[geos-commits] [SCM] GEOS branch svn-3.6 updated. c79068d2c53f0219100e74eafde1c55d6d127ca5
git at osgeo.org
git at osgeo.org
Thu Aug 9 14:58:16 PDT 2018
the project "GEOS".
The branch, svn-3.6 has been updated
via c79068d2c53f0219100e74eafde1c55d6d127ca5 (commit)
from 80c130478518bce6543c51cb8e217d3c09264dad (commit)
revisions in full, below.
commit c79068d2c53f0219100e74eafde1c55d6d127ca5
Author: Regina Obe <lr at pcorp.us>
Date: Thu Aug 9 17:58:18 2018 -0400
Increment version numbers to next release milestones
diff --git a/CMakeLists.txt b/CMakeLists.txt
index b5135b6..81ccaa3 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -29,7 +29,7 @@ set(CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake/modules")
# GEOS C++ library SONAME will use these encoding ABI break at every release
set(VERSION_MAJOR 3)
set(VERSION_MINOR 6)
-set(VERSION_PATCH 3)
+set(VERSION_PATCH 4dev)
set(VERSION "${VERSION_MAJOR}.${VERSION_MINOR}.${VERSION_PATCH}")
# JTS_PORT is the version of JTS this release is bound to
@@ -38,7 +38,7 @@ message(STATUS "Setting GEOS version ${VERSION} as port of JTS ${JTS_PORT}")
# GEOS C API version
set(CAPI_INTERFACE_CURRENT 11)
-set(CAPI_INTERFACE_REVISION 3)
+set(CAPI_INTERFACE_REVISION 4)
set(CAPI_INTERFACE_AGE 10)
math(EXPR CAPI_VERSION_MAJOR "${CAPI_INTERFACE_CURRENT} - ${CAPI_INTERFACE_AGE}")
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index ccabb6b..4988ed8 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -60,8 +60,8 @@ extern "C" {
#include <geos/version.h>
#define GEOS_CAPI_VERSION_MAJOR 1
#define GEOS_CAPI_VERSION_MINOR 10
-#define GEOS_CAPI_VERSION_PATCH 3
-#define GEOS_CAPI_VERSION "3.6.3-CAPI-1.10.3"
+#define GEOS_CAPI_VERSION_PATCH 4
+#define GEOS_CAPI_VERSION "3.6.4-CAPI-1.10.4"
#else
#ifndef GEOS_VERSION_MAJOR
#define GEOS_VERSION_MAJOR @VERSION_MAJOR@
diff --git a/configure.ac b/configure.ac
index 4405db0..15f9ece 100644
--- a/configure.ac
+++ b/configure.ac
@@ -15,7 +15,7 @@ JTS_PORT=1.13.0
dnl -- Version info for the CAPI
CAPI_INTERFACE_CURRENT=11
-CAPI_INTERFACE_REVISION=3
+CAPI_INTERFACE_REVISION=4
CAPI_INTERFACE_AGE=10
dnl
@@ -24,7 +24,7 @@ dnl -- encoding ABI break at every release
dnl
VERSION_MAJOR=3
VERSION_MINOR=6
-VERSION_PATCH=3
+VERSION_PATCH=4dev
VERSION="$VERSION_MAJOR.$VERSION_MINOR.$VERSION_PATCH"
dnl CAPI_VERSION_MAJOR=$(($CAPI_INTERFACE_CURRENT-$CAPI_INTERFACE_AGE))
Summary of changes:
CMakeLists.txt | 4 ++--
capi/geos_c.h.in | 4 ++--
configure.ac | 4 ++--
3 files changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
