[geos-commits] [SCM] geos branch master updated. b507095ff861fbe8642cd65660bf530e674efb2f
git at osgeo.org
git at osgeo.org
Thu Sep 7 03:28:15 PDT 2017
the project "geos".
via b507095ff861fbe8642cd65660bf530e674efb2f (commit)
via 4c9b08743a31f3ecf3fee742cbaffcb69e00d2f7 (commit)
from d36e59c25334a9b06bb9b4007982766c5071f7dc (commit)
revisions in full, below.
commit b507095ff861fbe8642cd65660bf530e674efb2f
Merge: d36e59c 4c9b087
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Sep 7 03:28:15 2017 -0700
Merge branch 'ml/rfc5-cpp11-configure' of mloskot/geos into master
commit 4c9b08743a31f3ecf3fee742cbaffcb69e00d2f7
Author: Mateusz Loskot <mateusz at loskot.net>
Date: Thu Sep 7 11:59:14 2017 +0200
Set C++11 as required standard
Add -Wsuggest-override or -Wmissing-override compiler options.
Part of GEOS RFC 5: C++11 Compilation Mode
diff --git a/configure.ac b/configure.ac
index 37122a3..1bc58fb 100644
--- a/configure.ac
+++ b/configure.ac
@@ -133,6 +133,16 @@ dnl --------------------------------------------------------------------
dnl - Append default C++ and C flags
+AX_CXX_COMPILE_STDCXX_11([noext],[mandatory])
+WARNFLAGS=""
+AC_LANG_PUSH([C++])
+dnl Available in GCC 5.1
+AX_CHECK_COMPILE_FLAG([-Wsuggest-override], [WARNFLAGS="$WARNFLAGS -Wsuggest-override"])
+dnl Available in clang 3.5
+AX_CHECK_COMPILE_FLAG([-Wmissing-override], [WARNFLAGS="$WARNFLAGS -Wmissing-override"])
+AC_LANG_POP([C++])
dnl In order for AC_LIBTOOL_COMPILER_OPTION to use
dnl the C compiler we need the hack below.
dnl It is likely a bug in the libtool macro file to
@@ -144,11 +154,10 @@ AC_LIBTOOL_LANG_CXX_CONFIG
# Set default AM_CXXFLAGS and AM_CFLAGS
# -pedantic: ISO does not support long long
# we add -Wno-long-long to avoid those messages
-WARNFLAGS=""
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -pedantic], [dummy_cv_pedantic], [-pedantic], [], [WARNFLAGS="$WARNFLAGS -pedantic"], [])
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [dummy_cv_wall], [-Wall], [], [WARNFLAGS="$WARNFLAGS -Wall"], [])
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ansi], [dummy_cv_ansi], [-ansi], [], [WARNFLAGS="$WARNFLAGS -ansi"], [])
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wno-long-long], [dummy_cv_no_long_long], [-Wno-long-long], [], [WARNFLAGS="$WARNFLAGS -Wno-long-long"], [])
+AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [dummy_cv_wall], [-Wall], [], [WARNFLAGS="$WARNFLAGS -Wall"], [])
+AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wno-long-long], [dummy_cv_wno_long_long], [-Wno-long-long], [], [WARNFLAGS="$WARNFLAGS -Wno-long-long"], [])
# To make numerical computation more stable, we use --ffloat-store
NUMERICFLAGS=""
diff --git a/macros/ax_check_compile_flag.m4 b/macros/ax_check_compile_flag.m4
new file mode 100755
index 0000000..ca36397
--- /dev/null
+++ b/macros/ax_check_compile_flag.m4
@@ -0,0 +1,74 @@
+# http://www.gnu.org/software/autoconf-archive/ax_check_compile_flag.html
+# SYNOPSIS
+# AX_CHECK_COMPILE_FLAG(FLAG, [ACTION-SUCCESS], [ACTION-FAILURE], [EXTRA-FLAGS], [INPUT])
+# DESCRIPTION
+# Check whether the given FLAG works with the current language's compiler
+# or gives an error. (Warnings, however, are ignored)
+# ACTION-SUCCESS/ACTION-FAILURE are shell commands to execute on
+# success/failure.
+# If EXTRA-FLAGS is defined, it is added to the current language's default
+# flags (e.g. CFLAGS) when the check is done. The check is thus made with
+# the flags: "CFLAGS EXTRA-FLAGS FLAG". This can for example be used to
+# force the compiler to issue an error when a bad flag is given.
+# INPUT gives an alternative input source to AC_COMPILE_IFELSE.
+# NOTE: Implementation based on AX_CFLAGS_GCC_OPTION. Please keep this
+# macro in sync with AX_CHECK_{PREPROC,LINK}_FLAG.
+# LICENSE
+# Copyright (c) 2008 Guido U. Draheim <guidod at gmx.de>
+# Copyright (c) 2011 Maarten Bosmans <mkbosmans at gmail.com>
+# This program is free software: you can redistribute it and/or modify it
+# under the terms of the GNU General Public License as published by the
+# Free Software Foundation, either version 3 of the License, or (at your
+# option) any later version.
+# This program is distributed in the hope that it will be useful, but
+# WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General
+# Public License for more details.
+# You should have received a copy of the GNU General Public License along
+# with this program. If not, see <http://www.gnu.org/licenses/>.
+# As a special exception, the respective Autoconf Macro's copyright owner
+# gives unlimited permission to copy, distribute and modify the configure
+# scripts that are the output of Autoconf when processing the Macro. You
+# need not follow the terms of the GNU General Public License when using
+# or distributing such scripts, even though portions of the text of the
+# Macro appear in them. The GNU General Public License (GPL) does govern
+# all other use of the material that constitutes the Autoconf Macro.
+# This special exception to the GPL applies to versions of the Autoconf
+# Macro released by the Autoconf Archive. When you make and distribute a
+# modified version of the Autoconf Macro, you may extend this special
+# exception to the GPL to apply to your modified version as well.
+#serial 4
+AC_DEFUN([AX_CHECK_COMPILE_FLAG],
+[AC_PREREQ(2.64)dnl for _AC_LANG_PREFIX and AS_VAR_IF
+AS_VAR_PUSHDEF([CACHEVAR],[ax_cv_check_[]_AC_LANG_ABBREV[]flags_$4_$1])dnl
+AC_CACHE_CHECK([whether _AC_LANG compiler accepts $1], CACHEVAR, [
+ ax_check_save_flags=$[]_AC_LANG_PREFIX[]FLAGS
+ _AC_LANG_PREFIX[]FLAGS="$[]_AC_LANG_PREFIX[]FLAGS $4 $1"
+ AC_COMPILE_IFELSE([m4_default([$5],[AC_LANG_PROGRAM()])],
+ [AS_VAR_SET(CACHEVAR,[yes])],
+ [AS_VAR_SET(CACHEVAR,[no])])
+ _AC_LANG_PREFIX[]FLAGS=$ax_check_save_flags])
+AS_VAR_IF(CACHEVAR,yes,
+ [m4_default([$2], :)],
+ [m4_default([$3], :)])
+AS_VAR_POPDEF([CACHEVAR])dnl
+])dnl AX_CHECK_COMPILE_FLAGS
diff --git a/macros/ax_cxx_compile_stdcxx.m4 b/macros/ax_cxx_compile_stdcxx.m4
index 0000000..2c18e49
--- /dev/null
+++ b/macros/ax_cxx_compile_stdcxx.m4
@@ -0,0 +1,562 @@
+# http://www.gnu.org/software/autoconf-archive/ax_cxx_compile_stdcxx.html
+# SYNOPSIS
+# AX_CXX_COMPILE_STDCXX(VERSION, [ext|noext], [mandatory|optional])
+# DESCRIPTION
+# Check for baseline language coverage in the compiler for the specified
+# version of the C++ standard. If necessary, add switches to CXX and
+# CXXCPP to enable support. VERSION may be '11' (for the C++11 standard)
+# or '14' (for the C++14 standard).
+# The second argument, if specified, indicates whether you insist on an
+# extended mode (e.g. -std=gnu++11) or a strict conformance mode (e.g.
+# -std=c++11). If neither is specified, you get whatever works, with
+# preference for an extended mode.
+# The third argument, if specified 'mandatory' or if left unspecified,
+# indicates that baseline support for the specified C++ standard is
+# required and that the macro should error out if no mode with that
+# support is found. If specified 'optional', then configuration proceeds
+# regardless, after defining HAVE_CXX${VERSION} if and only if a
+# supporting mode is found.
+# LICENSE
+# Copyright (c) 2008 Benjamin Kosnik <bkoz at redhat.com>
+# Copyright (c) 2012 Zack Weinberg <zackw at panix.com>
+# Copyright (c) 2013 Roy Stogner <roystgnr at ices.utexas.edu>
+# Copyright (c) 2014, 2015 Google Inc.; contributed by Alexey Sokolov <sokolov at google.com>
+# Copyright (c) 2015 Paul Norman <penorman at mac.com>
+# Copyright (c) 2015 Moritz Klammler <moritz at klammler.eu>
+# Copying and distribution of this file, with or without modification, are
+# permitted in any medium without royalty provided the copyright notice
+# and this notice are preserved. This file is offered as-is, without any
+# warranty.
+#serial 4
+dnl This macro is based on the code from the AX_CXX_COMPILE_STDCXX_11 macro
+dnl (serial version number 13).
+AC_DEFUN([AX_CXX_COMPILE_STDCXX], [dnl
+ m4_if([$1], [11], [],
+ [$1], [14], [],
+ [$1], [17], [m4_fatal([support for C++17 not yet implemented in AX_CXX_COMPILE_STDCXX])],
+ [m4_fatal([invalid first argument `$1' to AX_CXX_COMPILE_STDCXX])])dnl
+ m4_if([$2], [], [],
+ [$2], [ext], [],
+ [$2], [noext], [],
+ [m4_fatal([invalid second argument `$2' to AX_CXX_COMPILE_STDCXX])])dnl
+ m4_if([$3], [], [ax_cxx_compile_cxx$1_required=true],
+ [$3], [mandatory], [ax_cxx_compile_cxx$1_required=true],
+ [$3], [optional], [ax_cxx_compile_cxx$1_required=false],
+ [m4_fatal([invalid third argument `$3' to AX_CXX_COMPILE_STDCXX])])
+ AC_LANG_PUSH([C++])dnl
+ ac_success=no
+ AC_CACHE_CHECK(whether $CXX supports C++$1 features by default,
+ ax_cv_cxx_compile_cxx$1,
+ [AC_COMPILE_IFELSE([AC_LANG_SOURCE([_AX_CXX_COMPILE_STDCXX_testbody_$1])],
+ [ax_cv_cxx_compile_cxx$1=yes],
+ [ax_cv_cxx_compile_cxx$1=no])])
+ if test x$ax_cv_cxx_compile_cxx$1 = xyes; then
+ ac_success=yes
+ fi
+ m4_if([$2], [noext], [], [dnl
+ if test x$ac_success = xno; then
+ for switch in -std=gnu++$1 -std=gnu++0x; do
+ cachevar=AS_TR_SH([ax_cv_cxx_compile_cxx$1_$switch])
+ AC_CACHE_CHECK(whether $CXX supports C++$1 features with $switch,
+ $cachevar,
+ [ac_save_CXX="$CXX"
+ CXX="$CXX $switch"
+ AC_COMPILE_IFELSE([AC_LANG_SOURCE([_AX_CXX_COMPILE_STDCXX_testbody_$1])],
+ [eval $cachevar=yes],
+ [eval $cachevar=no])
+ CXX="$ac_save_CXX"])
+ if eval test x\$$cachevar = xyes; then
+ if test -n "$CXXCPP" ; then
+ CXXCPP="$CXXCPP $switch"
+ fi
+ ac_success=yes
+ break
+ fi
+ done
+ fi])
+ m4_if([$2], [ext], [], [dnl
+ dnl HP's aCC needs +std=c++11 according to:
+ dnl http://h21007.www2.hp.com/portal/download/files/unprot/aCxx/PDF_Release_Notes/769149-001.pdf
+ dnl Cray's crayCC needs "-h std=c++11"
+ for switch in -std=c++$1 -std=c++0x +std=c++$1 "-h std=c++$1"; do
+ $cachevar,
+ fi
+ ac_success=yes
+ break
+ fi
+ done
+ fi])
+ AC_LANG_POP([C++])
+ if test x$ax_cxx_compile_cxx$1_required = xtrue; then
+ AC_MSG_ERROR([*** A compiler with support for C++$1 language features is required.])
+ fi
+ fi
+ HAVE_CXX$1=0
+ AC_MSG_NOTICE([No compiler with C++$1 support was found])
+ else
+ HAVE_CXX$1=1
+ AC_DEFINE(HAVE_CXX$1,1,
+ [define if the compiler supports basic C++$1 syntax])
+ fi
+ AC_SUBST(HAVE_CXX$1)
+dnl Test body for checking C++11 support
+m4_define([_AX_CXX_COMPILE_STDCXX_testbody_11],
+ _AX_CXX_COMPILE_STDCXX_testbody_new_in_11
+dnl Test body for checking C++14 support
+m4_define([_AX_CXX_COMPILE_STDCXX_testbody_14],
+ _AX_CXX_COMPILE_STDCXX_testbody_new_in_14
+dnl Tests for new features in C++11
+m4_define([_AX_CXX_COMPILE_STDCXX_testbody_new_in_11], [[
+// If the compiler admits that it is not ready for C++11, why torture it?
+// Hopefully, this will speed up the test.
+#ifndef __cplusplus
+#error "This is not a C++ compiler"
+#elif __cplusplus < 201103L
+#error "This is not a C++11 compiler"
+#else
+namespace cxx11
+ namespace test_static_assert
+ template <typename T>
+ struct check
+ static_assert(sizeof(int) <= sizeof(T), "not big enough");
+ namespace test_final_override
+ struct Base
+ virtual void f() {}
+ struct Derived : public Base
+ virtual void f() override {}
+ namespace test_double_right_angle_brackets
+ template < typename T >
+ struct check {};
+ typedef check<void> single_type;
+ typedef check<check<void>> double_type;
+ typedef check<check<check<void>>> triple_type;
+ typedef check<check<check<check<void>>>> quadruple_type;
+ namespace test_decltype
+ int
+ f()
+ int a = 1;
+ decltype(a) b = 2;
+ return a + b;
+ namespace test_type_deduction
+ template < typename T1, typename T2 >
+ struct is_same
+ static const bool value = false;
+ struct is_same<T, T>
+ static const bool value = true;
+ auto
+ add(T1 a1, T2 a2) -> decltype(a1 + a2)
+ return a1 + a2;
+ int
+ test(const int c, volatile int v)
+ static_assert(is_same<int, decltype(0)>::value == true, "");
+ static_assert(is_same<int, decltype(c)>::value == false, "");
+ static_assert(is_same<int, decltype(v)>::value == false, "");
+ auto ac = c;
+ auto av = v;
+ auto sumi = ac + av + 'x';
+ auto sumf = ac + av + 1.0;
+ static_assert(is_same<int, decltype(ac)>::value == true, "");
+ static_assert(is_same<int, decltype(av)>::value == true, "");
+ static_assert(is_same<int, decltype(sumi)>::value == true, "");
+ static_assert(is_same<int, decltype(sumf)>::value == false, "");
+ static_assert(is_same<int, decltype(add(c, v))>::value == true, "");
+ return (sumf > 0.0) ? sumi : add(c, v);
+ namespace test_noexcept
+ int f() { return 0; }
+ int g() noexcept { return 0; }
+ static_assert(noexcept(f()) == false, "");
+ static_assert(noexcept(g()) == true, "");
+ namespace test_constexpr
+ template < typename CharT >
+ unsigned long constexpr
+ strlen_c_r(const CharT *const s, const unsigned long acc) noexcept
+ return *s ? strlen_c_r(s + 1, acc + 1) : acc;
+ strlen_c(const CharT *const s) noexcept
+ return strlen_c_r(s, 0UL);
+ static_assert(strlen_c("") == 0UL, "");
+ static_assert(strlen_c("1") == 1UL, "");
+ static_assert(strlen_c("example") == 7UL, "");
+ static_assert(strlen_c("another\0example") == 7UL, "");
+ namespace test_rvalue_references
+ template < int N >
+ struct answer
+ static constexpr int value = N;
+ answer<1> f(int&) { return answer<1>(); }
+ answer<2> f(const int&) { return answer<2>(); }
+ answer<3> f(int&&) { return answer<3>(); }
+ void
+ test()
+ int i = 0;
+ const int c = 0;
+ static_assert(decltype(f(i))::value == 1, "");
+ static_assert(decltype(f(c))::value == 2, "");
+ static_assert(decltype(f(0))::value == 3, "");
+ namespace test_uniform_initialization
+ struct test
+ static const int zero {};
+ static const int one {1};
+ static_assert(test::zero == 0, "");
+ static_assert(test::one == 1, "");
+ namespace test_lambdas
+ void
+ test1()
+ auto lambda1 = [](){};
+ auto lambda2 = lambda1;
+ lambda1();
+ lambda2();
+ int
+ test2()
+ auto a = [](int i, int j){ return i + j; }(1, 2);
+ auto b = []() -> int { return '0'; }();
+ auto c = [=](){ return a + b; }();
+ auto d = [&](){ return c; }();
+ auto e = [a, &b](int x) mutable {
+ const auto identity = [](int y){ return y; };
+ for (auto i = 0; i < a; ++i)
+ a += b--;
+ return x + identity(a + b);
+ }(0);
+ return a + b + c + d + e;
+ int
+ test3()
+ const auto nullary = [](){ return 0; };
+ const auto unary = [](int x){ return x; };
+ using nullary_t = decltype(nullary);
+ using unary_t = decltype(unary);
+ const auto higher1st = [](nullary_t f){ return f(); };
+ const auto higher2nd = [unary](nullary_t f1){
+ return [unary, f1](unary_t f2){ return f2(unary(f1())); };
+ return higher1st(nullary) + higher2nd(nullary)(unary);
+ namespace test_variadic_templates
+ template <int...>
+ struct sum;
+ template <int N0, int... N1toN>
+ struct sum<N0, N1toN...>
+ static constexpr auto value = N0 + sum<N1toN...>::value;
+ template <>
+ struct sum<>
+ static constexpr auto value = 0;
+ static_assert(sum<>::value == 0, "");
+ static_assert(sum<1>::value == 1, "");
+ static_assert(sum<23>::value == 23, "");
+ static_assert(sum<1, 2>::value == 3, "");
+ static_assert(sum<5, 5, 11>::value == 21, "");
+ static_assert(sum<2, 3, 5, 7, 11, 13>::value == 41, "");
+ // http://stackoverflow.com/questions/13728184/template-aliases-and-sfinae
+ // Clang 3.1 fails with headers of libstd++ 4.8.3 when using std::function
+ // because of this.
+ namespace test_template_alias_sfinae
+ struct foo {};
+ template<typename T>
+ using member = typename T::member_type;
+ void func(...) {}
+ void func(member<T>*) {}
+ void test();
+ void test() { func<foo>(0); }
+} // namespace cxx11
+#endif // __cplusplus >= 201103L
+dnl Tests for new features in C++14
+m4_define([_AX_CXX_COMPILE_STDCXX_testbody_new_in_14], [[
+// If the compiler admits that it is not ready for C++14, why torture it?
+#elif __cplusplus < 201402L
+#error "This is not a C++14 compiler"
+#else
+namespace cxx14
+ namespace test_polymorphic_lambdas
+ int
+ test()
+ const auto lambda = [](auto&&... args){
+ const auto istiny = [](auto x){
+ return (sizeof(x) == 1UL) ? 1 : 0;
+ const int aretiny[] = { istiny(args)... };
+ return aretiny[0];
+ return lambda(1, 1L, 1.0f, '1');
+ namespace test_binary_literals
+ constexpr auto ivii = 0b0000000000101010;
+ static_assert(ivii == 42, "wrong value");
+ namespace test_generalized_constexpr
+ constexpr unsigned long
+ auto length = 0UL;
+ for (auto p = s; *p; ++p)
+ ++length;
+ return length;
+ static_assert(strlen_c("x") == 1UL, "");
+ static_assert(strlen_c("test") == 4UL, "");
+ static_assert(strlen_c("another\0test") == 7UL, "");
+ namespace test_lambda_init_capture
+ int
+ test()
+ auto x = 0;
+ const auto lambda1 = [a = x](int b){ return a + b; };
+ const auto lambda2 = [a = lambda1(x)](){ return a; };
+ return lambda2();
+ namespace test_digit_seperators
+ constexpr auto ten_million = 100'000'000;
+ static_assert(ten_million == 100000000, "");
+ namespace test_return_type_deduction
+ auto f(int& x) { return x; }
+ decltype(auto) g(int& x) { return x; }
+ struct is_same
+ static constexpr auto value = false;
+ static constexpr auto value = true;
+ int
+ test()
+ auto x = 0;
+ static_assert(is_same<int, decltype(f(x))>::value, "");
+ static_assert(is_same<int&, decltype(g(x))>::value, "");
+ return x;
+} // namespace cxx14
+#endif // __cplusplus >= 201402L
diff --git a/macros/ax_cxx_compile_stdcxx_11.m4 b/macros/ax_cxx_compile_stdcxx_11.m4
index 0000000..0aadeaf
--- /dev/null
+++ b/macros/ax_cxx_compile_stdcxx_11.m4
@@ -0,0 +1,39 @@
+# http://www.gnu.org/software/autoconf-archive/ax_cxx_compile_stdcxx_11.html
+# SYNOPSIS
+# AX_CXX_COMPILE_STDCXX_11([ext|noext], [mandatory|optional])
+# DESCRIPTION
+# Check for baseline language coverage in the compiler for the C++11
+# standard; if necessary, add switches to CXX and CXXCPP to enable
+# support.
+# This macro is a convenience alias for calling the AX_CXX_COMPILE_STDCXX
+# macro with the version set to C++11. The two optional arguments are
+# forwarded literally as the second and third argument respectively.
+# Please see the documentation for the AX_CXX_COMPILE_STDCXX macro for
+# more information. If you want to use this macro, you also need to
+# download the ax_cxx_compile_stdcxx.m4 file.
+# LICENSE
+# warranty.
+#serial 17
+AX_REQUIRE_DEFINED([AX_CXX_COMPILE_STDCXX])
+AC_DEFUN([AX_CXX_COMPILE_STDCXX_11], [AX_CXX_COMPILE_STDCXX([11], [$1], [$2])])
Summary of changes:
configure.ac | 15 +-
macros/ax_check_compile_flag.m4 | 74 +++++
macros/ax_cxx_compile_stdcxx.m4 | 562 ++++++++++++++++++++++++++++++++++++
macros/ax_cxx_compile_stdcxx_11.m4 | 39 +++
4 files changed, 687 insertions(+), 3 deletions(-)
create mode 100755 macros/ax_check_compile_flag.m4
create mode 100755 macros/ax_cxx_compile_stdcxx.m4
create mode 100755 macros/ax_cxx_compile_stdcxx_11.m4
hooks/post-receive
geos
More information about the geos-commits
