[geos-commits] [SCM] geos branch master updated. e43016dd7397711e5bd64cdba92f2b6f671c4fbc
git at osgeo.org
git at osgeo.org
Thu Sep 7 12:34:58 PDT 2017
the project "geos".
via e43016dd7397711e5bd64cdba92f2b6f671c4fbc (commit)
from c5892faf4bdc3777420a638ed265d1e521d074b7 (commit)
revisions in full, below.
commit e43016dd7397711e5bd64cdba92f2b6f671c4fbc
Author: Mateusz Loskot <mateusz at loskot.net>
Date: Thu Sep 7 21:34:51 2017 +0200
[CMake] Rename tests targets using test_ prefix
diff --git a/tests/bigtest/CMakeLists.txt b/tests/bigtest/CMakeLists.txt
index 9c23383..9734b38 100644
--- a/tests/bigtest/CMakeLists.txt
+++ b/tests/bigtest/CMakeLists.txt
@@ -6,7 +6,7 @@
# This is free software; you can redistribute and/or modify it under
# the terms of the GNU Lesser General Public Licence as published
-# by the Free Software Foundation.
+# by the Free Software Foundation.
# See the COPYING file for more information.
@@ -19,26 +19,26 @@ if(GEOS_ENABLE_TESTS)
include_directories(${CMAKE_CURRENT_SOURCE_DIR})
include_directories(${CMAKE_CURRENT_SOURCE_DIR}/src/io/markup)
- add_executable(bug234 bug234.cpp)
+ add_executable(test_bug234 bug234.cpp)
- if(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK)
- target_link_libraries(bug234 GEOS)
- else()
- target_link_libraries(bug234 geos)
- endif()
+ if(APPLE AND GEOS_ENABLE_MACOSX_FRAMEWORK)
+ target_link_libraries(test_bug234 GEOS)
+ else()
+ target_link_libraries(test_bug234 geos)
+ endif()
- add_executable(TestSweepLineSpeed
+ add_executable(test_sweep_line_speed
TestSweepLineSpeed.cpp
GeometryTestFactory.cpp
bigtest.h)
- target_link_libraries(TestSweepLineSpeed GEOS)
+ target_link_libraries(test_sweep_line_speed GEOS)
else()
- target_link_libraries(TestSweepLineSpeed geos)
+ target_link_libraries(test_sweep_line_speed geos)
endif()
- add_test(bug234 ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/bug234)
- add_test(TestSweepLineSpeed ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/TestSweepLineSpeed)
+ add_test(test_bug234 ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_bug234)
+ add_test(test_sweep_line_speed ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_sweep_line_speed)
set(STATUS_RESULT "ON")
endif()
diff --git a/tests/unit/CMakeLists.txt b/tests/unit/CMakeLists.txt
index 25047f1..8bfc898 100644
--- a/tests/unit/CMakeLists.txt
+++ b/tests/unit/CMakeLists.txt
@@ -20,14 +20,15 @@ if(GEOS_ENABLE_TESTS)
file(GLOB_RECURSE geos_unit_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
- add_executable(geos_unit ${geos_unit_SOURCES})
+ add_executable(test_geos_unit ${geos_unit_SOURCES})
- target_link_libraries(geos_unit GEOS)
+ target_link_libraries(test_geos_unit GEOS)
else()
- target_link_libraries(geos_unit geos geos_c)
+ target_link_libraries(test_geos_unit geos geos_c)
endif()
- add_test(geos_unit ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/geos_unit)
+ add_test(test_geos_unit ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_geos_unit)
endif()
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index a300dce..1eebe10 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -30,18 +30,20 @@ if(GEOS_ENABLE_TESTS)
BufferResultMatcher.cpp
SingleSidedBufferResultMatcher.cpp)
- add_executable(simplewkttester ${simplewkttester_SOURCES})
+ add_executable(test_simplewkttester ${simplewkttester_SOURCES})
- target_link_libraries(simplewkttester GEOS)
+ target_link_libraries(test_simplewkttester GEOS)
else()
- target_link_libraries(simplewkttester geos)
+ target_link_libraries(test_simplewkttester geos)
endif()
- add_executable(xmltester ${xmltester_SOURCES})
+ add_executable(test_xmltester ${xmltester_SOURCES})
- target_link_libraries(xmltester GEOS)
+ target_link_libraries(test_xmltester GEOS)
else()
- target_link_libraries(xmltester geos)
+ target_link_libraries(test_xmltester geos)
endif()
set(XMLTESTS_DIR ${CMAKE_CURRENT_SOURCE_DIR}/tests)
@@ -105,7 +107,7 @@ if(GEOS_ENABLE_TESTS)
${XMLTESTS_DIR}/safe/16595.xml
${XMLTESTS_DIR}/safe/16596.xml)
- add_test(xmltester ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/xmltester ${SAVE_XMLTESTS})
+ add_test(test_xmltester ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/test_xmltester ${SAVE_XMLTESTS})
endif()
Summary of changes:
tests/bigtest/CMakeLists.txt | 24 ++++++++++++------------
tests/unit/CMakeLists.txt | 9 +++++----
tests/xmltester/CMakeLists.txt | 16 +++++++++-------
3 files changed, 26 insertions(+), 23 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
