[geos-commits] [SCM] geos branch master updated. c5892faf4bdc3777420a638ed265d1e521d074b7
Thu Sep 7 11:52:22 PDT 2017
the project "geos".
       via  c5892faf4bdc3777420a638ed265d1e521d074b7 (commit)
       via  6b236e95faf8a3f52d2ee4158d1e7f57829fe42f (commit)
      from  f1c2215d560473fec89c0b047f299e9028be6533 (commit)
revisions in full, below.
commit c5892faf4bdc3777420a638ed265d1e521d074b7
Author: Mateusz Loskot <mateusz at loskot.net>
Date:   Thu Sep 7 20:51:55 2017 +0200
    [CMake] Add tests/perf targets to build configuration
diff --git a/tests/CMakeLists.txt b/tests/CMakeLists.txt
index b772b01..fc8eee6 100644
--- a/tests/CMakeLists.txt
+++ b/tests/CMakeLists.txt
@@ -6,7 +6,7 @@
 # This is free software; you can redistribute and/or modify it under
 # the terms of the GNU Lesser General Public Licence as published
-# by the Free Software Foundation.
+# by the Free Software Foundation.
 # See the COPYING file for more information.
@@ -14,3 +14,4 @@
 add_subdirectory(unit)
 add_subdirectory(xmltester)
 add_subdirectory(bigtest)
+add_subdirectory(perf)
diff --git a/tests/perf/CMakeLists.txt b/tests/perf/CMakeLists.txt
new file mode 100644
index 0000000..034c6eb
--- /dev/null
+++ b/tests/perf/CMakeLists.txt
@@ -0,0 +1,34 @@
+# CMake configuration for GEOS perf tests
+# Copyright (C) 2017 Mateusz Loskot <mateusz at loskot.net>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU Lesser General Public Licence as published
+# See the COPYING file for more information.
+set(STATUS_MESSAGE "Enable GEOS performance tests build")
+set(STATUS_RESULT "OFF")
+if(GEOS_ENABLE_TESTS)
+  include_directories(${CMAKE_CURRENT_SOURCE_DIR})
+  add_executable(perf_class_sizes ClassSizes.cpp)
+  target_link_libraries(perf_class_sizes geos)
+  add_test(perf_class_sizes
+    ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_class_sizes)
+  add_subdirectory(operation)
+  add_subdirectory(capi)
+  set(STATUS_RESULT "ON")
+endif()
+message(STATUS "${STATUS_MESSAGE} - ${STATUS_RESULT}")
diff --git a/tests/perf/capi/CMakeLists.txt b/tests/perf/capi/CMakeLists.txt
index 0000000..15e5c78
--- /dev/null
+++ b/tests/perf/capi/CMakeLists.txt
@@ -0,0 +1,18 @@
+# CMake configuration for GEOS perf/capi tests
+add_executable(perf_memleak_mp_prep memleak_mp_prep.c)
+target_link_libraries(perf_memleak_mp_prep geos_c)
+add_test(perf_memleak_mp_prep ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_memleak_mp_prep)
diff --git a/tests/perf/operation/CMakeLists.txt b/tests/perf/operation/CMakeLists.txt
index 0000000..9a23175
--- /dev/null
+++ b/tests/perf/operation/CMakeLists.txt
@@ -0,0 +1,15 @@
+# CMake configuration for GEOS perf/operation tests
+add_subdirectory(buffer)
+add_subdirectory(predicate)
diff --git a/tests/perf/operation/buffer/CMakeLists.txt b/tests/perf/operation/buffer/CMakeLists.txt
index 0000000..b6fc3e4
--- /dev/null
+++ b/tests/perf/operation/buffer/CMakeLists.txt
@@ -0,0 +1,21 @@
+# CMake configuration for GEOS perf/operation/buffer tests
+include_directories(${CMAKE_CURRENT_SOURCE_DIR}/src/io/markup)
+add_executable(perf_iterated_buffer IteratedBufferStressTest.cpp)
+target_link_libraries(perf_iterated_buffer geos)
+add_test(perf_iterated_buffer
+  ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_iterated_buffer)
diff --git a/tests/perf/operation/predicate/CMakeLists.txt b/tests/perf/operation/predicate/CMakeLists.txt
index 0000000..da25f8f
--- /dev/null
+++ b/tests/perf/operation/predicate/CMakeLists.txt
@@ -0,0 +1,21 @@
+# CMake configuration for GEOS perf/operation/predicate tests
+add_executable(perf_rectangle_intersects RectangleIntersectsPerfTest.cpp)
+target_link_libraries(perf_rectangle_intersects geos)
+add_test(perf_rectangle_intersects
+  ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_rectangle_intersects)
diff --git a/tests/unit/CMakeLists.txt b/tests/unit/CMakeLists.txt
index 4d26190..25047f1 100644
--- a/tests/unit/CMakeLists.txt
+++ b/tests/unit/CMakeLists.txt
@@ -6,20 +6,20 @@
-set(STATUS_MESSAGE "Enable GEOSuUnit Tests build")
+set(STATUS_MESSAGE "Enable GEOS unit tests build")
   include_directories(${CMAKE_SOURCE_DIR}/capi)
   file(GLOB_RECURSE geos_unit_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
   add_executable(geos_unit ${geos_unit_SOURCES})
   if(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK)
     target_link_libraries(geos_unit GEOS)
@@ -37,4 +37,4 @@ message(STATUS "${STATUS_MESSAGE} - ${STATUS_RESULT}")
 # Group source files for IDE source explorers (e.g. Visual Studio)
-GenerateSourceGroups(tests/unit)
\ No newline at end of file
+GenerateSourceGroups(tests/unit)
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 3ee3eea..a300dce 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -6,12 +6,12 @@
-set(STATUS_MESSAGE "Enable GEOS XML Tester build")
+set(STATUS_MESSAGE "Enable GEOS XML tests build")
commit 6b236e95faf8a3f52d2ee4158d1e7f57829fe42f
Date:   Thu Sep 7 20:48:42 2017 +0200
    Add GEOS_DLL to opeartor<< functions in Profiler
diff --git a/include/geos/profiler.h b/include/geos/profiler.h
index 53595d5..377703e 100644
--- a/include/geos/profiler.h
+++ b/include/geos/profiler.h
@@ -177,10 +177,10 @@ public:
 /** \brief Return a string representing the Profile */
-std::ostream& operator<< (std::ostream& os, const Profile&);
+GEOS_DLL std::ostream& operator<< (std::ostream& os, const Profile&);
 /** \brief Return a string representing the Profiler */
-std::ostream& operator<< (std::ostream& os, const Profiler&);
+GEOS_DLL std::ostream& operator<< (std::ostream& os, const Profiler&);
 } // namespace geos::util
 } // namespace geos
Summary of changes:
 include/geos/profiler.h                       |    4 +--
 tests/CMakeLists.txt                          |    3 ++-
 tests/perf/CMakeLists.txt                     |   34 +++++++++++++++++++++++++
 tests/perf/capi/CMakeLists.txt                |   18 +++++++++++++
 tests/perf/operation/CMakeLists.txt           |   15 +++++++++++
 tests/perf/operation/buffer/CMakeLists.txt    |   21 +++++++++++++++
 tests/perf/operation/predicate/CMakeLists.txt |   21 +++++++++++++++
 tests/unit/CMakeLists.txt                     |   10 ++++----
 tests/xmltester/CMakeLists.txt                |    4 +--
 9 files changed, 120 insertions(+), 10 deletions(-)
 create mode 100644 tests/perf/CMakeLists.txt
 create mode 100644 tests/perf/capi/CMakeLists.txt
 create mode 100644 tests/perf/operation/CMakeLists.txt
 create mode 100644 tests/perf/operation/buffer/CMakeLists.txt
 create mode 100644 tests/perf/operation/predicate/CMakeLists.txt
hooks/post-receive
geos
More information about the geos-commits mailing list
