[geos-commits] [SCM] GEOS branch master updated. 3db733ddd1b6c4c407561023291cd648741ea79d
git at osgeo.org
git at osgeo.org
Fri Aug 17 19:53:30 PDT 2018
the project "GEOS".
via 3db733ddd1b6c4c407561023291cd648741ea79d (commit)
via 195dba53b722ed250715f7690c6cafc69627e311 (commit)
from 1e66be587d92ac281d85598a2f6c79c22e912a20 (commit)
revisions in full, below.
commit 3db733ddd1b6c4c407561023291cd648741ea79d
Merge: 195dba5 1e66be5
Author: Regina Obe <lr at pcorp.us>
Date: Fri Aug 17 22:52:49 2018 -0400
Merge branch 'master' of https://git.osgeo.org/gitea/geos/geos
commit 195dba53b722ed250715f7690c6cafc69627e311
Date: Fri Aug 17 22:52:34 2018 -0400
Take out the C++11 enforcement causing issue with finite - see #914. Also take out dev from pathc, its already in there
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 45a1a45..6bfe075 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -31,7 +31,9 @@ list(APPEND CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake/modules")
# Set C++ standard
-set(CMAKE_CXX_STANDARD 11)
+##remarking out the CMAKE_CXX_STANDARD 11 for now cause mingw64 gcc 8.1 doesn't like it
+## see ticket https://trac.osgeo.org/geos/ticket/914
+#set(CMAKE_CXX_STANDARD 11)
set(CMAKE_CXX_STANDARD_REQUIRED ON)
set(CMAKE_CXX_EXTENSIONS OFF)
@@ -43,7 +45,6 @@ message(STATUS "Setting C++ requirement to C++${CMAKE_CXX_STANDARD}")
# GEOS release version
# GEOS C++ library SONAME will use these encoding ABI break at every release
-set(GEOS_VERSION_PATCH "${GEOS_VERSION_PATCH}dev")
set(GEOS_VERSION "${GEOS_VERSION_MAJOR}.${GEOS_VERSION_MINOR}.${GEOS_VERSION_PATCH}")
set(VERSION "${GEOS_VERSION}")
Summary of changes:
CMakeLists.txt | 5 +++--
1 file changed, 3 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
