[geos-commits] [SCM] geos branch master updated. f0a3f0002f5dd3c8308c21d95aa1eb4008cb06d6
Thu Sep 7 01:06:30 PDT 2017
the project "geos".
       via  f0a3f0002f5dd3c8308c21d95aa1eb4008cb06d6 (commit)
      from  4d4474359b94f1ab04815b4131db44cdc0efe7ce (commit)
revisions in full, below.
commit f0a3f0002f5dd3c8308c21d95aa1eb4008cb06d6
Author: Mateusz Loskot <mateusz at loskot.net>
Date:   Thu Sep 7 10:05:13 2017 +0200
    [CMake] Add build-cmake.bat utility for convenience.
    Builds GEOS using CMake and Visual Studio 2017 for 32-bit or 64-bit platform.
    (eg. cd geos; tools\build-cmake.bat 64)
diff --git a/tools/build-cmake.bat b/tools/build-cmake.bat
new file mode 100644
index 0000000..4705e50
--- /dev/null
+++ b/tools/build-cmake.bat
@@ -0,0 +1,53 @@
+ at echo off
+rem Runs CMake to configure GEOS for Visual Studio 2017.
+rem Runs MSBuild to build the generated solution.
+rem
+rem Usage:
+rem 1. Copy build.bat to build.local.bat (git ignored file)
+rem 2. Make your adjustments in the CONFIGURATION section below
+rem 3. Run build.local.bat 32|64
+rem 4. Optionally, run devenv.exe {project}{32|64}.sln from command line
+rem ### CONFIGURATION #####################################
+rem #######################################################
+if not defined VS150COMNTOOLS goto :NoVS
+if [%1]==[] goto :Usage
+if [%1]==[32] goto :32
+if [%1]==[64] goto :64
+goto :Usage
+:32
+set GEOSP=32
+set MSBUILDP=Win32
+set GENERATOR="Visual Studio 15 2017"
+goto :Build
+:64
+set GEOSP=64
+set MSBUILDP=x64
+set GENERATOR="Visual Studio 15 2017 Win64"
+goto :Build
+:Build
+set BUILDDIR=_build.vs2017x%GEOSP%
+mkdir %BUILDDIR%
+pushd %BUILDDIR%
+"C:\Program Files\CMake\bin\cmake.exe" ^
+    -G %GENERATOR% ^
+move geos.sln geos%GEOSP%.sln
+REM msbuild.exe geos%GEOSP%.sln /p:Configuration=Release /p:Platform=%MSBUILDP%
+popd
+goto :EOF
+:NoVS
+ at echo build.bat
+ at echo  Visual Studio 2017 not found
+ at echo  "%%VS150COMNTOOLS%%" environment variable not defined
+exit /B 1
+:Usage
+ at echo build.bat
+ at echo Usage: build.bat [32 or 64]
+exit /B 1
Summary of changes:
 tools/build-cmake.bat |   53 +++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 53 insertions(+)
 create mode 100644 tools/build-cmake.bat
hooks/post-receive
geos
More information about the geos-commits mailing list
