[geos-commits] [SCM] geos branch master updated. 5d3e5a1c0e525b72481fdddec35f2929e8e4d665
git at osgeo.org
git at osgeo.org
Thu Sep 7 02:11:41 PDT 2017
the project "geos".
via 5d3e5a1c0e525b72481fdddec35f2929e8e4d665 (commit)
via 441dc93f8cd23dcdf204143d524e426f4ccb8bc3 (commit)
from f0a3f0002f5dd3c8308c21d95aa1eb4008cb06d6 (commit)
revisions in full, below.
commit 5d3e5a1c0e525b72481fdddec35f2929e8e4d665
Merge: f0a3f00 441dc93
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Sep 7 02:11:41 2017 -0700
Merge branch 'ml/remove-GeometryList' of mloskot/geos into master
commit 441dc93f8cd23dcdf204143d524e426f4ccb8bc3
Author: Mateusz Loskot <mateusz at loskot.net>
Date: Thu Sep 7 10:25:58 2017 +0200
Remove GeometryList class
It is completely unused in GEOS and becomes deprecated in C++11.
Use std::vector<Geometry::Ptr> instead.
Part of GEOS RFC 5: C++11 Compilation Mode
diff --git a/include/geos/geom/GeometryList.h b/include/geos/geom/GeometryList.h
deleted file mode 100644
index ca1502d..0000000
--- a/include/geos/geom/GeometryList.h
+++ /dev/null
@@ -1,83 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2006 Refractions Research Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: ORIGINAL WORK
-#ifndef GEOS_GEOM_GEOMETRYLIST_H
-#define GEOS_GEOM_GEOMETRYLIST_H
-#include <geos/export.h>
-#include <geos/geom/Geometry.h> // for auto_ptr
-#include <memory> // for auto_ptr
-#include <vector>
-#ifdef _MSC_VER
-#pragma warning(push)
-#pragma warning(disable: 4251) // warning C4251: needs to have dll-interface to be used by clients of class
-#endif
-namespace geos {
-namespace geom { // geos.geom
-/** \brief
- * Manager of Geometry pointers. Owns the Geometries.
-class GEOS_DLL GeometryList {
-public:
- /// auto_ptr needs to access private destructor
- friend class std::auto_ptr<GeometryList>;
- typedef std::vector<Geometry*>::size_type size_type;
- /// Only way to manage a GeometryList is trough
- /// this an auto_ptr<>. @see create()
- typedef std::auto_ptr<GeometryList> AutoPtr;
- /// Create an empty GeometryList
- static GeometryList::AutoPtr create();
- /// Add a geometry to the list (takes ownership)
- void add(Geometry::AutoPtr geom);
- /// Return number of geometries in this list
- size_type size() const;
- /// Returned object lifetime is bound to GeometryList lifetime
- Geometry* operator[] (size_type);
- const Geometry* operator[] (size_type) const;
-private:
- std::vector<Geometry*> geoms;
- GeometryList();
- ~GeometryList();
-} // namespace geos.geom
-#ifdef _MSC_VER
-#pragma warning(pop)
-#endif
-#endif // GEOS_GEOM_GEOMETRYLIST_H
diff --git a/src/geom/GeometryList.cpp b/src/geom/GeometryList.cpp
index b24f29c..0000000
--- a/src/geom/GeometryList.cpp
+++ /dev/null
@@ -1,80 +0,0 @@
-#include <geos/geom/GeometryList.h>
-#include <vector>
-namespace geos {
-/*private*/
-GeometryList::GeometryList()
-/*private*/
-GeometryList::~GeometryList()
- for (std::vector<Geometry*>::size_type i=0, n=geoms.size(); i<n; i++)
- delete geoms[i];
-/*public static*/
-GeometryList::AutoPtr
-GeometryList::create()
- return GeometryList::AutoPtr(new GeometryList());
-/*public*/
-void
-GeometryList::add(Geometry::AutoPtr geom)
- geoms.push_back(geom.release());
-/*public*/
-GeometryList::size_type
-GeometryList::size() const
- return geoms.size();
-/*public*/
-Geometry *
-GeometryList::operator[] (GeometryList::size_type i)
- return geoms[i];
-/*public*/
-const Geometry *
-GeometryList::operator[] (GeometryList::size_type i) const
- return geoms[i];
Summary of changes:
include/geos/geom/GeometryList.h | 83 --------------------------------------
src/geom/GeometryList.cpp | 80 ------------------------------------
2 files changed, 163 deletions(-)
delete mode 100644 include/geos/geom/GeometryList.h
delete mode 100644 src/geom/GeometryList.cpp
hooks/post-receive
geos
More information about the geos-commits
