[geos-commits] r4160 - in trunk/tests/unit/operation: linemerge overlay
svn_geos at osgeo.org
Wed Mar 2 04:29:21 PST 2016
Author: mloskot
Date: 2016-03-02 04:29:21 -0800 (Wed, 02 Mar 2016)
New Revision: 4160
trunk/tests/unit/operation/linemerge/LineMergerTest.cpp
trunk/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
Test merging MultiLineString result of union.
Remove unnecessary FIXED precision model from the triangle test in OverlayOpUnionTest.cpp.
Add comment to link corresponding tests in OverlayOpUnionTest.cpp and LineMergerTest.cpp.
Modified: trunk/tests/unit/operation/linemerge/LineMergerTest.cpp
--- trunk/tests/unit/operation/linemerge/LineMergerTest.cpp 2016-03-01 15:22:48 UTC (rev 4159)
+++ trunk/tests/unit/operation/linemerge/LineMergerTest.cpp 2016-03-02 12:29:21 UTC (rev 4160)
@@ -232,6 +232,47 @@
doTest(inpWKT, expWKT);
+ // Merge segments of a triangle
+ template<> template<>
+ void object::test<7>()
+ const char* inpWKT[] = {
+ "LINESTRING(0 0, 0 5)",
+ "LINESTRING(0 5, 5 5)",
+ "LINESTRING(5 5, 5 0)",
+ "LINESTRING(5 0, 0 0)",
+ NULL };
+ const char* expWKT[] = {
+ "LINESTRING(0 0, 0 5, 5 5, 5 0, 0 0)",
+ NULL };
+ doTest(inpWKT, expWKT);
+ // Merge union of segments of a triangle
+ void object::test<8>()
+ GeomPtr line1(readWKT("LINESTRING(0 0, 0 5)"));
+ GeomPtr line2(readWKT("LINESTRING(0 5, 5 5)"));
+ GeomPtr line3(readWKT("LINESTRING(5 5, 5 0)"));
+ GeomPtr line4(readWKT("LINESTRING(5 0, 0 0)"));
+ // Union segments incrementally
+ GeomPtr lines12(line1->Union(line2.get()));
+ GeomPtr lines123(lines12->Union(line3.get()));
+ GeomPtr lines1234(lines123->Union(line4.get()));
+ // MultiLineString expected by design, see corresponding test in OverlayOpUnionTest
+ ensure_equals(lines1234->getGeometryTypeId(), geos::geom::GEOS_MULTILINESTRING);
+ // Merge MultiLineString into LineString
+ LineMerger lineMerger;
+ lineMerger.add(lines1234.get());
+ mrgGeoms = lineMerger.getMergedLineStrings();
+ GeomPtr expected(readWKT("LINESTRING(0 0, 0 5, 5 5, 5 0, 0 0)"));
+ ensure(contains(*mrgGeoms, expected.get(), true));
} // namespace tut
Modified: trunk/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
--- trunk/tests/unit/operation/overlay/OverlayOpUnionTest.cpp 2016-03-01 15:22:48 UTC (rev 4159)
+++ trunk/tests/unit/operation/overlay/OverlayOpUnionTest.cpp 2016-03-02 12:29:21 UTC (rev 4160)
@@ -43,26 +43,24 @@
template<>
void object::test<1>()
- // Arrange
- geos::geom::PrecisionModel pm(1e+13);
- GeometryFactoryPtr factory = geos::geom::GeometryFactory::create(&pm);
+ GeometryFactoryPtr factory = geos::geom::GeometryFactory::create();
geos::io::WKTReader reader(*factory);
GeometryPtr line1(reader.read("LINESTRING(0 0, 0 5)"));
GeometryPtr line2(reader.read("LINESTRING(0 5, 5 5)"));
GeometryPtr line3(reader.read("LINESTRING(5 5, 5 0)"));
GeometryPtr line4(reader.read("LINESTRING(5 0, 0 0)"));
- // Act: union segments incrementally
+ // union segments incrementally
GeometryPtr lines12(line1->Union(line2.get()));
GeometryPtr lines123(lines12->Union(line3.get()));
GeometryPtr lines1234(lines123->Union(line4.get()));
- // Assert
// NOTE: Since the union operation makes no effort to simplify and
// drop nodes of degree 2 from the built topology,
// do not expect GEOS_LINESTRING.
+ // See LineMergerTest where the test triangle is generated as a single LineString.
} // namespace tut
More information about the geos-commits
