[geos-commits] r4254 - in trunk: . capi include/geos/geom tests/unit tests/unit/capi
Sandro Santilli
strk at kbt.io
Wed Sep 7 05:57:03 PDT 2016
Author: strk
Date: 2016-09-07 05:57:02 -0700 (Wed, 07 Sep 2016)
New Revision: 4254
Added:
trunk/tests/unit/capi/GEOSUserDataTest.cpp
trunk/NEWS
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
trunk/include/geos/geom/Geometry.h
trunk/tests/unit/Makefile.am
Add GEOSGeom_setUserData and GEOSGeom_getUserData
Patch by Rashad Kanavath <rashad.kanavath at c-s.fr>
Modified: trunk/NEWS
--- trunk/NEWS 2016-09-02 11:10:23 UTC (rev 4253)
+++ trunk/NEWS 2016-09-07 12:57:02 UTC (rev 4254)
@@ -5,6 +5,7 @@
- The PHP binding moved to its own repository:
http://git.osgeo.org/gogs/geos/php-geos (#765)
- New things:
+ - CAPI: GEOSGeom_{get,set}UserData (Rashad Kanavath)
- CAPI: GEOSGeom_setPrecision (#713) - PHP: Geometry->setPrecision
- CAPI: GEOSGeom_getPrecision
- CAPI: GEOSMinimumRotatedRectangle and GEOSMinimumWidth
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2016-09-02 11:10:23 UTC (rev 4253)
+++ trunk/capi/geos_c.cpp 2016-09-07 12:57:02 UTC (rev 4254)
@@ -717,6 +717,18 @@
return GEOSSetSRID_r( handle, g, srid );
+void *
+GEOSGeom_getUserData(const Geometry *g)
+ return GEOSGeom_getUserData_r( handle, g );
+void
+GEOSGeom_setUserData(Geometry *g, void* userData)
+ return GEOSGeom_setUserData_r( handle, g, userData );
char
GEOSHasZ(const Geometry *g)
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2016-09-02 11:10:23 UTC (rev 4253)
+++ trunk/capi/geos_c.h.in 2016-09-07 12:57:02 UTC (rev 4254)
@@ -955,6 +955,12 @@
extern void GEOS_DLL GEOSSetSRID_r(GEOSContextHandle_t handle,
GEOSGeometry* g, int SRID);
+extern void* GEOS_DLL GEOSGeom_getUserData_r(GEOSContextHandle_t handle,
+const GEOSGeometry* g);
+extern void GEOS_DLL GEOSGeom_setUserData_r(GEOSContextHandle_t handle,
+ GEOSGeometry* g, void* userData);
/* May be called on all geometries in GEOS 3.x, returns -1 on error and 1
* for non-multi geometries. Older GEOS versions only accept
* GeometryCollections or Multi* geometries here, and are likely to crash
@@ -1862,6 +1868,11 @@
extern void GEOS_DLL GEOSSetSRID(GEOSGeometry* g, int SRID);
+extern void* GEOS_DLL GEOSGeom_getUserData(const GEOSGeometry* g);
+extern void GEOS_DLL GEOSGeom_setUserData(GEOSGeometry* g, void* userData);
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2016-09-02 11:10:23 UTC (rev 4253)
+++ trunk/capi/geos_ts_c.cpp 2016-09-07 12:57:02 UTC (rev 4254)
@@ -2526,6 +2526,26 @@
void
+GEOSGeom_setUserData_r(GEOSContextHandle_t extHandle, Geometry *g, void* userData)
+ assert(0 != g);
+ if ( 0 == extHandle )
+ return;
+ GEOSContextHandleInternal_t *handle = 0;
+ handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if ( 0 == handle->initialized )
+ return;
+ g->setUserData(userData);
+void
GEOSSetSRID_r(GEOSContextHandle_t extHandle, Geometry *g, int srid)
assert(0 != g);
@@ -3601,6 +3621,39 @@
return out;
+ void*
+GEOSGeom_getUserData_r(GEOSContextHandle_t extHandle, const Geometry *g)
+ assert(0 != g);
+ return 0;
+ return 0;
+ try
+ return g->getUserData();
+ catch (const std::exception &e)
+ handle->ERROR_MESSAGE("%s", e.what());
+ catch (...)
+ handle->ERROR_MESSAGE("Unknown exception thrown");
+ return NULL;
int
GEOSGetSRID_r(GEOSContextHandle_t extHandle, const Geometry *g)
Modified: trunk/include/geos/geom/Geometry.h
--- trunk/include/geos/geom/Geometry.h 2016-09-02 11:10:23 UTC (rev 4253)
+++ trunk/include/geos/geom/Geometry.h 2016-09-07 12:57:02 UTC (rev 4254)
@@ -216,7 +216,7 @@
* @return the user data object, or <code>null</code> if none set
- void* getUserData() { return _userData; }
+ void* getUserData() const { return _userData; }
* \brief
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2016-09-02 11:10:23 UTC (rev 4253)
+++ trunk/tests/unit/Makefile.am 2016-09-07 12:57:02 UTC (rev 4254)
@@ -138,6 +138,7 @@
capi/GEOSNearestPointsTest.cpp \
capi/GEOSWithinTest.cpp \
capi/GEOSSimplifyTest.cpp \
+ capi/GEOSUserDataTest.cpp \
capi/GEOSPreparedGeometryTest.cpp \
capi/GEOSPointOnSurfaceTest.cpp \
capi/GEOSPolygonizer_getCutEdgesTest.cpp \
Added: trunk/tests/unit/capi/GEOSUserDataTest.cpp
--- trunk/tests/unit/capi/GEOSUserDataTest.cpp (rev 0)
+++ trunk/tests/unit/capi/GEOSUserDataTest.cpp 2016-09-07 12:57:02 UTC (rev 4254)
@@ -0,0 +1,105 @@
+// Test Suite for C-API GEOSSimplify
+#include <tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <memory>
+namespace tut
+ // Test Group
+ // Common data used in test cases.
+ struct test_capigeouserdata_data
+ GEOSGeometry* geom_;
+ static void notice(const char *fmt, ...)
+ std::fprintf( stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capigeouserdata_data()
+ : geom_(0)
+ initGEOS(notice, notice);
+ ~test_capigeouserdata_data()
+ GEOSGeom_destroy(geom_);
+ geom_ = 0;
+ finishGEOS();
+ typedef test_group<test_capigeouserdata_data> group;
+ typedef group::object object;
+ group test_capigeosuserdata_group("capi::GEOSUserData");
+ // Test Cases
+ // Test GEOSUserData
+ template<>
+ template<>
+ void object::test<1>()
+ geom_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ ensure ( 0 != GEOSisEmpty(geom_) );
+ int in = 1;
+ GEOSGeom_setUserData(geom_, &in);
+ int* out = (int *)GEOSGeom_getUserData(geom_);
+ ensure_equals(*out, 1);
+ struct UserData
+ int a;
+ int b;
+ template<>
+ template<>
+ void object::test<2>()
+ UserData in;
+ in.a = 1;
+ in.b = 2;
+ struct UserData* out = (struct UserData* )GEOSGeom_getUserData(geom_);
+ ensure_equals(in.a, out->a);
+ ensure_equals(in.b, out->b);
+ ensure_equals(&in, out);
+} // namespace tut
More information about the geos-commits
