[geos-commits] [SCM] geos branch master updated. 8193383d7020b369205c79ba9021e8b1774a84ca
git at osgeo.org
git at osgeo.org
Thu Sep 7 03:28:43 PDT 2017
the project "geos".
via 8193383d7020b369205c79ba9021e8b1774a84ca (commit)
via 50860b7a7466e88510dac92b4c1a568ee807e5c4 (commit)
from b507095ff861fbe8642cd65660bf530e674efb2f (commit)
revisions in full, below.
commit 8193383d7020b369205c79ba9021e8b1774a84ca
Merge: b507095 50860b7
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Sep 7 03:28:43 2017 -0700
Merge branch 'ml/rfc5-cpp11-unique_ptr' of mloskot/geos into master
commit 50860b7a7466e88510dac92b4c1a568ee807e5c4
Author: Mateusz Loskot <mateusz at loskot.net>
Date: Wed Sep 6 22:01:01 2017 +0200
Replace std::auto_ptr with std::unique_ptr
Rename T::AutoPtr to T::Ptr.
Add explicit move of input arguments of unique_ptr type
passed to sink functions.
Add explicit move of values of unique_ptr type
returned from source functions which give up class
member resource.
Comment source functions with:
NOTE: Apparently, this is 'source' method giving up the object resource.
Replace GeometryFactory::unique_ptr with GeometryFactory::Ptr based
on std::unique_ptr with custom GeometryFactoryDeleter.
Remove obscure dynamic_cast_auto_ptr from test utilities.
Part of GEOS RFC 5: C++11 Compilation Mode
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 66c792a..92fce4c 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -80,7 +80,7 @@ using geos::operation::overlay::OverlayOp;
using geos::operation::overlay::overlayOp;
using geos::operation::geounion::CascadedPolygonUnion;
-typedef std::auto_ptr<Geometry> GeomAutoPtr;
+typedef std::unique_ptr<Geometry> GeomPtr;
//## GLOBALS ################################################
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 1c52237..00e347f 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -144,7 +144,7 @@ using geos::util::IllegalArgumentException;
using geos::algorithm::distance::DiscreteHausdorffDistance;
using geos::algorithm::distance::DiscreteFrechetDistance;
typedef struct GEOSContextHandle_HS
@@ -2402,7 +2402,7 @@ GEOSUnaryUnion_r(GEOSContextHandle_t extHandle, const Geometry *g)
try
- GeomAutoPtr g3 ( g->Union() );
+ GeomPtr g3 ( g->Union() );
return g3.release();
catch (const std::exception &e)
@@ -2441,7 +2441,7 @@ GEOSNode_r(GEOSContextHandle_t extHandle, const Geometry *g)
try
- std::auto_ptr<Geometry> g3 = geos::noding::GeometryNoder::node(*g);
+ std::unique_ptr<Geometry> g3 = geos::noding::GeometryNoder::node(*g);
@@ -2560,7 +2560,7 @@ GEOSClipByRect_r(GEOSContextHandle_t extHandle, const Geometry *g, double xmin,
using geos::operation::intersection::Rectangle;
using geos::operation::intersection::RectangleIntersection;
Rectangle rect(xmin, ymin, xmax, ymax);
- std::auto_ptr<Geometry> g3 = RectangleIntersection::clip(*g, rect);
+ std::unique_ptr<Geometry> g3 = RectangleIntersection::clip(*g, rect);
@@ -4551,10 +4551,10 @@ GEOSGeom_setPrecision_r(GEOSContextHandle_t extHandle, const GEOSGeometry *g,
const PrecisionModel *pm = g->getPrecisionModel();
double cursize = pm->isFloating() ? 0 : 1.0/pm->getScale();
- std::auto_ptr<PrecisionModel> newpm;
+ std::unique_ptr<PrecisionModel> newpm;
if ( gridSize ) newpm.reset( new PrecisionModel(1.0/gridSize) );
else newpm.reset( new PrecisionModel() );
- GeometryFactory::unique_ptr gf =
+ GeometryFactory::Ptr gf =
GeometryFactory::create( newpm.get(), g->getSRID() );
Geometry *ret;
if ( gridSize && cursize != gridSize )
@@ -4701,7 +4701,7 @@ GEOSSimplify_r(GEOSContextHandle_t extHandle, const Geometry *g1, double toleran
try
using namespace geos::simplify;
- Geometry::AutoPtr g(DouglasPeuckerSimplifier::simplify(g1, tolerance));
+ Geometry::Ptr g(DouglasPeuckerSimplifier::simplify(g1, tolerance));
return g.release();
@@ -4734,7 +4734,7 @@ GEOSTopologyPreserveSimplify_r(GEOSContextHandle_t extHandle, const Geometry *g1
try
- Geometry::AutoPtr g(TopologyPreservingSimplifier::simplify(g1, tolerance));
+ Geometry::Ptr g(TopologyPreservingSimplifier::simplify(g1, tolerance));
return g.release();
@@ -6578,7 +6578,7 @@ GEOSSharedPaths_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g1, const G
const GeometryFactory* factory = g1->getFactory();
size_t count;
- std::auto_ptr< std::vector<Geometry*> > out1(
+ std::unique_ptr< std::vector<Geometry*> > out1(
new std::vector<Geometry*>()
count = forw.size();
@@ -6586,11 +6586,11 @@ GEOSSharedPaths_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g1, const G
for (size_t i=0; i<count; ++i) {
out1->push_back(forw[i]);
- std::auto_ptr<Geometry> out1g (
+ std::unique_ptr<Geometry> out1g (
factory->createMultiLineString(out1.release())
- std::auto_ptr< std::vector<Geometry*> > out2(
+ std::unique_ptr< std::vector<Geometry*> > out2(
count = back.size();
@@ -6598,18 +6598,18 @@ GEOSSharedPaths_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g1, const G
out2->push_back(back[i]);
- std::auto_ptr<Geometry> out2g (
+ std::unique_ptr<Geometry> out2g (
factory->createMultiLineString(out2.release())
- std::auto_ptr< std::vector<Geometry*> > out(
+ std::unique_ptr< std::vector<Geometry*> > out(
out->reserve(2);
out->push_back(out1g.release());
out->push_back(out2g.release());
- std::auto_ptr<Geometry> outg (
+ std::unique_ptr<Geometry> outg (
factory->createGeometryCollection(out.release())
@@ -6630,7 +6630,7 @@ GEOSSnap_r(GEOSContextHandle_t extHandle, const GEOSGeometry* g1,
try{
GeometrySnapper snapper( *g1 );
- std::auto_ptr<Geometry> ret = snapper.snapTo(*g2, tolerance);
+ std::unique_ptr<Geometry> ret = snapper.snapTo(*g2, tolerance);
return ret.release();
diff --git a/doc/example.cpp b/doc/example.cpp
index 1e1c226..0453c7b 100644
--- a/doc/example.cpp
+++ b/doc/example.cpp
@@ -392,7 +392,7 @@ create_arc(double llX, double llY, double width, double height, double startang,
return shapefactory.createArc(startang, endang);
-auto_ptr<Polygon>
+unique_ptr<Polygon>
create_sinestar(double cx, double cy, double size, int nArms, double armLenRat)
geos::geom::util::SineStarFactory fact(global_factory.get());
diff --git a/include/geos/algorithm/Centroid.h b/include/geos/algorithm/Centroid.h
index ebf0e69..16b7ae8 100644
--- a/include/geos/algorithm/Centroid.h
+++ b/include/geos/algorithm/Centroid.h
@@ -21,7 +21,7 @@
#include <geos/export.h>
#include <geos/geom/Coordinate.h> // for composition
-#include <memory> // for std::auto_ptr
+#include <memory> // for std::unique_ptr
// Forward declarations
namespace geos {
@@ -97,7 +97,7 @@ public:
private:
- std::auto_ptr<geom::Coordinate> areaBasePt;
+ std::unique_ptr<geom::Coordinate> areaBasePt;
geom::Coordinate triangleCent3;
geom::Coordinate cg3;
geom::Coordinate lineCentSum;
diff --git a/include/geos/geom/BinaryOp.h b/include/geos/geom/BinaryOp.h
index af5c74b..015d2f4 100644
--- a/include/geos/geom/BinaryOp.h
+++ b/include/geos/geom/BinaryOp.h
@@ -19,7 +19,7 @@
* This file provides a single templated function, taking two
* const Geometry pointers, applying a binary operator to them
- * and returning a result Geometry in an auto_ptr<>.
+ * and returning a result Geometry in an unique_ptr<>.
* The binary operator is expected to take two const Geometry pointers
* and return a newly allocated Geometry pointer, possibly throwing
@@ -69,7 +69,7 @@
#include <geos/util/TopologyException.h>
#include <geos/util.h>
-#include <memory> // for auto_ptr
+#include <memory> // for unique_ptr
//#define GEOS_DEBUG_BINARYOP 1
#define GEOS_DEBUG_BINARYOP_PRINT_INVALID 1
@@ -219,8 +219,8 @@ check_valid(const Geometry& g, const std::string& label, bool doThrow=false, boo
* May return the input untouched.
-inline std::auto_ptr<Geometry>
-fix_self_intersections(std::auto_ptr<Geometry> g, const std::string& label)
+inline std::unique_ptr<Geometry>
+fix_self_intersections(std::unique_ptr<Geometry> g, const std::string& label)
::geos::ignore_unused_variable_warning(label);
#ifdef GEOS_DEBUG_BINARYOP
@@ -269,10 +269,10 @@ fix_self_intersections(std::auto_ptr<Geometry> g, const std::string& label)
/// removal.
template <class BinOp>
-std::auto_ptr<Geometry>
+std::unique_ptr<Geometry>
SnapOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
- typedef std::auto_ptr<Geometry> GeomPtr;
+ typedef std::unique_ptr<Geometry> GeomPtr;
//using geos::precision::GeometrySnapper;
using geos::operation::overlay::snap::GeometrySnapper;
@@ -339,10 +339,10 @@ SnapOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
GeomPtr ret;
geos::util::TopologyException origException;
@@ -497,7 +497,7 @@ BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
for (double scale=maxScale; scale >= 1; scale /= 10)
PrecisionModel pm(scale);
- GeometryFactory::unique_ptr gf = GeometryFactory::create(&pm);
+ GeometryFactory::Ptr gf = GeometryFactory::create(&pm);
#if GEOS_DEBUG_BINARYOP
std::cerr << "Trying with scale " << scale << std::endl;
#endif
diff --git a/include/geos/geom/CoordinateList.h b/include/geos/geom/CoordinateList.h
index 2ca97de..902c007 100644
--- a/include/geos/geom/CoordinateList.h
+++ b/include/geos/geom/CoordinateList.h
@@ -25,7 +25,7 @@
#include <list>
#include <ostream> // for operator<<
#ifdef _MSC_VER
#pragma warning(push)
@@ -151,9 +151,9 @@ public:
return coords.erase(first, last);
- std::auto_ptr<Coordinate::Vect> toCoordinateArray() const
+ std::unique_ptr<Coordinate::Vect> toCoordinateArray() const
- std::auto_ptr<Coordinate::Vect> ret(new Coordinate::Vect);
+ std::unique_ptr<Coordinate::Vect> ret(new Coordinate::Vect);
ret->assign(coords.begin(), coords.end());
return ret;
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index 0b0ab90..008f891 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -23,7 +23,7 @@
#include <vector>
#include <iosfwd> // ostream
-#include <memory> // for auto_ptr typedef
+#include <memory> // for unique_ptr typedef
namespace geos {
@@ -66,7 +66,7 @@ protected:
public:
- typedef std::auto_ptr<CoordinateSequence> AutoPtr;
+ typedef std::unique_ptr<CoordinateSequence> Ptr;
virtual ~CoordinateSequence() {}
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index 32a410d..d6c0ef4 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -62,7 +62,7 @@ public:
friend std::ostream& operator<< (std::ostream& os, const Envelope& o);
- typedef std::auto_ptr<Envelope> AutoPtr;
+ typedef std::unique_ptr<Envelope> Ptr;
/** \brief
* Creates a null <code>Envelope</code>.
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 75cfd94..d82502a 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -171,13 +171,13 @@ public:
friend class GeometryFactory;
/// A vector of const Geometry pointers
- typedef std::vector<const Geometry *> ConstVect;
+ using ConstVect = std::vector<const Geometry *>;
/// A vector of non-const Geometry pointers
- typedef std::vector<Geometry *> NonConstVect;
+ using NonConstVect = std::vector<Geometry *>;
- /// An auto_ptr of Geometry
- typedef std::auto_ptr<Geometry> AutoPtr;
+ /// An unique_ptr of Geometry
+ using Ptr = std::unique_ptr<Geometry> ;
/// Make a deep-copy of this Geometry
virtual Geometry* clone() const=0;
@@ -614,7 +614,7 @@ public:
* @see UnaryUnionOp
- AutoPtr Union() const;
+ Ptr Union() const;
// throw(IllegalArgumentException *, TopologyException *);
@@ -765,7 +765,7 @@ public:
protected:
/// The bounding box of this Geometry
- mutable std::auto_ptr<Envelope> envelope;
+ mutable std::unique_ptr<Envelope> envelope;
/// Returns true if the array contains any non-empty Geometrys.
static bool hasNonEmptyElements(const std::vector<Geometry *>* geometries);
@@ -794,7 +794,7 @@ protected:
//virtual void checkEqualPrecisionModel(Geometry *other);
- virtual Envelope::AutoPtr computeEnvelopeInternal() const=0; //Abstract
+ virtual Envelope::Ptr computeEnvelopeInternal() const=0; //Abstract
virtual int compareToSameClass(const Geometry *geom) const=0; //Abstract
@@ -870,11 +870,11 @@ std::string geosversion();
std::string jtsport();
-// We use this instead of std::pair<auto_ptr<Geometry>> because C++11
+// We use this instead of std::pair<unique_ptr<Geometry>> because C++11
// forbids that construct:
// http://lwg.github.com/issues/lwg-closed.html#2068
struct GeomPtrPair {
GeomPtr first;
GeomPtr second;
diff --git a/include/geos/geom/GeometryCollection.h b/include/geos/geom/GeometryCollection.h
index ae24104..b7b5bbf 100644
--- a/include/geos/geom/GeometryCollection.h
+++ b/include/geos/geom/GeometryCollection.h
@@ -23,14 +23,14 @@
#include <geos/geom/Geometry.h> // for inheritance
//#include <geos/platform.h>
-#include <geos/geom/Envelope.h> // for proper use of auto_ptr<>
+#include <geos/geom/Envelope.h> // for proper use of unique_ptr<>
#include <geos/geom/Dimension.h> // for Dimension::DimensionType
#include <geos/inline.h>
#include <string>
#include <vector>
namespace geos {
@@ -190,7 +190,7 @@ protected:
std::vector<Geometry *>* geometries;
- Envelope::AutoPtr computeEnvelopeInternal() const;
+ Envelope::Ptr computeEnvelopeInternal() const;
int compareToSameClass(const Geometry *gc) const;
diff --git a/include/geos/geom/GeometryFactory.h b/include/geos/geom/GeometryFactory.h
index 474b4e8..e75560e 100644
--- a/include/geos/geom/GeometryFactory.h
+++ b/include/geos/geom/GeometryFactory.h
@@ -65,35 +65,26 @@ namespace geom { // geos::geom
* It is assumed that input Coordinates meet the given precision.
class GEOS_DLL GeometryFactory {
+private:
+ struct GeometryFactoryDeleter
+ void operator()(GeometryFactory* p) const
+ p->destroy();
public:
- // TODO: typedef std::unique_ptr<GeometryFactory,destroy>
- class unique_ptr {
- mutable GeometryFactory *_f;
- public:
- // Copying an auto_unique_ptr transfers ownership
- unique_ptr(const unique_ptr& o): _f(o.release()) {};
- GeometryFactory* release() const { GeometryFactory *f = _f; _f=0; return f; }
- void reset(GeometryFactory* f) { if ( _f ) _f->destroy(); _f = f; }
- // assigning an auto_unique_ptr transfers ownership
- unique_ptr& operator=(const unique_ptr& o) {
- reset( o.release() );
- return *this;
- GeometryFactory* get() const { return _f; }
- GeometryFactory* operator->() const { return _f; }
- GeometryFactory& operator*() { return *_f; };
- unique_ptr(): _f(0) {}
- unique_ptr(GeometryFactory* f): _f(f) {}
- ~unique_ptr() { reset(0); }
+ using Ptr = std::unique_ptr<GeometryFactory, GeometryFactoryDeleter>;
* \brief
* Constructs a GeometryFactory that generates Geometries having a
* floating PrecisionModel and a spatial-reference ID of 0.
- static GeometryFactory::unique_ptr create();
+ static GeometryFactory::Ptr create();
* \brief
@@ -107,7 +98,7 @@ public:
* and must be available for the whole lifetime
* of the GeometryFactory
- static GeometryFactory::unique_ptr create(const PrecisionModel *pm, int newSRID,
+ static GeometryFactory::Ptr create(const PrecisionModel *pm, int newSRID,
CoordinateSequenceFactory *nCoordinateSequenceFactory);
@@ -116,7 +107,7 @@ public:
* given CoordinateSequence implementation, a double-precision floating
* PrecisionModel and a spatial-reference ID of 0.
- static GeometryFactory::unique_ptr create(CoordinateSequenceFactory *nCoordinateSequenceFactory);
+ static GeometryFactory::Ptr create(CoordinateSequenceFactory *nCoordinateSequenceFactory);
* \brief
@@ -126,7 +117,7 @@ public:
* @param pm the PrecisionModel to use
- static GeometryFactory::unique_ptr create(const PrecisionModel *pm);
+ static GeometryFactory::Ptr create(const PrecisionModel *pm);
* \brief
@@ -137,14 +128,14 @@ public:
* @param pm the PrecisionModel to use, will be copied internally
* @param newSRID the SRID to use
- static GeometryFactory::unique_ptr create(const PrecisionModel* pm, int newSRID);
+ static GeometryFactory::Ptr create(const PrecisionModel* pm, int newSRID);
* \brief Copy constructor
* @param gf the GeometryFactory to clone from
- static GeometryFactory::unique_ptr create(const GeometryFactory &gf);
+ static GeometryFactory::Ptr create(const GeometryFactory &gf);
* \brief
@@ -224,8 +215,8 @@ public:
/// Construct a LinearRing taking ownership of given arguments
LinearRing* createLinearRing(CoordinateSequence* newCoords) const;
- std::auto_ptr<Geometry> createLinearRing(
- std::auto_ptr<CoordinateSequence> newCoords) const;
+ std::unique_ptr<Geometry> createLinearRing(
+ std::unique_ptr<CoordinateSequence> newCoords) const;
/// Construct a LinearRing with a deep-copy of given arguments
@@ -268,13 +259,13 @@ public:
LineString* createLineString() const;
/// Copy a LineString
- std::auto_ptr<LineString> createLineString(const LineString& ls) const;
+ std::unique_ptr<LineString> createLineString(const LineString& ls) const;
/// Construct a LineString taking ownership of given argument
LineString* createLineString(CoordinateSequence* coordinates) const;
- std::auto_ptr<Geometry> createLineString(
- std::auto_ptr<CoordinateSequence> coordinates) const;
+ std::unique_ptr<Geometry> createLineString(
+ std::unique_ptr<CoordinateSequence> coordinates) const;
/// Construct a LineString with a deep-copy of given argument
@@ -322,7 +313,7 @@ public:
/// @param toofar end iterator
template <class T>
- std::auto_ptr<Geometry> buildGeometry(T from, T toofar) const
+ std::unique_ptr<Geometry> buildGeometry(T from, T toofar) const
bool isHeterogeneous = false;
size_t count = 0;
@@ -341,12 +332,12 @@ public:
// for the empty geometry, return an empty GeometryCollection
if ( count == 0 ) {
- return std::auto_ptr<Geometry>( createGeometryCollection() );
+ return std::unique_ptr<Geometry>( createGeometryCollection() );
// for the single geometry, return a clone
if ( count == 1 ) {
- return std::auto_ptr<Geometry>( (*from)->clone() );
+ return std::unique_ptr<Geometry>( (*from)->clone() );
// Now we know it is a collection
@@ -364,20 +355,20 @@ public:
// for an heterogeneous ...
if ( isHeterogeneous ) {
- return std::auto_ptr<Geometry>( createGeometryCollection(fromGeoms) );
+ return std::unique_ptr<Geometry>( createGeometryCollection(fromGeoms) );
// At this point we know the collection is not hetereogenous.
if ( dynamic_cast<const Polygon*>(*from) ) {
- return std::auto_ptr<Geometry>( createMultiPolygon(fromGeoms) );
+ return std::unique_ptr<Geometry>( createMultiPolygon(fromGeoms) );
} else if ( dynamic_cast<const LineString*>(*from) ) {
- return std::auto_ptr<Geometry>( createMultiLineString(fromGeoms) );
+ return std::unique_ptr<Geometry>( createMultiLineString(fromGeoms) );
} else if ( dynamic_cast<const Point*>(*from) ) {
- return std::auto_ptr<Geometry>( createMultiPoint(fromGeoms) );
+ return std::unique_ptr<Geometry>( createMultiPoint(fromGeoms) );
// FIXME: Why not to throw an exception? --mloskot
assert(0); // buildGeomtry encountered an unkwnon geometry type
- return std::auto_ptr<Geometry>(); // nullptr
+ return std::unique_ptr<Geometry>(); // nullptr
/** \brief
diff --git a/include/geos/geom/LineSegment.h b/include/geos/geom/LineSegment.h
index 72ed905..5f5bc58 100644
--- a/include/geos/geom/LineSegment.h
+++ b/include/geos/geom/LineSegment.h
@@ -27,7 +27,7 @@
#include <iostream> // for ostream
namespace geos {
@@ -364,7 +364,7 @@ public:
* @param gf the geometery factory to use
* @return a LineString with the same geometry as this segment
- std::auto_ptr<LineString> toGeometry(const GeometryFactory& gf) const;
+ std::unique_ptr<LineString> toGeometry(const GeometryFactory& gf) const;
diff --git a/include/geos/geom/LineString.h b/include/geos/geom/LineString.h
index f7ab2f8..72fa019 100644
--- a/include/geos/geom/LineString.h
+++ b/include/geos/geom/LineString.h
@@ -25,13 +25,13 @@
#include <geos/platform.h> // do we need this ?
#include <geos/geom/Lineal.h> // for inheritance
-#include <geos/geom/CoordinateSequence.h> // for proper use of auto_ptr<>
+#include <geos/geom/CoordinateSequence.h> // for proper use of unique_ptr<>
#include <string>
#include <vector>
@@ -195,12 +195,12 @@ protected:
LineString(CoordinateSequence *pts, const GeometryFactory *newFactory);
/// Hopefully cleaner version of the above
- LineString(CoordinateSequence::AutoPtr pts,
+ LineString(CoordinateSequence::Ptr pts,
- CoordinateSequence::AutoPtr points;
+ CoordinateSequence::Ptr points;
private:
diff --git a/include/geos/geom/LinearRing.h b/include/geos/geom/LinearRing.h
index d763965..873dd8a 100644
--- a/include/geos/geom/LinearRing.h
+++ b/include/geos/geom/LinearRing.h
@@ -82,7 +82,7 @@ public:
- LinearRing(CoordinateSequence::AutoPtr points,
+ LinearRing(CoordinateSequence::Ptr points,
virtual Geometry *clone() const { return new LinearRing(*this); }
diff --git a/include/geos/geom/Point.h b/include/geos/geom/Point.h
index bc34963..14a5956 100644
--- a/include/geos/geom/Point.h
+++ b/include/geos/geom/Point.h
@@ -25,15 +25,15 @@
#include <geos/geom/Puntal.h> // for inheritance
#include <string>
#include <vector>
#ifdef _MSC_VER
@@ -155,7 +155,7 @@ protected:
Point(const Point &p);
int compareToSameClass(const Geometry *p) const;
@@ -164,7 +164,7 @@ private:
* The <code>Coordinate</code> wrapped by this <code>Point</code>.
- std::auto_ptr<CoordinateSequence> coordinates;
+ std::unique_ptr<CoordinateSequence> coordinates;
} // namespace geos::geom
diff --git a/include/geos/geom/Polygon.h b/include/geos/geom/Polygon.h
index 834b857..500a384 100644
--- a/include/geos/geom/Polygon.h
+++ b/include/geos/geom/Polygon.h
@@ -27,12 +27,12 @@
#include <geos/geom/Polygonal.h> // for inheritance
namespace geos {
@@ -182,7 +182,7 @@ protected:
std::vector<Geometry *> *holes; //Actually vector<LinearRing *>
private:
diff --git a/include/geos/geom/util/GeometryTransformer.h b/include/geos/geom/util/GeometryTransformer.h
index e98d9d7..410feea 100644
--- a/include/geos/geom/util/GeometryTransformer.h
+++ b/include/geos/geom/util/GeometryTransformer.h
@@ -23,10 +23,10 @@
#include <geos/geom/Coordinate.h> // destructor visibility for vector
-#include <geos/geom/Geometry.h> // destructor visibility for auto_ptr
-#include <geos/geom/CoordinateSequence.h> // destructor visibility for auto_ptr
+#include <geos/geom/Geometry.h> // destructor visibility for unique_ptr
+#include <geos/geom/CoordinateSequence.h> // destructor visibility for unique_ptr
#include <vector>
virtual ~GeometryTransformer();
- std::auto_ptr<Geometry> transform(const Geometry* nInputGeom);
+ std::unique_ptr<Geometry> transform(const Geometry* nInputGeom);
void setSkipTransformedInvalidInteriorRings(bool b);
@@ -114,42 +114,42 @@ protected:
* [final]
- CoordinateSequence::AutoPtr createCoordinateSequence(
- std::auto_ptr< std::vector<Coordinate> > coords);
+ CoordinateSequence::Ptr createCoordinateSequence(
+ std::unique_ptr< std::vector<Coordinate> > coords);
- virtual CoordinateSequence::AutoPtr transformCoordinates(
+ virtual CoordinateSequence::Ptr transformCoordinates(
const CoordinateSequence* coords,
const Geometry* parent);
- virtual Geometry::AutoPtr transformPoint(
+ virtual Geometry::Ptr transformPoint(
const Point* geom,
- virtual Geometry::AutoPtr transformMultiPoint(
+ virtual Geometry::Ptr transformMultiPoint(
const MultiPoint* geom,
- virtual Geometry::AutoPtr transformLinearRing(
+ virtual Geometry::Ptr transformLinearRing(
const LinearRing* geom,
- virtual Geometry::AutoPtr transformLineString(
+ virtual Geometry::Ptr transformLineString(
const LineString* geom,
- virtual Geometry::AutoPtr transformMultiLineString(
+ virtual Geometry::Ptr transformMultiLineString(
const MultiLineString* geom,
- virtual Geometry::AutoPtr transformPolygon(
+ virtual Geometry::Ptr transformPolygon(
const Polygon* geom,
- virtual Geometry::AutoPtr transformMultiPolygon(
+ virtual Geometry::Ptr transformMultiPolygon(
const MultiPolygon* geom,
- virtual Geometry::AutoPtr transformGeometryCollection(
+ virtual Geometry::Ptr transformGeometryCollection(
const GeometryCollection* geom,
diff --git a/include/geos/geom/util/SineStarFactory.h b/include/geos/geom/util/SineStarFactory.h
index 582a0d5..03c1b8c 100644
--- a/include/geos/geom/util/SineStarFactory.h
+++ b/include/geos/geom/util/SineStarFactory.h
@@ -106,7 +106,7 @@ public:
* @return the geometry representing the sine star
- std::auto_ptr<Polygon> createSineStar() const;
+ std::unique_ptr<Polygon> createSineStar() const;
diff --git a/include/geos/geomgraph/GeometryGraph.h b/include/geos/geomgraph/GeometryGraph.h
index 7e76dca..72224a6 100644
--- a/include/geos/geomgraph/GeometryGraph.h
+++ b/include/geos/geomgraph/GeometryGraph.h
@@ -28,7 +28,7 @@
#include <memory>
-#include <geos/geom/CoordinateSequence.h> // for auto_ptr<CoordinateSequence>
+#include <geos/geom/CoordinateSequence.h> // for unique_ptr<CoordinateSequence>
#include <geos/geomgraph/PlanarGraph.h>
#include <geos/geom/LineString.h> // for LineStringLT
@@ -105,9 +105,9 @@ private:
int argIndex;
/// Cache for fast responses to getBoundaryPoints
- std::auto_ptr< geom::CoordinateSequence > boundaryPoints;
+ std::unique_ptr< geom::CoordinateSequence > boundaryPoints;
- std::auto_ptr< std::vector<Node*> > boundaryNodes;
+ std::unique_ptr< std::vector<Node*> > boundaryNodes;
bool hasTooFewPointsVar;
diff --git a/include/geos/index/chain/MonotoneChain.h b/include/geos/index/chain/MonotoneChain.h
index a0b8801..97457c3 100644
--- a/include/geos/index/chain/MonotoneChain.h
+++ b/include/geos/index/chain/MonotoneChain.h
@@ -22,7 +22,7 @@
#include <geos/geom/Envelope.h> // for inline
namespace geos {
@@ -119,7 +119,7 @@ public:
* Allocates a new CoordinateSequence to hold the Coordinates
- std::auto_ptr<geom::CoordinateSequence> getCoordinates() const;
+ std::unique_ptr<geom::CoordinateSequence> getCoordinates() const;
* Determine all the line segments in the chain whose envelopes overlap
diff --git a/include/geos/index/quadtree/Node.h b/include/geos/index/quadtree/Node.h
index f37aacf..76f4fd4 100644
--- a/include/geos/index/quadtree/Node.h
+++ b/include/geos/index/quadtree/Node.h
@@ -57,7 +57,7 @@ class GEOS_DLL Node: public NodeBase {
private:
/// Owned by this class
- std::auto_ptr<geom::Envelope> env;
+ std::unique_ptr<geom::Envelope> env;
geom::Coordinate centre;
@@ -71,7 +71,7 @@ private:
Node* getSubnode(int index);
- std::auto_ptr<Node> createSubnode(int index);
+ std::unique_ptr<Node> createSubnode(int index);
protected:
@@ -82,19 +82,19 @@ protected:
public:
// Create a node computing level from given envelope
- static std::auto_ptr<Node> createNode(const geom::Envelope& env);
+ static std::unique_ptr<Node> createNode(const geom::Envelope& env);
/// Create a node containing the given node and envelope
/// @param node if not null, will be inserted to the returned node
/// @param addEnv minimum envelope to use for the node
- static std::auto_ptr<Node> createExpanded(std::auto_ptr<Node> node,
+ static std::unique_ptr<Node> createExpanded(std::unique_ptr<Node> node,
const geom::Envelope& addEnv);
- Node(std::auto_ptr<geom::Envelope> nenv, int nlevel)
+ Node(std::unique_ptr<geom::Envelope> nenv, int nlevel)
- env(nenv),
+ env(std::move(nenv)),
centre((env->getMinX()+env->getMaxX())/2,
(env->getMinY()+env->getMaxY())/2),
level(nlevel)
@@ -120,7 +120,7 @@ public:
NodeBase* find(const geom::Envelope *searchEnv);
- void insertNode(std::auto_ptr<Node> node);
+ void insertNode(std::unique_ptr<Node> node);
std::string toString() const;
diff --git a/include/geos/index/strtree/AbstractSTRtree.h b/include/geos/index/strtree/AbstractSTRtree.h
index d2a9ad2..bb4ddb1 100644
--- a/include/geos/index/strtree/AbstractSTRtree.h
+++ b/include/geos/index/strtree/AbstractSTRtree.h
@@ -21,7 +21,7 @@
#include <vector>
#include <list>
#include <cassert> // for inlines
#include <algorithm>
@@ -149,7 +149,7 @@ private:
BoundableList* boundablesOfALevel,
int level);
- virtual std::auto_ptr<BoundableList> sortBoundables(const BoundableList* input)=0;
+ virtual std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input)=0;
bool remove(const void* searchBounds, AbstractNode& node, void* item);
bool removeItem(AbstractNode& node, void* item);
@@ -183,14 +183,14 @@ protected:
std::vector <AbstractNode *> *nodes;
- // Ownership to caller (TODO: return by auto_ptr)
+ // Ownership to caller (TODO: return by unique_ptr)
virtual AbstractNode* createNode(int level)=0;
* Sorts the childBoundables then divides them into groups of size M, where
* M is the node capacity.
- virtual std::auto_ptr<BoundableList> createParentBoundables(
+ virtual std::unique_ptr<BoundableList> createParentBoundables(
BoundableList* childBoundables, int newLevel);
virtual AbstractNode* lastNode(BoundableList* nodeList)
@@ -227,7 +227,7 @@ protected:
/// Also builds the tree, if necessary.
bool remove(const void* itemEnv, void* item);
- std::auto_ptr<BoundableList> boundablesAtLevel(int level);
+ std::unique_ptr<BoundableList> boundablesAtLevel(int level);
// @@ should be size_t, probably
std::size_t nodeCapacity;
diff --git a/include/geos/index/strtree/SIRtree.h b/include/geos/index/strtree/SIRtree.h
index 3df520a..dc09da8 100644
--- a/include/geos/index/strtree/SIRtree.h
+++ b/include/geos/index/strtree/SIRtree.h
@@ -88,14 +88,14 @@ protected:
- std::auto_ptr<BoundableList> createParentBoundables(
+ std::unique_ptr<BoundableList> createParentBoundables(
AbstractNode* createNode(int level);
IntersectsOp* getIntersectsOp() {return intersectsOp;}
- std::auto_ptr<BoundableList> sortBoundables(const BoundableList* input);
+ std::unique_ptr<BoundableList> sortBoundables(const BoundableList* input);
private:
diff --git a/include/geos/index/strtree/STRtree.h b/include/geos/index/strtree/STRtree.h
index 4f87799..6f49bc8 100644
--- a/include/geos/index/strtree/STRtree.h
+++ b/include/geos/index/strtree/STRtree.h
@@ -79,15 +79,15 @@ private:
* group them into runs of size M (the node capacity). For each run, creates
* a new (parent) node.
- std::auto_ptr<BoundableList> createParentBoundables(BoundableList* childBoundables, int newLevel);
+ std::unique_ptr<BoundableList> createParentBoundables(BoundableList* childBoundables, int newLevel);
- std::auto_ptr<BoundableList> createParentBoundablesFromVerticalSlices(std::vector<BoundableList*>* verticalSlices, int newLevel);
+ std::unique_ptr<BoundableList> createParentBoundablesFromVerticalSlices(std::vector<BoundableList*>* verticalSlices, int newLevel);
STRIntersectsOp intersectsOp;
- std::auto_ptr<BoundableList> createParentBoundablesFromVerticalSlice(
+ std::unique_ptr<BoundableList> createParentBoundablesFromVerticalSlice(
int newLevel);
diff --git a/include/geos/linearref/LinearLocation.h b/include/geos/linearref/LinearLocation.h
index 66f1b67..fb0a74a 100644
--- a/include/geos/linearref/LinearLocation.h
+++ b/include/geos/linearref/LinearLocation.h
@@ -22,7 +22,7 @@
#define GEOS_LINEARREF_LINEARLOCATION_H
#include <string>
@@ -168,7 +168,7 @@ public:
* @param linearGeom a linear geometry
* @return the <tt>LineSegment</tt> containing the location
- std::auto_ptr<geom::LineSegment> getSegment(const geom::Geometry* linearGeom) const;
+ std::unique_ptr<geom::LineSegment> getSegment(const geom::Geometry* linearGeom) const;
* Tests whether this location refers to a valid
diff --git a/include/geos/noding/FastNodingValidator.h b/include/geos/noding/FastNodingValidator.h
index 18edb80..15e2288 100644
--- a/include/geos/noding/FastNodingValidator.h
+++ b/include/geos/noding/FastNodingValidator.h
@@ -98,7 +98,7 @@ private:
std::vector<noding::SegmentString*>& segStrings;
- std::auto_ptr<SingleInteriorIntersectionFinder> segInt;
+ std::unique_ptr<SingleInteriorIntersectionFinder> segInt;
bool isValidVar;
diff --git a/include/geos/noding/GeometryNoder.h b/include/geos/noding/GeometryNoder.h
index 3bbc3e6..af8a790 100644
--- a/include/geos/noding/GeometryNoder.h
+++ b/include/geos/noding/GeometryNoder.h
@@ -22,7 +22,7 @@
#include <geos/noding/SegmentString.h> // for NonConstVect
namespace geos {
@@ -41,11 +41,11 @@ class GEOS_DLL GeometryNoder
public:
- static std::auto_ptr<geom::Geometry> node(const geom::Geometry& geom);
+ static std::unique_ptr<geom::Geometry> node(const geom::Geometry& geom);
GeometryNoder(const geom::Geometry& g);
- std::auto_ptr<geom::Geometry> getNoded();
+ std::unique_ptr<geom::Geometry> getNoded();
private:
@@ -58,9 +58,9 @@ private:
Noder& getNoder();
- std::auto_ptr<Noder> noder;
+ std::unique_ptr<Noder> noder;
- std::auto_ptr<geom::Geometry> toGeometry(SegmentString::NonConstVect& noded);
+ std::unique_ptr<geom::Geometry> toGeometry(SegmentString::NonConstVect& noded);
GeometryNoder(GeometryNoder const&); /*= delete*/
GeometryNoder& operator=(GeometryNoder const&); /*= delete*/
diff --git a/include/geos/noding/snapround/HotPixel.h b/include/geos/noding/snapround/HotPixel.h
index 73e0938..3f613c9 100644
--- a/include/geos/noding/snapround/HotPixel.h
+++ b/include/geos/noding/snapround/HotPixel.h
@@ -24,7 +24,7 @@
-#include <geos/geom/Envelope.h> // for auto_ptr
+#include <geos/geom/Envelope.h> // for unique_ptr
#ifdef _MSC_VER
@@ -89,7 +89,7 @@ private:
std::vector<geom::Coordinate> corner;
/// Owned by this class, constructed on demand
- mutable std::auto_ptr<geom::Envelope> safeEnv;
+ mutable std::unique_ptr<geom::Envelope> safeEnv;
void initCorners(const geom::Coordinate& pt);
diff --git a/include/geos/noding/snapround/MCIndexSnapRounder.h b/include/geos/noding/snapround/MCIndexSnapRounder.h
index 5bb38b6..8fa377f 100644
--- a/include/geos/noding/snapround/MCIndexSnapRounder.h
+++ b/include/geos/noding/snapround/MCIndexSnapRounder.h
@@ -79,7 +79,7 @@ public:
pm(nPm),
scaleFactor(nPm.getScale()),
- pointSnapper(0)
+ pointSnapper(nullptr)
li.setPrecisionModel(&pm);
@@ -111,7 +111,7 @@ private:
std::vector<SegmentString*>* nodedSegStrings;
- std::auto_ptr<MCIndexPointSnapper> pointSnapper;
+ std::unique_ptr<MCIndexPointSnapper> pointSnapper;
void snapRound(MCIndexNoder& noder, std::vector<SegmentString*>* segStrings);
diff --git a/include/geos/operation/IsSimpleOp.h b/include/geos/operation/IsSimpleOp.h
index a48f365..8375e25 100644
--- a/include/geos/operation/IsSimpleOp.h
+++ b/include/geos/operation/IsSimpleOp.h
@@ -22,10 +22,10 @@
#define GEOS_OPERATION_ISSIMPLEOP_H
-#include <geos/geom/Coordinate.h> // for dtor visibility by auto_ptr (compos)
+#include <geos/geom/Coordinate.h> // for dtor visibility by unique_ptr (compos)
#include <map>
#ifdef _MSC_VER
@@ -206,7 +206,7 @@ private:
const geom::Geometry* geom;
- std::auto_ptr<geom::Coordinate> nonSimpleLocation;
+ std::unique_ptr<geom::Coordinate> nonSimpleLocation;
} // namespace geos.operation
diff --git a/include/geos/operation/buffer/BufferInputLineSimplifier.h b/include/geos/operation/buffer/BufferInputLineSimplifier.h
index 81d9a1c..297e46b 100644
--- a/include/geos/operation/buffer/BufferInputLineSimplifier.h
+++ b/include/geos/operation/buffer/BufferInputLineSimplifier.h
@@ -87,7 +87,7 @@ public:
* @param distanceTol simplification distance tolerance to use
* @return a simplified version of the coordinate sequence
- static std::auto_ptr<geom::CoordinateSequence> simplify(
+ static std::unique_ptr<geom::CoordinateSequence> simplify(
const geom::CoordinateSequence& inputLine, double distanceTol);
BufferInputLineSimplifier(const geom::CoordinateSequence& input);
@@ -102,7 +102,7 @@ public:
* @return the simplified coordinate list
- std::auto_ptr<geom::CoordinateSequence> simplify(double distanceTol);
+ std::unique_ptr<geom::CoordinateSequence> simplify(double distanceTol);
private:
@@ -124,7 +124,7 @@ private:
unsigned int findNextNonDeletedIndex(unsigned int index) const;
- std::auto_ptr<geom::CoordinateSequence> collapseLine() const;
+ std::unique_ptr<geom::CoordinateSequence> collapseLine() const;
bool isDeletable(int i0, int i1, int i2, double distanceTol) const;
diff --git a/include/geos/operation/buffer/OffsetCurveBuilder.h b/include/geos/operation/buffer/OffsetCurveBuilder.h
index 1c6e638..c8dbe71 100644
--- a/include/geos/operation/buffer/OffsetCurveBuilder.h
+++ b/include/geos/operation/buffer/OffsetCurveBuilder.h
@@ -26,7 +26,7 @@
#include <geos/operation/buffer/OffsetSegmentGenerator.h>
#include <vector>
#ifdef _MSC_VER
@@ -168,7 +168,7 @@ private:
void computeRingBufferCurve(const geom::CoordinateSequence& inputPts,
int side, OffsetSegmentGenerator& segGen);
- std::auto_ptr<OffsetSegmentGenerator> getSegGen(double dist);
+ std::unique_ptr<OffsetSegmentGenerator> getSegGen(double dist);
void computePointCurve(const geom::Coordinate& pt,
diff --git a/include/geos/operation/distance/DistanceOp.h b/include/geos/operation/distance/DistanceOp.h
index 62b5736..de6110d 100644
--- a/include/geos/operation/distance/DistanceOp.h
+++ b/include/geos/operation/distance/DistanceOp.h
@@ -215,7 +215,7 @@ private:
// working
algorithm::PointLocator ptLocator;
- // TODO: use auto_ptr
+ // TODO: use unique_ptr
std::vector<GeometryLocation*> *minDistanceLocation;
double minDistance;
diff --git a/include/geos/operation/distance/IndexedFacetDistance.h b/include/geos/operation/distance/IndexedFacetDistance.h
index a819662..5068b33 100644
--- a/include/geos/operation/distance/IndexedFacetDistance.h
+++ b/include/geos/operation/distance/IndexedFacetDistance.h
@@ -37,7 +37,7 @@ namespace geos {
~IndexedFacetDistance();
private:
- std::auto_ptr<geos::index::strtree::STRtree> cachedTree;
+ std::unique_ptr<geos::index::strtree::STRtree> cachedTree;
diff --git a/include/geos/operation/intersection/RectangleIntersection.h b/include/geos/operation/intersection/RectangleIntersection.h
index a3470f4..673ab27 100644
--- a/include/geos/operation/intersection/RectangleIntersection.h
+++ b/include/geos/operation/intersection/RectangleIntersection.h
@@ -83,7 +83,7 @@ class GEOS_DLL RectangleIntersection
* @return the clipped geometry
* @return NULL if the geometry is outside the {@link Rectangle}
- static std::auto_ptr<geom::Geometry> clip(const geom::Geometry & geom,
+ static std::unique_ptr<geom::Geometry> clip(const geom::Geometry & geom,
const Rectangle & rect);
@@ -98,16 +98,16 @@ class GEOS_DLL RectangleIntersection
- static std::auto_ptr<geom::Geometry> clipBoundary(const geom::Geometry & geom,
+ static std::unique_ptr<geom::Geometry> clipBoundary(const geom::Geometry & geom,
private:
RectangleIntersection(const geom::Geometry& geom, const Rectangle& rect);
- std::auto_ptr<geom::Geometry> clipBoundary();
+ std::unique_ptr<geom::Geometry> clipBoundary();
- std::auto_ptr<geom::Geometry> clip();
+ std::unique_ptr<geom::Geometry> clip();
const geom::Geometry &_geom;
const Rectangle &_rect;
diff --git a/include/geos/operation/intersection/RectangleIntersectionBuilder.h b/include/geos/operation/intersection/RectangleIntersectionBuilder.h
index 865b626..154444b 100644
--- a/include/geos/operation/intersection/RectangleIntersectionBuilder.h
+++ b/include/geos/operation/intersection/RectangleIntersectionBuilder.h
@@ -74,7 +74,7 @@ private:
* \brief Build the result geometry from partial results and clean up
- std::auto_ptr<geom::Geometry> build();
+ std::unique_ptr<geom::Geometry> build();
* \brief Build polygons from parts left by clipping one
diff --git a/include/geos/operation/linemerge/LineSequencer.h b/include/geos/operation/linemerge/LineSequencer.h
index f7d4c01..8dfd9a1 100644
--- a/include/geos/operation/linemerge/LineSequencer.h
+++ b/include/geos/operation/linemerge/LineSequencer.h
@@ -28,7 +28,7 @@
#include <vector>
#include <list>
#ifdef _MSC_VER
@@ -106,7 +106,7 @@ private:
const geom::GeometryFactory *factory;
unsigned int lineCount;
bool isRun;
- std::auto_ptr<geom::Geometry> sequencedGeometry;
+ std::unique_ptr<geom::Geometry> sequencedGeometry;
bool isSequenceableVar;
void addLine(const geom::LineString *lineString);
@@ -205,7 +205,7 @@ public:
factory(0),
lineCount(0),
isRun(false),
- sequencedGeometry(0),
+ sequencedGeometry(nullptr),
isSequenceableVar(false)
diff --git a/include/geos/operation/overlay/snap/GeometrySnapper.h b/include/geos/operation/overlay/snap/GeometrySnapper.h
index 61487b7..4fbe2ae 100644
--- a/include/geos/operation/overlay/snap/GeometrySnapper.h
+++ b/include/geos/operation/overlay/snap/GeometrySnapper.h
@@ -59,7 +59,7 @@ class GEOS_DLL GeometrySnapper {
public:
- typedef std::auto_ptr<geom::Geometry> GeomPtr;
+ typedef std::unique_ptr<geom::Geometry> GeomPtr;
* Snaps two geometries together with a given tolerance.
@@ -67,7 +67,7 @@ public:
* @param g0 a geometry to snap
* @param g1 a geometry to snap
* @param snapTolerance the tolerance to use
- * @param ret the snapped geometries as a pair of auto_ptrs
+ * @param ret the snapped geometries as a pair of smart pointers
* (output parameter)
static void snap(const geom::Geometry& g0,
* @return a new snapped Geometry
- std::auto_ptr<geom::Geometry> snapTo(const geom::Geometry& g,
+ std::unique_ptr<geom::Geometry> snapTo(const geom::Geometry& g,
double snapTolerance);
/** \brief
@@ -109,7 +109,7 @@ public:
* @param cleanResult clean the result
- std::auto_ptr<geom::Geometry> snapToSelf(double snapTolerance,
+ std::unique_ptr<geom::Geometry> snapToSelf(double snapTolerance,
bool cleanResult);
/** \brief
@@ -140,7 +140,7 @@ private:
const geom::Geometry& srcGeom;
/// Extract target (unique) coordinates
- std::auto_ptr<geom::Coordinate::ConstVect> extractTargetCoordinates(
+ std::unique_ptr<geom::Coordinate::ConstVect> extractTargetCoordinates(
// Declare type as noncopyable
diff --git a/include/geos/operation/overlay/snap/LineStringSnapper.h b/include/geos/operation/overlay/snap/LineStringSnapper.h
index 7658be0..d530b23 100644
--- a/include/geos/operation/overlay/snap/LineStringSnapper.h
+++ b/include/geos/operation/overlay/snap/LineStringSnapper.h
@@ -71,7 +71,7 @@ public:
// Snap points are assumed to be all distinct points (a set would be better, uh ?)
- std::auto_ptr<geom::Coordinate::Vect> snapTo(const geom::Coordinate::ConstVect& snapPts);
+ std::unique_ptr<geom::Coordinate::Vect> snapTo(const geom::Coordinate::ConstVect& snapPts);
void setAllowSnappingToSourceVertices(bool allow) {
allowSnappingToSourceVertices = allow;
diff --git a/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h b/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
index c7f19b0..823ac30 100644
--- a/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
+++ b/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
@@ -21,7 +21,7 @@
#include <geos/operation/overlay/OverlayOp.h> // for enums
namespace geos {
@@ -51,7 +51,7 @@ class SnapIfNeededOverlayOp
public:
overlayOp(const geom::Geometry& g0, const geom::Geometry& g1,
OverlayOp::OpCode opCode)
@@ -59,25 +59,25 @@ public:
return op.getResultGeometry(opCode);
intersection(const geom::Geometry& g0, const geom::Geometry& g1)
return overlayOp(g0, g1, OverlayOp::opINTERSECTION);
Union(const geom::Geometry& g0, const geom::Geometry& g1)
return overlayOp(g0, g1, OverlayOp::opUNION);
difference(const geom::Geometry& g0, const geom::Geometry& g1)
return overlayOp(g0, g1, OverlayOp::opDIFFERENCE);
symDifference(const geom::Geometry& g0, const geom::Geometry& g1)
return overlayOp(g0, g1, OverlayOp::opSYMDIFFERENCE);
@@ -91,7 +91,7 @@ public:
GeomPtr getResultGeometry(OverlayOp::OpCode opCode);
diff --git a/include/geos/operation/overlay/snap/SnapOverlayOp.h b/include/geos/operation/overlay/snap/SnapOverlayOp.h
index 93e5319..7be8811 100644
--- a/include/geos/operation/overlay/snap/SnapOverlayOp.h
+++ b/include/geos/operation/overlay/snap/SnapOverlayOp.h
@@ -20,9 +20,9 @@
#define GEOS_OP_OVERLAY_SNAP_SNAPOVERLAYOP_H
-#include <geos/precision/CommonBitsRemover.h> // for dtor visibility by auto_ptr
+#include <geos/precision/CommonBitsRemover.h> // for dtor visibility by unique_ptr
#ifdef _MSC_VER
@@ -58,7 +58,7 @@ class GEOS_DLL SnapOverlayOp
public:
@@ -66,25 +66,25 @@ public:
@@ -99,7 +99,7 @@ public:
@@ -122,7 +122,7 @@ private:
double snapTolerance;
- std::auto_ptr<precision::CommonBitsRemover> cbr;
+ std::unique_ptr<precision::CommonBitsRemover> cbr;
SnapOverlayOp(const SnapOverlayOp& other);
diff --git a/include/geos/operation/overlay/validate/FuzzyPointLocator.h b/include/geos/operation/overlay/validate/FuzzyPointLocator.h
index f9e68e8..7856372 100644
--- a/include/geos/operation/overlay/validate/FuzzyPointLocator.h
+++ b/include/geos/operation/overlay/validate/FuzzyPointLocator.h
@@ -21,11 +21,11 @@
#include <geos/algorithm/PointLocator.h> // for composition
-#include <geos/geom/Geometry.h> // for auto_ptr visibility of dtor
+#include <geos/geom/Geometry.h> // for unique_ptr visibility of dtor
#include <geos/geom/Location.h> // for Location::Value enum
#include <vector>
#ifdef _MSC_VER
@@ -71,16 +71,16 @@ private:
- std::auto_ptr<geom::Geometry> linework;
+ std::unique_ptr<geom::Geometry> linework;
// this function has been obsoleted
- std::auto_ptr<geom::Geometry> getLineWork(const geom::Geometry& geom);
+ std::unique_ptr<geom::Geometry> getLineWork(const geom::Geometry& geom);
/// Extracts linework for polygonal components.
/// @param g the geometry from which to extract
/// @return a lineal geometry containing the extracted linework
- std::auto_ptr<geom::Geometry> extractLineWork(const geom::Geometry& geom);
+ std::unique_ptr<geom::Geometry> extractLineWork(const geom::Geometry& geom);
FuzzyPointLocator(const FuzzyPointLocator& other);
diff --git a/include/geos/operation/overlay/validate/OffsetPointGenerator.h b/include/geos/operation/overlay/validate/OffsetPointGenerator.h
index 16ba6a4..3b1bbf9 100644
--- a/include/geos/operation/overlay/validate/OffsetPointGenerator.h
+++ b/include/geos/operation/overlay/validate/OffsetPointGenerator.h
@@ -21,12 +21,12 @@
-#include <geos/geom/MultiPoint.h> // for auto_ptr visibility of dtor
+#include <geos/geom/MultiPoint.h> // for unique_ptr visibility of dtor
#include <geos/geom/Coordinate.h> // for use in vector
#include <vector>
#ifdef _MSC_VER
@@ -57,7 +57,7 @@ public:
OffsetPointGenerator(const geom::Geometry& geom, double offset);
/// Gets the computed offset points.
- std::auto_ptr< std::vector<geom::Coordinate> > getPoints();
+ std::unique_ptr< std::vector<geom::Coordinate> > getPoints();
private:
@@ -65,7 +65,7 @@ private:
double offsetDistance;
- std::auto_ptr< std::vector<geom::Coordinate> > offsetPts;
+ std::unique_ptr< std::vector<geom::Coordinate> > offsetPts;
void extractPoints(const geom::LineString* line);
diff --git a/include/geos/operation/relate/RelateComputer.h b/include/geos/operation/relate/RelateComputer.h
index 23268e0..02a7515 100644
--- a/include/geos/operation/relate/RelateComputer.h
+++ b/include/geos/operation/relate/RelateComputer.h
@@ -90,7 +90,7 @@ private:
geomgraph::NodeMap nodes;
/// this intersection matrix will hold the results compute for the relate
- std::auto_ptr<geom::IntersectionMatrix> im;
+ std::unique_ptr<geom::IntersectionMatrix> im;
std::vector<geomgraph::Edge*> isolatedEdges;
diff --git a/include/geos/operation/union/CascadedPolygonUnion.h b/include/geos/operation/union/CascadedPolygonUnion.h
index 925d5c7..2cecfbc 100644
--- a/include/geos/operation/union/CascadedPolygonUnion.h
+++ b/include/geos/operation/union/CascadedPolygonUnion.h
@@ -97,7 +97,7 @@ private:
* @param g the geometry to filter
* @return a Polygonal geometry
- static std::auto_ptr<geom::Geometry> restrictToPolygons(std::auto_ptr<geom::Geometry> g);
+ static std::unique_ptr<geom::Geometry> restrictToPolygons(std::unique_ptr<geom::Geometry> g);
public:
CascadedPolygonUnion();
diff --git a/include/geos/operation/union/PointGeometryUnion.h b/include/geos/operation/union/PointGeometryUnion.h
index 67b3b75..31bbec3 100644
--- a/include/geos/operation/union/PointGeometryUnion.h
+++ b/include/geos/operation/union/PointGeometryUnion.h
@@ -48,7 +48,7 @@ class GEOS_DLL PointGeometryUnion
public:
- static std::auto_ptr<geom::Geometry> Union(
+ static std::unique_ptr<geom::Geometry> Union(
const geom::Puntal& pointGeom,
const geom::Geometry& otherGeom);
@@ -56,7 +56,7 @@ public:
PointGeometryUnion(const geom::Puntal& pointGeom,
- std::auto_ptr<geom::Geometry> Union() const;
+ std::unique_ptr<geom::Geometry> Union() const;
private:
const geom::Geometry& pointGeom;
diff --git a/include/geos/operation/union/UnaryUnionOp.h b/include/geos/operation/union/UnaryUnionOp.h
index 14daec3..5fcc0cf 100644
--- a/include/geos/operation/union/UnaryUnionOp.h
+++ b/include/geos/operation/union/UnaryUnionOp.h
@@ -87,21 +87,21 @@ class GEOS_DLL UnaryUnionOp
public:
template <typename T>
- static std::auto_ptr<geom::Geometry> Union(const T& geoms)
+ static std::unique_ptr<geom::Geometry> Union(const T& geoms)
UnaryUnionOp op(geoms);
return op.Union();
template <class T>
- static std::auto_ptr<geom::Geometry> Union(const T& geoms,
+ static std::unique_ptr<geom::Geometry> Union(const T& geoms,
geom::GeometryFactory& geomFact)
UnaryUnionOp op(geoms, geomFact);
return op.Union();
- static std::auto_ptr<geom::Geometry> Union(const geom::Geometry& geom)
+ static std::unique_ptr<geom::Geometry> Union(const geom::Geometry& geom)
UnaryUnionOp op(geom);
return op.Union();
@@ -140,7 +140,7 @@ public:
* @return an empty GEOMETRYCOLLECTION if no geometries were provided
* in the input
- std::auto_ptr<geom::Geometry> Union();
+ std::unique_ptr<geom::Geometry> Union();
private:
@@ -181,7 +181,7 @@ private:
* @return the union of the input geometry
- std::auto_ptr<geom::Geometry> unionNoOpt(const geom::Geometry& g0)
+ std::unique_ptr<geom::Geometry> unionNoOpt(const geom::Geometry& g0)
//using geos::operation::overlay::snap::SnapIfNeededOverlayOp;
@@ -202,8 +202,8 @@ private:
* @return the union of the input(s)
* @return null if both inputs are null
- std::auto_ptr<geom::Geometry> unionWithNull(std::auto_ptr<geom::Geometry> g0,
- std::auto_ptr<geom::Geometry> g1);
+ std::unique_ptr<geom::Geometry> unionWithNull(std::unique_ptr<geom::Geometry> g0,
+ std::unique_ptr<geom::Geometry> g1);
std::vector<const geom::Polygon*> polygons;
std::vector<const geom::LineString*> lines;
@@ -211,7 +211,7 @@ private:
const geom::GeometryFactory* geomFact;
- std::auto_ptr<geom::Geometry> empty;
+ std::unique_ptr<geom::Geometry> empty;
diff --git a/include/geos/operation/valid/ConnectedInteriorTester.h b/include/geos/operation/valid/ConnectedInteriorTester.h
index 8ac51fe..16c0b5d 100644
--- a/include/geos/operation/valid/ConnectedInteriorTester.h
+++ b/include/geos/operation/valid/ConnectedInteriorTester.h
@@ -23,7 +23,7 @@
-#include <geos/geom/GeometryFactory.h> // for GeometryFactory::unique_ptr
+#include <geos/geom/GeometryFactory.h> // for GeometryFactory::Ptr
#include <vector>
@@ -84,7 +84,7 @@ protected:
private:
- geom::GeometryFactory::unique_ptr geometryFactory;
+ geom::GeometryFactory::Ptr geometryFactory;
geomgraph::GeometryGraph &geomGraph;
diff --git a/include/geos/precision/CommonBitsOp.h b/include/geos/precision/CommonBitsOp.h
index 4b05e4b..af16b8a 100644
--- a/include/geos/precision/CommonBitsOp.h
+++ b/include/geos/precision/CommonBitsOp.h
@@ -16,7 +16,7 @@
#define GEOS_PRECISION_COMMONBITSOP_H
-#include <geos/precision/CommonBitsRemover.h> // for auto_ptr composition
+#include <geos/precision/CommonBitsRemover.h> // for unique_ptr composition
#include <vector>
#include <memory>
@@ -53,7 +53,7 @@ private:
bool returnToOriginalPrecision;
- std::auto_ptr<CommonBitsRemover> cbr;
+ std::unique_ptr<CommonBitsRemover> cbr;
/** \brief
* Computes a copy of the input Geometry with the calculated
@@ -71,8 +71,8 @@ private:
void removeCommonBits(
const geom::Geometry* geom0,
const geom::Geometry* geom1,
- std::auto_ptr<geom::Geometry>& rgeom0,
- std::auto_ptr<geom::Geometry>& rgeom1);
+ std::unique_ptr<geom::Geometry>& rgeom0,
+ std::unique_ptr<geom::Geometry>& rgeom1);
public:
diff --git a/include/geos/precision/GeometryPrecisionReducer.h b/include/geos/precision/GeometryPrecisionReducer.h
index 336c165..40069b1 100644
--- a/include/geos/precision/GeometryPrecisionReducer.h
+++ b/include/geos/precision/GeometryPrecisionReducer.h
@@ -20,8 +20,8 @@
#define GEOS_PRECISION_GEOMETRYPRECISIONREDUCER_H
namespace geos {
@@ -53,12 +53,12 @@ private:
bool isPointwise;
- std::auto_ptr<geom::Geometry> reducePointwise( const geom::Geometry& geom );
+ std::unique_ptr<geom::Geometry> reducePointwise( const geom::Geometry& geom );
- std::auto_ptr<geom::Geometry> fixPolygonalTopology(
+ std::unique_ptr<geom::Geometry> fixPolygonalTopology(
- geom::GeometryFactory::unique_ptr createFactory(
+ geom::GeometryFactory::Ptr createFactory(
const geom::GeometryFactory& oldGF,
const geom::PrecisionModel& newPM );
@@ -78,7 +78,7 @@ public:
* @param precModel the precision model to use
* @return the reduced geometry
- static std::auto_ptr<geom::Geometry> reduce(
+ static std::unique_ptr<geom::Geometry> reduce(
const geom::Geometry &g,
const geom::PrecisionModel &precModel )
- static std::auto_ptr<geom::Geometry> reducePointwise(
+ static std::unique_ptr<geom::Geometry> reducePointwise(
@@ -153,7 +153,7 @@ public:
isPointwise = pointwise;
- std::auto_ptr<geom::Geometry> reduce(const geom::Geometry& geom);
+ std::unique_ptr<geom::Geometry> reduce(const geom::Geometry& geom);
diff --git a/include/geos/precision/MinimumClearance.h b/include/geos/precision/MinimumClearance.h
index 5724c18..d33ac9b 100644
--- a/include/geos/precision/MinimumClearance.h
+++ b/include/geos/precision/MinimumClearance.h
@@ -29,7 +29,7 @@ class GEOS_DLL MinimumClearance {
private:
const geom::Geometry* inputGeom;
double minClearance;
- std::auto_ptr<geom::CoordinateSequence> minClearancePts;
+ std::unique_ptr<geom::CoordinateSequence> minClearancePts;
void compute();
public:
@@ -50,7 +50,7 @@ class GEOS_DLL MinimumClearance {
* @return the value of the minimum clearance distance
* or <tt>LINESTRING EMPTY</tt> if no Minimum Clearance distance exists
- std::auto_ptr<geom::LineString> getLine();
+ std::unique_ptr<geom::LineString> getLine();
diff --git a/include/geos/simplify/DouglasPeuckerLineSimplifier.h b/include/geos/simplify/DouglasPeuckerLineSimplifier.h
index 6b223aa..e60f197 100644
--- a/include/geos/simplify/DouglasPeuckerLineSimplifier.h
+++ b/include/geos/simplify/DouglasPeuckerLineSimplifier.h
@@ -21,7 +21,7 @@
#include <vector>
#ifdef _MSC_VER
@@ -47,15 +47,15 @@ class GEOS_DLL DouglasPeuckerLineSimplifier {
public:
typedef std::vector<short int> BoolVect;
- typedef std::auto_ptr<BoolVect> BoolVectAutoPtr;
+ typedef std::unique_ptr<BoolVect> BoolVectAutoPtr;
typedef std::vector<geom::Coordinate> CoordsVect;
- typedef std::auto_ptr<CoordsVect> CoordsVectAutoPtr;
+ typedef std::unique_ptr<CoordsVect> CoordsVectAutoPtr;
/** \brief
* Returns a newly allocated Coordinate vector, wrapped
- * into an auto_ptr
+ * into an unique_ptr
static CoordsVectAutoPtr simplify(
const CoordsVect& nPts,
@@ -75,7 +75,7 @@ public:
/** \brief
CoordsVectAutoPtr simplify();
diff --git a/include/geos/simplify/DouglasPeuckerSimplifier.h b/include/geos/simplify/DouglasPeuckerSimplifier.h
index 0bd1a60..d6c80f5 100644
--- a/include/geos/simplify/DouglasPeuckerSimplifier.h
+++ b/include/geos/simplify/DouglasPeuckerSimplifier.h
@@ -20,7 +20,7 @@
#define GEOS_SIMPLIFY_DOUBGLASPEUCKERSIMPLIFIER_H
namespace geos {
@@ -51,7 +51,7 @@ class GEOS_DLL DouglasPeuckerSimplifier {
public:
- static std::auto_ptr<geom::Geometry> simplify(
+ static std::unique_ptr<geom::Geometry> simplify(
const geom::Geometry* geom,
double tolerance);
@@ -69,7 +69,7 @@ public:
void setDistanceTolerance(double tolerance);
- std::auto_ptr<geom::Geometry> getResultGeometry();
+ std::unique_ptr<geom::Geometry> getResultGeometry();
private:
diff --git a/include/geos/simplify/LineSegmentIndex.h b/include/geos/simplify/LineSegmentIndex.h
index b1bc608..fa6ed0e 100644
--- a/include/geos/simplify/LineSegmentIndex.h
+++ b/include/geos/simplify/LineSegmentIndex.h
@@ -25,7 +25,7 @@
#include <vector>
#ifdef _MSC_VER
@@ -65,12 +65,12 @@ public:
void remove(const geom::LineSegment* seg);
- std::auto_ptr< std::vector<geom::LineSegment*> >
+ std::unique_ptr< std::vector<geom::LineSegment*> >
query(const geom::LineSegment* seg) const;
private:
- std::auto_ptr<index::quadtree::Quadtree> index;
+ std::unique_ptr<index::quadtree::Quadtree> index;
std::vector<geom::Envelope*> newEnvelopes;
diff --git a/include/geos/simplify/TaggedLineString.h b/include/geos/simplify/TaggedLineString.h
index 8afc83c..d21a904 100644
--- a/include/geos/simplify/TaggedLineString.h
+++ b/include/geos/simplify/TaggedLineString.h
@@ -63,11 +63,11 @@ public:
typedef std::vector<geom::Coordinate> CoordVect;
- typedef std::auto_ptr<CoordVect> CoordVectPtr;
+ typedef std::unique_ptr<CoordVect> CoordVectPtr;
typedef geom::CoordinateSequence CoordSeq;
- typedef std::auto_ptr<geom::CoordinateSequence> CoordSeqPtr;
+ typedef std::unique_ptr<geom::CoordinateSequence> CoordSeqPtr;
TaggedLineString(const geom::LineString* nParentLine,
std::size_t minimumSize=2);
@@ -92,11 +92,11 @@ public:
const std::vector<TaggedLineSegment*>& getSegments() const;
- void addToResult(std::auto_ptr<TaggedLineSegment> seg);
+ void addToResult(std::unique_ptr<TaggedLineSegment> seg);
- std::auto_ptr<geom::Geometry> asLineString() const;
+ std::unique_ptr<geom::Geometry> asLineString() const;
- std::auto_ptr<geom::Geometry> asLinearRing() const;
+ std::unique_ptr<geom::Geometry> asLinearRing() const;
private:
diff --git a/include/geos/simplify/TaggedLineStringSimplifier.h b/include/geos/simplify/TaggedLineStringSimplifier.h
index e5ff415..034c919 100644
--- a/include/geos/simplify/TaggedLineStringSimplifier.h
+++ b/include/geos/simplify/TaggedLineStringSimplifier.h
@@ -94,7 +94,7 @@ private:
// externally owned
LineSegmentIndex* outputIndex;
- std::auto_ptr<algorithm::LineIntersector> li;
+ std::unique_ptr<algorithm::LineIntersector> li;
/// non-const as segments are possibly added to it
TaggedLineString* line;
bool hasInteriorIntersection(const geom::LineSegment& seg0,
const geom::LineSegment& seg1) const;
- std::auto_ptr<TaggedLineSegment> flatten(
+ std::unique_ptr<TaggedLineSegment> flatten(
std::size_t start, std::size_t end);
/** \brief
diff --git a/include/geos/simplify/TaggedLinesSimplifier.h b/include/geos/simplify/TaggedLinesSimplifier.h
index 0afce17..11c2ce7 100644
--- a/include/geos/simplify/TaggedLinesSimplifier.h
+++ b/include/geos/simplify/TaggedLinesSimplifier.h
@@ -105,11 +105,11 @@ private:
void simplify(TaggedLineString& line);
- std::auto_ptr<LineSegmentIndex> inputIndex;
+ std::unique_ptr<LineSegmentIndex> inputIndex;
- std::auto_ptr<LineSegmentIndex> outputIndex;
+ std::unique_ptr<LineSegmentIndex> outputIndex;
- std::auto_ptr<TaggedLineStringSimplifier> taggedlineSimplifier;
+ std::unique_ptr<TaggedLineStringSimplifier> taggedlineSimplifier;
} // namespace geos::simplify
diff --git a/include/geos/simplify/TopologyPreservingSimplifier.h b/include/geos/simplify/TopologyPreservingSimplifier.h
index 7d4c54e..8c38140 100644
--- a/include/geos/simplify/TopologyPreservingSimplifier.h
+++ b/include/geos/simplify/TopologyPreservingSimplifier.h
@@ -26,7 +26,7 @@
#include <geos/simplify/TaggedLinesSimplifier.h>
#include <map>
#ifdef _MSC_VER
@@ -60,7 +60,7 @@ class GEOS_DLL TopologyPreservingSimplifier
public:
double tolerance);
@@ -78,13 +78,13 @@ public:
private:
- std::auto_ptr<TaggedLinesSimplifier> lineSimplifier;
+ std::unique_ptr<TaggedLinesSimplifier> lineSimplifier;
diff --git a/include/geos/triangulate/DelaunayTriangulationBuilder.h b/include/geos/triangulate/DelaunayTriangulationBuilder.h
index 16c069b..cbc6444 100644
--- a/include/geos/triangulate/DelaunayTriangulationBuilder.h
+++ b/include/geos/triangulate/DelaunayTriangulationBuilder.h
@@ -129,7 +129,7 @@ public:
* @param geomFact the geometry factory to use to create the output
* @return the edges of the triangulation. The caller takes ownership of the returned object.
- std::auto_ptr<geom::MultiLineString> getEdges(const geom::GeometryFactory &geomFact);
+ std::unique_ptr<geom::MultiLineString> getEdges(const geom::GeometryFactory &geomFact);
* Gets the faces of the computed triangulation as a {@link GeometryCollection}
@@ -138,7 +138,7 @@ public:
* @return the faces of the triangulation. The caller takes ownership of the returned object.
- std::auto_ptr<geom::GeometryCollection> getTriangles(const geom::GeometryFactory& geomFact);
+ std::unique_ptr<geom::GeometryCollection> getTriangles(const geom::GeometryFactory& geomFact);
* Computes the {@link Envelope} of a collection of {@link Coordinate}s.
diff --git a/include/geos/triangulate/VoronoiDiagramBuilder.h b/include/geos/triangulate/VoronoiDiagramBuilder.h
index aa847f0..dad3761 100644
--- a/include/geos/triangulate/VoronoiDiagramBuilder.h
+++ b/include/geos/triangulate/VoronoiDiagramBuilder.h
@@ -94,7 +94,7 @@ public:
* @return the subdivision containing the triangulation
- std::auto_ptr<quadedge::QuadEdgeSubdivision> getSubdivision();
+ std::unique_ptr<quadedge::QuadEdgeSubdivision> getSubdivision();
* Gets the faces of the computed diagram as a {@link GeometryCollection}
@@ -103,7 +103,7 @@ public:
* @return the faces of the diagram
- std::auto_ptr<geom::GeometryCollection> getDiagram(const geom::GeometryFactory& geomFact);
+ std::unique_ptr<geom::GeometryCollection> getDiagram(const geom::GeometryFactory& geomFact);
@@ -112,19 +112,19 @@ public:
- std::auto_ptr<geom::Geometry> getDiagramEdges(const geom::GeometryFactory& geomFact);
+ std::unique_ptr<geom::Geometry> getDiagramEdges(const geom::GeometryFactory& geomFact);
private:
- std::auto_ptr<geom::CoordinateSequence> siteCoords;
+ std::unique_ptr<geom::CoordinateSequence> siteCoords;
double tolerance;
- std::auto_ptr<quadedge::QuadEdgeSubdivision> subdiv;
+ std::unique_ptr<quadedge::QuadEdgeSubdivision> subdiv;
const geom::Envelope* clipEnv; // externally owned
geom::Envelope diagramEnv;
void create();
- static std::auto_ptr<geom::GeometryCollection>
+ static std::unique_ptr<geom::GeometryCollection>
clipGeometryCollection(const geom::GeometryCollection& geom, const geom::Envelope& clipEnv);
diff --git a/include/geos/triangulate/quadedge/QuadEdge.h b/include/geos/triangulate/quadedge/QuadEdge.h
index 367b32d..c005f81 100644
--- a/include/geos/triangulate/quadedge/QuadEdge.h
+++ b/include/geos/triangulate/quadedge/QuadEdge.h
@@ -60,7 +60,7 @@ public:
* @return the new QuadEdge* The caller is reponsible for
* freeing the returned pointer
- static std::auto_ptr<QuadEdge> makeEdge(const Vertex &o, const Vertex &d);
+ static std::unique_ptr<QuadEdge> makeEdge(const Vertex &o, const Vertex &d);
* Creates a new QuadEdge connecting the destination of a to the origin of
- static std::auto_ptr<QuadEdge> connect(QuadEdge &a, QuadEdge &b);
+ static std::unique_ptr<QuadEdge> connect(QuadEdge &a, QuadEdge &b);
* Splices two edges together or apart.
@@ -351,7 +351,7 @@ public:
* @return a LineSegment
- std::auto_ptr<geom::LineSegment> toLineSegment() const;
+ std::unique_ptr<geom::LineSegment> toLineSegment() const;
} //namespace geos.triangulate.quadedge
diff --git a/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h b/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
index 4a839ac..c738ac7 100644
--- a/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
+++ b/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
@@ -100,7 +100,7 @@ private:
double edgeCoincidenceTolerance;
Vertex frameVertex[3];
geom::Envelope frameEnv;
- std::auto_ptr<QuadEdgeLocator> locator;
+ std::unique_ptr<QuadEdgeLocator> locator;
public:
@@ -159,8 +159,8 @@ public:
* @param locator
* a QuadEdgeLocator
- inline void setLocator(std::auto_ptr<QuadEdgeLocator> locator) {
- this->locator = locator;
+ inline void setLocator(std::unique_ptr<QuadEdgeLocator> locator) {
+ this->locator = std::move(locator);
@@ -331,7 +331,7 @@ public:
* @return a List of QuadEdges. The caller takes ownership of the returned QuadEdgeList but not the
* items it contains.
- std::auto_ptr<QuadEdgeList> getPrimaryEdges(bool includeFrame);
+ std::unique_ptr<QuadEdgeList> getPrimaryEdges(bool includeFrame);
* Visitors
@@ -386,7 +386,7 @@ public:
* @param geomFact the GeometryFactory to use
* @return a MultiLineString. The caller takes ownership of the returned object.
- std::auto_ptr<geom::MultiLineString> getEdges(const geom::GeometryFactory& geomFact);
+ std::unique_ptr<geom::MultiLineString> getEdges(const geom::GeometryFactory& geomFact);
* Gets the geometry for the triangles in a triangulated subdivision as a {@link GeometryCollection}
@@ -395,7 +395,7 @@ public:
* @return a GeometryCollection of triangular Polygons. The caller takes ownership of the returned object.
- std::auto_ptr<geom::GeometryCollection> getTriangles(const geom::GeometryFactory &geomFact);
+ std::unique_ptr<geom::GeometryCollection> getTriangles(const geom::GeometryFactory &geomFact);
* Gets the cells in the Voronoi diagram for this triangulation.
@@ -407,7 +407,7 @@ public:
* @param geomFact a geometry factory
* @return a GeometryCollection of Polygons
- std::auto_ptr<geom::GeometryCollection> getVoronoiDiagram(const geom::GeometryFactory& geomFact);
+ std::unique_ptr<geom::GeometryCollection> getVoronoiDiagram(const geom::GeometryFactory& geomFact);
@@ -419,7 +419,7 @@ public:
- std::auto_ptr<geom::MultiLineString> getVoronoiDiagramEdges(const geom::GeometryFactory& geomFact);
+ std::unique_ptr<geom::MultiLineString> getVoronoiDiagramEdges(const geom::GeometryFactory& geomFact);
* Gets a List of {@link Polygon}s for the Voronoi cells
@@ -431,7 +431,7 @@ public:
* @return a List of Polygons
- std::auto_ptr< std::vector<geom::Geometry*> > getVoronoiCellPolygons(const geom::GeometryFactory& geomFact);
+ std::unique_ptr< std::vector<geom::Geometry*> > getVoronoiCellPolygons(const geom::GeometryFactory& geomFact);
* Gets a List of {@link LineString}s for the Voronoi cells
@@ -443,7 +443,7 @@ public:
* @return a List of LineString
- std::auto_ptr< std::vector<geom::Geometry*> > getVoronoiCellEdges(const geom::GeometryFactory& geomFact);
+ std::unique_ptr< std::vector<geom::Geometry*> > getVoronoiCellEdges(const geom::GeometryFactory& geomFact);
* Gets a collection of {@link QuadEdge}s whose origin
@@ -461,7 +461,7 @@ public:
* @param includeFrame true if the frame vertices should be included
* @return a collection of QuadEdge with the vertices of the subdivision as their origins
- std::auto_ptr<QuadEdgeSubdivision::QuadEdgeList> getVertexUniqueEdges(bool includeFrame);
+ std::unique_ptr<QuadEdgeSubdivision::QuadEdgeList> getVertexUniqueEdges(bool includeFrame);
* Gets the Voronoi cell around a site specified
@@ -474,7 +474,7 @@ public:
* @param geomFact a factory for building the polygon
* @return a polygon indicating the cell extent
- std::auto_ptr<geom::Geometry> getVoronoiCellPolygon(QuadEdge* qe ,const geom::GeometryFactory& geomFact);
+ std::unique_ptr<geom::Geometry> getVoronoiCellPolygon(QuadEdge* qe ,const geom::GeometryFactory& geomFact);
* Gets the Voronoi cell edge around a site specified
@@ -487,7 +487,7 @@ public:
- std::auto_ptr<geom::Geometry> getVoronoiCellEdge(QuadEdge* qe ,const geom::GeometryFactory& geomFact);
+ std::unique_ptr<geom::Geometry> getVoronoiCellEdge(QuadEdge* qe ,const geom::GeometryFactory& geomFact);
diff --git a/include/geos/triangulate/quadedge/Vertex.h b/include/geos/triangulate/quadedge/Vertex.h
index d0af7ce..8c5becd 100644
--- a/include/geos/triangulate/quadedge/Vertex.h
+++ b/include/geos/triangulate/quadedge/Vertex.h
@@ -143,18 +143,18 @@ public:
* @param v, a vertex
* @return returns the scaled vector
- inline std::auto_ptr<Vertex> times(double c) const {
- return std::auto_ptr<Vertex>(new Vertex(c * p.x, c * p.y));
+ inline std::unique_ptr<Vertex> times(double c) const {
+ return std::unique_ptr<Vertex>(new Vertex(c * p.x, c * p.y));
/* Vector addition */
- inline std::auto_ptr<Vertex> sum(Vertex v) const {
- return std::auto_ptr<Vertex>(new Vertex(p.x + v.getX(), p.y + v.getY()));
+ inline std::unique_ptr<Vertex> sum(Vertex v) const {
+ return std::unique_ptr<Vertex>(new Vertex(p.x + v.getX(), p.y + v.getY()));
/* and subtraction */
- inline std::auto_ptr<Vertex> sub(const Vertex &v) const {
- return std::auto_ptr<Vertex>(new Vertex(p.x - v.getX(), p.y - v.getY()));
+ inline std::unique_ptr<Vertex> sub(const Vertex &v) const {
+ return std::unique_ptr<Vertex>(new Vertex(p.x - v.getX(), p.y - v.getY()));
/* magnitude of vector */
@@ -163,8 +163,8 @@ public:
/* returns k X v (cross product). this is a vector perpendicular to v */
- inline std::auto_ptr<Vertex> cross() const {
- return std::auto_ptr<Vertex>(new Vertex(p.y, -p.x));
+ inline std::unique_ptr<Vertex> cross() const {
+ return std::unique_ptr<Vertex>(new Vertex(p.y, -p.x));
@@ -203,7 +203,7 @@ public:
bool leftOf(const QuadEdge &e) const;
private:
- static std::auto_ptr<algorithm::HCoordinate> bisector(const Vertex &a, const Vertex &b);
+ static std::unique_ptr<algorithm::HCoordinate> bisector(const Vertex &a, const Vertex &b);
inline double distance(const Vertex &v1, const Vertex &v2)
@@ -229,7 +229,7 @@ private:
* @param a the other end point.
* @return the point mid-way between this and that.
- virtual std::auto_ptr<Vertex> midPoint(const Vertex &a);
+ virtual std::unique_ptr<Vertex> midPoint(const Vertex &a);
* Computes the centre of the circumcircle of this vertex and two others.
@@ -238,7 +238,7 @@ private:
* @param c
* @return the Coordinate which is the circumcircle of the 3 points.
- virtual std::auto_ptr<Vertex> circleCenter(const Vertex &b, const Vertex &c) const;
+ virtual std::unique_ptr<Vertex> circleCenter(const Vertex &b, const Vertex &c) const;
* For this vertex enclosed in a triangle defined by three verticies v0, v1 and v2, interpolate
diff --git a/include/geos/util/GeometricShapeFactory.h b/include/geos/util/GeometricShapeFactory.h
index 8d34012..4bc2d3f 100644
--- a/include/geos/util/GeometricShapeFactory.h
+++ b/include/geos/util/GeometricShapeFactory.h
@@ -59,7 +59,7 @@ namespace util { // geos::util
* gsf.setSize(100);
* gsf.setNumPoints(100);
* gsf.setBase(Coordinate(0, 0));
- * std::auto_ptr<Polygon> rect ( gsf.createRectangle() );
+ * std::unique_ptr<Polygon> rect ( gsf.createRectangle() );
* </pre>
diff --git a/src/algorithm/InteriorPointArea.cpp b/src/algorithm/InteriorPointArea.cpp
index 787c2a2..3a1f6d1 100644
--- a/src/algorithm/InteriorPointArea.cpp
+++ b/src/algorithm/InteriorPointArea.cpp
@@ -30,7 +30,7 @@
#include <vector>
#include <typeinfo>
-#include <memory> // for auto_ptr
+#include <memory> // for unique_ptr
using namespace std;
using namespace geos::geom;
@@ -167,13 +167,13 @@ InteriorPointArea::addPolygon(const Geometry *geometry)
Coordinate intPt;
double width;
- auto_ptr<LineString> bisector ( horizontalBisector(geometry) );
+ unique_ptr<LineString> bisector ( horizontalBisector(geometry) );
if ( bisector->getLength() == 0.0 ) {
width = 0;
intPt = bisector->getCoordinateN(0);
else {
- auto_ptr<Geometry> intersections ( bisector->intersection(geometry) );
+ unique_ptr<Geometry> intersections ( bisector->intersection(geometry) );
const Geometry *widestIntersection = widestGeometry(intersections.get());
const Envelope *env = widestIntersection->getEnvelopeInternal();
width=env->getWidth();
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index 81abf7c..efe4388 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -108,7 +108,7 @@ Geometry::GeometryChangedFilter Geometry::geometryChangedFilter;
Geometry::Geometry(const GeometryFactory *newFactory)
- envelope(NULL),
+ envelope(nullptr),
_factory(newFactory),
_userData(NULL)
@@ -288,7 +288,7 @@ Geometry::disjoint(const Geometry *g) const
if (! getEnvelopeInternal()->intersects(g->getEnvelopeInternal()))
return true;
#endif
- auto_ptr<IntersectionMatrix> im ( relate(g) );
+ unique_ptr<IntersectionMatrix> im ( relate(g) );
bool res=im->isDisjoint();
return res;
@@ -301,7 +301,7 @@ Geometry::touches(const Geometry *g) const
return false;
#endif
bool res=im->isTouches(getDimension(), g->getDimension());
return res;
@@ -341,7 +341,7 @@ Geometry::intersects(const Geometry *g) const
return predicate::RectangleIntersects::intersects(*p, *this);
bool res=im->isIntersects();
return res;
@@ -363,7 +363,7 @@ Geometry::covers(const Geometry* g) const
return true;
- auto_ptr<IntersectionMatrix> im(relate(g));
+ unique_ptr<IntersectionMatrix> im(relate(g));
return im->isCovers();
@@ -376,7 +376,7 @@ Geometry::crosses(const Geometry *g) const
return false;
#endif
bool res=im->isCrosses(getDimension(), g->getDimension());
return res;
@@ -406,7 +406,7 @@ Geometry::contains(const Geometry *g) const
// return predicate::RectangleContains::contains((const Polygon&)*g, *this);
bool res=im->isContains();
return res;
@@ -419,7 +419,7 @@ Geometry::overlaps(const Geometry *g) const
return false;
#endif
bool res=im->isOverlaps(getDimension(), g->getDimension());
return res;
@@ -427,7 +427,7 @@ Geometry::overlaps(const Geometry *g) const
bool
Geometry::relate(const Geometry *g, const string &intersectionPattern) const
bool res=im->matches(intersectionPattern);
return res;
@@ -444,7 +444,7 @@ Geometry::equals(const Geometry *g) const
if (isEmpty()) return g->isEmpty();
else if (g->isEmpty()) return isEmpty();
bool res=im->isEquals(getDimension(), g->getDimension());
return res;
@@ -587,7 +587,7 @@ Geometry::Union(const Geometry *other) const
/* public */
-Geometry::AutoPtr
+Geometry::Ptr
Geometry::Union() const
using geos::operation::geounion::UnaryUnionOp;
diff --git a/src/geom/GeometryCollection.cpp b/src/geom/GeometryCollection.cpp
index 4ae343a..ecbfd4d 100644
--- a/src/geom/GeometryCollection.cpp
+++ b/src/geom/GeometryCollection.cpp
@@ -249,10 +249,10 @@ GeometryCollection::normalize()
sort(geometries->begin(), geometries->end(), GeometryGreaterThen());
-Envelope::AutoPtr
+Envelope::Ptr
GeometryCollection::computeEnvelopeInternal() const
- Envelope::AutoPtr envelope(new Envelope());
+ Envelope::Ptr envelope(new Envelope());
for (size_t i=0; i<geometries->size(); i++) {
const Envelope *env=(*geometries)[i]->getEnvelopeInternal();
envelope->expandToInclude(env);
@@ -270,7 +270,7 @@ GeometryCollection::compareToSameClass(const Geometry *g) const
const Coordinate*
GeometryCollection::getCoordinate() const
- // should use auto_ptr here or return NULL or throw an exception !
+ // should use unique_ptr here or return NULL or throw an exception !
// --strk;
if (isEmpty()) return new Coordinate();
return (*geometries)[0]->getCoordinate();
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index 94ed7d4..d8c306b 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -93,8 +93,8 @@ GeometryFactory::GeometryFactory()
/*public static*/
-GeometryFactory::unique_ptr
-GeometryFactory::create() { return GeometryFactory::unique_ptr(new GeometryFactory()); }
+GeometryFactory::Ptr
+GeometryFactory::create() { return GeometryFactory::Ptr(new GeometryFactory()); }
/*protected*/
GeometryFactory::GeometryFactory(const PrecisionModel* pm, int newSRID,
@@ -120,11 +120,11 @@ GeometryFactory::GeometryFactory(const PrecisionModel* pm, int newSRID,
/*public static*/
GeometryFactory::create(const PrecisionModel* pm, int newSRID,
CoordinateSequenceFactory* nCoordinateSequenceFactory)
- return GeometryFactory::unique_ptr(
+ return GeometryFactory::Ptr(
new GeometryFactory(pm, newSRID, nCoordinateSequenceFactory)
@@ -148,11 +148,11 @@ GeometryFactory::GeometryFactory(
/*public static*/
new GeometryFactory(nCoordinateSequenceFactory)
@@ -175,10 +175,10 @@ GeometryFactory::GeometryFactory(const PrecisionModel *pm)
/*public static*/
GeometryFactory::create(const PrecisionModel *pm)
new GeometryFactory(pm)
@@ -201,10 +201,10 @@ GeometryFactory::GeometryFactory(const PrecisionModel* pm, int newSRID)
/*public static*/
GeometryFactory::create(const PrecisionModel* pm, int newSRID)
new GeometryFactory(pm, newSRID)
@@ -221,10 +221,10 @@ GeometryFactory::GeometryFactory(const GeometryFactory &gf)
/*public static*/
GeometryFactory::create(const GeometryFactory &gf)
new GeometryFactory(gf)
@@ -470,10 +470,10 @@ GeometryFactory::createLinearRing(CoordinateSequence* newCoords) const
/*public*/
-Geometry::AutoPtr
-GeometryFactory::createLinearRing(CoordinateSequence::AutoPtr newCoords) const
+Geometry::Ptr
+GeometryFactory::createLinearRing(CoordinateSequence::Ptr newCoords) const
- return Geometry::AutoPtr(new LinearRing(newCoords, this));
+ return Geometry::Ptr(new LinearRing(std::move(newCoords), this));
/*public*/
@@ -615,10 +615,10 @@ GeometryFactory::createLineString() const
/*public*/
-std::auto_ptr<LineString>
+std::unique_ptr<LineString>
GeometryFactory::createLineString(const LineString& ls) const
- return std::auto_ptr<LineString>(new LineString(ls));
+ return std::unique_ptr<LineString>(new LineString(ls));
/*public*/
@@ -630,11 +630,11 @@ GeometryFactory::createLineString(CoordinateSequence *newCoords)
/*public*/
-Geometry::AutoPtr
-GeometryFactory::createLineString(CoordinateSequence::AutoPtr newCoords)
+Geometry::Ptr
+GeometryFactory::createLineString(CoordinateSequence::Ptr newCoords)
const
- return Geometry::AutoPtr(new LineString(newCoords, this));
+ return Geometry::Ptr(new LineString(std::move(newCoords), this));
/*public*/
diff --git a/src/geom/LineSegment.cpp b/src/geom/LineSegment.cpp
index 6aaa5bb..96f0fed 100644
--- a/src/geom/LineSegment.cpp
+++ b/src/geom/LineSegment.cpp
@@ -303,13 +303,13 @@ LineSegment::pointAlongOffset(double segmentLengthFraction,
/* public */
LineSegment::toGeometry(const GeometryFactory& gf) const
CoordinateSequence *cl=new CoordinateArraySequence();
cl->add(p0);
cl->add(p1);
gf.createLineString(cl) // ownership transferred
diff --git a/src/geom/LineString.cpp b/src/geom/LineString.cpp
index eb35180..c0cf23b 100644
--- a/src/geom/LineString.cpp
+++ b/src/geom/LineString.cpp
@@ -92,11 +92,11 @@ LineString::LineString(CoordinateSequence *newCoords,
/*public*/
-LineString::LineString(CoordinateSequence::AutoPtr newCoords,
+LineString::LineString(CoordinateSequence::Ptr newCoords,
const GeometryFactory *factory)
Geometry(factory),
- points(newCoords)
+ points(std::move(newCoords))
validateConstruction();
@@ -246,7 +246,7 @@ LineString::isCoordinate(Coordinate& pt) const
/*protected*/
-Envelope::AutoPtr
+Envelope::Ptr
LineString::computeEnvelopeInternal() const
if (isEmpty()) {
@@ -254,7 +254,7 @@ LineString::computeEnvelopeInternal() const
// as it would indicate "unknown"
// envelope. In this case we
// *know* the envelope is EMPTY.
- return Envelope::AutoPtr(new Envelope());
+ return Envelope::Ptr(new Envelope());
assert(points.get());
@@ -275,7 +275,7 @@ LineString::computeEnvelopeInternal() const
// caller expects a newly allocated Envelope.
// this function won't be called twice, unless
// cached Envelope is invalidated (set to NULL)
- return Envelope::AutoPtr(new Envelope(minx, maxx, miny, maxy));
+ return Envelope::Ptr(new Envelope(minx, maxx, miny, maxy));
bool
diff --git a/src/geom/LinearRing.cpp b/src/geom/LinearRing.cpp
index 7c2d915..3d4b496 100644
--- a/src/geom/LinearRing.cpp
+++ b/src/geom/LinearRing.cpp
@@ -47,11 +47,11 @@ LinearRing::LinearRing(CoordinateSequence* newCoords,
/*public*/
-LinearRing::LinearRing(CoordinateSequence::AutoPtr newCoords,
+LinearRing::LinearRing(CoordinateSequence::Ptr newCoords,
Geometry(newFactory),
- LineString(newCoords, newFactory)
+ LineString(std::move(newCoords), newFactory)
diff --git a/src/geom/Point.cpp b/src/geom/Point.cpp
index fb317f9..116a77d 100644
--- a/src/geom/Point.cpp
+++ b/src/geom/Point.cpp
@@ -144,14 +144,14 @@ Point::getBoundary() const
return getFactory()->createGeometryCollection(NULL);
-Envelope::AutoPtr
+Envelope::Ptr
Point::computeEnvelopeInternal() const
if (isEmpty()) {
- return Envelope::AutoPtr(new Envelope(getCoordinate()->x,
+ return Envelope::Ptr(new Envelope(getCoordinate()->x,
getCoordinate()->x, getCoordinate()->y,
getCoordinate()->y));
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 123f2cd..92cce89 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -242,10 +242,10 @@ Polygon::getBoundary() const
return ret;
-Envelope::AutoPtr
+Envelope::Ptr
Polygon::computeEnvelopeInternal() const
- return Envelope::AutoPtr(new Envelope(*(shell->getEnvelopeInternal())));
+ return Envelope::Ptr(new Envelope(*(shell->getEnvelopeInternal())));
bool
diff --git a/src/geom/util/GeometryTransformer.cpp b/src/geom/util/GeometryTransformer.cpp
index 821da72..fddd1f1 100644
--- a/src/geom/util/GeometryTransformer.cpp
+++ b/src/geom/util/GeometryTransformer.cpp
@@ -1,4 +1,4 @@
* GEOS - Geometry Engine Open Source
* http://geos.osgeo.org
@@ -73,7 +73,7 @@ void GeometryTransformer::setSkipTransformedInvalidInteriorRings(bool b)
/*public*/
-auto_ptr<Geometry>
+unique_ptr<Geometry>
GeometryTransformer::transform(const Geometry* nInputGeom)
using geos::util::IllegalArgumentException;
@@ -105,17 +105,17 @@ GeometryTransformer::transform(const Geometry* nInputGeom)
throw IllegalArgumentException("Unknown Geometry subtype.");
-std::auto_ptr<CoordinateSequence>
+std::unique_ptr<CoordinateSequence>
GeometryTransformer::createCoordinateSequence(
- return std::auto_ptr<CoordinateSequence>(
+ return std::unique_ptr<CoordinateSequence>(
factory->getCoordinateSequenceFactory()->create(
coords.release())
GeometryTransformer::transformCoordinates(
@@ -126,10 +126,10 @@ GeometryTransformer::transformCoordinates(
std::cerr << "GeometryTransformer::transformCoordinates(CoordinateSequence " << coords <<", Geometry " << parent << ");" << std::endl;
#endif
- return std::auto_ptr<CoordinateSequence>(coords->clone());
+ return std::unique_ptr<CoordinateSequence>(coords->clone());
-Geometry::AutoPtr
+Geometry::Ptr
GeometryTransformer::transformPoint(
const Point* geom,
@@ -140,13 +140,13 @@ GeometryTransformer::transformPoint(
std::cerr << "GeometryTransformer::transformPoint(Point " << geom <<", Geometry " << parent << ");" << std::endl;
#endif
- CoordinateSequence::AutoPtr cs(transformCoordinates(
+ CoordinateSequence::Ptr cs(transformCoordinates(
geom->getCoordinatesRO(), geom));
- return Geometry::AutoPtr(factory->createPoint(cs.release()));
+ return Geometry::Ptr(factory->createPoint(cs.release()));
-Geometry::AutoPtr
+Geometry::Ptr
GeometryTransformer::transformMultiPoint(
@@ -164,7 +164,7 @@ GeometryTransformer::transformMultiPoint(
const Point* p = dynamic_cast<const Point*>(geom->getGeometryN(i));
assert(p);
- Geometry::AutoPtr transformGeom = transformPoint(p, geom);
+ Geometry::Ptr transformGeom = transformPoint(p, geom);
if ( transformGeom.get() == NULL ) continue;
if ( transformGeom->isEmpty() ) continue;
@@ -172,11 +172,11 @@ GeometryTransformer::transformMultiPoint(
transGeomList->push_back(transformGeom.release());
- return Geometry::AutoPtr(factory->buildGeometry(transGeomList));
+ return Geometry::Ptr(factory->buildGeometry(transGeomList));
-Geometry::AutoPtr
+Geometry::Ptr
GeometryTransformer::transformLinearRing(
@@ -187,7 +187,7 @@ GeometryTransformer::transformLinearRing(
std::cerr << "GeometryTransformer::transformLinearRing(LinearRing " << geom <<", Geometry " << parent << ");" << std::endl;
#endif
- CoordinateSequence::AutoPtr seq(transformCoordinates(
+ CoordinateSequence::Ptr seq(transformCoordinates(
unsigned int seqSize = seq->size();
@@ -195,14 +195,15 @@ GeometryTransformer::transformLinearRing(
// ensure a valid LinearRing
if ( seqSize > 0 && seqSize < 4 && ! preserveType )
- return factory->createLineString(seq);
+ return factory->createLineString(std::move(seq));
+ else
+ return factory->createLinearRing(std::move(seq));
- return factory->createLinearRing(seq);
-Geometry::AutoPtr
+Geometry::Ptr
GeometryTransformer::transformLineString(
const Geometry* parent)
@@ -218,7 +219,7 @@ GeometryTransformer::transformLineString(
transformCoordinates(geom->getCoordinatesRO(), geom));
-Geometry::AutoPtr
+Geometry::Ptr
GeometryTransformer::transformMultiLineString(
const MultiLineString* geom,
@@ -237,7 +238,7 @@ GeometryTransformer::transformMultiLineString(
assert(l);
- Geometry::AutoPtr transformGeom = transformLineString(l, geom);
+ Geometry::Ptr transformGeom = transformLineString(l, geom);
@@ -245,11 +246,11 @@ GeometryTransformer::transformMultiLineString(
-Geometry::AutoPtr
+Geometry::Ptr
GeometryTransformer::transformPolygon(
const Polygon* geom,
@@ -266,7 +267,7 @@ GeometryTransformer::transformPolygon(
geom->getExteriorRing());
assert(lr);
- Geometry::AutoPtr shell = transformLinearRing(lr, geom);
+ Geometry::Ptr shell = transformLinearRing(lr, geom);
if ( shell.get() == NULL
|| ! dynamic_cast<LinearRing*>(shell.get())
|| shell->isEmpty() )
@@ -281,7 +282,7 @@ GeometryTransformer::transformPolygon(
geom->getInteriorRingN(i));
assert(lr);
- Geometry::AutoPtr hole(transformLinearRing(lr, geom));
+ Geometry::Ptr hole(transformLinearRing(lr, geom));
if ( hole.get() == NULL || hole->isEmpty() ) {
continue;
@@ -302,7 +303,7 @@ GeometryTransformer::transformPolygon(
Geometry* sh = shell.release();
LinearRing* lr = dynamic_cast<LinearRing*>(sh);
assert(lr);
- return Geometry::AutoPtr(factory->createPolygon(lr, holes));
+ return Geometry::Ptr(factory->createPolygon(lr, holes));
else
@@ -317,12 +318,12 @@ GeometryTransformer::transformPolygon(
delete holes; // :(
- return Geometry::AutoPtr(factory->buildGeometry(components));
+ return Geometry::Ptr(factory->buildGeometry(components));
-Geometry::AutoPtr
+Geometry::Ptr
GeometryTransformer::transformMultiPolygon(
const MultiPolygon* geom,
@@ -333,7 +334,7 @@ GeometryTransformer::transformMultiPolygon(
std::cerr << "GeometryTransformer::transformMultiPolygon(MultiPolygon " << geom <<", Geometry " << parent << ");" << std::endl;
#endif
- auto_ptr< vector<Geometry*> > transGeomList( new vector<Geometry*>() );
+ unique_ptr< vector<Geometry*> > transGeomList( new vector<Geometry*>() );
for (std::size_t i=0, n=geom->getNumGeometries(); i<n; i++)
@@ -341,7 +342,7 @@ GeometryTransformer::transformMultiPolygon(
assert(p);
- Geometry::AutoPtr transformGeom = transformPolygon(p, geom);
+ Geometry::Ptr transformGeom = transformPolygon(p, geom);
@@ -349,11 +350,11 @@ GeometryTransformer::transformMultiPolygon(
- return Geometry::AutoPtr(factory->buildGeometry(transGeomList.release()));
+ return Geometry::Ptr(factory->buildGeometry(transGeomList.release()));
-Geometry::AutoPtr
+Geometry::Ptr
GeometryTransformer::transformGeometryCollection(
const GeometryCollection* geom,
@@ -368,7 +369,7 @@ GeometryTransformer::transformGeometryCollection(
- Geometry::AutoPtr transformGeom = transform(
+ Geometry::Ptr transformGeom = transform(
geom->getGeometryN(i)); // no parent ?
if ( pruneEmptyGeometry && transformGeom->isEmpty() ) continue;
@@ -379,12 +380,12 @@ GeometryTransformer::transformGeometryCollection(
if ( preserveGeometryCollectionType )
- return Geometry::AutoPtr(factory->createGeometryCollection(
+ return Geometry::Ptr(factory->createGeometryCollection(
transGeomList));
else
diff --git a/src/geom/util/SineStarFactory.cpp b/src/geom/util/SineStarFactory.cpp
index aed6941..2086a63 100644
--- a/src/geom/util/SineStarFactory.cpp
+++ b/src/geom/util/SineStarFactory.cpp
@@ -41,10 +41,10 @@ namespace geom { // geos::geom
namespace util { // geos::geom::util
/* public */
-auto_ptr<Polygon>
+unique_ptr<Polygon>
SineStarFactory::createSineStar() const
- auto_ptr<Envelope> env ( dim.getEnvelope() );
+ unique_ptr<Envelope> env ( dim.getEnvelope() );
double radius = env->getWidth() / 2.0;
double armRatio = armLengthRatio;
@@ -57,7 +57,7 @@ SineStarFactory::createSineStar() const
double centreX = env->getMinX() + radius;
double centreY = env->getMinY() + radius;
- auto_ptr< vector<Coordinate> > pts ( new vector<Coordinate>(nPts+1) );
+ unique_ptr< vector<Coordinate> > pts ( new vector<Coordinate>(nPts+1) );
int iPt = 0;
for (int i = 0; i < nPts; i++) {
// the fraction of the way thru the current arm - in [0,1]
@@ -81,11 +81,11 @@ SineStarFactory::createSineStar() const
(*pts)[iPt] = Coordinate((*pts)[0]);
- auto_ptr<CoordinateSequence> cs (
+ unique_ptr<CoordinateSequence> cs (
geomFact->getCoordinateSequenceFactory()->create( pts.release() )
- auto_ptr<LinearRing> ring ( geomFact->createLinearRing( cs.release() ) );
- auto_ptr<Polygon> poly ( geomFact->createPolygon(ring.release(), 0) );
+ unique_ptr<LinearRing> ring ( geomFact->createLinearRing( cs.release() ) );
+ unique_ptr<Polygon> poly ( geomFact->createPolygon(ring.release(), 0) );
return poly;
diff --git a/src/geomgraph/GeometryGraph.cpp b/src/geomgraph/GeometryGraph.cpp
index 967d792..53d4bbf 100644
--- a/src/geomgraph/GeometryGraph.cpp
+++ b/src/geomgraph/GeometryGraph.cpp
@@ -50,7 +50,7 @@
#include <geos/inline.h>
#include <vector>
-#include <memory> // auto_ptr
+#include <memory> // unique_ptr
#include <cassert>
#include <typeinfo>
@@ -372,7 +372,7 @@ GeometryGraph::computeSelfNodes(LineIntersector &li,
SegmentIntersector *si = new SegmentIntersector(&li, true, false);
si->setIsDoneIfProperInt(isDoneIfProperInt);
- auto_ptr<EdgeSetIntersector> esi(createEdgeSetIntersector());
+ unique_ptr<EdgeSetIntersector> esi(createEdgeSetIntersector());
typedef vector<Edge*> EC;
EC *se = edges;
@@ -410,7 +410,7 @@ GeometryGraph::computeEdgeIntersections(GeometryGraph *g,
SegmentIntersector *si=new SegmentIntersector(li, includeProper, true);
si->setBoundaryNodes(getBoundaryNodes(), g->getBoundaryNodes());
diff --git a/src/geomgraph/PlanarGraph.cpp b/src/geomgraph/PlanarGraph.cpp
index e7b6a68..a1db6e5 100644
--- a/src/geomgraph/PlanarGraph.cpp
+++ b/src/geomgraph/PlanarGraph.cpp
@@ -212,8 +212,8 @@ PlanarGraph::addEdges(const vector<Edge*>& edgesToAdd)
// PlanarGraph destructor will delete all DirectedEdges
// in edgeEndList, which is where these are added
// by the ::add(EdgeEnd) call
- std::auto_ptr<DirectedEdge> de1(new DirectedEdge(e, true));
- std::auto_ptr<DirectedEdge> de2(new DirectedEdge(e, false));
+ std::unique_ptr<DirectedEdge> de1(new DirectedEdge(e, true));
+ std::unique_ptr<DirectedEdge> de2(new DirectedEdge(e, false));
de1->setSym(de2.get());
de2->setSym(de1.get());
diff --git a/src/index/chain/MonotoneChain.cpp b/src/index/chain/MonotoneChain.cpp
index fc5df41..9396bc3 100644
--- a/src/index/chain/MonotoneChain.cpp
+++ b/src/index/chain/MonotoneChain.cpp
@@ -66,10 +66,10 @@ MonotoneChain::getLineSegment(size_t index, LineSegment& ls) const
ls.p1 = pts[index+1];
MonotoneChain::getCoordinates() const
- return std::auto_ptr<CoordinateSequence>(pts.clone());
+ return std::unique_ptr<CoordinateSequence>(pts.clone());
void
diff --git a/src/index/quadtree/Node.cpp b/src/index/quadtree/Node.cpp
index aea9390..1499203 100644
--- a/src/index/quadtree/Node.cpp
+++ b/src/index/quadtree/Node.cpp
@@ -41,21 +41,20 @@ namespace index { // geos.index
namespace quadtree { // geos.index.quadtree
/* public static */
-std::auto_ptr<Node>
+std::unique_ptr<Node>
Node::createNode(const Envelope& env)
Key key(env);
- std::auto_ptr<Envelope> nenv ( new Envelope(key.getEnvelope()) );
- std::auto_ptr<Node> node (
- new Node(nenv, key.getLevel())
+ std::unique_ptr<Envelope> envelope(new Envelope(key.getEnvelope()));
+ std::unique_ptr<Node> node (
+ new Node(std::move(envelope), key.getLevel())
- return node;
+ return std::move(node);
/* static public */
-Node::createExpanded(std::auto_ptr<Node> node, const Envelope& addEnv)
+Node::createExpanded(std::unique_ptr<Node> node, const Envelope& addEnv)
Envelope expandEnv(addEnv);
if ( node.get() ) // should this be asserted ?
@@ -67,10 +66,10 @@ Node::createExpanded(std::auto_ptr<Node> node, const Envelope& addEnv)
cerr<<"Node::createExpanded computed "<<expandEnv.toString()<<endl;
#endif
- std::auto_ptr<Node> largerNode = createNode(expandEnv);
+ std::unique_ptr<Node> largerNode = createNode(expandEnv);
- largerNode->insertNode(node);
+ largerNode->insertNode(std::move(node));
return largerNode;
@@ -112,7 +111,7 @@ Node::find(const Envelope *searchEnv)
void
-Node::insertNode(std::auto_ptr<Node> node)
+Node::insertNode(std::unique_ptr<Node> node)
assert( env->contains(node->getEnvelope()) );
@@ -131,10 +130,10 @@ Node::insertNode(std::auto_ptr<Node> node)
// the quad is not a direct child, so make a new child
// quad to contain it and recursively insert the quad
- std::auto_ptr<Node> childNode ( createSubnode(index) );
+ std::unique_ptr<Node> childNode ( createSubnode(index) );
// childNode takes ownership of node
- childNode->insertNode(node);
+ childNode->insertNode(std::move(node));
// We take ownership of childNode
delete subnode[index];
@@ -153,7 +152,7 @@ Node::getSubnode(int index)
return subnode[index];
Node::createSubnode(int index)
// create a new subquad in the appropriate quadrant
@@ -188,8 +187,8 @@ Node::createSubnode(int index)
maxy=env->getMaxY();
break;
- std::auto_ptr<Envelope> sqEnv ( new Envelope(minx,maxx,miny,maxy) );
- std::auto_ptr<Node> node ( new Node(sqEnv, level-1) );
+ std::unique_ptr<Envelope> sqEnv ( new Envelope(minx,maxx,miny,maxy) );
+ std::unique_ptr<Node> node ( new Node(std::move(sqEnv), level-1) );
return node;
diff --git a/src/index/quadtree/Root.cpp b/src/index/quadtree/Root.cpp
index a7274ae..27a2424 100644
--- a/src/index/quadtree/Root.cpp
+++ b/src/index/quadtree/Root.cpp
@@ -78,11 +78,11 @@ Root::insert(const Envelope *itemEnv, void* item)
if (node==NULL || !node->getEnvelope()->contains(itemEnv))
- std::auto_ptr<Node> snode (node); // may be NULL
+ std::unique_ptr<Node> snode (node); // may be NULL
node = 0; subnode[index] = 0;
- Node::createExpanded(snode, *itemEnv);
+ Node::createExpanded(std::move(snode), *itemEnv);
#if GEOS_DEBUG
std::cerr<<"("<<this<<") created expanded node " << largerNode.get() << " containing previously reported subnode" << std::endl;
diff --git a/src/index/strtree/AbstractSTRtree.cpp b/src/index/strtree/AbstractSTRtree.cpp
index 914017e..fd2f926 100644
--- a/src/index/strtree/AbstractSTRtree.cpp
+++ b/src/index/strtree/AbstractSTRtree.cpp
@@ -63,15 +63,15 @@ AbstractSTRtree::build()
/*protected*/
-std::auto_ptr<BoundableList>
+std::unique_ptr<BoundableList>
AbstractSTRtree::createParentBoundables(BoundableList* childBoundables,
int newLevel)
assert(!childBoundables->empty());
- std::auto_ptr< BoundableList > parentBoundables ( new BoundableList() );
+ std::unique_ptr< BoundableList > parentBoundables ( new BoundableList() );
parentBoundables->push_back(createNode(newLevel));
- std::auto_ptr< BoundableList > sortedChildBoundables ( sortBoundables(childBoundables) );
+ std::unique_ptr< BoundableList > sortedChildBoundables ( sortBoundables(childBoundables) );
for (BoundableList::iterator i=sortedChildBoundables->begin(),
e=sortedChildBoundables->end();
@@ -96,7 +96,7 @@ AbstractNode*
AbstractSTRtree::createHigherLevels(BoundableList* boundablesOfALevel, int level)
assert(!boundablesOfALevel->empty());
createParentBoundables(boundablesOfALevel,level+1)
@@ -304,10 +304,10 @@ AbstractSTRtree::iterate(ItemVisitor& visitor)
/*protected*/
AbstractSTRtree::boundablesAtLevel(int level)
- std::auto_ptr<BoundableList> boundables ( new BoundableList() );
+ std::unique_ptr<BoundableList> boundables ( new BoundableList() );
boundablesAtLevel(level, root, boundables.get());
return boundables;
@@ -351,7 +351,7 @@ AbstractSTRtree::boundablesAtLevel(int level, AbstractNode* top,
ItemsList* AbstractSTRtree::itemsTree(AbstractNode* node)
- std::auto_ptr<ItemsList> valuesTreeForNode (new ItemsList());
+ std::unique_ptr<ItemsList> valuesTreeForNode (new ItemsList());
BoundableList::iterator end = node->getChildBoundables()->end();
for (BoundableList::iterator i = node->getChildBoundables()->begin();
diff --git a/src/index/strtree/BoundablePair.cpp b/src/index/strtree/BoundablePair.cpp
index 0e2ac8d..36b6262 100644
--- a/src/index/strtree/BoundablePair.cpp
+++ b/src/index/strtree/BoundablePair.cpp
@@ -104,7 +104,7 @@ void BoundablePair::expand(const Boundable* bndComposite, const Boundable* bndOt
std::vector<Boundable*> *children = ((AbstractNode*) bndComposite)->getChildBoundables();
for(std::vector<Boundable*>::iterator it = children->begin(); it != children->end(); ++it) {
Boundable* child = *it;
- std::auto_ptr<BoundablePair> bp(new BoundablePair(child, bndOther, itemDistance));
+ std::unique_ptr<BoundablePair> bp(new BoundablePair(child, bndOther, itemDistance));
if (minDistance == std::numeric_limits<double>::infinity() || bp->getDistance() < minDistance) {
priQ.push(bp.release());
diff --git a/src/index/strtree/SIRtree.cpp b/src/index/strtree/SIRtree.cpp
index 996983f..001ca21 100644
--- a/src/index/strtree/SIRtree.cpp
+++ b/src/index/strtree/SIRtree.cpp
@@ -33,14 +33,14 @@ static bool compareSIRBoundables(Boundable *a, Boundable *b){
/*protected*/
SIRtree::createParentBoundables(BoundableList *childBoundables,int newLevel)
- std::auto_ptr<BoundableList> parentBoundables ( new BoundableList() );
+ std::unique_ptr<BoundableList> parentBoundables ( new BoundableList() );
- std::auto_ptr<BoundableList> sortedChildBoundables ( sortBoundables(childBoundables) );
+ std::unique_ptr<BoundableList> sortedChildBoundables ( sortBoundables(childBoundables) );
//for(unsigned int i=0;i<sortedChildBoundables->size();i++)
@@ -131,10 +131,10 @@ void SIRtree::insert(double x1, double x2,void* item) {
AbstractSTRtree::insert(new Interval(min(x1,x2),max(x1, x2)),item);
SIRtree::sortBoundables(const BoundableList* input)
- std::auto_ptr<BoundableList> output ( new BoundableList(*input) );
+ std::unique_ptr<BoundableList> output ( new BoundableList(*input) );
sort(output->begin(), output->end(), compareSIRBoundables);
//output->sort(compareSIRBoundables);
return output;
diff --git a/src/index/strtree/STRtree.cpp b/src/index/strtree/STRtree.cpp
index 0d70434..9bc8435 100644
--- a/src/index/strtree/STRtree.cpp
+++ b/src/index/strtree/STRtree.cpp
@@ -106,19 +106,19 @@ STRtree::STRIntersectsOp::intersects(const void* aBounds, const void* bBounds)
/*private*/
STRtree::createParentBoundables(BoundableList* childBoundables, int newLevel)
int minLeafCount=(int) ceil((double)childBoundables->size()/(double)getNodeCapacity());
- std::auto_ptr< vector<BoundableList*> > verticalSlicesV (
+ std::unique_ptr< vector<BoundableList*> > verticalSlicesV (
verticalSlices(sortedChildBoundables.get(), (int)ceil(sqrt((double)minLeafCount)))
- std::auto_ptr<BoundableList> ret (
+ std::unique_ptr<BoundableList> ret (
createParentBoundablesFromVerticalSlices(verticalSlicesV.get(), newLevel)
for (size_t i=0, vssize=verticalSlicesV->size(); i<vssize; ++i)
@@ -131,15 +131,15 @@ STRtree::createParentBoundables(BoundableList* childBoundables, int newLevel)
/*private*/
STRtree::createParentBoundablesFromVerticalSlices(std::vector<BoundableList*>* verticalSlices, int newLevel)
assert(!verticalSlices->empty());
- std::auto_ptr<BoundableList> parentBoundables( new BoundableList() );
+ std::unique_ptr<BoundableList> parentBoundables( new BoundableList() );
for (size_t i=0, vssize=verticalSlices->size(); i<vssize; ++i)
- std::auto_ptr<BoundableList> toAdd (
+ std::unique_ptr<BoundableList> toAdd (
createParentBoundablesFromVerticalSlice(
(*verticalSlices)[i], newLevel)
@@ -154,7 +154,7 @@ STRtree::createParentBoundablesFromVerticalSlices(std::vector<BoundableList*>* v
/*protected*/
STRtree::createParentBoundablesFromVerticalSlice(BoundableList* childBoundables, int newLevel)
return AbstractSTRtree::createParentBoundables(childBoundables, newLevel);
@@ -328,11 +328,11 @@ STRtree::insert(const Envelope *itemEnv, void* item)
/*private*/
STRtree::sortBoundables(const BoundableList* input)
assert(input);
assert(output->size() == input->size());
sort(output->begin(), output->end(), yComparator);
diff --git a/src/io/WKTReader.cpp b/src/io/WKTReader.cpp
index b1b885e..25e24dc 100644
--- a/src/io/WKTReader.cpp
+++ b/src/io/WKTReader.cpp
@@ -60,7 +60,7 @@ namespace io { // geos.io
Geometry *
WKTReader::read(const string &wellKnownText)
- //auto_ptr<StringTokenizer> tokenizer(new StringTokenizer(wellKnownText));
+ //unique_ptr<StringTokenizer> tokenizer(new StringTokenizer(wellKnownText));
CLocalizer clocale;
StringTokenizer tokenizer(wellKnownText);
Geometry *g=NULL;
diff --git a/src/linearref/LinearLocation.cpp b/src/linearref/LinearLocation.cpp
index 49de76f..0b8b147 100644
--- a/src/linearref/LinearLocation.cpp
+++ b/src/linearref/LinearLocation.cpp
@@ -202,7 +202,7 @@ LinearLocation::getCoordinate(const Geometry* linearGeom) const
/* public */
-std::auto_ptr<LineSegment>
+std::unique_ptr<LineSegment>
LinearLocation::getSegment(const Geometry* linearGeom) const
const LineString* lineComp = dynamic_cast<const LineString *> (linearGeom->getGeometryN(componentIndex));
@@ -211,10 +211,10 @@ LinearLocation::getSegment(const Geometry* linearGeom) const
if (segmentIndex >= lineComp->getNumPoints() - 1)
Coordinate prev = lineComp->getCoordinateN(lineComp->getNumPoints() - 2);
- return std::auto_ptr<LineSegment>(new LineSegment(prev, p0));
+ return std::unique_ptr<LineSegment>(new LineSegment(prev, p0));
Coordinate p1 = lineComp->getCoordinateN(segmentIndex + 1);
- return std::auto_ptr<LineSegment>(new LineSegment(p0, p1));
+ return std::unique_ptr<LineSegment>(new LineSegment(p0, p1));
/* public */
diff --git a/src/noding/GeometryNoder.cpp b/src/noding/GeometryNoder.cpp
index 86eae67..fe2ad05 100644
--- a/src/noding/GeometryNoder.cpp
+++ b/src/noding/GeometryNoder.cpp
@@ -36,7 +36,7 @@
#include <geos/noding/snapround/SimpleSnapRounder.h>
#include <geos/noding/snapround/MCIndexSnapRounder.h>
#include <iostream>
namespace geos {
@@ -73,7 +73,7 @@ private:
/* public static */
-std::auto_ptr<geom::Geometry>
+std::unique_ptr<geom::Geometry>
GeometryNoder::node(const geom::Geometry& geom)
GeometryNoder noder(geom);
@@ -88,7 +88,7 @@ GeometryNoder::GeometryNoder(const geom::Geometry& g)
/* private */
GeometryNoder::toGeometry(SegmentString::NonConstVect& nodedEdges)
const geom::GeometryFactory *geomFact = argGeom.getFactory();
@@ -112,13 +112,13 @@ GeometryNoder::toGeometry(SegmentString::NonConstVect& nodedEdges)
- std::auto_ptr<geom::Geometry> noded ( geomFact->createMultiLineString( lines ) );
+ std::unique_ptr<geom::Geometry> noded ( geomFact->createMultiLineString( lines ) );
return noded;
/* public */
GeometryNoder::getNoded()
SegmentString::NonConstVect lineList;
@@ -138,7 +138,7 @@ GeometryNoder::getNoded()
throw ex;
- std::auto_ptr<geom::Geometry> noded = toGeometry(*nodedEdges);
+ std::unique_ptr<geom::Geometry> noded = toGeometry(*nodedEdges);
for ( unsigned int i = 0, n = nodedEdges->size(); i < n; ++i )
delete ( *nodedEdges )[i];
diff --git a/src/noding/snapround/HotPixel.cpp b/src/noding/snapround/HotPixel.cpp
index e35b9e3..6c9c178 100644
--- a/src/noding/snapround/HotPixel.cpp
+++ b/src/noding/snapround/HotPixel.cpp
@@ -60,7 +60,7 @@ HotPixel::getSafeEnvelope() const
if (safeEnv.get() == NULL) {
double safeTolerance = SAFE_ENV_EXPANSION_FACTOR / scaleFactor;
- safeEnv = auto_ptr<Envelope>(new Envelope(originalPt.x - safeTolerance,
+ safeEnv = unique_ptr<Envelope>(new Envelope(originalPt.x - safeTolerance,
originalPt.x + safeTolerance,
originalPt.y - safeTolerance,
originalPt.y + safeTolerance
diff --git a/src/noding/snapround/MCIndexSnapRounder.cpp b/src/noding/snapround/MCIndexSnapRounder.cpp
index e04b0bb..277e98e 100644
--- a/src/noding/snapround/MCIndexSnapRounder.cpp
+++ b/src/noding/snapround/MCIndexSnapRounder.cpp
@@ -126,7 +126,7 @@ void
MCIndexSnapRounder::checkCorrectness(
SegmentString::NonConstVect& inputSegmentStrings)
- auto_ptr<SegmentString::NonConstVect> resultSegStrings(
+ unique_ptr<SegmentString::NonConstVect> resultSegStrings(
NodedSegmentString::getNodedSubstrings(inputSegmentStrings)
diff --git a/src/operation/IsSimpleOp.cpp b/src/operation/IsSimpleOp.cpp
index 864f5c4..e832106 100644
--- a/src/operation/IsSimpleOp.cpp
+++ b/src/operation/IsSimpleOp.cpp
@@ -171,7 +171,7 @@ IsSimpleOp::isSimpleLinearGeometry(const Geometry *geom)
if (geom->isEmpty()) return true;
GeometryGraph graph(0,geom);
LineIntersector li;
- std::auto_ptr<SegmentIntersector> si (graph.computeSelfNodes(&li,true));
+ std::unique_ptr<SegmentIntersector> si (graph.computeSelfNodes(&li,true));
// if no self-intersection, must be simple
if (!si->hasIntersection()) return true;
diff --git a/src/operation/buffer/BufferBuilder.cpp b/src/operation/buffer/BufferBuilder.cpp
index ac0608b..b9881be 100644
--- a/src/operation/buffer/BufferBuilder.cpp
+++ b/src/operation/buffer/BufferBuilder.cpp
@@ -81,7 +81,7 @@ namespace {
// Debug routine
template <class Iterator>
-std::auto_ptr<Geometry>
+std::unique_ptr<Geometry>
convertSegStrings(const GeometryFactory* fact, Iterator it, Iterator et)
std::vector<Geometry*> lines;
@@ -91,7 +91,7 @@ convertSegStrings(const GeometryFactory* fact, Iterator it, Iterator et)
lines.push_back(line);
++it;
- return std::auto_ptr<Geometry>(fact->buildGeometry(lines));
+ return std::unique_ptr<Geometry>(fact->buildGeometry(lines));
@@ -151,7 +151,7 @@ BufferBuilder::bufferLineSingleSided( const Geometry* g, double distance,
BufferParameters modParams = bufParams;
modParams.setEndCapStyle(BufferParameters::CAP_FLAT);
modParams.setSingleSided(false); // ignore parameter for areal-only geometries
- std::auto_ptr<Geometry> buf;
+ std::unique_ptr<Geometry> buf;
// This is a (temp?) hack to workaround the fact that
// BufferBuilder BufferParamaters are immutable after
@@ -163,7 +163,7 @@ BufferBuilder::bufferLineSingleSided( const Geometry* g, double distance,
// Create MultiLineStrings from this polygon.
- std::auto_ptr<Geometry> bufLineString ( buf->getBoundary() );
+ std::unique_ptr<Geometry> bufLineString ( buf->getBoundary() );
#ifdef GEOS_DEBUG_SSB
std::cerr << "input|" << *l << std::endl;
@@ -175,7 +175,7 @@ BufferBuilder::bufferLineSingleSided( const Geometry* g, double distance,
std::vector< CoordinateSequence* > lineList;
- std::auto_ptr< CoordinateSequence > coords(g->getCoordinates());
+ std::unique_ptr< CoordinateSequence > coords(g->getCoordinates());
curveBuilder.getSingleSidedLineCurve(coords.get(), distance,
lineList, leftSide, !leftSide);
coords.reset();
@@ -221,7 +221,7 @@ BufferBuilder::bufferLineSingleSided( const Geometry* g, double distance,
for (size_t i=0, n=curveList.size(); i<n; ++i) delete curveList[i];
curveList.clear();
- std::auto_ptr<Geometry> singleSided ( geomFact->createMultiLineString(
+ std::unique_ptr<Geometry> singleSided ( geomFact->createMultiLineString(
singleSidedNodedEdges ) );
@@ -235,7 +235,7 @@ BufferBuilder::bufferLineSingleSided( const Geometry* g, double distance,
// diverge from original offset curves due to the addition of
// intersections with caps and joins curves
using geos::operation::overlay::snap::SnapOverlayOp;
- std::auto_ptr<Geometry> intersectedLines = SnapOverlayOp::overlayOp(*singleSided, *bufLineString, OverlayOp::opINTERSECTION);
+ std::unique_ptr<Geometry> intersectedLines = SnapOverlayOp::overlayOp(*singleSided, *bufLineString, OverlayOp::opINTERSECTION);
std::cerr << "intersection" << "|" << *intersectedLines << std::endl;
@@ -244,7 +244,7 @@ BufferBuilder::bufferLineSingleSided( const Geometry* g, double distance,
// Merge result lines together.
LineMerger lineMerge;
lineMerge.add( intersectedLines.get() );
- std::auto_ptr< std::vector< LineString* > > mergedLines (
+ std::unique_ptr< std::vector< LineString* > > mergedLines (
lineMerge.getMergedLineStrings() );
// Convert the result into a std::vector< Geometry* >.
@@ -255,7 +255,7 @@ BufferBuilder::bufferLineSingleSided( const Geometry* g, double distance,
// Remove end points if they are a part of the original line to be
// buffered.
- CoordinateSequence::AutoPtr coords(mergedLines->back()->getCoordinates());
+ CoordinateSequence::Ptr coords(mergedLines->back()->getCoordinates());
if ( NULL != coords.get() )
// Use 98% of the buffer width as the point-distance requirement - this
@@ -411,7 +411,7 @@ BufferBuilder::buffer(const Geometry *g, double distance)
#endif
Geometry* resultGeom=NULL;
- std::auto_ptr< std::vector<Geometry*> > resultPolyList;
+ std::unique_ptr< std::vector<Geometry*> > resultPolyList;
std::vector<BufferSubgraph*> subgraphList;
try {
diff --git a/src/operation/buffer/BufferInputLineSimplifier.cpp b/src/operation/buffer/BufferInputLineSimplifier.cpp
index ca9d78c..bc56c29 100644
--- a/src/operation/buffer/BufferInputLineSimplifier.cpp
+++ b/src/operation/buffer/BufferInputLineSimplifier.cpp
@@ -43,7 +43,7 @@ BufferInputLineSimplifier::BufferInputLineSimplifier(
/*public static*/
-std::auto_ptr<geom::CoordinateSequence>
+std::unique_ptr<geom::CoordinateSequence>
BufferInputLineSimplifier::simplify(const geom::CoordinateSequence& inputLine,
double distanceTol)
@@ -52,7 +52,7 @@ BufferInputLineSimplifier::simplify(const geom::CoordinateSequence& inputLine,
/* public */
BufferInputLineSimplifier::simplify(double nDistanceTol)
distanceTol = fabs(nDistanceTol);
@@ -120,10 +120,10 @@ BufferInputLineSimplifier::findNextNonDeletedIndex(unsigned int index) const
/* private */
BufferInputLineSimplifier::collapseLine() const
- std::auto_ptr<geom::CoordinateSequence> coordList(
+ std::unique_ptr<geom::CoordinateSequence> coordList(
new CoordinateArraySequence());
for (size_t i=0, n=inputLine.size(); i<n; ++i)
diff --git a/src/operation/buffer/BufferOp.cpp b/src/operation/buffer/BufferOp.cpp
index 10e47c1..eb12dce 100644
--- a/src/operation/buffer/BufferOp.cpp
+++ b/src/operation/buffer/BufferOp.cpp
@@ -254,7 +254,7 @@ BufferOp::bufferFixedPrecision(const PrecisionModel& fixedPM)
const Geometry *workGeom = argGeom;
const PrecisionModel& argPM = *(argGeom->getFactory()->getPrecisionModel());
- std::auto_ptr<Geometry> fixedGeom;
+ std::unique_ptr<Geometry> fixedGeom;
if ( argPM.getType() != PrecisionModel::FIXED || argPM.getScale() != fixedPM.getScale() )
using precision::GeometryPrecisionReducer;
diff --git a/src/operation/buffer/OffsetCurveBuilder.cpp b/src/operation/buffer/OffsetCurveBuilder.cpp
index fa79ad9..e3d1b8d 100644
--- a/src/operation/buffer/OffsetCurveBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveBuilder.cpp
@@ -67,7 +67,7 @@ OffsetCurveBuilder::getLineCurve(const CoordinateSequence *inputPts,
double posDistance = std::abs(distance);
- std::auto_ptr<OffsetSegmentGenerator> segGen = getSegGen(posDistance);
+ std::unique_ptr<OffsetSegmentGenerator> segGen = getSegGen(posDistance);
if (inputPts->getSize() <= 1) {
computePointCurve(inputPts->getAt(0), *segGen);
} else {
@@ -118,12 +118,12 @@ OffsetCurveBuilder::getSingleSidedLineCurve(const CoordinateSequence* inputPts,
double distTol = simplifyTolerance(distance);
- std::auto_ptr<OffsetSegmentGenerator> segGen = getSegGen(distance);
+ std::unique_ptr<OffsetSegmentGenerator> segGen = getSegGen(distance);
if ( leftSide ) {
//--------- compute points for left side of line
// Simplify the appropriate side of the line before generating
- std::auto_ptr<CoordinateSequence> simp1_ =
+ std::unique_ptr<CoordinateSequence> simp1_ =
BufferInputLineSimplifier::simplify( *inputPts, distTol );
const CoordinateSequence& simp1 = *simp1_;
@@ -143,7 +143,7 @@ OffsetCurveBuilder::getSingleSidedLineCurve(const CoordinateSequence* inputPts,
//---------- compute points for right side of line
- std::auto_ptr<CoordinateSequence> simp2_ =
+ std::unique_ptr<CoordinateSequence> simp2_ =
BufferInputLineSimplifier::simplify( *inputPts, -distTol );
const CoordinateSequence& simp2 = *simp2_;
@@ -181,7 +181,7 @@ OffsetCurveBuilder::getRingCurve(const CoordinateSequence *inputPts,
return;
- std::auto_ptr<OffsetSegmentGenerator> segGen = getSegGen(std::abs(distance));
+ std::unique_ptr<OffsetSegmentGenerator> segGen = getSegGen(std::abs(distance));
computeRingBufferCurve(*inputPts, side, *segGen);
segGen->getCoordinates(lineList);
@@ -202,7 +202,7 @@ OffsetCurveBuilder::computeLineBufferCurve(const CoordinateSequence& inputPts,
BufferInputLineSimplifier::simplify(inputPts, distTol);
@@ -218,7 +218,7 @@ OffsetCurveBuilder::computeLineBufferCurve(const CoordinateSequence& inputPts,
BufferInputLineSimplifier::simplify(inputPts, -distTol);
@@ -244,7 +244,7 @@ OffsetCurveBuilder::computeRingBufferCurve(const CoordinateSequence& inputPts,
// ensure that correct side is simplified
if (side == Position::RIGHT)
distTol = -distTol;
- std::auto_ptr<CoordinateSequence> simp_ =
+ std::unique_ptr<CoordinateSequence> simp_ =
const CoordinateSequence& simp = *simp_;
@@ -272,7 +272,7 @@ OffsetCurveBuilder::computeSingleSidedBufferCurve(
@@ -290,7 +290,7 @@ OffsetCurveBuilder::computeSingleSidedBufferCurve(
@@ -307,10 +307,10 @@ OffsetCurveBuilder::computeSingleSidedBufferCurve(
/*private*/
-std::auto_ptr<OffsetSegmentGenerator>
+std::unique_ptr<OffsetSegmentGenerator>
OffsetCurveBuilder::getSegGen(double dist)
- std::auto_ptr<OffsetSegmentGenerator> osg(
+ std::unique_ptr<OffsetSegmentGenerator> osg(
new OffsetSegmentGenerator(precisionModel, bufParams, dist)
return osg;
diff --git a/src/operation/buffer/OffsetCurveSetBuilder.cpp b/src/operation/buffer/OffsetCurveSetBuilder.cpp
index 59a995e..b32b0b6 100644
--- a/src/operation/buffer/OffsetCurveSetBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveSetBuilder.cpp
@@ -203,7 +203,7 @@ OffsetCurveSetBuilder::addLineString(const LineString *line)
#if GEOS_DEBUG
std::cerr<<__FUNCTION__<<": "<<line->toString()<<std::endl;
#endif
- std::auto_ptr<CoordinateSequence> coord(CoordinateSequence::removeRepeatedPoints(line->getCoordinatesRO()));
+ std::unique_ptr<CoordinateSequence> coord(CoordinateSequence::removeRepeatedPoints(line->getCoordinatesRO()));
#if GEOS_DEBUG
std::cerr<<" After coordinate removal: "<<coord->toString()<<std::endl;
#endif
diff --git a/src/operation/distance/FacetSequenceTreeBuilder.cpp b/src/operation/distance/FacetSequenceTreeBuilder.cpp
index bd5c970..e1273af 100644
--- a/src/operation/distance/FacetSequenceTreeBuilder.cpp
+++ b/src/operation/distance/FacetSequenceTreeBuilder.cpp
@@ -28,8 +28,8 @@ namespace operation {
namespace distance {
STRtree* FacetSequenceTreeBuilder::build(const Geometry* g) {
- std::auto_ptr<STRtree> tree(new STRtree(STR_TREE_NODE_CAPACITY));
- std::auto_ptr<std::vector<FacetSequence*> > sections(computeFacetSequences(g));
+ std::unique_ptr<STRtree> tree(new STRtree(STR_TREE_NODE_CAPACITY));
+ std::unique_ptr<std::vector<FacetSequence*> > sections(computeFacetSequences(g));
for (std::vector<FacetSequence*>::iterator it = sections->begin(); it != sections->end(); ++it) {
FacetSequence* section = *it;
tree->insert(section->getEnvelope(), section);
@@ -40,7 +40,7 @@ STRtree* FacetSequenceTreeBuilder::build(const Geometry* g) {
std::vector<FacetSequence*> * FacetSequenceTreeBuilder::computeFacetSequences(const Geometry* g) {
- std::auto_ptr<std::vector<FacetSequence*> > sections(new std::vector<FacetSequence*>());
+ std::unique_ptr<std::vector<FacetSequence*> > sections(new std::vector<FacetSequence*>());
class FacetSequenceAdder;
class FacetSequenceAdder : public geom::GeometryComponentFilter {
diff --git a/src/operation/distance/IndexedFacetDistance.cpp b/src/operation/distance/IndexedFacetDistance.cpp
index ce28061..a8f4d55 100644
--- a/src/operation/distance/IndexedFacetDistance.cpp
+++ b/src/operation/distance/IndexedFacetDistance.cpp
@@ -44,7 +44,7 @@ namespace geos {
} itemDistance;
- std::auto_ptr<STRtree> tree2(FacetSequenceTreeBuilder::build(g));
+ std::unique_ptr<STRtree> tree2(FacetSequenceTreeBuilder::build(g));
std::pair<const void*, const void*> obj = cachedTree->nearestNeighbour(tree2.get(), dynamic_cast<ItemDistance*>(&itemDistance));
diff --git a/src/operation/intersection/RectangleIntersection.cpp b/src/operation/intersection/RectangleIntersection.cpp
index e4cef09..335603a 100644
--- a/src/operation/intersection/RectangleIntersection.cpp
+++ b/src/operation/intersection/RectangleIntersection.cpp
@@ -660,14 +660,14 @@ RectangleIntersection::clip_geom(const geom::Geometry * g,
/* public static */
RectangleIntersection::clipBoundary(const geom::Geometry & g, const Rectangle & rect)
RectangleIntersection ri(g,rect);
return ri.clipBoundary();
RectangleIntersection::clipBoundary()
RectangleIntersectionBuilder parts(*_gf);
@@ -679,14 +679,14 @@ RectangleIntersection::clipBoundary()
/* public static */
RectangleIntersection::clip(const geom::Geometry & g, const Rectangle & rect)
return ri.clip();
RectangleIntersection::clip()
diff --git a/src/operation/intersection/RectangleIntersectionBuilder.cpp b/src/operation/intersection/RectangleIntersectionBuilder.cpp
index 728462f..c341ea7 100644
--- a/src/operation/intersection/RectangleIntersectionBuilder.cpp
+++ b/src/operation/intersection/RectangleIntersectionBuilder.cpp
@@ -140,7 +140,7 @@ void RectangleIntersectionBuilder::add(geom::Point * thePoint)
points.push_back(thePoint);
RectangleIntersectionBuilder::build()
// Total number of objects
@@ -148,7 +148,7 @@ RectangleIntersectionBuilder::build()
std::size_t n = polygons.size() + lines.size() + points.size();
if(n == 0)
- return std::auto_ptr<Geometry>(_gf.createGeometryCollection());
+ return std::unique_ptr<Geometry>(_gf.createGeometryCollection());
std::vector<Geometry *> *geoms = new std::vector<Geometry *>;
geoms->reserve(n);
@@ -165,7 +165,7 @@ RectangleIntersectionBuilder::build()
geoms->push_back(*i);
points.clear();
(*geoms)[0]->getFactory()->buildGeometry(geoms)
diff --git a/src/operation/linemerge/LineMergeGraph.cpp b/src/operation/linemerge/LineMergeGraph.cpp
index 0a92b7e..111df47 100644
--- a/src/operation/linemerge/LineMergeGraph.cpp
+++ b/src/operation/linemerge/LineMergeGraph.cpp
@@ -54,7 +54,7 @@ LineMergeGraph::addEdge(const LineString *lineString)
cerr<<"Adding LineString "<<lineString->toString()<<endl;
#endif
- std::auto_ptr<CoordinateSequence> coordinates (
+ std::unique_ptr<CoordinateSequence> coordinates (
CoordinateSequence::removeRepeatedPoints(lineString->getCoordinatesRO())
diff --git a/src/operation/linemerge/LineSequencer.cpp b/src/operation/linemerge/LineSequencer.cpp
index 939b506..798344f 100644
--- a/src/operation/linemerge/LineSequencer.cpp
+++ b/src/operation/linemerge/LineSequencer.cpp
@@ -183,7 +183,7 @@ LineSequencer::computeSequence()
Sequences* sequences = findSequences();
if (sequences == NULL) return;
- sequencedGeometry = auto_ptr<Geometry>(buildSequencedGeometry(*sequences));
+ sequencedGeometry = unique_ptr<Geometry>(buildSequencedGeometry(*sequences));
isSequenceableVar = true;
delAll(*sequences);
@@ -201,7 +201,7 @@ LineSequencer::computeSequence()
Geometry*
LineSequencer::buildSequencedGeometry(const Sequences& sequences)
- auto_ptr<Geometry::NonConstVect> lines(new Geometry::NonConstVect);
+ unique_ptr<Geometry::NonConstVect> lines(new Geometry::NonConstVect);
for (Sequences::const_iterator
i1=sequences.begin(), i1End=sequences.end();
diff --git a/src/operation/overlay/OverlayOp.cpp b/src/operation/overlay/OverlayOp.cpp
index cc87581..aa8a465 100644
--- a/src/operation/overlay/OverlayOp.cpp
+++ b/src/operation/overlay/OverlayOp.cpp
@@ -50,7 +50,7 @@
#include <functional>
#include <vector>
#include <sstream>
#ifndef GEOS_DEBUG
#define GEOS_DEBUG 0
diff --git a/src/operation/overlay/snap/GeometrySnapper.cpp b/src/operation/overlay/snap/GeometrySnapper.cpp
index 2a45987..f7d03f4 100644
--- a/src/operation/overlay/snap/GeometrySnapper.cpp
+++ b/src/operation/overlay/snap/GeometrySnapper.cpp
@@ -52,18 +52,18 @@ private:
const Coordinate::ConstVect& snapPts;
- CoordinateSequence::AutoPtr snapLine(
+ CoordinateSequence::Ptr snapLine(
const CoordinateSequence* srcPts)
- using std::auto_ptr;
+ using std::unique_ptr;
assert(srcPts);
assert(srcPts->toVector());
LineStringSnapper snapper(*(srcPts->toVector()), snapTol);
- auto_ptr<Coordinate::Vect> newPts = snapper.snapTo(snapPts);
+ unique_ptr<Coordinate::Vect> newPts = snapper.snapTo(snapPts);
const CoordinateSequenceFactory* cfact = factory->getCoordinateSequenceFactory();
- return auto_ptr<CoordinateSequence>(cfact->create(newPts.release()));
+ return unique_ptr<CoordinateSequence>(cfact->create(newPts.release()));
public:
@@ -76,7 +76,7 @@ public:
- CoordinateSequence::AutoPtr transformCoordinates(
+ CoordinateSequence::Ptr transformCoordinates(
const CoordinateSequence* coords,
@@ -88,10 +88,10 @@ public:
/*private*/
-std::auto_ptr<Coordinate::ConstVect>
+std::unique_ptr<Coordinate::ConstVect>
GeometrySnapper::extractTargetCoordinates(const Geometry& g)
- std::auto_ptr<Coordinate::ConstVect> snapPts(new Coordinate::ConstVect());
+ std::unique_ptr<Coordinate::ConstVect> snapPts(new Coordinate::ConstVect());
util::UniqueCoordinateArrayFilter filter(*snapPts);
g.apply_ro(&filter);
// integrity check
@@ -100,36 +100,36 @@ GeometrySnapper::extractTargetCoordinates(const Geometry& g)
/*public*/
GeometrySnapper::snapTo(const geom::Geometry& g, double snapTolerance)
using geom::util::GeometryTransformer;
// Get snap points
- auto_ptr<Coordinate::ConstVect> snapPts=extractTargetCoordinates(g);
+ unique_ptr<Coordinate::ConstVect> snapPts=extractTargetCoordinates(g);
// Apply a SnapTransformer to source geometry
// (we need a pointer for dynamic polymorphism)
- auto_ptr<GeometryTransformer> snapTrans(new SnapTransformer(snapTolerance, *snapPts));
+ unique_ptr<GeometryTransformer> snapTrans(new SnapTransformer(snapTolerance, *snapPts));
return snapTrans->transform(&srcGeom);
/*public*/
GeometrySnapper::snapToSelf(double snapTolerance, bool cleanResult)
// Get snap points
- auto_ptr<Coordinate::ConstVect> snapPts=extractTargetCoordinates(srcGeom);
+ unique_ptr<Coordinate::ConstVect> snapPts=extractTargetCoordinates(srcGeom);
GeomPtr result = snapTrans->transform(&srcGeom);
diff --git a/src/operation/overlay/snap/LineStringSnapper.cpp b/src/operation/overlay/snap/LineStringSnapper.cpp
index dfb8608..c15915d 100644
--- a/src/operation/overlay/snap/LineStringSnapper.cpp
+++ b/src/operation/overlay/snap/LineStringSnapper.cpp
@@ -50,7 +50,7 @@ namespace overlay { // geos.operation.overlay
namespace snap { // geos.operation.overlay.snap
/*public*/
-std::auto_ptr<Coordinate::Vect>
+std::unique_ptr<Coordinate::Vect>
LineStringSnapper::snapTo(const geom::Coordinate::ConstVect& snapPts)
geom::CoordinateList coordList(srcPts);
diff --git a/src/operation/overlay/snap/SnapIfNeededOverlayOp.cpp b/src/operation/overlay/snap/SnapIfNeededOverlayOp.cpp
index 7094d4d..9da6254 100644
--- a/src/operation/overlay/snap/SnapIfNeededOverlayOp.cpp
+++ b/src/operation/overlay/snap/SnapIfNeededOverlayOp.cpp
@@ -19,12 +19,12 @@
#include <geos/operation/overlay/snap/SnapIfNeededOverlayOp.h>
#include <geos/operation/overlay/snap/SnapOverlayOp.h>
#include <geos/operation/overlay/OverlayOp.h>
-#include <geos/geom/Geometry.h> // for use in auto_ptr
+#include <geos/geom/Geometry.h> // for use in unique_ptr
#include <geos/util.h>
#include <cassert>
#include <limits> // for numeric_limits
#ifndef GEOS_DEBUG
@@ -39,12 +39,12 @@ namespace overlay { // geos.operation.overlay
/* public */
-auto_ptr<Geometry>
SnapIfNeededOverlayOp::getResultGeometry(OverlayOp::OpCode opCode)
using geos::util::TopologyException;
- auto_ptr<Geometry> result;
+ unique_ptr<Geometry> result;
TopologyException origEx;
diff --git a/src/operation/overlay/snap/SnapOverlayOp.cpp b/src/operation/overlay/snap/SnapOverlayOp.cpp
index a6c5e0c..3b09324 100644
--- a/src/operation/overlay/snap/SnapOverlayOp.cpp
+++ b/src/operation/overlay/snap/SnapOverlayOp.cpp
@@ -23,7 +23,7 @@
#include <cassert>
#ifndef GEOS_DEBUG
@@ -48,7 +48,7 @@ SnapOverlayOp::computeSnapTolerance()
/* public */
-auto_ptr<Geometry>
SnapOverlayOp::getResultGeometry(OverlayOp::OpCode opCode)
geom::GeomPtrPair prepGeom;
diff --git a/src/operation/overlay/validate/FuzzyPointLocator.cpp b/src/operation/overlay/validate/FuzzyPointLocator.cpp
index 66055c9..f8d7449 100644
--- a/src/operation/overlay/validate/FuzzyPointLocator.cpp
+++ b/src/operation/overlay/validate/FuzzyPointLocator.cpp
@@ -27,7 +27,7 @@
#include <vector>
#include <sstream>
#ifndef GEOS_DEBUG
@@ -57,7 +57,7 @@ FuzzyPointLocator::FuzzyPointLocator(const geom::Geometry& geom,
/*private*/
FuzzyPointLocator::extractLineWork(const geom::Geometry& geom)
::geos::ignore_unused_variable_warning(geom);
@@ -76,7 +76,7 @@ FuzzyPointLocator::extractLineWork(const geom::Geometry& geom)
lineGeoms->push_back(lineGeom);
- return std::auto_ptr<Geometry>(g.getFactory()->buildGeometry(lineGeoms));
+ return std::unique_ptr<Geometry>(g.getFactory()->buildGeometry(lineGeoms));
} catch (...) { // avoid leaks
for (size_t i=0, n=lineGeoms->size(); i<n; ++i)
@@ -90,7 +90,7 @@ FuzzyPointLocator::extractLineWork(const geom::Geometry& geom)
/*private*/
FuzzyPointLocator::getLineWork(const geom::Geometry& geom)
@@ -110,7 +110,7 @@ FuzzyPointLocator::getLineWork(const geom::Geometry& geom)
@@ -128,7 +128,7 @@ FuzzyPointLocator::getLineWork(const geom::Geometry& geom)
FuzzyPointLocator::getLocation(const Coordinate& pt)
- auto_ptr<Geometry> point(g.getFactory()->createPoint(pt));
+ unique_ptr<Geometry> point(g.getFactory()->createPoint(pt));
double dist = linework->distance(point.get());
diff --git a/src/operation/overlay/validate/OffsetPointGenerator.cpp b/src/operation/overlay/validate/OffsetPointGenerator.cpp
index c28081b..127a923 100644
--- a/src/operation/overlay/validate/OffsetPointGenerator.cpp
+++ b/src/operation/overlay/validate/OffsetPointGenerator.cpp
@@ -27,7 +27,7 @@
#include <cassert>
#include <vector>
#include <cmath>
#include <algorithm> // std::for_each
@@ -54,7 +54,7 @@ OffsetPointGenerator::OffsetPointGenerator(const geom::Geometry& geom,
/*public*/
-std::auto_ptr< std::vector<geom::Coordinate> >
+std::unique_ptr< std::vector<geom::Coordinate> >
OffsetPointGenerator::getPoints()
assert (offsetPts.get() == NULL);
@@ -65,7 +65,8 @@ OffsetPointGenerator::getPoints()
for_each(lines.begin(), lines.end(),
bind1st(mem_fun(&OffsetPointGenerator::extractPoints), this));
- return offsetPts;
+ // NOTE: Apparently, this is 'source' method giving up the object resource.
+ return std::move(offsetPts);
/*private*/
diff --git a/src/operation/overlay/validate/OverlayResultValidator.cpp b/src/operation/overlay/validate/OverlayResultValidator.cpp
index 601045b..ee099e5 100644
--- a/src/operation/overlay/validate/OverlayResultValidator.cpp
+++ b/src/operation/overlay/validate/OverlayResultValidator.cpp
@@ -28,7 +28,7 @@
#include <cassert>
#include <vector>
#include <algorithm> // for std::min etc.
#ifndef GEOS_DEBUG
@@ -67,17 +67,17 @@ isArea(const Geometry& g)
return false;
-auto_ptr<MultiPoint>
+unique_ptr<MultiPoint>
toMultiPoint(vector<Coordinate>& coords)
const GeometryFactory& gf = *(GeometryFactory::getDefaultInstance());
const CoordinateSequenceFactory& csf =
*(gf.getCoordinateSequenceFactory());
- auto_ptr< vector<Coordinate> > nc ( new vector<Coordinate>(coords) );
- auto_ptr<CoordinateSequence> cs(csf.create(nc.release()));
+ unique_ptr< vector<Coordinate> > nc ( new vector<Coordinate>(coords) );
+ unique_ptr<CoordinateSequence> cs(csf.create(nc.release()));
- auto_ptr<MultiPoint> mp ( gf.createMultiPoint(*cs) );
+ unique_ptr<MultiPoint> mp ( gf.createMultiPoint(*cs) );
return mp;
@@ -153,7 +153,7 @@ void
OverlayResultValidator::addTestPts(const Geometry& g)
OffsetPointGenerator ptGen(g, 5 * boundaryDistanceTolerance);
- auto_ptr< vector<geom::Coordinate> > pts = ptGen.getPoints();
+ unique_ptr< vector<geom::Coordinate> > pts = ptGen.getPoints();
testCoords.insert(testCoords.end(), pts->begin(), pts->end());
@@ -163,7 +163,7 @@ OverlayResultValidator::addVertices(const Geometry& g)
// TODO: optimize this by not copying coordinates
// and pre-allocating memory
- auto_ptr<CoordinateSequence> cs ( g.getCoordinates() );
+ unique_ptr<CoordinateSequence> cs ( g.getCoordinates() );
const vector<Coordinate>* coords = cs->toVector();
testCoords.insert(testCoords.end(), coords->begin(), coords->end());
diff --git a/src/operation/relate/RelateComputer.cpp b/src/operation/relate/RelateComputer.cpp
index 996a90d..2144142 100644
--- a/src/operation/relate/RelateComputer.cpp
+++ b/src/operation/relate/RelateComputer.cpp
@@ -88,7 +88,7 @@ RelateComputer::computeIM()
<< std::endl;
#endif
- std::auto_ptr<SegmentIntersector> si1 (
+ std::unique_ptr<SegmentIntersector> si1 (
(*arg)[0]->computeSelfNodes(&li,false)
@@ -100,7 +100,7 @@ RelateComputer::computeIM()
<< std::endl;
#endif
- std::auto_ptr<SegmentIntersector> si2 (
+ std::unique_ptr<SegmentIntersector> si2 (
(*arg)[1]->computeSelfNodes(&li,false)
@@ -113,7 +113,7 @@ RelateComputer::computeIM()
#endif
// compute intersections between edges of the two input geometries
- std::auto_ptr< SegmentIntersector> intersector (
+ std::unique_ptr< SegmentIntersector> intersector (
(*arg)[0]->computeEdgeIntersections((*arg)[1], &li,false)
@@ -189,11 +189,11 @@ RelateComputer::computeIM()
// build EdgeEnds for all intersections
EdgeEndBuilder eeBuilder;
- std::auto_ptr< std::vector<EdgeEnd*> > ee0 (
+ std::unique_ptr< std::vector<EdgeEnd*> > ee0 (
eeBuilder.computeEdgeEnds((*arg)[0]->getEdges())
insertEdgeEnds(ee0.get());
- std::auto_ptr< std::vector<EdgeEnd*> > ee1 (
+ std::unique_ptr< std::vector<EdgeEnd*> > ee1 (
eeBuilder.computeEdgeEnds((*arg)[1]->getEdges())
diff --git a/src/operation/sharedpaths/SharedPathsOp.cpp b/src/operation/sharedpaths/SharedPathsOp.cpp
index 0a94387..62bfc37 100644
--- a/src/operation/sharedpaths/SharedPathsOp.cpp
+++ b/src/operation/sharedpaths/SharedPathsOp.cpp
@@ -108,7 +108,7 @@ SharedPathsOp::findLinearIntersections(PathList& to)
// TODO: optionally use the tolerance,
// snapping _g2 over _g1 ?
- std::auto_ptr<Geometry> full ( OverlayOp::overlayOp(
+ std::unique_ptr<Geometry> full ( OverlayOp::overlayOp(
&_g1, &_g2, OverlayOp::opINTERSECTION) );
// NOTE: intersection of equal lines yelds splitted lines,
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 95b53f3..04c2328 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -146,7 +146,7 @@ geom::Geometry* CascadedPolygonUnion::Union()
index.insert(g->getEnvelopeInternal(), g);
- std::auto_ptr<index::strtree::ItemsList> itemTree (index.itemsTree());
+ std::unique_ptr<index::strtree::ItemsList> itemTree (index.itemsTree());
return unionTree(itemTree.get());
@@ -158,7 +158,7 @@ geom::Geometry* CascadedPolygonUnion::unionTree(
* Recursively unions all subtrees in the list into single geometries.
* The result is a list of Geometry's only
- std::auto_ptr<GeometryListHolder> geoms(reduceToGeometries(geomTree));
+ std::unique_ptr<GeometryListHolder> geoms(reduceToGeometries(geomTree));
return binaryUnion(geoms.get());
@@ -179,8 +179,8 @@ geom::Geometry* CascadedPolygonUnion::binaryUnion(GeometryListHolder* geoms,
else {
// recurse on both halves of the list
std::size_t mid = (end + start) / 2;
- std::auto_ptr<geom::Geometry> g0 (binaryUnion(geoms, start, mid));
- std::auto_ptr<geom::Geometry> g1 (binaryUnion(geoms, mid, end));
+ std::unique_ptr<geom::Geometry> g0 (binaryUnion(geoms, start, mid));
+ std::unique_ptr<geom::Geometry> g1 (binaryUnion(geoms, mid, end));
return unionSafe(g0.get(), g1.get());
@@ -188,13 +188,13 @@ geom::Geometry* CascadedPolygonUnion::binaryUnion(GeometryListHolder* geoms,
GeometryListHolder*
CascadedPolygonUnion::reduceToGeometries(index::strtree::ItemsList* geomTree)
- std::auto_ptr<GeometryListHolder> geoms (new GeometryListHolder());
+ std::unique_ptr<GeometryListHolder> geoms (new GeometryListHolder());
typedef index::strtree::ItemsList::iterator iterator_type;
iterator_type end = geomTree->end();
for (iterator_type i = geomTree->begin(); i != end; ++i) {
if ((*i).get_type() == index::strtree::ItemsListItem::item_is_list) {
- std::auto_ptr<geom::Geometry> geom (unionTree((*i).get_itemslist()));
+ std::unique_ptr<geom::Geometry> geom (unionTree((*i).get_itemslist()));
geoms->push_back_owned(geom.get());
geom.release();
@@ -252,15 +252,15 @@ CascadedPolygonUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
check_valid(*g1, "unionUsingEnvelopeIntersection g1");
#endif
- std::auto_ptr<geom::Geometry> g0Int(extractByEnvelope(common, g0, disjointPolys));
- std::auto_ptr<geom::Geometry> g1Int(extractByEnvelope(common, g1, disjointPolys));
+ std::unique_ptr<geom::Geometry> g0Int(extractByEnvelope(common, g0, disjointPolys));
+ std::unique_ptr<geom::Geometry> g1Int(extractByEnvelope(common, g1, disjointPolys));
#if GEOS_DEBUG_CASCADED_UNION
check_valid(*g0Int, "unionUsingEnvelopeIntersection g0Int");
check_valid(*g1Int, "unionUsingEnvelopeIntersection g1Int");
#endif
- std::auto_ptr<geom::Geometry> u(unionActual(g0Int.get(), g1Int.get()));
+ std::unique_ptr<geom::Geometry> u(unionActual(g0Int.get(), g1Int.get()));
if ( ! check_valid(*u, "unionUsingEnvelopeIntersection unionActual return") )
@@ -300,7 +300,7 @@ CascadedPolygonUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
std::cerr << "unionUsingEnvelopeIntersection: " << polysOn.size() << "/" << disjointPolys.size() << " polys intersect union of final thing" << std::endl;
#endif
- std::auto_ptr<geom::Geometry> ret;
+ std::unique_ptr<geom::Geometry> ret;
if ( polysOn.empty() ) {
disjointPolys.push_back(u.get());
ret.reset( geom::util::GeometryCombiner::combine(disjointPolys));
@@ -367,11 +367,11 @@ CascadedPolygonUnion::extractByEnvelope(geom::Envelope const& env,
geom::Geometry*
CascadedPolygonUnion::unionActual(geom::Geometry* g0, geom::Geometry* g1)
- return restrictToPolygons(std::auto_ptr<geom::Geometry>(g0->Union(g1))).release();
+ return restrictToPolygons(std::unique_ptr<geom::Geometry>(g0->Union(g1))).release();
-CascadedPolygonUnion::restrictToPolygons(std::auto_ptr<geom::Geometry> g)
+CascadedPolygonUnion::restrictToPolygons(std::unique_ptr<geom::Geometry> g)
using namespace geom;
using namespace std;
@@ -384,7 +384,7 @@ CascadedPolygonUnion::restrictToPolygons(std::auto_ptr<geom::Geometry> g)
geom::util::PolygonExtracter::getPolygons(*g, polygons);
if (polygons.size() == 1)
- return std::auto_ptr<Geometry>(polygons[0]->clone());
+ return std::unique_ptr<Geometry>(polygons[0]->clone());
typedef vector<Geometry *> GeomVect;
@@ -393,7 +393,7 @@ CascadedPolygonUnion::restrictToPolygons(std::auto_ptr<geom::Geometry> g)
for (Polygon::ConstVect::size_type i=0; i<n; ++i) {
(*newpolys)[i] = polygons[i]->clone();
- return auto_ptr<Geometry>(
+ return unique_ptr<Geometry>(
g->getFactory()->createMultiPolygon(newpolys)
diff --git a/src/operation/union/CascadedUnion.cpp b/src/operation/union/CascadedUnion.cpp
index 825b830..e9b57f0 100644
--- a/src/operation/union/CascadedUnion.cpp
+++ b/src/operation/union/CascadedUnion.cpp
@@ -60,7 +60,7 @@ geom::Geometry* CascadedUnion::Union()
@@ -72,7 +72,7 @@ geom::Geometry* CascadedUnion::unionTree(
@@ -93,8 +93,8 @@ geom::Geometry* CascadedUnion::binaryUnion(GeometryListHolder* geoms,
else {
@@ -102,13 +102,13 @@ geom::Geometry* CascadedUnion::binaryUnion(GeometryListHolder* geoms,
GeometryListHolder*
CascadedUnion::reduceToGeometries(index::strtree::ItemsList* geomTree)
geom.release();
@@ -160,10 +160,10 @@ CascadedUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
std::vector<geom::Geometry*> disjointPolys;
return geom::util::GeometryCombiner::combine(disjointPolys);
diff --git a/src/operation/union/PointGeometryUnion.cpp b/src/operation/union/PointGeometryUnion.cpp
index a6f3a64..5bc7988 100644
--- a/src/operation/union/PointGeometryUnion.cpp
+++ b/src/operation/union/PointGeometryUnion.cpp
@@ -16,7 +16,7 @@
-#include <memory> // for auto_ptr
+#include <memory> // for unique_ptr
#include <cassert> // for assert
#include <algorithm> // for copy
#include <geos/operation/union/PointGeometryUnion.h>
@@ -35,7 +35,7 @@ namespace operation { // geos::operation
namespace geounion { // geos::operation::geounion
/* public */
PointGeometryUnion::Union() const
@@ -57,10 +57,10 @@ PointGeometryUnion::Union() const
// if no points are in exterior, return the other geom
if (exteriorCoords.empty())
- return std::auto_ptr<Geometry>(otherGeom.clone());
+ return std::unique_ptr<Geometry>(otherGeom.clone());
// make a puntal geometry of appropriate size
- std::auto_ptr<Geometry> ptComp;
+ std::unique_ptr<Geometry> ptComp;
if (exteriorCoords.size() == 1) {
ptComp.reset( geomFact->createPoint(*(exteriorCoords.begin())) );
@@ -73,13 +73,13 @@ PointGeometryUnion::Union() const
// add point component to the other geometry
- return std::auto_ptr<Geometry> (
+ return std::unique_ptr<Geometry> (
GeometryCombiner::combine(ptComp.get(), &otherGeom)
/* public static */
PointGeometryUnion::Union(const geom::Puntal& pointGeom,
const geom::Geometry& otherGeom)
diff --git a/src/operation/union/UnaryUnionOp.cpp b/src/operation/union/UnaryUnionOp.cpp
index 1d6093c..5a1cd6d 100644
--- a/src/operation/union/UnaryUnionOp.cpp
+++ b/src/operation/union/UnaryUnionOp.cpp
@@ -16,7 +16,7 @@
@@ -42,11 +42,11 @@ namespace operation { // geos::operation
/*private*/
-UnaryUnionOp::unionWithNull(std::auto_ptr<geom::Geometry> g0,
- std::auto_ptr<geom::Geometry> g1)
+UnaryUnionOp::unionWithNull(std::unique_ptr<geom::Geometry> g0,
+ std::unique_ptr<geom::Geometry> g1)
if ( ( ! g0.get() ) && ( ! g1.get() ) ) return ret;
if ( ! g0.get() ) return g1;
@@ -57,13 +57,13 @@ UnaryUnionOp::unionWithNull(std::auto_ptr<geom::Geometry> g0,
/*public*/
UnaryUnionOp::Union()
using geom::Puntal;
- typedef std::auto_ptr<geom::Geometry> GeomAutoPtr;
+ typedef std::unique_ptr<geom::Geometry> GeomPtr;
- GeomAutoPtr ret;
+ GeomPtr ret;
if ( ! geomFact ) return ret;
@@ -73,14 +73,14 @@ UnaryUnionOp::Union()
* This is not the case for polygons, so Cascaded Union is required.
- GeomAutoPtr unionPoints;
+ GeomPtr unionPoints;
if (!points.empty()) {
- GeomAutoPtr ptGeom = geomFact->buildGeometry( points.begin(),
+ GeomPtr ptGeom = geomFact->buildGeometry( points.begin(),
points.end() );
unionPoints = unionNoOpt(*ptGeom);
- GeomAutoPtr unionLines;
+ GeomPtr unionLines;
if (!lines.empty()) {
/* JTS compatibility NOTE:
* we use cascaded here for robustness [1]
@@ -96,7 +96,7 @@ UnaryUnionOp::Union()
unionLines = unionNoOpt(*unionLines);
- GeomAutoPtr unionPolygons;
+ GeomPtr unionPolygons;
if (!polygons.empty()) {
unionPolygons.reset( CascadedPolygonUnion::Union( polygons.begin(),
polygons.end() ) );
@@ -107,15 +107,15 @@ UnaryUnionOp::Union()
* but is mitigated by unioning lines and points first
- GeomAutoPtr unionLA = unionWithNull(unionLines, unionPolygons);
+ GeomPtr unionLA = unionWithNull(std::move(unionLines), std::move(unionPolygons));
assert(!unionLines.get()); assert(!unionPolygons.get());
if ( ! unionPoints.get() ) {
- ret = unionLA;
+ ret = std::move(unionLA);
assert(!unionLA.get());
else if ( ! unionLA.get() ) {
- ret = unionPoints;
+ ret = std::move(unionPoints);
assert(!unionPoints.get());
else {
diff --git a/src/operation/valid/ConsistentAreaTester.cpp b/src/operation/valid/ConsistentAreaTester.cpp
index 79ad036..451e5b9 100644
--- a/src/operation/valid/ConsistentAreaTester.cpp
+++ b/src/operation/valid/ConsistentAreaTester.cpp
@@ -29,7 +29,7 @@
#include <geos/operation/relate/RelateNode.h>
#include <geos/operation/relate/EdgeEndBundle.h>
#include <cassert>
@@ -69,7 +69,7 @@ ConsistentAreaTester::isNodeConsistentArea()
* To fully check validity, it is necessary to
* compute ALL intersections, including self-intersections within a single edge.
- auto_ptr<SegmentIntersector> intersector(geomGraph->computeSelfNodes(&li, true, true));
+ unique_ptr<SegmentIntersector> intersector(geomGraph->computeSelfNodes(&li, true, true));
* A proper intersection means that the area is not consistent.
diff --git a/src/operation/valid/IndexedNestedRingTester.h b/src/operation/valid/IndexedNestedRingTester.h
index 53e9012..eb6407b 100644
--- a/src/operation/valid/IndexedNestedRingTester.h
+++ b/src/operation/valid/IndexedNestedRingTester.h
@@ -91,7 +91,7 @@ private:
// CHECK: Owned by (seems unused)?
//geom::Envelope* totalEnv;
- // Owned by us (use auto_ptr ?)
+ // Owned by us (use unique_ptr ?)
geos::index::SpatialIndex* index; // 'index' in JTS
// Externally owned, if not null
diff --git a/src/precision/CommonBitsOp.cpp b/src/precision/CommonBitsOp.cpp
index 4ccc6c4..e8549c8 100644
--- a/src/precision/CommonBitsOp.cpp
+++ b/src/precision/CommonBitsOp.cpp
@@ -67,8 +67,8 @@ CommonBitsOp::intersection(
const Geometry* geom0,
const Geometry* geom1)
- auto_ptr<Geometry> rgeom0;
- auto_ptr<Geometry> rgeom1;
+ unique_ptr<Geometry> rgeom0;
+ unique_ptr<Geometry> rgeom1;
removeCommonBits(geom0, geom1, rgeom0, rgeom1);
return computeResultPrecision(rgeom0->intersection(rgeom1.get()));
@@ -79,8 +79,8 @@ CommonBitsOp::Union(
return computeResultPrecision(rgeom0->Union(rgeom1.get()));
@@ -91,8 +91,8 @@ CommonBitsOp::difference(
return computeResultPrecision(rgeom0->difference(rgeom1.get()));
@@ -103,8 +103,8 @@ CommonBitsOp::symDifference(
return computeResultPrecision(rgeom0->symDifference(rgeom1.get()));
@@ -113,7 +113,7 @@ CommonBitsOp::symDifference(
Geometry*
CommonBitsOp::buffer(const Geometry* geom0, double distance)
- auto_ptr<Geometry> rgeom0(removeCommonBits(geom0));
+ unique_ptr<Geometry> rgeom0(removeCommonBits(geom0));
return computeResultPrecision(rgeom0->buffer(distance));
@@ -148,8 +148,8 @@ void
CommonBitsOp::removeCommonBits(
const geom::Geometry* geom0,
const geom::Geometry* geom1,
- std::auto_ptr<geom::Geometry>& rgeom0,
- std::auto_ptr<geom::Geometry>& rgeom1)
+ std::unique_ptr<geom::Geometry>& rgeom0,
+ std::unique_ptr<geom::Geometry>& rgeom1)
cbr.reset(new CommonBitsRemover());
diff --git a/src/precision/EnhancedPrecisionOp.cpp b/src/precision/EnhancedPrecisionOp.cpp
index da7d7a3..abba62e 100644
--- a/src/precision/EnhancedPrecisionOp.cpp
+++ b/src/precision/EnhancedPrecisionOp.cpp
@@ -19,7 +19,7 @@
#include <geos/precision/EnhancedPrecisionOp.h>
#include <geos/precision/CommonBitsOp.h>
-#include <geos/precision/CommonBitsRemover.h> // for auto_ptr composition
+#include <geos/precision/CommonBitsRemover.h> // for unique_ptr composition
#include <geos/util/GEOSException.h>
diff --git a/src/precision/GeometryPrecisionReducer.cpp b/src/precision/GeometryPrecisionReducer.cpp
index 84eeabc..a5923ee 100644
--- a/src/precision/GeometryPrecisionReducer.cpp
+++ b/src/precision/GeometryPrecisionReducer.cpp
@@ -41,10 +41,10 @@ namespace precision { // geos.precision
/* private */
-auto_ptr<Geometry>
+unique_ptr<Geometry>
GeometryPrecisionReducer::reducePointwise(const Geometry &geom)
- auto_ptr<GeometryEditor> geomEdit;
+ unique_ptr<GeometryEditor> geomEdit;
if ( newFactory ) {
geomEdit.reset( new GeometryEditor(newFactory) );
@@ -62,16 +62,16 @@ GeometryPrecisionReducer::reducePointwise(const Geometry &geom)
PrecisionReducerCoordinateOperation prco(targetPM, finalRemoveCollapsed);
- std::auto_ptr<Geometry> g ( geomEdit->edit(&geom, &prco) );
+ std::unique_ptr<Geometry> g ( geomEdit->edit(&geom, &prco) );
return g;
/* public */
-auto_ptr<Geometry>
GeometryPrecisionReducer::reduce(const Geometry &geom)
- auto_ptr<Geometry> reducePW = reducePointwise(geom);
+ unique_ptr<Geometry> reducePW = reducePointwise(geom);
if ( isPointwise ) return reducePW;
@@ -99,15 +99,15 @@ GeometryPrecisionReducer::GeometryPrecisionReducer(const GeometryFactory &change
/* private */
-auto_ptr<Geometry>
GeometryPrecisionReducer::fixPolygonalTopology(const geom::Geometry& geom )
* If precision model was *not* changed, need to flip
* geometry to targetPM, buffer in that model, then flip back
- auto_ptr<Geometry> tmp;
- GeometryFactory::unique_ptr tmpFactory;
+ unique_ptr<Geometry> tmp;
+ GeometryFactory::Ptr tmpFactory;
const Geometry* geomToBuffer = &geom;
@@ -117,7 +117,7 @@ GeometryPrecisionReducer::fixPolygonalTopology(const geom::Geometry& geom )
geomToBuffer = tmp.get();
- auto_ptr<Geometry> bufGeom ( geomToBuffer->buffer(0) );
+ unique_ptr<Geometry> bufGeom ( geomToBuffer->buffer(0) );
if ( ! newFactory ) {
// a slick way to copy the geometry with the original precision factory
@@ -128,11 +128,11 @@ GeometryPrecisionReducer::fixPolygonalTopology(const geom::Geometry& geom )
/* private */
-GeometryFactory::unique_ptr
+GeometryFactory::Ptr
GeometryPrecisionReducer::createFactory( const GeometryFactory& oldGF,
const PrecisionModel& newPM )
- GeometryFactory::unique_ptr newFactory(
+ GeometryFactory::Ptr newFactory(
GeometryFactory::create(&newPM,
oldGF.getSRID(),
const_cast<CoordinateSequenceFactory*>(oldGF.getCoordinateSequenceFactory()))
diff --git a/src/precision/MinimumClearance.cpp b/src/precision/MinimumClearance.cpp
index 3799ee6..c30b3ac 100644
--- a/src/precision/MinimumClearance.cpp
+++ b/src/precision/MinimumClearance.cpp
@@ -39,14 +39,14 @@ double MinimumClearance::getDistance() {
return minClearance;
-std::auto_ptr<LineString> MinimumClearance::getLine() {
+std::unique_ptr<LineString> MinimumClearance::getLine() {
compute();
// return empty line string if no min pts were found
if (minClearance == std::numeric_limits<double>::infinity())
- return std::auto_ptr<LineString>(inputGeom->getFactory()->createLineString());
+ return std::unique_ptr<LineString>(inputGeom->getFactory()->createLineString());
- return std::auto_ptr<LineString>(inputGeom->getFactory()->createLineString(minClearancePts->clone()));
+ return std::unique_ptr<LineString>(inputGeom->getFactory()->createLineString(minClearancePts->clone()));
void MinimumClearance::compute() {
@@ -165,7 +165,7 @@ void MinimumClearance::compute() {
return;
// initialize to "No Distance Exists" state
- minClearancePts = std::auto_ptr<CoordinateSequence>(inputGeom->getFactory()->getCoordinateSequenceFactory()->create(2, 2));
+ minClearancePts = std::unique_ptr<CoordinateSequence>(inputGeom->getFactory()->getCoordinateSequenceFactory()->create(2, 2));
minClearance = std::numeric_limits<double>::infinity();
// handle empty geometries
diff --git a/src/simplify/DouglasPeuckerLineSimplifier.cpp b/src/simplify/DouglasPeuckerLineSimplifier.cpp
index ad85b7d..d10c022 100644
--- a/src/simplify/DouglasPeuckerLineSimplifier.cpp
+++ b/src/simplify/DouglasPeuckerLineSimplifier.cpp
@@ -21,7 +21,7 @@
#include <geos/geom/LineSegment.h>
#include <vector>
namespace geos {
@@ -75,7 +75,7 @@ DouglasPeuckerLineSimplifier::simplify()
- // auto_ptr transfer ownership to its
+ // unique_ptr transfer ownership to its
// returned copy
return coordList;
diff --git a/src/simplify/DouglasPeuckerSimplifier.cpp b/src/simplify/DouglasPeuckerSimplifier.cpp
index 0657645..239b71b 100644
--- a/src/simplify/DouglasPeuckerSimplifier.cpp
+++ b/src/simplify/DouglasPeuckerSimplifier.cpp
@@ -18,16 +18,16 @@
#include <geos/simplify/DouglasPeuckerSimplifier.h>
#include <geos/simplify/DouglasPeuckerLineSimplifier.h>
-#include <geos/geom/Geometry.h> // for AutoPtr typedefs
+#include <geos/geom/Geometry.h> // for Ptr typedefs
#include <geos/geom/MultiPolygon.h>
-#include <geos/geom/CoordinateSequence.h> // for AutoPtr typedefs
+#include <geos/geom/CoordinateSequence.h> // for Ptr typedefs
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/CoordinateSequenceFactory.h>
#include <geos/geom/util/GeometryTransformer.h> // for DPTransformer inheritance
#include <geos/util/IllegalArgumentException.h>
#include <cassert>
#ifndef GEOS_DEBUG
@@ -51,15 +51,15 @@ public:
protected:
const Geometry* parent);
- Geometry::AutoPtr transformPolygon(
+ Geometry::Ptr transformPolygon(
const Polygon* geom,
- Geometry::AutoPtr transformMultiPolygon(
+ Geometry::Ptr transformMultiPolygon(
const MultiPolygon* geom,
@@ -79,7 +79,7 @@ private:
* self-intersections
* @return a valid area geometry
- Geometry::AutoPtr createValidArea(const Geometry* roughAreaGeom);
+ Geometry::Ptr createValidArea(const Geometry* roughAreaGeom);
double distanceTolerance;
@@ -92,13 +92,13 @@ DPTransformer::DPTransformer(double t)
setSkipTransformedInvalidInteriorRings(true);
-Geometry::AutoPtr
+Geometry::Ptr
DPTransformer::createValidArea(const Geometry* roughAreaGeom)
- return Geometry::AutoPtr(roughAreaGeom->buffer(0.0));
+ return Geometry::Ptr(roughAreaGeom->buffer(0.0));
-CoordinateSequence::AutoPtr
+CoordinateSequence::Ptr
DPTransformer::transformCoordinates(
@@ -108,17 +108,17 @@ DPTransformer::transformCoordinates(
const Coordinate::Vect* inputPts = coords->toVector();
assert(inputPts);
- std::auto_ptr<Coordinate::Vect> newPts =
+ std::unique_ptr<Coordinate::Vect> newPts =
DouglasPeuckerLineSimplifier::simplify(*inputPts,
distanceTolerance);
- return CoordinateSequence::AutoPtr(
+ return CoordinateSequence::Ptr(
factory->getCoordinateSequenceFactory()->create(
newPts.release()
-Geometry::AutoPtr
+Geometry::Ptr
DPTransformer::transformPolygon(
@@ -128,7 +128,7 @@ DPTransformer::transformPolygon(
std::cerr << "DPTransformer::transformPolygon(Polygon " << geom << ", Geometry " << parent << ");" << std::endl;
#endif
- Geometry::AutoPtr roughGeom(GeometryTransformer::transformPolygon(geom, parent));
+ Geometry::Ptr roughGeom(GeometryTransformer::transformPolygon(geom, parent));
// don't try and correct if the parent is going to do this
if ( dynamic_cast<const MultiPolygon*>(parent) )
@@ -139,7 +139,7 @@ DPTransformer::transformPolygon(
return createValidArea(roughGeom.get());
-Geometry::AutoPtr
+Geometry::Ptr
DPTransformer::transformMultiPolygon(
@@ -147,7 +147,7 @@ DPTransformer::transformMultiPolygon(
#if GEOS_DEBUG
std::cerr << "DPTransformer::transformMultiPolygon(MultiPolygon " << geom << ", Geometry " << parent << ");" << std::endl;
#endif
- Geometry::AutoPtr roughGeom(GeometryTransformer::transformMultiPolygon(geom, parent));
+ Geometry::Ptr roughGeom(GeometryTransformer::transformMultiPolygon(geom, parent));
@@ -158,7 +158,7 @@ DPTransformer::transformMultiPolygon(
//DouglasPeuckerSimplifier::
/*public static*/
-Geometry::AutoPtr
+Geometry::Ptr
DouglasPeuckerSimplifier::simplify(const Geometry* geom,
double tolerance)
@@ -183,7 +183,7 @@ DouglasPeuckerSimplifier::setDistanceTolerance(double tol)
distanceTolerance = tol;
-Geometry::AutoPtr
+Geometry::Ptr
DouglasPeuckerSimplifier::getResultGeometry()
DPTransformer t(distanceTolerance);
diff --git a/src/simplify/LineSegmentIndex.cpp b/src/simplify/LineSegmentIndex.cpp
index 33184e1..9173d49 100644
--- a/src/simplify/LineSegmentIndex.cpp
+++ b/src/simplify/LineSegmentIndex.cpp
@@ -25,7 +25,7 @@
#include <geos/geom/Envelope.h>
#include <vector>
#include <cassert>
#ifndef GEOS_DEBUG
@@ -54,7 +54,7 @@ private:
const LineSegment* querySeg;
- auto_ptr< vector<LineSegment*> > items;
+ unique_ptr< vector<LineSegment*> > items;
public:
@@ -96,9 +96,10 @@ public:
- auto_ptr< vector<LineSegment*> > getItems()
+ unique_ptr< vector<LineSegment*> > getItems()
- return items;
+ return std::move(items);
@@ -156,7 +157,7 @@ LineSegmentIndex::remove(const LineSegment* seg)
/*public*/
-auto_ptr< vector<LineSegment*> >
+unique_ptr< vector<LineSegment*> >
LineSegmentIndex::query(const LineSegment* querySeg) const
Envelope env(querySeg->p0, querySeg->p1);
@@ -164,7 +165,7 @@ LineSegmentIndex::query(const LineSegment* querySeg) const
LineSegmentVisitor visitor(querySeg);
index->query(&env, visitor);
- auto_ptr< vector<LineSegment*> > itemsFound = visitor.getItems();
+ unique_ptr< vector<LineSegment*> > itemsFound = visitor.getItems();
return itemsFound;
diff --git a/src/simplify/TaggedLineString.cpp b/src/simplify/TaggedLineString.cpp
index e39eb37..91f5d31 100644
--- a/src/simplify/TaggedLineString.cpp
+++ b/src/simplify/TaggedLineString.cpp
@@ -20,7 +20,7 @@
#include <geos/simplify/TaggedLineSegment.h>
#include <geos/geom/LineString.h>
-#include <geos/geom/Geometry.h> // for auto_ptr destructor
+#include <geos/geom/Geometry.h> // for unique_ptr destructor
@@ -126,7 +126,7 @@ TaggedLineString::getParentCoordinates() const
/*public*/
TaggedLineString::getResultCoordinates() const
@@ -144,7 +144,7 @@ TaggedLineString::getResultCoordinates() const
CoordVect* v = pts.release();
- return CoordinateSequence::AutoPtr(parentLine->getFactory()->getCoordinateSequenceFactory()->create(v));
+ return CoordinateSequence::Ptr(parentLine->getFactory()->getCoordinateSequenceFactory()->create(v));
@@ -214,7 +214,7 @@ TaggedLineString::getSegments() const
/*public*/
-auto_ptr<Geometry>
TaggedLineString::asLineString() const
return parentLine->getFactory()->createLineString(
@@ -222,7 +222,7 @@ TaggedLineString::asLineString() const
/*public*/
-auto_ptr<Geometry>
TaggedLineString::asLinearRing() const
return parentLine->getFactory()->createLinearRing(
@@ -231,7 +231,7 @@ TaggedLineString::asLinearRing() const
/*public*/
void
-TaggedLineString::addToResult(auto_ptr<TaggedLineSegment> seg)
+TaggedLineString::addToResult(unique_ptr<TaggedLineSegment> seg)
#if GEOS_DEBUG
cerr << "TaggedLineString[" << this << "] adding "
diff --git a/src/simplify/TaggedLineStringSimplifier.cpp b/src/simplify/TaggedLineStringSimplifier.cpp
index 507c79f..ceaa50e 100644
--- a/src/simplify/TaggedLineStringSimplifier.cpp
+++ b/src/simplify/TaggedLineStringSimplifier.cpp
@@ -23,7 +23,7 @@
-//#include <geos/geom/Geometry.h> // for auto_ptr destructor
+//#include <geos/geom/Geometry.h> // for unique_ptr destructor
//#include <geos/geom/GeometryFactory.h>
//#include <geos/geom/CoordinateSequenceFactory.h>
@@ -103,11 +103,10 @@ TaggedLineStringSimplifier::simplifySection(std::size_t i,
std::cerr << "single segment, no flattening"
<< std::endl;
#endif
- auto_ptr<TaggedLineSegment> newSeg(new
+ unique_ptr<TaggedLineSegment> newSeg(new
TaggedLineSegment(*(line->getSegment(i))));
- line->addToResult(newSeg);
+ line->addToResult(std::move(newSeg));
// leave this segment in the input index, for efficiency
return;
@@ -155,7 +154,7 @@ TaggedLineStringSimplifier::simplifySection(std::size_t i,
if (isValidToSimplify)
- auto_ptr<TaggedLineSegment> newSeg = flatten(i, j);
+ unique_ptr<TaggedLineSegment> newSeg = flatten(i, j);
#if GEOS_DEBUG
std::cerr << "isValidToSimplify, adding seg "
@@ -164,7 +163,7 @@ TaggedLineStringSimplifier::simplifySection(std::size_t i,
<< std::endl;
#endif
return;
@@ -175,13 +174,13 @@ TaggedLineStringSimplifier::simplifySection(std::size_t i,
/*private*/
-auto_ptr<TaggedLineSegment>
+unique_ptr<TaggedLineSegment>
TaggedLineStringSimplifier::flatten(std::size_t start, std::size_t end)
// make a new segment for the simplified geometry
const Coordinate& p0 = linePts->getAt(start);
const Coordinate& p1 = linePts->getAt(end);
- auto_ptr<TaggedLineSegment> newSeg(new TaggedLineSegment(p0, p1));
+ unique_ptr<TaggedLineSegment> newSeg(new TaggedLineSegment(p0, p1));
// update the indexes
remove(line, start, end);
outputIndex->add(newSeg.get());
@@ -209,7 +208,7 @@ bool
TaggedLineStringSimplifier::hasBadOutputIntersection(
const LineSegment& candidateSeg)
- auto_ptr< vector<LineSegment*> > querySegs =
+ unique_ptr< vector<LineSegment*> > querySegs =
outputIndex->query(&candidateSeg);
for (vector<LineSegment*>::iterator
@@ -245,7 +244,7 @@ TaggedLineStringSimplifier::hasBadInputIntersection(
const vector<std::size_t>& sectionIndex,
inputIndex->query(&candidateSeg);
diff --git a/src/simplify/TopologyPreservingSimplifier.cpp b/src/simplify/TopologyPreservingSimplifier.cpp
index a669209..689c5e5 100644
--- a/src/simplify/TopologyPreservingSimplifier.cpp
+++ b/src/simplify/TopologyPreservingSimplifier.cpp
@@ -18,20 +18,20 @@
#include <geos/simplify/TopologyPreservingSimplifier.h>
#include <geos/simplify/TaggedLinesSimplifier.h>
-#include <geos/simplify/LineSegmentIndex.h> // for auto_ptr dtor
+#include <geos/simplify/LineSegmentIndex.h> // for unique_ptr dtor
#include <geos/simplify/TaggedLineString.h>
-#include <geos/simplify/TaggedLineStringSimplifier.h> // for auto_ptr dtor
-#include <geos/algorithm/LineIntersector.h> // for auto_ptr dtor
+#include <geos/simplify/TaggedLineStringSimplifier.h> // for unique_ptr dtor
+#include <geos/algorithm/LineIntersector.h> // for unique_ptr dtor
// for LineStringTransformer inheritance
// for LineStringMapBuilderFilter inheritance
#include <geos/geom/GeometryComponentFilter.h>
-#include <geos/geom/Geometry.h> // for auto_ptr dtor
+#include <geos/geom/Geometry.h> // for unique_ptr dtor
#include <geos/geom/LinearRing.h>
#include <map>
#include <cassert>
#include <iostream>
@@ -67,7 +67,7 @@ public:
protected:
@@ -142,7 +142,7 @@ LineStringTransformer::LineStringTransformer(LinesMap& nMap)
/*protected*/
LineStringTransformer::transformCoordinates(
@@ -187,10 +187,7 @@ LineStringTransformer::transformCoordinates(
* This class populates the given LineString=>TaggedLineString map
* with newly created TaggedLineString objects.
* Users must take care of deleting the map's values (elem.second).
- * Would be nice if auto_ptr<> worked in a container, but it doesn't :(
- * mloskot: So, let's write our own "shared smart pointer" or better ask
- * PCS about using Boost's shared_ptr.
+ * TODO: Consider container of unique_ptr
class LineStringMapBuilderFilter: public geom::GeometryComponentFilter
@@ -263,7 +260,7 @@ LineStringMapBuilderFilter::filter_ro(const Geometry* geom)
} // end of module-statics
/*public static*/
TopologyPreservingSimplifier::simplify(
const geom::Geometry* geom,
double tolerance)
@@ -295,16 +292,16 @@ TopologyPreservingSimplifier::setDistanceTolerance(double d)
/*public*/
TopologyPreservingSimplifier::getResultGeometry()
// empty input produces an empty result
- if (inputGeom->isEmpty()) return std::auto_ptr<Geometry>(inputGeom->clone());
+ if (inputGeom->isEmpty()) return std::unique_ptr<Geometry>(inputGeom->clone());
LinesMap linestringMap;
- std::auto_ptr<geom::Geometry> result;
+ std::unique_ptr<geom::Geometry> result;
try {
LineStringMapBuilderFilter lsmbf(linestringMap);
diff --git a/src/triangulate/DelaunayTriangulationBuilder.cpp b/src/triangulate/DelaunayTriangulationBuilder.cpp
index 35291df..fff47be 100644
--- a/src/triangulate/DelaunayTriangulationBuilder.cpp
+++ b/src/triangulate/DelaunayTriangulationBuilder.cpp
@@ -118,7 +118,7 @@ DelaunayTriangulationBuilder::getSubdivision()
return *subdiv;
-std::auto_ptr<MultiLineString>
+std::unique_ptr<MultiLineString>
DelaunayTriangulationBuilder::getEdges(
const GeometryFactory& geomFact)
@@ -126,7 +126,7 @@ DelaunayTriangulationBuilder::getEdges(
return subdiv->getEdges(geomFact);
-std::auto_ptr<geom::GeometryCollection>
+std::unique_ptr<geom::GeometryCollection>
DelaunayTriangulationBuilder::getTriangles(
const geom::GeometryFactory& geomFact)
diff --git a/src/triangulate/VoronoiDiagramBuilder.cpp b/src/triangulate/VoronoiDiagramBuilder.cpp
index 8cfbb4e..b9ea42b 100644
--- a/src/triangulate/VoronoiDiagramBuilder.cpp
+++ b/src/triangulate/VoronoiDiagramBuilder.cpp
@@ -83,7 +83,7 @@ VoronoiDiagramBuilder::create()
if(clipEnv)
diagramEnv.expandToInclude(clipEnv);
- std::auto_ptr<IncrementalDelaunayTriangulator::VertexList> vertices (
+ std::unique_ptr<IncrementalDelaunayTriangulator::VertexList> vertices (
DelaunayTriangulationBuilder::toVertices(*siteCoords)
@@ -92,41 +92,42 @@ VoronoiDiagramBuilder::create()
triangulator.insertSites(*vertices);
-std::auto_ptr<quadedge::QuadEdgeSubdivision>
+std::unique_ptr<quadedge::QuadEdgeSubdivision>
VoronoiDiagramBuilder::getSubdivision()
create();
- return subdiv;
+ return std::move(subdiv);
VoronoiDiagramBuilder::getDiagram(const geom::GeometryFactory& geomFact)
create();
- std::auto_ptr<geom::GeometryCollection> polys = subdiv->getVoronoiDiagram(geomFact);
+ std::unique_ptr<geom::GeometryCollection> polys = subdiv->getVoronoiDiagram(geomFact);
return clipGeometryCollection(*polys,diagramEnv);
VoronoiDiagramBuilder::getDiagramEdges(const geom::GeometryFactory& geomFact)
create();
- std::auto_ptr<geom::MultiLineString> edges = subdiv->getVoronoiDiagramEdges(geomFact);
- if ( edges->isEmpty() ) return std::auto_ptr<Geometry>(edges.release());
- std::auto_ptr<geom::Geometry> clipPoly ( geomFact.toGeometry(&diagramEnv) );
- std::auto_ptr<Geometry> clipped( clipPoly->intersection(edges.get()) );
+ std::unique_ptr<geom::MultiLineString> edges = subdiv->getVoronoiDiagramEdges(geomFact);
+ if ( edges->isEmpty() ) return std::unique_ptr<Geometry>(edges.release());
+ std::unique_ptr<geom::Geometry> clipPoly ( geomFact.toGeometry(&diagramEnv) );
+ std::unique_ptr<Geometry> clipped( clipPoly->intersection(edges.get()) );
return clipped;
VoronoiDiagramBuilder::clipGeometryCollection(const geom::GeometryCollection& geom, const geom::Envelope& clipEnv)
- std::auto_ptr<geom::Geometry> clipPoly ( geom.getFactory()->toGeometry(&clipEnv) );
- std::auto_ptr< std::vector<Geometry*> >clipped(new std::vector<Geometry*>);
+ std::unique_ptr<geom::Geometry> clipPoly ( geom.getFactory()->toGeometry(&clipEnv) );
+ std::unique_ptr< std::vector<Geometry*> >clipped(new std::vector<Geometry*>);
for(std::size_t i=0 ; i < geom.getNumGeometries() ; i++)
const Geometry* g = geom.getGeometryN(i);
- std::auto_ptr<Geometry> result;
+ std::unique_ptr<Geometry> result;
// don't clip unless necessary
if(clipEnv.contains(g->getEnvelopeInternal()))
@@ -144,7 +145,7 @@ VoronoiDiagramBuilder::clipGeometryCollection(const geom::GeometryCollection& ge
clipped->push_back(result.release());
- return std::auto_ptr<GeometryCollection>(geom.getFactory()->createGeometryCollection(clipped.release()));
+ return std::unique_ptr<GeometryCollection>(geom.getFactory()->createGeometryCollection(clipped.release()));
} //namespace geos.triangulate
diff --git a/src/triangulate/quadedge/QuadEdge.cpp b/src/triangulate/quadedge/QuadEdge.cpp
index 4a4e63a..82929ff 100644
--- a/src/triangulate/quadedge/QuadEdge.cpp
+++ b/src/triangulate/quadedge/QuadEdge.cpp
@@ -24,7 +24,7 @@ namespace quadedge { //geos.triangulate.quadedge
using namespace geos::geom;
-std::auto_ptr<QuadEdge>
+std::unique_ptr<QuadEdge>
QuadEdge::makeEdge(const Vertex &o, const Vertex &d)
QuadEdge *q0 = new QuadEdge();
@@ -47,13 +47,13 @@ QuadEdge::makeEdge(const Vertex &o, const Vertex &d)
base->setOrig(o);
base->setDest(d);
- return std::auto_ptr<QuadEdge>(base);
+ return std::unique_ptr<QuadEdge>(base);
QuadEdge::connect(QuadEdge &a, QuadEdge &b)
- std::auto_ptr<QuadEdge> q0 = makeEdge(a.dest(), b.orig());
+ std::unique_ptr<QuadEdge> q0 = makeEdge(a.dest(), b.orig());
splice(*q0, a.lNext());
splice(q0->sym(), b);
return q0;
@@ -165,10 +165,10 @@ QuadEdge::equalsOriented(const QuadEdge &qe) const
return false;
-std::auto_ptr<LineSegment>
+std::unique_ptr<LineSegment>
QuadEdge::toLineSegment() const
- return std::auto_ptr<geom::LineSegment>(
+ return std::unique_ptr<geom::LineSegment>(
new geom::LineSegment(vertex.getCoordinate(), dest().getCoordinate()));
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index 8e58ee0..cd227b4 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -109,22 +109,22 @@ QuadEdgeSubdivision::createFrame(const geom::Envelope &env)
void
QuadEdgeSubdivision::initSubdiv(QuadEdge* initEdges[3])
- std::auto_ptr<QuadEdge> tmp_auto_ptr;
+ std::unique_ptr<QuadEdge> tmp_ptr;
// build initial subdivision from frame
- tmp_auto_ptr = QuadEdge::makeEdge(frameVertex[0], frameVertex[1]);
- initEdges[0] = tmp_auto_ptr.get();
- tmp_auto_ptr.release();
+ tmp_ptr = QuadEdge::makeEdge(frameVertex[0], frameVertex[1]);
+ initEdges[0] = tmp_ptr.get();
+ tmp_ptr.release();
- tmp_auto_ptr = QuadEdge::makeEdge(frameVertex[1], frameVertex[2]);
- initEdges[1] = tmp_auto_ptr.get();
+ tmp_ptr = QuadEdge::makeEdge(frameVertex[1], frameVertex[2]);
+ initEdges[1] = tmp_ptr.get();
QuadEdge::splice(initEdges[0]->sym(), *initEdges[1]);
- tmp_auto_ptr = QuadEdge::makeEdge(frameVertex[2], frameVertex[0]);
- initEdges[2] = tmp_auto_ptr.get();
+ tmp_ptr = QuadEdge::makeEdge(frameVertex[2], frameVertex[0]);
+ initEdges[2] = tmp_ptr.get();
QuadEdge::splice(initEdges[1]->sym(), *initEdges[2]);
QuadEdge::splice(initEdges[2]->sym(), *initEdges[0]);
@@ -133,7 +133,7 @@ QuadEdgeSubdivision::initSubdiv(QuadEdge* initEdges[3])
QuadEdge&
QuadEdgeSubdivision::makeEdge(const Vertex &o, const Vertex &d)
- std::auto_ptr<QuadEdge> q0 = QuadEdge::makeEdge(o, d);
+ std::unique_ptr<QuadEdge> q0 = QuadEdge::makeEdge(o, d);
QuadEdge *q0_ptr = q0.get();
q0.release();
@@ -145,7 +145,7 @@ QuadEdgeSubdivision::makeEdge(const Vertex &o, const Vertex &d)
QuadEdge&
QuadEdgeSubdivision::connect(QuadEdge &a, QuadEdge &b)
- std::auto_ptr<QuadEdge> q0 = QuadEdge::connect(a, b);
+ std::unique_ptr<QuadEdge> q0 = QuadEdge::connect(a, b);
q0.release();
@@ -310,7 +310,7 @@ QuadEdgeSubdivision::isVertexOfEdge(const QuadEdge &e, const Vertex &v) const
return false;
-std::auto_ptr<QuadEdgeSubdivision::QuadEdgeList>
+std::unique_ptr<QuadEdgeSubdivision::QuadEdgeList>
QuadEdgeSubdivision::getPrimaryEdges(bool includeFrame)
QuadEdgeList *edges = new QuadEdgeList();
@@ -337,7 +337,7 @@ QuadEdgeSubdivision::getPrimaryEdges(bool includeFrame)
visitedEdges.insert(&edge->sym());
- return std::auto_ptr<QuadEdgeList>(edges);
+ return std::unique_ptr<QuadEdgeList>(edges);
QuadEdge**
@@ -444,10 +444,10 @@ QuadEdgeSubdivision::visitTriangles(TriangleVisitor *triVisitor, bool includeFra
-std::auto_ptr<geom::MultiLineString>
+std::unique_ptr<geom::MultiLineString>
QuadEdgeSubdivision::getEdges(const geom::GeometryFactory& geomFact)
- std::auto_ptr<QuadEdgeList> quadEdges(getPrimaryEdges(false));
+ std::unique_ptr<QuadEdgeList> quadEdges(getPrimaryEdges(false));
std::vector<Geometry *> edges(quadEdges->size());
const CoordinateSequenceFactory *coordSeqFact = geomFact.getCoordinateSequenceFactory();
int i = 0;
@@ -469,10 +469,10 @@ QuadEdgeSubdivision::getEdges(const geom::GeometryFactory& geomFact)
for(std::vector<Geometry*>::iterator it=edges.begin(); it!=edges.end(); ++it)
delete *it;
- return std::auto_ptr<MultiLineString>(result);
+ return std::unique_ptr<MultiLineString>(result);
-std::auto_ptr<GeometryCollection>
+std::unique_ptr<GeometryCollection>
QuadEdgeSubdivision::getTriangles( const GeometryFactory &geomFact)
TriList triPtsList;
@@ -494,38 +494,38 @@ QuadEdgeSubdivision::getTriangles( const GeometryFactory &geomFact)
delete *it;
tris.clear();
- return std::auto_ptr<GeometryCollection>(ret);
+ return std::unique_ptr<GeometryCollection>(ret);
//Methods for VoronoiDiagram
QuadEdgeSubdivision::getVoronoiDiagram(const geom::GeometryFactory& geomFact)
- std::auto_ptr< std::vector<geom::Geometry*> > vorCells = getVoronoiCellPolygons(geomFact);
- return std::auto_ptr<GeometryCollection>(geomFact.createGeometryCollection(vorCells.release()));
+ std::unique_ptr< std::vector<geom::Geometry*> > vorCells = getVoronoiCellPolygons(geomFact);
+ return std::unique_ptr<GeometryCollection>(geomFact.createGeometryCollection(vorCells.release()));
QuadEdgeSubdivision::getVoronoiDiagramEdges(const geom::GeometryFactory& geomFact)
- std::auto_ptr< std::vector<geom::Geometry*> > vorCells = getVoronoiCellEdges(geomFact);
- return std::auto_ptr<MultiLineString>(geomFact.createMultiLineString(vorCells.release()));
+ std::unique_ptr< std::vector<geom::Geometry*> > vorCells = getVoronoiCellEdges(geomFact);
+ return std::unique_ptr<MultiLineString>(geomFact.createMultiLineString(vorCells.release()));
-std::auto_ptr< std::vector<geom::Geometry*> >
+std::unique_ptr< std::vector<geom::Geometry*> >
QuadEdgeSubdivision::getVoronoiCellPolygons(const geom::GeometryFactory& geomFact)
- std::auto_ptr< std::vector<geom::Geometry*> > cells(new std::vector<geom::Geometry*>);
+ std::unique_ptr< std::vector<geom::Geometry*> > cells(new std::vector<geom::Geometry*>);
TriangleCircumcentreVisitor* tricircumVisitor = new TriangleCircumcentreVisitor();
visitTriangles((TriangleVisitor*)tricircumVisitor, true);
- std::auto_ptr<QuadEdgeSubdivision::QuadEdgeList> edges = getVertexUniqueEdges(false);
+ std::unique_ptr<QuadEdgeSubdivision::QuadEdgeList> edges = getVertexUniqueEdges(false);
for(QuadEdgeSubdivision::QuadEdgeList::iterator it=edges->begin() ; it!=edges->end() ; ++it)
QuadEdge *qe = *it;
- std::auto_ptr<geom::Geometry> poly = getVoronoiCellPolygon(qe,geomFact);
+ std::unique_ptr<geom::Geometry> poly = getVoronoiCellPolygon(qe,geomFact);
cells->push_back(poly.release());
@@ -533,19 +533,19 @@ QuadEdgeSubdivision::getVoronoiCellPolygons(const geom::GeometryFactory& geomFac
return cells;
QuadEdgeSubdivision::getVoronoiCellEdges(const geom::GeometryFactory& geomFact)
QuadEdge *qe = *it;
- std::auto_ptr<geom::Geometry> poly = getVoronoiCellEdge(qe,geomFact);
+ std::unique_ptr<geom::Geometry> poly = getVoronoiCellEdge(qe,geomFact);
@@ -553,7 +553,7 @@ QuadEdgeSubdivision::getVoronoiCellEdges(const geom::GeometryFactory& geomFact)
return cells;
-std::auto_ptr<geom::Geometry>
+std::unique_ptr<geom::Geometry>
QuadEdgeSubdivision::getVoronoiCellPolygon(QuadEdge* qe ,const geom::GeometryFactory& geomFact)
std::vector<Coordinate> cellPts;
@@ -577,8 +577,8 @@ QuadEdgeSubdivision::getVoronoiCellPolygon(QuadEdge* qe ,const geom::GeometryFac
coordList.insert(coordList.end(),*(coordList.end()),true);
- std::auto_ptr<Coordinate::Vect> pts = coordList.toCoordinateArray();
- std::auto_ptr<geom::Geometry> cellPoly(
+ std::unique_ptr<Coordinate::Vect> pts = coordList.toCoordinateArray();
+ std::unique_ptr<geom::Geometry> cellPoly(
geomFact.createPolygon(geomFact.createLinearRing(new geom::CoordinateArraySequence(pts.release())),NULL));
Vertex v = startQE->orig();
@@ -588,7 +588,7 @@ QuadEdgeSubdivision::getVoronoiCellPolygon(QuadEdge* qe ,const geom::GeometryFac
return cellPoly;
QuadEdgeSubdivision::getVoronoiCellEdge(QuadEdge* qe ,const geom::GeometryFactory& geomFact)
@@ -607,8 +607,8 @@ QuadEdgeSubdivision::getVoronoiCellEdge(QuadEdge* qe ,const geom::GeometryFactor
//for checking close ring in CoordList class:
coordList.closeRing();
- std::auto_ptr<geom::Geometry> cellEdge(
+ std::unique_ptr<geom::Geometry> cellEdge(
geomFact.createLineString(new geom::CoordinateArraySequence(pts.release())));
@@ -618,10 +618,10 @@ QuadEdgeSubdivision::getVoronoiCellEdge(QuadEdge* qe ,const geom::GeometryFactor
return cellEdge;
QuadEdgeSubdivision::getVertexUniqueEdges(bool includeFrame)
- std::auto_ptr<QuadEdgeSubdivision::QuadEdgeList> edges(new QuadEdgeList());
+ std::unique_ptr<QuadEdgeSubdivision::QuadEdgeList> edges(new QuadEdgeList());
std::set<Vertex> visitedVertices;
for(QuadEdgeSubdivision::QuadEdgeList::iterator it=quadEdges.begin() ; it!=quadEdges.end() ; ++it)
diff --git a/src/triangulate/quadedge/Vertex.cpp b/src/triangulate/quadedge/Vertex.cpp
index c286e60..04287f7 100644
--- a/src/triangulate/quadedge/Vertex.cpp
+++ b/src/triangulate/quadedge/Vertex.cpp
@@ -48,8 +48,8 @@ Vertex::Vertex() : p() {
int Vertex::classify(const Vertex &p0, const Vertex &p1)
Vertex &p2 = *this;
- std::auto_ptr<Vertex> a = p1.sub(p0);
- std::auto_ptr<Vertex> b = p2.sub(p0);
+ std::unique_ptr<Vertex> a = p1.sub(p0);
+ std::unique_ptr<Vertex> b = p2.sub(p0);
double sa = a->crossProduct(*b);
if (sa > 0.0)
@@ -83,7 +83,7 @@ bool Vertex::leftOf(const QuadEdge &e) const {
return isCCW(e.orig(), e.dest());
-std::auto_ptr<HCoordinate> Vertex::bisector(const Vertex &a, const Vertex &b)
+std::unique_ptr<HCoordinate> Vertex::bisector(const Vertex &a, const Vertex &b)
// returns the perpendicular bisector of the line segment ab
double dx = b.getX() - a.getX();
@@ -91,12 +91,12 @@ std::auto_ptr<HCoordinate> Vertex::bisector(const Vertex &a, const Vertex &b)
HCoordinate l1 = HCoordinate(a.getX() + dx / 2.0, a.getY() + dy / 2.0, 1.0);
HCoordinate l2 = HCoordinate(a.getX() - dy + dx / 2.0, a.getY() + dx + dy / 2.0, 1.0);
- return std::auto_ptr<HCoordinate>(new HCoordinate(l1, l2));
+ return std::unique_ptr<HCoordinate>(new HCoordinate(l1, l2));
double Vertex::circumRadiusRatio(const Vertex &b, const Vertex &c)
- std::auto_ptr<Vertex> x(circleCenter(b, c));
+ std::unique_ptr<Vertex> x(circleCenter(b, c));
double radius = distance(*x, b);
double edgeLength = distance(*this, b);
double el = distance(b, c);
@@ -113,24 +113,24 @@ double Vertex::circumRadiusRatio(const Vertex &b, const Vertex &c)
return radius / edgeLength;
-std::auto_ptr<Vertex> Vertex::midPoint(const Vertex &a)
+std::unique_ptr<Vertex> Vertex::midPoint(const Vertex &a)
double xm = (p.x + a.getX()) / 2.0;
double ym = (p.y + a.getY()) / 2.0;
double zm = (p.z + a.getZ()) / 2.0;
- return std::auto_ptr<Vertex>(new Vertex(xm, ym, zm));
+ return std::unique_ptr<Vertex>(new Vertex(xm, ym, zm));
-std::auto_ptr<Vertex> Vertex::circleCenter(const Vertex &b, const Vertex &c) const
+std::unique_ptr<Vertex> Vertex::circleCenter(const Vertex &b, const Vertex &c) const
- std::auto_ptr<Vertex> a(new Vertex(getX(), getY()));
+ std::unique_ptr<Vertex> a(new Vertex(getX(), getY()));
// compute the perpendicular bisector of cord ab
- std::auto_ptr<HCoordinate> cab = bisector(*a, b);
+ std::unique_ptr<HCoordinate> cab = bisector(*a, b);
// compute the perpendicular bisector of cord bc
- std::auto_ptr<HCoordinate> cbc = bisector(b, c);
+ std::unique_ptr<HCoordinate> cbc = bisector(b, c);
// compute the intersection of the bisectors (circle radii)
- std::auto_ptr<HCoordinate> hcc(new HCoordinate(*cab, *cbc));
- std::auto_ptr<Vertex> cc;
+ std::unique_ptr<HCoordinate> hcc(new HCoordinate(*cab, *cbc));
+ std::unique_ptr<Vertex> cc;
try
diff --git a/src/util/GeometricShapeFactory.cpp b/src/util/GeometricShapeFactory.cpp
index 26f317c..5d1e67c 100644
--- a/src/util/GeometricShapeFactory.cpp
+++ b/src/util/GeometricShapeFactory.cpp
@@ -89,7 +89,7 @@ GeometricShapeFactory::createRectangle()
int ipt = 0;
int nSide = nPts / 4;
if (nSide < 1) nSide = 1;
- std::auto_ptr<Envelope> env ( dim.getEnvelope() );
+ std::unique_ptr<Envelope> env ( dim.getEnvelope() );
double XsegLen = env->getWidth() / nSide;
double YsegLen = env->getHeight() / nSide;
@@ -126,7 +126,7 @@ GeometricShapeFactory::createRectangle()
Polygon*
GeometricShapeFactory::createCircle()
double xRadius = env->getWidth() / 2.0;
double yRadius = env->getHeight() / 2.0;
@@ -152,7 +152,7 @@ GeometricShapeFactory::createCircle()
LineString*
GeometricShapeFactory::createArc(double startAng, double angExtent)
@@ -181,7 +181,7 @@ GeometricShapeFactory::createArc(double startAng, double angExtent)
Polygon*
GeometricShapeFactory::createArcPolygon(double startAng, double angExtent)
diff --git a/tests/bigtest/TestSweepLineSpeed.cpp b/tests/bigtest/TestSweepLineSpeed.cpp
index 110d7ad..f4b02f0 100644
--- a/tests/bigtest/TestSweepLineSpeed.cpp
+++ b/tests/bigtest/TestSweepLineSpeed.cpp
@@ -53,7 +53,7 @@ void run(int nPts, GeometryFactory *fact) {
int main(int /* argc */, char** /* argv[] */) {
- GeometryFactory::unique_ptr factptr = GeometryFactory::create();
+ GeometryFactory::Ptr factptr = GeometryFactory::create();
GeometryFactory* fact = factptr.get();
run(1000,fact);
diff --git a/tests/bigtest/bug234.cpp b/tests/bigtest/bug234.cpp
index 4a7cfa3..6a2d0b1 100644
--- a/tests/bigtest/bug234.cpp
+++ b/tests/bigtest/bug234.cpp
@@ -12,7 +12,7 @@ using namespace geos::geom;
int main() {
- GeometryFactory::unique_ptr factory = GeometryFactory::create();
+ GeometryFactory::Ptr factory = GeometryFactory::create();
vector< Geometry * > *polys1 = new vector<Geometry*>();
vector< Geometry * > *polys2 = new vector<Geometry*>();
diff --git a/tests/perf/operation/buffer/IteratedBufferStressTest.cpp b/tests/perf/operation/buffer/IteratedBufferStressTest.cpp
index ccb8b9f..e661e23 100644
--- a/tests/perf/operation/buffer/IteratedBufferStressTest.cpp
+++ b/tests/perf/operation/buffer/IteratedBufferStressTest.cpp
@@ -30,7 +30,7 @@ using namespace geos::geom;
using namespace geos::io;
-typedef auto_ptr<Geometry> GeomPtr;
+typedef unique_ptr<Geometry> GeomPtr;
GeomPtr doBuffer(const Geometry& g, double dist)
diff --git a/tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp b/tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp
index 0c62f1a..654e675 100644
--- a/tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp
+++ b/tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp
@@ -48,7 +48,7 @@ public:
double size = 100;
Coordinate origin(0, 0);
- auto_ptr<Geometry> sinePoly (
+ unique_ptr<Geometry> sinePoly (
createSineStar(origin, size, nPts)->getBoundary()
@@ -60,7 +60,7 @@ public:
using geos::precision::SimpleGeometryPrecisionReducer;
PrecisionModel pm(size/10);
SimpleGeometryPrecisionReducer reducer(&pm);
- auto_ptr<Geometry> sinePolyCrinkly ( reducer.reduce(sinePoly.get()) );
+ unique_ptr<Geometry> sinePolyCrinkly ( reducer.reduce(sinePoly.get()) );
sinePoly.reset();
Geometry& target = *sinePolyCrinkly;
@@ -128,7 +128,7 @@ private:
- auto_ptr<Polygon> createSineStar(const Coordinate& origin,
+ unique_ptr<Polygon> createSineStar(const Coordinate& origin,
double size, int nPts)
using geos::geom::util::SineStarFactory;
@@ -139,7 +139,7 @@ private:
gsf.setNumPoints(nPts);
gsf.setArmLengthRatio(2);
gsf.setNumArms(20);
- auto_ptr<Polygon> poly = gsf.createSineStar();
+ unique_ptr<Polygon> poly = gsf.createSineStar();
return poly;
diff --git a/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp b/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp
index e484563..ef557cb 100644
--- a/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp
@@ -46,9 +46,9 @@ namespace tut
void object::test<1>()
const std::string wkt("LINESTRING ( 0 0, 0 1, 1 1)");
- Geometry::AutoPtr geom(reader_.read(wkt));
+ Geometry::Ptr geom(reader_.read(wkt));
- CoordinateSequence::AutoPtr pts(geom->getCoordinates());
+ CoordinateSequence::Ptr pts(geom->getCoordinates());
int const a = CGAlgorithms::computeOrientation(pts->getAt(0), pts->getAt(1), pts->getAt(2));
int const b = CGAlgorithms::computeOrientation(pts->getAt(0), pts->getAt(1), pts->getAt(2));
diff --git a/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp b/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
index 8d144cf..5ecbd54 100644
--- a/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
@@ -28,7 +28,7 @@ namespace tut
struct test_isccw_data
- typedef std::auto_ptr<geos::geom::Geometry> GeometryPtr;
+ typedef std::unique_ptr<geos::geom::Geometry> GeometryPtr;
geos::geom::CoordinateSequence* cs_;
geos::io::WKTReader reader_;
diff --git a/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp b/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp
index f3922bf..4e5ea78 100644
--- a/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp
@@ -24,7 +24,7 @@ namespace tut
struct test_ispointinring_data
- typedef std::auto_ptr<geos::geom::Geometry> GeomPtr;
+ typedef std::unique_ptr<geos::geom::Geometry> GeomPtr;
diff --git a/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp b/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp
index 6834346..bbeaf38 100644
--- a/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp
@@ -27,7 +27,7 @@ namespace tut
struct test_signedarea_data
diff --git a/tests/unit/algorithm/ConvexHullTest.cpp b/tests/unit/algorithm/ConvexHullTest.cpp
index ede64d3..3ceed5f 100644
--- a/tests/unit/algorithm/ConvexHullTest.cpp
+++ b/tests/unit/algorithm/ConvexHullTest.cpp
@@ -36,14 +36,9 @@ namespace tut
// dummy data, not used
struct test_convexhull_data
- // Typedefs used as short names by test cases
- typedef std::auto_ptr<geos::geom::Geometry> GeometryAPtr;
- typedef std::auto_ptr<geos::geom::LineString> LineStringAPtr;
- typedef geos::geom::GeometryFactory GeometryFactory;
GeometryPtr geom_;
geos::geom::PrecisionModel pm_;
- geos::geom::GeometryFactory::unique_ptr factory_;
+ geos::geom::GeometryFactory::Ptr factory_;
test_convexhull_data()
@@ -75,12 +70,12 @@ namespace tut
using geos::geom::LineString;
- GeometryAPtr lineGeom(reader_.read("LINESTRING (30 220, 240 220, 240 220)"));
- LineStringAPtr line(dynamic_cast_auto_ptr<LineString>(lineGeom));
+ Geometry::Ptr lineGeom(reader_.read("LINESTRING (30 220, 240 220, 240 220)"));
+ LineString::Ptr line(dynamic_cast<LineString*>(lineGeom.release()));
ensure(0 != line.get());
- GeometryAPtr hullGeom(reader_.read("LINESTRING (30 220, 240 220)"));
- LineStringAPtr convexHull(dynamic_cast_auto_ptr<LineString>(hullGeom));
+ Geometry::Ptr hullGeom(reader_.read("LINESTRING (30 220, 240 220)"));
+ LineString::Ptr convexHull(dynamic_cast<LineString*>(hullGeom.release()));
ensure(0 != convexHull.get());
geom_ = line->convexHull();
@@ -94,11 +89,11 @@ namespace tut
- GeometryAPtr geom(reader_.read("MULTIPOINT (130 240, 130 240, 130 240, 570 240, 570 240, 570 240, 650 240)"));
+ Geometry::Ptr geom(reader_.read("MULTIPOINT (130 240, 130 240, 130 240, 570 240, 570 240, 570 240, 650 240)"));
ensure(0 != geom.get());
- GeometryAPtr hullGeom(reader_.read("LINESTRING (130 240, 650 240)"));
+ Geometry::Ptr hullGeom(reader_.read("LINESTRING (130 240, 650 240)"));
geom_ = geom->convexHull();
@@ -112,11 +107,11 @@ namespace tut
- GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 0 0, 10 0)"));
+ Geometry::Ptr geom(reader_.read("MULTIPOINT (0 0, 0 0, 10 0)"));
- GeometryAPtr hullGeom(reader_.read("LINESTRING (0 0, 10 0)"));
+ Geometry::Ptr hullGeom(reader_.read("LINESTRING (0 0, 10 0)"));
@@ -130,11 +125,11 @@ namespace tut
- GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 10 0, 10 0)"));
+ Geometry::Ptr geom(reader_.read("MULTIPOINT (0 0, 10 0, 10 0)"));
@@ -148,11 +143,11 @@ namespace tut
- GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 5 0, 10 0)"));
+ Geometry::Ptr geom(reader_.read("MULTIPOINT (0 0, 5 0, 10 0)"));
@@ -166,13 +161,13 @@ namespace tut
- GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 5 1, 10 0)"));
+ Geometry::Ptr geom(reader_.read("MULTIPOINT (0 0, 5 1, 10 0)"));
- GeometryAPtr hullGeom(geom->convexHull());
+ Geometry::Ptr hullGeom(geom->convexHull());
ensure(0 != hullGeom.get());
- GeometryAPtr expectedHull(reader_.read("POLYGON ((0 0, 5 1, 10 0, 0 0))"));
+ Geometry::Ptr expectedHull(reader_.read("POLYGON ((0 0, 5 1, 10 0, 0 0))"));
ensure(0 != expectedHull.get());
ensure_equals( hullGeom->toString(), expectedHull->toString() );
@@ -185,11 +180,11 @@ namespace tut
- GeometryAPtr geom(reader_.read("MULTIPOINT (0 0, 0 0, 5 0, 5 0, 10 0, 10 0)"));
+ Geometry::Ptr geom(reader_.read("MULTIPOINT (0 0, 0 0, 5 0, 5 0, 10 0, 10 0)"));
diff --git a/tests/unit/algorithm/InteriorPointAreaTest.cpp b/tests/unit/algorithm/InteriorPointAreaTest.cpp
index 8445d6e..1542817 100644
--- a/tests/unit/algorithm/InteriorPointAreaTest.cpp
+++ b/tests/unit/algorithm/InteriorPointAreaTest.cpp
@@ -39,7 +39,7 @@ namespace tut
typedef geos::algorithm::InteriorPointArea InteriorPointArea;
geos::io::WKTReader reader;
- std::auto_ptr<Geometry> geom;
+ std::unique_ptr<Geometry> geom;
test_interiorpointarea_data()
diff --git a/tests/unit/algorithm/MinimumDiameterTest.cpp b/tests/unit/algorithm/MinimumDiameterTest.cpp
index 8a339d3..9be920a 100644
--- a/tests/unit/algorithm/MinimumDiameterTest.cpp
+++ b/tests/unit/algorithm/MinimumDiameterTest.cpp
@@ -36,13 +36,13 @@ namespace tut
struct test_minimumdiameter_data {
typedef geos::geom::Geometry Geometry;
typedef geos::geom::Coordinate Coordinate;
typedef geos::algorithm::MinimumDiameter MinimumDiameter;
test_minimumdiameter_data()
diff --git a/tests/unit/algorithm/PointLocatorTest.cpp b/tests/unit/algorithm/PointLocatorTest.cpp
index 82c02fa..25e0e28 100644
--- a/tests/unit/algorithm/PointLocatorTest.cpp
+++ b/tests/unit/algorithm/PointLocatorTest.cpp
@@ -8,7 +8,7 @@
#include <geos/algorithm/PointLocator.h>
#include <geos/geom/PrecisionModel.h>
-#include <geos/geom/Geometry.h> // required for use in auto_ptr
+#include <geos/geom/Geometry.h> // required for use in unique_ptr
#include <geos/geom/Coordinate.h>
// std
#include <sstream>
@@ -42,10 +42,10 @@ namespace tut
// for the same reason...
static PrecisionModel pm;
- static GeometryFactory::unique_ptr gf = GeometryFactory::create(&pm);
+ static GeometryFactory::Ptr gf = GeometryFactory::create(&pm);
static geos::io::WKTReader reader(gf.get());
- typedef std::auto_ptr<Geometry> GeomPtr;
+ typedef std::unique_ptr<Geometry> GeomPtr;
void runPtLocator(int expected, const Coordinate& pt,
const std::string& wkt)
diff --git a/tests/unit/algorithm/RobustLineIntersectionTest.cpp b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
index 95fb5d9..0937818 100644
--- a/tests/unit/algorithm/RobustLineIntersectionTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
@@ -7,7 +7,7 @@
// std
@@ -31,7 +31,7 @@ namespace tut
struct test_robustlineintersection_data
bool equals(const Coordinate& p0, const Coordinate& p1,
double distanceTolerance)
@@ -136,7 +136,7 @@ namespace tut
GeomPtr g(reader.read(expectedWKT));
- std::auto_ptr<CoordinateSequence> cs ( g->getCoordinates() );
+ std::unique_ptr<CoordinateSequence> cs ( g->getCoordinates() );
std::vector<Coordinate> intPt;
for (size_t i=0; i<cs->size(); ++i)
@@ -250,7 +250,7 @@ namespace tut
PrecisionModel pm;
- GeometryFactory::unique_ptr gf;
+ GeometryFactory::Ptr gf;
diff --git a/tests/unit/algorithm/RobustLineIntersectorTest.cpp b/tests/unit/algorithm/RobustLineIntersectorTest.cpp
index 68dd718..0f45798 100644
--- a/tests/unit/algorithm/RobustLineIntersectorTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectorTest.cpp
@@ -9,7 +9,7 @@
#include <geos/algorithm/CGAlgorithms.h>
#include <geos/geom/Point.h>
@@ -34,7 +34,7 @@ namespace tut
struct test_robustlineintersector_data {
LineIntersector i;
@@ -238,7 +238,7 @@ namespace tut
using geos::geom::GeometryFactory;
CoordinateSequence* cs = new CoordinateArraySequence();
cs->add(p1);
cs->add(p2);
@@ -300,7 +300,7 @@ namespace tut
geos::geom::PrecisionModel pm(1e+13);
- GeometryFactory::unique_ptr factory = GeometryFactory::create(&pm);
+ GeometryFactory::Ptr factory = GeometryFactory::create(&pm);
geos::io::WKBReader reader(*factory);
// POINT located between 3rd and 4th vertex of LINESTRING
diff --git a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
index 64a0e79..d4d55a2 100644
--- a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
@@ -9,7 +9,7 @@
#include <geos/algorithm/distance/DiscreteFrechetDistance.h>
// std
#include <cmath>
@@ -35,7 +35,7 @@ namespace tut
// Test data, not used
struct test_DiscreteFrechetDistance_data {
test_DiscreteFrechetDistance_data()
@@ -72,7 +72,7 @@ namespace tut
PrecisionModel pm;
diff --git a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
index 695aa64..236ce39 100644
--- a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
@@ -10,7 +10,7 @@
#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
// std
#include <cmath>
@@ -36,7 +36,7 @@ namespace tut
struct test_DiscreteHausdorffDistance_data {
test_DiscreteHausdorffDistance_data()
@@ -73,7 +73,7 @@ namespace tut
PrecisionModel pm;
diff --git a/tests/unit/capi/GEOSContainsTest.cpp b/tests/unit/capi/GEOSContainsTest.cpp
index f99056d..591cfb4 100644
--- a/tests/unit/capi/GEOSContainsTest.cpp
+++ b/tests/unit/capi/GEOSContainsTest.cpp
@@ -132,7 +132,7 @@ namespace tut
// A contains B if precision is limited to 1e+10
geos::geom::PrecisionModel pm(1e+10);
- geos::geom::GeometryFactory::unique_ptr factory = geos::geom::GeometryFactory::create(&pm);
+ geos::geom::GeometryFactory::Ptr factory = geos::geom::GeometryFactory::create(&pm);
std::istringstream sOuter(outer);
@@ -151,7 +151,7 @@ namespace tut
// A does NOT contain B if precision is extended to 1e+11 or beyond
geos::geom::PrecisionModel pm(1e+11);
@@ -185,7 +185,7 @@ namespace tut
@@ -204,7 +204,7 @@ namespace tut
// A contains B if FLOATING PM is used with extended precision
geos::geom::PrecisionModel pm;
diff --git a/tests/unit/capi/GEOSPreparedGeometryTest.cpp b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
index 907af92..2308f7e 100644
--- a/tests/unit/capi/GEOSPreparedGeometryTest.cpp
+++ b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
@@ -219,7 +219,7 @@ namespace tut
void object::test<8>()
@@ -271,7 +271,7 @@ namespace tut
geos::geom::PrecisionModel pm(1e+10); // NOTE: higher precision fails this test case
@@ -292,7 +292,7 @@ namespace tut
@@ -328,7 +328,7 @@ namespace tut
@@ -349,7 +349,7 @@ namespace tut
diff --git a/tests/unit/geom/CoordinateArraySequenceTest.cpp b/tests/unit/geom/CoordinateArraySequenceTest.cpp
index 9c1162e..4d4162c 100644
--- a/tests/unit/geom/CoordinateArraySequenceTest.cpp
+++ b/tests/unit/geom/CoordinateArraySequenceTest.cpp
@@ -541,7 +541,7 @@ namespace tut
typedef geos::geom::CoordinateSequenceFactory const* CoordinateFactoryCPtr;
CoordinateFactoryCPtr factory = geos::geom::CoordinateArraySequenceFactory::instance();
- std::auto_ptr<CoordinateSequence> sequence1ptr(factory->create(4, 2));
+ std::unique_ptr<CoordinateSequence> sequence1ptr(factory->create(4, 2));
CoordinateSequence& seq = *sequence1ptr;
// Index: 0 - Order: Y, X, Z
diff --git a/tests/unit/geom/CoordinateListTest.cpp b/tests/unit/geom/CoordinateListTest.cpp
index aedeb49..372d3a9 100644
--- a/tests/unit/geom/CoordinateListTest.cpp
+++ b/tests/unit/geom/CoordinateListTest.cpp
@@ -48,7 +48,7 @@ namespace tut
geos::geom::CoordinateList::iterator it, it2;
- std::auto_ptr< std::vector<Coordinate> > col( new std::vector<Coordinate>() );
+ std::unique_ptr< std::vector<Coordinate> > col( new std::vector<Coordinate>() );
col->push_back(a);
col->push_back(b);
col->push_back(c);
@@ -141,7 +141,7 @@ namespace tut
const Coordinate c(45,60);
const Coordinate d(100,0);
- std::auto_ptr< std::vector<Coordinate> > v( new std::vector<Coordinate>() );
+ std::unique_ptr< std::vector<Coordinate> > v( new std::vector<Coordinate>() );
v->push_back(a);
v->push_back(b);
v->push_back(c);
diff --git a/tests/unit/geom/Geometry/clone.cpp b/tests/unit/geom/Geometry/clone.cpp
index c5a5735..9fca572 100644
--- a/tests/unit/geom/Geometry/clone.cpp
+++ b/tests/unit/geom/Geometry/clone.cpp
@@ -20,9 +20,9 @@ namespace tut {
struct test_geometry_clone_data
- typedef std::auto_ptr<geos::geom::Geometry> GeomAutoPtr;
- GeometryFactory::unique_ptr factory;
+ GeometryFactory::Ptr factory;
test_geometry_clone_data()
@@ -44,11 +44,11 @@ template<>
template<>
- GeomAutoPtr g1(reader.read(
+ GeomPtr g1(reader.read(
"POINT (0 100)"
g1->setSRID(66);
- GeomAutoPtr g2(g1->clone());
+ GeomPtr g2(g1->clone());
ensure( g1->equalsExact(g2.get()) );
ensure_equals( g1->getSRID(), 66 );
@@ -60,11 +60,11 @@ template<>
template<>
void object::test<2>()
"LINESTRING (0 0, 0 100, 100 100, 100 0)"
g1->setSRID(66);
@@ -76,11 +76,11 @@ template<>
template<>
void object::test<3>()
"POLYGON ((0 0, 0 100, 100 100, 100 0, 0 0))"
g1->setSRID(66);
@@ -92,11 +92,11 @@ template<>
template<>
void object::test<4>()
"MULTIPOINT (0 100, 5 6)"
g1->setSRID(66);
@@ -108,11 +108,11 @@ template<>
template<>
void object::test<5>()
"MULTILINESTRING ((0 0, 0 100, 100 100, 100 0), (15 25, 25 52))"
g1->setSRID(66);
@@ -124,11 +124,11 @@ template<>
template<>
void object::test<6>()
"MULTIPOLYGON (((0 0, 0 100, 100 100, 100 0, 0 0)))"
g1->setSRID(66);
ensure_equals( g1->getSRID(), g2->getSRID() );
@@ -138,11 +138,11 @@ template<>
template<>
void object::test<7>()
"GEOMETRYCOLLECTION(MULTIPOLYGON (((0 0, 0 100, 100 100, 100 0, 0 0))),POINT(3 4))"
g1->setSRID(66);
diff --git a/tests/unit/geom/Geometry/coversTest.cpp b/tests/unit/geom/Geometry/coversTest.cpp
index ea33b72..992800c 100644
--- a/tests/unit/geom/Geometry/coversTest.cpp
+++ b/tests/unit/geom/Geometry/coversTest.cpp
@@ -20,10 +20,10 @@ namespace tut {
struct test_contains_data
- geos::geom::GeometryFactory::unique_ptr factory;
+ geos::geom::GeometryFactory::Ptr factory;
test_contains_data()
@@ -46,10 +46,10 @@ template<>
template<>
- GeomAutoPtr g2(reader.read(
+ GeomPtr g2(reader.read(
"POLYGON ((0 0, 0 100, 90 90, 90 0, 0 0))"
@@ -63,10 +63,10 @@ template<>
template<>
"LINESTRING (0 0, 0 100)"
@@ -81,10 +81,10 @@ template<>
template<>
"POINT(0 0)"
@@ -107,10 +107,10 @@ template<>
template<>
"POLYGON ((-1.183864 52.951915, -1.183862 52.951903, -1.183890 52.951900, -1.183924 52.951897, -1.183958 52.951894, -1.183954 52.951880, -1.183954 52.951878, -1.183932 52.951841, -1.183904 52.951844, -1.183870 52.951847, -1.183832 52.951852, -1.183824 52.951838, -1.183820 52.951830, -1.183870 52.951819, -1.183886 52.951815, -1.183890 52.951819, -1.183929 52.951810, -1.183909 52.951776, -1.183861 52.951787, -1.183853 52.951788, -1.183842 52.951770, -1.183970 52.951742, -1.183983 52.951763, -1.183963 52.951768, -1.183975 52.951788, -1.183994 52.951785, -1.184009 52.951807, -1.184002 52.951808, -1.184009 52.951835, -1.183990 52.951836, -1.183990 52.951836, -1.183990 52.951838, -1.184001 52.951880, -1.184018 52.951954, -1.184020 52.951956, -1.183998 52.951957, -1.183998 52.951956, -1.183996 52.951948, -1.183970 52.951906, -1.183936 52.951909, -1.183864 52.951915))"
"POINT (-1.183972 52.951871)"
diff --git a/tests/unit/geom/Geometry/equalsTest.cpp b/tests/unit/geom/Geometry/equalsTest.cpp
index 78c3943..a060767 100644
--- a/tests/unit/geom/Geometry/equalsTest.cpp
+++ b/tests/unit/geom/Geometry/equalsTest.cpp
@@ -20,7 +20,7 @@ namespace tut {
struct test_equals_data
test_equals_data()
@@ -42,19 +42,19 @@ group test_equals_data("geos::geom::Geometry::equals");
template<> template<> void object::test<1>() {
- GeomAutoPtr g1(reader.read("POINT EMPTY"));
+ GeomPtr g1(reader.read("POINT EMPTY"));
ensure( g1->equals(g1.get()) );
- GeomAutoPtr g2(reader.read("LINESTRING EMPTY"));
+ GeomPtr g2(reader.read("LINESTRING EMPTY"));
ensure( g2->equals(g2.get()) );
ensure( g2->equals(g1.get()) );
- GeomAutoPtr g3(reader.read("POLYGON EMPTY"));
+ GeomPtr g3(reader.read("POLYGON EMPTY"));
ensure( g3->equals(g3.get()) );
ensure( g3->equals(g2.get()) );
ensure( g3->equals(g1.get()) );
- GeomAutoPtr g4(reader.read("GEOMETRYCOLLECTION EMPTY"));
+ GeomPtr g4(reader.read("GEOMETRYCOLLECTION EMPTY"));
ensure( g4->equals(g4.get()) );
ensure( g4->equals(g3.get()) );
ensure( g4->equals(g2.get()) );
diff --git a/tests/unit/geom/Geometry/normalize.cpp b/tests/unit/geom/Geometry/normalize.cpp
index d25f236..05668c4 100644
--- a/tests/unit/geom/Geometry/normalize.cpp
+++ b/tests/unit/geom/Geometry/normalize.cpp
@@ -21,7 +21,7 @@ namespace tut {
struct test_geometry_normalize_data
geos::io::WKTWriter writer;
@@ -34,13 +34,13 @@ struct test_geometry_normalize_data
void
runTest(const char *from, const char *exp)
- GeomAutoPtr g1(reader.read(from));
+ GeomPtr g1(reader.read(from));
ensure(g1.get());
ensure(g2.get());
g2->normalize();
- GeomAutoPtr ge(reader.read(exp));
+ GeomPtr ge(reader.read(exp));
bool eq = g2->equalsExact(ge.get());
if ( ! eq ) {
using namespace std;
diff --git a/tests/unit/geom/Geometry/touchesTest.cpp b/tests/unit/geom/Geometry/touchesTest.cpp
index f566fba..ee65382 100644
--- a/tests/unit/geom/Geometry/touchesTest.cpp
+++ b/tests/unit/geom/Geometry/touchesTest.cpp
struct test_touches_data
geos::io::WKBReader breader;
@@ -48,11 +48,11 @@ template<>
template<>
"POINT (0 0)"
"POINT (0 0)"
@@ -65,11 +65,11 @@ template<>
template<>
"LINESTRING(0 0, 1 1, 0 2)"
"POINT (1 1)"
@@ -82,11 +82,11 @@ template<>
template<>
"POINT (0 2)"
@@ -99,11 +99,11 @@ template<>
template<>
"LINESTRING (-612844.96290006 279079.117329031,-257704.820935236 574364.179187424)"
"POINT (-257704.820935236 574364.179187424)"
@@ -120,8 +120,8 @@ void object::test<5>()
// B: LINESTRING(-2119.81532027122 4257.47493284327,-2119.81532027122 2326.7198668134)
std::stringstream wkbA("01020000000200000010efda91826fabc0a8e5329579a1b040008633595f6c8bc0a8e5329579a1b040");
std::stringstream wkbB("0102000000020000005999a871a18fa0c0a8e5329579a1b0405999a871a18fa0c0180a6292702da240");
- GeomAutoPtr a(breader.readHEX(wkbA));
- GeomAutoPtr b(breader.readHEX(wkbB));
+ GeomPtr a(breader.readHEX(wkbA));
+ GeomPtr b(breader.readHEX(wkbB));
ensure(a->touches(b.get()));
ensure(!a->disjoint(b.get()));
@@ -137,8 +137,8 @@ void object::test<6>()
// B: LINESTRING(1098.10978977856 4137.73818456235,1921.2999342099 2177.04893146225)
std::stringstream wkbA("010200000003000000603f483e8ac87ac092ba62a50373b1405851bb6c70289140b6d9a9f9bc29b04060a2990ed55799401226341da5a8b540");
std::stringstream wkbB("0102000000020000005851bb6c70289140b6d9a9f9bc29b040d019f42133059e40406c8b0d1902a140");
@@ -154,8 +154,8 @@ void object::test<7>()
// B: LINESTRING(4151.39687094207 3823.42922032493,6112.08612404217 2461.42370862944)
std::stringstream wkbA("01020000000200000098e8f0fe581eaa40ea70df8b95b2a3408c9532b39e5fb340417cd4fc9005b440");
std::stringstream wkbB("010200000002000000ec8455996537b040b834c4c2dbdead4086a8390c16e0b740f86456f0d83aa340");
// segments do not just touch, but intersect (float-point robustness issue likely)
ensure(!a->touches(b.get()));
diff --git a/tests/unit/geom/GeometryComponentFilterTest.cpp b/tests/unit/geom/GeometryComponentFilterTest.cpp
index 0e3e62a..09fbf11 100644
--- a/tests/unit/geom/GeometryComponentFilterTest.cpp
+++ b/tests/unit/geom/GeometryComponentFilterTest.cpp
@@ -16,10 +16,10 @@ namespace tut
struct test_geometrycomponentfilter_data
- typedef geos::geom::Geometry::AutoPtr GeometryPtr; // owner
+ typedef geos::geom::Geometry::Ptr GeometryPtr; // owner
typedef std::vector<geos::geom::Geometry const*> GeometryRefArray; // observer
- geos::geom::GeometryFactory::unique_ptr gf;
+ geos::geom::GeometryFactory::Ptr gf;
test_geometrycomponentfilter_data()
: gf(geos::geom::GeometryFactory::create())
diff --git a/tests/unit/geom/GeometryFactoryTest.cpp b/tests/unit/geom/GeometryFactoryTest.cpp
index c91208d..1127a79 100644
--- a/tests/unit/geom/GeometryFactoryTest.cpp
+++ b/tests/unit/geom/GeometryFactoryTest.cpp
@@ -54,7 +54,7 @@ namespace tut
const int srid_;
test_geometryfactory_data()
@@ -83,7 +83,7 @@ reader_(factory_.get())
- GeometryFactory::unique_ptr gf = GeometryFactory::create();
+ GeometryFactory::Ptr gf = GeometryFactory::create();
ensure_equals( gf->getSRID(), 0 );
ensure_equals( gf->getPrecisionModel()->getType(), geos::geom::PrecisionModel::FLOATING );
@@ -110,7 +110,7 @@ reader_(factory_.get())
PrecisionModel pm(1.0);
- GeometryFactory::unique_ptr gf = GeometryFactory::create(&pm, srid_, &csf);
+ GeometryFactory::Ptr gf = GeometryFactory::create(&pm, srid_, &csf);
ensure_equals( gf->getSRID(), srid_ );
ensure_equals( gf->getPrecisionModel()->getType(), geos::geom::PrecisionModel::FIXED );
@@ -140,7 +140,7 @@ reader_(factory_.get())
CoordinateArraySequenceFactory csf;
- GeometryFactory::unique_ptr gf = GeometryFactory::create(&csf);
+ GeometryFactory::Ptr gf = GeometryFactory::create(&csf);
@@ -165,7 +165,7 @@ reader_(factory_.get())
PrecisionModel pm(PrecisionModel::FIXED);
- GeometryFactory::unique_ptr gf(GeometryFactory::create(&pm));
+ GeometryFactory::Ptr gf(GeometryFactory::create(&pm));
ensure_equals( gf->getPrecisionModel()->getType(), PrecisionModel::FIXED );
@@ -188,7 +188,7 @@ reader_(factory_.get())
- GeometryFactory::unique_ptr gf(GeometryFactory::create(&pm, srid_));
+ GeometryFactory::Ptr gf(GeometryFactory::create(&pm, srid_));
@@ -208,7 +208,7 @@ reader_(factory_.get())
- GeometryFactory::unique_ptr gf(GeometryFactory::create(*factory_));
+ GeometryFactory::Ptr gf(GeometryFactory::create(*factory_));
ensure_equals( factory_->getSRID(), gf->getSRID() );
ensure_equals( factory_->getPrecisionModel()->getType(), gf->getPrecisionModel()->getType() );
@@ -1248,7 +1248,7 @@ reader_(factory_.get())
template<>
void object::test<36>()
- typedef std::auto_ptr<geos::geom::Geometry> GeometryAutoPtr;
+ typedef std::unique_ptr<geos::geom::Geometry> GeometryAutoPtr;
typedef std::vector<PointPtr> PointVect;
const std::size_t size = 3;
diff --git a/tests/unit/geom/GeometryFilterTest.cpp b/tests/unit/geom/GeometryFilterTest.cpp
index 5c56150..c3b1f92 100644
--- a/tests/unit/geom/GeometryFilterTest.cpp
+++ b/tests/unit/geom/GeometryFilterTest.cpp
struct test_geometryfilter_data
test_geometryfilter_data()
diff --git a/tests/unit/geom/LineStringTest.cpp b/tests/unit/geom/LineStringTest.cpp
index 2b004e0..6e13b4a 100644
--- a/tests/unit/geom/LineStringTest.cpp
+++ b/tests/unit/geom/LineStringTest.cpp
@@ -30,10 +30,10 @@ namespace tut
struct test_linestring_data
- typedef std::auto_ptr<geos::geom::LineString> LineStringAutoPtr;
+ typedef std::unique_ptr<geos::geom::LineString> LineStringAutoPtr;
LineStringPtr empty_line_;
diff --git a/tests/unit/geom/LinearRingTest.cpp b/tests/unit/geom/LinearRingTest.cpp
index ec0e940..760a11f 100644
--- a/tests/unit/geom/LinearRingTest.cpp
+++ b/tests/unit/geom/LinearRingTest.cpp
@@ -40,7 +40,7 @@ namespace tut
typedef geos::geom::LinearRing const* LinearRingCPtr;
geos::geom::LinearRing empty_ring_;
diff --git a/tests/unit/geom/MultiPointTest.cpp b/tests/unit/geom/MultiPointTest.cpp
index cf29e2a..0f6925a 100644
--- a/tests/unit/geom/MultiPointTest.cpp
+++ b/tests/unit/geom/MultiPointTest.cpp
@@ -24,11 +24,11 @@ namespace tut
// Common data used by tests
struct test_multipoint_data
- typedef std::auto_ptr<geos::geom::MultiPoint> MultiPointAutoPtr;
+ typedef std::unique_ptr<geos::geom::MultiPoint> MultiPointAutoPtr;
MultiPointAutoPtr empty_mp_;
diff --git a/tests/unit/geom/PointTest.cpp b/tests/unit/geom/PointTest.cpp
index 6bc2846..8996b0c 100644
--- a/tests/unit/geom/PointTest.cpp
+++ b/tests/unit/geom/PointTest.cpp
@@ -30,16 +30,16 @@ namespace tut
typedef geos::geom::Coordinate const* CoordinateCPtr;
typedef geos::geom::Geometry* GeometryPtr;
typedef geos::geom::Geometry const* GeometryCPtr;
typedef geos::geom::Point* PointPtr;
- typedef std::auto_ptr<geos::geom::Point> PointAutoPtr;
+ typedef std::unique_ptr<geos::geom::Point> PointAutoPtr;
typedef geos::geom::Point const* PointCPtr;
- GeometryFactory::unique_ptr factory_;
+ GeometryFactory::Ptr factory_;
PointAutoPtr empty_point_;
PointPtr point_;
diff --git a/tests/unit/geom/PolygonTest.cpp b/tests/unit/geom/PolygonTest.cpp
index 0145f2e..2e6b4ef 100644
--- a/tests/unit/geom/PolygonTest.cpp
+++ b/tests/unit/geom/PolygonTest.cpp
@@ -31,12 +31,12 @@ namespace tut
struct test_polygon_data
- typedef std::auto_ptr<geos::geom::Polygon> PolygonAutoPtr;
+ typedef std::unique_ptr<geos::geom::Polygon> PolygonAutoPtr;
PolygonAutoPtr empty_poly_;
diff --git a/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp b/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp
index 3d8bee4..0fbf991 100644
--- a/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp
+++ b/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp
@@ -23,10 +23,10 @@ namespace tut {
struct test_preparedgeometrytouches_data
- typedef std::auto_ptr<geos::geom::prep::PreparedGeometry> PrepGeomAutoPtr;
+ typedef std::unique_ptr<geos::geom::prep::PreparedGeometry> PrepGeomAutoPtr;
GeometryPtr g1;
GeometryPtr g2;
diff --git a/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp b/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
index 52d7492..170e7c7 100644
--- a/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
+++ b/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
GeometryPtr g_;
PreparedGeometryPtr pg_;
test_preparedgeometryfactory_data()
diff --git a/tests/unit/geom/util/GeometryExtracterTest.cpp b/tests/unit/geom/util/GeometryExtracterTest.cpp
index 3b91049..008d36d 100644
--- a/tests/unit/geom/util/GeometryExtracterTest.cpp
+++ b/tests/unit/geom/util/GeometryExtracterTest.cpp
@@ -26,11 +26,11 @@ namespace tut
struct test_geometryextracter_data
geos::io::WKTReader wktreader;
geos::io::WKTWriter wktwriter;
typedef geos::io::WKTReader WKTReader;
typedef geos::io::WKTWriter WKTWriter;
diff --git a/tests/unit/io/WKBReaderTest.cpp b/tests/unit/io/WKBReaderTest.cpp
index 5929736..b500765 100644
--- a/tests/unit/io/WKBReaderTest.cpp
+++ b/tests/unit/io/WKBReaderTest.cpp
@@ -31,13 +31,13 @@ namespace tut
struct test_wkbreader_data
geos::io::WKBReader wkbreader;
geos::io::WKBWriter xdrwkbwriter;
geos::io::WKBWriter ndrwkbwriter;
test_wkbreader_data()
diff --git a/tests/unit/io/WKBWriterTest.cpp b/tests/unit/io/WKBWriterTest.cpp
index db666d5..5b3399d 100644
--- a/tests/unit/io/WKBWriterTest.cpp
+++ b/tests/unit/io/WKBWriterTest.cpp
struct test_wkbwriter_data
diff --git a/tests/unit/io/WKTReaderTest.cpp b/tests/unit/io/WKTReaderTest.cpp
index 554062c..eabc61a 100644
--- a/tests/unit/io/WKTReaderTest.cpp
+++ b/tests/unit/io/WKTReaderTest.cpp
struct test_wktreader_data
test_wktreader_data()
@@ -150,7 +150,7 @@ namespace tut
namespace ggm = geos::geom;
namespace gio = geos::io;
ggm::PrecisionModel pm(ggm::PrecisionModel::FLOATING);
- ggm::GeometryFactory::unique_ptr gf = ggm::GeometryFactory::create(&pm);
+ ggm::GeometryFactory::Ptr gf = ggm::GeometryFactory::create(&pm);
gio::WKTReader wktReader(gf.get());
const std::string str = " POINT (0 0) ";
geom.reset(wktReader.read(str)); //HERE IT FAILS
diff --git a/tests/unit/io/WKTWriterTest.cpp b/tests/unit/io/WKTWriterTest.cpp
index bb0f9e5..94be2b0 100644
--- a/tests/unit/io/WKTWriterTest.cpp
+++ b/tests/unit/io/WKTWriterTest.cpp
@@ -27,10 +27,10 @@ namespace tut
PrecisionModel pm;
@@ -138,7 +138,7 @@ namespace tut
PrecisionModel pm3(0.001);
- GeometryFactory::unique_ptr gf3(GeometryFactory::create(&pm3));
+ GeometryFactory::Ptr gf3(GeometryFactory::create(&pm3));
WKTReader wktreader3(gf3.get());
GeomPtr geom ( wktreader3.read("POINT(123456 654321)") );
diff --git a/tests/unit/linearref/LengthIndexedLineTest.cpp b/tests/unit/linearref/LengthIndexedLineTest.cpp
index 6b5f705..b9aebb6 100644
--- a/tests/unit/linearref/LengthIndexedLineTest.cpp
+++ b/tests/unit/linearref/LengthIndexedLineTest.cpp
@@ -10,7 +10,7 @@
#include <geos/io/WKTWriter.h>
#include <geos/linearref/LengthIndexedLine.h>
@@ -30,7 +30,7 @@ using namespace std;
namespace tut {
static const double TOLERANCE_DIST = 0.001;
struct test_lengthindexedline_data
diff --git a/tests/unit/noding/BasicSegmentStringTest.cpp b/tests/unit/noding/BasicSegmentStringTest.cpp
index cee434c..db8e97f 100644
--- a/tests/unit/noding/BasicSegmentStringTest.cpp
+++ b/tests/unit/noding/BasicSegmentStringTest.cpp
@@ -21,10 +21,10 @@ namespace tut
struct test_basicsegmentstring_data
- typedef std::auto_ptr<geos::geom::CoordinateSequence> \
+ typedef std::unique_ptr<geos::geom::CoordinateSequence> \
CoordinateSequenceAutoPtr;
- typedef std::auto_ptr<geos::noding::BasicSegmentString> \
+ typedef std::unique_ptr<geos::noding::BasicSegmentString> \
SegmentStringAutoPtr;
const geos::geom::CoordinateSequenceFactory* csFactory;
diff --git a/tests/unit/noding/NodedSegmentStringTest.cpp b/tests/unit/noding/NodedSegmentStringTest.cpp
index 1bbe752..f89f7e1 100644
--- a/tests/unit/noding/NodedSegmentStringTest.cpp
+++ b/tests/unit/noding/NodedSegmentStringTest.cpp
struct test_nodedsegmentstring_data
- typedef std::auto_ptr<geos::noding::NodedSegmentString> \
+ typedef std::unique_ptr<geos::noding::NodedSegmentString> \
@@ -255,7 +255,7 @@ namespace tut
// SegmentString::NonConstVect inputStrings;
// inputStrings.push_back(makeSegmentString(cs2.get()).get());
-// std::auto_ptr<SegmentString::NonConstVect> nodedStrings(
+// std::unique_ptr<SegmentString::NonConstVect> nodedStrings(
// NodedSegmentString::getNodedSubstrings(inputStrings)
diff --git a/tests/unit/noding/OrientedCoordinateArray.cpp b/tests/unit/noding/OrientedCoordinateArray.cpp
index 01867b2..fa9c42e 100644
--- a/tests/unit/noding/OrientedCoordinateArray.cpp
+++ b/tests/unit/noding/OrientedCoordinateArray.cpp
@@ -29,11 +29,11 @@ namespace tut
- typedef std::auto_ptr<CoordinateSequence> CoordSeqPtr;
+ typedef std::unique_ptr<CoordinateSequence> CoordSeqPtr;
test_orientedcoordinatearray_data()
: pm_()
diff --git a/tests/unit/noding/SegmentNodeTest.cpp b/tests/unit/noding/SegmentNodeTest.cpp
index f396e4a..05712a3 100644
--- a/tests/unit/noding/SegmentNodeTest.cpp
+++ b/tests/unit/noding/SegmentNodeTest.cpp
struct test_segmentnode_data
CoordSeqPtr;
- typedef std::auto_ptr<geos::noding::SegmentString>
+ typedef std::unique_ptr<geos::noding::SegmentString>
SegmentStringPtr;
const geos::geom::CoordinateSequenceFactory* factory_;
diff --git a/tests/unit/noding/SegmentPointComparatorTest.cpp b/tests/unit/noding/SegmentPointComparatorTest.cpp
index 99a995c..9fb1f06 100644
--- a/tests/unit/noding/SegmentPointComparatorTest.cpp
+++ b/tests/unit/noding/SegmentPointComparatorTest.cpp
@@ -28,10 +28,10 @@ namespace tut
struct test_segmentpointcomparator_data
diff --git a/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp b/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
index 8c44b8c..ee5af63 100644
--- a/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
+++ b/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
@@ -49,8 +49,8 @@ namespace tut
typedef geos::geom::PrecisionModel PrecisionModel;
typedef geos::geom::CoordinateSequence CoordinateSequence;
typedef std::vector<SegmentString*> SegStrVct;
typedef std::vector<Geometry*> GeomVct;
ensure_equals( nodable.size(), 1u );
noder.computeNodes(&nodable);
- std::auto_ptr<SegStrVct> noded ( noder.getNodedSubstrings() );
+ std::unique_ptr<SegStrVct> noded ( noder.getNodedSubstrings() );
ensure_equals( "1e-5", noded->size(), 178u );
diff --git a/tests/unit/operation/IsSimpleOpTest.cpp b/tests/unit/operation/IsSimpleOpTest.cpp
index b1f995f..03cd68b 100644
--- a/tests/unit/operation/IsSimpleOpTest.cpp
+++ b/tests/unit/operation/IsSimpleOpTest.cpp
double tolerance_;
@@ -55,7 +55,7 @@ namespace tut
const std::string wkt("MULTILINESTRING ((20 120, 120 20), (20 20, 120 120))");
- const Geometry::AutoPtr geom(reader_.read(wkt));
+ const Geometry::Ptr geom(reader_.read(wkt));
// TODO - mloskot: What about support of new features of BoundaryNodeRule, in JTS
@@ -79,7 +79,7 @@ namespace tut
const std::string wkt("MULTILINESTRING ((100 100, 20 20, 200 20, 100 100), (100 200, 100 100))");
IsSimpleOp op;
bool simple = op.isSimpleLinearGeometry(geom.get());
@@ -93,7 +93,7 @@ namespace tut
const std::string wkt("LINESTRING (100 100, 20 20, 200 20, 100 100)");
IsSimpleOp op;
diff --git a/tests/unit/operation/buffer/BufferBuilderTest.cpp b/tests/unit/operation/buffer/BufferBuilderTest.cpp
index 9535b39..26ee047 100644
--- a/tests/unit/operation/buffer/BufferBuilderTest.cpp
+++ b/tests/unit/operation/buffer/BufferBuilderTest.cpp
@@ -33,8 +33,8 @@ namespace tut
int const default_quadrant_segments;
- typedef geos::geom::Geometry::AutoPtr GeomPtr;
- typedef std::auto_ptr<geos::geom::CoordinateSequence> CSPtr;
+ typedef geos::geom::Geometry::Ptr GeomPtr;
+ typedef std::unique_ptr<geos::geom::CoordinateSequence> CSPtr;
test_bufferbuilder_data()
: gf(*geos::geom::GeometryFactory::getDefaultInstance())
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index 6eb25b9..f5c6009 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -31,8 +31,8 @@ namespace tut
test_bufferop_data()
diff --git a/tests/unit/operation/distance/DistanceOpTest.cpp b/tests/unit/operation/distance/DistanceOpTest.cpp
index ceaae08..22914a4 100644
--- a/tests/unit/operation/distance/DistanceOpTest.cpp
+++ b/tests/unit/operation/distance/DistanceOpTest.cpp
@@ -30,8 +30,8 @@ namespace tut
test_distanceop_data()
: wktreader()
@@ -466,7 +466,7 @@ namespace tut
const char* wkb_geom2 = "010100000000000000000000000000000000000000";
geos::geom::PrecisionModel precision(geos::geom::PrecisionModel::FLOATING);
- GeometryFactory::unique_ptr f(GeometryFactory::create(&precision));
+ GeometryFactory::Ptr f(GeometryFactory::create(&precision));
std::istringstream istr1(wkb_geom1);
std::istringstream istr2(wkb_geom2);
geos::io::WKBReader wkb(*f);
diff --git a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
index 3b31f74..0bd73eb 100644
--- a/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
+++ b/tests/unit/operation/intersection/RectangleIntersectionTest.cpp
@@ -29,7 +29,7 @@ namespace tut
typedef geos::geom::Geometry Geom;
typedef geos::operation::intersection::Rectangle Rectangle;
typedef geos::operation::intersection::RectangleIntersection RectangleIntersection;
diff --git a/tests/unit/operation/linemerge/LineMergerTest.cpp b/tests/unit/operation/linemerge/LineMergerTest.cpp
index 817f96b..707d1ba 100644
--- a/tests/unit/operation/linemerge/LineMergerTest.cpp
+++ b/tests/unit/operation/linemerge/LineMergerTest.cpp
GeomVect inpGeoms;
GeomVect expGeoms;
diff --git a/tests/unit/operation/linemerge/LineSequencerTest.cpp b/tests/unit/operation/linemerge/LineSequencerTest.cpp
index a49b9f2..a34ec88 100644
--- a/tests/unit/operation/linemerge/LineSequencerTest.cpp
+++ b/tests/unit/operation/linemerge/LineSequencerTest.cpp
GeomVect inpGeoms;
diff --git a/tests/unit/operation/overlay/OverlayOpUnionTest.cpp b/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
index 2ebcc62..638d1e5 100644
--- a/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
+++ b/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
@@ -24,9 +24,9 @@ namespace tut
struct test_overlayopunion_data
- typedef geos::geom::GeometryFactory::unique_ptr GeometryFactoryPtr;
+ typedef geos::geom::GeometryFactory::Ptr GeometryFactoryPtr;
typedef test_group<test_overlayopunion_data> group;
diff --git a/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp b/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
index 51d8a64..5e39148 100644
--- a/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
+++ b/tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp
@@ -22,7 +22,7 @@ namespace tut
struct test_geometrysnapper_data
@@ -49,21 +49,21 @@ namespace tut
template<>
- GeomAutoPtr src(reader.read(
+ GeomPtr src(reader.read(
GeometrySnapper snapper( *(src.get()) );
- GeomAutoPtr snap(reader.read(
+ GeomPtr snap(reader.read(
"MULTIPOINT ((0 0), (0 100.0000001), (100 100), (100 0))"
- GeomAutoPtr expected(reader.read(
+ GeomPtr expected(reader.read(
"POLYGON ((0 0, 0 100.0000001, 100 100, 100 0, 0 0))"
- GeomAutoPtr ret(snapper.snapTo( *(snap.get()), 0.000001 ));
+ GeomPtr ret(snapper.snapTo( *(snap.get()), 0.000001 ));
ensure( ret->equalsExact(expected.get(),0) );
@@ -74,21 +74,21 @@ namespace tut
template<>
"MULTIPOINT ((0.0000001 50))"
"POLYGON ((0 0, 0.0000001 50, 0 100, 100 100, 100 0, 0 0))"
diff --git a/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp b/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp
index b4fb290..72f66f1 100644
--- a/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp
+++ b/tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp
@@ -42,7 +42,7 @@ namespace tut
using geos::geom::Coordinate;
using geos::operation::overlay::snap::LineStringSnapper;
- typedef std::auto_ptr<Coordinate::Vect> CoordsVectAptr;
+ typedef std::unique_ptr<Coordinate::Vect> CoordsVectAptr;
// source coordinates
@@ -80,7 +80,7 @@ namespace tut
@@ -119,7 +119,7 @@ namespace tut
@@ -164,7 +164,7 @@ namespace tut
@@ -196,7 +196,7 @@ namespace tut
@@ -223,7 +223,7 @@ namespace tut
@@ -252,7 +252,7 @@ namespace tut
// Source: (0 0, 10 0, 0 1)
// Source: (0 0, 1 0, 1 1)
@@ -338,7 +338,7 @@ namespace tut
// Source: (1 1, 5 9, 9 1, 1 1)
diff --git a/tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp b/tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp
index 1bc35e1..bce5b83 100644
--- a/tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp
+++ b/tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp
GeomPtr g;
diff --git a/tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp b/tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp
index c5e6c30..cb61fc6 100644
--- a/tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp
+++ b/tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp
geos::algorithm::PointLocator locator;
GeomPtr g;
for (size_t i=0, n=coords.size(); i<n; ++i)
const Coordinate& c = coords[i];
- auto_ptr<Geometry> pg(gf.createPoint(c));
+ unique_ptr<Geometry> pg(gf.createPoint(c));
double rdist = g->distance(pg.get());
if ( rdist > dist )
@@ -84,7 +84,7 @@ namespace tut
using geos::operation::overlay::validate::OffsetPointGenerator;
using geos::algorithm::PointLocator;
- using std::auto_ptr;
+ using std::unique_ptr;
using std::vector;
std::string wkt("POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))");
double dist = 10;
OffsetPointGenerator gen(*g, dist);
- auto_ptr< vector<Coordinate> > coords(gen.getPoints());
+ unique_ptr< vector<Coordinate> > coords(gen.getPoints());
ensure_equals(coords->size(), (g->getNumPoints()-1)*2);
@@ -108,7 +108,7 @@ namespace tut
using geos::geom::Location;
using std::vector;
std::string wkt("POLYGON((0 0, 10 0, 10 5, 10 10, 0 10, 0 0))");
@@ -118,7 +118,7 @@ namespace tut
ensure_equals(coords->size(), 10u);
using std::vector;
std::string wkt("POINT(10 -10)");
@@ -142,7 +142,7 @@ namespace tut
ensure_equals(coords->size(), 0u);
@@ -156,7 +156,7 @@ namespace tut
using std::vector;
std::string wkt("LINESTRING(10 -10, 5 600)");
@@ -166,7 +166,7 @@ namespace tut
ensure_equals(coords->size(), 2u);
@@ -180,7 +180,7 @@ namespace tut
using std::vector;
std::string wkt("MULTILINESTRING((10 -10, 5 600), (1045 -12, 0 0, -435 34))");
@@ -190,7 +190,7 @@ namespace tut
ensure_equals(coords->size(), 6u);
diff --git a/tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp b/tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp
index fda1585..e790fdf 100644
--- a/tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp
+++ b/tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp
@@ -30,7 +30,7 @@ namespace tut
GeomPtr g0, g1, gres;
diff --git a/tests/unit/operation/polygonize/PolygonizeTest.cpp b/tests/unit/operation/polygonize/PolygonizeTest.cpp
index 6072e67..c10eb39 100644
--- a/tests/unit/operation/polygonize/PolygonizeTest.cpp
+++ b/tests/unit/operation/polygonize/PolygonizeTest.cpp
@@ -32,7 +32,7 @@ namespace tut
typedef geos::geom::Polygon Poly;
typedef geos::operation::polygonize::Polygonizer Polygonizer;
Polygonizer polygonizer;
polygonizer.add(&inputGeoms);
- std::auto_ptr< std::vector<Poly*> > retGeoms;
+ std::unique_ptr< std::vector<Poly*> > retGeoms;
retGeoms.reset( polygonizer.getPolygons() );
delAll(inputGeoms);
diff --git a/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp b/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
index 49fd49a..20ef98e 100644
--- a/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
+++ b/tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp
SharedPathsOp::PathList forwDir;
SharedPathsOp::PathList backDir;
diff --git a/tests/unit/operation/union/CascadedPolygonUnionTest.cpp b/tests/unit/operation/union/CascadedPolygonUnionTest.cpp
index b161dc9..dadba85 100644
--- a/tests/unit/operation/union/CascadedPolygonUnionTest.cpp
+++ b/tests/unit/operation/union/CascadedPolygonUnionTest.cpp
test_cascadedpolygonuniontest_data()
typedef std::vector<geos::geom::Polygon*>::iterator iterator;
- std::auto_ptr<geos::geom::Geometry> unionAll;
+ std::unique_ptr<geos::geom::Geometry> unionAll;
iterator end = geoms->end();
for (iterator i = geoms->begin(); i != end; ++i)
@@ -74,8 +74,8 @@ namespace tut
void test_runner(test_cascadedpolygonuniontest_data& t,
std::vector<geos::geom::Polygon*>* geoms)
- std::auto_ptr<geos::geom::Geometry> union1(unionIterated(geoms));
- std::auto_ptr<geos::geom::Geometry> union2(unionCascaded(geoms));
+ std::unique_ptr<geos::geom::Geometry> union1(unionIterated(geoms));
+ std::unique_ptr<geos::geom::Geometry> union2(unionCascaded(geoms));
// For now we compare the WKT representations of the two generated
// geometries which works well for simple geometries only.
@@ -127,7 +127,7 @@ namespace tut
for (int i = 0; i < num; ++i) {
for (int j = 0; j < num; ++j) {
- std::auto_ptr<geos::geom::Point> pt(
+ std::unique_ptr<geos::geom::Point> pt(
gf.createPoint(geos::geom::Coordinate(i, j)));
g->push_back(dynamic_cast<geos::geom::Polygon*>(pt->buffer(radius)));
diff --git a/tests/unit/operation/union/UnaryUnionOpTest.cpp b/tests/unit/operation/union/UnaryUnionOpTest.cpp
index 9e92ebb..d98e03c 100644
--- a/tests/unit/operation/union/UnaryUnionOpTest.cpp
+++ b/tests/unit/operation/union/UnaryUnionOpTest.cpp
@@ -27,11 +27,11 @@ namespace tut
struct test_unaryuniontest_data
typedef geos::operation::geounion::UnaryUnionOp UnaryUnionOp;
diff --git a/tests/unit/operation/valid/IsValidTest.cpp b/tests/unit/operation/valid/IsValidTest.cpp
index c13c2ad..373fc0c 100644
--- a/tests/unit/operation/valid/IsValidTest.cpp
+++ b/tests/unit/operation/valid/IsValidTest.cpp
@@ -32,11 +32,11 @@ namespace tut
struct test_isvalidop_data
test_isvalidop_data()
: pm_(1), factory_(GeometryFactory::create(&pm_, 0))
diff --git a/tests/unit/operation/valid/ValidClosedRingTest.cpp b/tests/unit/operation/valid/ValidClosedRingTest.cpp
index 55ab3e3..d924848 100644
--- a/tests/unit/operation/valid/ValidClosedRingTest.cpp
+++ b/tests/unit/operation/valid/ValidClosedRingTest.cpp
@@ -37,11 +37,11 @@ namespace tut
struct test_validclosedring_data
geos::io::WKTReader rdr;
test_validclosedring_data()
diff --git a/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp b/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
index b3f4491..4cb8787 100644
--- a/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
+++ b/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
struct test_ValidSelfTouchingRingFormingHole_data
test_ValidSelfTouchingRingFormingHole_data()
diff --git a/tests/unit/precision/GeometryPrecisionReducerTest.cpp b/tests/unit/precision/GeometryPrecisionReducerTest.cpp
index c06fd39..b4a40f2 100644
--- a/tests/unit/precision/GeometryPrecisionReducerTest.cpp
+++ b/tests/unit/precision/GeometryPrecisionReducerTest.cpp
@@ -24,13 +24,13 @@ namespace tut
struct test_gpr_data
geos::geom::PrecisionModel pm_float_;
geos::geom::PrecisionModel pm_fixed_;
- GeometryFactory::unique_ptr factory_fixed_;
+ GeometryFactory::Ptr factory_fixed_;
geos::precision::GeometryPrecisionReducer reducer_;
geos::precision::GeometryPrecisionReducer reducerKeepCollapse_; // keep collapse
diff --git a/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp b/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp
index 7bab41e..051e3d3 100644
--- a/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp
+++ b/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp
@@ -22,12 +22,12 @@ namespace tut
struct test_sgpr_data
geos::precision::SimpleGeometryPrecisionReducer reducer_;
geos::precision::SimpleGeometryPrecisionReducer reducer2_; // keep collapse
diff --git a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
index 694cb08..edeb61d 100644
--- a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
+++ b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
test_dpsimp_data()
diff --git a/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp b/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
index 95f5273..e54787f 100644
--- a/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
+++ b/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
test_tpsimp_data()
: pm(1.0)
diff --git a/tests/unit/triangulate/DelaunayTest.cpp b/tests/unit/triangulate/DelaunayTest.cpp
index 9dc9df2..21db61e 100644
--- a/tests/unit/triangulate/DelaunayTest.cpp
+++ b/tests/unit/triangulate/DelaunayTest.cpp
@@ -44,7 +44,7 @@ namespace tut
void runDelaunay(const char *sitesWkt, bool computeTriangles, const char *expectedWkt, double tolerance=0.0)
WKTReader reader;
- std::auto_ptr<Geometry> results;
+ std::unique_ptr<Geometry> results;
Geometry *sites = reader.read(sitesWkt);
Geometry *expected = reader.read(expectedWkt);
DelaunayTriangulationBuilder builder;
@@ -85,7 +85,7 @@ namespace tut
//extract the triangles from the subdivision
const GeometryFactory& geomFact(*GeometryFactory::getDefaultInstance());
- std::auto_ptr<GeometryCollection> tris = sub.getTriangles(geomFact);
+ std::unique_ptr<GeometryCollection> tris = sub.getTriangles(geomFact);
// 2 - Test Triangle
diff --git a/tests/unit/triangulate/VoronoiTest.cpp b/tests/unit/triangulate/VoronoiTest.cpp
index 777fba8..07d8a1c 100644
--- a/tests/unit/triangulate/VoronoiTest.cpp
+++ b/tests/unit/triangulate/VoronoiTest.cpp
@@ -49,9 +49,9 @@ namespace tut
WKTReader reader;
WKTWriter writer;
geos::triangulate::VoronoiDiagramBuilder builder;
- std::auto_ptr<Geometry> sites ( reader.read(sitesWkt) );
- std::auto_ptr<Geometry> expected ( reader.read(expectedWkt) );
- std::auto_ptr<GeometryCollection> results;
+ std::unique_ptr<Geometry> sites ( reader.read(sitesWkt) );
+ std::unique_ptr<Geometry> expected ( reader.read(expectedWkt) );
+ std::unique_ptr<GeometryCollection> results;
builder.setSites(*sites);
@@ -87,7 +87,7 @@ namespace tut
Coordinate d(244,284);
- std::auto_ptr< std::vector<Coordinate> > v(new std::vector<Coordinate>());
+ std::unique_ptr< std::vector<Coordinate> > v(new std::vector<Coordinate>());
v->push_back(a);
v->push_back(b);
v->push_back(c);
@@ -97,7 +97,7 @@ namespace tut
builder.setSites(seq);
//getting the subdiv()
- std::auto_ptr<QuadEdgeSubdivision> subdiv = builder.getSubdivision();
+ std::unique_ptr<QuadEdgeSubdivision> subdiv = builder.getSubdivision();
ensure_equals(subdiv->getTolerance() , 0);
ensure_equals(subdiv->getEnvelope().toString(),"Env[-3540:4020,-3436:4050]");
diff --git a/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp b/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
index b7e65a1..fd3aaf1 100644
--- a/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
+++ b/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
ensure(!sub.isOnEdge(e, Coordinate(10, 10)));
ensure(!sub.isVertexOfEdge(e, Vertex(10, 10)));
- GeometryFactory::unique_ptr geomFact(GeometryFactory::create());
- std::auto_ptr<GeometryCollection> tris = sub.getTriangles(*geomFact);
+ GeometryFactory::Ptr geomFact(GeometryFactory::create());
+ std::unique_ptr<GeometryCollection> tris = sub.getTriangles(*geomFact);
tris.reset();
//WKTWriter wkt;
//printf("%s\n", wkt.writeFormatted(tris).c_str());
@@ -100,7 +100,7 @@ namespace tut
//Test for getVoronoiDiagram::
- std::auto_ptr<GeometryCollection> polys = subdiv->getVoronoiDiagram(geomFact);
+ std::unique_ptr<GeometryCollection> polys = subdiv->getVoronoiDiagram(geomFact);
const char *expected_str = "GEOMETRYCOLLECTION (POLYGON ((-5849.974929324658 2268.0517257497568, -4529.9920486948895 2247.139449440667, 221.20588235294116 210.91176470588235, -684.4227119984187 -2848.644297291955, -5849.974929324658 2268.0517257497568)), POLYGON ((212.5 -3774.5, -684.4227119984187 -2848.644297291955, 221.20588235294116 210.91176470588235, 2448.7167655626645 2188.608343256571, 6235.0370264064295 2248.0370264064295, 212.5 -3774.5)), POLYGON ((-4529.9920486948895 2247.139449440667, 2448.7167655626645 2188.608343256571, 221.20588235294116 210.91176470588235, -4529.9920486948895 2247.139449440667)))";
// std::cout << polys->toString() << std::endl;
@@ -127,19 +127,19 @@ namespace tut
" (230 250),"
" (210 290)"
- std::auto_ptr<Geometry> sites ( reader.read(wkt) );
- std::auto_ptr<CoordinateSequence> siteCoords (
+ std::unique_ptr<Geometry> sites ( reader.read(wkt) );
+ std::unique_ptr<CoordinateSequence> siteCoords (
DelaunayTriangulationBuilder::extractUniqueCoordinates(*sites)
Envelope env = DelaunayTriangulationBuilder::envelope(*siteCoords);
double expandBy = std::max(env.getWidth() , env.getHeight());
env.expandBy(expandBy);
- std::auto_ptr<QuadEdgeSubdivision> subdiv(
+ std::unique_ptr<QuadEdgeSubdivision> subdiv(
new quadedge::QuadEdgeSubdivision(env,10)
- std::auto_ptr<IncrementalDelaunayTriangulator::VertexList> vertices (
+ std::unique_ptr<IncrementalDelaunayTriangulator::VertexList> vertices (
DelaunayTriangulationBuilder::toVertices(*siteCoords)
@@ -148,11 +148,11 @@ namespace tut
for (std::size_t i=0; i<polys->getNumGeometries(); ++i) {
const Polygon* p = dynamic_cast<const Polygon*>(polys->getGeometryN(i));
ensure(p);
p->getExteriorRing()->getCoordinates()
size_t from = cs->size();
diff --git a/tests/unit/triangulate/quadedge/QuadEdgeTest.cpp b/tests/unit/triangulate/quadedge/QuadEdgeTest.cpp
index 9d961c4..f9a46bb 100644
--- a/tests/unit/triangulate/quadedge/QuadEdgeTest.cpp
+++ b/tests/unit/triangulate/quadedge/QuadEdgeTest.cpp
Vertex v3(1, 0);
Vertex v4(1, 1);
- std::auto_ptr<QuadEdge> q0;
- std::auto_ptr<QuadEdge> r0;
- std::auto_ptr<QuadEdge> s0;
+ std::unique_ptr<QuadEdge> q0;
+ std::unique_ptr<QuadEdge> r0;
+ std::unique_ptr<QuadEdge> s0;
q0 = QuadEdge::makeEdge(v1, v2);
r0 = QuadEdge::makeEdge(v3, v4);
@@ -78,9 +78,9 @@ namespace tut
Vertex v3(1, 0);
Vertex v4(1, 1);
r0 = QuadEdge::makeEdge(v2, v3);
@@ -110,11 +110,11 @@ namespace tut
Vertex v3(1, 0);
Vertex v4(1, 1);
- std::auto_ptr<QuadEdge> t0;
- std::auto_ptr<QuadEdge> u0;
+ std::unique_ptr<QuadEdge> t0;
+ std::unique_ptr<QuadEdge> u0;
//make a quadilateral
diff --git a/tests/unit/util/UniqueCoordinateArrayFilterTest.cpp b/tests/unit/util/UniqueCoordinateArrayFilterTest.cpp
index 1e1cf33..491683a 100644
--- a/tests/unit/util/UniqueCoordinateArrayFilterTest.cpp
+++ b/tests/unit/util/UniqueCoordinateArrayFilterTest.cpp
// Common data used in test cases.
struct test_uniquecoordinatearrayfilter_data
test_uniquecoordinatearrayfilter_data()
@@ -60,7 +60,7 @@ namespace tut
GeometryPtr geo(reader_.read(wkt));
ensure_equals( geo->getGeometryTypeId(), geos::geom::GEOS_MULTIPOINT );
- std::auto_ptr<geos::geom::CoordinateSequence> cs;
+ std::unique_ptr<geos::geom::CoordinateSequence> cs;
cs.reset(geo->getCoordinates());
ensure_equals(cs->getSize(), size5 );
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index cb5e520..4a58d7a 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -90,23 +90,6 @@ inline Type const* instanceOf(InstanceType const* instance)
return dynamic_cast<Type const*>(instance);
-template <typename Dst, typename Src>
-std::auto_ptr<Dst> dynamic_cast_auto_ptr(std::auto_ptr<Src>& ptr)
- Dst* res = dynamic_cast<Dst*>(ptr.get());
- if (0 != res)
- ptr.release();
- return std::auto_ptr<Dst>(res);
-std::auto_ptr<Dst> static_cast_auto_ptr(std::auto_ptr<Src>& ptr)
- return std::auto_ptr<Dst>(static_cast<Dst*>(ptr.release()));
// Geometries structure comparators
diff --git a/tests/xmltester/BufferResultMatcher.cpp b/tests/xmltester/BufferResultMatcher.cpp
index 6813d18..108575b 100644
--- a/tests/xmltester/BufferResultMatcher.cpp
+++ b/tests/xmltester/BufferResultMatcher.cpp
@@ -70,7 +70,7 @@ BufferResultMatcher::isSymDiffAreaInTolerance(
const geom::Geometry& actualBuffer,
const geom::Geometry& expectedBuffer)
- typedef std::auto_ptr<geom::Geometry> GeomPtr;
+ typedef std::unique_ptr<geom::Geometry> GeomPtr;
using namespace operation::overlay;
using geos::geom::BinaryOp;
@@ -101,7 +101,7 @@ BufferResultMatcher::isBoundaryHausdorffDistanceInTolerance(
const geom::Geometry& expectedBuffer, double distance)
using geos::algorithm::distance::DiscreteHausdorffDistance;
diff --git a/tests/xmltester/SimpleWKTTester.cpp b/tests/xmltester/SimpleWKTTester.cpp
index af732e2..44643b7 100644
--- a/tests/xmltester/SimpleWKTTester.cpp
+++ b/tests/xmltester/SimpleWKTTester.cpp
@@ -40,7 +40,7 @@ int main(int /*argc*/, char** /*argv*/)
string instr;
string outstr;
PrecisionModel pm;
- GeometryFactory::unique_ptr gf = GeometryFactory::create(&pm, 10);
+ GeometryFactory::Ptr gf = GeometryFactory::create(&pm, 10);
WKTReader *r = new WKTReader(gf.get());
WKTWriter *w = new WKTWriter();
Geometry *g;
diff --git a/tests/xmltester/SingleSidedBufferResultMatcher.cpp b/tests/xmltester/SingleSidedBufferResultMatcher.cpp
index d9200cd..8481669 100644
--- a/tests/xmltester/SingleSidedBufferResultMatcher.cpp
+++ b/tests/xmltester/SingleSidedBufferResultMatcher.cpp
@@ -74,7 +74,7 @@ SingleSidedBufferResultMatcher::isBoundaryHausdorffDistanceInTolerance(
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index d4e7d75..901f6e8 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -91,8 +91,8 @@ using std::runtime_error;
namespace {
-std::auto_ptr<const PreparedGeometry> prepare( const geom::Geometry *g ) {
- return std::auto_ptr<const PreparedGeometry> ( PreparedGeometryFactory::prepare(g) );
+std::unique_ptr<const PreparedGeometry> prepare( const geom::Geometry *g ) {
+ return std::unique_ptr<const PreparedGeometry> ( PreparedGeometryFactory::prepare(g) );
// Asymmetric Rounding Algorithm - equivalent to Java Math.round()
@@ -303,15 +303,15 @@ std::cerr << "SingleSidedBufferResultMatcher FAILED" << std::endl;
XMLTester::XMLTester()
- gA(0),
- gB(0),
- gT(0),
- pm(0),
- factory(0),
- wktreader(0),
- wktwriter(0),
- wkbreader(0),
- wkbwriter(0),
+ gA(nullptr),
+ gB(nullptr),
+ gT(nullptr),
+ pm(nullptr),
+ factory(nullptr),
+ wktreader(nullptr),
+ wktwriter(nullptr),
+ wkbreader(nullptr),
+ wkbwriter(nullptr),
test_predicates(0),
failed(0),
succeeded(0),
@@ -745,7 +745,7 @@ XMLTester::parseTest(const TiXmlNode* node)
- typedef std::auto_ptr< geom::Geometry > GeomAutoPtr;
+ typedef std::unique_ptr< geom::Geometry > GeomPtr;
int success=0; // no success by default
std::string opName;
@@ -825,7 +825,7 @@ XMLTester::parseTest(const TiXmlNode* node)
if (opName=="relate")
- std::auto_ptr<geom::IntersectionMatrix> im(gA->relate(gB));
+ std::unique_ptr<geom::IntersectionMatrix> im(gA->relate(gB));
assert(im.get());
if (im->matches(opArg3)) actual_result="true";
@@ -835,7 +835,7 @@ XMLTester::parseTest(const TiXmlNode* node)
else if (opName=="relatestring")
assert(im.get());
actual_result=im->toString();
@@ -860,15 +860,15 @@ XMLTester::parseTest(const TiXmlNode* node)
else if (opName=="intersection")
- GeomAutoPtr gRes(parseGeometry(opRes, "expected"));
+ GeomPtr gRes(parseGeometry(opRes, "expected"));
gRes->normalize();
profile.start();
#ifndef USE_BINARYOP
- GeomAutoPtr gRealRes(gA->intersection(gB));
+ GeomPtr gRealRes(gA->intersection(gB));
#else
- GeomAutoPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opINTERSECTION));
+ GeomPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opINTERSECTION));
#endif
profile.stop();
@@ -886,9 +886,9 @@ XMLTester::parseTest(const TiXmlNode* node)
else if (opName=="union")
- GeomAutoPtr gRealRes;
+ GeomPtr gRealRes;
if ( gB ) {
gRealRes.reset(gA->Union(gB));
@@ -911,13 +911,13 @@ XMLTester::parseTest(const TiXmlNode* node)
else if (opName=="difference")
gRes->normalize();
- GeomAutoPtr gRealRes(gA->difference(gB));
+ GeomPtr gRealRes(gA->difference(gB));
#else
- GeomAutoPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opDIFFERENCE));
+ GeomPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opDIFFERENCE));
#endif
gRealRes->normalize();
@@ -933,13 +933,13 @@ XMLTester::parseTest(const TiXmlNode* node)
else if (opName=="symdifference")
gRes->normalize();
- GeomAutoPtr gRealRes(gA->symDifference(gB));
+ GeomPtr gRealRes(gA->symDifference(gB));
#else
- GeomAutoPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opSYMDIFFERENCE));
+ GeomPtr gRealRes = BinaryOp(gA, gB, overlayOp(OverlayOp::opSYMDIFFERENCE));
#endif
@@ -1033,10 +1033,10 @@ XMLTester::parseTest(const TiXmlNode* node)
geom::Geometry *gT=gA;
if ( ( opArg1 == "B" || opArg1 == "b" ) && gB ) gT=gB;
gRes->normalize();
- GeomAutoPtr gRealRes(gT->getBoundary());
+ GeomPtr gRealRes(gT->getBoundary());
if (gRes->compareTo(gRealRes.get())==0) success=1;
@@ -1053,10 +1053,10 @@ XMLTester::parseTest(const TiXmlNode* node)
gRes->normalize();
- GeomAutoPtr gRealRes(gT->getCentroid());
+ GeomPtr gRealRes(gT->getCentroid());
if ( gRealRes.get() ) gRealRes->normalize();
else gRealRes.reset(factory->createPoint());
@@ -1088,10 +1088,10 @@ XMLTester::parseTest(const TiXmlNode* node)
gRes->normalize();
- GeomAutoPtr gRealRes(gT->convexHull());
+ GeomPtr gRealRes(gT->convexHull());
@@ -1110,12 +1110,12 @@ XMLTester::parseTest(const TiXmlNode* node)
gRes->normalize();
profile.start();
+ GeomPtr gRealRes;
double dist = std::atof(opArg2.c_str());
BufferParameters params;
@@ -1147,12 +1147,12 @@ XMLTester::parseTest(const TiXmlNode* node)
gRes->normalize();
profile.start();
+ GeomPtr gRealRes;
BufferParameters params ;
@@ -1192,12 +1192,12 @@ XMLTester::parseTest(const TiXmlNode* node)
gRes->normalize();
profile.start();
+ GeomPtr gRealRes;
@@ -1229,10 +1229,10 @@ XMLTester::parseTest(const TiXmlNode* node)
gRes->normalize();
- GeomAutoPtr gRealRes(gT->getInteriorPoint());
+ GeomPtr gRealRes(gT->getInteriorPoint());
@@ -1261,7 +1261,7 @@ XMLTester::parseTest(const TiXmlNode* node)
else if (opName=="polygonize")
- GeomAutoPtr gRes(wktreader->read(opRes));
+ GeomPtr gRes(wktreader->read(opRes));
gRes->normalize();
Polygonizer plgnzr;
@@ -1274,7 +1274,7 @@ XMLTester::parseTest(const TiXmlNode* node)
newgeoms->push_back((*polys)[i]);
delete polys;
- GeomAutoPtr gRealRes(factory->createGeometryCollection(newgeoms));
+ GeomPtr gRealRes(factory->createGeometryCollection(newgeoms));
@@ -1289,7 +1289,7 @@ XMLTester::parseTest(const TiXmlNode* node)
else if (opName=="linemerge")
gRes->normalize();
@@ -1298,11 +1298,11 @@ XMLTester::parseTest(const TiXmlNode* node)
LineMerger merger;
merger.add(gT);
- std::auto_ptr< std::vector<geom::LineString *> > lines ( merger.getMergedLineStrings() );
+ std::unique_ptr< std::vector<geom::LineString *> > lines ( merger.getMergedLineStrings() );
std::vector<geom::Geometry *>*newgeoms = new std::vector<geom::Geometry *>(lines->begin(),
lines->end());
@@ -1330,9 +1330,9 @@ XMLTester::parseTest(const TiXmlNode* node)
std::cerr << "Running intersection for areatest" << std::endl;
- GeomAutoPtr gI(gA->intersection(gB));
+ GeomPtr gI(gA->intersection(gB));
#else
- GeomAutoPtr gI = BinaryOp(gA, gB,
+ GeomPtr gI = BinaryOp(gA, gB,
#endif
@@ -1347,9 +1347,9 @@ XMLTester::parseTest(const TiXmlNode* node)
- GeomAutoPtr gDab(gA->difference(gB));
+ GeomPtr gDab(gA->difference(gB));
#else
- GeomAutoPtr gDab = BinaryOp(gA, gB,
+ GeomPtr gDab = BinaryOp(gA, gB,
#endif
@@ -1364,9 +1364,9 @@ XMLTester::parseTest(const TiXmlNode* node)
- GeomAutoPtr gDba(gB->difference(gA));
+ GeomPtr gDba(gB->difference(gA));
#else
- GeomAutoPtr gDba = BinaryOp(gB, gA,
+ GeomPtr gDba = BinaryOp(gB, gA,
#endif
@@ -1381,9 +1381,9 @@ XMLTester::parseTest(const TiXmlNode* node)
- GeomAutoPtr gSD(gA->symDifference(gB));
+ GeomPtr gSD(gA->symDifference(gB));
#else
- GeomAutoPtr gSD = BinaryOp(gA, gB,
+ GeomPtr gSD = BinaryOp(gA, gB,
#endif
@@ -1398,9 +1398,9 @@ XMLTester::parseTest(const TiXmlNode* node)
- GeomAutoPtr gU(gA->Union(gB));
+ GeomPtr gU(gA->Union(gB));
#else
- GeomAutoPtr gU = BinaryOp(gA, gB,
+ GeomPtr gU = BinaryOp(gA, gB,
overlayOp(OverlayOp::opUNION));
#endif
@@ -1663,7 +1663,7 @@ main(int argC, char* argV[])
* XMLTester binary ops invoked using the new BinaryOp template function.
* Revision 1.31 2006/04/07 13:26:38 strk
- * Use of auto_ptr<> to prevent confusing leaks in tester
+ * Use of unique_ptr<> to prevent confusing leaks in tester
* Revision 1.30 2006/03/22 16:01:33 strk
* indexBintree.h header split, classes renamed to match JTS
diff --git a/tests/xmltester/XMLTester.h b/tests/xmltester/XMLTester.h
index a867ed9..1b0db32 100644
--- a/tests/xmltester/XMLTester.h
+++ b/tests/xmltester/XMLTester.h
@@ -51,12 +51,12 @@ private:
geom::Geometry *gT;
bool usePrepared;
- std::auto_ptr<geom::PrecisionModel> pm;
- geom::GeometryFactory::unique_ptr factory;
- std::auto_ptr<io::WKTReader> wktreader;
- std::auto_ptr<io::WKTWriter> wktwriter;
- std::auto_ptr<io::WKBReader> wkbreader;
- std::auto_ptr<io::WKBWriter> wkbwriter;
+ std::unique_ptr<geom::PrecisionModel> pm;
+ geom::GeometryFactory::Ptr factory;
+ std::unique_ptr<io::WKTReader> wktreader;
+ std::unique_ptr<io::WKTWriter> wktwriter;
+ std::unique_ptr<io::WKBReader> wkbreader;
+ std::unique_ptr<io::WKBWriter> wkbwriter;
TiXmlDocument xml;
int verbose;
Summary of changes:
capi/geos_c.cpp | 2 +-
capi/geos_ts_c.cpp | 30 +++---
doc/example.cpp | 2 +-
include/geos/algorithm/Centroid.h | 4 +-
include/geos/geom/BinaryOp.h | 18 ++--
include/geos/geom/CoordinateList.h | 6 +-
include/geos/geom/CoordinateSequence.h | 4 +-
include/geos/geom/Envelope.h | 2 +-
include/geos/geom/Geometry.h | 18 ++--
include/geos/geom/GeometryCollection.h | 6 +-
include/geos/geom/GeometryFactory.h | 69 ++++++------
include/geos/geom/LineSegment.h | 4 +-
include/geos/geom/LineString.h | 12 +--
include/geos/geom/LinearRing.h | 2 +-
include/geos/geom/Point.h | 10 +-
include/geos/geom/Polygon.h | 6 +-
include/geos/geom/util/GeometryTransformer.h | 30 +++---
include/geos/geom/util/SineStarFactory.h | 2 +-
include/geos/geomgraph/GeometryGraph.h | 6 +-
include/geos/index/chain/MonotoneChain.h | 4 +-
include/geos/index/quadtree/Node.h | 14 +--
include/geos/index/strtree/AbstractSTRtree.h | 10 +-
include/geos/index/strtree/SIRtree.h | 4 +-
include/geos/index/strtree/STRtree.h | 8 +-
include/geos/linearref/LinearLocation.h | 4 +-
include/geos/noding/FastNodingValidator.h | 2 +-
include/geos/noding/GeometryNoder.h | 10 +-
include/geos/noding/snapround/HotPixel.h | 4 +-
include/geos/noding/snapround/MCIndexSnapRounder.h | 4 +-
include/geos/operation/IsSimpleOp.h | 6 +-
.../operation/buffer/BufferInputLineSimplifier.h | 6 +-
include/geos/operation/buffer/OffsetCurveBuilder.h | 4 +-
include/geos/operation/distance/DistanceOp.h | 2 +-
.../geos/operation/distance/IndexedFacetDistance.h | 2 +-
.../operation/intersection/RectangleIntersection.h | 8 +-
.../intersection/RectangleIntersectionBuilder.h | 2 +-
include/geos/operation/linemerge/LineSequencer.h | 6 +-
.../geos/operation/overlay/snap/GeometrySnapper.h | 10 +-
.../operation/overlay/snap/LineStringSnapper.h | 2 +-
.../operation/overlay/snap/SnapIfNeededOverlayOp.h | 14 +--
.../geos/operation/overlay/snap/SnapOverlayOp.h | 18 ++--
.../operation/overlay/validate/FuzzyPointLocator.h | 10 +-
.../overlay/validate/OffsetPointGenerator.h | 10 +-
include/geos/operation/relate/RelateComputer.h | 2 +-
.../geos/operation/union/CascadedPolygonUnion.h | 2 +-
include/geos/operation/union/PointGeometryUnion.h | 4 +-
include/geos/operation/union/UnaryUnionOp.h | 16 +--
.../geos/operation/valid/ConnectedInteriorTester.h | 4 +-
include/geos/precision/CommonBitsOp.h | 8 +-
include/geos/precision/GeometryPrecisionReducer.h | 16 +--
include/geos/precision/MinimumClearance.h | 4 +-
.../geos/simplify/DouglasPeuckerLineSimplifier.h | 10 +-
include/geos/simplify/DouglasPeuckerSimplifier.h | 6 +-
include/geos/simplify/LineSegmentIndex.h | 6 +-
include/geos/simplify/TaggedLineString.h | 10 +-
include/geos/simplify/TaggedLineStringSimplifier.h | 4 +-
include/geos/simplify/TaggedLinesSimplifier.h | 6 +-
.../geos/simplify/TopologyPreservingSimplifier.h | 8 +-
.../triangulate/DelaunayTriangulationBuilder.h | 4 +-
include/geos/triangulate/VoronoiDiagramBuilder.h | 12 +--
include/geos/triangulate/quadedge/QuadEdge.h | 6 +-
.../triangulate/quadedge/QuadEdgeSubdivision.h | 26 ++---
include/geos/triangulate/quadedge/Vertex.h | 22 ++--
include/geos/util/GeometricShapeFactory.h | 2 +-
src/algorithm/InteriorPointArea.cpp | 6 +-
src/geom/Geometry.cpp | 22 ++--
src/geom/GeometryCollection.cpp | 6 +-
src/geom/GeometryFactory.cpp | 40 +++----
src/geom/LineSegment.cpp | 4 +-
src/geom/LineString.cpp | 10 +-
src/geom/LinearRing.cpp | 4 +-
src/geom/Point.cpp | 6 +-
src/geom/Polygon.cpp | 4 +-
src/geom/util/GeometryTransformer.cpp | 73 ++++++-------
src/geom/util/SineStarFactory.cpp | 12 +--
src/geomgraph/GeometryGraph.cpp | 6 +-
src/geomgraph/PlanarGraph.cpp | 4 +-
src/index/chain/MonotoneChain.cpp | 4 +-
src/index/quadtree/Node.cpp | 31 +++---
src/index/quadtree/Root.cpp | 6 +-
src/index/strtree/AbstractSTRtree.cpp | 14 +--
src/index/strtree/BoundablePair.cpp | 2 +-
src/index/strtree/SIRtree.cpp | 10 +-
src/index/strtree/STRtree.cpp | 20 ++--
src/io/WKTReader.cpp | 2 +-
src/linearref/LinearLocation.cpp | 6 +-
src/noding/GeometryNoder.cpp | 12 +--
src/noding/snapround/HotPixel.cpp | 2 +-
src/noding/snapround/MCIndexSnapRounder.cpp | 2 +-
src/operation/IsSimpleOp.cpp | 2 +-
src/operation/buffer/BufferBuilder.cpp | 20 ++--
src/operation/buffer/BufferInputLineSimplifier.cpp | 8 +-
src/operation/buffer/BufferOp.cpp | 2 +-
src/operation/buffer/OffsetCurveBuilder.cpp | 24 ++---
src/operation/buffer/OffsetCurveSetBuilder.cpp | 2 +-
.../distance/FacetSequenceTreeBuilder.cpp | 6 +-
src/operation/distance/IndexedFacetDistance.cpp | 2 +-
.../intersection/RectangleIntersection.cpp | 8 +-
.../intersection/RectangleIntersectionBuilder.cpp | 6 +-
src/operation/linemerge/LineMergeGraph.cpp | 2 +-
src/operation/linemerge/LineSequencer.cpp | 4 +-
src/operation/overlay/OverlayOp.cpp | 2 +-
src/operation/overlay/snap/GeometrySnapper.cpp | 30 +++---
src/operation/overlay/snap/LineStringSnapper.cpp | 2 +-
.../overlay/snap/SnapIfNeededOverlayOp.cpp | 8 +-
src/operation/overlay/snap/SnapOverlayOp.cpp | 4 +-
.../overlay/validate/FuzzyPointLocator.cpp | 12 +--
.../overlay/validate/OffsetPointGenerator.cpp | 7 +-
.../overlay/validate/OverlayResultValidator.cpp | 14 +--
src/operation/relate/RelateComputer.cpp | 10 +-
src/operation/sharedpaths/SharedPathsOp.cpp | 2 +-
src/operation/union/CascadedPolygonUnion.cpp | 30 +++---
src/operation/union/CascadedUnion.cpp | 18 ++--
src/operation/union/PointGeometryUnion.cpp | 12 +--
src/operation/union/UnaryUnionOp.cpp | 30 +++---
src/operation/valid/ConsistentAreaTester.cpp | 4 +-
src/operation/valid/IndexedNestedRingTester.h | 2 +-
src/precision/CommonBitsOp.cpp | 22 ++--
src/precision/EnhancedPrecisionOp.cpp | 2 +-
src/precision/GeometryPrecisionReducer.cpp | 22 ++--
src/precision/MinimumClearance.cpp | 8 +-
src/simplify/DouglasPeuckerLineSimplifier.cpp | 4 +-
src/simplify/DouglasPeuckerSimplifier.cpp | 36 +++----
src/simplify/LineSegmentIndex.cpp | 13 +--
src/simplify/TaggedLineString.cpp | 12 +--
src/simplify/TaggedLineStringSimplifier.cpp | 19 ++--
src/simplify/TopologyPreservingSimplifier.cpp | 27 +++--
src/triangulate/DelaunayTriangulationBuilder.cpp | 4 +-
src/triangulate/VoronoiDiagramBuilder.cpp | 31 +++---
src/triangulate/quadedge/QuadEdge.cpp | 12 +--
src/triangulate/quadedge/QuadEdgeSubdivision.cpp | 82 +++++++--------
src/triangulate/quadedge/Vertex.cpp | 26 ++---
src/util/GeometricShapeFactory.cpp | 8 +-
tests/bigtest/TestSweepLineSpeed.cpp | 2 +-
tests/bigtest/bug234.cpp | 2 +-
.../operation/buffer/IteratedBufferStressTest.cpp | 2 +-
.../predicate/RectangleIntersectsPerfTest.cpp | 8 +-
.../CGAlgorithms/computeOrientationTest.cpp | 4 +-
tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp | 2 +-
.../algorithm/CGAlgorithms/isPointInRingTest.cpp | 2 +-
.../unit/algorithm/CGAlgorithms/signedAreaTest.cpp | 2 +-
tests/unit/algorithm/ConvexHullTest.cpp | 51 ++++-----
tests/unit/algorithm/InteriorPointAreaTest.cpp | 2 +-
tests/unit/algorithm/MinimumDiameterTest.cpp | 4 +-
tests/unit/algorithm/PointLocatorTest.cpp | 6 +-
.../unit/algorithm/RobustLineIntersectionTest.cpp | 8 +-
tests/unit/algorithm/RobustLineIntersectorTest.cpp | 8 +-
.../distance/DiscreteFrechetDistanceTest.cpp | 6 +-
.../distance/DiscreteHausdorffDistanceTest.cpp | 6 +-
tests/unit/capi/GEOSContainsTest.cpp | 8 +-
tests/unit/capi/GEOSPreparedGeometryTest.cpp | 10 +-
tests/unit/geom/CoordinateArraySequenceTest.cpp | 2 +-
tests/unit/geom/CoordinateListTest.cpp | 4 +-
tests/unit/geom/Geometry/clone.cpp | 32 +++---
tests/unit/geom/Geometry/coversTest.cpp | 20 ++--
tests/unit/geom/Geometry/equalsTest.cpp | 10 +-
tests/unit/geom/Geometry/normalize.cpp | 8 +-
tests/unit/geom/Geometry/touchesTest.cpp | 32 +++---
tests/unit/geom/GeometryComponentFilterTest.cpp | 4 +-
tests/unit/geom/GeometryFactoryTest.cpp | 16 +--
tests/unit/geom/GeometryFilterTest.cpp | 4 +-
tests/unit/geom/LineStringTest.cpp | 4 +-
tests/unit/geom/LinearRingTest.cpp | 2 +-
tests/unit/geom/MultiPointTest.cpp | 4 +-
tests/unit/geom/PointTest.cpp | 6 +-
tests/unit/geom/PolygonTest.cpp | 6 +-
.../geom/prep/PreparedGeometry/touchesTest.cpp | 4 +-
.../unit/geom/prep/PreparedGeometryFactoryTest.cpp | 2 +-
tests/unit/geom/util/GeometryExtracterTest.cpp | 4 +-
tests/unit/io/WKBReaderTest.cpp | 4 +-
tests/unit/io/WKBWriterTest.cpp | 2 +-
tests/unit/io/WKTReaderTest.cpp | 6 +-
tests/unit/io/WKTWriterTest.cpp | 6 +-
tests/unit/linearref/LengthIndexedLineTest.cpp | 4 +-
tests/unit/noding/BasicSegmentStringTest.cpp | 4 +-
tests/unit/noding/NodedSegmentStringTest.cpp | 6 +-
tests/unit/noding/OrientedCoordinateArray.cpp | 6 +-
tests/unit/noding/SegmentNodeTest.cpp | 4 +-
tests/unit/noding/SegmentPointComparatorTest.cpp | 4 +-
.../noding/snapround/MCIndexSnapRounderTest.cpp | 6 +-
tests/unit/operation/IsSimpleOpTest.cpp | 8 +-
tests/unit/operation/buffer/BufferBuilderTest.cpp | 4 +-
tests/unit/operation/buffer/BufferOpTest.cpp | 4 +-
tests/unit/operation/distance/DistanceOpTest.cpp | 6 +-
.../intersection/RectangleIntersectionTest.cpp | 2 +-
tests/unit/operation/linemerge/LineMergerTest.cpp | 2 +-
.../unit/operation/linemerge/LineSequencerTest.cpp | 2 +-
.../unit/operation/overlay/OverlayOpUnionTest.cpp | 4 +-
.../operation/overlay/snap/GeometrySnapperTest.cpp | 18 ++--
.../overlay/snap/LineStringSnapperTest.cpp | 18 ++--
.../overlay/validate/FuzzyPointLocatorTest.cpp | 2 +-
.../overlay/validate/OffsetPointGeneratorTest.cpp | 24 ++---
.../validate/OverlayResultValidatorTest.cpp | 2 +-
tests/unit/operation/polygonize/PolygonizeTest.cpp | 4 +-
.../operation/sharedpaths/SharedPathsOpTest.cpp | 2 +-
.../operation/union/CascadedPolygonUnionTest.cpp | 10 +-
tests/unit/operation/union/UnaryUnionOpTest.cpp | 4 +-
tests/unit/operation/valid/IsValidTest.cpp | 4 +-
tests/unit/operation/valid/ValidClosedRingTest.cpp | 4 +-
.../valid/ValidSelfTouchingRingFormingHoleTest.cpp | 4 +-
.../precision/GeometryPrecisionReducerTest.cpp | 6 +-
.../SimpleGeometryPrecisionReducerTest.cpp | 4 +-
.../unit/simplify/DouglasPeuckerSimplifierTest.cpp | 2 +-
.../simplify/TopologyPreservingSimplifierTest.cpp | 4 +-
tests/unit/triangulate/DelaunayTest.cpp | 4 +-
tests/unit/triangulate/VoronoiTest.cpp | 10 +-
.../quadedge/QuadEdgeSubdivisionTest.cpp | 18 ++--
tests/unit/triangulate/quadedge/QuadEdgeTest.cpp | 22 ++--
.../unit/util/UniqueCoordinateArrayFilterTest.cpp | 6 +-
tests/unit/utility.h | 17 ---
tests/xmltester/BufferResultMatcher.cpp | 4 +-
tests/xmltester/SimpleWKTTester.cpp | 2 +-
tests/xmltester/SingleSidedBufferResultMatcher.cpp | 2 +-
tests/xmltester/XMLTester.cpp | 110 ++++++++++----------
tests/xmltester/XMLTester.h | 12 +--
215 files changed, 1076 insertions(+), 1108 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
