[geos-commits] r4255 - trunk
Sandro Santilli
strk at kbt.io
Wed Sep 7 06:03:05 PDT 2016
Author: strk
Date: 2016-09-07 06:03:04 -0700 (Wed, 07 Sep 2016)
New Revision: 4255
trunk/CMakeLists.txt
CMake: generate geos_svn_revision.h in binary directory if not exists
Patch by Rashad Kanavath <rashad.kanavath at c-s.fr>
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2016-09-07 12:57:02 UTC (rev 4254)
+++ trunk/CMakeLists.txt 2016-09-07 13:03:04 UTC (rev 4255)
@@ -265,21 +265,19 @@
ENDMACRO(GET_SVN_REVISION)
# Determine SVN/Git revision
-set(GEOS_BUILD_PACKAGED TRUE)
+# Determine SVN/Git revision
if(EXISTS "${PROJECT_SOURCE_DIR}/.svn")
- set(GEOS_BUILD_PACKAGED FALSE)
GET_SVN_REVISION()
-elseif(EXISTS "${PROJECT_SOURCE_DIR}/.git")
-elseif(DEFINED ENV{CI})
endif()
-if (NOT GEOS_BUILD_PACKAGED)
+# geos_svn_revision.h does not exists in source or binary directory, we generate it
+if( NOT EXISTS "${PROJECT_SOURCE_DIR}/geos_svn_revision.h" AND
+ NOT EXISTS "${PROJECT_BINARY_DIR}/geos_svn_revision.h")
message(STATUS "Generating GEOS revision header in ${PROJECT_BINARY_DIR}/geos_svn_revision.h")
# CI builds (Travis CI, AppVeyor, etc.) perform git clone, not svn checkout.
- # So, CI environment needs a dummy revision to generate the required header.
+ # So, CI environment needs a dummy revision to generate the required header.
if (DEFINED ENV{CI})
set(Project_WC_REVISION 999999)
endif()
More information about the geos-commits
