[geos-commits] [SCM] geos branch svn-trunk updated. 5a730fc50dab2610a9e6c037b521accc66b7777b
git at osgeo.org
git at osgeo.org
Mon Apr 24 11:32:15 PDT 2017
the project "geos".
The branch, svn-trunk has been updated
via 5a730fc50dab2610a9e6c037b521accc66b7777b (commit)
from e1f6205d2ed6fe317f9eccdbede8824561d196e8 (commit)
revisions in full, below.
commit 5a730fc50dab2610a9e6c037b521accc66b7777b
Author: Mateusz Łoskot <mateusz at loskot.net>
Date: Mon Apr 24 20:28:54 2017 +0200
Avoid use of internal geos/util/math.h
Copy java_math_round geos/util/math.cpp to xmltester.cpp.
Declared functions are internal to the library
and not included in GEOS shared library exports.
Fixes #831
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 3f70ed4..54585bb 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -1,4 +1,4 @@
* GEOS - Geometry Engine Open Source
* http://geos.osgeo.org
@@ -39,7 +39,6 @@
#include <geos/operation/buffer/BufferOp.h>
#include <geos/util.h>
#include <geos/util/Interrupt.h>
-#include <geos/util/math.h>
//#include <geos/geomgraph.h>
#include <geos/io/WKBReader.h>
#include <geos/io/WKBWriter.h>
@@ -88,6 +87,34 @@ using std::runtime_error;
namespace {
+// Asymmetric Rounding Algorithm - equivalent to Java Math.round()
+// Copy from geos/util/math.cpp
+double java_math_round(double val)
+ double n;
+ double f = std::fabs(std::modf(val, &n));
+ if (val >= 0)
+ if (f < 0.5) {
+ return std::floor(val);
+ } else if (f > 0.5) {
+ return std::ceil(val);
+ } else {
+ return (n + 1.0);
+ } else {
+ if (f < 0.5) {
+ } else {
+ return n;
+} // java_math_round
// a utility function defining a very simple method to indent a line of text
const char * getIndent( unsigned int numIndents )
@@ -335,7 +362,7 @@ XMLTester::printTest(bool success, const std::string& expected_result, const std
std::cout << " test" << testCount << ": "
<< opSignature;
std::cout << ": " << (success?"ok.":"failed.");
- std::cout << " (" << std::setprecision(15) << geos::util::round(prof.getTot()/1000) << " ms)" << std::endl;
+ std::cout << " (" << std::setprecision(15) << java_math_round(prof.getTot()/1000) << " ms)" << std::endl;
std::cout << "\tDescription: " << curr_case_desc << std::endl;
Summary of changes:
tests/xmltester/XMLTester.cpp | 33 ++++++++++++++++++++++++++++++---
1 file changed, 30 insertions(+), 3 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
