[geos-commits] [SCM] GEOS branch master updated. 1e66be587d92ac281d85598a2f6c79c22e912a20
git at osgeo.org
git at osgeo.org
Mon Aug 13 04:20:13 PDT 2018
the project "GEOS".
via 1e66be587d92ac281d85598a2f6c79c22e912a20 (commit)
via ea7c7d80e70ed5719c3bf7a17df93f8053a0c744 (commit)
from 1fc7f585ed822ebbb685ba848f9537691d864697 (commit)
revisions in full, below.
commit 1e66be587d92ac281d85598a2f6c79c22e912a20
Merge: 1fc7f58 ea7c7d8
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Aug 13 07:19:25 2018 -0400
Merge branch 'trac-782'
commit ea7c7d80e70ed5719c3bf7a17df93f8053a0c744
Date: Tue Aug 7 20:24:25 2018 -0400
Fix predicate crash with empty collection components
Fixes #782
Closes https://github.com/libgeos/geos/pull/114
diff --git a/include/geos/algorithm/PointLocator.h b/include/geos/algorithm/PointLocator.h
index 11fef98..9bbe0a4 100644
--- a/include/geos/algorithm/PointLocator.h
+++ b/include/geos/algorithm/PointLocator.h
@@ -13,7 +13,7 @@
- * Last port: algorithm/PointLocator.java r320 (JTS-1.12)
+ * Last port: algorithm/PointLocator.java 95fbe34b (JTS-1.15.2-SNAPSHOT)
@@ -51,9 +51,8 @@ namespace algorithm { // geos::algorithm
* Notes:
* - instances of this class are not reentrant.
* - LinearRing objects do not enclose any area
- * points inside the ring are still in the EXTERIOR of the ring.
+ * (points inside the ring are still in the EXTERIOR of the ring.)
- * Last port: algorithm/PointLocator.java rev. 1.26 (JTS-1.7+)
class GEOS_DLL PointLocator {
public:
@@ -62,11 +61,9 @@ public:
* Computes the topological relationship (Location) of a single point
- * to a Geometry.
- * It handles both single-element
- * and multi-element Geometries.
- * The algorithm for multi-part Geometries
- * takes into account the boundaryDetermination rule.
+ * to a Geometry. It handles both single-element and multi-element Geometries.
+ * The algorithm for multi-part Geometriestakes into account the SFS
+ * Boundary Determination rule.
* @return the Location of the point relative to the input Geometry
diff --git a/src/algorithm/PointLocator.cpp b/src/algorithm/PointLocator.cpp
index 1ee0c5f..2249280 100644
--- a/src/algorithm/PointLocator.cpp
+++ b/src/algorithm/PointLocator.cpp
@@ -13,7 +13,7 @@
@@ -128,6 +128,9 @@ PointLocator::locate(const Coordinate& p, const Point *pt)
int
PointLocator::locate(const Coordinate& p, const LineString *l)
+ if (!l->getEnvelopeInternal()->intersects(p))
+ return Location::EXTERIOR;
const CoordinateSequence* pt=l->getCoordinatesRO();
if (! l->isClosed()) {
if ((p==pt->getAt(0)) || (p==pt->getAt(pt->getSize()-1))) {
@@ -143,7 +146,9 @@ PointLocator::locate(const Coordinate& p, const LineString *l)
int
PointLocator::locateInPolygonRing(const Coordinate& p, const LinearRing *ring)
- // can this test be folded into isPointInRing ?
+ if (!ring->getEnvelopeInternal()->intersects(p)) {
const CoordinateSequence *cl = ring->getCoordinatesRO();
diff --git a/tests/unit/capi/GEOSIntersectsTest.cpp b/tests/unit/capi/GEOSIntersectsTest.cpp
index 1bb8ab4..bda143a 100644
--- a/tests/unit/capi/GEOSIntersectsTest.cpp
+++ b/tests/unit/capi/GEOSIntersectsTest.cpp
@@ -158,5 +158,18 @@ namespace tut
+ // Test for #782 (collection with empty components)
+ template<>
+ template<>
+ void object::test<6>()
+ geom1_ = GEOSGeomFromWKT("LINESTRING(10 0, 0 0, 0 10)");
+ geom2_ = GEOSGeomFromWKT("MULTILINESTRING((10 -1,-1 10),EMPTY)");
+ char r1 = GEOSIntersects(geom1_, geom2_);
+ ensure_equals(r1, 1);
} // namespace tut
Summary of changes:
include/geos/algorithm/PointLocator.h | 13 +++++--------
src/algorithm/PointLocator.cpp | 9 +++++++--
tests/unit/capi/GEOSIntersectsTest.cpp | 13 +++++++++++++
3 files changed, 25 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits
