[geos-commits] [SCM] geos branch svn-3.6 updated. 05ae13d4391082df9b6e2252d77848577d6f1697
git at osgeo.org
git at osgeo.org
Tue Apr 25 01:36:48 PDT 2017
the project "geos".
The branch, svn-3.6 has been updated
via 05ae13d4391082df9b6e2252d77848577d6f1697 (commit)
via c8053dd2d4640a9176096cd355393efdec3b39fe (commit)
from 687d2b49a9acc2de82f5bfd481e3aaa8d9b45af7 (commit)
revisions in full, below.
commit 05ae13d4391082df9b6e2252d77848577d6f1697
Author: Mateusz Łoskot <mateusz at loskot.net>
Date: Mon Apr 24 20:28:54 2017 +0200
Avoid use of internal geos/util/math.h
Copy java_math_round geos/util/math.cpp to xmltester.cpp.
Declared functions are internal to the library
and not included in GEOS shared library exports.
Fixes #831
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 2505232..5673b8e 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -1,4 +1,4 @@
* GEOS - Geometry Engine Open Source
* http://geos.osgeo.org
@@ -39,7 +39,6 @@
#include <geos/operation/buffer/BufferOp.h>
#include <geos/util.h>
#include <geos/util/Interrupt.h>
-#include <geos/util/math.h>
//#include <geos/geomgraph.h>
#include <geos/io/WKBReader.h>
#include <geos/io/WKBWriter.h>
@@ -88,6 +87,34 @@ using std::runtime_error;
namespace {
+// Asymmetric Rounding Algorithm - equivalent to Java Math.round()
+// Copy from geos/util/math.cpp
+double java_math_round(double val)
+ double n;
+ double f = std::fabs(std::modf(val, &n));
+ if (val >= 0)
+ if (f < 0.5) {
+ return std::floor(val);
+ } else if (f > 0.5) {
+ return std::ceil(val);
+ } else {
+ return (n + 1.0);
+ } else {
+ if (f < 0.5) {
+ } else {
+ return n;
+} // java_math_round
// a utility function defining a very simple method to indent a line of text
const char * getIndent( unsigned int numIndents )
@@ -335,7 +362,7 @@ XMLTester::printTest(bool success, const std::string& expected_result, const std
std::cout << " test" << testCount << ": "
<< opSignature;
std::cout << ": " << (success?"ok.":"failed.");
- std::cout << " (" << std::setprecision(15) << geos::util::round(prof.getTot()/1000) << " ms)" << std::endl;
+ std::cout << " (" << std::setprecision(15) << java_math_round(prof.getTot()/1000) << " ms)" << std::endl;
std::cout << "\tDescription: " << curr_case_desc << std::endl;
commit c8053dd2d4640a9176096cd355393efdec3b39fe
Date: Tue Apr 18 14:39:28 2017 +0200
Add NMAKE_VER from VS 2017 Version 15.1
diff --git a/nmake.opt b/nmake.opt
index 9dd202b..6cfe4a6 100644
--- a/nmake.opt
+++ b/nmake.opt
@@ -144,6 +144,9 @@ GEOS_MSC = 1900
!ELSEIF "$(_NMAKE_VER)" == "14.10.25017.0"
GEOS_MSVC = 14.10
GEOS_MSC = 1910
+!ELSEIF "$(_NMAKE_VER)" == "14.10.25019.0"
+GEOS_MSVC = 14.10
+GEOS_MSC = 1910
!ELSE
GEOS_MSVC = 0.0
GEOS_MSC = 0
Summary of changes:
nmake.opt | 3 +++
tests/xmltester/XMLTester.cpp | 33 ++++++++++++++++++++++++++++++---
2 files changed, 33 insertions(+), 3 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
