[geos-commits] r4161 - trunk/tests/unit/operation/linemerge
svn_geos at osgeo.org
Wed Mar 2 04:34:13 PST 2016
Author: mloskot
Date: 2016-03-02 04:34:13 -0800 (Wed, 02 Mar 2016)
New Revision: 4161
trunk/tests/unit/operation/linemerge/LineMergerTest.cpp
Describe test cases
Modified: trunk/tests/unit/operation/linemerge/LineMergerTest.cpp
--- trunk/tests/unit/operation/linemerge/LineMergerTest.cpp 2016-03-02 12:29:21 UTC (rev 4160)
+++ trunk/tests/unit/operation/linemerge/LineMergerTest.cpp 2016-03-02 12:34:13 UTC (rev 4161)
@@ -160,6 +160,7 @@
doTest(inpWKT, expWKT);
+ // Only lines with coincident vertices may be merged.
template<> template<>
void object::test<2>()
@@ -181,6 +182,7 @@
+ // Two intersecting/crossing segments must not merge
void object::test<3>()
More information about the geos-commits
