[geos-commits] r4162 - trunk/tests/unit/geom
svn_geos at osgeo.org
Sat Mar 5 15:23:37 PST 2016
Author: mloskot
Date: 2016-03-05 15:23:37 -0800 (Sat, 05 Mar 2016)
New Revision: 4162
Added:
trunk/tests/unit/geom/GeometryComponentFilterTest.cpp
trunk/tests/unit/geom/GeometryFilterTest.cpp
Add test for GeometryFilter class.
Add test for GeometryComponentFilter class.
Both tests are based on common filter with intention to compare
behaviour both GeometryFilter vs GeometryComponentFilter,
with related discussion at
http://lists.osgeo.org/pipermail/geos-devel/2016-March/007441.html
Added: trunk/tests/unit/geom/GeometryComponentFilterTest.cpp
--- trunk/tests/unit/geom/GeometryComponentFilterTest.cpp (rev 0)
+++ trunk/tests/unit/geom/GeometryComponentFilterTest.cpp 2016-03-05 23:23:37 UTC (rev 4162)
@@ -0,0 +1,95 @@
+// Test Suite for geos::geom::GeometryComponentFilter class.
+#include <tut.hpp>
+// geos
+#include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/GeometryComponentFilter.h>
+#include <geos/io/WKTReader.h>
+// std
+#include <memory>
+#include <vector>
+namespace tut
+struct test_geometrycomponentfilter_data
+ typedef geos::geom::Geometry::AutoPtr GeometryPtr; // owner
+ typedef std::vector<geos::geom::Geometry const*> GeometryRefArray; // observer
+ geos::geom::GeometryFactory::unique_ptr gf;
+ geos::io::WKTReader reader;
+ test_geometrycomponentfilter_data()
+ : gf(geos::geom::GeometryFactory::create())
+ , reader(gf.get())
+typedef test_group<test_geometrycomponentfilter_data> group;
+typedef group::object object;
+group test_point_group("geos::geom::GeometryComponentFilter");
+// Test Cases
+// Split components into two categories: Lineal and all other types
+template<>
+template<>
+void object::test<1>()
+ // collection of 4 geometries
+ GeometryPtr g(reader.read("GEOMETRYCOLLECTION("
+ "POINT(0 0),"
+ "LINESTRING(0 0,1 1,1 2),"
+ "POLYGON((0 0,4 0,4 4,0 4,0 0)),"
+ "MULTILINESTRING((0 0,1 1,1 2),(2 3,3 2,5 4)))"));
+ struct GeometryComponentSplitter : public geos::geom::GeometryComponentFilter
+ GeometryRefArray& lineal;
+ GeometryRefArray& nonlineal;
+ GeometryComponentSplitter(GeometryRefArray& lineal, GeometryRefArray& nonlineal)
+ : lineal(lineal), nonlineal(nonlineal)
+ ensure(lineal.empty());
+ ensure(nonlineal.empty());
+ void filter_ro(geos::geom::Geometry const* g)
+ if (dynamic_cast<geos::geom::Lineal const*>(g))
+ lineal.push_back(g);
+ else
+ nonlineal.push_back(g);
+ void filter_rw(geos::geom::Geometry*) {}
+ GeometryRefArray lineal;
+ GeometryRefArray nonlineal;
+ GeometryComponentSplitter splitter(lineal, nonlineal);
+ g->apply_ro(&splitter);
+ // TODO: Verify the actual results
+ // lineal:
+ // 0: LineString
+ // 1: LinearRing
+ // 2: MultiLineString
+ // 3: LineString
+ // 4: LineString
+ // nonlineal:
+ // 0: GeometryCollection
+ // 1: Point
+ // 2: Polygon
+ ensure_equals(lineal.size(), 5); // TODO: Why MultiLineString is in?
+ // TODO: shouldn't be 1 for POLYGON?
+ ensure_equals(nonlineal.size(), 3);
+ // TODO: is 8 right?
+ ensure_equals(lineal.size() + nonlineal.size(), 8);
+} // namespace tut
Added: trunk/tests/unit/geom/GeometryFilterTest.cpp
--- trunk/tests/unit/geom/GeometryFilterTest.cpp (rev 0)
+++ trunk/tests/unit/geom/GeometryFilterTest.cpp 2016-03-05 23:23:37 UTC (rev 4162)
@@ -0,0 +1,96 @@
+// Test Suite for geos::geom::GeometryFilter class.
+#include <tut.hpp>
+// geos
+#include <geos/geom/GeometryFilter.h>
+// std
+#include <memory>
+#include <vector>
+namespace tut
+struct test_geometryfilter_data
+ test_geometryfilter_data()
+typedef test_group<test_geometryfilter_data> group;
+group test_point_group("geos::geom::GeometryFilter");
+// Test Cases
+// Split geometries into two categories: Lineal and all other types
+template<>
+template<>
+ "POINT(0 0),"
+ struct GeometrySplitter : public geos::geom::GeometryFilter
+ GeometrySplitter(GeometryRefArray& lineal, GeometryRefArray& nonlineal)
+ else
+ GeometrySplitter splitter(lineal, nonlineal);
+ // lineal:
+ // 0: LineString
+ // 1: MultiLineString
+ // 2: LineString
+ // 3: LineString
+ // nonlineal:
+ // 1: Point
+ // 2: Polygon
+ ensure_equals(lineal.size(), 4);
+ // TODO: is 7, shouldn't be not 4?
+ //ensure_equals(lineal.size() + nonlineal.size(), g->getNumGeometries());
+ ensure_equals(g->getNumGeometries(), 4);
+ ensure_equals(lineal.size() + nonlineal.size(), 7);
+} // namespace tut
More information about the geos-commits
