[geos-commits] r4163 - trunk/tests/unit/geom
svn_geos at osgeo.org
Sat Mar 5 15:40:32 PST 2016
Author: mloskot
Date: 2016-03-05 15:40:32 -0800 (Sat, 05 Mar 2016)
New Revision: 4163
trunk/tests/unit/geom/GeometryComponentFilterTest.cpp
trunk/tests/unit/geom/GeometryFilterTest.cpp
Fix repeated test groups definitions (introduced in r4162).
Modified: trunk/tests/unit/geom/GeometryComponentFilterTest.cpp
--- trunk/tests/unit/geom/GeometryComponentFilterTest.cpp 2016-03-05 23:23:37 UTC (rev 4162)
+++ trunk/tests/unit/geom/GeometryComponentFilterTest.cpp 2016-03-05 23:40:32 UTC (rev 4163)
@@ -31,7 +31,7 @@
typedef test_group<test_geometrycomponentfilter_data> group;
typedef group::object object;
-group test_point_group("geos::geom::GeometryComponentFilter");
+group test_geometrycomponentfilter_group("geos::geom::GeometryComponentFilter");
// Test Cases
Modified: trunk/tests/unit/geom/GeometryFilterTest.cpp
--- trunk/tests/unit/geom/GeometryFilterTest.cpp 2016-03-05 23:23:37 UTC (rev 4162)
+++ trunk/tests/unit/geom/GeometryFilterTest.cpp 2016-03-05 23:40:32 UTC (rev 4163)
@@ -31,7 +31,7 @@
typedef test_group<test_geometryfilter_data> group;
-group test_point_group("geos::geom::GeometryFilter");
+group test_geometryfilter_group("geos::geom::GeometryFilter");
// Test Cases
More information about the geos-commits
