectangle
+			  // Main loop will enter the Inside/Edge section
+		  else if(pos == Rectangle::Outside)
+			  // From Outside to Outside. We need to check whether
+			  // we created a line segment inside the box. In any
+			  // case, we will continue the main loop after this
+			  // which will then enter the Outside section.
+			  // Clip the other end too
+			  clip_to_edges(x,y,x0,y0,rect);
+			  Rectangle::Position prev_pos = rect.position(x0,y0);
+			  if( different(x0,y0,x,y) &&		// discard corners etc
+				  Rectangle::onEdge(prev_pos) &&		// discard if does not intersect rect
+				  Rectangle::onEdge(pos) &&
+				  !Rectangle::onSameEdge(prev_pos,pos)	// discard if travels along edge
+          std::vector<Coordinate> *coords = new std::vector<Coordinate>(2);
+				  (*coords)[0] = Coordinate(x0,y0);
+				  (*coords)[1] = Coordinate(x,y);
+          CoordinateSequence *seq = _csf->create(coords);
+				  geom::LineString * line = _gf->createLineString(seq);
+				  parts.add(line);
+			  // Continue main loop outside the rect
+		  else
+			  // From outside to edge. If the edge we hit first when
+			  // following the line is not the edge we end at, then
+			  // clearly we must go through the rectangle and hence
+			  // a start point must be set.
+			  Rectangle::Position newpos = rect.position(x0,y0);
+			  if(!Rectangle::onSameEdge(pos,newpos))
+				  add_start = true;
+			  else
+				  // we ignore the travel along the edge and continue
+				  // the main loop at the last edge point
+	  else
+		  // The point is now stricly inside or on the edge.
+		  // Keep iterating until the end or the point goes
+		  // outside. We may have to output partial linestrings
+		  // while iterating until we go strictly outside
+		  int start_index = i;			// 1st valid original point
+		  bool go_outside = false;
+		  while(!go_outside && ++i<n)
+			  x = cs[i].x;
+			  y = cs[i].y;
+			  Rectangle::Position prev_pos = pos;
+				  // Just keep going
+				  go_outside = true;
+				  // Clip the outside point to edges
+				  clip_to_edges(x, y, cs[i-1].x, cs[i-1].y, rect);
+				  // Does the line exit through the inside of the box?
+				  bool through_box = (different(x,y,cs[i].x,cs[i].y) &&
+									  !Rectangle::onSameEdge(prev_pos,pos));
+				  // Output a LineString if it at least one segment long
+				  if(start_index < i-1 || add_start || through_box)
+            std::vector<Coordinate> *coords = new std::vector<Coordinate>();
+					  if(add_start)
+						  coords->push_back(Coordinate(x0, y0));
+						  add_start = false;
+					  //line->addSubLineString(&g, start_index, i-1);
+            coords->insert(coords->end(), cs.begin()+start_index, cs.begin()+i);
+					  if(through_box) coords->push_back(Coordinate(x,y));
+					  parts.add(line);
+				  // And continue main loop on the outside
+			  else
+				  // on same edge?
+				  if(Rectangle::onSameEdge(prev_pos,pos))
+					  // Nothing to output if we haven't been elsewhere
+					  if(start_index < i-1 || add_start)
+						  //geom::LineString * line = new geom::LineString();
+						  if(add_start)
+							  //line->addPoint(x0,y0);
+						  parts.add(line);
+					  start_index = i;
+				  else
+					  // On different edge. Must have gone through the box
+					  // then - keep collecting points that generate inside
+					  // line segments
+		  // Was everything in? If so, generate no output but return true in this case only
+		  if(start_index == 0 && i >= n)
+			return true;
+		  // Flush the last line segment if data ended and there is something to flush
+		  if(!go_outside &&						// meaning data ended
+			 (start_index < i-1 || add_start))	// meaning something has to be generated
+			  if(add_start)
+			  parts.add(line);
+  return false;
+ * \brief Clip polygon, do not close clipped ones
+void
+RectangleIntersection::clip_polygon_to_linestrings(const geom::Polygon * g,
+								 RectangleIntersectionBuilder & toParts,
+  if(g == NULL || g->isEmpty())
+	return;
+  // Clip the exterior first to see what's going on
+  RectangleIntersectionBuilder parts(*_gf);
+  // If everything was in, just clone the original
+  if(clip_linestring_parts(g->getExteriorRing(), parts, rect))
+	  toParts.add(dynamic_cast<geom::Polygon *>(g->clone()));
+	  return;
+  // Now, if parts is empty, our rectangle may be inside the polygon
+  // If not, holes are outside too
+  if(parts.empty())
+	  // We could now check whether the rectangle is inside the outer
+	  // ring to avoid checking the holes. However, if holes are much
+	  // smaller than the exterior ring just checking the holes
+	  // separately could be faster.
+	  if(g->getNumInteriorRing() == 0)
+		return;
+  else
+	  // The exterior must have been clipped into linestrings.
+	  // Move them to the actual parts collector, clearing parts.
+	  parts.reconnect();
+	  parts.release(toParts);
+  // Handle the holes now:
+  // - Clipped ones become linestrings
+  // - Intact ones become new polygons without holes
+  for(int i=0, n=g->getNumInteriorRing(); i<n; ++i)
+	  if(clip_linestring_parts(g->getInteriorRingN(i), parts, rect))
+      // clones
+		  LinearRing *hole = dynamic_cast<LinearRing*>(g->getInteriorRingN(i)->clone());
+      // becomes exterior
+		  Polygon *poly = _gf->createPolygon(hole, 0);
+		  toParts.add(poly);
+	  else if(!parts.empty())
+ * \brief Clip polygon, close clipped ones
+void
+RectangleIntersection::clip_polygon_to_polygons(const geom::Polygon * g,
+	return;
+  const LineString *shell = g->getExteriorRing();
+  if(clip_linestring_parts(shell, parts, rect))
+	  return;
+  // If there were no intersections, the outer ring might be
+  // completely outside.
+  using geos::algorithm::CGAlgorithms;
+  if( parts.empty() )
+    const Coordinate rectCorner(rect.xmin(), rect.ymin());
+    if ( CGAlgorithms::locatePointInRing(rectCorner,
+                          *g->getExteriorRing()->getCoordinatesRO())
+         == Location::EXTERIOR )
+      return;
+  else
+    // TODO: make CCW checking part of clip_linestring_parts ?
+    if ( CGAlgorithms::isCCW(shell->getCoordinatesRO()) ) {
+      parts.reverseLines();
+  // Must do this to make sure all end points are on the edges
+  // - Clipped ones become part of the exterior
+  // - Intact ones become holes in new polygons formed by exterior parts
+	  RectangleIntersectionBuilder holeparts(*_gf);
+    const LineString *hole = g->getInteriorRingN(i);
+	  if(clip_linestring_parts(hole, holeparts, rect))
+		  LinearRing *cloned = dynamic_cast<LinearRing*>(hole->clone());
+		  Polygon *poly = _gf->createPolygon(cloned, 0);
+		  parts.add(poly);
+	  else
+		  if(!holeparts.empty())
+        if ( ! CGAlgorithms::isCCW(hole->getCoordinatesRO()) ) {
+          holeparts.reverseLines();
+			  holeparts.reconnect();
+			  holeparts.release(parts);
+		  else
+			  if( CGAlgorithms::isPointInRing(Coordinate(rect.xmin(), rect.ymin()),
+            g->getInteriorRingN(i)->getCoordinatesRO()) )
+				  // Completely inside the hole
+				  return;
+  parts.reconnectPolygons(rect);
+void
+RectangleIntersection::clip_polygon(const geom::Polygon * g,
+  if(keep_polygons)
+	clip_polygon_to_polygons(g, parts, rect);
+  else
+	clip_polygon_to_linestrings(g, parts, rect);
+void
+RectangleIntersection::clip_linestring(const geom::LineString * g,
+	return;
+  if(clip_linestring_parts(g, parts, rect))
+	parts.add(dynamic_cast<geom::LineString *>(g->clone()));
+void
+RectangleIntersection::clip_multipoint(const geom::MultiPoint * g,
+	return;
+  for(int i=0, n=g->getNumGeometries(); i<n; ++i)
+	  clip_point(dynamic_cast<const geom::Point *>(g->getGeometryN(i)),
+				 parts, rect);
+void
+RectangleIntersection::clip_multilinestring(const geom::MultiLineString * g,
+	return;
+	  clip_linestring(dynamic_cast<const geom::LineString *>(g->getGeometryN(i)),
+					  parts, rect);
+void
+RectangleIntersection::clip_multipolygon(const geom::MultiPolygon * g,
+	return;
+	  clip_polygon(dynamic_cast<const geom::Polygon *>(g->getGeometryN(i)),
+				   parts, rect, keep_polygons);
+void
+RectangleIntersection::clip_geometrycollection(
+	return;
+	  clip_geom(g->getGeometryN(i),
+void
+RectangleIntersection::clip_geom(const geom::Geometry * g,
+	if ( const Point* p = dynamic_cast<const geom::Point *>(g) )
+	  return clip_point(p, parts, rect);
+	else if ( const MultiPoint* p = dynamic_cast<const geom::MultiPoint *>(g) )
+	  return clip_multipoint(p, parts, rect);
+	else if ( const LineString* p = dynamic_cast<const geom::LineString *>(g) )
+	  return clip_linestring(p, parts, rect);
+	else if ( const MultiLineString* p = dynamic_cast<const geom::MultiLineString *>(g) )
+	  return clip_multilinestring(p, parts, rect);
+	else if ( const Polygon* p = dynamic_cast<const geom::Polygon *>(g) )
+	  return clip_polygon(p, parts, rect, keep_polygons);
+	else if ( const MultiPolygon* p = dynamic_cast<const geom::MultiPolygon *>(g) )
+	  return clip_multipolygon(p, parts, rect, keep_polygons);
+	else if ( const GeometryCollection* p = dynamic_cast<const geom::GeometryCollection *>(g) )
+	  return clip_geometrycollection(p, parts, rect, keep_polygons);
+  else {
+    throw util::UnsupportedOperationException("Encountered an unknown geometry component when clipping polygons");
+/* public static */
+std::auto_ptr<geom::Geometry>
+RectangleIntersection::clipBoundary(const geom::Geometry & g, const Rectangle & rect)
+  RectangleIntersection ri(g,rect);
+  return ri.clipBoundary();
+RectangleIntersection::clipBoundary()
+  bool keep_polygons = false;
+  clip_geom(&_geom, parts, _rect, keep_polygons);
+  return parts.build();
+RectangleIntersection::clip(const geom::Geometry & g, const Rectangle & rect)
+  return ri.clip();
+RectangleIntersection::clip()
+  bool keep_polygons = true;
+RectangleIntersection::RectangleIntersection(const geom::Geometry& geom, const Rectangle& rect)
+  : _geom(geom), _rect(rect),
+    _gf(geom.getFactory())
+  _csf = _gf->getCoordinateSequenceFactory();
Added: trunk/src/operation/intersection/RectangleIntersectionBuilder.cpp
--- trunk/src/operation/intersection/RectangleIntersectionBuilder.cpp	                        (rev 0)
+++ trunk/src/operation/intersection/RectangleIntersectionBuilder.cpp	2014-09-25 10:46:20 UTC (rev 4021)
@@ -0,0 +1,518 @@
+#include <geos/geom/GeometryCollection.h>
+namespace geos {
+RectangleIntersectionBuilder::~RectangleIntersectionBuilder()
+  for (std::list<geom::Polygon *>::iterator i=polygons.begin(), e=polygons.end(); i!=e; ++i)
+	  delete *i;
+  for (std::list<geom::LineString *>::iterator i=lines.begin(), e=lines.end(); i!=e; ++i)
+	  delete *i;
+  for (std::list<geom::Point *>::iterator i=points.begin(), e=points.end(); i!=e; ++i)
+	  delete *i;
+void
+RectangleIntersectionBuilder::reconnect()
+  // Nothing to reconnect if there aren't at least two lines
+  if(lines.size() < 2)
+       return;
+  geom::LineString * line1 = lines.front();
+  const geom::CoordinateSequence &cs1 = *line1->getCoordinatesRO();
+  geom::LineString * line2 = lines.back();
+  const geom::CoordinateSequence &cs2 = *line2->getCoordinatesRO();
+  const int n1 = cs1.size();
+  const int n2 = cs2.size();
+  // Safety check against bad input to prevent segfaults
+  if(n1==0 || n2==0)
+       return;
+  if (cs1[0] != cs2[n2-1]) return;
+  // Merge the two linestrings
+  CoordinateSequence *ncs = CoordinateSequence::removeRepeatedPoints(&cs2);
+  ncs->add(&cs1, false, true);
+  delete line1;
+  delete line2;
+  LineString * nline = _gf.createLineString(ncs);
+  lines.pop_front();
+  lines.pop_back();
+  lines.push_front(nline);
+void RectangleIntersectionBuilder::release(RectangleIntersectionBuilder & theParts)
+	  theParts.add(*i);
+	  theParts.add(*i);
+	  theParts.add(*i);
+  clear();
+ * \brief Clear the parts having transferred ownership elsewhere
+void RectangleIntersectionBuilder::clear()
+  polygons.clear();
+  lines.clear();
+  points.clear();
+ * \brief Test if there are no parts at all
+bool RectangleIntersectionBuilder::empty() const
+  return polygons.empty() && lines.empty() && points.empty();
+ * \brief Add intermediate Polygon
+void RectangleIntersectionBuilder::add(geom::Polygon * thePolygon)
+  polygons.push_back(thePolygon);
+ * \brief Add intermediate LineString
+void RectangleIntersectionBuilder::add(geom::LineString * theLine)
+  lines.push_back(theLine);
+ * \brief Add intermediate Point
+void RectangleIntersectionBuilder::add(geom::Point * thePoint)
+  points.push_back(thePoint);
+RectangleIntersectionBuilder::build()
+  // Total number of objects
+  std::size_t n = polygons.size() + lines.size() + points.size();
+  if(n == 0)
+	return std::auto_ptr<Geometry>(_gf.createGeometryCollection());
+  std::vector<Geometry *> *geoms = new std::vector<Geometry *>;
+  geoms->reserve(n);
+      geoms->push_back(*i);
+  polygons.clear();
+  lines.clear();
+  points.clear();
+    (*geoms)[0]->getFactory()->buildGeometry(geoms)
+ * Distance of 1st point of linestring to last point of linearring
+ * along rectangle edges
+double distance(const Rectangle & rect,
+  double dist = 0;
+  Rectangle::Position pos = rect.position(x1,y1);
+  Rectangle::Position endpos = rect.position(x2,y2);
+  while(true)
+	  // Close up when we have the same edge and the
+	  // points are in the correct clockwise order
+	  if((pos & endpos) != 0 &&
+		  (x1==rect.xmin() && y2>=y1) ||
+		  (y1==rect.ymax() && x2>=x1) ||
+		  (x1==rect.xmax() && y2<=y1) ||
+		  (y1==rect.ymin() && x2<=x1))
+		  dist += fabs(x2-x1) + fabs(y2-y1);
+		  break;
+	  pos = Rectangle::nextEdge(pos);
+	  if(pos & Rectangle::Left)
+		  dist += x1-rect.xmin();
+		  x1 = rect.xmin();
+	  else if(pos & Rectangle::Top)
+		  dist += rect.ymax()-y1;
+		  y1 = rect.ymax();
+	  else if(pos & Rectangle::Right)
+		  dist += rect.xmax()-x1;
+		  x1 = rect.xmax();
+	  else
+		  dist += y1-rect.ymin();
+		  y1 = rect.ymin();
+  return dist;
+				const std::vector<Coordinate> &ring,
+				const geom::LineString * line)
+  double nr = ring.size();
+  const Coordinate &c1 = ring[nr-1];
+  const CoordinateSequence * linecs = line->getCoordinatesRO();
+  const Coordinate &c2 = linecs->getAt(0);
+  return distance(rect,c1.x,c1.y,c2.x,c2.y);
+				const std::vector<Coordinate> &ring)
+  const Coordinate& c1 = ring[nr-1]; // TODO: ring.back() ?
+  const Coordinate& c2 = ring[0]; // TODO: ring.front() ?
+  return distance(rect, c1.x, c1.y, c2.x, c2.y);
+ * \brief Reverse given segment in a coordinate vector
+void reverse_points(std::vector<Coordinate> &v, int start, int end)
+  geom::Coordinate p1;
+  geom::Coordinate p2;
+  while(start < end)
+    p1 = v[start];
+    p2 = v[end];
+    v[start] = p2;
+    v[end] = p1;
+	  ++start;
+	  --end;
+ * \brief Normalize a ring into lexicographic order
+void
+normalize_ring(std::vector<Coordinate> &ring)
+  if(ring.empty())
+	return;
+  // Find the "smallest" coordinate
+  int best_pos = 0;
+  int n = ring.size();
+  for(int pos = 0; pos<n; ++pos)
+    // TODO: use CoordinateLessThan ?
+	  if(ring[pos].x < ring[best_pos].x)
+		best_pos = pos;
+	  else if(ring[pos].x == ring[best_pos].x &&
+			  ring[pos].y < ring[best_pos].y )
+		best_pos = pos;
+  // Quick exit if the ring is already normalized
+  if(best_pos == 0)
+	return;
+  // Flip hands -algorithm to the part without the
+  // duplicate last coordinate at n-1:
+  reverse_points(ring,0,best_pos-1);
+  reverse_points(ring,best_pos,n-2);
+  reverse_points(ring,0,n-2);
+  // And make sure the ring is valid by duplicating the first coordinate
+  // at the end:
+  geom::Coordinate c;
+  c = ring[0];
+  ring[n-1] = c;
+void
+RectangleIntersectionBuilder::close_boundary(
+					std::vector<Coordinate> * ring,
+  while(true)
+		  if(x1!=x2 || y1!=y2)		// the polygon may have started at a corner
+			ring->push_back(Coordinate(x2,y2));
+		  break;
+		x1 = rect.xmin();
+		y1 = rect.ymax();
+		x1 = rect.xmax();
+	  else
+		y1 = rect.ymin();
+	  ring->push_back(Coordinate(x1,y1));
+void
+RectangleIntersectionBuilder::close_ring(const Rectangle & rect,
+				std::vector<Coordinate> * ring)
+  double nr = ring->size();
+  Coordinate &c2 = (*ring)[0];
+  Coordinate &c1 = (*ring)[nr-1];
+  double x2 = c2.x;
+  double y2 = c2.y;
+  double x1 = c1.x;
+  double y1 = c1.y;
+  close_boundary(rect, ring, x1, y1, x2, y2);
+void
+RectangleIntersectionBuilder::reconnectPolygons(const Rectangle & rect)
+  // Build the exterior rings first
+  typedef std::vector< geom::Geometry *> LinearRingVect;
+  typedef std::pair< geom::LinearRing *, LinearRingVect * > ShellAndHoles;
+  typedef std::list< ShellAndHoles > ShellAndHolesList;
+  ShellAndHolesList exterior;
+  const CoordinateSequenceFactory &_csf = *_gf.getCoordinateSequenceFactory();
+  // If there are no lines, the rectangle must have been
+  // inside the exterior ring.
+  if(lines.empty())
+	  geom::LinearRing * ring = rect.toLinearRing(_gf);
+	  exterior.push_back(make_pair(ring, new LinearRingVect()));
+  else
+	  // Reconnect all lines into one or more linearrings
+	  // using box boundaries if necessary
+    std::vector<Coordinate> *ring = NULL;
+	  while(!lines.empty() || ring != NULL)
+		  if(ring == NULL)
+			  ring = new std::vector<Coordinate>();
+			  LineString *line = lines.front();
+        line->getCoordinatesRO()->toVector(*ring);
+			  delete line;
+		  // Distance to own endpoint
+		  double own_distance = distance(rect, *ring);
+		  // Find line to connect to
+      // TODO: should we use LineMerge op ?
+		  double best_distance = -1;
+		  std::list<LineString*>::iterator best_pos = lines.begin();
+		  for(std::list<LineString*>::iterator iter=lines.begin(); iter!=lines.end(); ++iter)
+			  double d = distance(rect, *ring, *iter);
+			  if(best_distance < 0 || d<best_distance)
+				  best_distance = d;
+				  best_pos = iter;
+		  // If own end point is closest, close the ring and continue
+		  if(best_distance < 0 || own_distance < best_distance)
+			  close_ring(rect,ring);
+			  normalize_ring(*ring);
+        geom::CoordinateSequence *shell_cs = _csf.create(ring);
+        geom::LinearRing *shell = _gf.createLinearRing(shell_cs);
+	      exterior.push_back(make_pair(shell, new LinearRingVect()));
+			  ring = NULL;
+		  else
+			  LineString * line = *best_pos;
+			  int nr = ring->size();
+        const CoordinateSequence& cs = *line->getCoordinatesRO();
+							 (*ring)[nr-1].x,
+							 (*ring)[nr-1].y,
+							 cs[0].x,
+               cs[0].y);
+        // above function adds the 1st point
+        for (size_t i=1; i<cs.size(); ++i)
+          ring->push_back(cs[i]);
+			  //ring->addSubLineString(line,1);
+			  delete line;
+			  lines.erase(best_pos);
+  // Attach holes to polygons
+    geom::Polygon *poly = *i;
+    const geom::LineString *hole = poly->getExteriorRing();
+	  if(exterior.size() == 1)
+		  exterior.front().second->push_back( hole->clone() );
+	  else
+		  hole->getCoordinatesRO()->getAt(0, c);
+      for (ShellAndHolesList::iterator i=exterior.begin(), e=exterior.end(); i!=e; ++i)
+        ShellAndHoles &p = *i;
+        const CoordinateSequence *shell_cs = p.first->getCoordinatesRO();
+        if( CGAlgorithms::isPointInRing(c, shell_cs) )
+          // add hole to shell
+          p.second->push_back(hole->clone());
+				  break;
+		delete poly;
+  // Build the result polygons
+  std::list<geom::Polygon *> new_polygons;
+	  geom::Polygon * poly = _gf.createPolygon(p.first, p.second);
+	  new_polygons.push_back(poly);
+  clear();
+  polygons = new_polygons;
+void
+RectangleIntersectionBuilder::reverseLines()
+  std::list<geom::LineString *> new_lines;
+  for (std::list<geom::LineString *>::reverse_iterator i=lines.rbegin(), e=lines.rend(); i!=e; ++i)
+    LineString *ol = *i;
+    new_lines.push_back(dynamic_cast<LineString*>(ol->reverse()));
+    delete ol;
+  lines = new_lines;
+#if GEOS_DEBUG
+  std::cout << "After lines reverse, parts are " << *this << std::endl;
+#endif
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am	2014-09-24 07:54:58 UTC (rev 4020)
+++ trunk/tests/unit/Makefile.am	2014-09-25 10:46:20 UTC (rev 4021)
@@ -89,6 +89,7 @@
 	operation/buffer/BufferOpTest.cpp \
 	operation/buffer/BufferParametersTest.cpp \
 	operation/distance/DistanceOpTest.cpp \
+	operation/intersection/RectangleIntersectionTest.cpp \
 	operation/IsSimpleOpTest.cpp \
 	operation/linemerge/LineMergerTest.cpp \
 	operation/linemerge/LineSequencerTest.cpp \
@@ -114,6 +115,7 @@
 	triangulate/DelaunayTest.cpp \
 	triangulate/VoronoiTest.cpp \
 	util/UniqueCoordinateArrayFilterTest.cpp \
+	capi/GEOSClipByRectTest.cpp \
 	capi/GEOSCoordSeqTest.cpp \
 	capi/GEOSDelaunayTriangulationTest.cpp \
 	capi/GEOSVoronoiDiagramTest.cpp \
Added: trunk/tests/unit/capi/GEOSClipByRectTest.cpp
--- trunk/tests/unit/capi/GEOSClipByRectTest.cpp	                        (rev 0)
+++ trunk/tests/unit/capi/GEOSClipByRectTest.cpp	2014-09-25 10:46:20 UTC (rev 4021)
@@ -0,0 +1,191 @@
+// Test Suite for C-API GEOSClipByRect
+#include <tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <memory>
+namespace tut
+  // Test Group
+  // Common data used in test cases.
+  struct test_capigeosclipbyrect_data
+    GEOSGeometry* geom1_;
+    GEOSGeometry* geom2_;
+    GEOSGeometry* geom3_;
+    GEOSWKTWriter* w_;
+    static void notice(const char *fmt, ...)
+      std::fprintf( stdout, "NOTICE: ");
+      va_list ap;
+      va_start(ap, fmt);
+      std::vfprintf(stdout, fmt, ap);
+      va_end(ap);
+      std::fprintf(stdout, "\n");
+    void isEqual(GEOSGeom g, const char *exp_wkt)
+      geom3_ = GEOSGeomFromWKT(exp_wkt);
+      bool eq = GEOSEquals(geom3_, g);
+      if ( ! eq ) {
+        std::printf("EXP: %s\n", exp_wkt);
+        char *obt_wkt = GEOSWKTWriter_write(w_, g);
+        std::printf("OBT: %s\n", obt_wkt);
+        free(obt_wkt);
+      ensure(eq);
+    test_capigeosclipbyrect_data()
+      : geom1_(0), geom2_(0), geom3_(0), w_(0)
+      initGEOS(notice, notice);
+      w_ = GEOSWKTWriter_create();
+      GEOSWKTWriter_setTrim(w_, 1);
+      GEOSWKTWriter_setRoundingPrecision(w_, 8);
+    ~test_capigeosclipbyrect_data()
+      GEOSGeom_destroy(geom1_);
+      GEOSGeom_destroy(geom2_);
+      GEOSGeom_destroy(geom3_);
+      GEOSWKTWriter_destroy(w_);
+      geom1_ = 0;
+      geom2_ = 0;
+      geom3_ = 0;
+      finishGEOS();
+  typedef test_group<test_capigeosclipbyrect_data> group;
+  typedef group::object object;
+  group test_capigeosclipbyrect_group("capi::GEOSClipByRect");
+  // Test Cases
+  /// Point outside
+  template<> template<> void object::test<1>()
+    geom1_ = GEOSGeomFromWKT("POINT(0 0)");
+    geom2_ = GEOSClipByRect(geom1_, 10, 10, 20, 20);
+    isEqual(geom2_, "POINT EMPTY");
+  /// Point inside
+  template<> template<> void object::test<2>()
+    geom1_ = GEOSGeomFromWKT("POINT(15 15)");
+    isEqual(geom2_, "POINT(15 15)");
+  /// Point on boundary
+  template<> template<> void object::test<3>()
+    geom1_ = GEOSGeomFromWKT("POINT(15 10)");
+  /// Line outside
+  template<> template<> void object::test<4>()
+    geom1_ = GEOSGeomFromWKT("LINESTRING(0 0, -5 5)");
+    isEqual(geom2_, "LINESTRING EMPTY");
+  /// Line inside
+  template<> template<> void object::test<5>()
+    geom1_ = GEOSGeomFromWKT("LINESTRING(15 15, 16 15)");
+    isEqual(geom2_, "LINESTRING(15 15, 16 15)");
+  /// Line on boundary
+  template<> template<> void object::test<6>()
+    geom1_ = GEOSGeomFromWKT("LINESTRING(10 15, 10 10, 15 10)");
+  /// Line splitting rectangle
+  template<> template<> void object::test<7>()
+    geom1_ = GEOSGeomFromWKT("LINESTRING(10 5, 25 20)");
+    isEqual(geom2_, "LINESTRING (15 10, 20 15)");
+  /// Polygon shell (CCW) fully on rectangle boundary
+  template<> template<> void object::test<8>()
+    geom1_ = GEOSGeomFromWKT("POLYGON((10 10, 20 10, 20 20, 10 20, 10 10))");
+    isEqual(geom2_, "POLYGON((10 10, 20 10, 20 20, 10 20, 10 10))");
+  /// Polygon shell (CW) fully on rectangle boundary
+  template<> template<> void object::test<9>()
+    geom1_ = GEOSGeomFromWKT("POLYGON((10 10, 10 20, 20 20, 20 10, 10 10))");
+  /// Polygon hole (CCW) fully on rectangle boundary
+  template<> template<> void object::test<10>()
+    geom1_ = GEOSGeomFromWKT("POLYGON((0 0, 0 30, 30 30, 30 0, 0 0),(10 10, 20 10, 20 20, 10 20, 10 10))");
+    isEqual(geom2_, "POLYGON EMPTY");
+  /// Polygon hole (CW) fully on rectangle boundary
+  template<> template<> void object::test<11>()
+    geom1_ = GEOSGeomFromWKT("POLYGON((0 0, 0 30, 30 30, 30 0, 0 0),(10 10, 10 20, 20 20, 20 10, 10 10))");
+  /// Polygon fully within rectangle
+  template<> template<> void object::test<12>()
+    const char *wkt = "POLYGON((1 1, 1 30, 30 30, 30 1, 1 1),(10 10, 20 10, 20 20, 10 20, 10 10))";
+    geom1_ = GEOSGeomFromWKT(wkt);
+    geom2_ = GEOSClipByRect(geom1_, 0, 0, 40, 40);
+    isEqual(geom2_, wkt);
+  /// Polygon overlapping rectangle
+  template<> template<> void object::test<13>()
+    const char *wkt = "POLYGON((0 0, 0 30, 30 30, 30 0, 0 0),(10 10, 20 10, 20 20, 10 20, 10 10))";
+    geom2_ = GEOSClipByRect(geom1_, 5, 5, 15, 15);
+    isEqual(geom2_, "POLYGON ((5 5, 5 15, 10 15, 10 10, 15 10, 15 5, 5 5))");
+} // namespace tut
Added: trunk/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
--- trunk/tests/unit/operation/intersection/RectangleIntersectionTest.cpp	                        (rev 0)
+++ trunk/tests/unit/operation/intersection/RectangleIntersectionTest.cpp	2014-09-25 10:46:20 UTC (rev 4021)
@@ -0,0 +1,1506 @@
+// Test Suite for geos::operation::intersection::RectangleIntersection class.
+// tut
+#include <tut.hpp>
+// geos
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
+// std
+#include <memory>
+#include <string>
+#include <vector>
+#include <iostream>
+namespace tut
+    // Test Group
+    // Common data used by tests
+    struct test_rectangleintersectiontest_data
+        geos::geom::GeometryFactory gf;
+        geos::io::WKTReader wktreader;
+        geos::io::WKTWriter wktwriter;
+        typedef geos::geom::Geometry::AutoPtr GeomPtr;
+        typedef geos::geom::Geometry Geom;
+        typedef geos::operation::intersection::Rectangle Rectangle;
+        typedef geos::operation::intersection::RectangleIntersection RectangleIntersection;
+        test_rectangleintersectiontest_data()
+          : gf(),
+            wktreader(&gf)
+          wktwriter.setTrim(true);
+        GeomPtr readWKT(const std::string& inputWKT)
+            return GeomPtr(wktreader.read(inputWKT));
+        static GeomPtr normalize(const Geom& g)
+          GeomPtr g2 ( g.clone() );
+          g2->normalize();
+          return g2;
+        bool isEqual(const Geom& a, const Geom& b, double tolerance=0)
+          using std::cout;
+          using std::endl;
+          bool eq;
+          // TODO: use HausdorffDistance ?
+          GeomPtr a2 = normalize(a);
+          GeomPtr b2 = normalize(b);
+          eq = a2->equalsExact(b2.get(), tolerance);
+          if  ( ! eq ) {
+            cout << "OBTAINED: " << wktwriter.write(b2.get()) << endl;
+          return eq;
+        void doLineClipTest(const char* inputWKT, const std::string& expectedWKT, const Rectangle& rect, double tolerance=0)
+          GeomPtr g = readWKT(inputWKT);
+          ensure(g.get());
+          GeomPtr obt = RectangleIntersection::clipBoundary(*g,rect);
+          ensure(obt.get());
+          bool ok = isEqual(*readWKT(expectedWKT), *obt, tolerance);
+          ensure(ok);
+        void doClipTest(const char* inputWKT, const std::string& expectedWKT, const Rectangle& rect, double tolerance=0)
+          ensure(g.get());
+          GeomPtr obt = RectangleIntersection::clip(*g,rect);
+          ensure(ok);
+// Compare with GEOSIntersection output
+#if 0
+          GeomPtr g2 ( rect.toPolygon(*g->getFactory()) );
+          obt.reset(g->intersection(g2.get()));
+          ok = isEqual(*readWKT(expectedWKT), *obt, tolerance);
+          ensure(ok);
+#endif
+    typedef test_group<test_rectangleintersectiontest_data, 256> group;
+    group test_rectangleintersectiontest_group("geos::operation::intersection::RectangleIntersection");
+    // inside
+      doLineClipTest(
+        "LINESTRING (1 1,1 9,9 9,9 1)",
+        Rectangle(0,0,10,10)
+    // outside
+      doLineClipTest(
+        "LINESTRING (-1 -9,-1 11,9 11)",
+        "GEOMETRYCOLLECTION EMPTY",
+    // go in from left
+      doLineClipTest(
+        "LINESTRING (-1 5,5 5,9 9)",
+        "LINESTRING (0 5,5 5,9 9)",
+    // go out from right
+      doLineClipTest(
+        "LINESTRING (5 5,8 5,12 5)",
+        "LINESTRING (5 5,8 5,10 5)",
+    // go in and out
+      doLineClipTest(
+        "LINESTRING (5 -1,5 5,1 2,-3 2,1 6)",
+        "MULTILINESTRING ((5 0,5 5,1 2,0 2),(0 5,1 6))",
+    // go along left edge
+      doLineClipTest(
+        "LINESTRING (0 3,0 5,0 7)",
+    // go out from left edge
+      doLineClipTest(
+        "LINESTRING (0 3,0 5,-1 7)",
+    // go in from left edge
+      doLineClipTest(
+        "LINESTRING (0 3,0 5,2 7)",
+        "LINESTRING (0 5,2 7)",
+    // triangle corner at bottom left corner
+      doLineClipTest(
+        "LINESTRING (2 1,0 0,1 2)",
+    // go from in to edge and back in
+      doLineClipTest(
+        "LINESTRING (3 3,0 3,0 5,2 7)",
+        "MULTILINESTRING ((3 3,0 3),(0 5,2 7))",
+    // go from in to edge and then straight out
+      doLineClipTest(
+        "LINESTRING (5 5,10 5,20 5)",
+        "LINESTRING (5 5,10 5)",
+    // triangle corner at left edge
+      doLineClipTest(
+        "LINESTRING (3 3,0 6,3 9)",
+    // polygon completely inside
+      doLineClipTest(
+        "POLYGON ((5 5,5 6,6 6,6 5,5 5))",
+    // polygon completely outside
+    template<> template<> void object::test<14>()
+      doLineClipTest(
+        "POLYGON ((15 15,15 16,16 16,16 15,15 15))",
+    // polygon surrounds the rectangle
+    template<> template<> void object::test<15>()
+      doLineClipTest(
+        "POLYGON ((-1 -1,-1 11,11 11,11 -1,-1 -1))",
+    // polygon cuts the rectangle
+    template<> template<> void object::test<16>()
+      doLineClipTest(
+        "POLYGON ((-1 -1,-1 5,5 5,5 -1,-1 -1))",
+        "LINESTRING (0 5,5 5,5 0)",
+    // polygon with hole cuts the rectangle
+    template<> template<> void object::test<17>()
+      doLineClipTest(
+        "POLYGON ((-2 -2,-2 5,5 5,5 -2,-2 -2), (3 3,4 4,4 2,3 3))",
+        "GEOMETRYCOLLECTION (POLYGON ((3 3,4 4,4 2,3 3)),LINESTRING (0 5,5 5,5 0))",
+    // rectangle cuts both the polygon and the hole
+    template<> template<> void object::test<18>()
+      doLineClipTest(
+        "POLYGON ((-2 -2,-2 5,5 5,5 -2,-2 -2), (-1 -1,3 1,3 3,-1 -1))",
+        "MULTILINESTRING ((0 5,5 5,5 0),(1 0,3 1,3 3,0 0))",
+    // Triangle at two corners and one edge
+    template<> template<> void object::test<19>()
+      doLineClipTest(
+        "POLYGON ((0 0,10 0,5 10,0 0))",
+        "LINESTRING (10 0,5 10,0 0)",
+    // Same triangle with another starting point
+    template<> template<> void object::test<20>()
+      doLineClipTest(
+        "POLYGON ((5 10,0 0,10 0,5 10))",
+    // Triangle intersection at corner and edge
+    template<> template<> void object::test<21>()
+      doLineClipTest(
+        "POLYGON ((-5 -5,5 5,5 -5,-5 -5))",
+        "LINESTRING (0 0,5 5,5 0)",
+    // Triangle intersection at adjacent edges
+    template<> template<> void object::test<22>()
+      doLineClipTest(
+        "POLYGON ((-1 5,5 11,5 5,-1 5))",
+        "MULTILINESTRING ((0 6,4 10),(5 10,5 5,0 5))",
+    // One triangle intersection and one inside edge
+    template<> template<> void object::test<23>()
+      doLineClipTest(
+        "POLYGON ((-5 5,5 10,5 5,-5 5))",
+        "LINESTRING (0.0 7.5,5 10,5 5,0 5)",
+    // Triangle intersection at center and end of the same edge
+    template<> template<> void object::test<24>()
+      doLineClipTest(
+        "POLYGON ((-10 5,10 10,10 5,-10 5))",
+        "MULTILINESTRING ((0.0 7.5,10 10),(10 5,0 5))",
+    // Two different edges clips
+    template<> template<> void object::test<25>()
+      doLineClipTest(
+        "POLYGON ((-5 5,15 15,15 5,-5 5))",
+        "MULTILINESTRING ((0.0 7.5,5 10),(10 5,0 5))",
+    // Inside triangle with all corners at edges
+    template<> template<> void object::test<26>()
+      doLineClipTest(
+        "POLYGON ((0 5,5 10,10 5,0 5))",
+    // Inside triangle whose base is one of the edges
+    template<> template<> void object::test<27>()
+      doLineClipTest(
+        "POLYGON ((0 0,5 5,10 0,0 0))",
+        "LINESTRING (0 0,5 5,10 0)",
+    // Triangle touching two corners on the outside
+    template<> template<> void object::test<28>()
+      doLineClipTest(
+        "POLYGON ((-5 5,5 15,15 5,-5 5))",
+        "LINESTRING (10 5,0 5)",
+    // Triangle with a diagonal and sharing two edges
+    template<> template<> void object::test<29>()
+      doLineClipTest(
+        "POLYGON ((0 0,10 10,10 0,0 0))",
+        "LINESTRING (0 0,10 10)",
+    // Triangle exits edge at a corner
+    template<> template<> void object::test<30>()
+      doLineClipTest(
+        "POLYGON ((-5 0,5 10,5 0,-5 0))",
+        "LINESTRING (0 5,5 10,5 0)",
+    // Triangle enters edge at a corner
+    template<> template<> void object::test<31>()
+      doLineClipTest(
+        "POLYGON ((-5 10,5 10,0 0,-5 10))",
+        "LINESTRING (5 10,0 0)",
+    // Triangle enters and exits the same edge
+    template<> template<> void object::test<32>()
+      doLineClipTest(
+        "POLYGON ((-5 0,5 10,15 0,-5 0))",
+        "LINESTRING (0 5,5 10,10 5)",
+    // Triangle enters at a corner and exits at another
+    template<> template<> void object::test<33>()
+      doLineClipTest(
+        "POLYGON ((-5 -5,15 15,15 -5,-5 -5))",
+    // From outside to nearest edge etc
+    template<> template<> void object::test<34>()
+      doLineClipTest(
+        "POLYGON ((-5 -5,0 5,5 0,-5 -5))",
+        "LINESTRING (0 5,5 0)",
+    // From outside to opposite edge etc
+    template<> template<> void object::test<35>()
+      doLineClipTest(
+        "POLYGON ((-10 5,10 5,0 -5,-10 5))",
+        "LINESTRING (0 5,10 5,5 0)",
+    // Drew all combinations I could imagine on paper, and added the following.
+    // All triangles fully inside
+    template<> template<> void object::test<36>()
+      doLineClipTest(
+        "POLYGON ((0 0,0 10,10 10,0 0))",
+        "LINESTRING (10 10,0 0)",
+    template<> template<> void object::test<37>()
+      doLineClipTest(
+        "POLYGON ((0 5,0 10,10 10,0 5))",
+        "LINESTRING (10 10,0 5)",
+    template<> template<> void object::test<38>()
+      doLineClipTest(
+        "POLYGON ((0 10,10 10,5 0,0 10))",
+        "LINESTRING (10 10,5 0,0 10)",
+    template<> template<> void object::test<39>()
+      doLineClipTest(
+        "POLYGON ((0 10,10 10,5 5,0 10))",
+        "LINESTRING (10 10,5 5,0 10)",
+    template<> template<> void object::test<40>()
+      doLineClipTest(
+        "POLYGON ((0 10,5 10,0 5,0 10))",
+        "LINESTRING (5 10,0 5)",
+    template<> template<> void object::test<41>()
+      doLineClipTest(
+        "POLYGON ((0 10,10 5,0 5,0 10))",
+        "LINESTRING (0 10,10 5,0 5)",
+    template<> template<> void object::test<42>()
+      doLineClipTest(
+        "POLYGON ((0 10,10 0,0 5,0 10))",
+        "LINESTRING (0 10,10 0,0 5)",
+    template<> template<> void object::test<43>()
+      doLineClipTest(
+        "POLYGON ((0 10,5 0,0 5,0 10))",
+        "LINESTRING (0 10,5 0,0 5)",
+    template<> template<> void object::test<44>()
+      doLineClipTest(
+        "POLYGON ((0 10,5 5,0 5,0 10))",
+        "LINESTRING (0 10,5 5,0 5)",
+    template<> template<> void object::test<45>()
+      doLineClipTest(
+        "POLYGON ((0 10,7 7,3 3,0 10))",
+    template<> template<> void object::test<46>()
+      doLineClipTest(
+        "POLYGON ((0 10,5 5,5 0,0 10))",
+    template<> template<> void object::test<47>()
+      doLineClipTest(
+        "POLYGON ((0 10,10 5,5 0,0 10))",
+    template<> template<> void object::test<48>()
+      doLineClipTest(
+        "POLYGON ((2 5,5 7,7 5,2 5))",
+    template<> template<> void object::test<49>()
+      doLineClipTest(
+        "POLYGON ((2 5,5 10,7 5,2 5))",
+    template<> template<> void object::test<50>()
+      doLineClipTest(
+        "POLYGON ((0 5,5 10,5 5,0 5))",
+    template<> template<> void object::test<51>()
+      doLineClipTest(
+    template<> template<> void object::test<52>()
+      doLineClipTest(
+        "POLYGON ((0 5,5 7,10 5,0 5))",
+    // No points inside, one intersection
+    template<> template<> void object::test<53>()
+      doLineClipTest(
+        "POLYGON ((-5 10,0 15,0 10,-5 10))",
+    template<> template<> void object::test<54>()
+      doLineClipTest(
+        "POLYGON ((-5 10,0 5,-5 0,-5 10))",
+    // No points inside, two intersections
+    template<> template<> void object::test<55>()
+      doLineClipTest(
+        "POLYGON ((-5 5,0 10,0 0,-5 5))",
+    template<> template<> void object::test<56>()
+      doLineClipTest(
+        "POLYGON ((-5 5,0 10,0 5,-5 5))",
+    template<> template<> void object::test<57>()
+      doLineClipTest(
+        "POLYGON ((-5 5,0 7,0 3,-5 5))",
+    // One point inside
+    template<> template<> void object::test<58>()
+      doLineClipTest(
+        "POLYGON ((5 5,-5 0,-5 10,5 5))",
+        "LINESTRING (0.0 7.5,5 5,0.0 2.5)",
+    template<> template<> void object::test<59>()
+      doLineClipTest(
+        "POLYGON ((5 0,-5 0,-5 10,5 0))",
+    template<> template<> void object::test<60>()
+      doLineClipTest(
+        "POLYGON((10 0,-10 0,-10 10,10 0))",
+        "LINESTRING (0 5,10 0)",
+    template<> template<> void object::test<61>()
+      doLineClipTest(
+        "POLYGON ((5 0,-5 5,-5 10,5 0))",
+        "LINESTRING (0 5,5 0,0.0 2.5)",
+    template<> template<> void object::test<62>()
+      doLineClipTest(
+        "POLYGON ((10 5,-10 0,-10 10,10 5))",
+        "LINESTRING (0.0 7.5,10 5,0.0 2.5)",
+    template<> template<> void object::test<63>()
+      doLineClipTest(
+        "POLYGON ((10 10,-10 0,-10 5,10 10))",
+        "LINESTRING (0.0 7.5,10 10,0 5)",
+    template<> template<> void object::test<64>()
+      doLineClipTest(
+        "POLYGON ((5 5,-5 -5,-5 15,5 5))",
+        "LINESTRING (0 10,5 5,0 0)",
+    template<> template<> void object::test<65>()
+      doLineClipTest(
+        "POLYGON ((10 5,-10 -5,-10 15,10 5))",
+        "LINESTRING (0 10,10 5,0 0)",
+    template<> template<> void object::test<66>()
+      doLineClipTest(
+        "POLYGON ((5 0,-5 0,-5 20,5 0))",
+        "LINESTRING (0 10,5 0)",
+    template<> template<> void object::test<67>()
+      doLineClipTest(
+        "POLYGON ((10 0,-10 0,-10 20,10 0))",
+        "LINESTRING (0 10,10 0)",
+    template<> template<> void object::test<68>()
+      doLineClipTest(
+        "POLYGON ((5 5,-10 5,0 15,5 5))",
+        "LINESTRING (2.5 10.0,5 5,0 5)",
+    template<> template<> void object::test<69>()
+      doLineClipTest(
+        "POLYGON ((5 5,-5 -5,0 15,5 5))",
+        "LINESTRING (2.5 10.0,5 5,0 0)",
+    template<> template<> void object::test<70>()
+      doLineClipTest(
+        "POLYGON ((5 5,-15 -20,-15 30,5 5))",
+        "LINESTRING (1 10,5 5,1 0)",
+    // Two points inside
+    template<> template<> void object::test<71>()
+      doLineClipTest(
+        "POLYGON ((5 7,5 3,-5 5,5 7))",
+        "LINESTRING (0 6,5 7,5 3,0 4)",
+    template<> template<> void object::test<72>()
+      doLineClipTest(
+        "POLYGON ((5 7,5 3,-5 13,5 7))",
+        "LINESTRING (0 10,5 7,5 3,0 8)",
+    template<> template<> void object::test<73>()
+      doLineClipTest(
+        "POLYGON ((6 6,4 4,-4 14,6 6))",
+        "LINESTRING (1.0 10.0,6 6,4 4,0 9)",
+        Rectangle(0,0,10,10), 1e-12
+    // Polygon with hole which surrounds the rectangle
+    template<> template<> void object::test<74>()
+      doLineClipTest(
+        "POLYGON ((-2 -2,-2 12,12 12,12 -2,-2 -2),(-1 -1,11 -1,11 11,-1 11,-1 -1))",
+    // Polygon surrounding the rect, but with a hole inside the rect
+    template<> template<> void object::test<75>()
+      doLineClipTest(
+        "POLYGON ((-2 -2,-2 12,12 12,12 -2,-2 -2),(1 1,9 1,9 9,1 9,1 1))",
+        "POLYGON ((1 1,9 1,9 9,1 9,1 1))",
+    // inside
+    template<> template<> void object::test<76>()
+      doClipTest(
+    // outside
+    template<> template<> void object::test<77>()
+      doClipTest(
+    template<> template<> void object::test<78>()
+      doClipTest(
+    template<> template<> void object::test<79>()
+      doClipTest(
+    // go in and out
+    template<> template<> void object::test<80>()
+      doClipTest(
+    template<> template<> void object::test<81>()
+      doClipTest(
+    template<> template<> void object::test<82>()
+      doClipTest(
+    template<> template<> void object::test<83>()
+      doClipTest(
+    template<> template<> void object::test<84>()
+      doClipTest(
+    template<> template<> void object::test<85>()
+      doClipTest(
+    template<> template<> void object::test<86>()
+      doClipTest(
+    template<> template<> void object::test<87>()
+      doClipTest(
+    template<> template<> void object::test<88>()
+      doClipTest(
+    template<> template<> void object::test<89>()
+      doClipTest(
+    template<> template<> void object::test<90>()
+      doClipTest(
+        "POLYGON ((0 0,0 10,10 10,10 0,0 0))",
+    template<> template<> void object::test<91>()
+      doClipTest(
+        "POLYGON ((0 0,0 5,5 5,5 0,0 0))",
+    template<> template<> void object::test<92>()
+      doClipTest(
+        "POLYGON ((0 0,0 5,5 5,5 0,0 0),(3 3,4 4,4 2,3 3))",
+    template<> template<> void object::test<93>()
+      doClipTest(
+        "POLYGON ((0 0,0 5,5 5,5 0,1 0,3 1,3 3,0 0))",
+    template<> template<> void object::test<94>()
+      doClipTest(
+    template<> template<> void object::test<95>()
+      doClipTest(
+    template<> template<> void object::test<96>()
+      doClipTest(
+        "POLYGON ((0 0,5 5,5 0,0 0))",
+    template<> template<> void object::test<97>()
+      doClipTest(
+    template<> template<> void object::test<98>()
+      doClipTest(
+    template<> template<> void object::test<99>()
+      doClipTest(
+    template<> template<> void object::test<100>()
+      doClipTest(
+    template<> template<> void object::test<101>()
+      doClipTest(
+        "POLYGON ((0 5,0 10,5 10,0 5))",
+    template<> template<> void object::test<102>()
+      doClipTest(
+        "POLYGON ((0 5,0 10,10 5,0 5))",
+    template<> template<> void object::test<103>()
+      doClipTest(
+        "POLYGON ((0 5,0 10,10 0,0 5))",
+    template<> template<> void object::test<104>()
+      doClipTest(
+        "POLYGON ((0 5,0 10,5 0,0 5))",
+    template<> template<> void object::test<105>()
+      doClipTest(
+        "POLYGON ((0 5,0 10,5 5,0 5))",
+    template<> template<> void object::test<106>()
+      doClipTest(
+    template<> template<> void object::test<107>()
+      doClipTest(
+    template<> template<> void object::test<108>()
+      doClipTest(
+    template<> template<> void object::test<109>()
+      doClipTest(
+    template<> template<> void object::test<110>()
+      doClipTest(
+    template<> template<> void object::test<111>()
+      doClipTest(
+    template<> template<> void object::test<112>()
+      doClipTest(
+    template<> template<> void object::test<113>()
+      doClipTest(
+    template<> template<> void object::test<114>()
+      doClipTest(
+    template<> template<> void object::test<115>()
+      doClipTest(
+    template<> template<> void object::test<116>()
+      doClipTest(
+    template<> template<> void object::test<117>()
+      doClipTest(
+    template<> template<> void object::test<118>()
+      doClipTest(
+    template<> template<> void object::test<119>()
+      doClipTest(
+        "POLYGON ((0.0 2.5,0.0 7.5,5 5,0.0 2.5))",
+    template<> template<> void object::test<120>()
+      doClipTest(
+        "POLYGON ((0 0,0 5,5 0,0 0))",
+    template<> template<> void object::test<121>()
+      doClipTest(
+        "POLYGON ((10 0,-10 0,-10 10,10 0))",
+        "POLYGON ((0 0,0 5,10 0,0 0))",
+    template<> template<> void object::test<122>()
+      doClipTest(
+        "POLYGON ((0.0 2.5,0 5,5 0,0.0 2.5))",
+    template<> template<> void object::test<123>()
+      doClipTest(
+        "POLYGON ((0.0 2.5,0.0 7.5,10 5,0.0 2.5))",
+    template<> template<> void object::test<124>()
+      doClipTest(
+        "POLYGON ((0 5,0.0 7.5,10 10,0 5))",
+    template<> template<> void object::test<125>()
+      doClipTest(
+        "POLYGON ((0 0,0 10,5 5,0 0))",
+    template<> template<> void object::test<126>()
+      doClipTest(
+        "POLYGON ((0 0,0 10,10 5,0 0))",
+    template<> template<> void object::test<127>()
+      doClipTest(
+        "POLYGON ((0 0,0 10,5 0,0 0))",
+    template<> template<> void object::test<128>()
+      doClipTest(
+        "POLYGON ((0 0,0 10,10 0,0 0))",
+    template<> template<> void object::test<129>()
+      doClipTest(
+        "POLYGON ((0 5,0 10,2.5 10.0,5 5,0 5))",
+    template<> template<> void object::test<130>()
+      doClipTest(
+        "POLYGON ((0 0,0 10,2.5 10.0,5 5,0 0))",
+    template<> template<> void object::test<131>()
+      doClipTest(
+        "POLYGON ((0 0,0 10,1 10,5 5,1 0,0 0))",
+    template<> template<> void object::test<132>()
+      doClipTest(
+        "POLYGON ((0 4,0 6,5 7,5 3,0 4))",
+    template<> template<> void object::test<133>()
+      doClipTest(
+        "POLYGON ((0 8,0 10,5 7,5 3,0 8))",
+    template<> template<> void object::test<134>()
+      doClipTest(
+        "POLYGON ((0 9,0 10,1.0 10.0,6 6,4 4,0 9))",
+    template<> template<> void object::test<135>()
+      doClipTest(
+    template<> template<> void object::test<136>()
+      doClipTest(
+        "POLYGON ((0 0,0 10,10 10,10 0,0 0),(1 1,9 1,9 9,1 9,1 1))",
+    // Polygon with hole cut at the right corner
+    template<> template<> void object::test<137>()
+      doClipTest(
+        "POLYGON ((5 5,15 5,15 -5,5 -5,5 5),(8 1,8 -1,9 -1,9 1,8 1))",
+        "POLYGON ((5 0,5 5,10 5,10 0,9 0,9 1,8 1,8 0,5 0))",
+    // Polygon going around a corner
+    template<> template<> void object::test<138>()
+      doClipTest(
+        "POLYGON ((-6 5,5 5,5 -6,-6 5))",
+    // Hole in a corner
+    template<> template<> void object::test<139>()
+      doClipTest(
+        "POLYGON ((-15 -15,-15 15,15 15,15 -15,-15 -15),(-5 5,-5 -5,5 -5,5 5,-5 5))",
+        "POLYGON ((0 5,0 10,10 10,10 0,5 0,5 5,0 5))",
+    // Hole going around a corner
+    template<> template<> void object::test<140>()
+      doClipTest(
+        "POLYGON ((-15 -15,-15 15,15 15,15 -15,-15 -15),(-6 5,5 -6,5 5,-6 5))",
+    // Surround the rectangle, hole outside rectangle
+    template<> template<> void object::test<141>()
+      doClipTest(
+        "POLYGON ((-15 -15,-15 15,15 15,15 -15,-15 -15),(-5 5,-6 5,-6 6,-5 6,-5 5))",
+    // Surround the rectangle, hole outside rectangle but shares edge
+    template<> template<> void object::test<142>()
+      doClipTest(
+        "POLYGON ((-15 -15,-15 15,15 15,15 -15,-15 -15),(0 5,-1 5,-1 6,0 6,0 5))",
+//-- NEW TESTS HERE
+    // Simple overlap, counter-clockwise shell
+    // Found in TestFunctionAA.xml case1 test1
+    template<> template<> void object::test<204>()
+      Rectangle r(10,10,100,100);
+      const char *inp =
+        "POLYGON ((50 50,200 50,200 200,50 200,50 50))"; // CCW
+        //"POLYGON((50 50,50 200,200 200,200 50,50 50))"; // CW
+      const char *exp =
+        "POLYGON ((50 50, 50 100, 100 100, 100 50, 50 50))";
+      doClipTest(inp, exp, r);
+    // Clockwise shell, clockwise hole (both clipped)
+    template<> template<> void object::test<205>()
+      Rectangle r(0,0,10,10);
+      const char *inp =
+        "POLYGON ("
+          "(-10 2,-10 8,8 8,8 2,-10 2)," // CW
+          "(-5 6,5 6,5 4,-5 4,-5 6)"     // CW
+      const char *exp =
+        "POLYGON((0 8,8 8, 8 2, 0 2, 0 4, 5 4, 5 6, 0 6, 0 8))";
+    // Counterclockwise shell, clockwise hole (both clipped)
+    template<> template<> void object::test<206>()
+      const char *inp =
+        "POLYGON ("
+          "(-10 2,8 2,8 8,-10 8,-10 2)," // CCW
+      const char *exp =
More information about the geos-commits
